path: root/tools
2020-02-12perf tools: Add Python 3 supportJaroslav Škarvada
Added Python 3 support while keeping Python 2.7 compatibility. Committer notes: This doesn't make it to auto detect python 3, one has to explicitely ask it to build with python 3 devel files, here are the instructions provided by Jaroslav: --- $ cp -a tools/perf tools/python3-perf $ make V=1 prefix=/usr -C tools/perf PYTHON=/usr/bin/python2 all $ make V=1 prefix=/usr -C tools/python3-perf PYTHON=/usr/bin/python3 all $ make V=1 prefix=/usr -C tools/python3-perf PYTHON=/usr/bin/python3 DESTDIR=%{buildroot} install-python_ext $ make V=1 prefix=/usr -C tools/perf PYTHON=/usr/bin/python2 DESTDIR=%{buildroot} install-python_ext --- We need to make this automatic, just like the existing tests for checking if the python2 devel files are in place, allowing the build with python3 if available, fallbacking to python2 and then just disabling it if none are available. So, using the PYTHON variable to build it using O= we get: Before this patch: $ rpm -q python3 python3-devel python3-3.6.4-7.fc27.x86_64 python3-devel-3.6.4-7.fc27.x86_64 $ rm -rf /tmp/build/perf/ ; mkdir -p /tmp/build/perf ; make O=/tmp/build/perf PYTHON=/usr/bin/python3 -C tools/perf install-bin make: Entering directory '/home/acme/git/linux/tools/perf' <SNIP> Makefile.config:670: Python 3 is not yet supported; please set Makefile.config:671: PYTHON and/or PYTHON_CONFIG appropriately. Makefile.config:672: If you also have Python 2 installed, then Makefile.config:673: try something like: Makefile.config:674: Makefile.config:675: make PYTHON=python2 Makefile.config:676: Makefile.config:677: Otherwise, disable Python support entirely: Makefile.config:678: Makefile.config:679: make NO_LIBPYTHON=1 Makefile.config:680: Makefile.config:681: *** . Stop. make[1]: *** [Makefile.perf:212: sub-make] Error 2 make: *** [Makefile:110: install-bin] Error 2 make: Leaving directory '/home/acme/git/linux/tools/perf' $ After: $ make O=/tmp/build/perf PYTHON=python3 -C tools/perf install-bin $ ldd ~/bin/perf | grep python libpython3.6m.so.1.0 => /lib64/libpython3.6m.so.1.0 (0x00007f58a31e8000) $ rpm -qf /lib64/libpython3.6m.so.1.0 python3-libs-3.6.4-7.fc27.x86_64 $ Now verify that when using the binding the right ELF file is loaded, using perf trace: $ perf trace -e open* perf test python 0.051 ( 0.016 ms): perf/3927 openat(dfd: CWD, filename: /etc/ld.so.cache, flags: CLOEXEC ) = 3 <SNIP> 18: 'import perf' in python : 8.849 ( 0.013 ms): sh/3929 openat(dfd: CWD, filename: /etc/ld.so.cache, flags: CLOEXEC ) = 3 <SNIP> 25.572 ( 0.008 ms): python3/3931 openat(dfd: CWD, filename: /tmp/build/perf/python/perf.cpython-36m-x86_64-linux-gnu.so, flags: CLOEXEC) = 3 <SNIP> Ok <SNIP> $ And using tools/perf/python/twatch.py, to show PERF_RECORD_ metaevents: $ python3 tools/perf/python/twatch.py cpu: 3, pid: 16060, tid: 16060 { type: fork, pid: 5207, ppid: 16060, tid: 5207, ptid: 16060, time: 10798513015459} cpu: 3, pid: 16060, tid: 16060 { type: fork, pid: 5208, ppid: 16060, tid: 5208, ptid: 16060, time: 10798513562503} cpu: 0, pid: 5208, tid: 5208 { type: comm, pid: 5208, tid: 5208, comm: grep } cpu: 2, pid: 5207, tid: 5207 { type: comm, pid: 5207, tid: 5207, comm: ps } cpu: 2, pid: 5207, tid: 5207 { type: exit, pid: 5207, ppid: 5207, tid: 5207, ptid: 5207, time: 10798551337484} cpu: 3, pid: 5208, tid: 5208 { type: exit, pid: 5208, ppid: 5208, tid: 5208, ptid: 5208, time: 10798551292153} cpu: 3, pid: 601, tid: 601 { type: fork, pid: 5209, ppid: 601, tid: 5209, ptid: 601, time: 10801779977324} ^CTraceback (most recent call last): File "tools/perf/python/twatch.py", line 68, in <module> main() File "tools/perf/python/twatch.py", line 40, in main evlist.poll(timeout = -1) KeyboardInterrupt $ # ps ax|grep twatch 5197 pts/8 S+ 0:00 python3 tools/perf/python/twatch.py # ls -la /proc/5197/smaps -r--r--r--. 1 acme acme 0 Feb 19 13:14 /proc/5197/smaps # grep python /proc/5197/smaps 558111307000-558111309000 r-xp 00000000 fd:00 3151710 /usr/bin/python3.6 558111508000-558111509000 r--p 00001000 fd:00 3151710 /usr/bin/python3.6 558111509000-55811150a000 rw-p 00002000 fd:00 3151710 /usr/bin/python3.6 7ffad6fc1000-7ffad7008000 r-xp 00000000 00:2d 220196 /tmp/build/perf/python/perf.cpython-36m-x86_64-linux-gnu.so 7ffad7008000-7ffad7207000 ---p 00047000 00:2d 220196 /tmp/build/perf/python/perf.cpython-36m-x86_64-linux-gnu.so 7ffad7207000-7ffad7208000 r--p 00046000 00:2d 220196 /tmp/build/perf/python/perf.cpython-36m-x86_64-linux-gnu.so 7ffad7208000-7ffad7215000 rw-p 00047000 00:2d 220196 /tmp/build/perf/python/perf.cpython-36m-x86_64-linux-gnu.so 7ffadea77000-7ffaded3d000 r-xp 00000000 fd:00 3151795 /usr/lib64/libpython3.6m.so.1.0 7ffaded3d000-7ffadef3c000 ---p 002c6000 fd:00 3151795 /usr/lib64/libpython3.6m.so.1.0 7ffadef3c000-7ffadef42000 r--p 002c5000 fd:00 3151795 /usr/lib64/libpython3.6m.so.1.0 7ffadef42000-7ffadefa5000 rw-p 002cb000 fd:00 3151795 /usr/lib64/libpython3.6m.so.1.0 # And with this patch, but building normally, without specifying the PYTHON=python3 part, which will make it use python2 if its devel files are available, like in this test: $ make O=/tmp/build/perf -C tools/perf install-bin $ ldd ~/bin/perf | grep python libpython2.7.so.1.0 => /lib64/libpython2.7.so.1.0 (0x00007f6a44410000) $ ldd /tmp/build/perf/python_ext_build/lib/perf.so | grep python libpython2.7.so.1.0 => /lib64/libpython2.7.so.1.0 (0x00007fed28a2c000) $ [acme@jouet perf]$ tools/perf/python/twatch.py cpu: 0, pid: 2817, tid: 2817 { type: fork, pid: 2817, ppid: 2817, tid: 8910, ptid: 2817, time: 11126454335306} cpu: 0, pid: 2817, tid: 2817 { type: comm, pid: 2817, tid: 8910, comm: worker } $ ps ax | grep twatch.py 8909 pts/8 S+ 0:00 /usr/bin/python tools/perf/python/twatch.py $ grep python /proc/8909/smaps 5579de658000-5579de659000 r-xp 00000000 fd:00 3156044 /usr/bin/python2.7 5579de858000-5579de859000 r--p 00000000 fd:00 3156044 /usr/bin/python2.7 5579de859000-5579de85a000 rw-p 00001000 fd:00 3156044 /usr/bin/python2.7 7f0de01f7000-7f0de023e000 r-xp 00000000 00:2d 230695 /tmp/build/perf/python/perf.so 7f0de023e000-7f0de043d000 ---p 00047000 00:2d 230695 /tmp/build/perf/python/perf.so 7f0de043d000-7f0de043e000 r--p 00046000 00:2d 230695 /tmp/build/perf/python/perf.so 7f0de043e000-7f0de044b000 rw-p 00047000 00:2d 230695 /tmp/build/perf/python/perf.so 7f0de6f0f000-7f0de6f13000 r-xp 00000000 fd:00 134975 /usr/lib64/python2.7/lib-dynload/_localemodule.so 7f0de6f13000-7f0de7113000 ---p 00004000 fd:00 134975 /usr/lib64/python2.7/lib-dynload/_localemodule.so 7f0de7113000-7f0de7114000 r--p 00004000 fd:00 134975 /usr/lib64/python2.7/lib-dynload/_localemodule.so 7f0de7114000-7f0de7115000 rw-p 00005000 fd:00 134975 /usr/lib64/python2.7/lib-dynload/_localemodule.so 7f0de7e73000-7f0de8052000 r-xp 00000000 fd:00 3173292 /usr/lib64/libpython2.7.so.1.0 7f0de8052000-7f0de8251000 ---p 001df000 fd:00 3173292 /usr/lib64/libpython2.7.so.1.0 7f0de8251000-7f0de8255000 r--p 001de000 fd:00 3173292 /usr/lib64/libpython2.7.so.1.0 7f0de8255000-7f0de8291000 rw-p 001e2000 fd:00 3173292 /usr/lib64/libpython2.7.so.1.0 $ Signed-off-by: Jaroslav Škarvada <jskarvad@redhat.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> LPU-Reference: 20180119205641.24242-1-jskarvad@redhat.com Link: https://lkml.kernel.org/n/tip-8d7dt9kqp83vsz25hagug8fu@git.kernel.org [ Removed explicit check for python version, allowing it to really build with python3 ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> (cherry picked from commit 66dfdff03d196e51322c6a85c0d8db8bb2bdd655)
2020-01-12bpf: reject passing modified ctx to helper functionsDaniel Borkmann
commit 58990d1ff3f7896ee341030e9a7c2e4002570683 upstream. As commit 28e33f9d78ee ("bpf: disallow arithmetic operations on context pointer") already describes, f1174f77b50c ("bpf/verifier: rework value tracking") removed the specific white-listed cases we had previously where we would allow for pointer arithmetic in order to further generalize it, and allow e.g. context access via modified registers. While the dereferencing of modified context pointers had been forbidden through 28e33f9d78ee, syzkaller did recently manage to trigger several KASAN splats for slab out of bounds access and use after frees by simply passing a modified context pointer to a helper function which would then do the bad access since verifier allowed it in adjust_ptr_min_max_vals(). Rejecting arithmetic on ctx pointer in adjust_ptr_min_max_vals() generally could break existing programs as there's a valid use case in tracing in combination with passing the ctx to helpers as bpf_probe_read(), where the register then becomes unknown at verification time due to adding a non-constant offset to it. An access sequence may look like the following: offset = args->filename; /* field __data_loc filename */ bpf_probe_read(&dst, len, (char *)args + offset); // args is ctx There are two options: i) we could special case the ctx and as soon as we add a constant or bounded offset to it (hence ctx type wouldn't change) we could turn the ctx into an unknown scalar, or ii) we generalize the sanity test for ctx member access into a small helper and assert it on the ctx register that was passed as a function argument. Fwiw, latter is more obvious and less complex at the same time, and one case that may potentially be legitimate in future for ctx member access at least would be for ctx to carry a const offset. Therefore, fix follows approach from ii) and adds test cases to BPF kselftests. Fixes: f1174f77b50c ("bpf/verifier: rework value tracking") Reported-by: syzbot+3d0b2441dbb71751615e@syzkaller.appspotmail.com Reported-by: syzbot+c8504affd4fdd0c1b626@syzkaller.appspotmail.com Reported-by: syzbot+e5190cb881d8660fb1a3@syzkaller.appspotmail.com Reported-by: syzbot+efae31b384d5badbd620@syzkaller.appspotmail.com Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Yonghong Song <yhs@fb.com> Acked-by: Edward Cree <ecree@solarflare.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-12libtraceevent: Fix lib installation with O=Sudip Mukherjee
[ Upstream commit 587db8ebdac2c5eb3a8851e16b26f2e2711ab797 ] When we use 'O=' with make to build libtraceevent in a separate folder it fails to install libtraceevent.a and libtraceevent.so.1.1.0 with the error: INSTALL /home/sudip/linux/obj-trace/libtraceevent.a INSTALL /home/sudip/linux/obj-trace/libtraceevent.so.1.1.0 cp: cannot stat 'libtraceevent.a': No such file or directory Makefile:225: recipe for target 'install_lib' failed make: *** [install_lib] Error 1 I used the command: make O=../../../obj-trace DESTDIR=~/test prefix==/usr install It turns out libtraceevent Makefile, even though it builds in a separate folder, searches for libtraceevent.a and libtraceevent.so.1.1.0 in its source folder. So, add the 'OUTPUT' prefix to the source path so that 'make' looks for the files in the correct place. Signed-off-by: Sudipm Mukherjee <sudipm.mukherjee@gmail.com> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: linux-trace-devel@vger.kernel.org Link: http://lore.kernel.org/lkml/20191115113610.21493-1-sudipm.mukherjee@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-09selftests: rtnetlink: add addresses with fixed life timeFlorian Westphal
[ Upstream commit 3cfa148826e3c666da1cc2a43fbe8689e2650636 ] This exercises kernel code path that deal with addresses that have a limited lifetime. Without previous fix, this triggers following crash on net-next: BUG: KASAN: null-ptr-deref in check_lifetime+0x403/0x670 Read of size 8 at addr 0000000000000010 by task kworker [..] Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf strbuf: Remove redundant va_end() in strbuf_addv()Mattias Jacobsson
commit 099be748865eece21362aee416c350c0b1ae34df upstream. Each call to va_copy() should have one, and only one, corresponding call to va_end(). In strbuf_addv() some code paths result in va_end() getting called multiple times. Remove the superfluous va_end(). Signed-off-by: Mattias Jacobsson <2pi@mok.nu> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sanskriti Sharma <sansharm@redhat.com> Link: http://lkml.kernel.org/r/20181229141750.16945-1-2pi@mok.nu Fixes: ce49d8436cff ("perf strbuf: Match va_{add,copy} with va_end") Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro1.iwamatsu@toshiba.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2020-01-04perf regs: Make perf_reg_name() return "unknown" instead of NULLArnaldo Carvalho de Melo
[ Upstream commit 5b596e0ff0e1852197d4c82d3314db5e43126bf7 ] To avoid breaking the build on arches where this is not wired up, at least all the other features should be made available and when using this specific routine, the "unknown" should point the user/developer to the need to wire this up on this particular hardware architecture. Detected in a container mipsel debian cross build environment, where it shows up as: In file included from /usr/mipsel-linux-gnu/include/stdio.h:867, from /git/linux/tools/perf/lib/include/perf/cpumap.h:6, from util/session.c:13: In function 'printf', inlined from 'regs_dump__printf' at util/session.c:1103:3, inlined from 'regs__printf' at util/session.c:1131:2: /usr/mipsel-linux-gnu/include/bits/stdio2.h:107:10: error: '%-5s' directive argument is null [-Werror=format-overflow=] 107 | return __printf_chk (__USE_FORTIFY_LEVEL - 1, __fmt, __va_arg_pack ()); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cross compiler details: mipsel-linux-gnu-gcc (Debian 9.2.1-8) 9.2.1 20190909 Also on mips64: In file included from /usr/mips64-linux-gnuabi64/include/stdio.h:867, from /git/linux/tools/perf/lib/include/perf/cpumap.h:6, from util/session.c:13: In function 'printf', inlined from 'regs_dump__printf' at util/session.c:1103:3, inlined from 'regs__printf' at util/session.c:1131:2, inlined from 'regs_user__printf' at util/session.c:1139:3, inlined from 'dump_sample' at util/session.c:1246:3, inlined from 'machines__deliver_event' at util/session.c:1421:3: /usr/mips64-linux-gnuabi64/include/bits/stdio2.h:107:10: error: '%-5s' directive argument is null [-Werror=format-overflow=] 107 | return __printf_chk (__USE_FORTIFY_LEVEL - 1, __fmt, __va_arg_pack ()); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ In function 'printf', inlined from 'regs_dump__printf' at util/session.c:1103:3, inlined from 'regs__printf' at util/session.c:1131:2, inlined from 'regs_intr__printf' at util/session.c:1147:3, inlined from 'dump_sample' at util/session.c:1249:3, inlined from 'machines__deliver_event' at util/session.c:1421:3: /usr/mips64-linux-gnuabi64/include/bits/stdio2.h:107:10: error: '%-5s' directive argument is null [-Werror=format-overflow=] 107 | return __printf_chk (__USE_FORTIFY_LEVEL - 1, __fmt, __va_arg_pack ()); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cross compiler details: mips64-linux-gnuabi64-gcc (Debian 9.2.1-8) 9.2.1 20190909 Fixes: 2bcd355b71da ("perf tools: Add interface to arch registers sets") Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: https://lkml.kernel.org/n/tip-95wjyv4o65nuaeweq31t7l1s@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2020-01-04perf script: Fix brstackinsn for AUXTRACEAdrian Hunter
[ Upstream commit 0cd032d3b5fcebf5454315400ab310746a81ca53 ] brstackinsn must be allowed to be set by the user when AUX area data has been captured because, in that case, the branch stack might be synthesized on the fly. This fixes the following error: Before: $ perf record -e '{intel_pt//,cpu/mem_inst_retired.all_loads,aux-sample-size=8192/pp}:u' grep -rqs jhgjhg /boot [ perf record: Woken up 19 times to write data ] [ perf record: Captured and wrote 2.274 MB perf.data ] $ perf script -F +brstackinsn --xed --itrace=i1usl100 | head Display of branch stack assembler requested, but non all-branch filter set Hint: run 'perf record -b ...' After: $ perf record -e '{intel_pt//,cpu/mem_inst_retired.all_loads,aux-sample-size=8192/pp}:u' grep -rqs jhgjhg /boot [ perf record: Woken up 19 times to write data ] [ perf record: Captured and wrote 2.274 MB perf.data ] $ perf script -F +brstackinsn --xed --itrace=i1usl100 | head grep 13759 [002] 8091.310257: 1862 instructions:uH: 5641d58069eb bmexec+0x86b (/bin/grep) bmexec+2485: 00005641d5806b35 jnz 0x5641d5806bd0 # MISPRED 00005641d5806bd0 movzxb (%r13,%rdx,1), %eax 00005641d5806bd6 add %rdi, %rax 00005641d5806bd9 movzxb -0x1(%rax), %edx 00005641d5806bdd cmp %rax, %r14 00005641d5806be0 jnb 0x5641d58069c0 # MISPRED mismatch of LBR data and executable 00005641d58069c0 movzxb (%r13,%rdx,1), %edi Fixes: 48d02a1d5c13 ("perf script: Add 'brstackinsn' for branch stacks") Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lore.kernel.org/lkml/20191127095322.15417-1-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to show function entry line as probe-ableMasami Hiramatsu
commit 91e2f539eeda26ab00bd03fae8dc434c128c85ed upstream. Fix die_walk_lines() to list the function entry line correctly. Since the dwarf_entrypc() does not return the entry pc if the DIE has only range attribute, __die_walk_funclines() fails to list the declaration line (entry line) in that case. To solve this issue, this introduces die_entrypc() which correctly returns the entry PC (the first address range) even if the DIE has only range attribute. With this fix die_walk_lines() shows the function entry line is able to probe correctly. Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157190837419.1859.4619125803596816752.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Thomas Backlund <tmb@mageia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-31libtraceevent: Fix memory leakage in copy_filter_typeHewenliang
[ Upstream commit 10992af6bf46a2048ad964985a5b77464e5563b1 ] It is necessary to free the memory that we have allocated when error occurs. Fixes: ef3072cd1d5c ("tools lib traceevent: Get rid of die in add_filter_type()") Signed-off-by: Hewenliang <hewenliang4@huawei.com> Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Tzvetomir Stoyanov <tstoyanov@vmware.com> Link: http://lore.kernel.org/lkml/20191119014415.57210-1-hewenliang4@huawei.com Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31x86/insn: Add some Intel instructions to the opcode mapAdrian Hunter
[ Upstream commit b980be189c9badba50634671e2303e92bf28e35a ] Add to the opcode map the following instructions: cldemote tpause umonitor umwait movdiri movdir64b enqcmd enqcmds encls enclu enclv pconfig wbnoinvd For information about the instructions, refer Intel SDM May 2019 (325462-070US) and Intel Architecture Instruction Set Extensions May 2019 (319433-037). The instruction decoding can be tested using the perf tools' "x86 instruction decoder - new instructions" test as folllows: $ perf test -v "new " 2>&1 | grep -i cldemote Decoded ok: 0f 1c 00 cldemote (%eax) Decoded ok: 0f 1c 05 78 56 34 12 cldemote 0x12345678 Decoded ok: 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%eax,%ecx,8) Decoded ok: 0f 1c 00 cldemote (%rax) Decoded ok: 41 0f 1c 00 cldemote (%r8) Decoded ok: 0f 1c 04 25 78 56 34 12 cldemote 0x12345678 Decoded ok: 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%rax,%rcx,8) Decoded ok: 41 0f 1c 84 c8 78 56 34 12 cldemote 0x12345678(%r8,%rcx,8) $ perf test -v "new " 2>&1 | grep -i tpause Decoded ok: 66 0f ae f3 tpause %ebx Decoded ok: 66 0f ae f3 tpause %ebx Decoded ok: 66 41 0f ae f0 tpause %r8d $ perf test -v "new " 2>&1 | grep -i umonitor Decoded ok: 67 f3 0f ae f0 umonitor %ax Decoded ok: f3 0f ae f0 umonitor %eax Decoded ok: 67 f3 0f ae f0 umonitor %eax Decoded ok: f3 0f ae f0 umonitor %rax Decoded ok: 67 f3 41 0f ae f0 umonitor %r8d $ perf test -v "new " 2>&1 | grep -i umwait Decoded ok: f2 0f ae f0 umwait %eax Decoded ok: f2 0f ae f0 umwait %eax Decoded ok: f2 41 0f ae f0 umwait %r8d $ perf test -v "new " 2>&1 | grep -i movdiri Decoded ok: 0f 38 f9 03 movdiri %eax,(%ebx) Decoded ok: 0f 38 f9 88 78 56 34 12 movdiri %ecx,0x12345678(%eax) Decoded ok: 48 0f 38 f9 03 movdiri %rax,(%rbx) Decoded ok: 48 0f 38 f9 88 78 56 34 12 movdiri %rcx,0x12345678(%rax) $ perf test -v "new " 2>&1 | grep -i movdir64b Decoded ok: 66 0f 38 f8 18 movdir64b (%eax),%ebx Decoded ok: 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%eax),%ecx Decoded ok: 67 66 0f 38 f8 1c movdir64b (%si),%bx Decoded ok: 67 66 0f 38 f8 8c 34 12 movdir64b 0x1234(%si),%cx Decoded ok: 66 0f 38 f8 18 movdir64b (%rax),%rbx Decoded ok: 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%rax),%rcx Decoded ok: 67 66 0f 38 f8 18 movdir64b (%eax),%ebx Decoded ok: 67 66 0f 38 f8 88 78 56 34 12 movdir64b 0x12345678(%eax),%ecx $ perf test -v "new " 2>&1 | grep -i enqcmd Decoded ok: f2 0f 38 f8 18 enqcmd (%eax),%ebx Decoded ok: f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%eax),%ecx Decoded ok: 67 f2 0f 38 f8 1c enqcmd (%si),%bx Decoded ok: 67 f2 0f 38 f8 8c 34 12 enqcmd 0x1234(%si),%cx Decoded ok: f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx Decoded ok: 67 f3 0f 38 f8 1c enqcmds (%si),%bx Decoded ok: 67 f3 0f 38 f8 8c 34 12 enqcmds 0x1234(%si),%cx Decoded ok: f2 0f 38 f8 18 enqcmd (%rax),%rbx Decoded ok: f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%rax),%rcx Decoded ok: 67 f2 0f 38 f8 18 enqcmd (%eax),%ebx Decoded ok: 67 f2 0f 38 f8 88 78 56 34 12 enqcmd 0x12345678(%eax),%ecx Decoded ok: f3 0f 38 f8 18 enqcmds (%rax),%rbx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%rax),%rcx Decoded ok: 67 f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: 67 f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx $ perf test -v "new " 2>&1 | grep -i enqcmds Decoded ok: f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx Decoded ok: 67 f3 0f 38 f8 1c enqcmds (%si),%bx Decoded ok: 67 f3 0f 38 f8 8c 34 12 enqcmds 0x1234(%si),%cx Decoded ok: f3 0f 38 f8 18 enqcmds (%rax),%rbx Decoded ok: f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%rax),%rcx Decoded ok: 67 f3 0f 38 f8 18 enqcmds (%eax),%ebx Decoded ok: 67 f3 0f 38 f8 88 78 56 34 12 enqcmds 0x12345678(%eax),%ecx $ perf test -v "new " 2>&1 | grep -i encls Decoded ok: 0f 01 cf encls Decoded ok: 0f 01 cf encls $ perf test -v "new " 2>&1 | grep -i enclu Decoded ok: 0f 01 d7 enclu Decoded ok: 0f 01 d7 enclu $ perf test -v "new " 2>&1 | grep -i enclv Decoded ok: 0f 01 c0 enclv Decoded ok: 0f 01 c0 enclv $ perf test -v "new " 2>&1 | grep -i pconfig Decoded ok: 0f 01 c5 pconfig Decoded ok: 0f 01 c5 pconfig $ perf test -v "new " 2>&1 | grep -i wbnoinvd Decoded ok: f3 0f 09 wbnoinvd Decoded ok: f3 0f 09 wbnoinvd Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: x86@kernel.org Link: http://lore.kernel.org/lkml/20191115135447.6519-3-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Filter out instances except for inlined subroutine and subprogramMasami Hiramatsu
[ Upstream commit da6cb952a89efe24bb76c4971370d485737a2d85 ] Filter out instances except for inlined_subroutine and subprogram DIE in die_walk_instances() and die_is_func_instance(). This fixes an issue that perf probe sets some probes on calling address instead of a target function itself. When perf probe walks on instances of an abstruct origin (a kind of function prototype of inlined function), die_walk_instances() can also pass a GNU_call_site (a GNU extension for call site) to callback. Since it is not an inlined instance of target function, we have to filter out when searching a probe point. Without this patch, perf probe sets probes on call site address too.This can happen on some function which is marked "inlined", but has actual symbol. (I'm not sure why GCC mark it "inlined"): # perf probe -D vfs_read p:probe/vfs_read _text+2500017 p:probe/vfs_read_1 _text+2499468 p:probe/vfs_read_2 _text+2499563 p:probe/vfs_read_3 _text+2498876 p:probe/vfs_read_4 _text+2498512 p:probe/vfs_read_5 _text+2498627 With this patch: Slightly different results, similar tho: # perf probe -D vfs_read p:probe/vfs_read _text+2498512 Committer testing: # uname -a Linux quaco 5.3.8-200.fc30.x86_64 #1 SMP Tue Oct 29 14:46:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux Before: # perf probe -D vfs_read p:probe/vfs_read _text+3131557 p:probe/vfs_read_1 _text+3130975 p:probe/vfs_read_2 _text+3131047 p:probe/vfs_read_3 _text+3130380 p:probe/vfs_read_4 _text+3130000 # uname -a Linux quaco 5.3.8-200.fc30.x86_64 #1 SMP Tue Oct 29 14:46:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux # After: # perf probe -D vfs_read p:probe/vfs_read _text+3130000 # Fixes: db0d2c6420ee ("perf probe: Search concrete out-of-line instances") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241937063.32002.11024544873990816590.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Skip end-of-sequence and non statement linesMasami Hiramatsu
[ Upstream commit f4d99bdfd124823a81878b44b5e8750b97f73902 ] Skip end-of-sequence and non-statement lines while walking through lines list. The "end-of-sequence" line information means: "the current address is that of the first byte after the end of a sequence of target machine instructions." (DWARF version 4 spec 6.2.2) This actually means out of scope and we can not probe on it. On the other hand, the statement lines (is_stmt) means: "the current instruction is a recommended breakpoint location. A recommended breakpoint location is intended to “represent” a line, a statement and/or a semantically distinct subpart of a statement." (DWARF version 4 spec 6.2.2) So, non-statement line info also should be skipped. These can reduce unneeded probe points and also avoid an error. E.g. without this patch: # perf probe -a "clear_tasks_mm_cpumask:1" Added new events: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_2 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_3 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_4 (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask_4 -aR sleep 1 # This puts 5 probes on one line, but acutally it's not inlined function. This is because there are many non statement instructions at the function prologue. With this patch: # perf probe -a "clear_tasks_mm_cpumask:1" Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 # Now perf-probe skips unneeded addresses. Committer testing: Slightly different results, but similar: Before: # uname -a Linux quaco 5.3.8-200.fc30.x86_64 #1 SMP Tue Oct 29 14:46:22 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux # # perf probe -a "clear_tasks_mm_cpumask:1" Added new events: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask:1) probe:clear_tasks_mm_cpumask_2 (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask_2 -aR sleep 1 # After: # perf probe -a "clear_tasks_mm_cpumask:1" Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask:1) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 # perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c) # Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241936090.32002.12156347518596111660.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to show calling lines of inlined functionsMasami Hiramatsu
[ Upstream commit 86c0bf8539e7f46d91bd105e55eda96e0064caef ] Fix to show calling lines of inlined functions (where an inline function is called). die_walk_lines() filtered out the lines inside inlined functions based on the address. However this also filtered out the lines which call those inlined functions from the target function. To solve this issue, check the call_file and call_line attributes and do not filter out if it matches to the line information. Without this fix, perf probe -L doesn't show some lines correctly. (don't see the lines after 17) # perf probe -L vfs_read <vfs_read@/home/mhiramat/ksrc/linux/fs/read_write.c:0> 0 ssize_t vfs_read(struct file *file, char __user *buf, size_t count, loff_t *pos) 1 { 2 ssize_t ret; 4 if (!(file->f_mode & FMODE_READ)) return -EBADF; 6 if (!(file->f_mode & FMODE_CAN_READ)) return -EINVAL; 8 if (unlikely(!access_ok(buf, count))) return -EFAULT; 11 ret = rw_verify_area(READ, file, pos, count); 12 if (!ret) { 13 if (count > MAX_RW_COUNT) count = MAX_RW_COUNT; 15 ret = __vfs_read(file, buf, count, pos); 16 if (ret > 0) { fsnotify_access(file); add_rchar(current, ret); } With this fix: # perf probe -L vfs_read <vfs_read@/home/mhiramat/ksrc/linux/fs/read_write.c:0> 0 ssize_t vfs_read(struct file *file, char __user *buf, size_t count, loff_t *pos) 1 { 2 ssize_t ret; 4 if (!(file->f_mode & FMODE_READ)) return -EBADF; 6 if (!(file->f_mode & FMODE_CAN_READ)) return -EINVAL; 8 if (unlikely(!access_ok(buf, count))) return -EFAULT; 11 ret = rw_verify_area(READ, file, pos, count); 12 if (!ret) { 13 if (count > MAX_RW_COUNT) count = MAX_RW_COUNT; 15 ret = __vfs_read(file, buf, count, pos); 16 if (ret > 0) { 17 fsnotify_access(file); 18 add_rchar(current, ret); } 20 inc_syscr(current); } Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241937995.32002.17899884017011512577.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Return a better scope DIE if there is no best scopeMasami Hiramatsu
[ Upstream commit c701636aeec4c173208697d68da6e4271125564b ] Make find_best_scope() returns innermost DIE at given address if there is no best matched scope DIE. Since Gcc sometimes generates intuitively strange line info which is out of inlined function address range, we need this fixup. Without this, sometimes perf probe failed to probe on a line inside an inlined function: # perf probe -D ksys_open:3 Failed to find scope of probe point. Error: Failed to add events. With this fix, 'perf probe' can probe it: # perf probe -D ksys_open:3 p:probe/ksys_open _text+25707308 p:probe/ksys_open_1 _text+25710596 p:probe/ksys_open_2 _text+25711114 p:probe/ksys_open_3 _text+25711343 p:probe/ksys_open_4 _text+25714058 p:probe/ksys_open_5 _text+2819653 p:probe/ksys_open_6 _text+2819701 Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com> Cc: Steven Rostedt (VMware) <rostedt@goodmis.org> Cc: Tom Zanussi <tom.zanussi@linux.intel.com> Link: http://lore.kernel.org/lkml/157291300887.19771.14936015360963292236.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Skip overlapped location on searching variablesMasami Hiramatsu
[ Upstream commit dee36a2abb67c175265d49b9a8c7dfa564463d9a ] Since debuginfo__find_probes() callback function can be called with the location which already passed, the callback function must filter out such overlapped locations. add_probe_trace_event() has already done it by commit 1a375ae7659a ("perf probe: Skip same probe address for a given line"), but add_available_vars() doesn't. Thus perf probe -v shows same address repeatedly as below: # perf probe -V vfs_read:18 Available variables at vfs_read:18 @<vfs_read+217> char* buf loff_t* pos ssize_t ret struct file* file @<vfs_read+217> char* buf loff_t* pos ssize_t ret struct file* file @<vfs_read+226> char* buf loff_t* pos ssize_t ret struct file* file With this fix, perf probe -V shows it correctly: # perf probe -V vfs_read:18 Available variables at vfs_read:18 @<vfs_read+217> char* buf loff_t* pos ssize_t ret struct file* file @<vfs_read+226> char* buf loff_t* pos ssize_t ret struct file* file Fixes: cf6eb489e5c0 ("perf probe: Show accessible local variables") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157241938927.32002.4026859017790562751.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf parse: If pmu configuration fails free termsIan Rogers
[ Upstream commit 38f2c4226e6bc3e8c41c318242821ba5dc825aba ] Avoid a memory leak when the configuration fails. Signed-off-by: Ian Rogers <irogers@google.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Jin Yao <yao.jin@linux.intel.com> Cc: John Garry <john.garry@huawei.com> Cc: Kan Liang <kan.liang@linux.intel.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Martin KaFai Lau <kafai@fb.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Song Liu <songliubraving@fb.com> Cc: Stephane Eranian <eranian@google.com> Cc: Yonghong Song <yhs@fb.com> Cc: bpf@vger.kernel.org Cc: clang-built-linux@googlegroups.com Cc: netdev@vger.kernel.org Link: http://lore.kernel.org/lkml/20191030223448.12930-9-irogers@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to probe a function which has no entry pcMasami Hiramatsu
[ Upstream commit 5d16dbcc311d91267ddb45c6da4f187be320ecee ] Fix 'perf probe' to probe a function which has no entry pc or low pc but only has ranges attribute. probe_point_search_cb() uses dwarf_entrypc() to get the probe address, but that doesn't work for the function DIE which has only ranges attribute. Use die_entrypc() instead. Without this fix: # perf probe -k ../build-x86_64/vmlinux -D clear_tasks_mm_cpumask:0 Probe point 'clear_tasks_mm_cpumask' not found. Error: Failed to add events. With this: # perf probe -k ../build-x86_64/vmlinux -D clear_tasks_mm_cpumask:0 p:probe/clear_tasks_mm_cpumask clear_tasks_mm_cpumask+0 Committer testing: Before: [root@quaco ~]# perf probe clear_tasks_mm_cpumask:0 Probe point 'clear_tasks_mm_cpumask' not found. Error: Failed to add events. [root@quaco ~]# After: [root@quaco ~]# perf probe clear_tasks_mm_cpumask:0 Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 [root@quaco ~]# Using it with 'perf trace': [root@quaco ~]# perf trace -e probe:clear_tasks_mm_cpumask Doesn't seem to be used in x86_64: $ find . -name "*.c" | xargs grep clear_tasks_mm_cpumask ./kernel/cpu.c: * clear_tasks_mm_cpumask - Safely clear tasks' mm_cpumask for a CPU ./kernel/cpu.c:void clear_tasks_mm_cpumask(int cpu) ./arch/xtensa/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/csky/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/sh/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/arm/kernel/smp.c: clear_tasks_mm_cpumask(cpu); ./arch/powerpc/mm/nohash/mmu_context.c: clear_tasks_mm_cpumask(cpu); $ find . -name "*.h" | xargs grep clear_tasks_mm_cpumask ./include/linux/cpu.h:void clear_tasks_mm_cpumask(int cpu); $ find . -name "*.S" | xargs grep clear_tasks_mm_cpumask $ Fixes: e1ecbbc3fa83 ("perf probe: Fix to handle optimized not-inlined functions") Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199319438.8075.4695576954550638618.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31libsubcmd: Use -O0 with DEBUG=1James Clark
[ Upstream commit 22bd8f1b5a1dd168ba4eba27cb17643a11012f5d ] When a 'make DEBUG=1' build is done, the command parser is still built with -O6 and is hard to step through, fix it making it use -O0 in that case. Signed-off-by: James Clark <james.clark@arm.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Ian Rogers <irogers@google.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: nd <nd@arm.com> Link: http://lore.kernel.org/lkml/20191028113340.4282-1-james.clark@arm.com [ split from a larger patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to show inlined function callsite without entry_pcMasami Hiramatsu
[ Upstream commit 18e21eb671dc87a4f0546ba505a89ea93598a634 ] Fix 'perf probe --line' option to show inlined function callsite lines even if the function DIE has only ranges. Without this: # perf probe -L amd_put_event_constraints ... 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) __amd_put_nb_event_constraints(cpuc, event); 5 } With this patch: # perf probe -L amd_put_event_constraints ... 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) 4 __amd_put_nb_event_constraints(cpuc, event); 5 } Committer testing: Before: [root@quaco ~]# perf probe -L amd_put_event_constraints <amd_put_event_constraints@/usr/src/debug/kernel-5.2.fc30/linux-5.2.18-200.fc30.x86_64/arch/x86/events/amd/core.c:0> 0 static void amd_put_event_constraints(struct cpu_hw_events *cpuc, struct perf_event *event) 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) __amd_put_nb_event_constraints(cpuc, event); 5 } PMU_FORMAT_ATTR(event, "config:0-7,32-35"); PMU_FORMAT_ATTR(umask, "config:8-15" ); [root@quaco ~]# After: [root@quaco ~]# perf probe -L amd_put_event_constraints <amd_put_event_constraints@/usr/src/debug/kernel-5.2.fc30/linux-5.2.18-200.fc30.x86_64/arch/x86/events/amd/core.c:0> 0 static void amd_put_event_constraints(struct cpu_hw_events *cpuc, struct perf_event *event) 2 { 3 if (amd_has_nb(cpuc) && amd_is_nb_event(&event->hw)) 4 __amd_put_nb_event_constraints(cpuc, event); 5 } PMU_FORMAT_ATTR(event, "config:0-7,32-35"); PMU_FORMAT_ATTR(umask, "config:8-15" ); [root@quaco ~]# perf probe amd_put_event_constraints:4 Added new event: probe:amd_put_event_constraints (on amd_put_event_constraints:4) You can now use it in all perf tools, such as: perf record -e probe:amd_put_event_constraints -aR sleep 1 [root@quaco ~]# [root@quaco ~]# perf probe -l probe:amd_put_event_constraints (on amd_put_event_constraints:4@arch/x86/events/amd/core.c) probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c) [root@quaco ~]# Using it: [root@quaco ~]# perf trace -e probe:* ^C[root@quaco ~]# Ok, Intel system here... :-) Fixes: 4cc9cec636e7 ("perf probe: Introduce lines walker interface") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199322107.8075.12659099000567865708.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to show ranges of variables in functions without entry_pcMasami Hiramatsu
[ Upstream commit af04dd2f8ebaa8fbd46f698714acbf43da14da45 ] Fix to show ranges of variables (--range and --vars option) in functions which DIE has only ranges but no entry_pc attribute. Without this fix: # perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> (No matched variables) With this fix: # perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> [VAL] int cpu @<clear_tasks_mm_cpumask+[0-35,317-317,2052-2059]> Committer testing: Before: [root@quaco ~]# perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> (No matched variables) [root@quaco ~]# After: [root@quaco ~]# perf probe --range -V clear_tasks_mm_cpumask Available variables at clear_tasks_mm_cpumask @<clear_tasks_mm_cpumask+0> [VAL] int cpu @<clear_tasks_mm_cpumask+[0-23,23-105,105-106,106-106,1843-1850,1850-1862]> [root@quaco ~]# Using it: [root@quaco ~]# perf probe clear_tasks_mm_cpumask cpu Added new event: probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask with cpu) You can now use it in all perf tools, such as: perf record -e probe:clear_tasks_mm_cpumask -aR sleep 1 [root@quaco ~]# perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c with cpu) [root@quaco ~]# [root@quaco ~]# perf trace -e probe:*cpumask ^C[root@quaco ~]# Fixes: 349e8d261131 ("perf probe: Add --range option to show a variable's location range") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199323018.8075.8179744380479673672.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to probe an inline function which has no entry pcMasami Hiramatsu
[ Upstream commit eb6933b29d20bf2c3053883d409a53f462c1a3ac ] Fix perf probe to probe an inlne function which has no entry pc or low pc but only has ranges attribute. This seems very rare case, but I could find a few examples, as same as probe_point_search_cb(), use die_entrypc() to get the entry address in probe_point_inline_cb() too. Without this patch: # perf probe -D __amd_put_nb_event_constraints Failed to get entry address of __amd_put_nb_event_constraints. Probe point '__amd_put_nb_event_constraints' not found. Error: Failed to add events. With this patch: # perf probe -D __amd_put_nb_event_constraints p:probe/__amd_put_nb_event_constraints amd_put_event_constraints+43 Committer testing: Before: [root@quaco ~]# perf probe -D __amd_put_nb_event_constraints Failed to get entry address of __amd_put_nb_event_constraints. Probe point '__amd_put_nb_event_constraints' not found. Error: Failed to add events. [root@quaco ~]# After: [root@quaco ~]# perf probe -D __amd_put_nb_event_constraints p:probe/__amd_put_nb_event_constraints _text+33789 [root@quaco ~]# Fixes: 4ea42b181434 ("perf: Add perf probe subcommand, a kprobe-event setup helper") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199320336.8075.16189530425277588587.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Walk function lines in lexical blocksMasami Hiramatsu
[ Upstream commit acb6a7047ac2146b723fef69ee1ab6b7143546bf ] Since some inlined functions are in lexical blocks of given function, we have to recursively walk through the DIE tree. Without this fix, perf-probe -L can miss the inlined functions which is in a lexical block (like if (..) { func() } case.) However, even though, to walk the lines in a given function, we don't need to follow the children DIE of inlined functions because those do not have any lines in the specified function. We need to walk though whole trees only if we walk all lines in a given file, because an inlined function can include another inlined function in the same file. Fixes: b0e9cb2802d4 ("perf probe: Fix to search nested inlined functions in CU") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157190836514.1859.15996864849678136353.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to list probe event with correct line numberMasami Hiramatsu
[ Upstream commit 3895534dd78f0fd4d3f9e05ee52b9cdd444a743e ] Since debuginfo__find_probe_point() uses dwarf_entrypc() for finding the entry address of the function on which a probe is, it will fail when the function DIE has only ranges attribute. To fix this issue, use die_entrypc() instead of dwarf_entrypc(). Without this fix, perf probe -l shows incorrect offset: # perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask+18446744071579263632@work/linux/linux/kernel/cpu.c) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask+18446744071579263752@work/linux/linux/kernel/cpu.c) With this: # perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@work/linux/linux/kernel/cpu.c) probe:clear_tasks_mm_cpumask_1 (on clear_tasks_mm_cpumask:21@work/linux/linux/kernel/cpu.c) Committer testing: Before: [root@quaco ~]# perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask+18446744071579765152@kernel/cpu.c) [root@quaco ~]# After: [root@quaco ~]# perf probe -l probe:clear_tasks_mm_cpumask (on clear_tasks_mm_cpumask@kernel/cpu.c) [root@quaco ~]# Fixes: 1d46ea2a6a40 ("perf probe: Fix listing incorrect line number with inline function") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157199321227.8075.14655572419136993015.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf probe: Fix to find range-only function instanceMasami Hiramatsu
[ Upstream commit b77afa1f810f37bd8a36cb1318178dfe2d7af6b6 ] Fix die_is_func_instance() to find range-only function instance. In some case, a function instance can be made without any low PC or entry PC, but only with address ranges by optimization. (e.g. cold text partially in "text.unlikely" section) To find such function instance, we have to check the range attribute too. Fixes: e1ecbbc3fa83 ("perf probe: Fix to handle optimized not-inlined functions") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/157190835669.1859.8368628035930950596.stgit@devnote2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf report: Add warning when libunwind not compiled inJin Yao
[ Upstream commit 800d3f561659b5436f8c57e7c26dd1f6928b5615 ] We received a user report that call-graph DWARF mode was enabled in 'perf record' but 'perf report' didn't unwind the callstack correctly. The reason was, libunwind was not compiled in. We can use 'perf -vv' to check the compiled libraries but it would be valuable to report a warning to user directly (especially valuable for a perf newbie). The warning is: Warning: Please install libunwind development packages during the perf build. Both TUI and stdio are supported. Signed-off-by: Jin Yao <yao.jin@linux.intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@linux.intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/20191011022122.26369-1-yao.jin@linux.intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31perf test: Report failure for mmap eventsLeo Yan
[ Upstream commit 6add129c5d9210ada25217abc130df0b7096ee02 ] When fail to mmap events in task exit case, it misses to set 'err' to -1; thus the testing will not report failure for it. This patch sets 'err' to -1 when fails to mmap events, thus Perf tool can report correct result. Fixes: d723a55096b8 ("perf test: Add test case for checking number of EXIT events") Signed-off-by: Leo Yan <leo.yan@linaro.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lore.kernel.org/lkml/20191011091942.29841-1-leo.yan@linaro.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-31tools/power/cpupower: Fix initializer override in hsw_ext_cstatesNathan Chancellor
[ Upstream commit 7e5705c635ecfccde559ebbbe1eaf05b5cc60529 ] When building cpupower with clang, the following warning appears: utils/idle_monitor/hsw_ext_idle.c:42:16: warning: initializer overrides prior initialization of this subobject [-Winitializer-overrides] .desc = N_("Processor Package C2"), ^~~~~~~~~~~~~~~~~~~~~~ ./utils/helpers/helpers.h:25:33: note: expanded from macro 'N_' #define N_(String) gettext_noop(String) ^~~~~~ ./utils/helpers/helpers.h:23:30: note: expanded from macro 'gettext_noop' #define gettext_noop(String) String ^~~~~~ utils/idle_monitor/hsw_ext_idle.c:41:16: note: previous initialization is here .desc = N_("Processor Package C9"), ^~~~~~~~~~~~~~~~~~~~~~ ./utils/helpers/helpers.h:25:33: note: expanded from macro 'N_' #define N_(String) gettext_noop(String) ^~~~~~ ./utils/helpers/helpers.h:23:30: note: expanded from macro 'gettext_noop' #define gettext_noop(String) String ^~~~~~ 1 warning generated. This appears to be a copy and paste or merge mistake because the name and id fields both have PC9 in them, not PC2. Remove the second assignment to fix the warning. Fixes: 7ee767b69b68 ("cpupower: Add Haswell family 0x45 specific idle monitor to show PC8,9,10 states") Link: https://github.com/ClangBuiltLinux/linux/issues/718 Signed-off-by: Nathan Chancellor <natechancellor@gmail.com> Signed-off-by: Shuah Khan <skhan@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01usbip: tools: fix fd leakage in the function of read_attr_usbip_statusHewenliang
commit 26a4d4c00f85cb844dd11dd35e848b079c2f5e8f upstream. We should close the fd before the return of read_attr_usbip_status. Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with vudc backend") Signed-off-by: Hewenliang <hewenliang4@huawei.com> Cc: stable <stable@vger.kernel.org> Link: https://lore.kernel.org/r/20191025043515.20053-1-hewenliang4@huawei.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-01x86/insn: Fix awk regexp warningsAlexander Kapshuk
commit 700c1018b86d0d4b3f1f2d459708c0cdf42b521d upstream. gawk 5.0.1 generates the following regexp warnings: GEN /home/sasha/torvalds/tools/objtool/arch/x86/lib/inat-tables.c awk: ../arch/x86/tools/gen-insn-attr-x86.awk:260: warning: regexp escape sequence `\:' is not a known regexp operator awk: ../arch/x86/tools/gen-insn-attr-x86.awk:350: (FILENAME=../arch/x86/lib/x86-opcode-map.txt FNR=41) warning: regexp escape sequence `\&' is not a known regexp operator Ealier versions of gawk are not known to generate these warnings. The gawk manual referenced below does not list characters ':' and '&' as needing escaping, so 'unescape' them. See https://www.gnu.org/software/gawk/manual/html_node/Escape-Sequences.html for more info. Running diff on the output generated by the script before and after applying the patch reported no differences. [ bp: Massage commit message. ] [ Caught the respective tools header discrepancy. ] Reported-by: kbuild test robot <lkp@intel.com> Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com> Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: x86-ml <x86@kernel.org> Link: https://lkml.kernel.org/r/20190924044659.3785-1-alexander.kapshuk@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-12-01ACPICA: Use %d for signed int print formatting instead of %uColin Ian King
[ Upstream commit f8ddf49b420112e28bdd23d7ad52d7991a0ccbe3 ] Fix warnings found using static analysis with cppcheck, use %d printf format specifier for signed ints rather than %u Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Erik Schmauss <erik.schmauss@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01selftests/powerpc/cache_shape: Fix out-of-tree buildMichael Ellerman
[ Upstream commit 69f8117f17b332a68cd8f4bf8c2d0d3d5b84efc5 ] Use TEST_GEN_PROGS and don't redefine all, this makes the out-of-tree build work. We need to move the extra dependencies below the include of lib.mk, because it adds the $(OUTPUT) prefix if it's defined. We can also drop the clean rule, lib.mk does it for us. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01selftests/powerpc/switch_endian: Fix out-of-tree buildMichael Ellerman
[ Upstream commit 266bac361d5677e61a6815bd29abeb3bdced2b07 ] For the out-of-tree build to work we need to tell switch_endian_test to look for check-reversed.S in $(OUTPUT). Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01selftests/powerpc/signal: Fix out-of-tree buildJoel Stanley
[ Upstream commit 27825349d7b238533a47e3d98b8bb0efd886b752 ] We should use TEST_GEN_PROGS, not TEST_PROGS. That tells the selftests makefile (lib.mk) that those tests are generated (built), and so it adds the $(OUTPUT) prefix for us, making the out-of-tree build work correctly. It also means we don't need our own clean rule, lib.mk does it. We also have to update the signal_tm rule to use $(OUTPUT). Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01selftests: watchdog: Fix error message.Jerry Hoemann
[ Upstream commit 04d5e4bd37516ad60854eb74592c7dbddd75d277 ] Printf's say errno but print the string version of error. Make consistent. Signed-off-by: Jerry Hoemann <jerry.hoemann@hpe.com> Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01selftests: watchdog: fix message when /dev/watchdog open failsShuah Khan (Samsung OSG)
[ Upstream commit 9a244229a4b850b11952a0df79607c69b18fd8df ] When /dev/watchdog open fails, watchdog exits with "watchdog not enabled" message. This is incorrect when open fails due to insufficient privilege. Fix message to clearly state the reason when open fails with EACCESS when a non-root user runs it. Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01selftests/ftrace: Fix to test kprobe $comm arg only if availableMasami Hiramatsu
[ Upstream commit 2452c96e617a0ff6fb2692e55217a3fa57a7322c ] Test $comm in kprobe-event argument syntax testcase only if it is supported on the kernel because $comm has been introduced 4.8 kernel. So on older stable kernel, it should be skipped. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01usbip: tools: fix atoi() on non-null terminated stringColin Ian King
[ Upstream commit e325808c0051b16729ffd472ff887c6cae5c6317 ] Currently the call to atoi is being passed a single char string that is not null terminated, so there is a potential read overrun along the stack when parsing for an integer value. Fix this by instead using a 2 char string that is initialized to all zeros to ensure that a 1 char read into the string is always terminated with a \0. Detected by cppcheck: "Invalid atoi() argument nr 1. A nul-terminated string is required." Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with vudc backend") Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-12-01tools: gpio: Correctly add make dependencies for gpio_utilsLaura Abbott
commit 0161a94e2d1c713bd34d72bc0239d87c31747bf7 upstream. gpio tools fail to build correctly with make parallelization: $ make -s -j24 ld: gpio-utils.o: file not recognized: file truncated make[1]: *** [/home/labbott/linux_upstream/tools/build/Makefile.build:145: lsgpio-in.o] Error 1 make: *** [Makefile:43: lsgpio-in.o] Error 2 make: *** Waiting for unfinished jobs.... This is because gpio-utils.o is used across multiple targets. Fix this by making gpio-utios.o a proper dependency. Cc: <stable@vger.kernel.org> Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-24tools: PCI: Fix broken pcitest compilationAlan Mikhak
[ Upstream commit 8a5e0af240e07dd3d4897eb8ff52aab757da7fab ] pcitest is currently broken due to the following compiler error and related warning. Fix by changing the run_test() function signature to return an integer result. pcitest.c: In function run_test: pcitest.c:143:9: warning: return with a value, in function returning void return (ret < 0) ? ret : 1 - ret; /* return 0 if test succeeded */ pcitest.c: In function main: pcitest.c:232:9: error: void value not ignored as it ought to be return run_test(test); Fixes: fef31ecaaf2c ("tools: PCI: Fix compilation warnings") Signed-off-by: Alan Mikhak <alan.mikhak@sifive.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Reviewed-by: Paul Walmsley <paul.walmsley@sifive.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-24tools: PCI: Fix compilation warningsGustavo Pimentel
[ Upstream commit fef31ecaaf2c5c54db85b35e893bf8abec96b93f ] Current compilation produces the following warnings: tools/pci/pcitest.c: In function 'run_test': tools/pci/pcitest.c:56:9: warning: unused variable 'time' [-Wunused-variable] double time; ^~~~ tools/pci/pcitest.c:55:25: warning: unused variable 'end' [-Wunused-variable] struct timespec start, end; ^~~ tools/pci/pcitest.c:55:18: warning: unused variable 'start' [-Wunused-variable] struct timespec start, end; ^~~~~ tools/pci/pcitest.c:146:1: warning: control reaches end of non-void function [-Wreturn-type] } ^ Fix them: - remove unused variables - change function return from int to void, since it's not used Signed-off-by: Gustavo Pimentel <gustavo.pimentel@synopsys.com> [lorenzo.pieralisi@arm.com: rewrote the commit log] Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Reviewed-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-24idr: Fix idr_get_next race with idr_removeMatthew Wilcox (Oracle)
commit 5c089fd0c73411f2170ab795c9ffc16718c7d007 upstream. If the entry is deleted from the IDR between the call to radix_tree_iter_find() and rcu_dereference_raw(), idr_get_next() will return NULL, which will end the iteration prematurely. We should instead continue to the next entry in the IDR. This only happens if the iteration is protected by the RCU lock. Most IDR users use a spinlock or semaphore to exclude simultaneous modifications. It was noticed once the PID allocator was converted to use the IDR, as it uses the RCU lock, but there may be other users elsewhere in the kernel. We can't use the normal pattern of calling radix_tree_deref_retry() (which catches both a retry entry in a leaf node and a node entry in the root) as the IDR supports storing entries which are unaligned, which will trigger an infinite loop if they are encountered. Instead, we have to explicitly check whether the entry is a retry entry. Fixes: 0a835c4f090a ("Reimplement IDR and IDA using the radix tree") Reported-by: Brendan Gregg <bgregg@netflix.com> Tested-by: Brendan Gregg <bgregg@netflix.com> Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12perf tools: Fix time sortingJiri Olsa
commit 722ddfde366fd46205456a9c5ff9b3359dc9a75e upstream. The final sort might get confused when the comparison is done over bigger numbers than int like for -s time. Check the following report for longer workloads: $ perf report -s time -F time,overhead --stdio Fix hist_entry__sort() to properly return int64_t and not possible cut int. Fixes: 043ca389a318 ("perf tools: Use hpp formats to sort final output") Signed-off-by: Jiri Olsa <jolsa@kernel.org> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Michael Petlan <mpetlan@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org # v3.16+ Link: http://lore.kernel.org/lkml/20191104232711.16055-1-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12tools: gpio: Use !building_out_of_srctree to determine srctreeShuah Khan
commit 4a6a6f5c4aeedb72db871d60bfcca89835f317aa upstream. make TARGETS=gpio kselftest fails with: Makefile:23: tools/build/Makefile.include: No such file or directory When the gpio tool make is invoked from tools Makefile, srctree is cleared and the current logic check for srctree equals to empty string to determine srctree location from CURDIR. When the build in invoked from selftests/gpio Makefile, the srctree is set to "." and the same logic used for srctree equals to empty is needed to determine srctree. Check building_out_of_srctree undefined as the condition for both cases to fix "make TARGETS=gpio kselftest" build failure. Cc: stable@vger.kernel.org Signed-off-by: Shuah Khan <skhan@linuxfoundation.org> Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-10selftests/powerpc: Fix compile error on tlbie_test due to newer gccDesnes A. Nunes do Rosario
commit 5b216ea1c40cf06eead15054c70e238c9bd4729e upstream. Newer versions of GCC (>= 9) demand that the size of the string to be copied must be explicitly smaller than the size of the destination. Thus, the NULL char has to be taken into account on strncpy. This will avoid the following compiling error: tlbie_test.c: In function 'main': tlbie_test.c:639:4: error: 'strncpy' specified bound 100 equals destination size strncpy(logdir, optarg, LOGDIR_NAME_SIZE); ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ cc1: all warnings being treated as errors Cc: stable@vger.kernel.org # v4.14 Signed-off-by: Desnes A. Nunes do Rosario <desnesn@linux.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Link: https://lore.kernel.org/r/20191003211010.9711-1-desnesn@linux.ibm.com [sandipan: Backported to v4.14] Signed-off-by: Sandipan Das <sandipan@linux.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-10selftests/powerpc: Add test case for tlbie vs mtpidr ordering issueAneesh Kumar K.V
commit 93cad5f789951eaa27c3392b15294b4e51253944 upstream. Cc: stable@vger.kernel.org # v4.14 Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com> [mpe: Some minor fixes to make it build] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Link: https://lore.kernel.org/r/20190924035254.24612-4-aneesh.kumar@linux.ibm.com [sandipan: Backported to v4.14] Signed-off-by: Sandipan Das <sandipan@linux.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-10selftests: net: reuseport_dualstack: fix uninitalized parameterWei Wang
[ Upstream commit d64479a3e3f9924074ca7b50bd72fa5211dca9c1 ] This test reports EINVAL for getsockopt(SOL_SOCKET, SO_DOMAIN) occasionally due to the uninitialized length parameter. Initialize it to fix this, and also use int for "test_family" to comply with the API standard. Fixes: d6a61f80b871 ("soreuseport: test mixed v4/v6 sockets") Reported-by: Maciej Żenczykowski <maze@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Wei Wang <weiwan@google.com> Cc: Craig Gallek <cgallek@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-10perf kmem: Fix memory leak in compact_gfp_flags()Yunfeng Ye
[ Upstream commit 1abecfcaa7bba21c9985e0136fa49836164dd8fd ] The memory @orig_flags is allocated by strdup(), it is freed on the normal path, but leak to free on the error path. Fix this by adding free(orig_flags) on the error path. Fixes: 0e11115644b3 ("perf kmem: Print gfp flags in human readable string") Signed-off-by: Yunfeng Ye <yeyunfeng@huawei.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Feilong Lin <linfeilong@huawei.com> Cc: Hu Shiyuan <hushiyuan@huawei.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/f9e9f458-96f3-4a97-a1d5-9feec2420e07@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-10perf c2c: Fix memory leak in build_cl_output()Yunfeng Ye
[ Upstream commit ae199c580da1754a2b051321eeb76d6dacd8707b ] There is a memory leak problem in the failure paths of build_cl_output(), so fix it. Signed-off-by: Yunfeng Ye <yeyunfeng@huawei.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Feilong Lin <linfeilong@huawei.com> Cc: Hu Shiyuan <hushiyuan@huawei.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lore.kernel.org/lkml/4d3c0178-5482-c313-98e1-f82090d2d456@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-06perf jevents: Fix period for Intel fixed countersAndi Kleen
[ Upstream commit 6bdfd9f118bd59cf0f85d3bf4b72b586adea17c1 ] The Intel fixed counters use a special table to override the JSON information. During this override the period information from the JSON file got dropped, which results in inst_retired.any and similar running with frequency mode instead of a period. Just specify the expected period in the table. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Link: http://lore.kernel.org/lkml/20190927233546.11533-2-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-11-06perf map: Fix overlapped map handlingSteve MacLean
[ Upstream commit ee212d6ea20887c0ef352be8563ca13dbf965906 ] Whenever an mmap/mmap2 event occurs, the map tree must be updated to add a new entry. If a new map overlaps a previous map, the overlapped section of the previous map is effectively unmapped, but the non-overlapping sections are still valid. maps__fixup_overlappings() is responsible for creating any new map entries from the previously overlapped map. It optionally creates a before and an after map. When creating the after map the existing code failed to adjust the map.pgoff. This meant the new after map would incorrectly calculate the file offset for the ip. This results in incorrect symbol name resolution for any ip in the after region. Make maps__fixup_overlappings() correctly populate map.pgoff. Add an assert that new mapping matches old mapping at the beginning of the after map. Committer-testing: Validated correct parsing of libcoreclr.so symbols from .NET Core 3.0 preview9 (which didn't strip symbols). Preparation: ~/dotnet3.0-preview9/dotnet new webapi -o perfSymbol cd perfSymbol ~/dotnet3.0-preview9/dotnet publish perf record ~/dotnet3.0-preview9/dotnet \ bin/Debug/netcoreapp3.0/publish/perfSymbol.dll ^C Before: perf script --show-mmap-events 2>&1 | grep -e MMAP -e unknown |\ grep libcoreclr.so | head -n 4 dotnet 1907 373352.698780: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615726000(0x768000) @ 0 08:02 5510620 765057155]: \ r-xp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701091: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615974000(0x1000) @ 0x24e000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701241: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615c42000(0x1000) @ 0x51c000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.705249: 250000 cpu-clock: \ 7fe6159a1f99 [unknown] \ (.../3.0.0-preview9-19423-09/libcoreclr.so) After: perf script --show-mmap-events 2>&1 | grep -e MMAP -e unknown |\ grep libcoreclr.so | head -n 4 dotnet 1907 373352.698780: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615726000(0x768000) @ 0 08:02 5510620 765057155]: \ r-xp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701091: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615974000(0x1000) @ 0x24e000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so dotnet 1907 373352.701241: PERF_RECORD_MMAP2 1907/1907: \ [0x7fe615c42000(0x1000) @ 0x51c000 08:02 5510620 765057155]: \ rwxp .../3.0.0-preview9-19423-09/libcoreclr.so All the [unknown] symbols were resolved. Signed-off-by: Steve MacLean <Steve.MacLean@Microsoft.com> Tested-by: Brian Robbins <brianrob@microsoft.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Davidlohr Bueso <dave@stgolabs.net> Cc: Eric Saint-Etienne <eric.saint.etienne@oracle.com> Cc: John Keeping <john@metanate.com> Cc: John Salem <josalem@microsoft.com> Cc: Leo Yan <leo.yan@linaro.org> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Song Liu <songliubraving@fb.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom McDonald <thomas.mcdonald@microsoft.com> Link: http://lore.kernel.org/lkml/BN8PR21MB136270949F22A6A02335C238F7800@BN8PR21MB1362.namprd21.prod.outlook.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
