path: root/tools
2015-12-14tools/net: Use include/uapi with __EXPORTED_HEADERS__Kamal Mostafa
[ Upstream commit d7475de58575c904818efa369c82e88c6648ce2e ] Use the local uapi headers to keep in sync with "recently" added #define's (e.g. SKF_AD_VLAN_TPID). Refactored CFLAGS, and bpf_asm doesn't need -I. Fixes: 3f356385e8a4 ("filter: bpf_asm: add minimal bpf asm tool") Signed-off-by: Kamal Mostafa <kamal@canonical.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27tools lib traceevent: Fix string handling in heterogeneous arch environmentsKapileshwar Singh
[ Upstream commit c2e4b24ff848bb180f9b9cd873a38327cd219ad2 ] When a trace recorded on a 32-bit device is processed with a 64-bit binary, the higher 32-bits of the address need to ignored. The lack of this results in the output of the 64-bit pointer value to the trace as the 32-bit address lookup fails in find_printk(). Before: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: 2cec5c058d98c After: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: RT throttling activated The problem occurs in PRINT_FIELD when the field is recognized as a pointer to a string (of the type const char *) Heterogeneous architectures cases below can arise and should be handled: * Traces recorded using 32-bit addresses processed on a 64-bit machine * Traces recorded using 64-bit addresses processed on a 32-bit machine Reported-by: Juri Lelli <juri.lelli@arm.com> Signed-off-by: Kapileshwar Singh <kapileshwar.singh@arm.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Javi Merino <javi.merino@arm.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1442928123-13824-1-git-send-email-kapileshwar.singh@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27perf header: Fixup reading of HEADER_NRCPUS featureArnaldo Carvalho de Melo
[ Upstream commit caa470475d9b59eeff093ae650800d34612c4379 ] The original patch introducing this header wrote the number of CPUs available and online in one order and then swapped those values when reading, fix it. Before: # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 4 # echo 0 > /sys/devices/system/cpu/cpu2/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 3 # echo 0 > /sys/devices/system/cpu/cpu1/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 2 After the fix, bringing back the CPUs online: # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 2 # nrcpus avail : 4 # echo 1 > /sys/devices/system/cpu/cpu2/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 3 # nrcpus avail : 4 # echo 1 > /sys/devices/system/cpu/cpu1/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 4 Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)") Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27perf stat: Get correct cpu id for print_aggrKan Liang
[ Upstream commit 601083cffb7cabdcc55b8195d732f0f7028570fa ] print_aggr() fails to print per-core/per-socket statistics after commit 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events") if events have differnt cpus. Because in print_aggr(), aggr_get_id needs index (not cpu id) to find core/pkg id. Also, evsel cpu maps should be used to get aggregated id. Here is an example: Counting events cycles,uncore_imc_0/cas_count_read/. (Uncore event has cpumask 0,18) $ perf stat -e cycles,uncore_imc_0/cas_count_read/ -C0,18 --per-core sleep 2 Without this patch, it failes to get CPU 18 result. Performance counter stats for 'CPU(s) 0,18': S0-C0 1 7526851 cycles S0-C0 1 1.05 MiB uncore_imc_0/cas_count_read/ S1-C0 0 <not counted> cycles S1-C0 0 <not counted> MiB uncore_imc_0/cas_count_read/ With this patch, it can get both CPU0 and CPU18 result. Performance counter stats for 'CPU(s) 0,18': S0-C0 1 6327768 cycles S0-C0 1 0.47 MiB uncore_imc_0/cas_count_read/ S1-C0 1 330228 cycles S1-C0 1 0.29 MiB uncore_imc_0/cas_count_read/ Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Stephane Eranian <eranian@google.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events") Link: http://lkml.kernel.org/r/1435820925-51091-1-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27perf report: Add support for srcfile sort keyArnaldo Carvalho de Melo
[ Upstream commit 31191a85fb875cf123cea56bbfd34f4b941f3c79 ] In some cases it's useful to characterize samples by file. This is useful to get a higher level categorization, for example to map cost to subsystems. Add a srcfile sort key to perf report. It builds on top of the existing srcline support. Commiter notes: E.g.: # perf record -F 10000 usleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.016 MB perf.data (13 samples) ] [root@zoo ~]# perf report -s srcfile --stdio # Total Lost Samples: 0 # # Samples: 13 of event 'cycles' # Event count (approx.): 869878 # # Overhead Source File # ........ ........... 60.99% . 20.62% paravirt.h 14.23% rmap.c 4.04% signal.c 0.11% msr.h # The first line is collecting all the files for which srcfiles couldn't somehow get resolved to: # perf report -s srcfile,dso --stdio # Total Lost Samples: 0 # # Samples: 13 of event 'cycles' # Event count (approx.): 869878 # # Overhead Source File Shared Object # ........ ........... ................ 40.97% . ld-2.20.so 20.62% paravirt.h [kernel.vmlinux] 20.02% . libc-2.20.so 14.23% rmap.c [kernel.vmlinux] 4.04% signal.c [kernel.vmlinux] 0.11% msr.h [kernel.vmlinux] # XXX: Investigate why that is not resolving on Fedora 21, Andi says he hasn't seen this on Fedora 22. Signed-off-by: Andi Kleen <ak@linux.intel.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1438988064-21834-1-git-send-email-andi@firstfloor.org [ Added column length update, from 0e65bdb3f90f ('perf hists: Update the column width for the "srcline" sort key') ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27perf tools: Fix copying of /proc/kcoreAdrian Hunter
[ Upstream commit b5cabbcbd157a4bf5a92dfc85134999a3b55342d ] A copy of /proc/kcore containing the kernel text can be made to the buildid cache. e.g. perf buildid-cache -v -k /proc/kcore To workaround objdump limitations, a copy is also made when annotating against /proc/kcore. The copying process stops working from libelf about v1.62 onwards (the problem was found with v1.63). The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails because additional validation has been added to gelf_getphdr(). The use of gelf_getphdr() is a misguided attempt to get default initialization of the Gelf_Phdr structure. That should not be necessary because every member of the Gelf_Phdr structure is subsequently assigned. So just remove the call to gelf_getphdr(). Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be removed also. Committer notes: Note to stable@kernel.org, from Adrian in the cover letter for this patchkit: The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think it is important enough for stable. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-15Revert "tools/vm: fix page-flags build"Sasha Levin
This reverts commit a821ac4c66382f9d6387c8311608f13c6749fea9. That patch is not suitable for 3.18. Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-06-10tools/vm: fix page-flags buildAndi Kleen
[ Upstream commit 4933f55fe72c86e57efc454dd6e673c7f17af5a3 ] libabikfs.a doesn't exist anymore, so we now need to link with libapi.a. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for ↵Thomas D
O= option in Makefile [ Upstream commit f82263c6989c31ae9b94cecddffb29dcbec38710 ] Since commit ee0778a30153 ("tools/power: turbostat: make Makefile a bit more capable") turbostat's Makefile is using [...] BUILD_OUTPUT := $(PWD) [...] which obviously causes trouble when building "turbostat" with make -C /usr/src/linux/tools/power/x86/turbostat ARCH=x86 turbostat because GNU make does not update nor guarantee that $PWD is set. This patch changes the Makefile to use $CURDIR instead, which GNU make guarantees to set and update (i.e. when using "make -C ...") and also adds support for the O= option (see "make help" in your root of your kernel source tree for more details). Link: https://bugs.gentoo.org/show_bug.cgi?id=533918 Fixes: ee0778a30153 ("tools/power: turbostat: make Makefile a bit more capable") Signed-off-by: Thomas D. <whissi@whissi.de> Cc: Mark Asselstine <mark.asselstine@windriver.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17tools lib traceevent kbuffer: Remove extra update to data pointer in PADDINGSteven Rostedt (Red Hat)
[ Upstream commit c5e691928bf166ac03430e957038b60adba3cf6c ] When a event PADDING is hit (a deleted event that is still in the ring buffer), translate_data() sets the length of the padding and also updates the data pointer which is passed back to the caller. This is unneeded because the caller also updates the data pointer with the passed back length. translate_data() should not update the pointer, only set the length. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org # 3.12+ Link: http://lkml.kernel.org/r/20150324135923.461431960@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17perf tools: Work around lack of sched_getcpu in glibc < 2.6.Vinson Lee
[ Upstream commit e1e455f4f4d35850c30235747620d0d078fe9f64 ] This patch fixes this build error with glibc < 2.6. CC util/cloexec.o cc1: warnings being treated as errors util/cloexec.c: In function ‘perf_flag_probe’: util/cloexec.c:24: error: implicit declaration of function ‘sched_getcpu’ util/cloexec.c:24: error: nested extern declaration of ‘sched_getcpu’ make: *** [util/cloexec.o] Error 1 Signed-off-by: Vinson Lee <vlee@twitter.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Yann Droneaud <ydroneaud@opteya.com> Cc: stable@vger.kernel.org # 3.18+ Link: http://lkml.kernel.org/r/1427137761-16119-1-git-send-email-vlee@twopensource.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17perf symbols: Define STT_GNU_IFUNC for glibc 2.9 and older.Vinson Lee
[ Upstream commit 4e31050f482c02c822b150d71cf1ea5be7c9d6e4 ] The token STT_GNU_IFUNC is not available with glibc 2.9 and older. Define this token if it is not already defined. This patch fixes this build errors with older versions of glibc. CC util/symbol-elf.o util/symbol-elf.c: In function ‘elf_sym__is_function’: util/symbol-elf.c:75: error: ‘STT_GNU_IFUNC’ undeclared (first use in this function) util/symbol-elf.c:75: error: (Each undeclared identifier is reported only once util/symbol-elf.c:75: error: for each function it appears in.) make: *** [util/symbol-elf.o] Error 1 Signed-off-by: Vinson Lee <vlee@twitter.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Anton Blanchard <anton@samba.org> Cc: Avi Kivity <avi@cloudius-systems.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Waiman Long <Waiman.Long@hp.com> Cc: stable@vger.kernel.org # 3.17+ Link: http://lkml.kernel.org/r/1423528286-13630-1-git-send-email-vlee@twopensource.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-06perf tools: Fix probing for PERF_FLAG_FD_CLOEXEC flagAdrian Hunter
commit 48536c9195ae8c2a00fd8f400bac72ab613feaab upstream. Commit f6edb53c4993ffe92ce521fb449d1c146cea6ec2 converted the probe to a CPU wide event first (pid == -1). For kernels that do not support the PERF_FLAG_FD_CLOEXEC flag the probe fails with EINVAL. Since this errno is not handled pid is not reset to 0 and the subsequent use of pid = -1 as an argument brings in an additional failure path if perf_event_paranoid > 0: $ perf record -- sleep 1 perf_event_open(..., 0) failed unexpectedly with error 13 (Permission denied) [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.007 MB /tmp/perf.data (11 samples) ] Also, ensure the fd of the confirmation check is closed and comment why pid = -1 is used. Needs to go to 3.18 stable tree as well. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Based-on-patch-by: David Ahern <david.ahern@oracle.com> Acked-by: David Ahern <david.ahern@oracle.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/54EC610C.8000403@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16perf session: Do not fail on processing out of order eventJiri Olsa
commit f61ff6c06dc8f32c7036013ad802c899ec590607 upstream. Linus reported perf report command being interrupted due to processing of 'out of order' event, with following error: Timestamp below last timeslice flush 0x5733a8 [0x28]: failed to process type: 3 I could reproduce the issue and in my case it was caused by one CPU (mmap) being behind during record and userspace mmap reader seeing the data after other CPUs data were already stored. This is expected under some circumstances because we need to limit the number of events that we queue for reordering when we receive a PERF_RECORD_FINISHED_ROUND or when we force flush due to memory pressure. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt.fleming@intel.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1417016371-30249-1-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-16ktest: Fix make_min_config to handle new assign_configs callSteven Rostedt (Red Hat)
commit 9972fc0b859e7aaeb6d2d33bdb591959d9a436c0 upstream. Commit 6071c22e1755 "ktest: Rewrite the config-bisect to actually work" fixed the config-bisect to work nicely but in doing so it broke make_min_config by changing the way assign_configs works. The assign_configs function now adds the config to the hash even if it is disabled, but changes the hash value to be that of the line "# CONFIG_FOO is not set". Unfortunately, the make_min_config test only checks to see if the config is removed. It now needs to check if the config is in the hash and not set to be disabled. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Unbreak the unprivileged remount testsEric W. Biederman
commit db86da7cb76f797a1a8b445166a15cb922c6ff85 upstream. A security fix in caused the way the unprivileged remount tests were using user namespaces to break. Tweak the way user namespaces are being used so the test works again. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08mnt: Update unprivileged remount testEric W. Biederman
commit 4a44a19b470a886997d6647a77bb3e38dcbfa8c5 upstream. - MNT_NODEV should be irrelevant except when reading back mount flags, no longer specify MNT_NODEV on remount. - Test MNT_NODEV on devpts where it is meaningful even for unprivileged mounts. - Add a test to verify that remount of a prexisting mount with the same flags is allowed and does not change those flags. - Cleanup up the definitions of MS_REC, MS_RELATIME, MS_STRICTATIME that are used when the code is built in an environment without them. - Correct the test error messages when tests fail. There were not 5 tests that tested MS_RELATIME. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) sunhme driver lacks DMA mapping error checks, based upon a report by Meelis Roos. 2) Fix memory leak in mvpp2 driver, from Sudip Mukherjee. 3) DMA memory allocation sizes are wrong in systemport ethernet driver, fix from Florian Fainelli. 4) Fix use after free in mac80211 defragmentation code, from Johannes Berg. 5) Some networking uapi headers missing from Kbuild file, from Stephen Hemminger. 6) TUN driver gets csum_start offset wrong when VLAN accel is enabled, and macvtap has a similar bug, from Herbert Xu. 7) Adjust several tunneling drivers to set dev->iflink after registry, because registry sets that to -1 overwriting whatever we did. From Steffen Klassert. 8) Geneve forgets to set inner tunneling type, causing GSO segmentation to fail on some NICs. From Jesse Gross. 9) Fix several locking bugs in stmmac driver, from Fabrice Gasnier and Giuseppe CAVALLARO. 10) Fix spurious timeouts with NewReno on low traffic connections, from Marcelo Leitner. 11) Fix descriptor updates in enic driver, from Govindarajulu Varadarajan. 12) PPP calls bpf_prog_create() with locks held, which isn't kosher. Fix from Takashi Iwai. 13) Fix NULL deref in SCTP with malformed INIT packets, from Daniel Borkmann. 14) psock_fanout selftest accesses past the end of the mmap ring, fix from Shuah Khan. 15) Fix PTP timestamping for VLAN packets, from Richard Cochran. 16) netlink_unbind() calls in netlink pass wrong initial argument, from Hiroaki SHIMODA. 17) vxlan socket reuse accidently reuses a socket when the address family is different, so we have to explicitly check this, from Marcelo Lietner. 18) Fix missing include in nft_reject_bridge.c breaking the build on ppc and other architectures, from Guenter Roeck. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) vxlan: Do not reuse sockets for a different address family smsc911x: power-up phydev before doing a software reset. lib: rhashtable - Remove weird non-ASCII characters from comments net/smsc911x: Fix delays in the PHY enable/disable routines net/smsc911x: Fix rare soft reset timeout issue due to PHY power-down mode netlink: Properly unbind in error conditions. net: ptp: fix time stamp matching logic for VLAN packets. cxgb4 : dcb open-lldp interop fixes selftests/net: psock_fanout seg faults in sock_fanout_read_ring() net: bcmgenet: apply MII configuration in bcmgenet_open() net: bcmgenet: connect and disconnect from the PHY state machine net: qualcomm: Fix dependency ixgbe: phy: fix uninitialized status in ixgbe_setup_phy_link_tnx net: phy: Correctly handle MII ioctl which changes autonegotiation. ipv6: fix IPV6_PKTINFO with v4 mapped net: sctp: fix memory leak in auth key management net: sctp: fix NULL pointer dereference in af->from_addr_param on malformed packet net: ppp: Don't call bpf_prog_create() in ppp_lock net/mlx4_en: Advertize encapsulation offloads features only when VXLAN tunnel is set cxgb4 : Fix bug in DCB app deletion ...
2014-11-11selftests/net: psock_fanout seg faults in sock_fanout_read_ring()Shuah Khan
The while loop in sock_fanout_read_ring() checks mmap region bounds after access, causing it to segfault. Fix it to check count before accessing header->tp_status. This problem can be reproduced consistently when the test in run as follows: make -C tools/testing/selftests TARGETS=net run_tests or make run_tests from tools/testing/selftests or make run_test from tools/testing/selftests/net Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-04Merge tag 'ftracetest-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftracetest fix from Steven Rostedt: "Running the ftracetests on a machine that had the debugfs file system mounted in two locations caused the ftracetests to fail. This is because the ftracetests script does a grep of the /proc/mounts file to find where the debugfs file system is mounted. If it is mounted twice, then the grep returns two lines instead of just one. This causes the ftracetests to get confused and fail. Use "head -1" to only return the first mount point for debugfs" * tag 'ftracetest-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftracetest: Take the first debugfs mount found
2014-11-03ftracetest: Take the first debugfs mount foundSteven Rostedt (Red Hat)
Running ftracetests on a box that mounted debugfs in two locations made the ftracetests fail. This is because the tests uses a grep of debugfs from the /proc/mounts file to find the debugfs mount point, and then appends "/tracing" to that string to get the tracing directory. If the debugfs directory is mounted twice, then that grep will return two answers and appending "/tracing" to a string with two lines will not work. Use "head -1" to only take the first mount point found. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-10-31Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus on the kernel side: - a revert for a newly introduced PMU driver which isn't complete yet and where we ran out of time with fixes (to be tried again in v3.19) - this makes up for a large chunk of the diffstat. - compilation warning fixes - a printk message fix - event_idx usage fixes/cleanups" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Trivial typo fix for --demangle perf tools: Fix report -F dso_from for data without branch info perf tools: Fix report -F dso_to for data without branch info perf tools: Fix report -F symbol_from for data without branch info perf tools: Fix report -F symbol_to for data without branch info perf tools: Fix report -F mispredict for data without branch info perf tools: Fix report -F in_tx for data without branch info perf tools: Fix report -F abort for data without branch info perf tools: Make CPUINFO_PROC an array to support different kernel versions perf callchain: Use global caching provided by libunwind perf/x86/intel: Revert incomplete and undocumented Broadwell client support perf/x86: Fix compile warnings for intel_uncore perf: Fix typos in sample code in the perf_event.h header perf: Fix and clean up initialization of pmu::event_idx perf: Fix bogus kernel printk perf diff: Add missing hists__init() call at tool start
2014-10-29perf probe: Trivial typo fix for --demangleMasami Hiramatsu
Replace "Disable" with "Enable", since --demangle option enables symbol demangling, not disable it. perf probe has --demangle and --no-demangle options, but the command-line help (--help) shows only --demangle option. So it should explain about --demangle. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Hemant Kumar <hemant@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20141027203124.21219.68278.stgit@localhost.localdomain Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F dso_from for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F dso_from perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-8-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F dso_to for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F dso_to perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-7-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F symbol_from for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F symbol_from perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-6-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F symbol_to for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F symbol_to perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-5-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F mispredict for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F mispredict perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-4-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F in_tx for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F in_tx perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-3-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Fix report -F abort for data without branch infoJiri Olsa
The branch field sorting code assumes hist_entry::branch_info is allocated, which is wrong and following perf session ends up with report segfault. $ perf record ls $ perf report -F abort perf: Segmentation fault Checking that hist_entry::branch_info is valid and display "N/A" string in snprint callback if it's not. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1413468427-31049-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf tools: Make CPUINFO_PROC an array to support different kernel versionsWang Nan
After kernel 3.7 (commit b4b8f770eb10a1bccaf8aa0ec1956e2dd7ed1e0a), /proc/cpuinfo replaces 'Processor' to 'model name'. This patch makes CPUINFO_PROC to an array and provides two choices for ARM, makes it compatible for different kernel version. v1 -> v2: minor changes as suggested by Namhyung Kim: - Doesn't pass @h and @evlist to __write_cpudesc; - Coding style fix. v2 -> v3: - Rebase: git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux.git perf/core Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Li Zefan <lizefan@huawei.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1414115126-7479-1-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-29perf callchain: Use global caching provided by libunwindNamhyung Kim
The libunwind provides two caching policy which are global and per-thread. As perf unwinds callchains in a single thread, it'd sufficient to use global caching. This speeds up my perf report from 14s to 7s on a ~260MB data file. Although the output sometimes contains a slight difference (~0.01% in terms of number of lines printed) on callchains which were not resolved. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jean Pihet <jean.pihet@linaro.org> Cc: Arun Sharma <asharma@fb.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-22perf diff: Add missing hists__init() call at tool startKan Liang
It also uses hists/hist_entries, hists__init() should be called before creating any evsels. Otherwise no extra space will be allocated per perf_evsel nor this space will be initialized when allocating a new perf_evsel instance, resulting in reads/writes to non allocated space, oops. Fix it. Signed-off-by: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1414004561-22096-1-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-21ACPICA: acpiexec: Do not put STDIN into raw mode unless it is a terminal.Bob Moore
Eliminate an error message for batch-mode processing on unix systems. ACPICA BZ 1114. This patch is mainly for fixing the issues of acpiexec which is not in the Linux upstream. Link: https://bugs.acpica.org/show_bug.cgi?id=1114 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-21ACPICA: acpidump: Add ACPI 1.0 RSDP support.Lv Zheng
The acpidump currently always uses ACPI 2.0 format to dump RSDP, this patch adds ACPI 1.0 RSDP support. Link: https://bugs.acpica.org/show_bug.cgi?id=1097 Link: https://bugs.acpica.org/show_bug.cgi?id=1103 Signed-off-by: Lv Zheng <lv.zheng@intel.com> Reported-and-tested-by: Rudolf Marek <r.marek@assembler.cz> Reported-and-tested-by: Rafal <fatwildcat@gmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-10-17perf script: Add period as a default output columnJiri Olsa
Adding period as a default output column in script command fo hardware, software and raw events. If PERF_SAMPLE_PERIOD sample type is defined in perf.data, following will be displayed in perf script output: $ perf script ls 8034 57477.887209: 250000 task-clock: ffffffff81361d72 memset ([kernel.kallsyms]) ls 8034 57477.887464: 250000 task-clock: ffffffff816f6d92 _raw_spin_unlock_irqrestore ([kernel.kallsyms]) ls 8034 57477.887708: 250000 task-clock: ffffffff811a94f0 do_munmap ([kernel.kallsyms]) ls 8034 57477.887959: 250000 task-clock: 34080916c6 get_next_seq (/usr/lib64/libc-2.17.so) ls 8034 57477.888208: 250000 task-clock: 3408079230 _IO_doallocbuf (/usr/lib64/libc-2.17.so) ls 8034 57477.888717: 250000 task-clock: ffffffff814242c8 n_tty_write ([kernel.kallsyms]) ls 8034 57477.889285: 250000 task-clock: 3408076402 fwrite_unlocked (/usr/lib64/libc-2.17.so) Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: "Jen-Cheng(Tommy) Huang" <tommy24@gatech.edu> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jen-Cheng(Tommy) Huang <tommy24@gatech.edu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1408977943-16594-10-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf script: Add period data columnJiri Olsa
Adding period data column to be displayed in perf script. It's possible to get period values using -f option, like: $ perf script -f comm,tid,time,period,ip,sym,dso :26019 26019 52414.329088: 3707 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) :26019 26019 52414.329088: 44 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) :26019 26019 52414.329093: 1987 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) :26019 26019 52414.329093: 6 ffffffff8105443a native_write_msr_safe ([kernel.kallsyms]) ls 26019 52414.329442: 537558 3407c0639c _dl_map_object_from_fd (/usr/lib64/ld-2.17.so) ls 26019 52414.329442: 2099 3407c0639c _dl_map_object_from_fd (/usr/lib64/ld-2.17.so) ls 26019 52414.330181: 1242100 34080917bb get_next_seq (/usr/lib64/libc-2.17.so) ls 26019 52414.330181: 3774 34080917bb get_next_seq (/usr/lib64/libc-2.17.so) ls 26019 52414.331427: 1083662 ffffffff810c7dc2 update_curr ([kernel.kallsyms]) ls 26019 52414.331427: 360 ffffffff810c7dc2 update_curr ([kernel.kallsyms]) Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: "Jen-Cheng(Tommy) Huang" <tommy24@gatech.edu> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jen-Cheng(Tommy) Huang <tommy24@gatech.edu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1408977943-16594-9-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf evsel: No need to drag util/cgroup.hArnaldo Carvalho de Melo
The only thing we need is a forward declaration for 'struct cgroup_sel', that is inside 'struct perf_evsel'. Include cgroup.h instead on the tools that support cgroups. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-b7kuymbgf0zxi5viyjjtu5hk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf evlist: Add missing 'struct option' forward declarationArnaldo Carvalho de Melo
It was being found, by chance, because evsel.h needlessly includes util/cgroup.h, which will be sorted out in a following patch. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-xsvxr747wkkpg1ay9dramorr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-17perf evsel: Move exit stuff from __delete to __exitArnaldo Carvalho de Melo
So that when an evsel is embedded into other struct it can free up resources calling perf_evsel__exit(). Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-n1w68pfe9m2vkhm4sqs8y1en@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf kvm stat live: Enable events copyingAlexander Yarygin
Process of analyzing events caused by 2 functions: mmap_read() and finished_round(). During mmap_read(), perf receives events from shared memory, queues their pointers for further processing in finished_round() and notifies the kernel that the events have been processed. By the time when finished_round() is invoked, queued events can be overwritten by the kernel, so the finished_round() occurs on potentially corrupted memory. Since there is no place where the event can be safely consumed, let's copy events when queueing. Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1412347212-28237-3-git-send-email-yarygin@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf session: Add option to copy events when queueingAlexander Yarygin
When processing events the session code has an ordered samples queue which is used to time-sort events coming in across multiple mmaps. At a later point in time samples on the queue are flushed up to some timestamp at which point the event is actually processed. When analyzing events live (ie., record/analysis path in the same command) there is a race that leads to corrupted events and parse errors which cause perf to terminate. The problem is that when the event is placed in the ordered samples queue it is only a reference to the event which is really sitting in the mmap buffer. Even though the event is queued for later processing the mmap tail pointer is updated which indicates to the kernel that the event has been processed. The race is flushing the event from the queue before it gets overwritten by some other event. For commands trying to process events live (versus just writing to a file) and processing a high rate of events this leads to parse failures and perf terminates. Examples hitting this problem are 'perf kvm stat live', especially with nested VMs which generate 100,000+ traces per second, and a command processing scheduling events with a high rate of context switching -- e.g., running 'perf bench sched pipe'. This patch offers live commands an option to copy the event when it is placed in the ordered samples queue. Based on a patch from David Ahern <dsahern@gmail.com> Signed-off-by: Alexander Yarygin <yarygin@linux.vnet.ibm.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1412347212-28237-2-git-send-email-yarygin@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf Documentation: Fix typos in perf/DocumentationMasanari Iida
This patch fix spelling typos found in tool/perf/Documentation. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Randy Dunlap <rdunlap@infradead.org> Link: http://lkml.kernel.org/r/1410275930-17207-1-git-send-email-standby24x7@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf trace: Use thread_{,_set}_priv helpersNamhyung Kim
This is mechanical changes only for accounting access to thread->priv properly in the source level. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-6-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf kvm: Use thread_{,_set}_priv helpersNamhyung Kim
This is mechanical changes only for accounting access to thread->priv properly in the source level. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-5-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf callchain: Create an address space per threadNamhyung Kim
The unw_addr_space_t in libunwind represents an address space to be used for stack unwinding. It doesn't need to be create/destory everytime to unwind callchain (as in get_entries) and can have a same lifetime as thread (unless exec called). So move the address space construction/destruction logic to the thread lifetime handling functions. This is a preparation to enable caching in the unwind library. Note that it saves unw_addr_space_t object using thread__set_priv(). It seems currently only used by perf trace and perf kvm stat commands which don't use callchain. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jean Pihet <jean.pihet@linaro.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Arun Sharma <asharma@fb.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-3-git-send-email-namhyung@kernel.org [ Fixup unwind-libunwind.c missing CALLCHAIN_DWARF definition, added missing __maybe_unused on unused parameters in stubs at util/unwind.h ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf report: Set callchain_param.record_mode for future useNamhyung Kim
Normally the callchain_param.record_mode is used only for record path. But as it might need to prepare something for dwarf unwinding, setup this info for perf report too. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412556363-26229-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf evlist: Fix for double free in tools/perf statYasser Shalabi
Fix for double free bug in tools/perf due to dangling thread_map pointer in perf_evlist struct. Code path excercised when perf stat -C switch is used but not set and is followed by another switch. Example: perf stat -C -e. Signed-off-by: Yasser Shalabi <yassershalabi@gmail.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1412437077-13109-1-git-send-email-yassershalabi@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf test: Add test case for pmu event new style formatKan Liang
Add test case in automated tests suite. It checks not only the two types of pmu event stytle formats "pmu_event_name" and "cpu/pmu_event_name/", but also the different formats mixtures which are more likely to trigger parse issue. The patch set including this one has been tested by the perf automated test: ./perf test parse -v" On haswell, ivybridge and Romley platform. The patch set also has been tested on haswell by the following script. Note: please make sure that your test system support TSX and L1-dcache-loads events. Otherwise, you may want to change the events to other pmu events. [lk@localhost ~]$ cat perf_style_test.sh # hardware events + kernel pmu event with different style perf stat -x, -e cycles,mem-stores,tx-start sleep 2 perf stat -x, -e cpu-cycles,cycles-ct,cycles-t sleep 2 perf stat -x, -e cycles,cpu/cycles-ct/,cpu/cycles-t/ sleep 2 perf stat -x, -e instructions,cpu/tx-start/ sleep 2 perf stat -x, -e '{cycles,tx-start}' sleep 2 perf stat -x, -e '{cycles,cpu/tx-start/}' sleep 2 # HW Cache event + kernel pmu event with different style perf stat -x, -e L1-dcache-loads,cpu/mem-stores/,tx-start sleep 2 perf stat -x, -e L1-dcache-loads,mem-stores,cpu/tx-start/ sleep 2 perf stat -x, -e '{L1-dcache-loads,mem-stores}' sleep 2 perf stat -x, -e '{L1-dcache-loads,cpu/tx-start/}' sleep 2 # Raw event + kernel pmu event with different style: perf stat -x, -e cpu/event=0xc0,umask=0x00/,mem-loads,cpu/mem-stores/ sleep 2 perf stat -x, -e cpu/event=0xc0,umask=0x00/,tx-start,cpu/el-start/ sleep 2 perf stat -x, -e '{cpu/event=0xc0,umask=0x00/,tx-start}' sleep 2 Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1412694532-23391-5-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-10-15perf tools: Add support to new style format of kernel PMU eventKan Liang
Add new rules for kernel PMU event. Currently, the patch only want to handle the PMU event name as "a-b" and "a". event_pmu: PE_KERNEL_PMU_EVENT sep_dc | PE_PMU_EVENT_PRE '-' PE_PMU_EVENT_SUF sep_dc PE_KERNEL_PMU_EVENT token is for cycles-ct/cycles-t/mem-loads/mem-stores. The prefix cycles is mixed up with cpu-cycles. loads and stores are mixed up with cache event So they have to be hardcode in lex. PE_PMU_EVENT_PRE and PE_PMU_EVENT_SUF tokens are for other PMU events. The lex looks generic identifier up in the table and return the matched token. If there is no match, generic PE_NAME token will be return. Using the rules, kernel PMU event could use new style format without // so you can use: perf record -e mem-loads ... instead of: perf record -e cpu/mem-loads/ Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1412694532-23391-4-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
