path: root/tools
2014-04-11Merge tag 'pm+acpi-3.15-rc1-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI and power management fixes and updates from Rafael Wysocki: "This is PM and ACPI material that has emerged over the last two weeks and one fix for a CPU hotplug regression introduced by the recent CPU hotplug notifiers registration series. Included are intel_idle and turbostat updates from Len Brown (these have been in linux-next for quite some time), a new cpufreq driver for powernv (that might spend some more time in linux-next, but BenH was asking me so nicely to push it for 3.15 that I couldn't resist), some cpufreq fixes and cleanups (including fixes for some silly breakage in a couple of cpufreq drivers introduced during the 3.14 cycle), assorted ACPI cleanups, wakeup framework documentation fixes, a new sysfs attribute for cpuidle and a new command line argument for power domains diagnostics. Specifics: - Fix for a recently introduced CPU hotplug regression in ARM KVM from Ming Lei. - Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32 cpufreq drivers introduced during the 3.14 cycle (-stable material) from Chen Gang and Viresh Kumar. - New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits from Gautham R Shenoy and Srivatsa S Bhat. - Exynos cpufreq driver fix preventing it from being included into multiplatform builds that aren't supported by it from Sachin Kamat. - cpufreq cleanups related to the usage of the driver_data field in struct cpufreq_frequency_table from Viresh Kumar. - cpufreq ppc driver cleanup from Sachin Kamat. - Intel BayTrail support for intel_idle and ACPI idle from Len Brown. - Intel CPU model 54 (Atom N2000 series) support for intel_idle from Jan Kiszka. - intel_idle fix for Intel Ivy Town residency targets from Len Brown. - turbostat updates (Intel Broadwell support and output cleanups) from Len Brown. - New cpuidle sysfs attribute for exporting C-states' target residency information to user space from Daniel Lezcano. - New kernel command line argument to prevent power domains enabled by the bootloader from being turned off even if they are not in use (for diagnostics purposes) from Tushar Behera. - Fixes for wakeup sysfs attributes documentation from Geert Uytterhoeven. - New ACPI video blacklist entry for ThinkPad Helix from Stephen Chandler Paul. - Assorted ACPI cleanups and a Kconfig help update from Jonghwan Choi, Zhihui Zhang, Hanjun Guo" * tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits) ACPI: Update the ACPI spec information in Kconfig arm, kvm: fix double lock on cpu_add_remove_lock cpuidle: sysfs: Export target residency information cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h cpufreq: create another field .flags in cpufreq_frequency_table cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table cpufreq: don't print value of .driver_data from core cpufreq: ia64: don't set .driver_data to index cpufreq: powernv: Select CPUFreq related Kconfig options for powernv cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids cpufreq: powernv: cpufreq driver for powernv platform cpufreq: at32ap: don't declare local variable as static cpufreq: loongson2_cpufreq: don't declare local variable as static cpufreq: unicore32: fix typo issue for 'clk' cpufreq: exynos: Disable on multiplatform build PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes PM / domains: Add pd_ignore_unused to keep power domains enabled ACPI / dock: Drop dock_device_ids[] table ACPI / video: Favor native backlight interface for ThinkPad Helix ACPI / thermal: Fix wrong variable usage in debug statement ...
2014-04-08Merge branch 'pm-cpuidle'Rafael J. Wysocki
* pm-cpuidle: cpuidle: sysfs: Export target residency information intel_idle: fine-tune IVT residency targets tools/power turbostat: Run on Broadwell tools/power turbostat: simplify output, add Avg_MHz intel_idle: Add CPU model 54 (Atom N2000 series) intel_idle: support Bay Trail intel_idle: allow sparse sub-state numbering, for Bay Trail ACPI idle: permit sparse C-state sub-state numbers
2014-04-08Merge branch 'release' of ↵Rafael J. Wysocki
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-cpuidle Pull intel_idle and turbostat material for v3.15-rc1 from Len Brown. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: intel_idle: fine-tune IVT residency targets tools/power turbostat: Run on Broadwell tools/power turbostat: simplify output, add Avg_MHz intel_idle: Add CPU model 54 (Atom N2000 series) intel_idle: support Bay Trail intel_idle: allow sparse sub-state numbering, for Bay Trail ACPI idle: permit sparse C-state sub-state numbers
2014-04-07tools/vm/page-types.c: page-cache sniffing featureKonstantin Khlebnikov
After this patch 'page-types' can walk over a file's mappings and analyze populated page cache pages mostly without disturbing its state. It maps chunk of file, marks VMA as MADV_RANDOM to turn off readahead, pokes VMA via mincore() to determine cached pages, triggers page-fault only for them, and finally gathers information via pagemap/kpageflags. Before unmap it marks VMA as MADV_SEQUENTIAL for ignoring reference bits. usage: page-types -f <path> If <path> is directory it will analyse all files in all subdirectories. Symlinks are not followed as well as mount points. Hardlinks aren't handled, they'll be dumped as many times as they are found. Recursive walk brings all dentries into dcache and populates page cache of block-devices aka 'Buffers'. Probably it's worth to add ioctl for dumping file page cache as array of PFNs as a replacement for this hackish juggling with mmap/madvise/mincore/pagemap. Also recursive walk could be replaced with dumping cached inodes via some ioctl or debugfs interface followed by openning them via open_by_handle_at, this would fix hardlinks handling and unneeded population of dcache and buffers. This interface might be used as data source for constructing readahead plans and for background optimizations of actively used files. collateral changes: + fix 64-bit LFS: define _FILE_OFFSET_BITS instead of _LARGEFILE64_SOURCE + replace lseek + read with single pread + make show_page_range() reusable after flush usage example: ~/src/linux/tools/vm$ sudo ./page-types -L -f page-types foffset offset flags page-types Inode: 2229277 Size: 89065 (22 pages) Modify: Tue Feb 25 12:00:59 2014 (162 seconds ago) Access: Tue Feb 25 12:01:00 2014 (161 seconds ago) 0 3cbf3b __RU_lA____M________________________ 1 38946a __RU_lA____M________________________ 2 1a3cec __RU_lA____M________________________ 3 1a8321 __RU_lA____M________________________ 4 3af7cc __RU_lA____M________________________ 5 1ed532 __RU_lA_____________________________ 6 2e436a __RU_lA_____________________________ 7 29a35e ___U_lA_____________________________ 8 2de86e ___U_lA_____________________________ 9 3bdfb4 ___U_lA_____________________________ 10 3cd8a3 ___U_lA_____________________________ 11 2afa50 ___U_lA_____________________________ 12 2534c2 ___U_lA_____________________________ 13 1b7a40 ___U_lA_____________________________ 14 17b0be ___U_lA_____________________________ 15 392b0c ___U_lA_____________________________ 16 3ba46a __RU_lA_____________________________ 17 397dc8 ___U_lA_____________________________ 18 1f2a36 ___U_lA_____________________________ 19 21fd30 __RU_lA_____________________________ 20 2c35ba __RU_l______________________________ 21 20f181 __RU_l______________________________ flags page-count MB symbolic-flags long-symbolic-flags 0x000000000000002c 2 0 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 11 0 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 4 0 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000086c 5 0 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 22 0 ~/src/linux/tools/vm$ sudo ./page-types -f / flags page-count MB symbolic-flags long-symbolic-flags 0x0000000000000028 21761 85 ___U_l______________________________ uptodate,lru 0x000000000000002c 127279 497 __RU_l______________________________ referenced,uptodate,lru 0x0000000000000068 74160 289 ___U_lA_____________________________ uptodate,lru,active 0x000000000000006c 84469 329 __RU_lA_____________________________ referenced,uptodate,lru,active 0x000000000000007c 1 0 __RUDlA_____________________________ referenced,uptodate,dirty,lru,active 0x0000000000000228 370 1 ___U_l___I__________________________ uptodate,lru,reclaim 0x0000000000000828 49 0 ___U_l_____M________________________ uptodate,lru,mmap 0x000000000000082c 126 0 __RU_l_____M________________________ referenced,uptodate,lru,mmap 0x0000000000000868 137 0 ___U_lA____M________________________ uptodate,lru,active,mmap 0x000000000000086c 12890 50 __RU_lA____M________________________ referenced,uptodate,lru,active,mmap total 321242 1254 Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Borislav Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
Pull arch/tile updates from Chris Metcalf: "These fix a few stray build issues seen in linux-next, and also add the minimal required support for perf to tilegx" * git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: remove unused variable 'devcap' tile: Fix vDSO compilation issue with allyesconfig perf tools: Allow building for tile tile/perf: Support perf_events on tilegx and tilepro tile: Enable NMIs on return from handle_nmi() without errors tile: Add support for handling PMC hardware tile: don't use __get_cpu_var() with structure-typed arguments tile: avoid overflow in ns2cycles
2014-04-04Merge tag 'ktest-v3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull single ktest fix from Steven Rostedt: "This just contains a single update by Satoru Takeuchi, which adds CLOSE_CONSOLE_SIGNAL to the kvm.conf file, as the kvm guest requires a different signal than a normal console uses" * tag 'ktest-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Set CLOSE_CONSOLE_SIGNAL in the kvm.conf
2014-04-04Merge branches 'turbostat' and 'intel_idle' into releaseLen Brown
2014-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Here is my initial pull request for the networking subsystem during this merge window: 1) Support for ESN in AH (RFC 4302) from Fan Du. 2) Add full kernel doc for ethtool command structures, from Ben Hutchings. 3) Add BCM7xxx PHY driver, from Florian Fainelli. 4) Export computed TCP rate information in netlink socket dumps, from Eric Dumazet. 5) Allow IPSEC SA to be dumped partially using a filter, from Nicolas Dichtel. 6) Convert many drivers to pci_enable_msix_range(), from Alexander Gordeev. 7) Record SKB timestamps more efficiently, from Eric Dumazet. 8) Switch to microsecond resolution for TCP round trip times, also from Eric Dumazet. 9) Clean up and fix 6lowpan fragmentation handling by making use of the existing inet_frag api for it's implementation. 10) Add TX grant mapping to xen-netback driver, from Zoltan Kiss. 11) Auto size SKB lengths when composing netlink messages based upon past message sizes used, from Eric Dumazet. 12) qdisc dumps can take a long time, add a cond_resched(), From Eric Dumazet. 13) Sanitize netpoll core and drivers wrt. SKB handling semantics. Get rid of never-used-in-tree netpoll RX handling. From Eric W Biederman. 14) Support inter-address-family and namespace changing in VTI tunnel driver(s). From Steffen Klassert. 15) Add Altera TSE driver, from Vince Bridgers. 16) Optimizing csum_replace2() so that it doesn't adjust the checksum by checksumming the entire header, from Eric Dumazet. 17) Expand BPF internal implementation for faster interpreting, more direct translations into JIT'd code, and much cleaner uses of BPF filtering in non-socket ocntexts. From Daniel Borkmann and Alexei Starovoitov" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1976 commits) netpoll: Use skb_irq_freeable to make zap_completion_queue safe. net: Add a test to see if a skb is freeable in irq context qlcnic: Fix build failure due to undefined reference to `vxlan_get_rx_port' net: ptp: move PTP classifier in its own file net: sxgbe: make "core_ops" static net: sxgbe: fix logical vs bitwise operation net: sxgbe: sxgbe_mdio_register() frees the bus Call efx_set_channels() before efx->type->dimension_resources() xen-netback: disable rogue vif in kthread context net/mlx4: Set proper build dependancy with vxlan be2net: fix build dependency on VxLAN mac802154: make csma/cca parameters per-wpan mac802154: allow only one WPAN to be up at any given time net: filter: minor: fix kdoc in __sk_run_filter netlink: don't compare the nul-termination in nla_strcmp can: c_can: Avoid led toggling for every packet. can: c_can: Simplify TX interrupt cleanup can: c_can: Store dlc private can: c_can: Reduce register access can: c_can: Make the code readable ...
2014-04-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio updates from Rusty Russell: "Nothing exciting: virtio-blk users might see a bit of a boost from the doubling of the default queue length though" * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio-blk: base queue-depth on virtqueue ringsize or module param Revert a02bbb1ccfe8: MAINTAINERS: add virtio-dev ML for virtio virtio: fail adding buffer on broken queues. virtio-rng: don't crash if virtqueue is broken. virtio_balloon: don't crash if virtqueue is broken. virtio_blk: don't crash, report error if virtqueue is broken. virtio_net: don't crash if virtqueue is broken. virtio_balloon: don't softlockup on huge balloon changes. virtio: Use pci_enable_msix_exact() instead of pci_enable_msix() MAINTAINERS: virtio-dev is subscribers only tools/virtio: add a missing ) tools/virtio: fix missing kmemleak_ignore symbol tools/virtio: update internal copies of headers
2014-04-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull main powerpc updates from Ben Herrenschmidt: "This time around, the powerpc merges are going to be a little bit more complicated than usual. This is the main pull request with most of the work for this merge window. I will describe it a bit more further down. There is some additional cpuidle driver work, however I haven't included it in this tree as it depends on some work in tip/timer-core which Thomas accidentally forgot to put in a topic branch. Since I didn't want to carry all of that tip timer stuff in powerpc -next, I setup a separate branch on top of Thomas tree with just that cpuidle driver in it, and Stephen has been carrying that in next separately for a while now. I'll send a separate pull request for it. Additionally, two new pieces in this tree add users for a sysfs API that Tejun and Greg have been deprecating in drivers-core-next. Thankfully Greg reverted the patch that removes the old API so this merge can happen cleanly, but once merged, I will send a patch adjusting our new code to the new API so that Greg can send you the removal patch. Now as for the content of this branch, we have a lot of perf work for power8 new counters including support for our new "nest" counters (also called 24x7) under pHyp (not natively yet). We have new functionality when running under the OPAL firmware (non-virtualized or KVM host), such as access to the firmware error logs and service processor dumps, system parameters and sensors, along with a hwmon driver for the latter. There's also a bunch of bug fixes accross the board, some LE fixes, and a nice set of selftests for validating our various types of copy loops. On the Freescale side, we see mostly new chip/board revisions, some clock updates, better support for machine checks and debug exceptions, etc..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (70 commits) powerpc/book3s: Fix CFAR clobbering issue in machine check handler. powerpc/compat: 32-bit little endian machine name is ppcle, not ppc powerpc/le: Big endian arguments for ppc_rtas() powerpc: Use default set of netfilter modules (CONFIG_NETFILTER_ADVANCED=n) powerpc/defconfigs: Enable THP in pseries defconfig powerpc/mm: Make sure a local_irq_disable prevent a parallel THP split powerpc: Rate-limit users spamming kernel log buffer powerpc/perf: Fix handling of L3 events with bank == 1 powerpc/perf/hv_{gpci, 24x7}: Add documentation of device attributes powerpc/perf: Add kconfig option for hypervisor provided counters powerpc/perf: Add support for the hv 24x7 interface powerpc/perf: Add support for the hv gpci (get performance counter info) interface powerpc/perf: Add macros for defining event fields & formats powerpc/perf: Add a shared interface to get gpci version and capabilities powerpc/perf: Add 24x7 interface headers powerpc/perf: Add hv_gpci interface header powerpc: Add hvcalls for 24x7 and gpci (Get Performance Counter Info) sysfs: create bin_attributes under the requested group powerpc/perf: Enable BHRB access for EBB events powerpc/perf: Add BHRB constraint and IFM MMCRA handling for EBB ...
2014-04-01Merge tag 'char-misc-3.15-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver updates for 3.15-rc1. Lots of various things here, including the new mcb driver subsystem. All of these have been in linux-next for a while" * tag 'char-misc-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (118 commits) extcon: Move OF helper function to extcon core and change function name extcon: of: Remove unnecessary function call by using the name of device_node extcon: gpio: Use SIMPLE_DEV_PM_OPS macro extcon: palmas: Use SIMPLE_DEV_PM_OPS macro mei: don't use deprecated DEFINE_PCI_DEVICE_TABLE macro mei: amthif: fix checkpatch error mei: client.h fix checkpatch errors mei: use cl_dbg where appropriate mei: fix Unnecessary space after function pointer name mei: report consistently copy_from/to_user failures mei: drop pr_fmt macros mei: make me hw headers private to me hw. mei: fix memory leak of pending write cb objects mei: me: do not reset when less than expected data is received drivers: mcb: Fix build error discovered by 0-day bot cs5535-mfgpt: Simplify dependencies spmi: pm: drop bus-level PM suspend/resume routines spmi: pmic_arb: make selectable on ARCH_QCOM Drivers: hv: vmbus: Increase the limit on the number of pfns we can handle pch_phub: Report error writing MAC back to user ...
2014-03-31Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Main changes: Kernel side changes: - Add SNB/IVB/HSW client uncore memory controller support (Stephane Eranian) - Fix various x86/P4 PMU driver bugs (Don Zickus) Tooling, user visible changes: - Add several futex 'perf bench' microbenchmarks (Davidlohr Bueso) - Speed up thread map generation (Don Zickus) - Introduce 'perf kvm --list-cmds' command line option for use by scripts (Ramkumar Ramachandra) - Print the evsel name in the annotate stdio output, prep to fix support outputting annotation for multiple events, not just for the first one (Arnaldo Carvalho de Melo) - Allow setting preferred callchain method in .perfconfig (Jiri Olsa) - Show in what binaries/modules 'perf probe's are set (Masami Hiramatsu) - Support distro-style debuginfo for uprobe in 'perf probe' (Masami Hiramatsu) Tooling, internal changes and fixes: - Use tid in mmap/mmap2 events to find maps (Don Zickus) - Record the reason for filtering an address_location (Namhyung Kim) - Apply all filters to an addr_location (Namhyung Kim) - Merge al->filtered with hist_entry->filtered in report/hists (Namhyung Kim) - Fix memory leak when synthesizing thread records (Namhyung Kim) - Use ui__has_annotation() in 'report' (Namhyung Kim) - hists browser refactorings to reuse code accross UIs (Namhyung Kim) - Add support for the new DWARF unwinder library in elfutils (Jiri Olsa) - Fix build race in the generation of bison files (Jiri Olsa) - Further streamline the feature detection display, trimming it a bit to show just the libraries detected, using VF=1 gets a more verbose output, showing the less interesting feature checks as well (Jiri Olsa). - Check compatible symtab type before loading dso (Namhyung Kim) - Check return value of filename__read_debuglink() (Stephane Eranian) - Move some hashing and fs related code from tools/perf/util/ to tools/lib/ so that it can be used by more tools/ living utilities (Borislav Petkov) - Prepare DWARF unwinding code for using an elfutils alternative unwinding library (Jiri Olsa) - Fix DWARF unwind max_stack processing (Jiri Olsa) - Add dwarf unwind 'perf test' entry (Jiri Olsa) - 'perf probe' improvements including memory leak fixes, sharing the intlist class with other tools, uprobes/kprobes code sharing and use of ref_reloc_sym (Masami Hiramatsu) - Shorten sample symbol resolving by adding cpumode to struct addr_location (Arnaldo Carvalho de Melo) - Fix synthesizing mmaps for threads (Don Zickus) - Fix invalid output on event group stdio report (Namhyung Kim) - Fixup header alignment in 'perf sched latency' output (Ramkumar Ramachandra) - Fix off-by-one error in 'perf timechart record' argv handling (Ramkumar Ramachandra) Tooling, cleanups: - Remove unused thread__find_map function (Jiri Olsa) - Remove unused simple_strtoul() function (Ramkumar Ramachandra) Tooling, documentation updates: - Update function names in debug messages (Ramkumar Ramachandra) - Update some code references in design.txt (Ramkumar Ramachandra) - Clarify load-latency information in the 'perf mem' docs (Andi Kleen) - Clarify x86 register naming in 'perf probe' docs (Andi Kleen)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (96 commits) perf tools: Remove unused simple_strtoul() function perf tools: Update some code references in design.txt perf evsel: Update function names in debug messages perf tools: Remove thread__find_map function perf annotate: Print the evsel name in the stdio output perf report: Use ui__has_annotation() perf tools: Fix memory leak when synthesizing thread records perf tools: Use tid in mmap/mmap2 events to find maps perf report: Merge al->filtered with hist_entry->filtered perf symbols: Apply all filters to an addr_location perf symbols: Record the reason for filtering an address_location perf sched: Fixup header alignment in 'latency' output perf timechart: Fix off-by-one error in 'record' argv handling perf machine: Factor machine__find_thread to take tid argument perf tools: Speed up thread map generation perf kvm: introduce --list-cmds for use by scripts perf ui hists: Pass evsel to hpp->header/width functions explicitly perf symbols: Introduce thread__find_cpumode_addr_location perf session: Change header.misc dump from decimal to hex perf ui/tui: Reuse generic __hpp__fmt() code ...
2014-03-31Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU updates from Ingo Molnar: "Main changes: - Torture-test changes, including refactoring of rcutorture and introduction of a vestigial locktorture. - Real-time latency fixes. - Documentation updates. - Miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (77 commits) rcu: Provide grace-period piggybacking API rcu: Ensure kernel/rcu/rcu.h can be sourced/used stand-alone rcu: Fix sparse warning for rcu_expedited from kernel/ksysfs.c notifier: Substitute rcu_access_pointer() for rcu_dereference_raw() Documentation/memory-barriers.txt: Clarify release/acquire ordering rcutorture: Save kvm.sh output to log rcutorture: Add a lock_busted to test the test rcutorture: Place kvm-test-1-run.sh output into res directory rcutorture: Rename TREE_RCU-Kconfig.txt locktorture: Add kvm-recheck.sh plug-in for locktorture rcutorture: Gracefully handle NULL cleanup hooks locktorture: Add vestigial locktorture configuration rcutorture: Introduce "rcu" directory level underneath configs rcutorture: Rename kvm-test-1-rcu.sh rcutorture: Remove RCU dependencies from ver_functions.sh API rcutorture: Create CFcommon file for common Kconfig parameters rcutorture: Create config files for scripted test-the-test testing rcutorture: Add an rcu_busted to test the test locktorture: Add a lock-torture kernel module rcutorture: Abstract kvm-recheck.sh ...
2014-03-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: Documentation/devicetree/bindings/net/micrel-ks8851.txt net/core/netpoll.c The net/core/netpoll.c conflict is a bug fix in 'net' happening to code which is completely removed in 'net-next'. In micrel-ks8851.txt we simply have overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-18perf tools: Remove unused simple_strtoul() functionRamkumar Ramachandra
Moreover, the corresponding function in include/linux/kernel.h is marked obsolete. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395176715-4465-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Update some code references in design.txtRamkumar Ramachandra
Update the names of some functions and enums in design.txt. The document still has some stale information, but the motivation behind this patch is to allow a developer to quickly grep and learn about the associated structures. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395169804-1293-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf evsel: Update function names in debug messagesRamkumar Ramachandra
perf_event_open() was renamed to sys_perf_event_open(); update the debug messages to reflect this. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395169842-1399-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Remove thread__find_map functionJiri Olsa
Because it's not used any more. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1395154016-26709-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf annotate: Print the evsel name in the stdio outputArnaldo Carvalho de Melo
So that when showing multiple events annotations, we can figure out which is which: # perf record -a -e instructions,cycles sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.826 MB perf.data (~36078 samples) ] # perf evlist instructions cycles # perf annotate intel_idle 2> /dev/null | head -1 Percent | Source code & Disassembly of vmlinux for instructions # Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-n1r51l329434js84qtb2c6l9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf report: Use ui__has_annotation()Namhyung Kim
Since we introduced the ui__has_annotation() for that, don't open code it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1395124359-11744-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Fix memory leak when synthesizing thread recordsNamhyung Kim
Checking default guest machine should be done before allocating event structures otherwise it'll leak memory. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joe Mario <jmario@redhat.com> Link: http://lkml.kernel.org/r/87ob15tx6a.fsf@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf tools: Use tid in mmap/mmap2 events to find mapsDon Zickus
Now that we can properly synthesize threads system-wide, make sure the mmap and mmap2 events use tids instead of pids to locate their maps. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1393429527-167840-3-git-send-email-dzickus@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf report: Merge al->filtered with hist_entry->filteredNamhyung Kim
I.e. don't drop al->filtered entries, create the hist_entries and use its ->filtered bitmap, that is kept with the same semantics for its bitmap, leaving the filtering to be done at the hist_entry level, i.e. in the UIs. This will allow zooming in/out the filters. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-xeyhkepu7plw716lrtb0zlnu@git.kernel.org [ yanked this out of a previous patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf symbols: Apply all filters to an addr_locationNamhyung Kim
Instead of bailing out as soon as we find a filter that applies, go on checking all of them so that we can zoom in/out filters. We also need to make sure we only update al->filtered after thread__find_addr_map(), because there is where al->filtered gets initialized to zero. This will increase the cost of processing when all we don't need this toggling, but will provide flexibility for the TUI and GTK+ interfaces, that will incur in creating the hist_entries just once. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-fhv9lhzdjxgp9w3w3668lsfw@git.kernel.org [ yanked this out of a previous patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf symbols: Record the reason for filtering an address_locationNamhyung Kim
By turning the addr_location->filtered member from a boolean to a u8 bitmap, reusing (and extending) the hist_filter enum for that. This patch doesn't change the logic at all, as it keeps the meaning of al->filtered !0 to mean that the entry _was_ filtered, so no change in how this value is interpreted needs to be done at this point. This will be soon used in upcoming patches. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-89hmfgtr9t22sky1lyg7nw7l@git.kernel.org [ yanked this out of a previous patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf sched: Fixup header alignment in 'latency' outputRamkumar Ramachandra
Before: --------------------------------------------------------------------------------------------------------------- Task | Runtime ms | Switches | Average delay ms | Maximum delay ms | Maximum delay at | --------------------------------------------------------------------------------------------------------------- ... | | | | | git:24540 | 336.622 ms | 10 | avg: 0.032 ms | max: 0.062 ms | max at: 115610.111046 s git:24541 | 0.457 ms | 1 | avg: 0.000 ms | max: 0.000 ms | max at: 0.000000 s ----------------------------------------------------------------------------------------- TOTAL: | 396.542 ms | 353 | --------------------------------------------------- After: ----------------------------------------------------------------------------------------------------------------- Task | Runtime ms | Switches | Average delay ms | Maximum delay ms | Maximum delay at | ----------------------------------------------------------------------------------------------------------------- ... | | | | | git:24540 | 336.622 ms | 10 | avg: 0.032 ms | max: 0.062 ms | max at: 115610.111046 s git:24541 | 0.457 ms | 1 | avg: 0.000 ms | max: 0.000 ms | max at: 0.000000 s ----------------------------------------------------------------------------------------------------------------- TOTAL: | 396.542 ms | 353 | --------------------------------------------------- Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1395065901-25740-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18perf timechart: Fix off-by-one error in 'record' argv handlingRamkumar Ramachandra
Since 367b315 (perf timechart: Add support for -P and -T in timechart recording, 2013-11-01), the 'perf timechart record' command stopped working: $ perf timechart record -- git status Workload failed: No such file or directory This happens because of an off-by-one error while preparing the argv for cmd_record(): it attempts to execute the command 'status' and complains that it doesn't exist. Fix this error. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Acked-by: Stanislav Fomichev <stfomichev@yandex-team.ru> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stanislav Fomichev <stfomichev@yandex-team.ru> Link: http://lkml.kernel.org/r/1394985965-2332-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-18Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull two 'perf bench' fixes from Arnaldo: * Make 'perf bench mem' (i.e. no args) mean 'run all tests' so that we can run all tests, not stopping at the numa ones. (Arnaldo Carvalho de Melo) * Fix NULL pointer dereference after last test in in "perf bench all" (Patrick Palka) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-16Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc smaller fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Fix leak in uncore_type_init failure paths perf machine: Use map as success in ip__resolve_ams perf symbols: Fix crash in elf_section_by_name perf trace: Decode architecture-specific signal numbers
2014-03-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c drivers/net/xen-netback/netback.c Both the r8152 and netback conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14perf machine: Factor machine__find_thread to take tid argumentJiri Olsa
Forcing the code to always search thread by pid/tid pair. The PID value will be needed in future to determine the process thread leader for map groups sharing. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1394805606-25883-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf tools: Speed up thread map generationDon Zickus
When trying to capture perf data on a system running spejbb2013, perf hung for about 15 minutes. This is because it took that long to gather about 10,000 thread maps and process them. I don't think a user wants to wait that long. Instead, recognize that thread maps are roughly equivalent to pid maps and just quickly copy those instead. To do this, I synthesize 'fork' events, this eventually calls thread__fork() and copies the maps over. The overhead goes from 15 minutes down to about a few seconds. -- V2: based on Jiri's comments, moved malloc up a level and made sure the memory was freed Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joe Mario <jmario@redhat.com> Link: http://lkml.kernel.org/r/1394808224-113774-1-git-send-email-dzickus@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf kvm: introduce --list-cmds for use by scriptsRamkumar Ramachandra
Introduce $ perf kvm --list-cmds to dump a raw list of commands for use by the completion script. In order to do this, introduce parse_options_subcommand() for handling subcommands as a special case in the parse-options machinery. Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1393896396-10427-1-git-send-email-artagnon@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf ui hists: Pass evsel to hpp->header/width functions explicitlyNamhyung Kim
Those functions need evsel to investigate event group and it's passed via hpp->ptr. However as it can be missed easily so it's better to pass it via an argument IMHO. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1394437440-11609-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf symbols: Introduce thread__find_cpumode_addr_locationArnaldo Carvalho de Melo
Its one level up thread__find_addr_location, where it will look in different domains for a sample: user, kernel, hypervisor, etc. Will soon be used by a patchkit by Andi Kleen. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-so6nxkh7xj48bc5kq4jpj991@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf session: Change header.misc dump from decimal to hexDon Zickus
When printing the raw dump of a data file, the header.misc is printed as a decimal. Unfortunately, that field is a bit mask, so it is hard to interpret as a decimal. Print in hex, so the user can easily see what bits are set and more importantly what type of info it is conveying. V2: add 0x in front per Jiri Olsa Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1393386227-149412-3-git-send-email-dzickus@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf ui/tui: Reuse generic __hpp__fmt() codeNamhyung Kim
The __hpp__color_fmt used in the TUI code can be replace by the generic code with small change in print_fn callback. And it also needs to move callback function to the generic __hpp__fmt(). No functional changes intended. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393809254-4480-5-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf ui/hists: Pass struct hpp to print functionsNamhyung Kim
Instead of the pointer to buffer and its size so that it can also get private argument passed along with hpp. This is a preparation of further change. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393809254-4480-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf ui/gtk: Reuse generic __hpp__fmt() codeNamhyung Kim
The __hpp__color_fmt used in the gtk code can be replace by the generic code with small change in print_fn callback. This is a preparation to upcoming changes and no functional changes intended. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393809254-4480-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf ui/stdio: Fix invalid output on event group reportNamhyung Kim
When some of group member has 0 overhead, it printed previous percentage instead of 0.00%. It's because passing integer 0 as a percent rather than double 0.0 so the remaining bits came from garbage. The TUI and GTK don't have this problem since they pass 0.0. Before: # Samples: 845 of event 'anon group { cycles, cache-references, cache-misses }' # Event count (approx.): 174775051 # # Overhead Samples # ........................ .................................... # 20.32% 8.58% 73.51% 45 30 138 6.87% 6.87% 6.87% 21 0 0 5.29% 0.31% 0.31% 10 1 0 1.89% 1.89% 1.89% 6 0 0 1.76% 1.76% 1.76% 2 0 0 After: # Overhead Samples # ........................ .................................... # 20.32% 8.58% 73.51% 45 30 138 6.87% 0.00% 0.00% 21 0 0 5.29% 0.31% 0.00% 10 1 0 1.89% 0.00% 0.00% 6 0 0 1.76% 0.00% 0.00% 2 0 0 Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393809254-4480-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Fix NULL pointer dereference in "perf bench all"Patrick Palka
The for_each_bench() macro must check that the "benchmarks" field of a collection is not NULL before dereferencing it because the "all" collection in particular has a NULL "benchmarks" field (signifying that it has no benchmarks to iterate over). This fixes this NULL pointer dereference when running "perf bench all": [root@ssdandy ~]# perf bench all <SNIP> # Running mem/memset benchmark... # Copying 1MB Bytes ... 2.453675 GB/Sec 12.056327 GB/Sec (with prefault) Segmentation fault (core dumped) [root@ssdandy ~]# Signed-off-by: Patrick Palka <patrick@parcs.ath.cx> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1394664051-6037-1-git-send-email-patrick@parcs.ath.cx Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf tools: Fix synthesizing mmaps for threadsDon Zickus
Currently if a process creates a bunch of threads using pthread_create and then perf is run in system_wide mode, the mmaps for those threads are not captured with a synthesized mmap event. The reason is those threads are not visible when walking the /proc/ directory looking for /proc/<pid>/maps files. Instead they are discovered using the /proc/<pid>/tasks file (which the synthesized comm event uses). This causes problems when a program is trying to map a data address to a tid. Because the tid has no maps, the event is dropped. Changing the program to look up using the pid instead of the tid, finds the correct maps but creates ugly hacks in the program to carry the correct tid around. Fix this by moving the walking of the /proc/<pid>/tasks up a level (out of the comm function) based on Arnaldo's suggestion. Tweaked things a bit to special case the 'full' bit and 'guest' check. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1393429527-167840-2-git-send-email-dzickus@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf probe: Clarify x86 register naming for perf probeAndi Kleen
Clarify how to specify x86 registers in perf probe. I recently ran into this problem and had to figure it out from the source. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/1393596135-4227-3-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf mem: Clarify load-latency in documentationAndi Kleen
Clarify in the documentation that 'perf mem report' reports use-latency, not load/store-latency on Intel systems. This often causes confusion with users. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1393596135-4227-2-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Add futex-requeue microbenchmarkDavidlohr Bueso
Block a bunch of threads on a futex and requeue them on another, N at a time. This program is particularly useful to measure the latency of nthread requeues without waking up any tasks -- thus mimicking a regular futex_wait. An example run: $ perf bench futex requeue -r 100 -t 64 Run summary [PID 151011]: Requeuing 64 threads (from 0x7d15c4 to 0x7d15c8), 1 at a time. [Run 1]: Requeued 64 of 64 threads in 0.0400 ms [Run 2]: Requeued 64 of 64 threads in 0.0390 ms [Run 3]: Requeued 64 of 64 threads in 0.0400 ms ... [Run 100]: Requeued 64 of 64 threads in 0.0390 ms Requeued 64 of 64 threads in 0.0399 ms (+-0.37%) Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jason Low <jason.low2@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/r/1387081917-9102-4-git-send-email-davidlohr@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Add futex-wake microbenchmarkDavidlohr Bueso
Block a bunch of threads on a futex and wake them up, N at a time. This program is particularly useful to measure the latency of nthread wakeups in non-error situations: all waiters are queued and all wake calls wakeup one or more tasks. An example run: $ perf bench futex wake -t 512 -r 100 Run summary [PID 27823]: blocking on 512 threads (at futex 0x7e10d4), waking up 1 at a time. [Run 1]: Wokeup 512 of 512 threads in 6.0080 ms [Run 2]: Wokeup 512 of 512 threads in 5.2280 ms [Run 3]: Wokeup 512 of 512 threads in 4.8300 ms ... [Run 100]: Wokeup 512 of 512 threads in 5.0100 ms Wokeup 512 of 512 threads in 5.0109 ms (+-2.25%) Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jason Low <jason.low2@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/r/1387081917-9102-3-git-send-email-davidlohr@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Add futex-hash microbenchmarkDavidlohr Bueso
Introduce futexes to perf-bench and add a program that stresses and measures the kernel's implementation of the hash table. This is a multi-threaded program that simply measures the amount of failed futex wait calls - we only want to deal with the hashing overhead, so a negative return of futex_wait_setup() is enough to do the trick. An example run: $ perf bench futex hash -t 32 Run summary [PID 10989]: 32 threads, each operating on 1024 [private] futexes for 10 secs. [thread 0] futexes: 0x19d9b10 ... 0x19dab0c [ 418713 ops/sec ] [thread 1] futexes: 0x19daca0 ... 0x19dbc9c [ 469913 ops/sec ] [thread 2] futexes: 0x19dbe30 ... 0x19dce2c [ 479744 ops/sec ] ... [thread 31] futexes: 0x19fbb80 ... 0x19fcb7c [ 464179 ops/sec ] Averaged 454310 operations/sec (+- 0.84%), total secs = 10 Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jason Low <jason.low2@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/r/1387081917-9102-2-git-send-email-davidlohr@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench numa: Make no args mean 'run all tests'Arnaldo Carvalho de Melo
If we call just: perf bench numa mem it will present the same output as: perf bench numa mem -h i.e. ask for instructions about what to run. While that is kinda ok, using 'run all tests' as the default, i.e. making 'no parms' be equivalent to: perf bench numa mem -a Will allow: perf bench numa all to actually do what is asked: i.e. run all the 'bench' tests, instead of responding to that by asking what to do. That, in turn, allows: perf bench all to actually complete, for the same reasons. And after that, the tests that come after that, and that at some point hit a NULL deref, will run, allowing me to reproduce a recently reported problem. That when you have the needed numa libraries, which wasn't the case for the reporter, making me a bit confused after trying to reproduce his report. So make no parms mean -a. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Patrick Palka <patrick@parcs.ath.cx> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-x7h0ghx4pef4n0brywg21krk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "I know this is a bit more than you want to see, and I've told the wireless folks under no uncertain terms that they must severely scale back the extent of the fixes they are submitting this late in the game. Anyways: 1) vmxnet3's netpoll doesn't perform the equivalent of an ISR, which is the correct implementation, like it should. Instead it does something like a NAPI poll operation. This leads to crashes. From Neil Horman and Arnd Bergmann. 2) Segmentation of SKBs requires proper socket orphaning of the fragments, otherwise we might access stale state released by the release callbacks. This is a 5 patch fix, but the initial patches are giving variables and such significantly clearer names such that the actual fix itself at the end looks trivial. From Michael S. Tsirkin. 3) TCP control block release can deadlock if invoked from a timer on an already "owned" socket. Fix from Eric Dumazet. 4) In the bridge multicast code, we must validate that the destination address of general queries is the link local all-nodes multicast address. From Linus Lüssing. 5) The x86 BPF JIT support for negative offsets puts the parameter for the helper function call in the wrong register. Fix from Alexei Starovoitov. 6) The descriptor type used for RTL_GIGA_MAC_VER_17 chips in the r8169 driver is incorrect. Fix from Hayes Wang. 7) The xen-netback driver tests skb_shinfo(skb)->gso_type bits to see if a packet is a GSO frame, but that's not the correct test. It should use skb_is_gso(skb) instead. Fix from Wei Liu. 8) Negative msg->msg_namelen values should generate an error, from Matthew Leach. 9) at86rf230 can deadlock because it takes the same lock from it's ISR and it's hard_start_xmit method, without disabling interrupts in the latter. Fix from Alexander Aring. 10) The FEC driver's restart doesn't perform operations in the correct order, so promiscuous settings can get lost. Fix from Stefan Wahren. 11) Fix SKB leak in SCTP cookie handling, from Daniel Borkmann. 12) Reference count and memory leak fixes in TIPC from Ying Xue and Erik Hugne. 13) Forced eviction in inet_frag_evictor() must strictly make sure all frags are deleted, otherwise module unload (f.e. 6lowpan) can crash. Fix from Florian Westphal. 14) Remove assumptions in AF_UNIX's use of csum_partial() (which it uses as a hash function), which breaks on PowerPC. From Anton Blanchard. The main gist of the issue is that csum_partial() is defined only as a value that, once folded (f.e. via csum_fold()) produces a correct 16-bit checksum. It is legitimate, therefore, for csum_partial() to produce two different 32-bit values over the same data if their respective alignments are different. 15) Fix endiannes bug in MAC address handling of ibmveth driver, also from Anton Blanchard. 16) Error checks for ipv6 exthdrs offload registration are reversed, from Anton Nayshtut. 17) Externally triggered ipv6 addrconf routes should count against the garbage collection threshold. Fix from Sabrina Dubroca. 18) The PCI shutdown handler added to the bnx2 driver can wedge the chip if it was not brought up earlier already, which in particular causes the firmware to shut down the PHY. Fix from Michael Chan. 19) Adjust the sanity WARN_ON_ONCE() in qdisc_list_add() because as currently coded it can and does trigger in legitimate situations. From Eric Dumazet. 20) BNA driver fails to build on ARM because of a too large udelay() call, fix from Ben Hutchings. 21) Fair-Queue qdisc holds locks during GFP_KERNEL allocations, fix from Eric Dumazet. 22) The vlan passthrough ops added in the previous release causes a regression in source MAC address setting of outgoing headers in some circumstances. Fix from Peter Boström" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (70 commits) ipv6: Avoid unnecessary temporary addresses being generated eth: fec: Fix lost promiscuous mode after reconnecting cable bonding: set correct vlan id for alb xmit path at86rf230: fix lockdep splats net/mlx4_en: Deregister multicast vxlan steering rules when going down vmxnet3: fix building without CONFIG_PCI_MSI MAINTAINERS: add networking selftests to NETWORKING net: socket: error on a negative msg_namelen MAINTAINERS: Add tools/net to NETWORKING [GENERAL] packet: doc: Spelling s/than/that/ net/mlx4_core: Load the IB driver when the device supports IBoE net/mlx4_en: Handle vxlan steering rules for mac address changes net/mlx4_core: Fix wrong dump of the vxlan offloads device capability xen-netback: use skb_is_gso in xenvif_start_xmit r8169: fix the incorrect tx descriptor version tools/net/Makefile: Define PACKAGE to fix build problems x86: bpf_jit: support negative offsets bridge: multicast: enable snooping on general queries only bridge: multicast: add sanity check for general query destination tcp: tcp_release_cb() should release socket ownership ...
2014-03-13tools/virtio: add a missing )Joel Stanley
Fixes the following build failure: cc -g -O2 -Wall -I. -I ../../usr/include/ -Wno-pointer-sign -fno-strict-overflow -fno-strict-aliasing -fno-common -MMD -U_FORTIFY_SOURCE -c -o virtio_test.o virtio_test.c virtio_test.c: In function ‘run_test’: virtio_test.c:176:7: error: expected ‘)’ before ‘r’ r = -1; ^ Fixes: 53c18c9906441 (virtio_test: verify if virtqueue_kick() succeeded) Cc: Heinz Graalfs <graalfs@linux.vnet.ibm.com> Signed-off-by: Joel Stanley <joel@jms.id.au> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
