path: root/tools
2014-03-03Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull liblockdep fixes from Ingo Molnar: "A handful of build fixes for liblockdep" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tools/liblockdep: Use realpath for srctree and objtree tools/liblockdep: Add a stub for new rcu_is_watching tools/liblockdep: Mark runtests.sh as executable tools/liblockdep: Add include directory to allow tests to compile tools/liblockdep: Fix include of asm/hash.h tools/liblockdep: Fix initialization code path
2014-02-28perf tools: Fix strict alias issue for find_first_bitJiri Olsa
When compiling perf tool code with gcc 4.4.7 I'm getting following error: CC util/session.o cc1: warnings being treated as errors util/session.c: In function ‘perf_session_deliver_event’: tools/perf/util/include/linux/bitops.h:109: error: dereferencing pointer ‘p’ does break strict-aliasing rules tools/perf/util/include/linux/bitops.h:101: error: dereferencing pointer ‘p’ does break strict-aliasing rules util/session.c:697: note: initialized from here tools/perf/util/include/linux/bitops.h:101: note: initialized from here make[1]: *** [util/session.o] Error 1 make: *** [util/session.o] Error 2 The aliased types here are u64 and unsigned long pointers, which is safe for the find_first_bit processing. This error shows up for me only for gcc 4.4 on 32bit x86, even for -Wstrict-aliasing=3, while newer gcc are quiet and scream here for -Wstrict-aliasing={2,1}. Looks like newer gcc changed the rules for strict alias warnings. The gcc documentation offers workaround for valid aliasing by using __may_alias__ attribute: http://gcc.gnu.org/onlinedocs/gcc-4.4.0/gcc/Type-Attributes.html Using this workaround for the find_first_bit function. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1393434867-20271-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-27perf tools: fix BFD detection on opensuseAndi Kleen
opensuse libbfd requires -lz -liberty to build. Add those to the BFD feature detection. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: David Ahern <dsahern@gmail.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1389469379-13340-2-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-27Merge branch 'liblockdep-fixes' of https://github.com/sashalevin/liblockdep ↵Ingo Molnar
into core/urgent Pull tools/lib/lockdep/ fixes from Sasha Levin. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: * Fix annotation on stdio/GTK+ interfaces (Namhyung Kim) * Fix file descriptor leaking while searching DSOs for suitable symtab (Namhyung Kim). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-26tools/liblockdep: Use realpath for srctree and objtreeWang Nan
If BUILD_SRC or CURDIR contains tailing '/', the file names passed to gcc will contain '//'. It will be contained .o's in debuginfo, then confuse debugedit: https://bugzilla.redhat.com/show_bug.cgi?id=304121 This patch uses realpath command to makesure potential tailing '/'s are removed. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Geng Hui <hui.geng@huawei.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Add a stub for new rcu_is_watchingSasha Levin
Stub out rcu_is_watching(), prevents build error with the updated tree. Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Mark runtests.sh as executableSasha Levin
runtests.sh is used to run the sanity tests for liblockdep and should be set +x. Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Add include directory to allow tests to compileIra W. Snyder
All of the programs in the tests directory require the liblockdep/mutex.h header in order to compile. Add the include directory to the compiler options so that the tests can be built with the provided Makefile. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Fix include of asm/hash.hIra W. Snyder
Commit 71ae8aac ("lib: introduce arch optimized hash library") added an include to <linux/hash.h> for setting up an architecture specific fast hash. This patch mirrors the fix used for perf, titled "tools: perf: util: fix include for non x86 architectures". Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-26tools/liblockdep: Fix initialization code pathIra W. Snyder
This makes initialization actually happen. Without it, initialization is always skipped due to an incorrect conditional statement. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-02-24perf symbols: Destroy unused symsrcsNamhyung Kim
Stephane reported that perf report and annotate failed to process data using lots of (> 500) shared libraries. It was because of the limit on number of open files (ulimit -n). Currently when perf loads a DSO, it'll look for normal and dynamic symbol tables. And if it fails to find out both tables, it'll iterate all of possible symtab types. But many of them are useless since they have no additional information and the problem is that it's not closing those files even though they're not used. Fix it. Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Cody P Schafer <cody@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1392859976-32760-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-24perf annotate: Check availability of annotate when processing samplesNamhyung Kim
The TUI of perf report and top support annotation, but stdio and GTK don't. So it should be checked before calling hist_entry__inc_addr_ samples() to avoid wasting resources that will never be used. perf annotate need it regardless of UI and sort keys, so the check of whether to allocate resources should be on the tools that have annotate as an option in the TUI, 'report' and 'top', not on the function called by all of them. It caused perf annotate on ppc64 to produce zero output, since the buckets were not being allocated. Reported-by: Anton Blanchard <anton@samba.org> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Anton Blanchard <anton@samba.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1392859976-32760-1-git-send-email-namhyung@kernel.org [ Renamed (report,top)__needs_annotate() to ui__has_annotation() ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-22Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixlets from all around the place" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/uncore: Fix IVT/SNB-EP uncore CBOX NID filter table perf/x86: Correctly use FEATURE_PDCM perf, nmi: Fix unknown NMI warning perf trace: Fix ioctl 'request' beautifier build problems on !(i386 || x86_64) arches perf trace: Add fallback definition of EFD_SEMAPHORE perf list: Fix checking for supported events on older kernels perf tools: Handle PERF_RECORD_HEADER_EVENT_TYPE properly perf probe: Do not add offset twice to uprobe address perf/x86: Fix Userspace RDPMC switch perf/x86/intel/p6: Add userspace RDPMC quirk for PPro
2014-02-13perf trace: Fix ioctl 'request' beautifier build problems on !(i386 || ↵Arnaldo Carvalho de Melo
x86_64) arches Supporting decoding the ioctl 'request' parameter needs more work to properly support more architectures, the current approach doesn't work on at least powerpc and sparc, as reported by Ben Hutchings in http://lkml.kernel.org/r/1391593985.3003.48.camel@deadeye.wl.decadent.org.uk . Work around that by making it to be ifdefed for the architectures known to work with the current, limited approach, i386 and x86_64 till better code is written. Reported-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Ben Hutchings <ben@decadent.org.uk> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: <stable@vger.kernel.org> # 3.13 Fixes: 78645cf3ed32 ("perf trace: Initial beautifier for ioctl's 'cmd' arg") Link: http://lkml.kernel.org/n/tip-ss04k11insqlu329xh5g02q0@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf trace: Add fallback definition of EFD_SEMAPHOREBen Hutchings
glibc 2.17 is missing this on sparc, despite the fact that it's not architecture-specific. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 49af9e93adfa ('perf trace: Beautify eventfd2 'flags' arg') Cc: <stable@vger.kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1391648435.3003.100.camel@deadeye.wl.decadent.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf list: Fix checking for supported events on older kernelsVince Weaver
"perf list" listing of hardware events doesn't work on older ARM devices. The change enabling event detection: commit b41f1cec91c37eeea6fdb15effbfa24ea0a5536b Author: Namhyung Kim <namhyung.kim@lge.com> Date: Tue Aug 27 11:41:53 2013 +0900 perf list: Skip unsupported events uses the following code in tools/perf/util/parse-events.c: struct perf_event_attr attr = { .type = type, .config = config, .disabled = 1, .exclude_kernel = 1, }; On ARM machines pre-dating the Cortex-A15 this doesn't work, as these machines don't support .exclude_kernel. So starting with 3.12 "perf list" does not report any hardware events at all on older machines (seen on Rasp-Pi, Pandaboard, Beagleboard, etc). This version of the patch makes changes suggested by Namhyung Kim to check for EACCESS and retry (instead of just dropping the exclude_kernel) so we can properly handle machines where /proc/sys/kernel/perf_event_paranoid is set to 2. Reported-by: Chad Paradis <chad.paradis@umit.maine.edu> Signed-off-by: Vince Weaver <vincent.weaver@maine.edu> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Chad Paradis <chad.paradis@umit.maine.edu> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1312301536150.28814@vincent-weaver-1.um.maine.edu Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf tools: Handle PERF_RECORD_HEADER_EVENT_TYPE properlyJiri Olsa
We removed event types from data file in following commits: 6065210 perf tools: Remove event types framework completely 44b3c57 perf tools: Remove event types from perf data file We no longer need this information, because we can get it directly from tracepoints. But we still need to handle PERF_RECORD_HEADER_EVENT_TYPE event for the sake of old perf data files created in pipe mode like: $ perf.3.4 record -o - foo >perf.data $ perf.312 report -i - < perf.data Reported-by: Stephane Eranian <eranian@google.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1391524668-12546-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf probe: Do not add offset twice to uprobe addressMasami Hiramatsu
Fix perf-probe not to add offset value twice to uprobe probe address when post processing. The tevs[i].point.address struct member is the address of symbol+offset, but current perf-probe adjusts the point.address by adding the offset. As a result, the probe address becomes symbol+offset+offset. This may cause unexpected code corruption. Urgent fix is needed. Without this fix: --- # ./perf probe -x ./perf dso__load_vmlinux+4 # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d2b8) # nm ./perf.orig | grep dso__load_vmlinux\$ 000000000046d0a0 T dso__load_vmlinux --- You can see the given offset is 3 but the actual probed address is dso__load_vmlinux+8. With this fix: --- # ./perf probe -x ./perf dso__load_vmlinux+4 # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d2b4) --- Now the problem is fixed. Note: This bug is introduced by commit fb7345bbf7fad9bf72ef63a19c707970b9685812 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140205051858.6519.27314.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-09Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Tooling fixes, mostly related to the KASLR fallout, but also other fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf buildid-cache: Check relocation when checking for existing kcore perf tools: Adjust kallsyms for relocated kernel perf tests: No need to set up ref_reloc_sym perf symbols: Prevent the use of kcore if the kernel has moved perf record: Get ref_reloc_sym from kernel map perf machine: Set up ref_reloc_sym in machine__create_kernel_maps() perf machine: Add machine__get_kallsyms_filename() perf tools: Add kallsyms__get_function_start() perf symbols: Fix symbol annotation for relocated kernel perf tools: Fix include for non x86 architectures perf tools: Fix AAAAARGH64 memory barriers perf tools: Demangle kernel and kernel module symbols too perf/doc: Remove mention of non-existent set_perf_event_pending() from design.txt
2014-02-02Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull turbostat updates from Len Brown. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: introduce -s to dump counters tools/power turbostat: remove unused command line option turbostat: Add option to report joules consumed per sample turbostat: run on HSX turbostat: Add a .gitignore to ignore the compiled turbostat binary turbostat: Clean up error handling; disambiguate error messages; use err and errx turbostat: Factor out common function to open file and exit on failure turbostat: Add a helper to parse a single int out of a file turbostat: Check return value of fscanf turbostat: Use GCC's CPUID functions to support PIC turbostat: Don't attempt to printf an off_t with %zx turbostat: Don't put unprocessed uapi headers in the include path
2014-02-01tools/power turbostat: introduce -s to dump countersAndy Shevchenko
The new option allows just run turbostat and get dump of counter values. It's useful when we have something more than one program to test. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2014-02-01tools/power turbostat: remove unused command line optionAndy Shevchenko
The -s is not used, let's remove it, and update quick help accordingly. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2014-01-31perf buildid-cache: Check relocation when checking for existing kcoreAdrian Hunter
perf buildid-cache does not make another copy of kcore if the buildid and modules match an existing copy. That does not take into account the possibility that the kernel has been relocated. Extend the check to check if the reference relocation symbol matches too, otherwise do make a copy. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-10-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tools: Adjust kallsyms for relocated kernelAdrian Hunter
If the kernel is relocated at boot time, kallsyms will not match data recorded previously. That does not matter for modules because they are corrected anyway. It also does not matter if vmlinux is being used for symbols. But if perf tools has only kallsyms then the symbols will not match. Fix by applying the delta gained by comparing the old and current addresses of the relocation reference symbol. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-9-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tests: No need to set up ref_reloc_symAdrian Hunter
Now that ref_reloc_sym is set up by machine__create_kernel_maps(), the "vmlinux symtab matches kallsyms" test does have to do it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-8-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf symbols: Prevent the use of kcore if the kernel has movedAdrian Hunter
Use of kcore is predicated upon it matching the recorded data. If the kernel has been relocated at boot time (i.e. since the data was recorded) then do not use kcore. Note that it is possible to make a copy of kcore at the time the data is recorded using 'perf buildid-cache'. Then the perf tools will use the copy because it does match the data. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-7-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf record: Get ref_reloc_sym from kernel mapAdrian Hunter
Now that ref_reloc_sym is set up when the kernel map is created, 'perf record' does not need to pass the symbol names to perf_event__synthesize_kernel_mmap() which can read the values needed from ref_reloc_sym directly. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-6-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf machine: Set up ref_reloc_sym in machine__create_kernel_maps()Adrian Hunter
The ref_reloc_sym is always needed for the kernel map in order to check for relocation. Consequently set it up when the kernel map is created. Otherwise it was only being set up by 'perf record'. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-5-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf machine: Add machine__get_kallsyms_filename()Adrian Hunter
Separate out the logic used to make the kallsyms full path name for a machine. It will be reused in a subsequent patch. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-4-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tools: Add kallsyms__get_function_start()Adrian Hunter
Separate out the logic used to find the start address of the reference symbol used to track kernel relocation. kallsyms__get_function_start() is used in subsequent patches. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf symbols: Fix symbol annotation for relocated kernelAdrian Hunter
Kernel maps map memory addresses to file offsets. For symbol annotation, objdump needs the object VMA addresses. For an unrelocated kernel, that is the same as the memory address. The addresses passed to objdump for symbol annotation did not take into account kernel relocation. This patch fixes that. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1391004884-10334-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-31perf tools: Fix include for non x86 architecturesFrancesco Fusco
Commit 71ae8aac ("lib: introduce arch optimized hash library") added an include to <linux/hash.h> for setting up an architecture specific fast hash. Since perf includes directly the non-uapi kernel header, it cannot find <asm/hash.h> on non-x86 and thus prevents perf to be compiled on every architecture other than x86. The problem is the inclusion of <asm/hash.h> in hash.h that results in the following error originating from util/evlist.c: fatal error: asm/hash.h: No such file or directory This commit simply adds an empty <asm/hash.h> stub/file to fix the compile issue on non-x86 architectures. As perf does not use any of these new functions, it fixes the compilation and therefore seems to be the most appropriate solution to go with. Signed-off-by: Francesco Fusco <ffusco@redhat.com> Link: http://lkml.kernel.org/r/2cf8143aad65a6aa6fe30325ef8a65847141afa2.1390829373.git.ffusco@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-29perf tools: Fix AAAAARGH64 memory barriersPeter Zijlstra
Someone got the load and store barriers mixed up for AAAAARGH64. Turn them the right side up. Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Fixes: a94d342b9cb0 ("tools/perf: Add required memory barriers") Cc: Ingo Molnar <mingo@kernel.org> Cc: Will Deacon <will.deacon@arm.com> Link: http://lkml.kernel.org/r/20140124154002.GF31570@twins.programming.kicks-ass.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-27perf tools: Demangle kernel and kernel module symbols tooAvi Kivity
Some kernels contain C++ code, and thus their symbols need to be demangled. This allows 'perf kvm top' to generate readable output. Signed-off-by: Avi Kivity <avi@cloudius-systems.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/26f71bf5bf7ee1408e3f1a803556d5df18223ef1.1390420726.git.avi@cloudius-systems.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-26perf/doc: Remove mention of non-existent set_perf_event_pending() from ↵Baruch Siach
design.txt set_perf_event_pending() was removed in e360adbe ("irq_work: Add generic hardirq context callbacks"). Signed-off-by: Baruch Siach <baruch@tkos.co.il> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/4c54761865d40210be0628cb84701afc5d57b5d8.1390686193.git.baruch@tkos.co.il Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-25Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "A handful of tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf symbols: Load map before using map->map_ip() perf tools: Fix traceevent plugin path definitions perf symbols: Fix JIT symbol resolution on heap perf stat: Fix memory corruption of xyarray when cpumask is used perf evsel: Remove duplicate member zeroing after free perf tools: Ensure sscanf does not overrun the "mem" field perf stat: fix NULL pointer reference bug with event unit perf tools: Add support for the xtensa architecture perf session: Free cpu_map in perf_session__cpu_bitmap perf timechart: Fix wrong SVG height
2014-01-24Merge tag 'pm+acpi-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "As far as the number of commits goes, the top spot belongs to ACPI this time with cpufreq in the second position and a handful of PM core, PNP and cpuidle updates. They are fixes and cleanups mostly, as usual, with a couple of new features in the mix. The most visible change is probably that we will create struct acpi_device objects (visible in sysfs) for all devices represented in the ACPI tables regardless of their status and there will be a new sysfs attribute under those objects allowing user space to check that status via _STA. Consequently, ACPI device eject or generally hot-removal will not delete those objects, unless the table containing the corresponding namespace nodes is unloaded, which is extremely rare. Also ACPI container hotplug will be handled quite a bit differently and cpufreq will support CPU boost ("turbo") generically and not only in the acpi-cpufreq driver. Specifics: - ACPI core changes to make it create a struct acpi_device object for every device represented in the ACPI tables during all namespace scans regardless of the current status of that device. In accordance with this, ACPI hotplug operations will not delete those objects, unless the underlying ACPI tables go away. - On top of the above, new sysfs attribute for ACPI device objects allowing user space to check device status by triggering the execution of _STA for its ACPI object. From Srinivas Pandruvada. - ACPI core hotplug changes reducing code duplication, integrating the PCI root hotplug with the core and reworking container hotplug. - ACPI core simplifications making it use ACPI_COMPANION() in the code "glueing" ACPI device objects to "physical" devices. - ACPICA update to upstream version 20131218. This adds support for the DBG2 and PCCT tables to ACPICA, fixes some bugs and improves debug facilities. From Bob Moore, Lv Zheng and Betty Dall. - Init code change to carry out the early ACPI initialization earlier. That should allow us to use ACPI during the timekeeping initialization and possibly to simplify the EFI initialization too. From Chun-Yi Lee. - Clenups of the inclusions of ACPI headers in many places all over from Lv Zheng and Rashika Kheria (work in progress). - New helper for ACPI _DSM execution and rework of the code in drivers that uses _DSM to execute it via the new helper. From Jiang Liu. - New Win8 OSI blacklist entries from Takashi Iwai. - Assorted ACPI fixes and cleanups from Al Stone, Emil Goode, Hanjun Guo, Lan Tianyu, Masanari Iida, Oliver Neukum, Prarit Bhargava, Rashika Kheria, Tang Chen, Zhang Rui. - intel_pstate driver updates, including proper Baytrail support, from Dirk Brandewie and intel_pstate documentation from Ramkumar Ramachandra. - Generic CPU boost ("turbo") support for cpufreq from Lukasz Majewski. - powernow-k6 cpufreq driver fixes from Mikulas Patocka. - cpufreq core fixes and cleanups from Viresh Kumar, Jane Li, Mark Brown. - Assorted cpufreq drivers fixes and cleanups from Anson Huang, John Tobias, Paul Bolle, Paul Walmsley, Sachin Kamat, Shawn Guo, Viresh Kumar. - cpuidle cleanups from Bartlomiej Zolnierkiewicz. - Support for hibernation APM events from Bin Shi. - Hibernation fix to avoid bringing up nonboot CPUs with ACPI EC disabled during thaw transitions from Bjørn Mork. - PM core fixes and cleanups from Ben Dooks, Leonardo Potenza, Ulf Hansson. - PNP subsystem fixes and cleanups from Dmitry Torokhov, Levente Kurusa, Rashika Kheria. - New tool for profiling system suspend from Todd E Brandt and a cpupower tool cleanup from One Thousand Gnomes" * tag 'pm+acpi-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (153 commits) thermal: exynos: boost: Automatic enable/disable of BOOST feature (at Exynos4412) cpufreq: exynos4x12: Change L0 driver data to CPUFREQ_BOOST_FREQ Documentation: cpufreq / boost: Update BOOST documentation cpufreq: exynos: Extend Exynos cpufreq driver to support boost cpufreq / boost: Kconfig: Support for software-managed BOOST acpi-cpufreq: Adjust the code to use the common boost attribute cpufreq: Add boost frequency support in core intel_pstate: Add trace point to report internal state. cpufreq: introduce cpufreq_generic_get() routine ARM: SA1100: Create dummy clk_get_rate() to avoid build failures cpufreq: stats: create sysfs entries when cpufreq_stats is a module cpufreq: stats: free table and remove sysfs entry in a single routine cpufreq: stats: remove hotplug notifiers cpufreq: stats: handle cpufreq_unregister_driver() and suspend/resume properly cpufreq: speedstep: remove unused speedstep_get_state platform: introduce OF style 'modalias' support for platform bus PM / tools: new tool for suspend/resume performance optimization ACPI: fix module autoloading for ACPI enumerated devices ACPI: add module autoloading support for ACPI enumerated devices ACPI: fix create_modalias() return value handling ...
2014-01-23test: check copy_to/from_user boundary validationKees Cook
To help avoid an architecture failing to correctly check kernel/user boundaries when handling copy_to_user, copy_from_user, put_user, or get_user, perform some simple tests and fail to load if any of them behave unexpectedly. Specifically, this is to make sure there is a way to notice if things like what was fixed in commit 8404663f81d2 ("ARM: 7527/1: uaccess: explicitly check __user pointer when !CPU_USE_DOMAINS") ever regresses again, for any architecture. Additionally, adds new "user" selftest target, which loads this module. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23perf symbols: Load map before using map->map_ip()Masami Hiramatsu
In map_groups__find_symbol() map->map_ip is used without ensuring the map is loaded. Then the address passed to map->map_ip isn't mapped at the first time. E.g. below code always fails to get a symbol at the first call; addr = /* Somewhere in the kernel text */ symbol_conf.try_vmlinux_path = true; symbol__init(); host_machine = machine__new_host(); sym = machine__find_kernel_function(host_machine, addr, NULL, NULL); /* Note that machine__find_kernel_function calls map_groups__find_symbol */ This ensures it by calling map__load before using it in map_groups__find_symbol(). Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: "Steven Rostedt (Red Hat)" <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140123022950.7206.17357.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-23perf tools: Fix traceevent plugin path definitionsJosh Boyer
The plugindir_SQ definition contains $(prefix) which is not needed as the $(libdir) definition already contains prefix in it. This leads to the path including an extra prefix in it, e.g. /usr/usr/lib64. The -DPLUGIN_DIR defintion includes DESTDIR. This is incorrect, as it sets the plugin search path to include the value of DESTDIR. DESTDIR is a mechanism to install in a non-standard location such as a chroot or an RPM build root. In the RPM case, this leads to the search path being incorrect after the resulting RPM is installed (or in some cases an RPM build failure). Remove both of these unnecessary inclusions. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20140122150147.GK16455@hansolo.jdub.homelinux.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-23Merge tag 'perf-core-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf tooling fixes and updates from Arnaldo Carvalho de Melo: * Fix JIT symbol resolution on heap (Namhyung Kim) * Fix wrong SVG height in 'timechart' (Stanislav Fomichev) * Free temp cpu_map in perf_session__cpu_bitmap (Stanislav Fomichev) * Fix NULL pointer reference bug with event unit in 'stat' (Stephane Eranian) * Fix memory corruption of xyarray when cpumask is used (Stephane Eranian) * Ensure sscanf does not overrun the "mem" field (Alan Cox) * Add support for the xtensa architecture (Baruch Siach) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-21perf symbols: Fix JIT symbol resolution on heapNamhyung Kim
Gaurav reported that perf cannot profile JIT program if it executes the code on heap. This was because current map__new() only handle JIT on anon mappings - extends it to handle no_dso (heap, stack) case too. This patch assumes JIT profiling only provides dynamic function symbols so check the mapping type to distinguish the case. It'd provide no symbols for data mapping - if we need to support symbols on data mappings later it should be changed. Reported-by: Gaurav Jain <gjain@fb.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Gaurav Jain <gjain@fb.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Gaurav Jain <gjain@fb.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1389836971-3549-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-20Merge tag 'char-misc-3.14-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver patches from Greg KH: "Here's the big char/misc driver patches for 3.14-rc1. Lots of little things, and a new "big" driver, genwqe. Full details are in the shortlog" * tag 'char-misc-3.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (90 commits) mei: limit the number of consecutive resets mei: revamp mei reset state machine drivers/char: don't use module_init in non-modular ttyprintk.c VMCI: fix error handling path when registering guest driver extcon: gpio: Add power resume support Documentation: HOWTO: Updates on subsystem trees, patchwork, -next (vs. -mm) in ko_KR Documentation: HOWTO: update for 2.6.x -> 3.x versioning in ko_KR Documentation: HOWTO: update stable address in ko_KR Documentation: HOWTO: update LXR web link in ko_KR char: nwbutton: open-code interruptible_sleep_on mei: fix syntax in comments and debug output mei: nfc: mei_nfc_free has to be called under lock mei: use hbm idle state to prevent spurious resets mei: do not run reset flow from the interrupt thread misc: genwqe: fix return value check in genwqe_device_create() GenWQE: Fix warnings for sparc GenWQE: Fix compile problems for Alpha Documentation/misc-devices/mei/mei-amt-version.c: remove unneeded call of mei_deinit() GenWQE: Rework return code for flash-update ioctl sgi-xp: open-code interruptible_sleep_on_timeout ...
2014-01-20perf stat: Fix memory corruption of xyarray when cpumask is usedStephane Eranian
This patch fixes a memory corruption problem with the xyarray when the evsel fds get closed at the end of the run_perf_stat() call. It could be triggered with: # perf stat -a -e power/energy-cores/ ls When cpumask are used by events (.e.g, RAPL or uncores) then the evsel fds are allocated based on the actual number of CPUs monitored. That number can be smaller than the total number of CPUs on the system. The problem arises at the end by perf stat closes the fds twice. When fds are closed, their entry in the xyarray are set to -1. The first close() on the evsel is made from __run_perf_stat() and it uses the actual number of CPUS for the event which is how the xyarray was allocated for. The second is from perf_evlist_close() but that one is on the total number of CPUs in the system, so it assume the xyarray was allocated to cover it. However it was not, and some writes corrupt memory. The fix is in perf_evlist_close() is to first try with the evsel->cpus if present, if not use the evlist->cpus. That fixes the problem. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1389972846-6566-3-git-send-email-eranian@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-20perf evsel: Remove duplicate member zeroing after freeStephane Eranian
No need to set evsel->fd to NULL after calling perf_evsel__free_fd(), as this method already does that. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-wu6kul8fpapr8iyqm685ewtf@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-20perf tools: Ensure sscanf does not overrun the "mem" fieldAlan Cox
Make the parsing robust. (perf has some other assumptions that BUFSIZE <= MAX_PATH which are not touched here) Reported-by: Jackie Chang Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-g2uoiwbrpiimb63rx32qv8ne@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-20perf stat: fix NULL pointer reference bug with event unitStephane Eranian
This patch fixes a problem with the handling of the newly introduced optional event unit. The following cmdline caused a segfault: $ perf stat -e cpu/event-0x3c/ ls This patch fixes the problem with the default setting for alias->unit which was eventually causing the segfault. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1389972846-6566-2-git-send-email-eranian@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-20perf tools: Add support for the xtensa architectureBaruch Siach
Tested using kernel tracepoints on a QEMU simulated environment. Kernel support for perf depends on the patch "xtensa: enable HAVE_PERF_EVENTS", which is scheduled for v3.14. Hardware performance counters are not supported under xtensa yet. Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-xtensa@linux-xtensa.org Link: http://lkml.kernel.org/r/aafcdb22f04e2d3188d2938528939481be56b649.1389608855.git.baruch@tkos.co.il Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
