commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream.
Need to check for /dev/zero.
Most likely more strings are missing too.
Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Vinson Lee <vlee@freedesktop.org>
commit d0528b5d71faf612014dd7672e44225c915344b2 upstream.
Judging anonymous memory's vm_area_struct, perf_mmap_event's filename
will be set to "//anon" indicating this vma belongs to anonymous
memory.
Once hugepage is used, vma's vm_file points to hugetlbfs. In this way,
this vma will not be regarded as anonymous memory by is_anon_memory() in
perf user space utility.
Signed-off-by: Joshua Zhu <zhu.wen-jie@hp.com>
Cc: Akihiro Nagai <akihiro.nagai.hw@hitachi.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Joshua Zhu <zhu.wen-jie@hp.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1357363797-3550-1-git-send-email-zhu.wen-jie@hp.com
This reverts commit 2431496fbdd142ccc83138d94f3f510a36ce9270 as it was
applied incorrectly twice.
Thanks to Jiri for pointing this out.
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Andrew Vagin <avagin@openvz.org>
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream.
The correct syntax for gcc -x is "gcc -x assembler", not
"gcc -xassembler". Even though the latter happens to work, the former
is what is documented in the manual page and thus what gcc wrappers
such as icecream do expect.
This isn't a cosmetic change. The missing space prevents icecream from
recognizing compilation tasks it can't handle, leading to silent kernel
miscompilations.
Besides me, credits go to Michael Matz and Dirk Mueller for
investigating the miscompilation issue and tracking it down to this
incorrect -x parameter syntax.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Bernhard Walle <bernhard@bwalle.de>
Cc: Michal Marek <mmarek@suse.cz>
commit eb9c5836384cd2a276254df6254ed71117983626 upstream.
The out functions should only handle actual available data instead of the complete buffer.
Otherwise for example the ep0_consume function will report ghost events since it tries to decode
the complete buffer - which may contain partly invalid data.
Signed-off-by: Matthias Fend <matthias.fend@wolfvision.net>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
[Patch not needed upstream as this is a backport build bugfix - gregkh
gcc correctly complains:
util/hist.c: In function ‘__hists__add_entry’:
util/hist.c:240:27: error: invalid type argument of ‘->’ (have ‘struct hist_entry’)
util/hist.c:241:23: error: invalid type argument of ‘->’ (have ‘struct hist_entry’)
for this new code:
+ if (he->ms.map != entry->ms.map) {
+ he->ms.map = entry->ms.map;
+ if (he->ms.map)
+ he->ms.map->referenced = true;
because "entry" is a "struct hist_entry", not a pointer to a struct.
In mainline, "entry" is a pointer to struct passed as argument to the function.
So this is broken during backporting. But obviously not compile tested.
Signed-off-by: Zeev Tarantov <zeev.tarantov@gmail.com>
Cc: Signed-off-by: David S. Miller <davem@davemloft.net>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 63fa471dd49e9c9ce029d910d1024330d9b1b145 upstream.
When a process exec()'s, all the maps are retired, but we keep the hist
entries around which hold references to those outdated maps.
If the same library gets mapped in for which we have hist entries, a new
map will be created. But when we take a perf entry hit within that map,
we'll find the existing hist entry with the older map.
This causes symbol translations to be done incorrectly. For example,
the perf entry processing will lookup the correct uptodate map entry and
use that to calculate the symbol and DSO relative address. But later
when we update the histogram we'll translate the address using the
outdated map file instead leading to conditions such as out-of-range
offsets in symbol__inc_addr_samples().
Therefore, update the map of the hist_entry dynamically at lookup/
creation time.
Link: http://lkml.kernel.org/r/20120327.031418.1220315351537060808.davem@davemloft.net
commit b832796caa1fda8516464a003c8c7cc547bc20c2 upstream.
I have a workload where perf top scribbles over the stack and we SEGV.
What makes it interesting is that an snprintf is causing this.
The workload is a c++ gem that has method names over 3000 characters
long, but snprintf is designed to avoid overrunning buffers. So what
went wrong?
The problem is we assume snprintf returns the number of characters
written:
ret += repsep_snprintf(bf + ret, size - ret, "[%c] ", self->level);
ret += repsep_snprintf(bf + ret, size - ret, "%s", self->ms.sym->name);
Unfortunately this is not how snprintf works. snprintf returns the
number of characters that would have been written if there was enough
space. In the above case, if the first snprintf returns a value larger
than size, we pass a negative size into the second snprintf and happily
scribble over the stack. If you have 3000 character c++ methods thats a
lot of stack to trample.
This patch fixes repsep_snprintf by clamping the value at size - 1 which
is the maximum snprintf can write before adding the NULL terminator.
I get the sinking feeling that there are a lot of other uses of snprintf
that have this same bug, we should audit them all.
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com>
Link: http://lkml.kernel.org/r/20120307114249.44275ca3@kryten
commit 7a0153ee15575a4d07b5da8c96b79e0b0fd41a12 upstream.
By adding following objects:
bench/mem-memcpy-x86-64-asm.o
the x86_64 perf binary ended up with executable stack.
The reason was that above object are assembler sourced and is missing the
GNU-stack note section. In such case the linker assumes that the final binary
should not be restricted at all and mark the stack as RWX.
Adding section ".note.GNU-stack" definition to mentioned object, with all
flags disabled, thus omiting this object from linker stack flags decision.
Problem introduced in:
$ git describe ea7872b
v2.6.37-rc2-19-gea7872b
Reported-at: https://bugzilla.redhat.com/show_bug.cgi?id=783570
Reported-by: Clark Williams <williams@redhat.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1328100848-5630-1-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
[ committer note: Backported fix to perf/urgent (3.3-rc2+) ]
commit a4a03fc7ef89020baca4f19174e6a43767c6d78a upstream.
This patch fixes an issue where perf report shows nan% for certain
perf.data files. The below is from a report for a do_fork probe:
-nan% sshd [kernel.kallsyms] [k] do_fork
-nan% packagekitd [kernel.kallsyms] [k] do_fork
-nan% dbus-daemon [kernel.kallsyms] [k] do_fork
-nan% bash [kernel.kallsyms] [k] do_fork
A git bisect shows commit f3bda2c as the cause. However, looking back
through the git history, I saw commit 640c03c which seems to have
removed the required initialization for perf_sample->period. The problem
only started showing after commit f3bda2c. The below patch re-introduces
the initialization and it fixes the problem for me.
With the below patch, for the same perf.data:
73.08% bash [kernel.kallsyms] [k] do_fork
8.97% 11-dhclient [kernel.kallsyms] [k] do_fork
6.41% sshd [kernel.kallsyms] [k] do_fork
3.85% 20-chrony [kernel.kallsyms] [k] do_fork
2.56% sendmail [kernel.kallsyms] [k] do_fork
This patch applies over current linux-tip commit 9949284.
$ git describe 640c03c
v2.6.37-rc3-83-g640c03c
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20120203170113.5190.25558.stgit@localhost6.localdomain6
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit 49908a1b25d448d68fd26faca260e1850201575f upstream.
A update is made to the sched:sched_switch event that adds some
logic to the first parameter of the __print_flags() that shows the
state of tasks. This change cause perf to fail parsing the flags.
A simple fix is needed to have the parser be able to process ops
within the argument.
Reported-by: Andrew Vagin <avagin@openvz.org>
commit d06c27b22aa66e48e32f03f9387328a9af9b0625 upstream.
commit 44a56040a0037a845d5fa218dffde464579f0cab upstream.
Fix perf probe to show correct error string when it
fails to delete an event. The write(2) returns -1
if failed, and errno stores real error number.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20111004104504.14591.41266.stgit@fedora15
commit adb091846318f86e4f46c7d6a7b40d2f478abdbe upstream.
64bit PowerPC debuginfo files have an empty function descriptor section.
I hit a SEGV when perf tried to use this section for symbol resolution.
To fix this we need to check the section is valid and we can do this by
checking for type SHT_PROGBITS.
Cc: <stable@kernel.org>
Link: http://lkml.kernel.org/r/20110824065242.895239970@samba.org
commit aba8d056078e47350d85b06a9cabd5afcc4b72ea upstream.
In addition to /etc/perfconfig and $HOME/.perfconfig, perf looks for
configuration in the file ./config, imitating git which looks at
$GIT_DIR/config. If ./config is not a perf configuration file, it
fails, or worse, treats it as a configuration file and changes behavior
in some unexpected way.
"config" is not an unusual name for a file to be lying around and perf
does not have a private directory dedicated for its own use, so let's
just stop looking for configuration in the cwd. Callers needing
context-sensitive configuration can use the PERF_CONFIG environment
variable.
Requested-by: Christian Ohm <chr.ohm@gmx.net>
Cc: 632923@bugs.debian.org
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Christian Ohm <chr.ohm@gmx.net>
Link: http://lkml.kernel.org/r/20110805165838.GA7237@elie.gateway.2wire.net
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit eda3913bb70ecebac13adccffe1e7f96e93cee02 upstream.
The perf_event_attr struct has two __u32's at the top and
they need to be swapped individually.
With this change I was able to analyze a perf.data collected in a
32-bit PPC VM on an x86 system. I tested both 32-bit and 64-bit
binaries for the Intel analysis side; both read the PPC perf.data
file correctly.
-v2:
- changed the existing perf_event__attr_swap() to swap only elements
of perf_event_attr and exported it for use in swapping the
attributes in the file header
- updated swap_ops used for processing events
Signed-off-by: David Ahern <dsahern@gmail.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: acme@ghostprotocols.net
Cc: peterz@infradead.org
Cc: paulus@samba.org
Link: http://lkml.kernel.org/r/1310754849-12474-1-git-send-email-dsahern@gmail.com
commit 08a4a43fc407d780bdde36d98f89c0dbb2a6be6b upstream.
Builds for 32-bit perf binaries on a 64-bit host currently fail
with this error:
bench/../../../arch/x86/lib/memcpy_64.S: Assembler messages:
bench/../../../arch/x86/lib/memcpy_64.S:29: Error: bad register name `%rdi'
bench/../../../arch/x86/lib/memcpy_64.S:34: Error: invalid instruction suffix for `movs'
bench/../../../arch/x86/lib/memcpy_64.S:50: Error: bad register name `%rdi'
bench/../../../arch/x86/lib/memcpy_64.S:61: Error: bad register name `%rdi'
The problem is the detection of the host arch without considering passed in
flags. This change fixes 32-bit builds via:
make EXTRA_CFLAGS=-m32
and 64-bit builds still reference the memcpy_64.S.
Link: http://lkml.kernel.org/r/1310420304-21452-1-git-send-email-dsahern@gmail.com
'timers-urgent-for-linus' and 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tools/perf: Fix static build of perf tool
tracing: Fix regression in printk_formats file
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
generic-ipi: Fix kexec boot crash by initializing call_single_queue before enabling interrupts
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: Make watchdog robust vs. interruption
timerfd: Fix wakeup of processes when timer is cancelled on clock change
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, MAINTAINERS: Add x86 MCE people
x86, efi: Do not reserve boot services regions within reserved areas
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Move RCU_BOOST #ifdefs to header file
rcu: use softirq instead of kthreads except when RCU_BOOST=y
rcu: Use softirq to address performance regression
rcu: Simplify curing of load woes
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
kbuild: Call depmod.sh via shell
perf: clear out make flags when calling kernel make kernelver
To build a statically linked version of the perf tool all needed
libraries must be added in the correct order to get the symbols
resolved. Currently this is broken when, e.g. python or newt
support is enabled -- libpython needs libpthread which is an
unconditional link dependency of the perf tool; libslang needs
libm, another unconditional dependency. To solve the problem in
the long run without the need to keep track of transitive
library dependencies, simply make the linker look at the EXTLIBS
multiple times until it has all symbols resolved.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/1308171818-20370-1-git-send-email-minipli@googlemail.com
When generating the perf version from the kernel version using 'make
kernelver' it is necessary to clear out any MAKEFLAGS otherwise they may
trigger additional output which pollute the contents.
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Commit a26ac2455ffcf3(rcu: move TREE_RCU from softirq to kthread)
introduced performance regression. In an AIM7 test, this commit degraded
performance by about 40%.
The commit runs rcu callbacks in a kthread instead of softirq. We observed
high rate of context switch which is caused by this. Out test system has
64 CPUs and HZ is 1000, so we saw more than 64k context switch per second
which is caused by RCU's per-CPU kthread. A trace showed that most of
the time the RCU per-CPU kthread doesn't actually handle any callbacks,
but instead just does a very small amount of work handling grace periods.
This means that RCU's per-CPU kthreads are making the scheduler do quite
a bit of work in order to allow a very small amount of RCU-related
processing to be done.
Alex Shi's analysis determined that this slowdown is due to lock
contention within the scheduler. Unfortunately, as Peter Zijlstra points
out, the scheduler's real-time semantics require global action, which
means that this contention is inherent in real-time scheduling. (Yes,
perhaps someone will come up with a workaround -- otherwise, -rt is not
going to do well on large SMP systems -- but this patch will work around
this issue in the meantime. And "the meantime" might well be forever.)
This patch therefore re-introduces softirq processing to RCU, but only
for core RCU work. RCU callbacks are still executed in kthread context,
so that only a small amount of RCU work runs in softirq context in the
common case. This should minimize ksoftirqd execution, allowing us to
skip boosting of ksoftirqd for CONFIG_RCU_BOOST=y kernels.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: "Alex,Shi" <alex.shi@intel.com>
perf: Use make kernelversion instead of parsing the Makefile
kbuild: Hack for depmod not handling X.Y versions
kbuild: Move depmod call to a separate script
kbuild: Fix <linux/version.h> for empty SUBLEVEL or PATCHLEVEL
kbuild: Fix KERNELVERSION for empty SUBLEVEL or PATCHLEVEL
kbuild: silence Nothing to be done for 'all' message
perf: Fix comments in include/linux/perf_event.h
perf: Comment /proc/sys/kernel/perf_event_paranoid to be part of user ABI
perf python: Fix argument name list of read_on_cpu()
perf evlist: Don't die if sample_{id_all|type} is invalid
perf python: Use exception to propagate errors
perf evlist: Remove dependency on debug routines
perf, cgroups: Fix up for new API
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest:
ktest: Ignore unset values of the minconfig in config_bisect
ktest: Fix result of rebooting the kernel
ktest: Fix off-by-one in config bisect result
Mandatory arguments need to be present in the argument name list, as
well as optional arguments, otherwise python barfs:
# ./python/twatch.py
Traceback (most recent call last):
File "./python/twatch.py", line 41, in <module>
main()
File "./python/twatch.py", line 32, in main
event = evlist.read_on_cpu(cpu)
RuntimeError: more argument specifiers than keyword list entries
Hence, add cpu to the name list.
Cc: David Ahern <daahern@cisco.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Link: http://lkml.kernel.org/r/1301588863-20210-1-git-send-email-fweisbec@gmail.com
Fixes two more cases where the python binding would not load:
. Not finding die(), which it shouldn't anyway, not good to just stop the
world because some particular perf.data file is invalid, just propagate
the error to the caller.
. Not finding perf_sample_size: fix it by moving it from event.c to evsel,
where it belongs, as most cases are moving to operate on an evsel object.o
One of the fixed problems:
[root@emilia ~]# python
>>> import perf
File "<stdin>", line 1, in <module>
ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: perf_sample_size
[root@emilia ~]#
Link: http://lkml.kernel.org/n/tip-1hkj7b2cvgbfnoizsekjb6c9@git.kernel.org
We were using pr_debug to tell the user about not being able to parse a sample
where we should really use the python way of reporting errors: exceptions.
Fixes this problem:
>>> import perf
ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: eprintf
[root@emilia ~]
As we want to keep the objects linked in the python binding (and in the future
in a shared library) minimal.
Link: http://lkml.kernel.org/n/tip-m9dba9kaluas0kq8r58z191c@git.kernel.org
So far we avoided having to link debug.o in the python binding, keep it
that way by not using ui__warning() in evlist.c.
Link: http://lkml.kernel.org/n/tip-4wtew8hd3g7ejnlehtspys2t@git.kernel.org
By ignoring the unset values of the minconfig in deciding
what to test in the config_bisect can cause the problem
config from being tested too.
Just do not test the configs that are set in the minconfig.
The command that is called that reboots the kernel may fail
but the return code is not passed back to the ktest.pl script.
This is because a ';' is used between the two commands and
if the second command fails, only the first command's return
code is returned. Using a '&&' between the two commands fixes
this.
Because in perl the array size returned by $#arr, is the last
index and not the actually size of the array, we end the config
bisect early, thinking there is only one config left when there
are in fact two. Thus the result has a 50% chance of picking
the correct config that caused the problem.
Add ability to test the new event idx feature,
enable by default.
We now just warn the user about the fact and go on providing just
userspace samples.
This fixes a problem when no vmlinux is explicetely passed by the user,
thus symbol_conf.vmlinux_name is NULL, no suitable vmlinux is found, and
then we get:
aldebaran:~> perf top -p 7557
[kernel.kallsyms] with build id 44d9a989eabbd79e486bc079d6b743d397c204e0
not found, continuing without symbols
The (null) file can't be used
Reported-by: Ingo Molnar <mingo@elte.hu>
Link: http://lkml.kernel.org/n/tip-cj2g81hn64wv2bipmqk4fy2m@git.kernel.org
Link: http://lkml.kernel.org/n/tip-cyl5zmi1nu35vyu7l5im2pyv@git.kernel.org
Link: http://lkml.kernel.org/n/tip-weqbs0tkk2u0qp1xxdxxosfg@git.kernel.org
perf_evsel__alloc_fd allocates an array of file descriptors with the
memory initialized to 0. The array has dimensions for cpus and threads.
Later, __perf_evsel__open calls sys_perf_event_open for each cpu and thread
dimensions. If the open fails for any of the cpus or threads then the fd's
for this event are closed and the fd entry in the array is set to -1. Now,
if the first attempt fails for the event (e.g., the event is not supported)
the remaining dimensions (cpu > 0 and thread > 0) are not touched and left
at the initialized value of 0.
builtin-stat catches ENOENT and ENOSYS failures and allows the command to
continue. The end result is that stat attempts to read from an fd of 0 which
of course is stdin and so the command hangs until you type ctrl-D.
Resolve by initializing the array to -1 since an fd < 0 is already
handled.
Link: http://lkml.kernel.org/r/1306511914-8016-1-git-send-email-dsahern@gmail.com
Suggested-by: Ingo Molnar <mingo@elte.hu>
Link: http://lkml.kernel.org/n/tip-i1p8vrhq7xveyui6t1sc914e@git.kernel.org
Where /usr/include/linux/const.h is not present, e.g. RHEL5.
Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/n/tip-ypcw2mu0w7dl1rrc6ncz3pee@git.kernel.org
Perf uses /proc/modules to figure out where kernel modules are loaded.
With the advent of kptr_restrict, non root users get zeroes for all module
start addresses.
So check if kptr_restrict is non zero and don't generate the syntethic
PERF_RECORD_MMAP events for them.
Warn the user about it in perf record and in perf report.
In perf report the reference relocation symbol being zero means that
kptr_restrict was set, thus /proc/kallsyms has only zeroed addresses, so don't
use it to fixup symbol addresses when using a valid kallsyms (in the buildid
cache) or vmlinux (in the vmlinux path) build-id located automatically or
specified by the user.
Provide an explanation about it in 'perf report' if kernel samples were taken,
checking if a suitable vmlinux or kallsyms was found/specified.
Restricted /proc/kallsyms don't go to the buildid cache anymore.
Example:
[acme@emilia ~]$ perf record -F 100000 sleep 1
WARNING: Kernel address maps (/proc/{kallsyms,modules}) are restricted, check
/proc/sys/kernel/kptr_restrict.
Samples in kernel functions may not be resolved if a suitable vmlinux file is
not found in the buildid cache or in the vmlinux path.
Samples in kernel modules won't be resolved at all.
If some relocation was applied (e.g. kexec) symbols may be misresolved even
with a suitable vmlinux or kallsyms file.
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.005 MB perf.data (~231 samples) ]
[acme@emilia ~]$
[acme@emilia ~]$ perf report --stdio
Kernel address maps (/proc/{kallsyms,modules}) were restricted,
check /proc/sys/kernel/kptr_restrict before running 'perf record'.
If some relocation was applied (e.g. kexec) symbols may be misresolved.
Samples in kernel modules can't be resolved as well.
# Events: 13 cycles
# Overhead Command Shared Object Symbol
20.24% sleep [kernel.kallsyms] [k] page_fault
20.04% sleep [kernel.kallsyms] [k] filemap_fault
19.78% sleep [kernel.kallsyms] [k] __lru_cache_add
19.69% sleep ld-2.12.so [.] memcpy
14.71% sleep [kernel.kallsyms] [k] dput
4.70% sleep [kernel.kallsyms] [k] flush_signal_handlers
0.73% sleep [kernel.kallsyms] [k] perf_event_comm
0.11% sleep [kernel.kallsyms] [k] native_write_msr_safe
# (For a higher level overview, try: perf report --sort comm,dso)
[acme@emilia ~]$
This is because it found a suitable vmlinux (build-id checked) in
/lib/modules/2.6.39-rc7+/build/vmlinux (use -v in perf report to see the long
file name).
If we remove that file from the vmlinux path:
[root@emilia ~]# mv /lib/modules/2.6.39-rc7+/build/vmlinux \
/lib/modules/2.6.39-rc7+/build/vmlinux.OFF
[kernel.kallsyms] with build id 57298cdbe0131f6871667ec0eaab4804dcf6f562
Kernel address maps (/proc/{kallsyms,modules}) were restricted, check
As no suitable kallsyms nor vmlinux was found, kernel samples can't be
resolved.
# Events: 13 cycles
80.31% sleep [kernel.kallsyms] [k] 0xffffffff8103425a
[acme@emilia ~]$
Reported-by: Stephane Eranian <eranian@google.com>
Suggested-by: David Miller <davem@davemloft.net>
Cc: Dave Jones <davej@redhat.com>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Link: http://lkml.kernel.org/n/tip-mt512joaxxbhhp1odop04yit@git.kernel.org
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: trivial@kernel.org
Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1105261011290.17400@swampdragon.chaosbits.net
perf tools: Fix sample type size calculation in 32 bits archs
profile: Use vzalloc() rather than vmalloc() & memset()
The shift used here to count the number of bits set in
the mask doesn't work above the low part for archs that
are not 64 bits.
Fix the constant used for the shift.
This fixes a 32-bit perf top failure reported by Eric Dumazet:
Can't parse sample, err = -14
Reported-and-tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Link: http://lkml.kernel.org/r/1306200686-17317-1-git-send-email-fweisbec@gmail.com
perf tools: Fix sample size bit operations
perf tools: Fix ommitted mmap data update on remap
watchdog: Change the default timeout and configure nmi watchdog period based on watchdog_thresh
watchdog: Disable watchdog when thresh is zero
watchdog: Only disable/enable watchdog if neccessary
watchdog: Fix rounding bug in get_sample_period()
perf tools: Propagate event parse error handling
perf tools: Robustify dynamic sample content fetch
perf tools: Pre-check sample size before parsing
perf tools: Move evlist sample helpers to evlist area
perf tools: Remove junk code in mmap size handling
perf tools: Check we are able to read the event size on mmap
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
ktest: Allow options to be used by other options
ktest: Create variables for the ktest config files
ktest: Reboot after each patchcheck run
ktest: Reboot to good kernel after every bisect run
ktest: If test failed due to timeout, print that
ktest: Fix post install command
What we want is to count the number of bits in the mask,
not some other random operation written in the middle
of the night.
Link: http://lkml.kernel.org/r/1306148788-6179-2-git-send-email-fweisbec@gmail.com
[ Fixed perf_event__names[] alignment which was nearby and hurting my eyes ... ]
Commit eac9eacee16 "perf tools: Check we are able to read the event
size on mmap" brought a check to ensure we can read the size of the
event before dereferencing it, and do a remap otherwise to move the
buffer forward.
However that remap was ommitting all the necessary work to
update the new page offset, head, and to unmap previous pages,
etc...
To fix this, gather all the code that fetches the event in a
seperate helper which does all the necessary checks about the
header/event size and tells us anytime a remap is needed.
Link: http://lkml.kernel.org/r/1306148788-6179-3-git-send-email-fweisbec@gmail.com
