path: root/tools
2010-08-02perf: Resurrect flat callchainsFrederic Weisbecker
commit 97aa1052739c6a06cb6b0467dbf410613d20bc97 upstream. Initialize the callchain radix tree root correctly. When we walk through the parents, we must stop after the root, but since it wasn't well initialized, its parent pointer was random. Also the number of hits was random because uninitialized, hence it was part of the callchain while the root doesn't contain anything. This fixes segfaults and percentages followed by empty callchains while running: perf report -g flat Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05perf top: Properly notify the user that vmlinux is missingArnaldo Carvalho de Melo
commit b0a9ab62ab96e258a0ddd81d7fe2719c3db36006 upstream. Before this patch this message would very briefly appear on the screen and then the screen would get updates only on the top, for number of interrupts received, etc, but no annotation would be performed: [root@doppio linux-2.6-tip]# perf top -s n_tty_write > /tmp/bla objdump: '[kernel.kallsyms]': No such file Now this is what the user gets: [root@doppio linux-2.6-tip]# perf top -s n_tty_write Can't annotate n_tty_write: No vmlinux file was found in the path: [0] vmlinux [1] /boot/vmlinux [2] /boot/vmlinux-2.6.33-rc5 [3] /lib/modules/2.6.33-rc5/build/vmlinux [4] /usr/lib/debug/lib/modules/2.6.33-rc5/vmlinux [root@doppio linux-2.6-tip]# This bug was introduced when we added automatic search for vmlinux, before that time the user had to specify a vmlinux file. Reported-by: David S. Miller <davem@davemloft.net> Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268664418-28328-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-05perf: Fix endianness argument compatibility with OPT_BOOLEAN() and introduce ↵Ian Munsie
OPT_INCR() commit c05556421742eb47f80301767653a4bcb19de9de upstream. Parsing an option from the command line with OPT_BOOLEAN on a bool data type would not work on a big-endian machine due to the manner in which the boolean was being cast into an int and incremented. For example, running 'perf probe --list' on a PowerPC machine would fail to properly set the list_events bool and would therefore print out the usage information and terminate. This patch makes OPT_BOOLEAN work as expected with a bool datatype. For cases where the original OPT_BOOLEAN was intentionally being used to increment an int each time it was passed in on the command line, this patch introduces OPT_INCR with the old behaviour of OPT_BOOLEAN (the verbose variable is currently the only such example of this). I have reviewed every use of OPT_BOOLEAN to verify that a true C99 bool was passed. Where integers were used, I verified that they were only being used for boolean logic and changed them to bools to ensure that they would not be mistakenly used as ints. The major exception was the verbose variable which now uses OPT_INCR instead of OPT_BOOLEAN. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: <stable@kernel.org> Cc: Git development list <git@vger.kernel.org> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Valdis.Kletnieks@vt.edu Cc: WANG Cong <amwang@redhat.com> Cc: Thiago Farina <tfransosi@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mike Galbraith <efault@gmx.de> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: John Kacur <jkacur@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-13perf record: Add a fallback to the reference relocation symbolArnaldo Carvalho de Melo
Usually "_text" is enough, but I received reports that its not always available, so fallback to "_stext" for the symbol we use to check if we need to apply any relocation to all the symbols in the kernel symtab, for when, for instance, kexec is being used. Reported-by: Darren Hart <dvhltc@us.ibm.com> Reported-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-11perf: Fix static strings treated like dynamic onesFrederic Weisbecker
The raw_field_ptr() helper, used to retrieve the address of a field inside a trace event, treats every strings as if they were dynamic ie: having a secondary level of indirection to retrieve their contents. FIELD_IS_STRING doesn't mean FIELD_IS_DYNAMIC, we only need to compute the secondary dereference for the latter case. This fixes perf sched segfaults, bad cmdline report and may be some other bugs. Reported-by: Jason Baron <jbaron@redhat.com> Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Tom Zanussi <tzanussi@gmail.com>
2010-04-06perf kmem: Fix breakage introduced by 5a0e3ad slab.h scriptArnaldo Carvalho de Melo
Commit 5a0e3ad ("include cleanup: Update gfp.h and slab.h includes to prepare for breaking implicit slab.h inclusion from percpu.h") added a '#include <linux/slab.h>' to tools/perf/builtin-kmem.h because: that tool has lines like this: if (!strcmp(event->name, "kmalloc") || !strcmp(event->name, "kmem_cache_alloc")) { process_alloc_event(data, event, cpu, timestamp, thread, 0); return; } So, using the script regex: >>> import re >>> s = re.compile(r'^(|.*[^a-zA-Z0-9_])_*(slab_is_available|kmem_cache_|k[mzc]alloc|krealloc|kz?free|ksize|__getname|putname)') >>> l = ' !strcmp(event->name, "kmem_cache_alloc")) {' >>> s.search(l) <_sre.SRE_Match object at 0xb77b1ad0> >>> Remove that file that is not available in the tools/perf include path and thus builtin-kmem.c couldn't be compiled. Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Tejun Heo <tj@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <1270561053-14308-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-04-02perf, probe-finder: Build fix on DebianBorislav Petkov
Building chokes with: In file included from /usr/include/gelf.h:53, from /usr/include/elfutils/libdw.h:53, from util/probe-finder.h:61, from util/probe-finder.c:39: /usr/include/libelf.h:98: error: expected specifier-qualifier-list before 'off64_t' [...] Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <20100329164755.GA16034@aftab> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02perf/scripts: Tuple was set from long in both branches in python_process_event()Tom Zanussi
This is a fix to the signed/unsigned field handling in the Python scripting engine, based on a patch from Roel Kluin. Basically, Python wants to use a PyInt (which is internally a long) if it can i.e. if the value will fit into that type. If not, it stores it into a PyLong, which isn't actually a long, but an arbitrary-precision integer variable. The code below is similar to to what Python does internally, and it seems to work as expected on the x86 and x86_64 sytems I tested it on. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org LKML-Reference: <1270184305.6422.10.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: powerpc/perf_events: Fix call-graph recording, add perf_arch_fetch_caller_regs perf top: Add missing initialization to zero perf probe: Use original address instead of CU-based address perf probe: Fix offset to allow signed value perf top: Improve the autosizing of column lenghts perf probe: Fix need_dwarf flag if lazy matching is used perf probe: Fix probe_point buffer overrun
2010-03-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (35 commits) perf: Fix unexported generic perf_arch_fetch_caller_regs perf record: Don't try to find buildids in a zero sized file perf: export perf_trace_regs and perf_arch_fetch_caller_regs perf, x86: Fix hw_perf_enable() event assignment perf, ppc: Fix compile error due to new cpu notifiers perf: Make the install relative to DESTDIR if specified kprobes: Calculate the index correctly when freeing the out-of-line execution slot perf tools: Fix sparse CPU numbering related bugs perf_event: Fix oops triggered by cpu offline/online perf: Drop the obsolete profile naming for trace events perf: Take a hot regs snapshot for trace events perf: Introduce new perf_fetch_caller_regs() for hot regs snapshot perf/x86-64: Use frame pointer to walk on irq and process stacks lockdep: Move lock events under lockdep recursion protection perf report: Print the map table just after samples for which no map was found perf report: Add multiple event support perf session: Change perf_session post processing functions to take histogram tree perf session: Add storage for seperating event types in report perf session: Change add_hist_entry to take the tree root instead of session perf record: Add ID and to recorded event data when recording multiple events ...
2010-03-16perf top: Add missing initialization to zeroArnaldo Carvalho de Melo
The dso_short_width has to start as zero, as we're calculating the maximum short DSO name length, somehow I missed this one. Reported-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268774926-27488-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-16perf probe: Use original address instead of CU-based addressMasami Hiramatsu
Use original address for looking up the location of variables for dwarf_getlocation_addr() instead of CU-based address. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20100315170235.31852.91195.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-16perf probe: Fix offset to allow signed valueMasami Hiramatsu
Fix dereference offset to intmax_t from uintmax_t, because it can have negative values (for example local variable's offset from frame pointer). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20100315170228.31852.71946.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-16perf top: Improve the autosizing of column lenghtsArnaldo Carvalho de Melo
When profiling C++ workloads the symbol name length can be really big, so cap it before it garbles the result. This builds upon the autosizing already present where we choose to use the short, basename of DSOs instead of its long, full pathname. Reported-by: Pavel Krauz <krauz@cngroup.cz> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268676230-9261-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-13Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf: Provide generic perf_sample_data initialization MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer perf trace: Don't use pager if scripting perf trace/scripting: Remove extraneous header read perf, ARM: Modify kuser rmb() call to compile for Thumb-2 x86/stacktrace: Don't dereference bad frame pointers perf archive: Don't try to collect files without a build-id perf_events, x86: Fixup fixed counter constraints perf, x86: Restrict the ANY flag perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE perf, x86: add some IBS macros to perf_event.h perf, x86: make IBS macros available in perf_event.h hw-breakpoints: Remove stub unthrottle callback x86/hw-breakpoints: Remove the name field perf: Remove pointless breakpoint union perf lock: Drop the buffers multiplexing dependency perf lock: Fix and add misc documentally things percpu: Add __percpu sparse annotations to hw_breakpoint
2010-03-13perf probe: Fix need_dwarf flag if lazy matching is usedMasami Hiramatsu
Set need_dwarf if lazy matching pattern is specified, because lazy matching requires real source path for which we must use debuginfo. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20100312232224.2017.54550.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-13perf probe: Fix probe_point buffer overrunMasami Hiramatsu
Fix probe_point array-size overrun problem. In some cases (e.g. inline function), one user-specified probe-point can be translated to many probe address, and it overruns pre-defined array-size. This also removes redundant MAX_PROBES macro definition. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: <stable@kernel.org> LKML-Reference: <20100312232217.2017.45017.stgit@localhost6.localdomain6> [ Note that only root can create new probes. Eventually we should remove the MAX_PROBES limit, but that is a larger patch not eligible to perf/urgent treatment. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11perf record: Don't try to find buildids in a zero sized fileArnaldo Carvalho de Melo
Fixing this symptom: [acme@mica linux-2.6-tip]$ perf record -a -f Fatal: Permission error - are you root? Bus error [acme@mica linux-2.6-tip]$ I.e. if for some reason no data is collected, in this case a non root user trying to do systemwide profiling, no data will be collected, and then we end up trying to mmap a zero sized file and access the file header, b00m. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: <stable@kernel.org> LKML-Reference: <1268333592-30872-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11perf: Make the install relative to DESTDIR if specifiedJohn Kacur
Without this change, the install path is relative to prefix/DESTDIR where prefix is automatically set to $HOME. This can produce unexpected results. For example: make -C tools/perf DESTDIR=/home/jkacur/tmp install-man creates the directory: /home/jkacur/home/jkacur/tmp/share/... instead of the expected: /home/jkacur/tmp/share/... Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Kyle McMartin <kyle@redhat.com> Cc: <stable@kernel.org> LKML-Reference: <1268312220-12880-1-git-send-email-jkacur@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-11perf tools: Fix sparse CPU numbering related bugsPaul Mackerras
At present, the perf subcommands that do system-wide monitoring (perf stat, perf record and perf top) don't work properly unless the online cpus are numbered 0, 1, ..., N-1. These tools ask for the number of online cpus with sysconf(_SC_NPROCESSORS_ONLN) and then try to create events for cpus 0, 1, ..., N-1. This creates problems for systems where the online cpus are numbered sparsely. For example, a POWER6 system in single-threaded mode (i.e. only running 1 hardware thread per core) will have only even-numbered cpus online. This fixes the problem by reading the /sys/devices/system/cpu/online file to find out which cpus are online. The code that does that is in tools/perf/util/cpumap.[ch], and consists of a read_cpu_map() function that sets up a cpumap[] array and returns the number of online cpus. If /sys/devices/system/cpu/online can't be read or can't be parsed successfully, it falls back to using sysconf to ask how many cpus are online and sets up an identity map in cpumap[]. The perf record, perf stat and perf top code then calls read_cpu_map() in the system-wide monitoring case (instead of sysconf) and uses cpumap[] to get the cpu numbers to pass to perf_event_open. Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> LKML-Reference: <20100310093609.GA3959@brick.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf report: Print the map table just after samples for which no map was foundArnaldo Carvalho de Melo
If -vv is used just the map table will be printed, -vvv will print the symbol table too, with it we can see that we have a bug where some samples are not being resolved to a map when we get them in the perf.data stream, but after we have it all processed, we can find the right map, some reordering probably is happening. Upcoming patches will provide ways to ask for most PERF_SAMPLE_ conditional samples to be taken for !PERF_RECORD_SAMPLE events too, then we'll be able to ask for PERF_SAMPLE_TIME and PERF_SAMPLE_CPU to help diagnose this. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268161097-17761-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf report: Add multiple event supportEric B Munson
Perf report does not handle multiple events being reported, even though perf record stores them properly on disk. This patch addresses that issue by adding the logic to perf report to use the event stream id that is saved by record and the new data structures to seperate the event streams and report them individually. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-6-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf session: Change perf_session post processing functions to take ↵Eric B Munson
histogram tree Now that report can store historgrams for multiple events we need to be able to do the post processing work for each histogram. This patch changes the post processing functions so that they can be called individually for each event's histogram. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> [ Guarantee bisectabilty by fixing up builtin-report.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf session: Add storage for seperating event types in reportEric B Munson
This patch adds the structures necessary to count each event type independently in perf report. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-4-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf session: Change add_hist_entry to take the tree root instead of sessionEric B Munson
In order to minimize the impact of storing multiple events in a report this function will now take the root of the histogram tree so that the logic for selecting the proper tree can be inserted before the call. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf record: Add ID and to recorded event data when recording multiple eventsEric B Munson
Currently perf record does not write the ID or the to disk for events. This doesn't allow report to tell if an event stream contains one or more types of events. This patch adds this entry to the list of data that record will write to disk if more than one event was requested. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf probe: Add missing variable initializationArnaldo Carvalho de Melo
cc1: warnings being treated as errors util/probe-finder.c: In function 'find_line_range': util/probe-finder.c:172: warning: 'src' may be used uninitialized in this function make: *** [util/probe-finder.o] Error 1 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf tools: Don't trow away old map slices not overlapped by new mapsArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267800842-22324-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-09Merge commit 'v2.6.34-rc1' into perf/urgentIngo Molnar
Conflicts: tools/perf/util/probe-event.c Merge reason: Pick up -rc1 and resolve the conflict as well. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05Merge branch 'perf-probes-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-probes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Issue at least one memory barrier in stop_machine_text_poke() perf probe: Correct probe syntax on command line help perf probe: Add lazy line matching support perf probe: Show more lines after last line perf probe: Check function address range strictly in line finder perf probe: Use libdw callback routines perf probe: Use elfutils-libdw for analyzing debuginfo perf probe: Rename probe finder functions perf probe: Fix bugs in line range finder perf probe: Update perf probe document perf probe: Do not show --line option without dwarf support kprobes: Add documents of jump optimization kprobes/x86: Support kprobes jump optimization on x86 x86: Add text_poke_smp for SMP cross modifying code kprobes/x86: Cleanup save/restore registers kprobes/x86: Boost probes when reentering kprobes: Jump optimization sysctl interface kprobes: Introduce kprobes jump optimization kprobes: Introduce generic insn_slot framework kprobes/x86: Cleanup RELATIVEJUMP_INSTRUCTION to RELATIVEJUMP_OPCODE
2010-03-04perf trace: Don't use pager if scriptingTom Zanussi
It's useful for paging through raw traces, but just gets in the way when scripting. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1267599873-8193-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-04perf trace/scripting: Remove extraneous header readTom Zanussi
perf_header__read() is already done in perf_session__open(), so remove it from the script gen case. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1267599873-8193-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-04perf, ARM: Modify kuser rmb() call to compile for Thumb-2Will Deacon
The Thumb-2 instruction set does not provide an encoding for sub pc, r0, #95 as present in the rmb() definition used by perf. This results in compilation failure when using a compiler targetting an instruction set other than ARM. This patch redefines rmb() for ARM by casting the address of the kuser helper to a function pointer, therefore getting the compiler to take care of making the call. Patch taken against tip/master. Signed-off-by: Will Deacon <will.deacon@arm.com> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Jamie Iles <jamie.iles@picochip.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1267616878-2154-1-git-send-email-will.deacon@arm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-04perf probe: Correct probe syntax on command line helpMasami Hiramatsu
Move @SRC right after FUNC in syntax according to syntax change on command line help. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> LKML-Reference: <20100304033843.3819.10087.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-02perf archive: Don't try to collect files without a build-idArnaldo Carvalho de Melo
To avoid these error: [root@doppio ~]# perf archive tar: .build-id/00/00000000000000000000000000000000000000: Cannot stat: No such file or directory tar: .build-id/00/00000000000000000000000000000000000000: Cannot stat: No such file or directory tar: .build-id/00/00000000000000000000000000000000000000: Cannot stat: No such file or directory tar: .build-id/00/00000000000000000000000000000000000000: Cannot stat: No such file or directory tar: Exiting with failure status due to previous errors [root@doppio ~]# More work is needed to support archiving symtabs for binaries without a build-id, perhaps creating a perf.data UUID + adding build-ids for the binaries copied into the cache and then have this perf.data session UUID be a directory with symlinks to the by now calculated build-id of the files inside it. Or just do an extra pass and insert the calculated build-ids in the perf.data header. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-28Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits) perf_event, amd: Fix spinlock initialization perf_event: Fix preempt warning in perf_clock() perf tools: Flush maps on COMM events perf_events, x86: Split PMU definitions into separate files perf annotate: Handle samples not at objdump output addr boundaries perf_events, x86: Remove superflous MSR writes perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in() perf_events, x86: AMD event scheduling perf_events: Add new start/stop PMU callbacks perf_events: Report the MMAP pgoff value in bytes perf annotate: Defer allocating sym_priv->hist array perf symbols: Improve debugging information about symtab origins perf top: Use a macro instead of a constant variable perf symbols: Check the right return variable perf/scripts: Tag syscall_name helper as not yet available perf/scripts: Add perf-trace-python Documentation perf/scripts: Remove unnecessary PyTuple resizes perf/scripts: Add syscall tracing scripts perf/scripts: Add Python scripting engine perf/scripts: Remove check-perf-trace from listed scripts ... Fix trivial conflict in tools/perf/util/probe-event.c
2010-02-27perf lock: Drop the buffers multiplexing dependencyFrederic Weisbecker
We need to deal with time ordered events to build a correct state machine of lock events. This is why we multiplex the lock events buffers. But the ordering is done from the kernel, on the tracing fast path, leading to high contention between cpus. Without multiplexing, the events appears in a weak order. If we have four events, each split per cpu, perf record will read the events buffers in the following order: [ CPU0 ev0, CPU0 ev1, CPU0 ev3, CPU0 ev4, CPU1 ev0, CPU1 ev0....] To handle a post processing reordering, we could just read and sort the whole in memory, but it just doesn't scale with high amounts of events: lock events can fill huge amounts in few times. Basically we need to sort in memory and find a "grace period" point when we know that a given slice of previously sorted events can be committed for post-processing, so that we can unload the memory usage step by step and keep a scalable sorting list. There is no strong rules about how to define such "grace period". What does this patch is: We define a FLUSH_PERIOD value that defines a grace period in seconds. We want to have a slice of events covering 2 * FLUSH_PERIOD in our sorted list. If FLUSH_PERIOD is big enough, it ensures every events that occured in the first half of the timeslice have all been buffered and there are none remaining and there won't be further to put inside this first timeslice. Then once we reach the 2 * FLUSH_PERIOD timeslice, we flush the first half to be gentle with the memory (the second half can still get new events in the middle, so wait another period to flush it) FLUSH_PERIOD is defined to 5 seconds. Say the first event started on time t0. We can safely assume that at the time we are processing events of t0 + 10 seconds, ther won't be anymore events to read from perf.data that occured between t0 and t0 + 5 seconds. Hence we can safely flush the first half. To point out funky bugs, we have a guardian that checks a new event timestamp is not below the last event's timestamp flushed and that displays a warning in this case. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jens Axboe <jens.axboe@oracle.com>
2010-02-27perf lock: Fix and add misc documentally thingsHitoshi Mitake
I've forgot to add 'perf lock' line to command-list.txt, so users of perf could not find perf lock when they type 'perf'. Fixing command-list.txt requires document (tools/perf/Documentation/perf-lock.txt). But perf lock is too much "under construction" to write a stable document, so this is something like pseudo document for now. And I wrote description of perf lock at help section of CONFIG_LOCK_STAT, this will navigate users of lock trace events. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> LKML-Reference: <1265267295-8388-1-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-02-27Merge commit 'v2.6.33' into perf/coreFrederic Weisbecker
Merge reason: __percpu annotations need the corresponding sparse address space definition upstream. Conflicts: tools/perf/util/probe-event.c (trivial)
2010-02-26perf tools: Flush maps on COMM eventsDavid S. Miller
Even though we don't register the counters until the child is right about to exec(), we're still going to get at least a few events while the fork()'d child is still executing 'perf' and in particular we're going to get the MMAP events. We can't distinguish the ones in the newly executed process because the PID will be the same. One way to solve this would be to have a PERF_RECORD_EXEC event, and when this is seen 'perf' can flush it's map cache. We can't use PERF_RECORD_COMM since that's generated by other things, not just exec(). Actually, thinking about it some more, using PERF_RECORD_COMM might be a good enough approximation. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267196914-16238-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26perf annotate: Handle samples not at objdump output addr boundariesArnaldo Carvalho de Melo
Without this patch we get this for need_resched: [root@mica ~]# perf annotate need_resched ------------------------------------------------ Percent | Source code & Disassembly of vmlinux ------------------------------------------------ : : : Disassembly of section .text: : : ffffffff810095ed <need_resched>: : return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p); : } : : static inline int need_resched(void) : { 0.00 : ffffffff810095ed: 55 push %rbp : return unlikely(test_thread_flag(TIF_NEED_RESCHED)); 0.00 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi : : static inline struct thread_info *current_thread_info(void) : { : struct thread_info *ti; : ti = (void *)(percpu_read_stable(kernel_stack) + 0.00 : ffffffff810095f3: 65 48 8b 3c 25 48 b5 mov %gs:0xb548,%rdi 0.00 : ffffffff810095fa: 00 00 : return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p); : } : : static inline int need_resched(void) : { 0.00 : ffffffff810095fc: 48 89 e5 mov %rsp,%rbp : return unlikely(test_thread_flag(TIF_NEED_RESCHED)); 0.00 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi 0.00 : ffffffff81009606: e8 9d ff ff ff callq ffffffff810095a8 <test_ti_thread_flag> : } 0.00 : ffffffff8100960b: c9 leaveq 0.00 : ffffffff8100960c: 85 c0 test %eax,%eax 0.00 : ffffffff8100960e: 0f 95 c0 setne %al 0.00 : ffffffff81009611: 0f b6 c0 movzbl %al,%eax : Disassembly of section .vsyscall_0: : Disassembly of section .vsyscall_fn: : Disassembly of section .vsyscall_1: : Disassembly of section .vsyscall_2: : Disassembly of section .init.text: : Disassembly of section .altinstr_replacement: : Disassembly of section .exit.text: [root@mica ~]# But from the 'perf report' result we know that there are hits for need_resched on a 4 way machine mostly doing nothing, so after adding code to show what is in each hist offset and collapsing IP hits for what happens between objdump lines we get, for the same perf.data file: [root@mica ~]# perf annotate -v need_resched ------------------------------------------------ Percent | Source code & Disassembly of vmlinux ------------------------------------------------ : : : Disassembly of section .text: : : ffffffff810095ed <need_resched>: : return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p); : } : : static inline int need_resched(void) : { 0.00 : ffffffff810095ed: 55 push %rbp : return unlikely(test_thread_flag(TIF_NEED_RESCHED)); 52.78 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi : : static inline struct thread_info *current_thread_info(void) : { : struct thread_info *ti; : ti = (void *)(percpu_read_stable(kernel_stack) + 0.00 : ffffffff810095f3: 65 48 8b 3c 25 48 b5 mov %gs:0xb548,%rdi 0.00 : ffffffff810095fa: 00 00 : return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p); : } : : static inline int need_resched(void) : { 0.00 : ffffffff810095fc: 48 89 e5 mov %rsp,%rbp : return unlikely(test_thread_flag(TIF_NEED_RESCHED)); 9.72 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi 0.00 : ffffffff81009606: e8 9d ff ff ff callq ffffffff810095a8 <test_ti_thread_flag> : } 0.00 : ffffffff8100960b: c9 leaveq 0.00 : ffffffff8100960c: 85 c0 test %eax,%eax 37.50 : ffffffff8100960e: 0f 95 c0 setne %al 0.00 : ffffffff81009611: 0f b6 c0 movzbl %al,%eax : Disassembly of section .vsyscall_0: : Disassembly of section .vsyscall_fn: : Disassembly of section .vsyscall_1: : Disassembly of section .vsyscall_2: : Disassembly of section .init.text: : Disassembly of section .altinstr_replacement: : Disassembly of section .exit.text: [root@mica ~]# And now 'perf annotate -v', verbose mode, will show the hits per precise IP, so that one can make sense of the attribution to each objdumop line: [root@mica ~]# perf annotate -v need_resched Looking at the vmlinux_path (5 entries long) Using /lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux for symbols annotate_sym: filename=/lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux, sym=need_resched, start=0xffffffff810095ed, end=0xffffffff81009614 ------------------------------------------------ Percent | Source code & Disassembly of vmlinux ------------------------------------------------ ffffffff810095f1: 152 ffffffff81009603: 28 ffffffff8100960f: 55 ffffffff81009610: 53 h->sum: 288 <SNIP same annotation> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267194194-15670-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf probe: Add lazy line matching supportMasami Hiramatsu
Add lazy line matching support for specifying new probes. This also changes the syntax of perf probe a bit. Now perf probe accepts one of below probe event definitions. 1) Define event based on function name [EVENT=]FUNC[@SRC][:RLN|+OFF|%return|;PTN] [ARG ...] 2) Define event based on source file with line number [EVENT=]SRC:ALN [ARG ...] 3) Define event based on source file with lazy pattern [EVENT=]SRC;PTN [ARG ...] - New lazy matching pattern(PTN) follows ';' (semicolon). And it must be put the end of the definition. - So, @SRC is no longer the part which must be put at the end of the definition. Note that ';' (semicolon) can be interpreted as the end of a command by the shell. This means that you need to quote it. (anyway you will need to quote the lazy pattern itself too, because it may contains other sensitive characters, like '[',']' etc.). Lazy matching ------------- The lazy line matching is similar to glob matching except ignoring spaces in both of pattern and target. e.g. 'a=*' can matches 'a=b', 'a = b', 'a == b' and so on. This provides some sort of flexibility and robustness to probe point definitions against minor code changes. (for example, actual 10th line of schedule() can be changed easily by modifying schedule(), but the same line matching 'rq=cpu_rq*' may still exist.) Changes in v3: - Cast Dwarf_Addr to uintmax_t for printf-formats. Changes in v2: - Cast Dwarf_Addr to unsigned long long for printf-formats. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20100225133611.6725.45078.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf probe: Show more lines after last lineMasami Hiramatsu
Show 2 more lines after the last probe-able line. This will clearly show the last closed-brace of inline functions. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20100225133604.6725.76820.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf probe: Check function address range strictly in line finderMasami Hiramatsu
Check (inlined) function address range strictly for improving output of probe-able lines of inline functions. Without this change, perf probe --line <function> sometimes showed other inline function bodies too, because it didn't filter out inlined functions. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20100225133557.6725.20697.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf probe: Use libdw callback routinesMasami Hiramatsu
Use libdw callback functions aggressively, and remove local tree-search API. This change simplifies the code. Changes in v3: - Cast Dwarf_Addr to uintmax_t for printf-formats. Changes in v2: - Cast Dwarf_Addr to unsigned long long for printf-formats. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20100225133549.6725.81499.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf probe: Use elfutils-libdw for analyzing debuginfoMasami Hiramatsu
Newer gcc introduces newer & richer debuginfo, and only libdw in elfutils project can support it. So perf probe moves onto elfutils-libdw from libdwarf. Changes in v3: - Cast Dwarf_Addr/Dwarf_Word to uintmax_t for printf-formats. - Recover a sign-prefix which was removed in v2 by mistake. Changes in v2: - Fix a type-casting bug in Makefile. - Cast Dwarf_Addr/Dwarf_Word to unsigned long long for printf-formats. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20100225133542.6725.34724.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf probe: Rename probe finder functionsMasami Hiramatsu
Rename *_probepoint to *_probe_point, for nothing but a cosmetic reason. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> LKML-Reference: <20100225133534.6725.52615.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
