commit e572d0887137acfc53f18175522964ec19d88175 upstream.
When doing a kernel build with 'make -s', everything is silenced except
the objtool build. That's because the tools tree support for silent
builds is some combination of missing and broken.
Three changes are needed to fix it:
- Makefile: propagate '-s' to the sub-make's MAKEFLAGS variable so the
tools Makefiles can see it.
- tools/scripts/Makefile.include: fix the tools Makefiles' ability to
recognize '-s'. The MAKE_VERSION and MAKEFLAGS checks are copied from
the top-level Makefile. This silences the "DESCEND objtool" message.
- tools/build/Makefile.build: add support to the tools Build files for
recognizing '-s'. Again the MAKE_VERSION and MAKEFLAGS checks are
copied from the top-level Makefile. This silences all the object
compile/link messages.
Reported-and-Tested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Michal Marek <mmarek@suse.com>
Link: http://lkml.kernel.org/r/e8967562ef640c3ae9a76da4ae0f4e47df737c34.1484799200.git.jpoimboe@redhat.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 321a7c35c90cc834851ceda18a8ee18f1d032b92 ]
Certain systems are designed to have sparse/discontiguous nodes. On
such systems, 'perf bench numa' hangs, shows wrong number of nodes and
shows values for non-existent nodes. Handle this by only taking nodes
that are exposed by kernel to userspace.
Signed-off-by: Satheesh Rajendran <sathnaga@linux.vnet.ibm.com>
Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1edbcd353c009e109e93d78f2f46381930c340fe.1511368645.git.sathnaga@linux.vnet.ibm.com
Signed-off-by: Balamuruhan S <bala24@linux.vnet.ibm.com>
[ Upstream commit 89d0aeab4252adc2a7ea693637dd21c588bfa2d1 ]
The stdio perf top crashes when we change the terminal
window size. The reason is that we assumed we get the
perf_top pointer as a signal handler argument which is
not the case.
Changing the SIGWINCH handler logic to change global
resize variable, which is checked in the main thread
loop.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Tested-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-ysuzwz77oev1ftgvdscn9bpu@git.kernel.org
commit 961888b1d76d84efc66a8f5604b06ac12ac2f978 upstream.
For distributions with old userspace header files, the _sigfault
structure is different. mpx-mini-test fails with the following
error:
[root@Purley]# mpx-mini-test_64 tabletest
XSAVE is supported by HW & OS
XSAVE processor supported state mask: 0x2ff
XSAVE OS supported state mask: 0x2ff
BNDREGS: size: 64 user: 1 supervisor: 0 aligned: 0
BNDCSR: size: 64 user: 1 supervisor: 0 aligned: 0
starting mpx bounds table test
ERROR: siginfo bounds do not match shadow bounds for register 0
Fix it by using the correct offset of _lower/_upper in _sigfault.
RHEL needs this patch to work.
Signed-off-by: Rui Wang <rui.y.wang@intel.com>
Cc: dave.hansen@linux.intel.com
Fixes: e754aedc26ef ("x86/mpx, selftests: Add MPX self test")
Link: http://lkml.kernel.org/r/1513586050-1641-1-git-send-email-rui.y.wang@intel.com
commit 4105c69703cdeba76f384b901712c9397b04e9c2 upstream.
On 64-bit builds, we should not rely on "int $0x80" working (it only does if
CONFIG_IA32_EMULATION=y is enabled). To keep the "Set TF and check int80"
test running on 64-bit installs with CONFIG_IA32_EMULATION=y enabled, build
this test only if we can also build 32-bit binaries (which should be a
good approximation for that).
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: linux-kselftest@vger.kernel.org
Cc: shuah@kernel.org
Link: http://lkml.kernel.org/r/20180211111013.16888-5-linux@dominikbrodowski.net
commit 2cbc0d66de0480449c75636f55697c7ff3af61fc upstream.
Without this patch, the move test may succeed, but the "int $0x80" causes
a segfault, resulting in a false negative output of this self-test.
Link: http://lkml.kernel.org/r/20180211111013.16888-4-linux@dominikbrodowski.net
commit ce676638fe7b284132a7d7d5e7e7ad81bab9947e upstream.
This also gets rid of two build warnings:
protection_keys.c: In function ‘dumpit’:
protection_keys.c:419:3: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result]
write(1, buf, nr_read);
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
commit 4c1baad223906943b595a887305f2e8124821dad upstream.
Running the compaction_test sometimes results in out-of-memory
failures. When I debugged this, it turned out that the code to
reset the number of hugepages to the initial value is simply
broken since we write into an open sysctl file descriptor
multiple times without seeking back to the start.
Adding the lseek here fixes the problem.
Cc: stable@vger.kernel.org
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Link: https://bugs.linaro.org/show_bug.cgi?id=3145
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit ef824501f50846589f02173d73ce3fe6021a9d2a upstream.
usbip host lists devices attached to vhci_hcd on the same server
when user does attach over localhost or specifies the server as the
remote.
usbip attach -r localhost -b busid
or
usbip attach -r servername (or server IP)
Fix it to check and not list devices that are attached to vhci_hcd.
commit ef54cf0c600fb8f5737fb001a9e357edda1a1de8 upstream.
usbip host binds to devices attached to vhci_hcd on the same server
remote.
or
Unbind followed by bind works, however device is left in a bad state with
accesses via the attached busid result in errors and system hangs during
shutdown.
Fix it to check and bail out if the device is already attached to vhci_hcd.
[ Upstream commit dbdc468f35ee827cab2753caa1c660bdb832243a ]
cpuidle_monitor used to assume that cpu0 is always online which is not
a valid assumption on POWER machines. This patch fixes this by getting
the cpu on which the current thread is running, instead of always using
cpu0 for monitoring which may not be online.
Signed-off-by: Abhishek Goel <huntbag@linux.vnet.ibm.com>
[ Upstream commit 53d1cd6b125fb9d69303516a1179ebc3b72f797a ]
cpupower_is_cpu_online was incorrectly checking for 0. This patch fixes
this by checking for 1 when the cpu is online.
commit 1696784eb7b52b13b62d160c028ef2c2c981d4f2 upstream.
The GPIO tools build fails when using a buildroot toolchain that uses musl
as it's C library:
arm-broomstick-linux-musleabi-gcc -Wp,-MD,./.gpio-event-mon.o.d \
-Wp,-MT,gpio-event-mon.o -O2 -Wall -g -D_GNU_SOURCE \
-Iinclude -D"BUILD_STR(s)=#s" -c -o gpio-event-mon.o gpio-event-mon.c
gpio-event-mon.c:30:6: error: unknown type name ‘u_int32_t’; did you mean ‘uint32_t’?
u_int32_t handleflags,
uint32_t
The glibc headers installed on my laptop include sys/types.h in
unistd.h, but it appears that musl does not.
Fixes: 97f69747d8b1 ("tools/gpio: add the gpio-event-mon tool")
Signed-off-by: Joel Stanley <joel@jms.id.au>
commit e5dfa3f902b9a642ae8c6997d57d7c41e384a90b upstream.
The usbip userspace tools call sprintf()/snprintf() and don't check for
the return value which can lead the paths to overflow, truncating the
final file in the path.
More urgently, GCC 7 now warns that these aren't checked with
-Wformat-overflow, and with -Werror enabled in configure.ac, that makes
these tools unbuildable.
This patch fixes these problems by replacing sprintf() with snprintf() in
one place and adding checks for the return value of snprintf().
Reviewed-by: Peter Senna Tschudin <peter.senna@gmail.com>
Signed-off-by: Jonathan Dieter <jdieter@lesbg.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
commit cfd6ed4537a9e938fa76facecd4b9cd65b6d1563 upstream.
GCC 7 now warns when switch statements fall through implicitly, and with
-Werror enabled in configure.ac, that makes these tools unbuildable.
We fix this by notifying the compiler that this particular case statement
is meant to fall through.
commit 2f2d0088eb93db5c649d2a5e34a3800a8a935fc5 upstream.
When a client has a USB device attached over IP, the vhci_hcd driver is
locally leaking a socket pointer address via the
/sys/devices/platform/vhci_hcd/status file (world-readable) and in debug
output when "usbip --debug port" is run.
Fix it to not leak. The socket pointer address is not used at the moment
and it was made visible as a convenient way to find IP address from socket
pointer address by looking up /proc/net/{tcp,tcp6}.
As this opens a security hole, the fix replaces socket pointer address with
sockfd.
Reported-by: Secunia Research <vuln@secunia.com>
commit 7a759cd8e8272ee18922838ee711219c7c796a31 upstream.
With commit: 0a943cb10ce78 (tools build: Add HOSTARCH Makefile variable)
when building for ARCH=x86_64, ARCH=x86_64 is passed to perf instead of
ARCH=x86, so the perf build process searchs header files from
tools/arch/x86_64/include, which doesn't exist.
The following build failure is seen:
In file included from util/event.c:2:0:
tools/include/uapi/linux/mman.h:4:27: fatal error: uapi/asm/mman.h: No such file or directory
compilation terminated.
Fix this issue by using SRCARCH instead of ARCH in perf, just like the
main kernel Makefile and tools/objtool's.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Eugeniu Rosca <erosca@de.adit-jv.com>
Cc: Jan Stancek <jstancek@redhat.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Rui Teng <rui.teng@linux.vnet.ibm.com>
Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Fixes: 0a943cb10ce7 ("tools build: Add HOSTARCH Makefile variable")
Link: http://lkml.kernel.org/r/1491793357-14977-2-git-send-email-jiada_wang@mentor.com
Cc: Tuomas Tynkkynen <tuomas@tuxera.com>
commit 385d11b152c4eb638eeb769edcb3249533bb9a00 upstream.
If a nonexistent file is supplied to objtool, it complains with a
non-helpful error:
open: No such file or directory
Improve it to:
objtool: Can't open 'foo': No such file or directory
Reported-by: Markus <M4rkusXXL@web.de>
Link: http://lkml.kernel.org/r/406a3d00a21225eee2819844048e17f68523ccf6.1516025651.git.jpoimboe@redhat.com
Objtool 1.0 (pre-ORC) produces the following warning when it encounters
a retpoline:
arch/x86/crypto/camellia-aesni-avx2-asm_64.o: warning: objtool: .altinstr_replacement+0xf: return instruction outside of a callable function
That warning is meant to catch GCC bugs and missing ENTRY/ENDPROC
annotations, neither of which are applicable to alternatives. Silence
the warning for alternative instructions, just like objtool 2.0 already
does.
Reported-by: David Woodhouse <dwmw2@infradead.org>
commit 352909b49ba0d74929b96af6dfbefc854ab6ebb5 upstream.
This tests that the vsyscall entries do what they're expected to do.
It also confirms that attempts to read the vsyscall page behave as
expected.
If changes are made to the vsyscall code or its memory map handling,
running this test in all three of vsyscall=none, vsyscall=emulate,
and vsyscall=native are helpful.
(Because it's easy, this also compares the vsyscall results to their
vDSO equivalents.)
Note to KAISER backporters: please test this under all three
vsyscall modes. Also, in the emulate and native modes, make sure
that test_vsyscall_64 agrees with the command line or config
option as to which mode you're in. It's quite easy to mess up
the kernel such that native mode accidentally emulates
or vice versa.
Greg, etc: please backport this to all your Meltdown-patched
kernels. It'll help make sure the patches didn't regress
vsyscalls.
CSigned-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Link: http://lkml.kernel.org/r/2b9c5a174c1d60fd7774461d518aa75598b1d8fd.1515719552.git.luto@kernel.org
commit 258c76059cece01bebae098e81bacb1af2edad17 upstream.
Getting objtool to understand retpolines is going to be a bit of a
challenge. For now, take advantage of the fact that retpolines are
patched in with alternatives. Just read the original (sane)
non-alternative instruction, and ignore the patched-in retpoline.
This allows objtool to understand the control flow *around* the
retpoline, even if it can't yet follow what's inside. This means the
ORC unwinder will fail to unwind from inside a retpoline, but will work
fine otherwise.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Cc: gnomes@lxorguk.ukuu.org.uk
Cc: thomas.lendacky@amd.com
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Kees Cook <keescook@google.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org>
Cc: Paul Turner <pjt@google.com>
Link: https://lkml.kernel.org/r/1515707194-20531-3-git-send-email-dwmw@amazon.co.uk
[dwmw2: Applies to tools/objtool/builtin-check.c not check.[ch]]
commit 39b735332cb8b33a27c28592d969e4016c86c3ea upstream.
A direct jump to a retpoline thunk is really an indirect jump in
disguise. Change the objtool instruction type accordingly.
Objtool needs to know where indirect branches are so it can detect
switch statement jump tables.
This fixes a bunch of warnings with CONFIG_RETPOLINE like:
arch/x86/events/intel/uncore_nhmex.o: warning: objtool: nhmex_rbox_msr_enable_event()+0x44: sibling call from callable instruction with modified stack frame
kernel/signal.o: warning: objtool: copy_siginfo_to_user()+0x91: sibling call from callable instruction with modified stack frame
Link: https://lkml.kernel.org/r/1515707194-20531-2-git-send-email-dwmw@amazon.co.uk
[dwmw2: Applies to tools/objtool/builtin-check.c not check.c]
commit e390f9a9689a42f477a6073e2e7df530a4c1b740 upstream.
The '__unreachable' and '__func_stack_frame_non_standard' sections are
only used at compile time. They're discarded for vmlinux but they
should also be discarded for modules.
Since this is a recurring pattern, prefix the section names with
".discard.". It's a nice convention and vmlinux.lds.h already discards
such sections.
Also remove the 'a' (allocatable) flag from the __unreachable section
since it doesn't make sense for a discarded section.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Jessica Yu <jeyu@redhat.com>
Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends")
Link: http://lkml.kernel.org/r/20170301180444.lhd53c5tibc4ns77@treble
[dwmw2: Remove the unreachable part in backporting since it's not here yet]
Signed-off-by: David Woodhouse <dwmw@amazon.co.ku>
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION.
Added "nokaiser" boot option: an early param like "noinvpcid".
Most places now check int kaiser_enabled (#defined 0 when not
CONFIG_KAISER) instead of #ifdef CONFIG_KAISER; but entry_64.S
and entry_64_compat.S are using the ALTERNATIVE technique, which
patches in the preferred instructions at runtime. That technique
is tied to x86 cpu features, so X86_FEATURE_KAISER is fabricated.
Prior to "nokaiser", Kaiser #defined _PAGE_GLOBAL 0: revert that,
but be careful with both _PAGE_GLOBAL and CR4.PGE: setting them when
nokaiser like when !CONFIG_KAISER, but not setting either when kaiser -
neither matters on its own, but it's hard to be sure that _PAGE_GLOBAL
won't get set in some obscure corner, or something add PGE into CR4.
By omitting _PAGE_GLOBAL from __supported_pte_mask when kaiser_enabled,
all page table setup which uses pte_pfn() masks it out of the ptes.
It's slightly shameful that the same declaration versus definition of
kaiser_enabled appears in not one, not two, but in three header files
(asm/kaiser.h, asm/pgtable.h, asm/tlbflush.h). I felt safer that way,
than with #including any of those in any of the others; and did not
feel it worth an asm/kaiser_enabled.h - kernel/cpu/common.c includes
them all, so we shall hear about it if they get out of synch.
Cleanups while in the area: removed the silly #ifdef CONFIG_KAISER
from kaiser.c; removed the unused native_get_normal_pgd(); removed
the spurious reg clutter from SWITCH_*_CR3 macro stubs; corrected some
comments. But more interestingly, set CR4.PSE in secondary_startup_64:
the manual is clear that it does not matter whether it's 0 or 1 when
4-level-pts are enabled, but I was distracted to find cr4 different on
BSP and auxiliaries - BSP alone was adding PSE, in probe_page_size_mask().
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 544c4605acc5ae4afe7dd5914147947db182f2fb upstream.
usbip bind writes commands followed by random string when writing to
match_busid attribute in sysfs, caused by using full variable size
instead of string length.
Signed-off-by: Juan Zea <juan.zea@qindel.com>
When building objtool, we get the warning:
warning: objtool: x86 instruction decoder differs from kernel
That's due to commit 2816c0455cea088f07a210f8a00701a82a78aa9c which was
commit 12a78d43de767eaf8fb272facb7a7b6f2dc6a9df upstream that modified
arch/x86/lib/x86-opcode-map.txt without also updating the objtool copy.
The objtool copy was updated in a much larger patch upstream, but we
don't need all of that here, so just update the single file.
If this gets too annoying, I'll just end up doing what we did for 4.14
and backport the whole series to keep this from happening again, but as
this seems to be rare in the 4.9-stable series, this single patch should
be fine.
[ Upstream commit e7ede72a6d40cb3a30c087142d79381ca8a31dab ]
The current symbols__fixup_end() heuristic for the last entry in the rb
tree is suboptimal as it leads to not being able to recognize the symbol
in the call graph in a couple of corner cases, for example:
i) If the symbol has a start address (f.e. exposed via kallsyms)
that is at a page boundary, then the roundup(curr->start, 4096)
for the last entry will result in curr->start == curr->end with
a symbol length of zero.
ii) If the symbol has a start address that is shortly before a page
boundary, then also here, curr->end - curr->start will just be
very few bytes, where it's unrealistic that we could perform a
match against.
Instead, change the heuristic to roundup(curr->start, 4096) + 4096, so
that we can catch such corner cases and have a better chance to find
that specific symbol. It's still just best effort as the real end of the
symbol is unknown to us (and could even be at a larger offset than the
current range), but better than the current situation.
Alexei reported that he recently run into case i) with a JITed eBPF
program (these are all page aligned) as the last symbol which wasn't
properly shown in the call graph (while other eBPF program symbols in
the rb tree were displayed correctly). Since this is a generic issue,
lets try to improve the heuristic a bit.
Reported-and-Tested-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Fixes: 2e538c4a1847 ("perf tools: Improve kernel/modules symbol lookup")
Link: http://lkml.kernel.org/r/bb5c80d27743be6f12afc68405f1956a330e1bc9.1489614365.git.daniel@iogearbox.net
[ Upstream commit 46aa6a302b53f543f8e8b8e1714dc5e449ad36a6 ]
linux/tools/testing/selftests/vm $ make
gcc -Wall -I ../../../../usr/include compaction_test.c -lrt -o /compaction_test
/usr/lib/gcc/x86_64-pc-linux-gnu/4.9.4/../../../../x86_64-pc-linux-gnu/bin/ld: cannot open output file /compaction_test: Permission denied
collect2: error: ld returned 1 exit status
make: *** [../lib.mk:54: /compaction_test] Error 1
Since commit a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT")
selftests/vm build fails if run from the "selftests/vm" directory, but
it works in the selftests/ directory. It's quicker to be able to do a
local vm-only build after a tree wipe and this patch allows for it
again.
Link: http://lkml.kernel.org/r/20170302173738.18994-4-aarcange@redhat.com
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
[ Upstream commit a6400120d042397675fcf694060779d21e9e762d ]
The MPX hardware data structurse are defined in a weird way: they define
their size in bytes and then union that with the type with which we want
to access them.
Yes, this is weird, but it does work. But, new GCC's complain that we
are accessing the array out of bounds. Just make it a zero-sized array
so gcc will stop complaining. There was not really a bug here.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/20171111001229.58A7933D@viggo.jf.intel.com
[ Upstream commit a6d8a21596df041f36f4c2ccc260c459e3e851f1 ]
Tests under alignment subdirectory are skipped when executed on previous
generation hardware, but harness still marks them as failed.
test: test_copy_unaligned
tags: git_version:unknown
[SKIP] Test skipped on line 26
skip: test_copy_unaligned
selftests: copy_unaligned [FAIL]
The MAGIC_SKIP_RETURN_VALUE value assigned to rc variable is retained till
the program exit which causes the test to be marked as failed.
This patch resets the value before returning to the main() routine.
With this patch the test o/p is as follows:
selftests: copy_unaligned [PASS]
Signed-off-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
[ Upstream commit 2a4d0c627f5374f365a873dea4e10ae0bb437680 ]
Kernel erases R8..R11 registers prior returning to userspace
from int80:
https://lkml.org/lkml/2009/10/1/164
GCC can reuse these registers and doesn't expect them to change
during syscall invocation. I met this kind of bug in CRIU once
GCC 6.1 and CLANG stored local variables in those registers
and the kernel zerofied them during syscall:
https://github.com/xemul/criu/commit/990d33f1a1cdd17bca6c2eb059ab3be2564f7fa2
By that reason I suggest to add those registers to clobbers
in selftests. Also, as noted by Andy - removed unneeded clobber
for flags in INT $0x80 inline asm.
Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: 0x7f454c46@gmail.com
Cc: Borislav Petkov <bp@suse.de>
Cc: Shuah Khan <shuah@kernel.org>
Link: http://lkml.kernel.org/r/20170213101336.20486-1-dsafonov@virtuozzo.com
commit 297d6b6e56c2977fc504c61bbeeaa21296923f89 upstream.
While reading in more than one block (50) of KVP records, the allocation
goes per block, but the reads used the total number of allocated records
(without resetting the pointer/stream). This causes the records buffer to
overrun when the refresh reads more than one block over the previous
capacity (e.g. reading more than 100 KVP records whereas the in-memory
database was empty before).
Fix this by reading the correct number of KVP records from file each time.
Signed-off-by: Paul Meyer <Paul.Meyer@microsoft.com>
Signed-off-by: Long Li <longli@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit 6ae8eefc6c8fe050f057781b70a83262eb0a61ee ]
LIST_POISON[12] are used to initialize list_head and hlist_node
pointers, and do void pointer arithmetic, which C++ doesn't like, so, to
avoid drifting from the kernel by introducing some HLIST_POISON to do
away with void pointer math, just make those poisoned pointers be NULL
when building it with a C++ compiler.
Noticed with:
$ make LLVM_CONFIG=/usr/bin/llvm-config-3.9 LIBCLANGLLVM=1
CXX util/c++/clang.o
CXX util/c++/clang-test.o
In file included from /home/lizj/linux/tools/include/linux/list.h:5:0,
from /home/lizj/linux/tools/perf/util/namespaces.h:13,
from /home/lizj/linux/tools/perf/util/util.h:15,
from /home/lizj/linux/tools/perf/util/util-cxx.h:20,
from util/c++/clang-c.h:5,
from util/c++/clang-test.cpp:2:
/home/lizj/linux/tools/include/linux/list.h: In function ‘void list_del(list_head*)’:
/home/lizj/linux/tools/include/linux/poison.h:14:31: error: pointer of type ‘void *’ used in arithmetic [-Werror=pointer-arith]
# define POISON_POINTER_DELTA 0
/home/lizj/linux/tools/include/linux/poison.h:22:41: note: in expansion of macro ‘POISON_POINTER_DELTA’
#define LIST_POISON1 ((void *) 0x100 + POISON_POINTER_DELTA)
/home/lizj/linux/tools/include/linux/list.h:107:16: note: in expansion of macro ‘LIST_POISON1’
entry->next = LIST_POISON1;
In file included from /home/lizj/linux/tools/perf/util/namespaces.h:13:0,
/home/lizj/linux/tools/include/linux/list.h:107:14: error: invalid conversion from ‘void*’ to ‘list_head*’ [-fpermissive]
Reported-by: Li Zhijian <lizhijian@cn.fujitsu.com>
Cc: Philip Li <philip.li@intel.com>
Link: http://lkml.kernel.org/n/tip-m5ei2o0mjshucbr28baf5lqz@git.kernel.org
[ Upstream commit 22905582f6dd4bbd0c370fe5732c607452010c04 ]
Command perf test -v 16 (Setup struct perf_event_attr test) always
reports success even if the test case fails. It works correctly if you
also specify -F (for don't fork).
root@s35lp76 perf]# ./perf test -v 16
15: Setup struct perf_event_attr :
--- start ---
running './tests/attr/test-record-no-delay'
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.002 MB /tmp/tmp4E1h7R/perf.data
(1 samples) ]
expected task=0, got 1
expected precise_ip=0, got 3
expected wakeup_events=1, got 0
FAILED './tests/attr/test-record-no-delay' - match failure
test child finished with 0
---- end ----
Setup struct perf_event_attr: Ok
The reason for the wrong error reporting is the return value of the
system() library call. It is called in run_dir() file tests/attr.c and
returns the exit status, in above case 0xff00.
This value is given as parameter to the exit() function which can only
handle values 0-0xff.
The child process terminates with exit value of 0 and the parent does
not detect any error.
This patch corrects the error reporting and prints the correct test
result.
Signed-off-by: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
LPU-Reference: 20170913081209.39570-2-tmricht@linux.vnet.ibm.com
Link: http://lkml.kernel.org/n/tip-rdube6rfcjsr1nzue72c7lqn@git.kernel.org
[ Upstream commit c15562c0dcb2c7f26e891923b784cf1926b8c833 ]
usbip_host_driver.h now depends on several additional headers, which
need to be installed along with it.
Fixes: 021aed845303 ("staging: usbip: userspace: migrate usbip_host_driver ...")
Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with ...")
[ Upstream commit fec8f5ae1715a01c72ad52cb2ecd8aacaf142302 ]
We weren't testing the .limit and .limit_in_pages fields very well.
Add more tests.
This addition seems to trigger the "bits 16:19 are undefined" issue
that was fixed in an earlier patch. I think that, at least on my
CPU, the high nibble of the limit ends in LAR bits 16:19.
Cc: Borislav Petkov <bpetkov@suse.de>
Link: http://lkml.kernel.org/r/5601c15ea9b3113d288953fd2838b18bedf6bc67.1509794321.git.luto@kernel.org
commit afb999cdef69148f366839e74470d8f5375ba5f1 upstream.
Some distributions (Debian, OpenSUSE) have a udev rule in place to cancel
all fallback mechanism uevents immediately. This would obviously
make it hard to test against the fallback mechanism test interface,
so we need to check for this.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 880444e214cfd293a2e8cc4bd3505f7ffa6ce33a upstream.
Error that we expect should not be spilled to stdout.
Without this we get:
./fw_filesystem.sh: line 58: printf: write error: Invalid argument
./fw_filesystem.sh: line 63: printf: write error: No such device
./fw_filesystem.sh: line 69: echo: write error: No such file or directory
./fw_filesystem.sh: filesystem loading works
./fw_filesystem.sh: async filesystem loading works
With it:
[ Upstream commit 75fc5ae5cc53fff71041ecadeb3354a2b4c9fe42 ]
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Link: http://lkml.kernel.org/r/1485952447-7013-2-git-send-email-treeze.taeung@gmail.com
[ Upstream commit 22048c5485503749754b3b5daf9d99ef89fcacdc ]
turbostat displays a GFXMHz column, which comes from reading
/sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz
But GFXMHz was not changing, even when a manual
cat /sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz
showed a new value.
It turns out that a rewind() on the open file is not sufficient,
fflush() (or a close/open) is needed to read fresh values.
Reported-by: Yaroslav Isakov <yaroslav.isakov@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 10859f3855db4c6f10dc7974ff4b3a292f3de8e0 upstream.
The 2.26 release of glibc changed how siginfo_t is defined, and the earlier
work-around to using the kernel definition are no longer needed. The old
way needs to stay around for a while, though.
Reported-by: Seth Forshee <seth.forshee@canonical.com>
Cc: Will Drewry <wad@chromium.org>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
commit 23d98c204386a98d9ef9f9e744f41443ece4929f upstream.
Those are funny cases. Make sure they work.
(Something is screwy with signal handling if a selector is 1, 2, or 3.
Anyone who wants to dive into that rabbit hole is welcome to do so.)
Cc: Chang Seok <chang.seok.bae@intel.com>
commit 0eb46345364d7318b11068c46e8a68d5dc10f65e upstream.
After the link tests, there is a race on one side of the test for
the link coming up. It's possible, in some cases, for the test script
to write to the 'peer_trans' files before the link has come up.
To fix this, we simply use the link event file to ensure both sides
see the link as up before continuning.
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Acked-by: Allen Hubbe <Allen.Hubbe@dell.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Fixes: a9c59ef77458 ("ntb_test: Add a selftest script for the NTB subsystem")
commit 07b0b22b3e58824f70b9188d085d400069ca3240 upstream.
The code mistakenly prints the local perf results for the remote test
so the script reports identical results for both directions. Fix this
by ensuring we print the remote result.
commit eebc509b20881b92d62e317b2c073e57c5f200f0 upstream.
Fix --funcs (-F) option to show correct symbols for offline module.
Since previous perf-probe uses machine__findnew_module_map() for offline
module, even if user passes a module file (with full path) which is for
other architecture, perf-probe always tries to load symbol map for
current kernel module.
This fix uses dso__new_map() to load the map from given binary as same
as a map for user applications.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/148350053478.19001.15435255244512631545.stgit@devbox
Cc: Krister Johansen <kjlx@templeofstupid.com>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ]
Those are binaries as well, so should be installed by:
make -C tools/perf install-bin'
too.
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ]
Currently, the sched:sched_switch tracepoint reports deadline tasks with
priority -1. But when reading the trace via perf script I've got the
following output:
# ./d & # (d is a deadline task, see [1])
# perf record -e sched:sched_switch -a sleep 1
# perf script
swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295]
d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295]
The task d reports the wrong priority [4294967295]. This happens because
the "int prio" is stored in an unsigned long long val. Although it is
set as a %lld, as int is shorter than unsigned long long,
trace_seq_printf prints it as a positive number.
The fix is just to cast the val as an int, and print it as a %d,
as in the sched:sched_switch tracepoint's "format".
The output with the fix is:
# ./d &
# perf script
swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1]
d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120]
[1] d.c
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <linux/types.h>
#include <linux/sched.h>
struct sched_attr {
__u32 size, sched_policy;
__u64 sched_flags;
__s32 sched_nice;
__u32 sched_priority;
__u64 sched_runtime, sched_deadline, sched_period;
int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags)
return syscall(__NR_sched_setattr, pid, attr, flags);
int main(void)
struct sched_attr attr = {
.size = sizeof(attr),
.sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */
.sched_runtime = 10 * 1000 * 1000,
.sched_period = attr.sched_deadline = 30 * 1000 * 1000,
if (sched_setattr(0, &attr, 0) < 0) {
perror("sched_setattr");
return -1;
for(;;);
Committer notes:
Got the program from the provided URL, http://bristot.me/lkml/d.c,
trimmed it and included in the cset log above, so that we have
everything needed to test it in one place.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com
[ Upstream commit 1f2ed153b916c95a49a1ca9d7107738664224b7f ]
Since 'perf probe' supports cross-arch probes, it is possible to analyze
different arch kernel image which has different bits-per-long.
In that case, it fails to get the module name because it uses the
MOD_NAME_OFFSET macro based on the host machine bits-per-long, instead
of the target arch bits-per-long.
This fixes above issue by changing modname-offset based on the target
archs bit width. This is ok because linux kernel uses LP64 model on
64bit arch.
E.g. without this (on x86_64, and target module is arm32):
$ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup
p:probe/configfs_lookup :configfs_lookup+0
^-Here is an empty module name.
With this fix, you can see correct module name:
p:probe/configfs_lookup configfs:configfs_lookup+0
Link: http://lkml.kernel.org/r/148337043836.6752.383495516397005695.stgit@devbox
