path: root/tools
2017-03-23Add a eBPF helper function to retrieve socket uidChenbo Feng
Returns the owner uid of the socket inside a sk_buff. This is useful to perform per-UID accounting of network traffic or per-UID packet filtering. The socket need to be a fullsock otherwise overflowuid is returned. Signed-off-by: Chenbo Feng <fengc@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-23Add a helper function to get socket cookie in eBPFChenbo Feng
Retrieve the socket cookie generated by sock_gen_cookie() from a sk_buff with a known socket. Generates a new cookie if one was not yet set.If the socket pointer inside sk_buff is NULL, 0 is returned. The helper function coud be useful in monitoring per socket networking traffic statistics and provide a unique socket identifier per namespace. Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Willem de Bruijn <willemb@google.com> Signed-off-by: Chenbo Feng <fengc@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/genet/bcmmii.c drivers/net/hyperv/netvsc.c kernel/bpf/hashtab.c Almost entirely overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Several netfilter fixes from Pablo and the crew: - Handle fragmented packets properly in netfilter conntrack, from Florian Westphal. - Fix SCTP ICMP packet handling, from Ying Xue. - Fix big-endian bug in nftables, from Liping Zhang. - Fix alignment of fake conntrack entry, from Steven Rostedt. 2) Fix feature flags setting in fjes driver, from Taku Izumi. 3) Openvswitch ipv6 tunnel source address not set properly, from Or Gerlitz. 4) Fix jumbo MTU handling in amd-xgbe driver, from Thomas Lendacky. 5) sk->sk_frag.page not released properly in some cases, from Eric Dumazet. 6) Fix RTNL deadlocks in nl80211, from Johannes Berg. 7) Fix erroneous RTNL lockdep splat in crypto, from Herbert Xu. 8) Cure improper inflight handling during AF_UNIX GC, from Andrey Ulanov. 9) sch_dsmark doesn't write to packet headers properly, from Eric Dumazet. 10) Fix SCM_TIMESTAMPING_OPT_STATS handling in TCP, from Soheil Hassas Yeganeh. 11) Add some IDs for Motorola qmi_wwan chips, from Tony Lindgren. 12) Fix nametbl deadlock in tipc, from Ying Xue. 13) GRO and LRO packets not counted correctly in mlx5 driver, from Gal Pressman. 14) Fix reset of internal PHYs in bcmgenet, from Doug Berger. 15) Fix hashmap allocation handling, from Alexei Starovoitov. 16) nl_fib_input() needs stronger netlink message length checking, from Eric Dumazet. 17) Fix double-free of sk->sk_filter during sock clone, from Daniel Borkmann. 18) Fix RX checksum offloading in aquantia driver, from Pavel Belous. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (85 commits) net:ethernet:aquantia: Fix for RX checksum offload. amd-xgbe: Fix the ECC-related bit position definitions sfc: cleanup a condition in efx_udp_tunnel_del() Bluetooth: btqcomsmd: fix compile-test dependency inet: frag: release spinlock before calling icmp_send() tcp: initialize icsk_ack.lrcvtime at session start time genetlink: fix counting regression on ctrl_dumpfamily() socket, bpf: fix sk_filter use after free in sk_clone_lock ipv4: provide stronger user input validation in nl_fib_input() bpf: fix hashmap extra_elems logic enic: update enic maintainers net: bcmgenet: remove bcmgenet_internal_phy_setup() ipv6: make sure to initialize sockc.tsflags before first use fjes: Do not load fjes driver if extended socket device is not power on. fjes: Do not load fjes driver if system does not have extended socket device. net/mlx5e: Count LRO packets correctly net/mlx5e: Count GSO packets correctly net/mlx5: Increase number of max QPs in default profile net/mlx5e: Avoid supporting udp tunnel port ndo for VF reps net/mlx5e: Use the proper UAPI values when offloading TC vlan actions ...
2017-03-22bpf: Add tests for map-in-mapMartin KaFai Lau
Test cases for array of maps and hash of maps. Signed-off-by: Martin KaFai Lau <kafai@fb.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-22bpf: fix hashmap extra_elems logicAlexei Starovoitov
In both kmalloc and prealloc mode the bpf_map_update_elem() is using per-cpu extra_elems to do atomic update when the map is full. There are two issues with it. The logic can be misused, since it allows max_entries+num_cpus elements to be present in the map. And alloc_extra_elems() at map creation time can fail percpu alloc for large map values with a warn: WARNING: CPU: 3 PID: 2752 at ../mm/percpu.c:892 pcpu_alloc+0x119/0xa60 illegal size (32824) or align (8) for percpu allocation The fixes for both of these issues are different for kmalloc and prealloc modes. For prealloc mode allocate extra num_possible_cpus elements and store their pointers into extra_elems array instead of actual elements. Hence we can use these hidden(spare) elements not only when the map is full but during bpf_map_update_elem() that replaces existing element too. That also improves performance, since pcpu_freelist_pop/push is avoided. Unfortunately this approach cannot be used for kmalloc mode which needs to kfree elements after rcu grace period. Therefore switch it back to normal kmalloc even when full and old element exists like it was prior to commit 6c9059817432 ("bpf: pre-allocate hash map elements"). Add tests to check for over max_entries and large map values. Reported-by: Dave Jones <davej@codemonkey.org.uk> Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements") Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Martin KaFai Lau <kafai@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-21selftests/bpf: fix broken build, take 2Zi Shen Lim
Merge of 'linux-kselftest-4.11-rc1': 1. Partially removed use of 'test_objs' target, breaking force rebuild of BPFOBJ, introduced in commit d498f8719a09 ("bpf: Rebuild bpf.o for any dependency update"). Update target so dependency on BPFOBJ is restored. 2. Introduced commit 2047f1d8ba28 ("selftests: Fix the .c linking rule") which fixes order of LDLIBS. Commit d02d8986a768 ("bpf: Always test unprivileged programs") added libcap dependency into CFLAGS. Use LDLIBS instead to fix linking of test_verifier. 3. Introduced commit d83c3ba0b926 ("selftests: Fix selftests build to just build, not run tests"). Reordering the Makefile allows us to remove the 'all' target. Tested both: selftests/bpf$ make and selftests$ make TARGETS=bpf on Ubuntu 16.04.2. Signed-off-by: Zi Shen Lim <zlim.lnx@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Tested-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Tested-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-17Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Thomas Gleixner: "A set of perf related fixes: - fix a CR4.PCE propagation issue caused by usage of mm instead of active_mm and therefore propagated the wrong value. - perf core fixes, which plug a use-after-free issue and make the event inheritance on fork more robust. - a tooling fix for symbol handling" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf symbols: Fix symbols__fixup_end heuristic for corner cases x86/perf: Clarify why x86_pmu_event_mapped() isn't racy x86/perf: Fix CR4.PCE propagation to use active_mm instead of mm perf/core: Better explain the inherit magic perf/core: Simplify perf_event_free_task() perf/core: Fix event inheritance on fork() perf/core: Fix use-after-free in perf_release()
2017-03-17perf symbols: Fix symbols__fixup_end heuristic for corner casesDaniel Borkmann
The current symbols__fixup_end() heuristic for the last entry in the rb tree is suboptimal as it leads to not being able to recognize the symbol in the call graph in a couple of corner cases, for example: i) If the symbol has a start address (f.e. exposed via kallsyms) that is at a page boundary, then the roundup(curr->start, 4096) for the last entry will result in curr->start == curr->end with a symbol length of zero. ii) If the symbol has a start address that is shortly before a page boundary, then also here, curr->end - curr->start will just be very few bytes, where it's unrealistic that we could perform a match against. Instead, change the heuristic to roundup(curr->start, 4096) + 4096, so that we can catch such corner cases and have a better chance to find that specific symbol. It's still just best effort as the real end of the symbol is unknown to us (and could even be at a larger offset than the current range), but better than the current situation. Alexei reported that he recently run into case i) with a JITed eBPF program (these are all page aligned) as the last symbol which wasn't properly shown in the call graph (while other eBPF program symbols in the rb tree were displayed correctly). Since this is a generic issue, lets try to improve the heuristic a bit. Reported-and-Tested-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Fixes: 2e538c4a1847 ("perf tools: Improve kernel/modules symbol lookup") Link: http://lkml.kernel.org/r/bb5c80d27743be6f12afc68405f1956a330e1bc9.1489614365.git.daniel@iogearbox.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2017-03-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/broadcom/genet/bcmgenet.c net/core/sock.c Conflicts were overlapping changes in bcmgenet and the lockdep handling of sockets. Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Ensure that mtu is at least IPV6_MIN_MTU in ipv6 VTI tunnel driver, from Steffen Klassert. 2) Fix crashes when user tries to get_next_key on an LPM bpf map, from Alexei Starovoitov. 3) Fix detection of VLAN fitlering feature for bnx2x VF devices, from Michal Schmidt. 4) We can get a divide by zero when TCP socket are morphed into listening state, fix from Eric Dumazet. 5) Fix socket refcounting bugs in skb_complete_wifi_ack() and skb_complete_tx_timestamp(). From Eric Dumazet. 6) Use after free in dccp_feat_activate_values(), also from Eric Dumazet. 7) Like bonding team needs to use ETH_MAX_MTU as netdev->max_mtu, from Jarod Wilson. 8) Fix use after free in vrf_xmit(), from David Ahern. 9) Don't do UDP Fragmentation Offload on IPComp ipsec packets, from Alexey Kodanev. 10) Properly check napi_complete_done() return value in order to decide whether to re-enable IRQs or not in amd-xgbe driver, from Thomas Lendacky. 11) Fix double free of hwmon device in marvell phy driver, from Andrew Lunn. 12) Don't crash on malformed netlink attributes in act_connmark, from Etienne Noss. 13) Don't remove routes with a higher metric in ipv6 ECMP route replace, from Sabrina Dubroca. 14) Don't write into a cloned SKB in ipv6 fragmentation handling, from Florian Westphal. 15) Fix routing redirect races in dccp and tcp, basically the ICMP handler can't modify the socket's cached route in it's locked by the user at this moment. From Jon Maxwell. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (108 commits) qed: Enable iSCSI Out-of-Order qed: Correct out-of-bound access in OOO history qed: Fix interrupt flags on Rx LL2 qed: Free previous connections when releasing iSCSI qed: Fix mapping leak on LL2 rx flow qed: Prevent creation of too-big u32-chains qed: Align CIDs according to DORQ requirement mlxsw: reg: Fix SPVMLR max record count mlxsw: reg: Fix SPVM max record count net: Resend IGMP memberships upon peer notification. dccp: fix memory leak during tear-down of unsuccessful connection request tun: fix premature POLLOUT notification on tun devices dccp/tcp: fix routing redirect race ucc/hdlc: fix two little issue vxlan: fix ovs support net: use net->count to check whether a netns is alive or not bridge: drop netfilter fake rtable unconditionally ipv6: avoid write to a possibly cloned skb net: wimax/i2400m: fix NULL-deref at probe isdn/gigaset: fix NULL-deref at probe ...
2017-03-13Merge tag 'powerpc-4.11-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull some more powerpc fixes from Michael Ellerman: "The main item is the addition of the Power9 Machine Check handler. This was delayed to make sure some details were correct, and is as minimal as possible. The rest is small fixes, two for the Power9 PMU, two dealing with obscure toolchain problems, two for the PowerNV IOMMU code (used by VFIO), and one to fix a crash on 32-bit machines with macio devices due to missing dma_ops. Thanks to: Alexey Kardashevskiy, Cyril Bur, Larry Finger, Madhavan Srinivasan, Nicholas Piggin" * tag 'powerpc-4.11-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc/64s: POWER9 machine check handler powerpc/64s: allow machine check handler to set severity and initiator powerpc/64s: fix handling of non-synchronous machine checks powerpc/pmac: Fix crash in dma-mapping.h with NULL dma_ops powerpc/powernv/ioda2: Update iommu table base on ownership change powerpc/powernv/ioda2: Gracefully fail if too many TCE levels requested selftests/powerpc: Replace stxvx and lxvx with stxvd2x/lxvd2x powerpc/perf: Handle sdar_mode for marked event in power9 powerpc/perf: Fix perf_get_data_addr() for power9 DD1 powerpc/boot: Fix zImage TOC alignment
2017-03-12selftests/bpf: fix broken buildAlexei Starovoitov
Recent merge of 'linux-kselftest-4.11-rc1' tree broke bpf test build. None of the tests were building and test_verifier.c had tons of compiler errors. Fix it and add #ifdef CAP_IS_SUPPORTED to support old versions of libcap. Tested on centos 6.8 and 7 Signed-off-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Tested-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-09userfaultfd: selftest: vm: allow to build in vm/ directoryAndrea Arcangeli
linux/tools/testing/selftests/vm $ make gcc -Wall -I ../../../../usr/include compaction_test.c -lrt -o /compaction_test /usr/lib/gcc/x86_64-pc-linux-gnu/4.9.4/../../../../x86_64-pc-linux-gnu/bin/ld: cannot open output file /compaction_test: Permission denied collect2: error: ld returned 1 exit status make: *** [../lib.mk:54: /compaction_test] Error 1 Since commit a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT") selftests/vm build fails if run from the "selftests/vm" directory, but it works in the selftests/ directory. It's quicker to be able to do a local vm-only build after a tree wipe and this patch allows for it again. Link: http://lkml.kernel.org/r/20170302173738.18994-4-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-09scripts/spelling.txt: add "overide" pattern and fix typo instancesMasahiro Yamada
Fix typos and add the following to the scripts/spelling.txt: overide||override While we are here, fix the doubled "address" in the touched line Documentation/devicetree/bindings/regulator/ti-abb-regulator.txt. Also, fix the comment block style in the touched hunks in drivers/media/dvb-frontends/drx39xyj/drx_driver.h. Link: http://lkml.kernel.org/r/1481573103-11329-21-git-send-email-yamada.masahiro@socionext.com Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-09selftests/powerpc: Replace stxvx and lxvx with stxvd2x/lxvd2xCyril Bur
On POWER8 (ISA 2.07) lxvx and stxvx are defined to be extended mnemonics of lxvd2x and stxvd2x. For POWER9 (ISA 3.0) the HW architects in their infinite wisdom made lxvx and stxvx instructions in their own right. POWER9 aware GCC will use the POWER9 instruction for lxvx and stxvx causing these selftests to fail on POWER8. Further compounding the issue, because of the way -mvsx works it will cause the power9 instructions to be used regardless of -mcpu=power8 to GCC or -mpower8 to AS. The safest way to address the problem for now is to not use the extended mnemonic. We don't care how the CPU loads the values from memory since the tests only performs register comparisons, so using stdvd2x/lxvd2x does not impact the test. Signed-off-by: Cyril Bur <cyrilbur@gmail.com> Acked-by: Balbir Singh<bsingharora@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-03-08Merge tag 'ktest-v4.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest fixes from Steven Rostedt: "Greg Kroah-Hartman reported to me that the ktest of v4.11-rc1 locked up in an infinite loop while doing the make mrproper. Looking into the cause I noticed that a recent update to the function run_command (used for running all shell commands, including "make mrproper") changed the internal loop to use the function wait_for_input. The wait_for_input function uses select to look at two file descriptors. One is the file descriptor of the command it is running, the other is STDIN. The STDIN check was not checking the return status of the sysread call, and was also just writing a lot of data into syswrite without regard to the size of the data read. Changing the code to check the return status of sysread, and also to still process the passed in descriptor data without looping back to the select fixed Greg's problem. While looking at this code I also realized that the loop did not honor the timeout if STDIN always had input (or for some reason return error). this could prevent wait_for_input to timeout on the file descriptor it is suppose to be waiting for. That is fixed too" * tag 'ktest-v4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Make sure wait_for_input does honor the timeout ktest: Fix while loop in wait_for_input
2017-03-08ktest: Make sure wait_for_input does honor the timeoutSteven Rostedt (VMware)
The function wait_for_input takes in a timeout, and even has a default timeout. But if for some reason the STDIN descriptor keeps sending in data, the function will never time out. The timout is to wait for the data from the passed in file descriptor, not for STDIN. Adding a test in the case where there's no data from the passed in file descriptor that checks to see if the timeout passed, will ensure that it will timeout properly even if there's input in STDIN. Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2017-03-08ktest: Fix while loop in wait_for_inputSteven Rostedt (VMware)
The run_command function was changed to use the wait_for_input function to allow having a timeout if the command to run takes too much time. There was a bug in the wait_for_input where it could end up going into an infinite loop. There's two issues here. One is that the return value of the sysread wasn't used for the write (to write a proper size), and that it should continue processing the passed in file descriptor too even if there was input. There was no check for error, if for some reason STDIN returned an error, the function would go into an infinite loop and never exit. Reported-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Tested-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Fixes: 6e98d1b4415f ("ktest: Add timeout to ssh command") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
2017-03-07Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes and minor updates all over the place: - an SGI/UV fix - a defconfig update - a build warning fix - move the boot_params file to the arch location in debugfs - a pkeys fix - selftests fix - boot message fixes - sparse fixes - a resume warning fix - ioapic hotplug fixes - reboot quirks ... plus various minor cleanups" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/build/x86_64_defconfig: Enable CONFIG_R8169 x86/reboot/quirks: Add ASUS EeeBook X205TA/W reboot quirk x86/hpet: Prevent might sleep splat on resume x86/boot: Correct setup_header.start_sys name x86/purgatory: Fix sparse warning, symbol not declared x86/purgatory: Make functions and variables static x86/events: Remove last remnants of old filenames x86/pkeys: Check against max pkey to avoid overflows x86/ioapic: Split IOAPIC hot-removal into two steps x86/PCI: Implement pcibios_release_device to release IRQ from IOAPIC x86/intel_rdt: Remove duplicate inclusion of linux/cpu.h x86/vmware: Remove duplicate inclusion of asm/timer.h x86/hyperv: Hide unused label x86/reboot/quirks: Add ASUS EeeBook X205TA reboot quirk x86/platform/uv/BAU: Fix HUB errors by remove initial write to sw-ack register x86/selftests: Add clobbers for int80 on x86_64 x86/apic: Simplify enable_IR_x2apic(), remove try_to_enable_IR() x86/apic: Fix a warning message in logical CPU IDs allocation x86/kdebugfs: Move boot params hierarchy under (debugfs)/x86/
2017-03-07Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core fixes from Ingo Molnar: "A couple of sched.h splitup related build fixes, plus an objtool fix" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: objtool: Fix another GCC jump table detection issue drivers/char/nwbutton: Fix build breakage caused by include file reshuffling h8300: Fix build breakage caused by header file changes avr32: Fix build error caused by include file reshuffling
2017-03-07Merge branch 'idr-4.11' of git://git.infradead.org/users/willy/linux-daxLinus Torvalds
Pull idr fix (and new tests) from Matthew Wilcox: "One urgent patch in here; freeing the correct IDA bitmap. Everything else is changes to the test suite" * 'idr-4.11' of git://git.infradead.org/users/willy/linux-dax: radix tree test suite: Specify -m32 in LDFLAGS too ida: Free correct IDA bitmap radix tree test suite: Depend on Makefile and quieten grep radix tree test suite: Fix build with --as-needed radix tree test suite: Build 32 bit binaries radix tree test suite: Add performance test for radix_tree_join() radix tree test suite: Add performance test for radix_tree_split() radix tree test suite: Add performance benchmarks radix tree test suite: Add test for radix_tree_clear_tags() radix tree test suite: Add tests for ida_simple_get() and ida_simple_remove() radix tree test suite: Add test for idr_get_next()
2017-03-07Merge tag 'powerpc-4.11-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: "Five fairly small fixes for things that went in this cycle. A fairly large patch to rework the CAS logic on Power9, necessitated by a late change to the firmware API, and we can't boot without it. Three fixes going to stable, allowing more instructions to be emulated on LE, fixing a boot crash on 32-bit Freescale BookE machines, and the OPAL XICS workaround. And a patch from me to sort the selects under CONFIG PPC. Annoying churn, but worth it in the long run, and best for it to go in now to avoid conflicts. Thanks to: Alexey Kardashevskiy, Anton Blanchard, Balbir Singh, Gautham R. Shenoy, Laurentiu Tudor, Nicholas Piggin, Paul Mackerras, Ravi Bangoria, Sachin Sant, Shile Zhang, Suraj Jitindar Singh" * tag 'powerpc-4.11-3' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc: Sort the selects under CONFIG_PPC powerpc/64: Fix L1D cache shape vector reporting L1I values powerpc/64: Avoid panic during boot due to divide by zero in init_cache_info() powerpc: Update to new option-vector-5 format for CAS powerpc: Parse the command line before calling CAS powerpc/xics: Work around limitations of OPAL XICS priority handling powerpc/64: Fix checksum folding in csum_add() powerpc/powernv: Fix opal tracepoints with JUMP_LABEL=n powerpc/booke: Fix boot crash due to null hugepd powerpc: Fix compiling a BE kernel with a powerpc64le toolchain selftest/powerpc: Fix false failures for skipped tests powerpc/powernv: Fix bug due to labeling ambiguity in power_enter_stop powerpc/64: Invalidate process table caching after setting process table powerpc: emulate_step() tests for load/store instructions powerpc: Emulation support for load/store instructions on LE
2017-03-07radix tree test suite: Specify -m32 in LDFLAGS tooMatthew Wilcox
Michael's patch to use the default make rule for linking and the patch from Rehas to use -m32 if building a 32-bit test-suite on a 64-bit platform don't work well together. Reported-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07ida: Free correct IDA bitmapMatthew Wilcox
There's a relatively rare race where we look at the per-cpu preallocated IDA bitmap, see it's NULL, allocate a new one, and atomically update it. If the kmalloc() happened to sleep and we were rescheduled to a different CPU, or an interrupt came in at the exact right time, another task might have successfully allocated a bitmap and already deposited it. I forgot what the semantics of cmpxchg() were and ended up freeing the wrong bitmap leading to KASAN reporting a use-after-free. Dmitry found the bug with syzkaller & wrote the patch. I wrote the test case that will reproduce the bug without his patch being applied. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Depend on Makefile and quieten grepMatthew Wilcox
Changing the CFLAGS in the Makefile didn't always lead to a recompilation because the OFILES didn't depend on the Makefile. Also, after doing make clean, grep would still complain about a missing map-shift.h; we need -s as well as -q. Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Fix build with --as-neededMichael Ellerman
Currently the radix tree test suite doesn't build with toolchains that use --as-needed by default, for example Ubuntu's: cc -I. -I../../include -g -O2 -Wall -D_LGPL_SOURCE -fsanitize=address -lpthread -lurcu main.o ... -o main /usr/bin/ld: regression1.o: undefined reference to symbol 'pthread_join@@GLIBC_2.17' /lib/powerpc64le-linux-gnu/libpthread.so.0: error adding symbols: DSO missing from command line collect2: error: ld returned 1 exit status This is caused by the custom makefile rules placing LDFLAGS before the .o files that need the libraries. We could fix it by using --no-as-needed, or rewriting the custom rules. But we can also just drop the custom rules and move the libraries to LDLIBS, and then the default rules work correctly - with the one caveat that we need to add -fsanitize=address to LDFLAGS because that must be passed to the linker as well as the compiler. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Build 32 bit binariesRehas Sachdeva
Add option 'make BUILD=32' for building 32-bit binaries. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Add performance test for radix_tree_join()Rehas Sachdeva
2017-03-07radix tree test suite: Add performance test for radix_tree_split()Rehas Sachdeva
2017-03-07radix tree test suite: Add performance benchmarksRehas Sachdeva
Add performance benchmarks for radix tree insertion, tagging and deletion. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Add test for radix_tree_clear_tags()Rehas Sachdeva
Assert that radix_tree_clear_tags() clears the tags on the passed node and slot. Assert that the case where the radix tree has only one entry at index zero and the node is NULL, is also handled. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Add tests for ida_simple_get() and ida_simple_remove()Rehas Sachdeva
Assert that ida_simple_get() allocates an id in the passed range or returns error on failure, and ida_simple_remove() releases an allocated id. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07radix tree test suite: Add test for idr_get_next()Rehas Sachdeva
Assert that idr_get_next() returns the next populated entry in the tree with an ID greater than or equal to the value pointed to by @nextid argument. Signed-off-by: Rehas Sachdeva <aquannie@gmail.com> Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
2017-03-07objtool: Fix another GCC jump table detection issueJosh Poimboeuf
Arnd Bergmann reported a (false positive) objtool warning: drivers/infiniband/sw/rxe/rxe_resp.o: warning: objtool: rxe_responder()+0xfe: sibling call from callable instruction with changed frame pointer The issue is in find_switch_table(). It tries to find a switch statement's jump table by walking backwards from an indirect jump instruction, looking for a relocation to the .rodata section. In this case it stopped walking prematurely: the first .rodata relocation it encountered was for a variable (resp_state_name) instead of a jump table, so it just assumed there wasn't a jump table. The fix is to ignore any .rodata relocation which refers to an ELF object symbol. This works because the jump tables are anonymous and have no symbols associated with them. Reported-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 3732710ff6f2 ("objtool: Improve rare switch jump table pattern detection") Link: http://lkml.kernel.org/r/20170302225723.3ndbsnl4hkqbne7a@treble Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-06tools: hv: Add clean up function for Ubuntu configHaiyang Zhang
This patch adds a function to clean up duplicate config info on Ubuntu. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-04Merge tag 'kvm-4.11-2' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull more KVM updates from Radim Krčmář: "Second batch of KVM changes for the 4.11 merge window: PPC: - correct assumption about ASDR on POWER9 - fix MMIO emulation on POWER9 x86: - add a simple test for ioperm - cleanup TSS (going through KVM tree as the whole undertaking was caused by VMX's use of TSS) - fix nVMX interrupt delivery - fix some performance counters in the guest ... and two cleanup patches" * tag 'kvm-4.11-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: nVMX: Fix pending events injection x86/kvm/vmx: remove unused variable in segment_base() selftests/x86: Add a basic selftest for ioperm x86/asm: Tidy up TSS limit code kvm: convert kvm.users_count from atomic_t to refcount_t KVM: x86: never specify a sample period for virtualized in_tx_cp counters KVM: PPC: Book3S HV: Don't use ASDR for real-mode HPT faults on POWER9 KVM: PPC: Book3S HV: Fix software walk of guest process page tables
2017-03-03Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc final vfs updates from Al Viro: "A few unrelated patches that got beating in -next. Everything else will have to go into the next window ;-/" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: hfs: fix hfs_readdir() selftest for default_file_splice_read() infoleak 9p: constify ->d_name handling
2017-03-03Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm fixes from Dan Williams: "A fix and regression test case for nvdimm namespace label compatibility. Details: - An "nvdimm namespace label" is metadata on an nvdimm that provisions dimm capacity into a "namespace" that can host a block device / dax-filesytem, or a device-dax character device. A namespace is an object that other operating environment and platform firmware needs to comprehend for capabilities like booting from an nvdimm. The label metadata contains a checksum that Linux was not calculating correctly leading to other environments rejecting the Linux label. These have received a build success notification from the kbuild robot, and a positive test result from Nick who reported the problem" * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: nfit, libnvdimm: fix interleave set cookie calculation tools/testing/nvdimm: make iset cookie predictable
2017-03-03Merge tag 'linux-kselftest-4.11-rc1-urgent_fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest fix from Shuah Khan: "This update consists of an urgent fix for individual test build failures introduced in the 4.11-rc1 update" * tag 'linux-kselftest-4.11-rc1-urgent_fix' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests: lib.mk Fix individual test builds
2017-03-02Merge tag 'pm-turbostat-4.11-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull turbostat utility updates from Rafael Wysocki: "Power management turbostat utility updates. These update turbostat significantly and in particular: - default output is now verbose, --debug is no longer required to get all counters. As a result, some options have been added to specify exactly what output is wanted. - added --quiet to skip system configuration output - added --list, --show and --hide parameters - added --cpu parameter - enhanced Baytrail SoC support - added Gemini Lake SoC support - added sysfs C-state columns Also the symbol definitions in arch/x86/include/asm/intel-family.h and arch/x86/include/asm/msr-index.h are updated and the intel_idle and intel_pstate drivers are modified to use the updated symbols. Credits to Len Brown for all of these changes" * tag 'pm-turbostat-4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (44 commits) tools/power turbostat: version 17.02.24 tools/power turbostat: bugfix: --add u32 was printed as u64 tools/power turbostat: show error on exec tools/power turbostat: dump p-state software config tools/power turbostat: show package number, even without --debug tools/power turbostat: support "--hide C1" etc. tools/power turbostat: move --Package and --processor into the --cpu option tools/power turbostat: turbostat.8 update tools/power turbostat: update --list feature tools/power turbostat: use wide columns to display large numbers tools/power turbostat: Add --list option to show available header names tools/power turbostat: fix zero IRQ count shown in one-shot command mode tools/power turbostat: add --cpu parameter tools/power turbostat: print sysfs C-state stats tools/power turbostat: extend --add option to accept /sys path tools/power turbostat: skip unused counters on BDX tools/power turbostat: fix decoding for GLM, DNV, SKX turbo-ratio limits tools/power turbostat: skip unused counters on SKX tools/power turbostat: Denverton: use HW CC1 counter, skip C3, C7 tools/power turbostat: initial Gemini Lake SOC support ...
2017-03-03selftest/powerpc: Fix false failures for skipped testsSachin Sant
Tests under alignment subdirectory are skipped when executed on previous generation hardware, but harness still marks them as failed. test: test_copy_unaligned tags: git_version:unknown [SKIP] Test skipped on line 26 skip: test_copy_unaligned selftests: copy_unaligned [FAIL] The MAGIC_SKIP_RETURN_VALUE value assigned to rc variable is retained till the program exit which causes the test to be marked as failed. This patch resets the value before returning to the main() routine. With this patch the test o/p is as follows: test: test_copy_unaligned tags: git_version:unknown [SKIP] Test skipped on line 26 skip: test_copy_unaligned selftests: copy_unaligned [PASS] Signed-off-by: Sachin Sant <sachinp@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2017-03-02give up on gcc ilog2() constant optimizationsLinus Torvalds
gcc-7 has an "optimization" pass that completely screws up, and generates the code expansion for the (impossible) case of calling ilog2() with a zero constant, even when the code gcc compiles does not actually have a zero constant. And we try to generate a compile-time error for anybody doing ilog2() on a constant where that doesn't make sense (be it zero or negative). So now gcc7 will fail the build due to our sanity checking, because it created that constant-zero case that didn't actually exist in the source code. There's a whole long discussion on the kernel mailing about how to work around this gcc bug. The gcc people themselevs have discussed their "feature" in https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785 but it's all water under the bridge, because while it looked at one point like it would be solved by the time gcc7 was released, that was not to be. So now we have to deal with this compiler braindamage. And the only simple approach seems to be to just delete the code that tries to warn about bad uses of ilog2(). So now "ilog2()" will just return 0 not just for the value 1, but for any non-positive value too. It's not like I can recall anybody having ever actually tried to use this function on any invalid value, but maybe the sanity check just meant that such code never made it out in public. Reported-by: Laura Abbott <labbott@redhat.com> Cc: John Stultz <john.stultz@linaro.org>, Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-03-02selftests: lib.mk Fix individual test buildsShuah Khan
In commit a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT"), added support to generate compile targets in a user specified directory. OUTPUT variable controls the location which is undefined when tests are built in the test directory or with "make -C tools/testing/selftests/x86". make -C tools/testing/selftests/x86/ make: Entering directory '/lkml/linux_4.11/tools/testing/selftests/x86' Makefile:44: warning: overriding recipe for target 'clean' ../lib.mk:51: warning: ignoring old recipe for target 'clean' gcc -m64 -o /single_step_syscall_64 -O2 -g -std=gnu99 -pthread -Wall single_step_syscall.c -lrt -ldl /usr/bin/ld: cannot open output file /single_step_syscall_64: Permission denied collect2: error: ld returned 1 exit status Makefile:50: recipe for target '/single_step_syscall_64' failed make: *** [/single_step_syscall_64] Error 1 make: Leaving directory '/lkml/linux_4.11/tools/testing/selftests/x86' Same failure with "cd tools/testing/selftests/x86/;make" run. Fix this with a change to lib.mk to define OUTPUT to be the pwd when MAKELEVEL is 0. This covers both cases mentioned above. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2017-03-01Merge branch 'turbostat' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull changes related to turbostat for v4.11 from Len Brown. * 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (44 commits) tools/power turbostat: version 17.02.24 tools/power turbostat: bugfix: --add u32 was printed as u64 tools/power turbostat: show error on exec tools/power turbostat: dump p-state software config tools/power turbostat: show package number, even without --debug tools/power turbostat: support "--hide C1" etc. tools/power turbostat: move --Package and --processor into the --cpu option tools/power turbostat: turbostat.8 update tools/power turbostat: update --list feature tools/power turbostat: use wide columns to display large numbers tools/power turbostat: Add --list option to show available header names tools/power turbostat: fix zero IRQ count shown in one-shot command mode tools/power turbostat: add --cpu parameter tools/power turbostat: print sysfs C-state stats tools/power turbostat: extend --add option to accept /sys path tools/power turbostat: skip unused counters on BDX tools/power turbostat: fix decoding for GLM, DNV, SKX turbo-ratio limits tools/power turbostat: skip unused counters on SKX tools/power turbostat: Denverton: use HW CC1 counter, skip C3, C7 tools/power turbostat: initial Gemini Lake SOC support ...
2017-03-01objtool, modules: Discard objtool annotation sections for modulesJosh Poimboeuf
The '__unreachable' and '__func_stack_frame_non_standard' sections are only used at compile time. They're discarded for vmlinux but they should also be discarded for modules. Since this is a recurring pattern, prefix the section names with ".discard.". It's a nice convention and vmlinux.lds.h already discards such sections. Also remove the 'a' (allocatable) flag from the __unreachable section since it doesn't make sense for a discarded section. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jessica Yu <jeyu@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends") Link: http://lkml.kernel.org/r/20170301180444.lhd53c5tibc4ns77@treble Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-01selftests/x86: Add a basic selftest for iopermAndy Lutomirski
This doesn't fully exercise the interaction between KVM and ioperm(), but it does test basic functionality. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
2017-03-01x86/events: Remove last remnants of old filenamesBorislav Petkov
Update to the new file paths, remove them from introductory comments. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20170218113140.8051-1-bp@alien8.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2017-03-01x86/selftests: Add clobbers for int80 on x86_64Dmitry Safonov
Kernel erases R8..R11 registers prior returning to userspace from int80: https://lkml.org/lkml/2009/10/1/164 GCC can reuse these registers and doesn't expect them to change during syscall invocation. I met this kind of bug in CRIU once GCC 6.1 and CLANG stored local variables in those registers and the kernel zerofied them during syscall: https://github.com/xemul/criu/commit/990d33f1a1cdd17bca6c2eb059ab3be2564f7fa2 By that reason I suggest to add those registers to clobbers in selftests. Also, as noted by Andy - removed unneeded clobber for flags in INT $0x80 inline asm. Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com> Acked-by: Andy Lutomirski <luto@kernel.org> Cc: 0x7f454c46@gmail.com Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Shuah Khan <shuah@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kselftest@vger.kernel.org Link: http://lkml.kernel.org/r/20170213101336.20486-1-dsafonov@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-03-01tools/testing/nvdimm: make iset cookie predictableDan Williams
For testing changes to the iset cookie algorithm we need a value that is constant from run-to-run. Stop including dynamic data in the emulated region_offset values. Also, pick values that sort in a different order depending on whether the comparison is a memcmp() of two 8-byte arrays or subtraction of two 64-bit values. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
