commit f428ebd184c82a7914b2aa7e9f868918aaf7ea78 upstream.
Someone got the load and store barriers mixed up for AAAAARGH64. Turn
them the right side up.
Reported-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Fixes: a94d342b9cb0 ("tools/perf: Add required memory barriers")
Link: http://lkml.kernel.org/r/20140124154002.GF31570@twins.programming.kicks-ass.net
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 02c5bb4a352a4cca56e9b5d3a2a57d61062eb2e1 upstream.
SIGSTKFLT is not defined on alpha, mips or sparc.
SIGEMT and SIGSWI are defined on some architectures and should be
decoded here if so.
Fixes: 8bad5b0abfdb ('perf trace: Beautify signal number arg in several syscalls')
Link: http://lkml.kernel.org/r/1391648441.3003.101.camel@deadeye.wl.decadent.org.uk
commit 79d26a6a19ace19faabf8d8d27d3430be2e26d34 upstream.
glibc 2.17 is missing this on sparc, despite the fact that it's not
architecture-specific.
Fixes: 49af9e93adfa ('perf trace: Beautify eventfd2 'flags' arg')
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/1391648435.3003.100.camel@deadeye.wl.decadent.org.uk
x86_64) arches
commit 844ae5b46c08dbc7ba695b543c023f9cf3bbf9ff upstream.
Supporting decoding the ioctl 'request' parameter needs more work to
properly support more architectures, the current approach doesn't work
on at least powerpc and sparc, as reported by Ben Hutchings in
http://lkml.kernel.org/r/1391593985.3003.48.camel@deadeye.wl.decadent.org.uk .
Work around that by making it to be ifdefed for the architectures known
to work with the current, limited approach, i386 and x86_64 till better
code is written.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Acked-by: Ben Hutchings <ben@decadent.org.uk>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-ss04k11insqlu329xh5g02q0@git.kernel.org
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream.
turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems
that have certain security features enabled by default that make -fPIC
the default, this causes a build error:
turbostat.c: In function ‘check_cpuid’:
turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’
asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx");
GCC provides a header cpuid.h, containing a __get_cpuid function that
works with both PIC and non-PIC. (On PIC, it saves and restores ebx
around the cpuid instruction.) Use that instead.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Signed-off-by: Len Brown <len.brown@intel.com>
commit b731f3119de57144e16c19fd593b8daeb637843e upstream.
turbostat's Makefile puts arch/x86/include/uapi/ in the include path, so
that it can include <asm/msr.h> from it. It isn't in general safe to
include even uapi headers directly from the kernel tree without
processing them through scripts/headers_install.sh, but asm/msr.h
happens to work.
However, that include path can break with some versions of system
headers, by overriding some system headers with the unprocessed versions
directly from the kernel source. For instance:
In file included from /build/x86-generic/usr/include/bits/sigcontext.h:28:0,
from /build/x86-generic/usr/include/signal.h:339,
from /build/x86-generic/usr/include/sys/wait.h:31,
from turbostat.c:27:
../../../../arch/x86/include/uapi/asm/sigcontext.h:4:28: fatal error: linux/compiler.h: No such file or directory
This occurs because the system bits/sigcontext.h on that build system
includes <asm/sigcontext.h>, and asm/sigcontext.h in the kernel source
includes <linux/compiler.h>, which scripts/headers_install.sh would have
filtered out.
Since turbostat really only wants a single header, just include that one
header rather than putting an entire directory of kernel headers on the
include path.
In the process, switch from msr.h to msr-index.h, since turbostat just
wants the MSR numbers.
commit ad85ace07a05062ef6b59c35a5e80b6eaee1eee6 upstream.
Currently, if we use perf kvm --guestkallsyms --guestmodules report, we
can not get the perf information from perf data file. All sample are
shown as unknown.
Reproducing steps:
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ]
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep %
100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330
This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation).
In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine
which has the same pid, if no machine found, deliver it to *default* guest. But if we use
perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built
and added. Then the default guest which with pid == 0 will never get a symbol.
And because the new machine initialized here has no kernel map created, the symbol delivered to
it will be marked as "unknown".
This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way.
Verification steps:
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1
[ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ]
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep %
22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70
19.99% :6471 [guest.kernel.kallsyms] [g] d_free
18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments
16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task
12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to
7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick
1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write
0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Acked-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com
If a user calls 'cpupower set --perf-bias 15', the process will end with
a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi
call. This is because the getopt_long structure currently has all of
the options as having an optional_argument when they really have a
required argument. We change the structure to use required_argument to
match the short options and it resolves the issue.
This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Thomas Renninger <trenn@suse.de>
Cc: stable@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a bunch of USB fixes for 3.13-rc3.
Nothing major, but we seem to have an argument about a XHCI fix, so
I'm not including a revert that Sarah requested, because that breaks a
USB network driver, and I can't revert the USB network driver fix
without reintroducing other bugs that it fixed. So as it is,
everything should now be working. Worse case, I can revert the XHCI
fix before 3.13-final is out, but it seems to work well here with my
testing, so all should be good.
Other than that, some driver updates based on reports"
* tag 'usb-3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (40 commits)
usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED
usb: ohci-pxa27x: include linux/dma-mapping.h
USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem
usb: tools: fix a regression issue that gcc can't link to pthread
USB: switch maintainership of chipidea to Peter
USB: pl2303: fixed handling of CS5 setting
USB: ftdi_sio: fixed handling of unsupported CSIZE setting
USB: mos7840: correct handling of CS5 setting
USB: spcp8x5: correct handling of CS5 setting
usb: wusbcore: fix deadlock in wusbhc_gtk_rekey
usb: wusbcore: do device lookup while holding the hc mutex
usb: wusbcore: send keepalives to unauthenticated devices
USB: option: support new huawei devices
USB: serial: option: blacklist interface 1 for Huawei E173s-6
usb: xhci: Link TRB must not occur within a USB payload burst
usb: gadget: f_mass_storage: call try_to_freeze only when its safe
usb: gadget: tcm_usb_gadget: mark bot_cleanup_old_alt static
usb: gadget: ffs: fix sparse warning
usb: gadget: zero: module parameters can be static
usb: gadget: storage: fix sparse warning
Reproduce:
ray@hr-bak:~/usb$ make -C tools/usb/
make: Entering directory `/home/ray/usb/tools/usb'
gcc -Wall -Wextra -g -lpthread -I../include -o testusb testusb.c
/tmp/cc0EMxfy.o: In function `main':
/home/ray/usb/tools/usb/testusb.c:508: undefined reference to `pthread_create'
/home/ray/usb/tools/usb/testusb.c:531: undefined reference to `pthread_join'
collect2: error: ld returned 1 exit status
make: *** [testusb] Error 1
make: Leaving directory `/home/ray/usb/tools/usb'
Comments:
In the latest version (4.7.3) of gcc compiler, it requres that
libraries must follow the object or source files like below:
"gcc hello.c -lpthread" instead of "gcc -lpthread hello.c"
And it isn't encountered at gcc version 4.7.2.
So this patch fix to move the pthread option after testusb.c.
Signed-off-by: Huang Rui <ray.huang@amd.com>
Pull perf fixes from Ingo Molnar:
"Misc kernel and tooling fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tools lib traceevent: Fix conversion of pointer to integer of different size
perf/trace: Properly use u64 to hold event_id
perf: Remove fragile swevent hlist optimization
ftrace, perf: Avoid infinite event generation loop
tools lib traceevent: Fix use of multiple options in processing field
perf header: Fix possible memory leaks in process_group_desc()
perf header: Fix bogus group name
perf tools: Tag thread comm as overriden
idlestates in sysfs are counted from 0.
This fixes a wrong error message.
Current behavior on a machine with 4 sleep states is:
cpupower idle-set -e 4
Idlestate 4 enabled on CPU 0
-----Wrong---------------------
cpupower idle-set -e 5
Idlestate enabling not supported by kernel
-----Must and now will be -----
Idlestate 6 not available on CPU 0
cpupower idle-set -e 6
Signed-off-by: Thomas Renninger <trenn@suse.de>
The cpupower idle-set subcommand was introduce recently.
This patch provides the missing manpage.
If cpupower is properly installed it will show up automatically
(similar to git), when invoking:
cpupower help idle-set
or
cpupower idle-set --help
Some parts have been taken over and adjusted from
git commit 62d6ae880e3e76098
documentation submitted by Carsten Emde.
Pull more ACPI and power management updates from Rafael Wysocki:
- ACPI-based device hotplug fixes for issues introduced recently and a
fix for an older error code path bug in the ACPI PCI host bridge
driver
- Fix for recently broken OMAP cpufreq build from Viresh Kumar
- Fix for a recent hibernation regression related to s2disk
- Fix for a locking-related regression in the ACPI EC driver from
Puneet Kumar
- System suspend error code path fix related to runtime PM and runtime
PM documentation update from Ulf Hansson
- cpufreq's conservative governor fix from Xiaoguang Chen
- New processor IDs for intel_idle and turbostat and removal of an
obsolete Kconfig option from Len Brown
- New device IDs for the ACPI LPSS (Low-Power Subsystem) driver and
ACPI-based PCI hotplug (ACPIPHP) cleanup from Mika Westerberg
- Removal of several ACPI video DMI blacklist entries that are not
necessary any more from Aaron Lu
- Rework of the ACPI companion representation in struct device and code
cleanup related to that change from Rafael J Wysocki, Lan Tianyu and
Jarkko Nikula
- Fixes for assigning names to ACPI-enumerated I2C and SPI devices from
Jarkko Nikula
* tag 'pm+acpi-2-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (24 commits)
PCI / hotplug / ACPI: Drop unused acpiphp_debug declaration
ACPI / scan: Set flags.match_driver in acpi_bus_scan_fixed()
ACPI / PCI root: Clear driver_data before failing enumeration
ACPI / hotplug: Fix PCI host bridge hot removal
ACPI / hotplug: Fix acpi_bus_get_device() return value check
cpufreq: governor: Remove fossil comment in the cpufreq_governor_dbs()
ACPI / video: clean up DMI table for initial black screen problem
ACPI / EC: Ensure lock is acquired before accessing ec struct members
PM / Hibernate: Do not crash kernel in free_basic_memory_bitmaps()
ACPI / AC: Remove struct acpi_device pointer from struct acpi_ac
spi: Use stable dev_name for ACPI enumerated SPI slaves
i2c: Use stable dev_name for ACPI enumerated I2C slaves
ACPI: Provide acpi_dev_name accessor for struct acpi_device device name
ACPI / bind: Use (put|get)_device() on ACPI device objects too
ACPI: Eliminate the DEVICE_ACPI_HANDLE() macro
ACPI / driver core: Store an ACPI device pointer in struct acpi_dev_node
cpufreq: OMAP: Fix compilation error 'r & ret undeclared'
PM / Runtime: Fix error path for prepare
PM / Runtime: Update documentation around probe|remove|suspend
cpufreq: conservative: set requested_freq to policy max when it is over policy max
gcc complaint on 32-bit system:
/home/acme/git/linux/tools/lib/traceevent/event-parse.c: In function ‘eval_num_arg’:
/home/acme/git/linux/tools/lib/traceevent/event-parse.c:3468:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
This is because the eval_num_arg returns everything as an 'unsigned long long',
so it converts a void pointer to a wider integer, fix it by converting the void
pointer to an integer of the same size, 'unsigned long', before casting it to
'unsigned long long'.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/n/tip-yllx4aqcg06v5n4vjpwiiuld@git.kernel.org
Jiri Olsa reported that the scsi_dispatch_cmd_done event failed to parse
with:
Error: expected type 5 but read 4
The problem is with this part of the print_fmt:
__print_symbolic(((REC->result) >> 24) & 0xff, ...
The __print_symbolic() helper function's first parameter is the field to
use to determine what symbol to print based on the value of the result.
The parser can handle one operation, but it can not handle multiple
operations ('>>' and '&').
Add code to process all operations for the field argument for
__print_symbolic() as well as __print_flags().
Reported-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20131118142314.27ca334b@gandalf.local.home
After processing all group descriptors or encountering an error, it
frees all descriptors. However, current logic can leak memory since it
might not traverse all descriptors.
Note that the 'i' can have different value than nr_groups when an error
occurred and it's safe to call free(desc[i].name) for every desc since
we already make it NULL when it's reused for group names.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1384741244-7271-2-git-send-email-namhyung@kernel.org
When processing event group descriptor in perf file header, we reuse an
allocated group name but forgot to prevent it from freeing.
Reported-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1384741244-7271-1-git-send-email-namhyung@kernel.org
The problem is that when a thread overrides its default ":%pid" comm, we
forget to tag the thread comm as overriden. Hence, this overriden comm
is not inherited on future forks. Fix it.
Tested-by: David Ahern <dsahern@gmail.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/20131116010207.GA18855@localhost.localdomain
* pm-tools:
tools / power turbostat: Support Silvermont
"Tooling changes only: it includes the ARM tooling fixlets, various
other fixes, smaller updates, minor cleanups"
perf record: Add an option to force per-cpu mmaps
perf probe: Add '--demangle'/'--no-demangle'
perf ui browser: Fix segfault caused by off by one handling END key
perf symbols: Limit max callchain using max_stack on DWARF unwinding too
perf evsel: Introduce perf_evsel__prev() method
perf tools: Use perf_evlist__{first,last}, perf_evsel__next
perf tools: Synthesize anon MMAP records again
perf top: Add missing newline if the 'uid' is invalid
perf tools: Remove trivial extra semincolon
perf trace: Tweak summary output
tools/perf/build: Fix feature-libunwind-debug-frame handling
tools/perf/build: Fix timerfd feature check
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Nothing really exciting: some groundwork for changing virtio endian,
and some robustness fixes for broken virtio devices, plus minor
tweaks"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio_scsi: verify if queue is broken after virtqueue_get_buf()
x86, asmlinkage, lguest: Pass in globals into assembler statement
virtio: mmio: fix signature checking for BE guests
virtio_ring: adapt to notify() returning bool
virtio_net: verify if queue is broken after virtqueue_get_buf()
virtio_console: verify if queue is broken after virtqueue_get_buf()
virtio_blk: verify if queue is broken after virtqueue_get_buf()
virtio_ring: add new function virtqueue_is_broken()
virtio_test: verify if virtqueue_kick() succeeded
virtio_net: verify if virtqueue_kick() succeeded
virtio_ring: let virtqueue_{kick()/notify()} return a bool
virtio_ring: change host notification API
virtio_config: remove virtio_config_val
virtio: use size-based config accessors.
virtio_config: introduce size-based accessors.
virtio_ring: plug kmemleak false positive.
virtio: pm: use CONFIG_PM_SLEEP instead of CONFIG_PM
By default, when tasks are specified (i.e. -p, -t or -u options)
per-thread mmaps are created.
Add an option to override that and force per-cpu mmaps.
Further comments by peterz:
So this option allows -t/-p/-u to create one buffer per cpu and attach
all the various thread/process/user tasks' their counters to that one
buffer?
As opposed to the current state where each such counter would have its
own buffer.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Tested-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1383313899-15987-7-git-send-email-adrian.hunter@intel.com
You can't pass demangled name into "perf probe", because of special chars:
./perf probe -f -x /tmp/a.out 'foo(int)'
Semantic error :There is non-digit char in line number.
And you can't even pass without demangling (because it search symbol in
DSO with demangle=true):
./perf probe -f -x /tmp/a.out _Z3fooi
no symbols found in /tmp/a.out, maybe install a debug package?
However:
nm /tmp/a.out | grep foo
000000000040056d T _Z3fooi
After this patch, using the next command:
./perf probe -f --no-demangle -x /tmp/a.out _Z3fooi
probe will be successfully added.
Signed-off-by: Azat Khuzhin <a3at.mail@gmail.com>
Link: http://lkml.kernel.org/r/1382947464-31266-1-git-send-email-a3at.mail@gmail.com
$ perf record ls
$ perf report
Press 'down enter end'
Result:
Program received signal SIGSEGV, Segmentation fault.
The UI browser, used on a argv array would access past the end of the
array on SEEK_END because it wasn't using 'nr_entries - 1', fix it.
Reported-by: v.karpov@samsung.com
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=59291
Link: http://lkml.kernel.org/n/tip-3g83ipasqi219ktv764xzzjs@git.kernel.org
It was affecting only frame-pointer (fp) based callchain processing.
Usage example:
perf top --call-graph dwarf,1024 --max-stack 2
Works for any tool that does callchain resolving and provides a
--max-stack option.
Cc: Waiman Long <Waiman.Long@hp.com>
Link: http://lkml.kernel.org/n/tip-eu45v8s3tq9ruay8tpfyon79@git.kernel.org
Just one use so far, on the hists browser, for completeness since there
we use perf_evlist__{first,last} and perf_evsel__next() for handling the
TAB and UNTAB keys.
Link: http://lkml.kernel.org/n/tip-d09l4lejp5427enuf3igpckw@git.kernel.org
In a few remaining places where the equivalent open coded variant was
still being used.
Link: http://lkml.kernel.org/n/tip-4vjnloi5fisilykwxalb5nel@git.kernel.org
When introducing the PERF_RECORD_MMAP2 in:
5c5e854bc760 perf tools: Add attr->mmap2 support
A check for the number of entries parsed by sscanf was introduced that
assumed all of the 8 fields needed to be correctly parsed so that
particular /proc/pid/maps line would be considered synthesizable.
That broke anon records synthesizing, as it doesn't have the 'execname'
field.
Fix it by keeping the sscanf return check, changing it to not require
that the 'execname' variable be parsed, so that the preexisting logic
can kick in and set it to '//anon'.
This should get things like JIT profiling working again.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Bill Gray <bgray@redhat.com>
Cc: Joe Mario <jmario@redhat.com>
Cc: Richard Fowles <rfowles@redhat.com>
Link: http://lkml.kernel.org/n/tip-bo4akalno7579shpz29u867j@git.kernel.org
[ commit log message is mine, dzickus reported the problem with a patch ]
Add missing newline if the 'uid' is invalid:
hubble:~> perf top --stdio -u help
Error:
Invalid User: helphubble:~>
Fixed by this patch:
comet:~/tip/tools/perf> perf top --stdio -u help
Error:
Invalid User: help
Link: http://lkml.kernel.org/r/20131112232609.GA31474@gmail.com
Accidentally ran into these, get rid of them.
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Link: http://lkml.kernel.org/r/1384323864.2527.8.camel@buesod1.americas.hpqcorp.net
Tweak the summary output as suggested by Ingo Molnar:
[penberg@localhost ~]$ perf trace -a --duration 10000 --summary -- sleep 1
^C
Summary of events:
Xorg (817), 148 events, 0.0%, 0.000 msec
syscall calls min avg max stddev
(msec) (msec) (msec) (%)
read 7 0.002 0.004 0.011 32.00%
rt_sigprocmask 40 0.001 0.001 0.002 1.31%
ioctl 6 0.002 0.003 0.005 19.45%
writev 7 0.004 0.018 0.059 43.76%
select 9 0.000 74.513 507.869 74.61%
setitimer 4 0.001 0.002 0.002 10.08%
Suggested-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/r/1384345308-24404-1-git-send-email-penberg@kernel.org
Set feature-libunwind-debug-frame. We don't want it in
CORE_FEATURE_TESTS because it's not the generic case, but we
need to set it in the !feature-libunwind case.
Also, because x86 distributions typically don't have
dwarf_find_debug_frame() unwinding method:
test-libunwind-debug-frame.c:(.text+0x31): undefined reference to `_Ux86_64_dwarf_find_debug_frame'
Restrict this new API to ARM for the time being.
With this patch test-all.c works again, so repeat perf builds
are fast again:
comet:~/tip> perf stat --null --repeat 5 make -C tools/perf/
0,452899660 seconds time elapsed ( +- 0,11% )
While with before it was:
1,674001829 seconds time elapsed ( +- 0,16% )
[ Includes fix to config/feature-checks/Makefile from Will Deacon. ]
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Jean Pihet <jean.pihet@linaro.org>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Link: http://lkml.kernel.org/n/tip-scsoctqzmou3rpkixCHezy9e@git.kernel.org
'feature_timerfd' is checked all the time and calculated explicitly,
in a serial fashion. Add it to CORE_FEATURE_TESTS which causes it to
be built in parallel, using the newfangled parallel build autodetection
code.
This shaves 137 msecs off the perf build time on my system, which
speeds up the common case cached build by 43%:
Before:
0,453771441 seconds time elapsed ( +- 0,09% )
After:
0,316290185 seconds time elapsed ( +- 0,24% )
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/n/tip-bb92CmexihopoSyqnkqepvsy@git.kernel.org
Pull perf updates from Ingo Molnar:
"A number of fixes:
- Fix segfault on perf trace -i perf.data, from Namhyung Kim.
- Fix segfault with --no-mmap-pages, from David Ahern.
- Don't force a refresh during progress update in the TUI, greatly
reducing startup costs, fix from Patrick Palka.
- Fix sw clock event period test wrt not checking if using >
max_sample_freq.
- Handle throttle events in 'object code reading' test, fix from
Adrian Hunter.
- Prevent condition that all sort keys are elided, fix from Namhyung
Kim.
- Round mmap pages to power 2, from David Ahern.
And a number of late arrival changes:
- Add summary only option to 'perf trace', suppressing the decoding
of events, from David Ahern
- 'perf trace --summary' formatting simplifications, from Pekka
Enberg.
- Beautify fifth argument of mmap() as fd, in 'perf trace', from
Namhyung Kim.
- Add direct access to dynamic arrays in libtraceevent, from Steven
Rostedt.
- Synthesize non-exec MMAP records when --data used, allowing the
resolution of data addresses to symbols (global variables, etc), by
Arnaldo Carvalho de Melo.
- Code cleanups by David Ahern and Adrian Hunter"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits)
tools lib traceevent: Add direct access to dynamic arrays
perf target: Shorten perf_target__ to target__
perf tests: Handle throttle events in 'object code reading' test
perf evlist: Refactor mmap_pages parsing
perf evlist: Round mmap pages to power 2 - v2
perf record: Fix segfault with --no-mmap-pages
perf trace: Add summary only option
perf trace: Simplify '--summary' output
perf trace: Change syscall summary duration order
perf tests: Compensate lower sample freq with longer test loop
perf trace: Fix segfault on perf trace -i perf.data
perf trace: Separate tp syscall field caching into init routine to be reused
perf trace: Beautify fifth argument of mmap() as fd
perf tests: Use lower sample_freq in sw clock event period test
perf tests: Check return of perf_evlist__open sw clock event period test
perf record: Move existing write_output into helper function
perf record: Use correct return type for write()
perf tools: Prevent condition that all sort keys are elided
perf machine: Simplify synthesize_threads method
perf machine: Introduce synthesize_threads method out of open coded equivalent
Merge dependencies to apply a fix.
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
"This time we only have a few changes as there are no soc thermal
changes from Eduardo. The only big change is the introduction of
TMON, a tool to help visualize, tune, and test the thermal subsystem.
The rest is mostly cleanups and fixes all over.
Specifics:
- introduce TMON, a tool base on thermal sysfs I/F. It can be used
to visualize, tune and test the thermal subsystem.
- fix a zone/cooling device binding problem, when both thermal zone
bind parameters and .bind() callback are available"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux:
tools/thermal: Introduce tmon, a tool for thermal subsystem
thermal: Fix binding problem when there is thermal zone params
thermal: cpu_cooling: fix return value check in cpufreq_cooling_register()
Thermal: Check for validity before doing kfree
thermal/intel_powerclamp: Add newer CPU models
Thermal: Tidy up error handling in powerclamp_init
thermal: Kconfig: cosmetic fixes
ACPI/thermal : Remove zone disabled warning
typo in drivers/thermal/Kconfig: lpatform instead of platform
Pull ARM updates from Russell King:
"Included in this series are:
1. BE8 (modern big endian) changes for ARM from Ben Dooks
2. big.Little support from Nicolas Pitre and Dave Martin
3. support for LPAE systems with all system memory above 4GB
4. Perf updates from Will Deacon
5. Additional prefetching and other performance improvements from Will.
6. Neon-optimised AES implementation fro Ard.
7. A number of smaller fixes scattered around the place.
There is a rather horrid merge conflict in tools/perf - I was never
notified of the conflict because it originally occurred between Will's
tree and other stuff. Consequently I have a resolution which Will
forwarded me, which I'll forward on immediately after sending this
mail.
The other notable thing is I'm expecting some build breakage in the
crypto stuff on ARM only with Ard's AES patches. These were merged
into a stable git branch which others had already pulled, so there's
little I can do about this. The problem is caused because these
patches have a dependency on some code in the crypto git tree - I
tried requesting a branch I can pull to resolve these, and all I got
each time from the crypto people was "we'll revert our patches then"
which would only make things worse since I still don't have the
dependent patches. I've no idea what's going on there or how to
resolve that, and since I can't split these patches from the rest of
this pull request, I'm rather stuck with pushing this as-is or
reverting Ard's patches.
Since it should "come out in the wash" I've left them in - the only
build problems they seem to cause at the moment are with randconfigs,
and since it's a new feature anyway. However, if by -rc1 the
dependencies aren't in, I think it'd be best to revert Ard's patches"
I resolved the perf conflict roughly as per the patch sent by Russell,
but there may be some differences. Any errors are likely mine. Let's
see how the crypto issues work out..
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits)
ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h"
ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg().
ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h
ARM: 7871/1: amba: Extend number of IRQS
ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise()
ARM: 7872/1: Support arch_irq_work_raise() via self IPIs
ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
ARM: 7878/1: nommu: Implement dummy early_paging_init()
ARM: 7876/1: clear Thumb-2 IT state on exception handling
ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}()
ARM: footbridge: fix build warnings for netwinder
ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu
ARM: fix misplaced arch_virt_to_idmap()
ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown
ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation
ARM: 7869/1: remove unused XSCALE_PMU Kconfig param
ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t
ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments
ARM: 7862/1: pcpu: replace __get_cpu_var_uses
ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code
Soft dirty bit allows us to track which pages are written since the last
clear_ref (by "echo 4 > /proc/pid/clear_refs".) This is useful for
userspace applications to know their memory footprints.
Note that the kernel exposes this flag via bit[55] of /proc/pid/pagemap,
and the semantics is not a default one (scheduled to be the default in the
near future.) However, it shifts to the new semantics at the first
clear_ref, and the users of soft dirty bit always do it before utilizing
the bit, so that's not a big deal. Users must avoid relying on the bit in
page-types before the first clear_ref.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Support the next generation Intel Atom processor
mirco-architecture, formerly called Silvermont.
The server version, formerly called "Avoton",
is named the "Intel(R) Atom(TM) Processor C2000 Product Family".
The client version, formerly called "Bay Trail",
is named the "Intel Atom Processor Z3000 Series",
as well as various "Intel Pentium Processor"
and "Intel Celeron Processor" brands, depending
on form-factor.
Silvermont has a set of MSRs not far off from NHM,
but the RAPL register set is a sub-set of those previously supported.
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo:
* Add summary only option to 'perf trace', suppressing the decoding of
* 'perf trace --summary' formatting simplifications, from Pekka Emberg.
* Beautify fifth argument of mmap() as fd, in 'perf trace', from Namhyung Kim.
* Fix segfault on perf trace -i perf.data, from Namhyung Kim.
* Fix segfault with --no-mmap-pages, from David Ahern.
* Round mmap pages to power 2, from David Ahern.
* Add direct access to dynamic arrays in libtraceevent, from Steven Rostedt.
* Handle throttle events in 'object code reading' test, fix from Adrian Hunter.
* Prevent condition that all sort keys are elided, fix from Namhyung Kim.
* Synthesize non-exec MMAP records when --data used, allowing the resolution of
data addresses to symbols (global variables, etc).
* Don't force a refresh during progress update in the TUI, greatly reducing
* Fix sw clock event period test wrt not checking if using > max_sample_freq.
* Code cleanups by David Ahern and Adrian Hunter.
Jiri Olsa was writing a plugin for the cfg80211_tx_mlme_mgmt trace
event, and was not able to get the implemented function working.
The event's print fmt looks like:
"netdev:%s(%d), ftype:0x%.2x", REC->name, REC->ifindex,
__le16_to_cpup((__le16 *)__get_dynamic_array(frame))
As there's no helper function for __le16_to_cpup(), Jiri was creating one
with a plugin. But unfortunately, it would not work even though he set
up the plugin correctly.
The problem is that the function parameters do not handle the helper
function "__get_dynamic_array()", and that passes in a NULL pointer.
Adding PRINT_DYNAMIC_ARRAY direct support to eval_num_arg() allows the
use of __get_dynamic_array() in function parameters.
Tested-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20131111160810.0ba9df7d@gandalf.local.home
Getting unwieldly long, for this app domain should be descriptive enough
and the use of __ to separate the class from the method names should
help with avoiding clashes with other code bases.
Reported-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/20131112113427.GA4053@ghostprotocols.net
Unhandled events cause an error that fails the test, fix it.
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/5281DFE5.3000909@intel.com
Logic will be re-used for the out-pages argument for mmap based writes
in perf-record.
Signed-off-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1384267617-3446-4-git-send-email-dsahern@gmail.com
Currently perf requires the -m / --mmap_pages option to be a power of 2.
To be more user friendly perf should automatically round this up to the
next power of 2.
Currently:
$ perf record -m 3 -a -- sleep 1
--mmap_pages/-m value must be a power of two.sleep: Terminated
With patch:
rounding mmap pages size to 16384 (4 pages)
v2: Add bytes units to rounding message per Ingo's request. Other
suggestions (e.g., prefixing INFO) should be addressed by wrapping
pr_info to catch all instances.
Link: http://lkml.kernel.org/r/1384267617-3446-3-git-send-email-dsahern@gmail.com
Adrian reported a segfault when using --no-out-pages:
$ tools/perf/perf record -vv --no-out-pages uname
Segmentation fault (core dumped)
The same occurs with --no-mmap-pages. Fix by checking that str is
non-NULL before parsing it.
Reported-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1384267617-3446-2-git-send-email-dsahern@gmail.com
Per request from Pekka make --summary a summary only option meaning do
not show the individual system calls. Add another option to see all
syscalls along with the summary. In addition use 's' and 'S' as
shortcuts for the options.
Requested-by: Pekka Enberg <penberg@kernel.org>
Tested-by: Pekka Enberg <penberg@kernel.org>
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/1384273875-3751-1-git-send-email-dsahern@gmail.com
The output of 'perf trace --summary' tries to be too cute with
formatting and makes it very hard to read. Simplify it in the spirit of
"strace -c":
[penberg@localhost libtrading]$ perf trace -a --duration 10000 --summary -- sleep 1
^C
Summary of events:
dbus-daemon (555), 10 events, 0.0%, 0.000 msec
msec/call
sendmsg 2 0.002 0.005 0.008 55.00
recvmsg 2 0.002 0.003 0.005 44.00
epoll_wait 1 0.000 0.000 0.000 0.00
NetworkManager (667), 56 events, 0.0%, 0.000 msec
msec/call
poll 2 0.000 0.002 0.003 100.00
sendmsg 10 0.004 0.007 0.016 15.41
recvmsg 16 0.002 0.003 0.005 8.24
zfs-fuse (669), 4 events, 0.0%, 0.000 msec
msec/call
futex 2 0.000 0.001 0.002 100.00
Link: http://lkml.kernel.org/r/1384267334-18953-1-git-send-email-penberg@kernel.org
Switch duration order to minimum, average, maximum for the '--summary'
command line option because it's more natural to read.
Link: http://lkml.kernel.org/r/1384265410-12344-1-git-send-email-penberg@kernel.org
