path: root/tools
2014-07-09tools: ffs-test: fix header values endianessMichal Nazarewicz
commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream. It appears that no one ever run ffs-test on a big-endian machine, since it used cpu-endianess for fs_count and hs_count fields which should be in little-endian format. Fix by wrapping the numbers in cpu_to_le32. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-11perf tools: Fix cache event name generationJiri Olsa
commit 275ef3878f698941353780440fec6926107a320b upstream. If the event name is specified with all 3 components, the last one overwrites the previous one during the name composing within the parse_events_add_cache function. Fixing this by properly adjusting the string index. Reported-by: Joel Uckelman <joel@lightboxtechnologies.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joel Uckelman <joel@lightboxtechnologies.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LPU-Reference: 20120905175133.GA18352@krava.brq.redhat.com [ committer note: Remove the newline fix, done already in 42e1fb7 ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Vinson Lee <vlee@twopensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-11perf tools: Remove extraneous newline when parsing hardware cache eventsArnaldo Carvalho de Melo
commit 42e1fb776087713b5482cd7cf6cac998fbdd6544 upstream. Noticed while developing a 'perf test' entry to verify that perf_evsel__name works. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-xz6zgh38mp3cjnd2udh38z8f@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Vinson Lee <vlee@twopensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13turbostat: Use GCC's CPUID functions to support PICJosh Triplett
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream. turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems that have certain security features enabled by default that make -fPIC the default, this causes a build error: turbostat.c: In function ‘check_cpuid’: turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’ asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx"); ^ GCC provides a header cpuid.h, containing a __get_cpuid function that works with both PIC and non-PIC. (On PIC, it saves and restores ebx around the cpuid instruction.) Use that instead. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-08cpupower: Fix segfault due to incorrect getopt_long arugmentsJosh Boyer
commit f447ef4a56dee4b68a91460bcdfe06b5011085f2 upstream. If a user calls 'cpupower set --perf-bias 15', the process will end with a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi call. This is because the getopt_long structure currently has all of the options as having an optional_argument when they really have a required argument. We change the structure to use required_argument to match the short options and it resolves the issue. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439 Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01perf tools: Handle JITed code in shared memoryAndi Kleen
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream. Need to check for /dev/zero. Most likely more strings are missing too. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Vinson Lee <vlee@freedesktop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-14perf tools: Add anonymous huge page recognitionJoshua Zhu
commit d0528b5d71faf612014dd7672e44225c915344b2 upstream. Judging anonymous memory's vm_area_struct, perf_mmap_event's filename will be set to "//anon" indicating this vma belongs to anonymous memory. Once hugepage is used, vma's vm_file points to hugetlbfs. In this way, this vma will not be regarded as anonymous memory by is_anon_memory() in perf user space utility. Signed-off-by: Joshua Zhu <zhu.wen-jie@hp.com> Cc: Akihiro Nagai <akihiro.nagai.hw@hitachi.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joshua Zhu <zhu.wen-jie@hp.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vinson Lee <vlee@freedesktop.org> Link: http://lkml.kernel.org/r/1357363797-3550-1-git-send-email-zhu.wen-jie@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07perf: net_dropmonitor: Fix symbol-relative addressesBen Hutchings
commit 5a1e99dd2028e00998d42029be86835d8ef4a46e upstream. The comparison between traced and symbol addresses is backwards: if the traced address doesn't exactly match a symbol (which we don't expect it to), we'll show the next symbol and the offset to it, whereas we should show the previous symbol and the offset from it. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07perf: net_dropmonitor: Fix trace parameter orderBen Hutchings
commit 140c3c6a2bcd2c31e2f7f5a8d59689724776c8e5 upstream. This works much better if we don't treat protocol numbers as addresses. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28tools: hv: Netlink source address validation allows DoSTomas Hozza
commit 95a69adab9acfc3981c504737a2b6578e4d846ef upstream. The source code without this patch caused hypervkvpd to exit when it processed a spoofed Netlink packet which has been sent from an untrusted local user. Now Netlink messages with a non-zero nl_pid source address are ignored and a warning is printed into the syslog. Signed-off-by: Tomas Hozza <thozza@redhat.com> Acked-by: K. Y. Srinivasan <kys@microsoft.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04perf tools: Fix build with bison 2.3 and older.Vinson Lee
commit 85df3b3769222894e9692b383c7af124b7721086 upstream. The %name-prefix "prefix" syntax is not available on bison 2.3 and older. Substitute with the -p "prefix" command-line option for compatibility with older versions of bison. This patch fixes this build error with older versions of bison. CC util/sysfs.o BISON util/pmu-bison.c util/pmu.y:2.14-24: syntax error, unexpected string, expecting = make: *** [util/pmu-bison.c] Error 1 Signed-off-by: Vinson Lee <vlee@twitter.com> Tested-by: Li Zefan <lizefan@huawei.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Link: http://lkml.kernel.org/r/1360792138-29186-1-git-send-email-vlee@twitter.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17perf test: fix a build error on builtin-testZheng Liu
commit 12f8f74b2a4d26c4facfa7ef99487cf0930f6ef7 upstream. Recently I build perf and get a build error on builtin-test.c. The error is as following: $ make CC perf.o CC builtin-test.o cc1: warnings being treated as errors builtin-test.c: In function ‘sched__get_first_possible_cpu’: builtin-test.c:977: warning: implicit declaration of function ‘CPU_ALLOC’ builtin-test.c:977: warning: nested extern declaration of ‘CPU_ALLOC’ builtin-test.c:977: warning: assignment makes pointer from integer without a cast builtin-test.c:978: warning: implicit declaration of function ‘CPU_ALLOC_SIZE’ builtin-test.c:978: warning: nested extern declaration of ‘CPU_ALLOC_SIZE’ builtin-test.c:979: warning: implicit declaration of function ‘CPU_ZERO_S’ builtin-test.c:979: warning: nested extern declaration of ‘CPU_ZERO_S’ builtin-test.c:982: warning: implicit declaration of function ‘CPU_FREE’ builtin-test.c:982: warning: nested extern declaration of ‘CPU_FREE’ builtin-test.c:992: warning: implicit declaration of function ‘CPU_ISSET_S’ builtin-test.c:992: warning: nested extern declaration of ‘CPU_ISSET_S’ builtin-test.c:998: warning: implicit declaration of function ‘CPU_CLR_S’ builtin-test.c:998: warning: nested extern declaration of ‘CPU_CLR_S’ make: *** [builtin-test.o] Error 1 This problem is introduced in 3e7c439a. CPU_ALLOC and related macros are missing in sched__get_first_possible_cpu function. In 54489c18, commiter mentioned that CPU_ALLOC has been removed. So CPU_ALLOC calls in this function are removed to let perf to be built. Signed-off-by: Vinson Lee <vlee@twitter.com> Signed-off-by: Zheng Liu <wenqing.lz@taobao.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Vinson Lee <vlee@twitter.com> Cc: Zheng Liu <wenqing.lz@taobao.com> Link: http://lkml.kernel.org/r/1352422726-31114-1-git-send-email-vlee@twitter.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13lguest: fix occasional crash in example launcher.Rusty Russell
commit ca16f580a5db7e60bfafe59a50bb133bd3347491 upstream. We usually got away with ->next on the final entry being NULL, but it finally bit me. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-13kbuild: Fix gcc -x syntaxJean Delvare
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream. The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07tools/hv: Check for read/write errorsBen Hutchings
commit 436473bc2173499ae274d0f50111d1e355006caf upstream. hv_kvp_daemon currently does not check whether fread() or fwrite() succeed. Add the necessary checks. Also, remove the incorrect use of feof() before fread(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07tools/hv: Fix exit() error codeBen Hutchings
commit 6bb22fea25624ab593eee376fa5fb82d1b13f45a upstream. Linux native exit codes are 8-bit unsigned values. exit(-1) results in an exit code of 255, which is usually reserved for shells reporting 'command not found'. Use the portable value EXIT_FAILURE. (Not that this matters much for a daemon.) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-07tools/hv: Fix file handle leakBen Hutchings
commit d5ab482799e7c4c4b7c0aa67e8710dce28115d03 upstream. Match up each fopen() with an fclose(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-16Tools: hv: verify origin of netlink connector messageOlaf Hering
commit bcc2c9c3fff859e0eb019fe6fec26f9b8eba795c upstream. The SuSE security team suggested to use recvfrom instead of recv to be certain that the connector message is originated from kernel. CVE-2012-2669 Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Marcus Meissner <meissner@suse.de> Signed-off-by: Sebastian Krahmer <krahmer@suse.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-10kbuild: install kernel-page-flags.hUlrich Drepper
commit 9295b7a07c859a42346221b5839be0ae612333b0 upstream. Programs using /proc/kpageflags need to know about the various flags. The <linux/kernel-page-flags.h> provides them and the comments in the file indicate that it is supposed to be used by user-level code. But the file is not installed. Install the headers and mark the unstable flags as out-of-bounds. The page-type tool is also adjusted to not duplicate the definitions Signed-off-by: Ulrich Drepper <drepper@gmail.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-06-01USB: ffs-test: fix length argument of out function callMatthias Fend
commit eb9c5836384cd2a276254df6254ed71117983626 upstream. The out functions should only handle actual available data instead of the complete buffer. Otherwise for example the ep0_consume function will report ghost events since it tries to decode the complete buffer - which may contain partly invalid data. Signed-off-by: Matthias Fend <matthias.fend@wolfvision.net> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-09perf stat: handle ENXIO error for perf_event_openDavid Ahern
perf stat on PPC currently fails to run: $ perf stat -- sleep 1 Error: open_counter returned with 6 (No such device or address). /bin/dmesg may provide additional information. Fatal: Not all events could be opened. The problem is that until 2.6.37 (behavior changed with commit b0a873e) perf on PPC returns ENXIO when hw_perf_event_init() fails. With this patch we get the expected behavior: $ perf stat -v -- sleep 1 cycles event is not supported by the kernel. stalled-cycles-frontend event is not supported by the kernel. stalled-cycles-backend event is not supported by the kernel. instructions event is not supported by the kernel. branches event is not supported by the kernel. branch-misses event is not supported by the kernel. ... Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1336490956-57145-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-07perf: Turn off compiler warnings for flex and bison generated filesGreg Kroah-Hartman
We don't know what types of warnings different versions of flex and bison combined with different versions of gcc is going to generate, so just punt and don't warn about anything. This fixes the build of perf for me on an openSUSE 12.1 system. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20120504183254.GA11154@kroah.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-05-02Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Fixes for perf/urgent: - Add fallback in 'perf stat' for kernels that don't support perf_event_attr.exclude_guest, from Stephane Eranian. - Fix build id cache add routine to take the size of the buffer and not of a pointer, from Namhyung Kim. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-05-01Merge tag 'ktest-for-v3.4-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull two bug fixes in ktest from Steven Rostedt. * tag 'ktest-for-v3.4-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Fix reboot on success stopping all reboots ktest.pl: Fix combined usage of BISECT_REVERSE and BISECT_SKIP
2012-05-01perf stat: Fix case where guest/host monitoring is not supported by kernelStephane Eranian
By default, perf stat sets exclude_guest = 1. But when you run perf on a kernel which does not support host/guest filtering, then you get an error saying the event in unsupported. This comes from the fact that when the perf_event_attr struct passed by the user is larger than the one known to the kernel there is safety check which ensures that all unknown bits are zero. But here, exclude_guest is 1 (part of the unknown bits) and thus the perf_event_open() syscall return EINVAL. To my surprise, running perf record on the same kernel did not exhibit the problem. The reason is that perf record handles the problem by catching the error and retrying with guest/host excludes set to zero. For some reason, this was not done with perf stat. This patch fixes this problem. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Gleb Natapov <gleb@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joro@8bytes.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Link: http://lkml.kernel.org/r/20120427124538.GA7230@quad Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-01perf build-id: Fix filename size calculationNamhyung Kim
The filename is a pointer variable so the sizeof(filename) will return length of a pointer. Fix it by using 'size'. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1335881976-3282-1-git-send-email-namhyung@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-01ktest: Fix reboot on success stopping all rebootsSteven Rostedt
The change to let individual tests decide to reboot the machine on success of the entire test also prevented errors from rebooting when an error was detected. The "no_reboot" variable was only cleared if the test had reboot_on_success set. But the no_reboot variable also prevents the test rebooting when an error was detected even when REBOOT_ON_ERROR was set. Add a new "reboot_success" variable that is used to determine if the test should reboot on success and not touch the no_reboot variable. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-01ktest.pl: Fix combined usage of BISECT_REVERSE and BISECT_SKIPRuss Dill
When BISECT_REVERSE and BISECT_SKIP are used together with boot or test testing, build failures are treated as boot or test failures and 'git bisect bad' is executed instead of 'git bisect skip'. This is because the $ret value of -1 is treated as a build failure, but the $reverse_bisect logic does not properly handle this. Simple fix, only invert it if it is positive. Link: http://lkml.kernel.org/r/1335235380-8509-1-git-send-email-Russ.Dill@ti.com Signed-off-by: Russ Dill <Russ.Dill@ti.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-04-20perf symbols: Read plt symbols from proper symtab_type binaryJiri Olsa
When loading symbols from DSO we check multiple paths of DSO binary until we succeed to load symbols ('.symtab' section). Once symbols are read we try to load also plt symbols. During the reading of plt symbols, the dso file is reopened from location given by dso->long_name. This could be wrong in case we want process buildid binaries. The change is to make the plt symbols being read from the DSO path, that normal symbols were read from. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1334756818-6631-1-git-send-email-jolsa@redhat.com [ committer note: moved dso to be the first parameter of that function ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-17perf tools: Add 'G' and 'H' modifiers to event parsingGleb Natapov
They were dropped during conversion of event parser. Add test case to make sure this will not happen again. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/20120417111345.GK11918@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-16perf tools: Drop CROSS_COMPILE from flex and bison callsOtavio Salvador
The flex and bison tools generate arch-independent C code so its binaries are not prefixed with the target-arch prefix. With this patch the Linux 3.4-rc2 can be successfuly build on OE-Core. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Link: http://lkml.kernel.org/r/1334148270-13139-1-git-send-email-otavio@ossystems.com.br Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-16perf report: Fix crash showing warning related to kernel mapsDavid Ahern
While testing https://lkml.org/lkml/2012/4/10/123 I hit this crash: (gdb) bt 0 0x000000000042000f in __cmd_report (rep=0x7fff80cec580) at builtin-report.c:380 1 cmd_report (argc=0, argv=<optimized out>, prefix=<optimized out>) at builtin-report.c:759 2 0x0000000000414513 in run_builtin (p=0x7724a8, argc=3, argv=0x7fff80ceca70) at perf.c:273 3 0x0000000000413d41 in handle_internal_command (argv=0x7fff80ceca70, argc=3) at perf.c:345 4 run_argv (argv=0x7fff80cec880, argcp=0x7fff80cec88c) at perf.c:389 5 main (argc=3, argv=0x7fff80ceca70) at perf.c:487 kernel_map can be NULL, so need to handle it while dumping a warning to user. v2: - fixed RB_EMPTY_ROOT check -- desc takes the altnerative output when RB_EMPTY_ROOT is false. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Link: http://lkml.kernel.org/r/1334544855-55021-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-15Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf tooling fixes from Arnaldo Carvalho de Melo: . Properly handle ~/.debug, the build id cache, when it is a symlink, fix from Chanho Park . Fixes for the parser generation process, from Jiri Olsa and Namhyung Kim . Fix build when NO_GTK2 is specified, From Stephane Eranian . When a machine is not found, bump the relevant error stat but return 0, so that we correctly move to the next perf event. Fix from Jiri Olsa Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-04-14perf archive: Correct cutting of symbolic linkChanho Park
If a '$PERF_BUILDID_DIR'(typically $HOME/.debug) is a symbolic link directory, cutting of the path will fail. Here is an example where a buildid directory is a symbolic link. / # ls -al /root lrwxrwxrwx 1 root root 13 Mar 26 2012 /root -> opt/home/root / # cd ~ /opt/home/root # perf record -a -g sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.322 MB perf.data (~14057 samples) ] /opt/home/root # perf archive tar: Removing leading `/' from member names Now please run: $ tar xvf perf.data.tar.bz2 -C ~/.debug wherever you need to run 'perf report' on. /opt/home/root # mkdir temp /opt/home/root # tar xf perf.data.tar.bz2 -C ./temp /opt/home/root # find ./temp -name "*kernel*" ./temp/opt/home/root/.debug/[kernel.kallsyms] -> If successfully cut off the path, [kernel.kallsyms] is located in top of the archived file. This patch enables to cut correctly even if the buildid directory is a symbolic link. Signed-off-by: Chanho Park <chanho61.park@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333348109-12598-1-git-send-email-chanho61.park@samsung.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-14perf tools: Ignore auto-generated bison/flex filesNamhyung Kim
The commit 65f3e56e0c81 ("perf tools: Remove auto-generated bison/flex files") removed those files from git, so they'll be listed on untracked files after building perf. Fix it. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333948274-20043-1-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-14perf tools: Fix parsers' rules to dependenciesJiri Olsa
Currently the parsers objects (bison/flex related) are each time perf is built. No matter the generated files are already in place, the parser generation is executed every time. Changing the rules to have proper flex/bison objects generation dependencies. The parsers code is not rebuilt until the flex/bison source files are touched. Also when flex/bison source is changed, only dependent objects are rebuilt. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1334140791-3024-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-13Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull various perf tooling fixes from Arnaldo Carvalho de Melo.
2012-04-12Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull trivial perf build failure fix from Thomas Gleixner. * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix getrusage() related build failure on glibc trunk
2012-04-12perf tools: fix NO_GTK2 Makefile config errorStephane Eranian
In case the user specified NO_GTK2 on the make cmdline, compilation would fail with undefined symbol because the Makefile would not set the correct cpp variable: NO_GTK2 vs. NO_GTK2_SUPPORT. This patch renames the variable to the correct name. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120410103513.GA9229@quad Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-12perf session: Skip event correctly for unknown id/machineJiri Olsa
In case the perf_session__process_event function fails, we estimate the next event offset. This is not necessary for sample event failing on unknown ID or machine. In such case we know proper size of the event, so we dont need to guess. Also failure statistics are updated correctly so we don't miss any information. Forcing perf_session__process_event to return 0 in case of unknown ID or machine. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1334233262-5679-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-11perf kvm: Finding struct machine fails for PERF_RECORD_MMAPNikunj A. Dadhania
Running 'perf kvm --host --guest --guestmount /tmp/guestmount record -a -g -- sleep 2' Was resulting in a segfault. For event type PERF_RECORD_MMAP, event->ip.pid is being used in perf_session__find_machine_for_cpumode, which is not correct. The event->ip.pid field happens to be 0 in this case and results in returning a NULL machine object. Finally, access to self->pid in machine__mmap_name, results in a segfault later. For PERF_RECORD_MMAP type, pass event->mmap.pid. Signed-off-by: Nikunj A. Dadhania <nikunj@linux.vnet.ibm.com> Reviewed-by: David Ahern <dsahern@gmail.com> Tested-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Nikunj A. Dadhania <nikunj@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120409081835.10576.22018.stgit@abhimanyu.in.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf annotate: Validate addr in symbol__inc_addr_samplesArnaldo Carvalho de Melo
This routine was checking only if the provided address was after sym->end, not if it was before sym->start. Fix that by checking for both and return in both cases -ERANGE, so that tools can communicate this to the user properly, or if they chose so, to abort. This problem was reported previously but the fixes involved either doing what was being done for the > end case, i.e. silently drop the sample, returning 0, or aborting at this function, which is in a lib (or better, is slated to be at some point) and shouldn't abort. The 'report' tool already checks this value and uses pr_debug to warn the user. This patch makes the 'top' tool check it too and warn once per map where such range problem takes place. Reported-by: David Miller <davem@davemloft.net> Reported-by: Sorin Dumitru <dumitru.sorin87@gmail.com> Reported-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-lw8gs7p9i9nhldilo82tzpne@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf hists browser: Fix NULL deref in hists browsing codeJiri Olsa
If there's an event with no samples in data file, the perf report command can segfault after entering the event details menu. Following steps reproduce the issue: # ./perf record -e syscalls:sys_enter_kexec_load,syscalls:sys_enter_mmap ls # ./perf report # enter '0 syscalls:sys_enter_kexec_load' menu # pres ENTER twice Above steps are valid assuming ls wont run kexec.. ;) The check for sellection to be NULL is missing. The fix makes sure it's being check. Above steps now endup with menu being displayed allowing 'Exit' as the only option. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333570898-10505-2-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf hists: Catch and handle out-of-date hist entry maps.David Miller
When a process exec()'s, all the maps are retired, but we keep the hist entries around which hold references to those outdated maps. If the same library gets mapped in for which we have hist entries, a new map will be created. But when we take a perf entry hit within that map, we'll find the existing hist entry with the older map. This causes symbol translations to be done incorrectly. For example, the perf entry processing will lookup the correct uptodate map entry and use that to calculate the symbol and DSO relative address. But later when we update the histogram we'll translate the address using the outdated map file instead leading to conditions such as out-of-range offsets in symbol__inc_addr_samples(). Therefore, update the map of the hist_entry dynamically at lookup/ creation time. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/20120327.031418.1220315351537060808.davem@davemloft.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf annotate: Fix hist decayArnaldo Carvalho de Melo
We were only decaying the entries for the offsets that were associated with an objdump line. That way, when we accrued the whole instruction addr range, more than 100% was appearing in some cases in the live annotation TUI. Fix it by not traversing the source code line at all, just iterate thru the complete addr range decaying each one. Reported-by: Mike Galbraith <mgalbraith@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-hcae5oxa22syjrnalsxz7s6n@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf top: Add intel_idle to the skip listArnaldo Carvalho de Melo
TODO: Accrue the cycles in the skip_list to an idle total, and show this on the 'top' UI, as suggested by Steven. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-9nfecmgghgl5747rjxqpc28f@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-04perf tools: Fix getrusage() related build failure on glibc trunkMarkus Trippelsdorf
On a system running glibc trunk perf doesn't build: CC builtin-sched.o builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration] [...] Fix it by including sys/resource.h. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120404084527.GA294@x4 Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-31Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates and fixes from Ingo Molnar: "It's mostly fixes, but there's also two late items: - preliminary GTK GUI support for perf report - PMU raw event format descriptors in sysfs, to be parsed by tooling The raw event format in sysfs is a new ABI. For example for the 'CPU' PMU we have: aldebaran:~> ll /sys/bus/event_source/devices/cpu/format/* -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/any -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/cmask -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/edge -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/event -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/inv -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/offcore_rsp -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/pc -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/umask those lists of fields contain a specific format: aldebaran:~> cat /sys/bus/event_source/devices/cpu/format/offcore_rsp config1:0-63 So, those who wish to specify raw events can now use the following event format: -e cpu/cmask=1,event=2,umask=3 Most people will not want to specify any events (let alone raw events), they'll just use whatever default event the tools use. But for more obscure PMU events that have no cross-architecture generic events the above syntax is more usable and a bit more structured than specifying hex numbers." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) perf tools: Remove auto-generated bison/flex files perf annotate: Fix off by one symbol hist size allocation and hit accounting perf tools: Add missing ref-cycles event back to event parser perf annotate: addr2line wants addresses in same format as objdump perf probe: Finder fails to resolve function name to address tracing: Fix ent_size in trace output perf symbols: Handle NULL dso in dso__name_len perf symbols: Do not include libgen.h perf tools: Fix bug in raw sample parsing perf tools: Fix display of first level of callchains perf tools: Switch module.h into export.h perf: Move mmap page data_head offset assertion out of header perf: Fix mmap_page capabilities and docs perf diff: Fix to work with new hists design perf tools: Fix modifier to be applied on correct events perf tools: Fix various casting issues for 32 bits perf tools: Simplify event_read_id exit path tracing: Fix ftrace stack trace entries tracing: Move the tracing_on/off() declarations into CONFIG_TRACING perf report: Add a simple GTK2-based 'perf report' browser ...
2012-03-31Merge branch 'perf/urgent' of ↵Ingo Molnar
2012-03-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & Power Management changes from Len Brown: - ACPI 5.0 after-ripples, ACPICA/Linux divergence cleanup - cpuidle evolving, more ARM use - thermal sub-system evolving, ditto - assorted other PM bits Fix up conflicts in various cpuidle implementations due to ARM cpuidle cleanups (ARM at91 self-refresh and cpu idle code rewritten into "standby" in asm conflicting with the consolidation of cpuidle time keeping), trivial SH include file context conflict and RCU tracing fixes in generic code. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (77 commits) ACPI throttling: fix endian bug in acpi_read_throttling_status() Disable MCP limit exceeded messages from Intel IPS driver ACPI video: Don't start video device until its associated input device has been allocated ACPI video: Harden video bus adding. ACPI: Add support for exposing BGRT data ACPI: export acpi_kobj ACPI: Fix logic for removing mappings in 'acpi_unmap' CPER failed to handle generic error records with multiple sections ACPI: Clean redundant codes in scan.c ACPI: Fix unprotected smp_processor_id() in acpi_processor_cst_has_changed() ACPI: consistently use should_use_kmap() PNPACPI: Fix device ref leaking in acpi_pnp_match ACPI: Fix use-after-free in acpi_map_lsapic ACPI: processor_driver: add missing kfree ACPI, APEI: Fix incorrect APEI register bit width check and usage Update documentation for parameter *notrigger* in einj.txt ACPI, APEI, EINJ, new parameter to control trigger action ACPI, APEI, EINJ, limit the range of einj_param ACPI, APEI, Fix ERST header length check cpuidle: power_usage should be declared signed integer ...
