commit 58d406ed6a5f1ca4bc1dba5390b718c67847fa5f upstream.
Some versions of grep don't treat '\s' properly. When building perf on such
systems and using a kernel tarball the perf version is unable to be determined
from the main kernel Makefile and the user is left with a version of '..'.
Replacing the use of '\s' with '[[:space:]]', which should work in all grep
versions, gives a usable version number.
Reported-by: Tapan Dhimant <tdhimant@akamai.com>
Cc: Tapan Dhimant <tdhimant@akamai.com>
LKML-Reference: <1300241800-30281-1-git-send-email-johunt@akamai.com>
Signed-off-by: Josh Hunt <johunt@akamai.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
kallsyms has a virtual file name [kernel.kallsyms]. Currently, it can't
be added to buildid cache successfully because the code
(build_id_cache__add_s) tries to resolve [kernel.kallsyms] to a real
absolute pathname and that fails.
Fixes it by not resolving it and just use the name [kernel.kallsyms].
So dir ~/.debug/[kernel.kallsyms] is created.
Original bug report at:
https://lkml.org/lkml/2011/3/1/524
Tested-by: Han Pingtian <phan@redhat.com>
Cc: Han Pingtian <phan@redhat.com>
LKML-Reference: <1299165837-27817-1-git-send-email-ming.m.lin@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
The ec5761e cset introduced the symfs feature with a bug for loading vmlinux
files that ended up causing this failure:
[root@emilia v2.6.38-rc5+]# strace -e trace=open perf top --vmlinux ./vmlinux 2>&1 | tail -3
open("/./vmlinux", O_RDONLY) = -1 ENOENT (No such file or directory)
./vmlinux with build id b9266bf40e98dadb5d43a2f3e95d3c5d4aff46dc not found, continuing without symbols
The ./vmlinux file can't be used
Remove the extra slash, just like is done in the DSO__ORIG_DSO handling in
dso__load() and other parts of the ec5761e cset.
Reported-by: Ingo Molnar <mingo@elte.hu>
Cc: David Ahern <daahern@cisco.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <new-submission>
Currently numcpus is determined in pid_put_sample which is only
called on sched_switch/sched_wakeup sample processing.
On a machine with a lot cpus I often saw the last cpu missing.
Check for (max) numcpus on every event happening and in the
beginning. -> fixes the issue for me.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: lenb@kernel.org
LKML-Reference: <1298842606-55712-6-git-send-email-trenn@suse.de>
This fix is needed for eye of gnome and firefox svg viewers.
Only Inkscape can handle the broken case.
Compare with the other svg_legenda_box declarations, looks
like a typo slipped in at this place.
Cc: lenb@kernel.org
LKML-Reference: <1298842606-55712-5-git-send-email-trenn@suse.de>
So that we match the header where we state the number of events with the
"Samples" column when using 'perf report -n/--show-nr-samples':
[root@emilia ~]# perf record -a sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.111 MB perf.data (~4860 samples) ]
[root@emilia ~]# perf report --stdio --show-nr-samples
# Events: 11 cycles
# Overhead Samples Command Shared Object Symbol
16.65% 1 sleep [kernel.kallsyms] [k] unmap_vmas
16.10% 1 perf libpthread-2.12.so [.] __pthread_cleanup_push_defer
15.79% 2 perf [kernel.kallsyms] [k] format_decode
12.88% 1 kworker/1:2 [kernel.kallsyms] [k] cache_reap
10.69% 1 swapper [kernel.kallsyms] [k] _raw_spin_lock
7.55% 1 sleep [kernel.kallsyms] [k] prepare_exec_creds
6.00% 1 perf [jbd2] [k] start_this_handle
5.29% 1 perf [kernel.kallsyms] [k] seq_read
4.75% 1 perf [kernel.kallsyms] [k] get_pid_task
4.30% 1 perf [kernel.kallsyms] [k] _raw_spin_unlock_irqrestore
# (For a higher level overview, try: perf report --sort comm,dso)
[root@emilia ~]#
Reported-by: Stephane Eranian <eranian@google.com>
Reported-by: Cliff Wickman <cpw@sgi.com>
Acked-by: Stephane Eranian <eranian@google.com>
Cc: <stable@kernel.org>
[ cherry-picked it from perf/core, as it has been reported by others as well. ]
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'tools-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
tools: turbostat: style updates
tools: turbostat: fix bitwise and operand
Follow kernel coding style traditions more closely.
Delete typedef, re-name "per cpu counters" to
simply be counters etc.
This patch changes no functionality.
Suggested-by: Thiago Farina <tfransosi@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
bug could cause false positive on indicating
presence of invarient TSC or APERF support.
Jeff Moyer reported these messages:
Warning: ... trying to fall back to cpu-clock-ticks
couldn't open /proc/-1/status
couldn't open /proc/-1/maps
[ls output]
[ perf record: Captured and wrote 0.008 MB perf.data (~363 samples) ]
That lead me and David Ahern to see that something was fishy on the thread
synthesizing routines, at least for the case where the workload is started
from 'perf record', as -1 is the default for target_tid in 'perf record --tid'
parameter, so somehow we were trying to synthesize the PERF_RECORD_MMAP and
PERF_RECORD_COMM events for the thread -1, a bug.
So I investigated this and noticed that when we introduced support for
recording a process and its threads using --pid some bugs were introduced and
that the way to fix it was to instead of passing the target_tid to the event
synthesizing routines we should better pass the thread_map that has the list of
threads for a --pid or just the single thread for a --tid.
Checked in the following ways:
On a 8-way machine run cyclictest:
[root@emilia ~]# perf record cyclictest -a -t -n -p99 -i100 -d50
policy: fifo: loadavg: 0.00 0.13 0.31 2/139 28798
T: 0 (28791) P:99 I:100 C: 25072 Min: 4 Act: 5 Avg: 6 Max: 122
T: 1 (28792) P:98 I:150 C: 16715 Min: 4 Act: 6 Avg: 5 Max: 27
T: 2 (28793) P:97 I:200 C: 12534 Min: 4 Act: 5 Avg: 4 Max: 8
T: 3 (28794) P:96 I:250 C: 10028 Min: 4 Act: 5 Avg: 5 Max: 96
T: 4 (28795) P:95 I:300 C: 8357 Min: 5 Act: 6 Avg: 5 Max: 12
T: 5 (28796) P:94 I:350 C: 7163 Min: 5 Act: 6 Avg: 5 Max: 12
T: 6 (28797) P:93 I:400 C: 6267 Min: 4 Act: 5 Avg: 5 Max: 9
T: 7 (28798) P:92 I:450 C: 5571 Min: 4 Act: 5 Avg: 5 Max: 9
^C[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.108 MB perf.data (~4719 samples) ]
[root@emilia ~]#
This will create one extra thread per CPU:
[root@emilia ~]# tuna -t cyclictest -CP
thread ctxt_switches
pid SCHED_ rtpri affinity voluntary nonvoluntary cmd
28825 OTHER 0 0xff 2169 671 cyclictest
28832 FIFO 93 6 52338 1 cyclictest
28833 FIFO 92 7 46524 1 cyclictest
28826 FIFO 99 0 209360 1 cyclictest
28827 FIFO 98 1 139577 1 cyclictest
28828 FIFO 97 2 104686 0 cyclictest
28829 FIFO 96 3 83751 1 cyclictest
28830 FIFO 95 4 69794 1 cyclictest
28831 FIFO 94 5 59825 1 cyclictest
[root@emilia ~]#
So we should expect only samples for the above 9 threads when using the
--dump-raw-trace|-D perf report switch to look at the column with the tid:
[root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c
629 28825
110 28826
491 28827
308 28828
198 28829
621 28830
225 28831
203 28832
89 28833
[root@emilia ~]#
So for workloads started by 'perf record' seems to work, now for existing workloads,
just run cyclictest first, without 'perf record':
28859 OTHER 0 0xff 594 200 cyclictest
28864 FIFO 95 4 16587 1 cyclictest
28865 FIFO 94 5 14219 1 cyclictest
28866 FIFO 93 6 12443 0 cyclictest
28867 FIFO 92 7 11062 1 cyclictest
28860 FIFO 99 0 49779 1 cyclictest
28861 FIFO 98 1 33190 1 cyclictest
28862 FIFO 97 2 24895 1 cyclictest
28863 FIFO 96 3 19918 1 cyclictest
[root@emilia ~]#
and then later did:
[root@emilia ~]# perf record --pid 28859 sleep 3
[ perf record: Captured and wrote 0.027 MB perf.data (~1195 samples) ]
[root@emilia ~]#
To collect 3 seconds worth of samples for pid 28859 and its children:
15 28859
33 28860
19 28861
13 28862
13 28863
10 28864
11 28865
9 28866
255 28867
[root@emilia ~]#
Works, last thing is to check if looking at just one of those threads also works:
[root@emilia ~]# perf record --tid 28866 sleep 3
[ perf record: Captured and wrote 0.006 MB perf.data (~242 samples) ]
3 28866
[root@emilia ~]#
Works too.
Reported-by: Jeff Moyer <jmoyer@redhat.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Introduced in: c52b12ed, when this sequence:
count[0] = count[1] = count[2] = 0;
Was replaced with:
aggr->val = 0;
Which is equivalent to zeroing just the first entry in the 'count'
array.
Fix it by zeroing the three entries with:
aggr->val = aggr->ena = aggr->run = 0;
It's enough to include the local "debug.h" file to trigger it.
man time reveals this is already declared in glibc:
time - get time in seconds
-> rename the variable.
Cc: arjan@infradead.org
LPU-Reference: <1295620209-13859-2-git-send-email-trenn@suse.de>
The -Wstack-protector and -Wvolatile-register-var warnings, for
instance, are not supported by gcc 3.4.6.
So fix by doing the same check we already do for -fstack-protector-all.
With this and the other patches in this series, perf builds unmodified
on, for instance, RHEL4.
[acme@localhost linux]$ make O=~acme/git/build/perf -C tools/perf
make: Entering directory `/home/acme/git/linux/tools/perf'
Makefile:526: No libdw.h found or old libdw.h found or elfutils is older than 0.138, disables dwarf support. Please install new elfutils-devel/libdw-dev
Makefile:582: newt not found, disables TUI support. Please install newt-devel or libnewt-dev
CC /home/acme/git/build/perf/builtin-annotate.o
In file included from builtin-annotate.c:23:
util/parse-events.h:26: warning: declaration of 'evsel_list' shadows a global declaration
util/parse-events.h:12: warning: shadowed declaration is here
make: *** [/home/acme/git/build/perf/builtin-annotate.o] Error 1
make: Leaving directory `/home/acme/git/linux/tools/perf'
[acme@localhost linux]$ gcc --version | head -1
gcc (GCC) 3.4.6 20060404 (Red Hat 3.4.6-11)
Fix it by renaming the parameter to evlist.
We need the definiton for __always_inline in bitops.h to fix the build
on distros where it isn't available or compiler.h doesn't get included
indirectly.
One of the fixes needed to build perf on RHEL4 systems, for instance.
Using %L[uxd] has issues in some architectures, like on ppc64. Fix it
by making our 64 bit integers typedefs of stdint.h types and using
PRI[ux]64 like, for instance, git does.
Reported by Denis Kirjanov that provided a patch for one case, I went
and changed all cases.
Reported-by: Denis Kirjanov <dkirjanov@kernel.org>
Tested-by: Denis Kirjanov <dkirjanov@kernel.org>
LKML-Reference: <20110120093246.GA8031@hera.kernel.org>
Cc: Denis Kirjanov <dkirjanov@kernel.org>
Cc: Pingtian Han <phan@redhat.com>
Where we don't have CPU_ALLOC & friends. As the tools are being used in older
distros where the only allowed change are to replace the kernel, like RHEL4 and
5.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
When some of CPUs are offline:
# cat /sys/devices/system/cpu/online
0,6-31
perf test will fail on #3 testcase:
3: detect open syscall event on all cpus:
--- start ---
perf_evsel__read_on_cpu: expected to intercept 111 calls on cpu 0, got 681
perf_evsel__read_on_cpu: expected to intercept 112 calls on cpu 1, got 117
perf_evsel__read_on_cpu: expected to intercept 113 calls on cpu 2, got 118
perf_evsel__read_on_cpu: expected to intercept 114 calls on cpu 3, got 119
perf_evsel__read_on_cpu: expected to intercept 115 calls on cpu 4, got 120
perf_evsel__read_on_cpu: expected to intercept 116 calls on cpu 5, got 121
perf_evsel__read_on_cpu: expected to intercept 117 calls on cpu 6, got 122
perf_evsel__read_on_cpu: expected to intercept 118 calls on cpu 7, got 123
perf_evsel__read_on_cpu: expected to intercept 119 calls on cpu 8, got 124
perf_evsel__read_on_cpu: expected to intercept 120 calls on cpu 9, got 125
perf_evsel__read_on_cpu: expected to intercept 121 calls on cpu 10, got 126
This patch try to use 'cpus->map[cpu]' when setting cpu affinity, and
will check the return code of sched_setaffinity()
LKML-Reference: <20110120114707.GA11781@hpt.nay.redhat.com>
Signed-off-by: Han Pingtian <phan@redhat.com>
In ARM's Thumb mode the bottom bit of the symbol address is set to mark
the function as Thumb; the instructions are in reality 2 or 4 byte on 2
byte alignments, and when the +1 address is used in annotate it causes
objdump to disassemble invalid instructions.
The patch removes that bottom bit during symbol loading.
Many thinks to Dave Martin for comments on an initial version of the
patch.
(For reference this corresponds to this bug
https://bugs.launchpad.net/linux-linaro/+bug/677547 )
Cc: Dave Martin <dave.martin@linaro.org>
LKML-Reference: <20110121163922.GA31398@davesworkthinkpad>
Signed-off-by: Dr. David Alan Gilbert <david.gilbert@linaro.org>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Fix tracepoint id to string perf.data header table
perf tools: Fix handling of wildcards in tracepoint event selectors
powerpc: perf: Fix frequency calculation for overflowing counters
It was broken by f006d25 that passed just the event name, not the complete
sys:event that it expected to open the /sys/.../sys/sys:event/id file to get
the id.
Fix it by moving it to after parse_events in cmd_record, as at that point
we can just traverse the evsel_list and use evsel->attr.config +
event_name(evsel) instead of re-opening the /id file.
Reported-by: Franck Bui-Huu <vagabon.xyz@gmail.com>
Cc: Franck Bui-Huu <vagabon.xyz@gmail.com>
LKML-Reference: <20110117202801.GG2085@ghostprotocols.net>
It wasn't accounting the ':' when consuming bytes in the the event
selector string, so parse_events() would fail in this test:
if (!(*str == 0 || *str == ',' || isspace(*str)))
return -1;
as *str would be pointing to '*', the last character in the '-e' arg in:
$ perf record -q -a -D -e sched:sched_* | perf script -i - -s perf-script.py
'timers-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: avoid pointless blocked-task warnings
rcu: demote SRCU_SYNCHRONIZE_DELAY from kernel-parameter status
rtmutex: Fix comment about why new_owner can be NULL in wake_futex_pi()
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, olpc: Add missing Kconfig dependencies
x86, mrst: Set correct APB timer IRQ affinity for secondary cpu
x86: tsc: Fix calibration refinement conditionals to avoid divide by zero
x86, ia64, acpi: Clean up x86-ism in drivers/acpi/numa.c
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
timekeeping: Make local variables static
time: Rename misnamed minsec argument of clocks_calc_mult_shift()
tracing: Remove syscall_exit_fields
tracing: Only process module tracepoints once
perf record: Add "nodelay" mode, disabled by default
perf sched: Fix list of events, dropping unsupported ':r' modifier
Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return"
perf top: Fix annotate segv
perf evsel: Fix order of event list deletion
Sometimes there is a need to use perf in "live-log" mode. The problem
is, for seldom events, actual info output is largely delayed because
perf-record reads sample data in whole pages.
So for such scenarious, add flag for perf-record to go in "nodelay"
mode. To track e.g. what's going on in icmp_rcv while ping is running
Use it with something like this:
(1) $ perf probe -L icmp_rcv | grep -U8 '^ *43\>'
goto error;
38 if (!pskb_pull(skb, sizeof(*icmph)))
goto error;
icmph = icmp_hdr(skb);
43 ICMPMSGIN_INC_STATS_BH(net, icmph->type);
* 18 is the highest 'known' ICMP type. Anything else is a mystery
* RFC 1122: 3.2.2 Unknown ICMP messages types MUST be silently
* discarded.
50 if (icmph->type > NR_ICMP_TYPES)
goto error;
$ perf probe icmp_rcv:43 'type=icmph->type'
(2) $ cat trace-icmp.py
def trace_begin():
print "in trace_begin"
def trace_end():
print "in trace_end"
def probe__icmp_rcv(event_name, context, common_cpu,
common_secs, common_nsecs, common_pid, common_comm,
__probe_ip, type):
print_header(event_name, common_cpu, common_secs, common_nsecs,
common_pid, common_comm)
print "__probe_ip=%u, type=%u\n" % \
(__probe_ip, type),
(3) $ perf record -a -D -e probe:icmp_rcv -o - | \
perf script -i - -s trace-icmp.py
Thanks to Peter Zijlstra for pointing how to do it.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Ingo Molnar <mingo@elte.hu>, Mike Galbraith <efault@gmx.de>
LKML-Reference: <20110112140613.GA11698@tugrik.mns.mnsspb.ru>
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
Looks to me like the :r modifier is not supported anymore, so remove it from
the list of events.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Robert Richter <robert.richter@amd.com>
LKML-Reference: <AANLkTim=jawJyBj0iFd0r4-LCKzvjFW+NddzJMD5GUB9@mail.gmail.com>
Signed-off-by: Stephane Eranian <eranian@google.com>
* 'tools' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
tools: create power/x86/x86_energy_perf_policy
tools: create power/x86/turbostat
* git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest: (30 commits)
ktest: Ask for the manditory config options instead of just failing
ktest: Copy the last good and bad configs in config_bisect
ktest: For grub reboot, use run_ssh instead of run_command
ktest: Added force stop after success and failure
ktest: Parse off the directory name in useconfig for failures
ktest: Use different temp config name for minconfig
ktest: Updated the sample.conf for the latest options
ktest: Added compare script to test ktest.pl to sample.conf
ktest: Added config_bisect test type
ktest/cleanups: Added version 0.2, ssh as options
ktest: Output something easy to parse for failure or success
ktest: Allow a test case to undefine a default value
ktest: Use $output_config instead of typing $outputdir/.config
ktest: Write to stdout if no log file is given
ktest: Use oldnoconfig instead of yes command
ktest: Update the sample config file with more documentation
ktest: New TEST_START instead of using [], and use real SHA1s
ktest: Add poweroff after halt and powercycle after reboot
ktest: Add POST_INSTALL to allow initrds to be created
ktest: Added sample.conf, new %default option format
MSR_IA32_ENERGY_PERF_BIAS first became available on Westmere Xeon.
It is implemented in all Sandy Bridge processors -- mobile, desktop and server.
It is expected to become increasingly important in subsequent generations.
x86_energy_perf_policy is a user-space utility to set the
hardware energy vs performance policy hint in the processor.
Most systems would benefit from "x86_energy_perf_policy normal"
at system startup, as the hardware default is maximum performance
at the expense of energy efficiency.
See x86_energy_perf_policy.8 man page for more information.
Background:
Linux-2.6.36 added "epb" to /proc/cpuinfo to indicate
if an x86 processor supports MSR_IA32_ENERGY_PERF_BIAS,
without actually modifying the MSR.
In March, 2010, Venkatesh Pallipadi proposed a small driver
that programmed MSR_IA32_ENERGY_PERF_BIAS, based on
the cpufreq governor in use. It also offered
a boot-time cmdline option to override.
http://lkml.org/lkml/2010/3/4/457
But hiding the hardware policy behind the
governor choice was deemed "kinda icky".
In June, 2010, I proposed a generic user/kernel API to
generalize the power/performance policy trade-off.
"RFC: /sys/power/policy_preference"
http://lkml.org/lkml/2010/6/16/399
That is my preference for implementing this capability,
but I received no support on the list.
So in September, 2010, I sent x86_energy_perf_policy.c to LKML,
a user-space utility that scribbles directly to the MSR.
http://lkml.org/lkml/2010/9/28/246
Here is that same utility, after responding to some review feedback,
to live in tools/power/, where it is easily found.
turbostat is a Linux tool to observe proper operation
of Intel(R) Turbo Boost Technology.
turbostat displays the actual processor frequency
on x86 processors that include APERF and MPERF MSRs.
Note that turbostat is of limited utility on Linux
kernels 2.6.29 and older, as acpi_cpufreq cleared
APERF/MPERF up through that release.
On Intel Core i3/i5/i7 (Nehalem) and newer processors,
turbostat also displays residency in idle power saving states,
which are necessary for diagnosing any cpuidle issues
that may have an effect on turbo-mode.
See the turbostat.8 man page for example usage.
This reverts commit aa7bc7ef73efc46d7c3a0e185eefaf85744aec98.
It removed the fallback from hardware profiling to software profiling.
.e.g., in a VM with no PMU.
Reported-by: David Ahern <daahern@cisco.com>
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
perf session: Fix infinite loop in __perf_session__process_events
perf evsel: Support perf_evsel__open(cpus > 1 && threads > 1)
perf sched: Use PTHREAD_STACK_MIN to avoid pthread_attr_setstacksize() fail
perf stat: better error message for unsupported events
perf sched: Fix allocation result check
perf, x86: P4 PMU - Fix unflagged overflows handling
dynamic debug: Fix build issue with older gcc
tracing: Fix TRACE_EVENT power tracepoint creation
tracing: Fix preempt count leak
tracepoint: Add __rcu annotation
tracing: remove duplicate null-pointer check in skb tracepoint
tracing/trivial: Add missing comma in TRACE_EVENT comment
tracing: Include module.h in define_trace.h
x86: Save rbp in pt_regs on irq entry
x86, dumpstack: Fix unused variable warning
x86, NMI: Clean-up default_do_nmi()
x86, NMI: Allow NMI reason io port (0x61) to be processed on any CPU
x86, NMI: Remove DIE_NMI_IPI
x86, NMI: Add priorities to handlers
Before we had sym_counter, it was initialized to zero and we used that
as an index in the global attrs variable, now we have a list of evsel
entries, and sym_counter became sym_evsel, that remained initialized to
zero (NULL): b00m.
Fix it by initializing it to the first entry in the evsel list.
Bug-introduced: 69aad6f
Reported-by: Kirill Smelkov <kirr@mns.spb.ru>
Tested-by: Kirill Smelkov <kirr@mns.spb.ru>
Cc: Kirill Smelkov <kirr@mns.spb.ru>
We need to defer calling perf_evsel_list__delete() till after atexit
registered routines, because we need to traverse the events being
recorded at that time at least on 'perf record'.
This fixes the problem reported by Thomas Renninger where cmd_record
called by cmd_timechart would not write the tracing data to the perf.data
file header because the evsel_list at atexit (control+C on 'perf timechart
record') time would be empty, being already deleted by run_builtin(),
and thus 'perf timechart' when trying to process such perf.data file would
die with:
"no trace data in the file"
Problem introduced in 70d544d.
Reported-by: Thomas Renninger <trenn@suse.de>
Cc: Thomas Renninger <trenn@suse.de>
In this if statement:
if (head + event->header.size >= mmap_size) {
if (mmaps[map_idx]) {
munmap(mmaps[map_idx], mmap_size);
mmaps[map_idx] = NULL;
page_offset = page_size * (head / page_size);
file_offset += page_offset;
head -= page_offset;
goto remap;
With, for instance, these values:
head=2992
event->header.size=48
mmap_size=3040
We end up endlessly looping back to remap. Off by one.
Problem introduced in 55b4462.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Bisected-by: David Ahern <daahern@cisco.com>
Tested-by: David Ahern <daahern@cisco.com>
And a test for it:
[acme@felicio linux]$ perf test
1: vmlinux symtab matches kallsyms: Ok
2: detect open syscall event: Ok
3: detect open syscall event on all cpus: Ok
Translating C the test does:
1. generates different number of open syscalls on each CPU
by using sched_setaffinity
2. Verifies that the expected number of events is generated
on each CPU
It works as expected.
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
slub: Fix a crash during slabinfo -v
tracing/slab: Move kmalloc tracepoint out of inline code
slub: Fix slub_lock down/up imbalance
slub: Fix build breakage in Documentation/vm
slub tracing: move trace calls out of always inlined functions to reduce kernel code size
slub: move slabinfo.c to tools/slub/slabinfo.c
on ppc64:
/usr/include/bits/local_lim.h:#define PTHREAD_STACK_MIN 131072
therefore following set of commands:
gives:
perf.2.6.37test: builtin-sched.c:493: create_tasks: Assertion `!(err)' failed.
So make sure we do not set stack size lower than PTHREAD_STACK_MIN.
LKML-Reference: <20110110160417.GB2685@psychotron.brq.redhat.com>
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Improve sys_perf_event_open ENOENT return handling in top and record, just
like 5a3446b does for stat.
For unsupported events (e.g., H/W events when running in a VM)
perf stat currently fails with the error message:
Error: open_counter returned with 2 (No such file or directory).
/bin/dmesg may provide additional information.
Fatal: Not all events could be opened.
dmesg is of no help and it is not clear as to why it fails to
open the counter. This patch changes the error message to
Error: cache-misses event is not supported.
Cc: a.p.zijlstra@chello.nl
LPU-Reference: <1294597272-17335-1-git-send-email-daahern@cisco.com>
Signed-off-by: David Ahern <daahern@cisco.com>
Bug introduced in ce47dc56.
Reported-by: Mike Galbraith <efault@gmx.de>
Cc: Chris Samuel <chris@csamuel.org>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (65 commits)
[S390] prevent unneccesary loops_per_jiffy recalculation
[S390] cpuinfo: use get_online_cpus() instead of preempt_disable()
[S390] smp: remove cpu hotplug messages
[S390] mutex: enable spinning mutex on s390
[S390] mutex: Introduce arch_mutex_cpu_relax()
[S390] cio: fix ccwgroup unregistration race condition
[S390] perf: add DWARF register lookup for s390
[S390] cleanup ftrace backend functions
[S390] ptrace cleanup
[S390] smp/idle: call init_idle() before starting a new cpu
[S390] smp: delay idle task creation
[S390] dasd: Correct retry counter for terminated I/O.
[S390] dasd: Add support for raw ECKD access.
[S390] dasd: Prevent deadlock during suspend/resume.
[S390] dasd: Improve handling of stolen DASD reservation
[S390] dasd: do path verification for paths added at runtime
[S390] dasd: add High Performance FICON multitrack support
[S390] cio: reduce memory consumption of itcw structures
[S390] nmi: enable machine checks early
[S390] qeth: buffer count imbalance
Since commit 69aad6f1(perf tools: Introduce event selectors), only
perf_event_attr::type and ::config are passed to event selector, which
makes perf tool not work correctly.
For example, PEBS does not work because perf_event_attr::precise_ip is
not passed to the syscall.
LKML-Reference: <1294369869.20563.19.camel@minggr.sh.intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1436 commits)
cassini: Use local-mac-address prom property for Cassini MAC address
net: remove the duplicate #ifdef __KERNEL__
net: bridge: check the length of skb after nf_bridge_maybe_copy_header()
netconsole: clarify stopping message
netconsole: don't announce stopping if nothing happened
cnic: Fix the type field in SPQ messages
netfilter: fix export secctx error handling
netfilter: fix the race when initializing nf_ct_expect_hash_rnd
ipv4: IP defragmentation must be ECN aware
net: r6040: Return proper error for r6040_init_one
dcb: use after free in dcb_flushapp()
dcb: unlock on error in dcbnl_ieee_get()
net: ixp4xx_eth: Return proper error for eth_init_one
include/linux/if_ether.h: Add #define ETH_P_LINK_CTL for HPNA and wlan local tunnel
net: add POLLPRI to sock_def_readable()
af_unix: Avoid socket->sk NULL OOPS in stream connect security hooks.
net_sched: pfifo_head_drop problem
mac80211: remove stray extern
mac80211: implement off-channel TX using hw r-o-c offload
mac80211: implement hardware offload for remain-on-channel
It seems that some gcc versions build by default with frame pointers
and some others omit them.
Just build the tools with frame pointers as the callchains can be an
important part of the perf workflow.
LKML-Reference: <1294325513-14276-3-git-send-email-fweisbec@gmail.com>
I found when specifying all tracepoints with -e to one of subcommand,
such as 'stat', the program will trigger a buffer overflow error, like
this:
*** buffer overflow detected ***: ./perf terminated
======= Backtrace: =========
/lib64/libc.so.6(__fortify_fail+0x37)[0x382cefb2c7]
The tracepoints are separated by comma, something like this:
$ perf stat -a -e `perf list |grep Tracepoint|awk -F'[' '{gsub(/[[:space:]]+/,"",$1);array[FNR]=$1}END{outputs=array[1];for (i=2;i<=FNR;i++){ outputs=outputs "," array[i];};print outputs}'`
The root reason of this problem is that store_event_type() is called for all
events, and will overflow the 'filename' at:
strncat(filename, orgname, strlen(orgname));
This patch fixes it by calling store_event_type() only when the event name has
been found.
LKML-Reference: <20110106093922.GB6713@hpt.nay.redhat.com>
Not accessed outside builtin-script, so make them static.
That already does what was being done here. The warning is now unconditionally
given by __perf_session__process_pipe_events, just like for non pipe processing.
Just like we do at __perf_session__process_events
