path: root/tools
2014-06-04perf probe: Fix perf probe to find correct variable DIEMasami Hiramatsu
Fix perf probe to find correct variable DIE which has location or external instance by tracking down the lexical blocks. Current die_find_variable() expects that the all variable DIEs which has DW_TAG_variable have a location. However, since recent dwarf information may have declaration variable DIEs at the entry of function (subprogram), die_find_variable() returns it. To solve this problem, it must track down the DIE tree to find a DIE which has an actual location or a reference for external instance. e.g. finding a DIE which origin is <0xdc73>; <1><11496>: Abbrev Number: 95 (DW_TAG_subprogram) <11497> DW_AT_abstract_origin: <0xdc42> <1149b> DW_AT_low_pc : 0x1850 [...] <2><114cc>: Abbrev Number: 119 (DW_TAG_variable) <- this is a declaration <114cd> DW_AT_abstract_origin: <0xdc73> <2><114d1>: Abbrev Number: 119 (DW_TAG_variable) [...] <3><115a7>: Abbrev Number: 105 (DW_TAG_lexical_block) <115a8> DW_AT_ranges : 0xaa0 <4><115ac>: Abbrev Number: 96 (DW_TAG_variable) <- this has a location <115ad> DW_AT_abstract_origin: <0xdc73> <115b1> DW_AT_location : 0x486c (location list) Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Acked-by: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20140529121930.30879.87092.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-06-04perf probe: Fix a segfault if asked for variable it doesn't findMasami Hiramatsu
Fix a segfault bug by asking for variable it doesn't find. Since the convert_variable() didn't handle error code returned from convert_variable_location(), it just passed an incomplete variable field and then a segfault was occurred when formatting the field. This fixes that bug by handling success code correctly in convert_variable(). Other callers of convert_variable_location() are correctly checking the return code. This bug was introduced by following commit. But another hidden erroneous error handling has been there previously (-ENOMEM case). commit 3d918a12a1b3088ac16ff37fa52760639d6e2403 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20140529105232.28251.30447.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-11Merge branch 'liblockdep-fixes-3.15' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into perf/urgent Pull liblockdep fixes from Sasha Levin, to fix two build related bugs. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-08tools/liblockdep: Remove all build files when doing make cleanSasha Levin
We forgot to remove the shared library with the version number when 'make clean' ran, fix the clean pattern. Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-05-08tools/liblockdep: Build liblockdep from tools/MakefileS. Lockwood-Childs
add targets to build liblockdep with make -C tools liblockdep like the way other stuff under tools/ can be built Signed-off-by: S. Lockwood-Childs <sjl@vctlabs.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-05-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) e1000e computes header length incorrectly wrt vlans, fix from Vlad Yasevich. 2) ns_capable() check in sock_diag netlink code, from Andrew Lutomirski. 3) Fix invalid queue pairs handling in virtio_net, from Amos Kong. 4) Checksum offloading busted in sxgbe driver due to incorrect descriptor layout, fix from Byungho An. 5) Fix build failure with SMC_DEBUG set to 2 or larger, from Zi Shen Lim. 6) Fix uninitialized A and X registers in BPF interpreter, from Alexei Starovoitov. 7) Fix arch dependencies of candence driver. 8) Fix netlink capabilities checking tree-wide, from Eric W Biederman. 9) Don't dump IFLA_VF_PORTS if netlink request didn't ask for it in IFLA_EXT_MASK, from David Gibson. 10) IPV6 FIB dump restart doesn't handle table changes that happen meanwhile, causing the code to loop forever or emit dups, fix from Kumar Sandararajan. 11) Memory leak on VF removal in bnx2x, from Yuval Mintz. 12) Bug fixes for new Altera TSE driver from Vince Bridgers. 13) Fix route lookup key in SCTP, from Xugeng Zhang. 14) Use BH blocking spinlocks in SLIP, as per a similar fix to CAN/SLCAN driver. From Oliver Hartkopp. 15) TCP doesn't bump retransmit counters in some code paths, fix from Eric Dumazet. 16) Clamp delayed_ack in tcp_cubic to prevent theoretical divides by zero. Fix from Liu Yu. 17) Fix locking imbalance in error paths of HHF packet scheduler, from John Fastabend. 18) Properly reference the transport module when vsock_core_init() runs, from Andy King. 19) Fix buffer overflow in cdc_ncm driver, from Bjørn Mork. 20) IP_ECN_decapsulate() doesn't see a correct SKB network header in ip_tunnel_rcv(), fix from Ying Cai. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits) net: macb: Fix race between HW and driver net: macb: Remove 'unlikely' optimization net: macb: Re-enable RX interrupt only when RX is done net: macb: Clear interrupt flags net: macb: Pass same size to DMA_UNMAP as used for DMA_MAP ip_tunnel: Set network header properly for IP_ECN_decapsulate() e1000e: Restrict MDIO Slow Mode workaround to relevant parts e1000e: Fix issue with link flap on 82579 e1000e: Expand workaround for 10Mb HD throughput bug e1000e: Workaround for dropped packets in Gig/100 speeds on 82579 net/mlx4_core: Don't issue PCIe speed/width checks for VFs net/mlx4_core: Load the Eth driver first net/mlx4_core: Fix slave id computation for single port VF net/mlx4_core: Adjust port number in qp_attach wrapper when detaching net: cdc_ncm: fix buffer overflow Altera TSE: ALTERA_TSE should depend on HAS_DMA vsock: Make transport the proto owner net: sched: lock imbalance in hhf qdisc net: mvmdio: Check for a valid interrupt instead of an error net phy: Check for aneg completion before setting state to PHY_RUNNING ...
2014-05-01Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus an Intel RAPL PMU driver fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tests x86: Fix stack map lookup in dwarf unwind test perf x86: Fix perf to use non-executable stack, again perf tools: Remove extra '/' character in events file path perf machine: Search for modules in %s/lib/modules/%s perf tests: Add static build make test perf tools: Fix bfd dependency libraries detection perf tools: Use LDFLAGS instead of ALL_LDFLAGS perf/x86: Fix RAPL rdmsrl_safe() usage tools lib traceevent: Fix memory leak in pretty_print() tools lib traceevent: Fix backward compatibility macros for pevent filter enums perf tools: Disable libdw unwind for all but x86 arch perf tests x86: Fix memory leak in sample_ustack()
2014-04-30bpf_dbg: fix wrong register usageBrendan Hickey
The AND instruction is erroneously using the X register instead of the K register. Signed-off-by: Brendan Hickey <bhickey@google.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-30perf tests x86: Fix stack map lookup in dwarf unwind testJiri Olsa
Previous commit 'perf x86: Fix perf to use non-executable stack, again' moved stack map into MAP__VARIABLE map type again. Fixing the dwarf unwind test stack map lookup appropriately. Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Link: http://lkml.kernel.org/n/tip-ttzyhbe4zls24z7ednkmhvxl@git.kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-30perf x86: Fix perf to use non-executable stack, againMathias Krause
arch/x86/tests/regs_load.S is missing the linker note about the stack requirements, therefore making the linker fall back to an executable stack. As this object gets linked against the final perf binary, it'll needlessly end up with an executable stack. Fix this by adding the appropriate linker note. Also add a global linker flag to prevent future regressions, as suggested by Jiri. This way perf won't get an executable stack even if we fail to add the .GNU-stack linker note to future assembler files. Though, doing so might create regressions the other way around, when (statically) linking against libraries needing an executable stack. But, apparently, regressing in that direction is wanted as it is an indicator of poor code quality -- or just missing linker notes. Fixes: 3c8b06f981 ("perf tests x86: Introduce perf_regs_load function") Signed-off-by: Mathias Krause <minipli@googlemail.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1398617466-22749-1-git-send-email-minipli@googlemail.com Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-30perf tools: Remove extra '/' character in events file pathXia Kaixu
The array debugfs_known_mountpoints[] will cause extra '/' character output. Remove it. pre: $ perf probe -l /sys/kernel/debug//tracing/uprobe_events file does not exist - please rebuild kernel with CONFIG_UPROBE_EVENTS. post: $ perf probe -l /sys/kernel/debug/tracing/uprobe_events file does not exist - please rebuild kernel with CONFIG_UPROBE_EVENTS. Signed-off-by: Xia Kaixu <xiakaixu@huawei.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/535B6660.2060001@huawei.com Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-30perf machine: Search for modules in %s/lib/modules/%sRichard Yao
Modules installed outside of the kernel's build system should go into "%s/lib/modules/%s/extra", but at present, perf will only look at them when they are in "%s/lib/modules/%s/kernel". Lets encourage good citizenship by relaxing this requirement to "%s/lib/modules/%s". This way open source modules that are out-of-tree have no incentive to start populating a directory reserved for in-kernel modules and I can stop hex-editing my system's perf binary when profiling OSS out-of-tree modules. Feedback from Namhyung Kim correctly revealed that the hex-edits that I had been doing meant that perf was also traversing the build and source symlinks in %s/lib/modules/%s. That is undesireable, so we explicitly exclude them from traversal with a minor tweak to the traversal routine. Signed-off-by: Richard Yao <ryao@gentoo.org> Acked-by: Namhyung kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1398532675-13684-1-git-send-email-ryao@gentoo.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-30perf tests: Add static build make testJiri Olsa
Adding test for building static perf build into the automated suite. Also available via following commands: $ make -f tests/make make_static - make_static: cd . && make -f Makefile DESTDIR=/tmp/tmp.7u5MlB4njo LDFLAGS=-static $ make -f tests/make make_static_O - make_static_O: cd . && make -f Makefile O=/tmp/tmp.Ay6r3wEmtX DESTDIR=/tmp/tmp.vK0KQwO0Vi LDFLAGS=-static Acked-by: David Ahern <dsahern@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1398760413-7574-1-git-send-email-jolsa@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-30perf tools: Fix bfd dependency libraries detectionJiri Olsa
There's false assumption in the library detection code assuming -liberty and -lz are always present once bfd is detected. The fails on Ubuntu (14.04) as reported by Ingo. Forcing the bdf dependency libraries detection any time bfd library is detected. Reported-by: Ingo Molnar <mingo@kernel.org> Tested-by: Ingo Molnar <mingo@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1398676935-6615-1-git-send-email-jolsa@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-30perf tools: Use LDFLAGS instead of ALL_LDFLAGSJiri Olsa
We no longer use ALL_LDFLAGS, Replacing with LDFLAGS. Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1398675770-3109-1-git-send-email-jolsa@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-23Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/jolsa/perf into perf/urgent Pull perf/urgent fixes from Jiri Olsa: * Fix memory leak and backward compatibility macros for pevent filter enums in traceevent library (Steven Rostedt) * Disable libdw unwind for all but x86 arch (Jiri Olsa) * Fix memory leak in sample_ustack (Masanari Iida) Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-23tools lib traceevent: Fix memory leak in pretty_print()Steven Rostedt
Commit 12e55569a244 "tools lib traceevent: Use helper trace-seq in print functions like kernel does" added a extra trace_seq helper to process string arguments like the kernel does it. But the difference between the kernel and the userspace library is that the kernel's trace_seq structure has a static allocated buffer. The userspace one has a dynamically allocated one. It requires a trace_seq_destroy(), otherwise it produces a nasty memory leak. Cc: stable@vger.kernel.org # 3.14+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20140422192330.6bb09bf8@gandalf.local.home Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-23tools lib traceevent: Fix backward compatibility macros for pevent filter enumsSteven Rostedt
The return value for pevent_filter_match() is suppose to return FILTER_NONE if the event doesn't have a filter, and FILTER_NOEXIST if there is no filter at all. But the change 41e12e580a7 "tools lib traceevent: Refactor pevent_filter_match() to get rid of die()" replaced the return value with PEVENT_ERRNO__* values and added "backward compatibility" macros that used the old names. Unfortunately, the NOEXIST and NONE macros were swapped, and this broke users that use the old return names. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20140421222346.0351ced4@gandalf.local.home Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-23perf tools: Disable libdw unwind for all but x86 archJiri Olsa
So far there's only x86 libdw unwind support merged in perf. Disable it on all other architectures in case libdw unwind support is detected in system. Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Josh Boyer <jwboyer@fedoraproject.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1397988006-14158-1-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-23perf tests x86: Fix memory leak in sample_ustack()Masanari Iida
The buf is not freed, when kernel failed to get stack map and return. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Link: http://lkml.kernel.org/r/1398091024-7901-1-git-send-email-standby24x7@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-21tools/power/acpi: Minor bugfixesThomas Renninger
- bindir is created, but sbindir is used -> fix that - the debug parts are there twice (copy paste bug?). Remove one of the exact same parts Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-20Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf tooling fixes from Ingo Molnar: "Three small tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Improve error reporting perf tools: Adjust symbols in VDSO perf kvm: Fix 'Min time' counting in report command
2014-04-20perf tools: Improve error reportingAdrien BAK
In the current version, when using perf record, if something goes wrong in tools/perf/builtin-record.c:375 session = perf_session__new(file, false, NULL); The error message: "Not enough memory for reading per file header" is issued. This error message seems to be outdated and is not very helpful. This patch proposes to replace this error message by "Perf session creation failed" I believe this issue has been brought to lkml: https://lkml.org/lkml/2014/2/24/458 although this patch only tackles a (small) part of the issue. Additionnaly, this patch improves error reporting in tools/perf/util/data.c open_file_write. Currently, if the call to open fails, the user is unaware of it. This patch logs the error, before returning the error code to the caller. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Adrien BAK <adrien.bak@metascale.org> Link: http://lkml.kernel.org/r/1397786443.3093.4.camel@beast [ Reorganize the changelog into paragraphs ] [ Added empty line after fd declaration in open_file_write ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-20perf tools: Adjust symbols in VDSOVladimir Nikulichev
pert-report doesn't resolve function names in VDSO: $ perf report --stdio -g flat,0.0,15,callee --sort pid ... 8.76% 0x7fff6b1fe861 __gettimeofday ACE_OS::gettimeofday() ... In this case symbol values should be adjusted the same way as for executables, relocatable objects and prelinked libraries. After fix: $ perf report --stdio -g flat,0.0,15,callee --sort pid ... 8.76% __vdso_gettimeofday __gettimeofday ACE_OS::gettimeofday() Signed-off-by: Vladimir Nikulichev <nvs@tbricks.com> Tested-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Adrian Hunter <adrian.hunter@intel.com> Link: http://lkml.kernel.org/r/969812.163009436-sendEmail@nvs Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-20perf kvm: Fix 'Min time' counting in report commandAlexander Yarygin
Every event in the perf-kvm has a 'stats' structure, which contains max/min/average/etc times of handling this event. The problem is that the 'perf-kvm stat report' command always shows that 'min time' is 0us for every event. Example: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 0us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 0us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 0us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 0us 44us 16.49us ( +- 38.20% ) [..] This happens because the 'stats' structure is not initialized and stats->min equals to 0. Lets initialize the structure for every event after its allocation using init_stats() function. This initializes stats->min to -1 and makes 'Min time' statistics counting work: # perf kvm stat report Analyze events for all VCPUs: VM-EXIT Samples Samples% Time% Min Time Max Time Avg time [..] 0xB2 MSCH 12 0.07% 0.00% 6us 8us 7.31us ( +- 2.11% ) 0xB2 CHSC 12 0.07% 0.00% 7us 18us 9.39us ( +- 9.49% ) 0xB2 STPX 8 0.05% 0.00% 1us 2us 1.88us ( +- 7.18% ) 0xB2 STSI 7 0.04% 0.00% 1us 44us 16.49us ( +- 38.20% ) [..] Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1397053319-2130-3-git-send-email-borntraeger@de.ibm.com [ Fixing the perf examples changelog output ] Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-18Merge tag 'char-misc-3.15-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver fixes from Greg KH: "Here are a few driver fixes for char/misc drivers that resolve reported issues. All have been in linux-next successfully for a few days" * tag 'char-misc-3.15-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Drivers: hv: vmbus: Negotiate version 3.0 when running on ws2012r2 hosts Tools: hv: Handle the case when the target file exists correctly vme_tsi148: Utilize to_pci_dev() macro vme_tsi148: Fix PCI address mapping assumption vme_tsi148: Fix typo in tsi148_slave_get() w1: avoid recursive device_add w1: fix netlink refcnt leak on error path misc: Grammar s/addition/additional/ drivers: mcb: fix memory leak in chameleon_parse_cells() error path mei: ignore client writing state during cb completion mei: me: do not load the driver if the FW doesn't support MEI interface GenWQE: Increase driver version number GenWQE: Fix multithreading problems GenWQE: Ensure rc is not returning an uninitialized value GenWQE: Add wmb before DDCB is started GenWQE: Enable access to VPD flash area
2014-04-16Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Tooling fixes, plus a simple hardware-enablement patch for the Intel RAPL PMU (energy use measurement) on Haswell CPUs, which I hope is still fine at this stage" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Instead of redirecting flex output, use -o perf tools: Fix double free in perf test 21 (code-reading.c) perf stat: Initialize statistics correctly perf bench: Set more defaults in the 'numa' suite perf bench: Fix segfault at the end of an 'all' execution perf bench: Update manpage to mention numa and futex perf probe: Use dwarf_getcfi_elf() instead of dwarf_getcfi() perf probe: Fix to handle errors in line_range searching perf probe: Fix --line option behavior perf tools: Pick up libdw without explicit LIBDW_DIR MAINTAINERS: Change e-mail to kernel.org one perf callchains: Disable unwind libraries when libelf isn't found tools lib traceevent: Do not call warning() directly tools lib traceevent: Print event name when show warning if possible perf top: Fix documentation of invalid -s option perf/x86: Enable DRAM RAPL support on Intel Haswell
2014-04-16Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "liblockdep fixes and mutex debugging fixes" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/mutex: Fix debug_mutexes tools/liblockdep: Add proper versioning to the shared obj tools/liblockdep: Ignore asmlinkage and visible
2014-04-16Tools: hv: Handle the case when the target file exists correctlyK. Y. Srinivasan
Return the appropriate error code and handle the case when the target file exists correctly. This fixes a bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Cc: <stable@vger.kernel.org> [3.14] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-15perf tools: Instead of redirecting flex output, use -oCody P Schafer
This gives us a real filename instead of having '<stdout>' show up all over the place when debugging. Signed-off-by: Cody P Schafer <cody@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1396652539-2416-1-git-send-email-cody@linux.vnet.ibm.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-15perf tools: Fix double free in perf test 21 (code-reading.c)Adrian Hunter
perf_evlist__delete() deletes attached cpu and thread maps but the test is still using them, so remove them from the evlist before deleting it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Link: http://lkml.kernel.org/r/53465E3E.8070201@intel.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14Merge branch 'perf-core-for-mingo' into perf/urgentIngo Molnar
Conflicts: tools/perf/bench/numa.c Pull perf fixes from Jiri Olsa. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-14Merge branch 'liblockdep-fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into core/urgent Pull liblockdep fixes from Sasha Levin: " 1. There was a build breakage caused by marking a function 'asmlinkage' in lockdep.h. Fix that by ignoring asmlinkage and visible annotations. 2. Josh Boyer mentioned that Fedora would like to include liblockdep as a package, so we had to fix our versioning methods from being dumb and pointless to something actually usable. So now liblockdep.so tracks the kernel version which makes lives of distro folks much easier. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-04-14perf stat: Initialize statistics correctlyAndi Kleen
perf stat did initialize the stats structure used to compute stddev etc. incorrectly. It merely zeroes it. But one member (min) needs to be set to a non zero value. This causes min to be not computed at all. Call init_stats() correctly. It doesn't matter for stat currently because it doesn't use min, but it's still better to do it correctly. The other users of statistics are already correct. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1395768699-16060-1-git-send-email-andi@firstfloor.org Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf bench: Set more defaults in the 'numa' suiteRamkumar Ramachandra
Currently, $ perf bench numa mem errors out with usage information. To make this more user-friendly, let us provide a minimum set of default values required for a test run. As an added bonus, $ perf bench all now goes all the way to completion. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395964219-22173-2-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf bench: Fix segfault at the end of an 'all' executionRamkumar Ramachandra
At the end of $ perf bench all the program segfaults because it attempts to dereference a NULL pointer. Fix this fault. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395964219-22173-4-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf bench: Update manpage to mention numa and futexRamkumar Ramachandra
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395964219-22173-3-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf probe: Use dwarf_getcfi_elf() instead of dwarf_getcfi()Namhyung Kim
The dwarf_getcfi() only checks .debug_frame section for CFI, but as most binaries only have .eh_frame it'd return NULL and it makes some variables inaccessible. Using dwarf_getcfi_elf (along with dwarf_getelf()) allows to show and add probe to more variables. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/1396854348-9296-1-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf probe: Fix to handle errors in line_range searchingMasami Hiramatsu
As Namhyung reported(https://lkml.org/lkml/2014/4/1/89), current perf-probe -L option doesn't handle errors in line-range searching correctly. It causes a SEGV if an error occured in the line-range searching. ---- $ perf probe -x ./perf -v -L map__load Open Debuginfo file: /home/namhyung/project/linux/tools/perf/perf fname: util/map.c, lineno:153 New line range: 153 to 2147483647 path: (null) Segmentation fault (core dumped) ---- This is because line_range_inline_cb() ignores errors from find_line_range_by_line() which means that lr->path is already freed on the error path in find_line_range_by_line(). As a result, get_real_path() accesses the lr->path and it causes a NULL pointer exception. This fixes line_range_inline_cb() to handle the error correctly, and report it to the caller. Anyway, this just fixes a possible SEGV bug, Namhyung's patch is also required. Reported-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20140402054831.19080.27006.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf probe: Fix --line option behaviorNamhyung Kim
The commit 5a62257a3ddd1 ("perf probe: Replace line_list with intlist") replaced line_list to intlist but it has a problem that if a same line was added again, it'd return -EEXIST rather than 1. Since line_range_walk_cb() only checks the result being negative, it resulted in failure or segfault sometimes. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/1396327677-3657-1-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf tools: Pick up libdw without explicit LIBDW_DIRRamkumar Ramachandra
The Makefile logic sets FEATURE_CHECKS_CFLAGS-libdw-dwarf-unwind and FEATURE_CHECKS_LDFLAGS-libdw-dwarf-unwind only if LIBDW_DIR is defined. This means that under a normal setup, $ make NO_LIBUNWIND=1 won't automatically pick up libdw. Fix this. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Acked-by: Jean Pihet <jean.pihet@linaro.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395873845-466-1-git-send-email-artagnon@gmail.com Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf callchains: Disable unwind libraries when libelf isn't foundArnaldo Carvalho de Melo
I.e. do the same as when NO_LIBELF is explicitely passed in the 'make' command line, fixing this: Auto-detecting system features: ... dwarf: [ OFF ] ... glibc: [ on ] ... gtk2: [ OFF ] ... libaudit: [ OFF ] ... libbfd: [ OFF ] ... libelf: [ OFF ] ... libunwind: [ OFF ] ... libdw-dwarf-unwind: [ OFF ] ... DWARF post unwind library: libdw <SNIP> CC /tmp/build/perf/util/symbol-minimal.o CC /tmp/build/perf/util/unwind-libdw.o arch/x86/util/unwind-libdw.c:1:30: fatal error: elfutils/libdwfl.h: No such file or directory compilation terminated. CC /tmp/build/perf/tests/keep-tracking.o util/unwind-libdw.c:2:28: fatal error: elfutils/libdw.h: No such file or directory compilation terminated. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-e39j1yxanltjx4t0msse63ax@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14tools lib traceevent: Do not call warning() directlyNamhyung Kim
The patch 3a3ffa2e82205 ("tools lib traceevent: Report better error message on bad function args") added the error message but it seems there's no reason to call warning() directly. So change it to do_warning_event() to provide event information too. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1395192174-26273-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14tools lib traceevent: Print event name when show warning if possibleNamhyung Kim
It's sometimes useful to know where the parse failure was occurred. Add do_warning_event() macro to see the failing event. It now shows the messages like below: $ perf test 5 5: parse events tests : Warning: [kvmmmu:kvm_mmu_get_page] bad op token { Warning: [kvmmmu:kvm_mmu_sync_page] bad op token { Warning: [kvmmmu:kvm_mmu_unsync_page] bad op token { Warning: [kvmmmu:kvm_mmu_prepare_zap_page] bad op token { Warning: [kvmmmu:fast_page_fault] function is_writable_pte not defined Warning: [xen:xen_mmu_ptep_modify_prot_commit] function sizeof not defined Warning: [xen:xen_mmu_ptep_modify_prot_start] function sizeof not defined Warning: [xen:xen_mmu_set_pgd] function sizeof not defined Warning: [xen:xen_mmu_set_pud] function sizeof not defined Warning: [xen:xen_mmu_set_pmd] function sizeof not defined ... Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ramkumar Ramachandra <artagnon@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1395192174-26273-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-14perf top: Fix documentation of invalid -s optionNamhyung Kim
On perf top, the -s option is used for --sort, but the man page contains invalid documentation of -s option for --sym-annotate. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1395193578-27098-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-04-11Merge tag 'pm+acpi-3.15-rc1-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management fixes and updates from Rafael Wysocki: "This is PM and ACPI material that has emerged over the last two weeks and one fix for a CPU hotplug regression introduced by the recent CPU hotplug notifiers registration series. Included are intel_idle and turbostat updates from Len Brown (these have been in linux-next for quite some time), a new cpufreq driver for powernv (that might spend some more time in linux-next, but BenH was asking me so nicely to push it for 3.15 that I couldn't resist), some cpufreq fixes and cleanups (including fixes for some silly breakage in a couple of cpufreq drivers introduced during the 3.14 cycle), assorted ACPI cleanups, wakeup framework documentation fixes, a new sysfs attribute for cpuidle and a new command line argument for power domains diagnostics. Specifics: - Fix for a recently introduced CPU hotplug regression in ARM KVM from Ming Lei. - Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32 cpufreq drivers introduced during the 3.14 cycle (-stable material) from Chen Gang and Viresh Kumar. - New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits from Gautham R Shenoy and Srivatsa S Bhat. - Exynos cpufreq driver fix preventing it from being included into multiplatform builds that aren't supported by it from Sachin Kamat. - cpufreq cleanups related to the usage of the driver_data field in struct cpufreq_frequency_table from Viresh Kumar. - cpufreq ppc driver cleanup from Sachin Kamat. - Intel BayTrail support for intel_idle and ACPI idle from Len Brown. - Intel CPU model 54 (Atom N2000 series) support for intel_idle from Jan Kiszka. - intel_idle fix for Intel Ivy Town residency targets from Len Brown. - turbostat updates (Intel Broadwell support and output cleanups) from Len Brown. - New cpuidle sysfs attribute for exporting C-states' target residency information to user space from Daniel Lezcano. - New kernel command line argument to prevent power domains enabled by the bootloader from being turned off even if they are not in use (for diagnostics purposes) from Tushar Behera. - Fixes for wakeup sysfs attributes documentation from Geert Uytterhoeven. - New ACPI video blacklist entry for ThinkPad Helix from Stephen Chandler Paul. - Assorted ACPI cleanups and a Kconfig help update from Jonghwan Choi, Zhihui Zhang, Hanjun Guo" * tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits) ACPI: Update the ACPI spec information in Kconfig arm, kvm: fix double lock on cpu_add_remove_lock cpuidle: sysfs: Export target residency information cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h cpufreq: create another field .flags in cpufreq_frequency_table cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table cpufreq: don't print value of .driver_data from core cpufreq: ia64: don't set .driver_data to index cpufreq: powernv: Select CPUFreq related Kconfig options for powernv cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids cpufreq: powernv: cpufreq driver for powernv platform cpufreq: at32ap: don't declare local variable as static cpufreq: loongson2_cpufreq: don't declare local variable as static cpufreq: unicore32: fix typo issue for 'clk' cpufreq: exynos: Disable on multiplatform build PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes PM / domains: Add pd_ignore_unused to keep power domains enabled ACPI / dock: Drop dock_device_ids[] table ACPI / video: Favor native backlight interface for ThinkPad Helix ACPI / thermal: Fix wrong variable usage in debug statement ...
2014-04-08Merge branch 'pm-cpuidle'Rafael J. Wysocki
* pm-cpuidle: cpuidle: sysfs: Export target residency information intel_idle: fine-tune IVT residency targets tools/power turbostat: Run on Broadwell tools/power turbostat: simplify output, add Avg_MHz intel_idle: Add CPU model 54 (Atom N2000 series) intel_idle: support Bay Trail intel_idle: allow sparse sub-state numbering, for Bay Trail ACPI idle: permit sparse C-state sub-state numbers
2014-04-08Merge branch 'release' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-cpuidle Pull intel_idle and turbostat material for v3.15-rc1 from Len Brown. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: intel_idle: fine-tune IVT residency targets tools/power turbostat: Run on Broadwell tools/power turbostat: simplify output, add Avg_MHz intel_idle: Add CPU model 54 (Atom N2000 series) intel_idle: support Bay Trail intel_idle: allow sparse sub-state numbering, for Bay Trail ACPI idle: permit sparse C-state sub-state numbers
2014-04-07tools/vm/page-types.c: page-cache sniffing featureKonstantin Khlebnikov
After this patch 'page-types' can walk over a file's mappings and analyze populated page cache pages mostly without disturbing its state. It maps chunk of file, marks VMA as MADV_RANDOM to turn off readahead, pokes VMA via mincore() to determine cached pages, triggers page-fault only for them, and finally gathers information via pagemap/kpageflags. Before unmap it marks VMA as MADV_SEQUENTIAL for ignoring reference bits. usage: page-types -f <path> If <path> is directory it will analyse all files in all subdirectories. Symlinks are not followed as well as mount points. Hardlinks aren't handled, they'll be dumped as many times as they are found. Recursive walk brings all dentries into dcache and populates page cache of block-devices aka 'Buffers'. Probably it's worth to add ioctl for dumping file page cache as array of PFNs as a replacement for this hackish juggling with mmap/madvise/mincore/pagemap. Also recursive walk could be replaced with dumping cached inodes via some ioctl or debugfs interface followed by openning them via open_by_handle_at, this would fix hardlinks handling and unneeded population of dcache and buffers. This interface might be used as data source for constructing readahead plans and for background optimizations of actively used files. collateral changes: + fix 64-bit LFS: define _FILE_OFFSET_BITS instead of _LARGEFILE64_SOURCE + replace lseek + read with single pread + make show_page_range() reusable after flush usage example: ~/src/linux/tools/vm$ sudo ./page-types -L -f page-types foffset offset flags page-types Inode: 2229277 Size: 89065 (22 pages) Modify: Tue Feb 25 12:00:59 2014 (162 seconds ago) Access: Tue Feb 25 12:01:00 2014 (161 seconds ago) 0 3cbf3b __RU_lA____M________________________ 1 38946a __RU_lA____M________________________ 2 1a3cec __RU_lA____M________________________ 3 1a8321 __RU_lA____M________________________ 4 3af7cc __RU_lA____M________________________ 5 1ed532 __RU_lA_____________________________ 6 2e436a __RU_lA_____________________________ 7 29a35e ___U_lA_____________________________ 8 2de86e ___U_lA_____________________________ 9 3bdfb4 ___U_lA_____________________________ 10 3cd8a3 ___U_lA_____________________________ 11 2afa50 ___U_lA_____________________________ 12 2534c2 ___U_lA_____________________________ 13 1b7a40 ___U_lA_____________________________ 14 17b0be ___U_lA_____________________________ 15 392b0c ___U_lA_____________________________ 16 3ba46a __RU_lA_____________________________ 17 397dc8 ___U_lA_____________________________ 18 1f2a36 ___U_lA_____________________________ 19 21fd30 __RU_lA_____________________________ 20 2c35ba __RU_l______________________________ 21 20f181 __RU_l______________________________ flags page-count MB symbolic-flags long-symbolic-flags 0x000000000000002c 2 0 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 11 0 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 4 0 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000086c 5 0 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 22 0 ~/src/linux/tools/vm$ sudo ./page-types -f / flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000028 21761 85 ___U_l______________________________ uptodate,lru 0x000000000000002c 127279 497 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 74160 289 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 84469 329 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000007c 1 0 __RUDlA_____________________________ referenced,uptodate,dirty,lru,active 0x0000000000000228 370 1 ___U_l___I__________________________ uptodate,lru,reclaim 0x0000000000000828 49 0 ___U_l_____M________________________ uptodate,lru,mmap 0x000000000000082c 126 0 __RU_l_____M________________________ referenced,uptodate,lru,mmap 0x0000000000000868 137 0 ___U_lA____M________________________ uptodate,lru,active,mmap 0x000000000000086c 12890 50 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 321242 1254 Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile updates from Chris Metcalf: "These fix a few stray build issues seen in linux-next, and also add the minimal required support for perf to tilegx" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: remove unused variable 'devcap' tile: Fix vDSO compilation issue with allyesconfig perf tools: Allow building for tile tile/perf: Support perf_events on tilegx and tilepro tile: Enable NMIs on return from handle_nmi() without errors tile: Add support for handling PMC hardware tile: don't use __get_cpu_var() with structure-typed arguments tile: avoid overflow in ns2cycles
