path: root/tools
2014-09-17mnt: Add tests for unprivileged remount cases that have found to be faultyEric W. Biederman
commit db181ce011e3c033328608299cd6fac06ea50130 upstream. Kenton Varda <kenton@sandstorm.io> discovered that by remounting a read-only bind mount read-only in a user namespace the MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user to the remount a read-only mount read-write. Upon review of the code in remount it was discovered that the code allowed nosuid, noexec, and nodev to be cleared. It was also discovered that the code was allowing the per mount atime flags to be changed. The first naive patch to fix these issues contained the flaw that using default atime settings when remounting a filesystem could be disallowed. To avoid this problems in the future add tests to ensure unprivileged remounts are succeeding and failing at the appropriate times. Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-07-18tools: ffs-test: fix header values endianessMichal Nazarewicz
commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream. It appears that no one ever run ffs-test on a big-endian machine, since it used cpu-endianess for fs_count and hs_count fields which should be in little-endian format. Fix by wrapping the numbers in cpu_to_le32. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2014-02-13turbostat: Use GCC's CPUID functions to support PICJosh Triplett
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream. turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems that have certain security features enabled by default that make -fPIC the default, this causes a build error: turbostat.c: In function ‘check_cpuid’: turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’ asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx"); ^ GCC provides a header cpuid.h, containing a __get_cpuid function that works with both PIC and non-PIC. (On PIC, it saves and restores ebx around the cpuid instruction.) Use that instead. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13turbostat: Don't put unprocessed uapi headers in the include pathJosh Triplett
commit b731f3119de57144e16c19fd593b8daeb637843e upstream. turbostat's Makefile puts arch/x86/include/uapi/ in the include path, so that it can include <asm/msr.h> from it. It isn't in general safe to include even uapi headers directly from the kernel tree without processing them through scripts/headers_install.sh, but asm/msr.h happens to work. However, that include path can break with some versions of system headers, by overriding some system headers with the unprocessed versions directly from the kernel source. For instance: In file included from /build/x86-generic/usr/include/bits/sigcontext.h:28:0, from /build/x86-generic/usr/include/signal.h:339, from /build/x86-generic/usr/include/sys/wait.h:31, from turbostat.c:27: ../../../../arch/x86/include/uapi/asm/sigcontext.h:4:28: fatal error: linux/compiler.h: No such file or directory This occurs because the system bits/sigcontext.h on that build system includes <asm/sigcontext.h>, and asm/sigcontext.h in the kernel source includes <linux/compiler.h>, which scripts/headers_install.sh would have filtered out. Since turbostat really only wants a single header, just include that one header rather than putting an entire directory of kernel headers on the include path. In the process, switch from msr.h to msr-index.h, since turbostat just wants the MSR numbers. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06perf kvm: Fix kvm report without guestmount.Dongsheng Yang
commit ad85ace07a05062ef6b59c35a5e80b6eaee1eee6 upstream. Currently, if we use perf kvm --guestkallsyms --guestmodules report, we can not get the perf information from perf data file. All sample are shown as unknown. Reproducing steps: # perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ] # perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep % 100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330 This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation). In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine which has the same pid, if no machine found, deliver it to *default* guest. But if we use perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built and added. Then the default guest which with pid == 0 will never get a symbol. And because the new machine initialized here has no kernel map created, the symbol delivered to it will be marked as "unknown". This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way. Verification steps: # ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ] # ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep % 22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70 19.99% :6471 [guest.kernel.kallsyms] [g] d_free 18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments 16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task 12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to 7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick 1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write 0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09cpupower: Fix segfault due to incorrect getopt_long arugmentsJosh Boyer
commit f447ef4a56dee4b68a91460bcdfe06b5011085f2 upstream. If a user calls 'cpupower set --perf-bias 15', the process will end with a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi call. This is because the getopt_long structure currently has all of the options as having an optional_argument when they really have a required argument. We change the structure to use required_argument to match the short options and it resolves the issue. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439 Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04perf tools: Synthesize anon MMAP records againDon Zickus
commit 9d4ecc8893832337daf241236841db966fa53489 upstream. When introducing the PERF_RECORD_MMAP2 in: 5c5e854bc760 perf tools: Add attr->mmap2 support A check for the number of entries parsed by sscanf was introduced that assumed all of the 8 fields needed to be correctly parsed so that particular /proc/pid/maps line would be considered synthesizable. That broke anon records synthesizing, as it doesn't have the 'execname' field. Fix it by keeping the sscanf return check, changing it to not require that the 'execname' variable be parsed, so that the preexisting logic can kick in and set it to '//anon'. This should get things like JIT profiling working again. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Bill Gray <bgray@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joe Mario <jmario@redhat.com> Cc: Richard Fowles <rfowles@redhat.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-bo4akalno7579shpz29u867j@git.kernel.org [ commit log message is mine, dzickus reported the problem with a patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04perf tools: Remove cast of non-variadic function to variadicMichael Hudson-Doyle
commit 53805eca3d89b095062c11a6798689bb0af09216 upstream. The 4fb71074a570 (perf ui/hist: Consolidate hpp helpers) cset introduced a cast of percent_color_snprintf to a function pointer type with varargs. Change percent_color_snprintf to be variadic and remove the cast. The symptom of this was all percentages being reported as 0.00% in perf report --stdio output on the armhf arch. Signed-off-by: Michael Hudson-Doyle <michael.hudson@linaro.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Link: http://lkml.kernel.org/r/87zjppvw7y.fsf@canonical.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-28perf tools: Fixup mmap event consumptionZhouyi Zhou
The tail position of the event buffer should only be modified after actually use that event. If not the event buffer could be invalid before use, and segment fault occurs when invoking perf top -G. Signed-off-by: Zhouyi Zhou <yizhouzhou@ict.ac.cn> Cc: David Ahern <dsahern@gmail.com> Cc: Zhouyi Zhou <yizhouzhou@ict.ac.cn> Link: http://lkml.kernel.org/r/1382600613-32177-1-git-send-email-zhouzhouyi@gmail.com [ Simplified the logic using exit gotos and renamed write_tail method to mmap_consume ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-28perf top: Split -G and --call-graphJiri Olsa
Splitting -G and --call-graph for record command, so we could use '-G' with no option. The '-G' option now takes NO argument and enables the configured unwind method, which is currently the frame pointers method. It will be possible to configure unwind method via config file in upcoming patches. All current '-G' arguments is overtaken by --call-graph option. NOTE: The documentation for top --call-graph option was wrongly copied from report command. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Tested-by: David Ahern <dsahern@gmail.com> Tested-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: David Ahern <dsahern@gmail.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1382797536-32303-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-28perf record: Split -g and --call-graphJiri Olsa
Splitting -g and --call-graph for record command, so we could use '-g' with no option. The '-g' option now takes NO argument and enables the configured unwind method, which is currently the frame pointers method. It will be possible to configure unwind method via config file in upcoming patches. All current '-g' arguments is overtaken by --call-graph option. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Tested-by: David Ahern <dsahern@gmail.com> Tested-by: Ingo Molnar <mingo@kernel.org> Reviewed-by: David Ahern <dsahern@gmail.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1382797536-32303-2-git-send-email-jolsa@redhat.com [ reordered -g/--call-graph on --help and expanded the man page according to comments by David Ahern and Namhyung Kim ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-28perf hists: Add color overhead for stdio output bufferJiri Olsa
Following commit tightened up the buffer size for output to strict width of used format columns: 99cf666 perf hists: Fix formatting of long symbol names This works fine until you hit color overhead output which places extra bytes into output buffer. We need to account for color overhead in the output buffer. Adding maximum color byte size to the output buffer size. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1382700293-1803-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-28perf tools: Fix up /proc/PID/maps parsingArnaldo Carvalho de Melo
When introducing support for MMAP2 we considered more parts of each map representation in /proc/PID/maps, and when disabling it we forgot to reduce the number of expected parsed/assigned entries in the sscanf call, fix it to expect the right number of desired fields, 5. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Based-on-a-patch-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-vrbo1wik997ahjzl1chm3bdm@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-24perf script python: Fix mem leak due to missing Py_DECREFs on dict entriesJoseph Schuchart
We are using the Python scripting interface in perf to extract kernel events relevant for performance analysis of HPC codes. We noticed that the "perf script" call allocates a significant amount of memory (in the order of several 100 MiB) during it's run, e.g. 125 MiB for a 25 MiB input file: $> perf record -o perf.data -a -R -g fp \ -e power:cpu_frequency -e sched:sched_switch \ -e sched:sched_migrate_task -e sched:sched_process_exit \ -e sched:sched_process_fork -e sched:sched_process_exec \ -e cycles -m 4096 --freq 4000 $> /usr/bin/time perf script -i perf.data -s dummy_script.py 0.84user 0.13system 0:01.92elapsed 51%CPU (0avgtext+0avgdata 125532maxresident)k 73072inputs+0outputs (57major+33086minor)pagefaults 0swaps Upon further investigation using the valgrind massif tool, we noticed that Python objects that are created in trace-event-python.c via PyString_FromString*() (and their Integer and Long counterparts) are never free'd. The reason for this seem to be missing Py_DECREF calls on the objects that are returned by these functions and stored in the Python dictionaries. The Python dictionaries do not steal references (as opposed to Python tuples and lists) but instead add their own reference. Hence, the reference that is returned by these object creation functions is never released and the memory is leaked. (see [1,2]) The attached patch fixes this by wrapping all relevant calls to PyDict_SetItemString() and decrementing the reference counter immediately after the Python function call. This reduces the allocated memory to a reasonable amount: $> /usr/bin/time perf script -i perf.data -s dummy_script.py 0.73user 0.05system 0:00.79elapsed 99%CPU (0avgtext+0avgdata 49132maxresident)k 0inputs+0outputs (0major+14045minor)pagefaults 0swaps For comparison, with a 120 MiB input file the memory consumption reported by time drops from almost 600 MiB to 146 MiB. The patch has been tested using Linux 3.8.2 with Python 2.7.4 and Linux 3.11.6 with Python 2.7.5. Please let me know if you need any further information. [1] http://docs.python.org/2/c-api/tuple.html#PyTuple_SetItem [2] http://docs.python.org/2/c-api/dict.html#PyDict_SetItemString Signed-off-by: Joseph Schuchart <joseph.schuchart@tu-dresden.de> Reviewed-by: Tom Zanussi <tom.zanussi@linux.intel.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tom.zanussi@linux.intel.com> Link: http://lkml.kernel.org/r/1381468543-25334-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-20Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: " * Fix build error on Fedora 12. * Fix to initialize fname always before use it, bug introduced during this merge window, from Masami Hiramatsu. * Disable PERF_RECORD_MMAP2 support, from Stephane Eranian. " Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-17perf: Disable PERF_RECORD_MMAP2 supportStephane Eranian
For now, we disable the extended MMAP record support (MMAP2). We have identified cases where it would not report the correct mapping information, clone(VM_CLONE) but with separate pids. We will revisit the support once we find a solution for this case. The patch changes the kernel to return EINVAL if attr->mmap2 is set. The patch also modifies the perf tool to use regular PERF_RECORD_MMAP for synthetic events and it also prevents the tool from requesting attr->mmap2 mode because the kernel would reject it. The support will be revisited once the kenrel interface is updated. In V2, we reduce the patch to the strict minimum. In V3, we avoid calling perf_event_open() with mmap2 set because we know it will fail and require fallback retry. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131017173215.GA8820@quad Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-17perf scripting perl: Fix build error on Fedora 12Arnaldo Carvalho de Melo
Cast __u64 to u64 to silence this warning on older distros, such as Fedora 12: CC /tmp/build/perf/util/scripting-engines/trace-event-perl.o cc1: warnings being treated as errors util/scripting-engines/trace-event-perl.c: In function ‘perl_process_tracepoint’: util/scripting-engines/trace-event-perl.c:285: error: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘__u64’ make[1]: *** [/tmp/build/perf/util/scripting-engines/trace-event-perl.o] Error 1 make: *** [install] Error 2 make: Leaving directory `/home/acme/git/linux/tools/perf' [acme@fedora12 linux]$ Reported-by: Waiman Long <Waiman.Long@hp.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tom.zanussi@linux.intel.com> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/n/tip-nlxofdqcdjfm0w9o6bgq4kqv@git.kernel.org Link: http://lkml.kernel.org/r/1381265120-58532-1-git-send-email-Waiman.Long@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-16tools/testing/selftests: fix uninitialized variableFelipe Pena
The err variable is intended to receive the timer_create() return before checking it Signed-off-by: Felipe Pena <felipensp@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-15perf probe: Fix to initialize fname always before use itMasami Hiramatsu
Fix perf probe --list to initialize fname local var always before use it. This may cause a SEGV if there is a probe which is in the function body but not in any inline function. Problem introduced in: commit e08cfd4bda76 Author: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Date: Mon Sep 30 18:21:44 2013 +0900 perf probe: Fix to find line information for probe list Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20131011122317.9662.29736.stgit@kbuild-fedora.novalocal Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-04perf session: Fix infinite loop on invalid perf.data fileNamhyung Kim
perf-record updates the header in the perf.data file at termination. Without this update perf-report (and other processing built-ins) it caused an infinite loop when perf report (or something like) called. This is because the algorithm in __perf_session__process_events() depends on the data_size which is read from file header. Use file size directly instead in this case to do the best-effort processing. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Tested-by: David Ahern <dsahern@gmail.com> Tested-by: Sonny Rao <sonnyrao@chromium.org> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sonny Rao <sonnyrao@chromium.org> Link: http://lkml.kernel.org/r/1380529188-27193-1-git-send-email-namhyung@kernel.org Signed-off-by: David Ahern <dsahern@gmail.com> [ Reworded warning as per Ingo Molnar suggestion, replaces 'perf.data' with session->filename, to precisely identify the data file involved ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-04perf tools: Fix installation of libexec componentsArnaldo Carvalho de Melo
Doing a fresh install on a user home directory needs to first make sure that the ~/libexec/perf-core/ directory is present so that 'perf-archive' like scripts, 'perf test' attr config files and 'perf script' scripts can be installed. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-z7ryi3r1b9dn9smbfnab0fdc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-04perf probe: Fix to find line information for probe listMasami Hiramatsu
Fix to find the correct (as much as possible) line information for listing probes. Without this fix, perf probe --list action will show incorrect line information as below; probe:getname_flags (on getname_flags@ksrc/linux-3/fs/namei.c) probe:getname_flags_1 (on getname:-89@x86/include/asm/current.h) probe:getname_flags_2 (on user_path_at_empty:-2054@x86/include/asm/current.h) The minus line number is obviously wrong, and current.h is not related to the probe point. Deeper investigation discovered that there were 2 issues related to this bug, and minor typos too. The 1st issue is the rack of considering about nested inlined functions, which causes the wrong (relative) line number. The 2nd issue is that the dwarf line info is not correct at those points. It points 14th line of current.h. Since it seems that the line info includes somewhat unreliable information, this fixes perf to try to find correct line information from both of debuginfo and line info as below. 1) Probe address is the entry of a function instance In this case, the line is set as the function declared line. 2) Probe address is the entry of an expanded inline function block In this case, the line is set as the function call-site line. This means that the line number is relative from the entry line of caller function (which can be an inlined function if nested) 3) Probe address is inside a function instance or an expanded inline function block In this case, perf probe queries the line number from lineinfo and verify the function declared file is same as the file name queried from lineinfo. If the file name is different, it is a failure case. The probe address is shown as symbol+offset. 4) Probe address is not in the any function instance This is a failure case, the probe address is shown as symbol+offset. With this fix, perf probe -l shows correct probe lines as below; probe:getname_flags (on getname_flags@ksrc/linux-3/fs/namei.c) probe:getname_flags_1 (on getname:2@ksrc/linux-3/fs/namei.c) probe:getname_flags_2 (on user_path_at_empty:4@ksrc/linux-3/fs/namei.c) Changes at v2: - Fix typos in the function comments. (Thanks to Namhyung Kim) - Use die_find_top_inlinefunc instead of die_find_inlinefunc_next. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20130930092144.1693.11058.stgit@udc4-manage.rcp.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-04perf tools: Fix libaudit testArnaldo Carvalho de Melo
In ubuntu systems the libaudit test was always failing due to the newline in the printf call not being escaped, which somehow didn't prevented the test from working as expected on other systems, such as fedora18. Fix it by removing the newline, as this is just a test, that program is just a compile test. The error messages, obtained using 'make V=1': CHK libaudit <stdin>: In function ‘main’: <stdin>:5:9: error: missing terminating " character [-Werror] <stdin>:5:2: error: missing terminating " character <stdin>:6:1: error: missing terminating " character [-Werror] <stdin>:6:1: error: missing terminating " character <stdin>:7:2: error: expected expression before ‘return’ <stdin>:8:1: error: expected ‘;’ before ‘}’ token cc1: all warnings being treated as errors config/Makefile:241: No libaudit.h found, disables 'trace' tool, please install audit-libs-devel or libaudit-dev After this change the test works as expected in all systems tested and the 'trace' tool is built when the needed devel packages are installed. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-0trw8qs9hafeopc0vj1sicay@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-04perf stat: Set child_pid after perf_evlist__prepare_workload()Namhyung Kim
The commit acf2892270dc ("perf stat: Use perf_evlist__prepare/ start_workload()") converted to use the function but forgot to update child_pid. Fix it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1380531671-28076-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-04perf tools: Add default handler for mmap2 eventsDavid Ahern
Commands that do not implement an mmap2 handler should at least not die with a segfault when processing files with MMAP2 events. Signed-off-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1379900700-5186-5-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-29Revert "perf symbols: Demangle cloned functions"Ingo Molnar
This reverts commit de95ab53645a2f0015e0f68ee723f18dce2b8b51. Markus Trippelsdorf reported that this commit broke 'perf top': > I just see a gray screen with no text at all. Sometimes the > following error messages are printed: > > *** Error in `perf': invalid fastbin entry (free): 0x00000000029b18c0 > *** > *** Error in `perf': malloc(): memory corruption (fast): 0x0000000000ee0b10 *** While this code is fixable, the commit itself fails on several levels: - it should have been a separate helper function - why the heck does it do strchr() twice - it casts a const char * over into char * - sloppy style - it's not even a regression fix! So lets revert it and re-try the patch in v3.13. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25perf symbols: Demangle cloned functionsAndi Kleen
The libbfd C++ demangler doesn't seem to deal with cloned functions, like symbol.clone.NUM. Just strip the dot part before demangling and add it back later. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1378998998-10802-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-25perf machine: Fix path unpopulated in machine__create_modules()Adrian Hunter
In machine__create_modules() the 'path' char array was used in a call to symbol__restricted_filename() without always being populated. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1379845338-29637-2-git-send-email-adrian.hunter@intel.com [ Split patch removing unrelated conversion of sprintf to snprintf to perf/core ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-25perf tools: Explicitly add libdl dependencyDavid Ahern
Fixes compile failure on Fedora 12. Signed-off-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1379900700-5186-3-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-25perf probe: Fix probing symbols with optimization suffixMasami Hiramatsu
Fix perf probe to probe on some symbols which have some optimzation suffixes, e.g. ".part", ".isra", and ".constprop". To fix this issue, instead of using the DIE name, perf probe uses the symbol name found by dwfl_module_addrsym(). This also involves a perf probe --vars operation update which now shows the symbol name instead of the DIE name. Without this patch, putting a probe on an inlined function which was compiled with a suffixed symbol will fail like this: $ perf probe -v getname_flags probe-definition(0): getname_flags symbol:getname_flags file:(null) line:0 offset:0 return:0 lazy:(null) 0 arguments Looking at the vmlinux_path (6 entries long) Using /lib/modules/3.11.0+/build/vmlinux for symbols found inline addr: 0xffffffff8119bb70 Probe point found: getname_flags+0 found inline addr: 0xffffffff8119bcb6 Probe point found: getname+6 found inline addr: 0xffffffff811a06a6 Probe point found: user_path_at_empty+6 find 3 probe_trace_events. Opening /sys/kernel/debug//tracing/kprobe_events write=1 Added new events: Writing event: p:probe/getname_flags getname_flags+0 Failed to write event: No such file or directory Error: Failed to add events. (-1) Because the debuginfo knows only the original (non suffix) symbol name, it uses the original symbol for probe address but the kernel (kallsyms) knows only suffixed symbol. Then, the kernel rejects that original symbol. This patch uses dwfl_module_addrsym() to get the correct (suffixed) symbol from symtab when a probe point is found. Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20130925131616.31632.46658.stgit@udc4-manage.rcp.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-24perf trace: Add mmap2 handlerDavid Ahern
5c5e854b changed perf_event__synthesize_mmap_events to generate MMAP2 events. Since perf-trace does not have a handler for it it dies with a segfault when trying to process files: perf trace -i /tmp/perf.data Segmentation fault Signed-off-by: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1379900700-5186-4-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-24perf kmem: Make it work again on non NUMA machinesJiri Olsa
The commit '2814eb0 perf kmem: Remove die() calls' disabled 'perf kmem' command for machines without numa support. It made the command fail if '/sys/devices/system/node' dir wasn't found. Skipping the numa based initialization in case the directory is not found and continue execution. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1379003976-5839-5-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-20perf: Fix capabilities bitfield compatibility in 'struct perf_event_mmap_page'Peter Zijlstra
Solve the problems around the broken definition of perf_event_mmap_page:: cap_usr_time and cap_usr_rdpmc fields which used to overlap, partially fixed by: 860f085b74e9 ("perf: Fix broken union in 'struct perf_event_mmap_page'") The problem with the fix (merged in v3.12-rc1 and not yet released officially), noticed by Vince Weaver is that the new behavior is not detectable by new user-space, and that due to the reuse of the field names it's easy to mis-compile a binary if old headers are used on a new kernel or new headers are used on an old kernel. To solve all that make this change explicit, detectable and self-contained, by iterating the ABI the following way: - Always clear bit 0, and rename it to usrpage->cap_bit0, to at least not confuse old user-space binaries. RDPMC will be marked as unavailable to old binaries but that's within the ABI, this is a capability bit. - Rename bit 1 to ->cap_bit0_is_deprecated and always set it to 1, so new libraries can reliably detect that bit 0 is deprecated and perma-zero without having to check the kernel version. - Use bits 2, 3, 4 for the newly defined, correct functionality: cap_user_rdpmc : 1, /* The RDPMC instruction can be used to read counts */ cap_user_time : 1, /* The time_* fields are used */ cap_user_time_zero : 1, /* The time_zero field is used */ - Rename all the bitfield names in perf_event.h to be different from the old names, to make sure it's not possible to mis-compile it accidentally with old assumptions. The 'size' field can then be used in the future to add new fields and it will act as a natural ABI version indicator as well. Also adjust tools/perf/ userspace for the new definitions, noticed by Adrian Hunter. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Also-Fixed-by: Adrian Hunter <adrian.hunter@intel.com> Link: http://lkml.kernel.org/n/tip-zr03yxjrpXesOzzupszqglbv@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-20Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: * Check for SIGINT in more loops, allowing tools such as 'perf report' to react faster to Ctrl+C, from Arnaldo Carvalho de Melo. * Fix objdump line parsing offset validation in the annotate code, from Adrian Hunter. * Fix buildid cache handling of kallsyms with kcore, from Adrian Hunter. * Fix compile with libelf without get_phdrnum, from Adrian Hunter. * Sharpen the libaudit dependencies test, refusing to build with older libraries that doesn't have all the functions used by 'perf trace", fix from Ingo Molnar. * Fill in new definitions for madvise()/mmap() flags to fix the build in older systems, from Ingo Molnar. * Fix old GCC build error in older systems in the kallsyms parsing code in trace-event-parse.c, from Ingo Molnar. * Ignore DWARF declaration tags, allowing, for instance, that the $ perf probe -L getname command succeeds in showing the source code for the 'getname' kernel function, telling in which lines probes can be inserted, fix from Masami Hiramatsu. * Fix linux/magic.h related build breakage in some systems, fix from Vinson Lee. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-19tools lib lk: Uninclude linux/magic.h in debugfs.cVinson Lee
The compilation only looks for linux/magic.h from the default include paths, which does not include the source tree. This results in a build error if linux/magic.h is not available or not installed. For example, this build error occurs on CentOS 5. $ make -C tools/lib/lk V=1 [...] gcc -o debugfs.o -c -ggdb3 -Wall -Wextra -std=gnu99 -Werror -O6 -D_FORTIFY_SOURCE=2 -Wbad-function-cast -Wdeclaration-after-statement -Wformat-security -Wformat-y2k -Winit-self -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wno-system-headers -Wold-style-definition -Wpacked -Wredundant-decls -Wshadow -Wstrict-aliasing=3 -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wundef -Wwrite-strings -Wformat -fPIC -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 debugfs.c debugfs.c:8:25: error: linux/magic.h: No such file or directory The only symbol from linux/magic.h needed by debugfs.c is DEBUGFS_MAGIC, and that is already defined in debugfs.h. linux/magic.h isn't providing any extra symbols and can unincluded. This is similar to the approach by perf, which has its own magic.h wrapper at tools/perf/util/include/linux/magic.h Signed-off-by: Vinson Lee <vlee@twitter.com> Acked-by: Borislav Petkov <bp@suse.de> Cc: Borislav Petkov <bp@suse.de> Cc: Vinson Lee <vlee@freedesktop.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1379546200-17028-1-git-send-email-vlee@freedesktop.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf tools: Fix old GCC build error in trace-event-parse.c:parse_proc_kallsyms()Ingo Molnar
Old GCC (4.1) does not see through the code flow of parse_proc_kallsyms() and gets confused about the status of 'fmt': util/trace-event-parse.c: In function ‘parse_proc_kallsyms’: util/trace-event-parse.c:189: warning: ‘fmt’ may be used uninitialized in this function make: *** [util/trace-event-parse.o] Error 1 Help out GCC by initializing 'fmt' to NULL. Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20130912131649.GC23826@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf probe: Fix finder to find lines of given functionMasami Hiramatsu
The commit ba28c59bc9ed8fb7b9a753cd88ee54a2c4f6265b fixed a declaration entry bug in probe_point_search_cb(). There are same bugs in line finder and call_probe_finder(). This introduces a new dwarf utility function to determine given DIE is a function definition, not declaration. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20120423032435.8737.80064.stgit@localhost.localdomain Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf session: Check for SIGINT in more loopsArnaldo Carvalho de Melo
When processing big files we were not checking if session_done was set by the SIGINT signal handler, for instance in 'perf report'. Fix it. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-pyad42lgrtq7xhg2dpsoauq7@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf tools: Fix compile with libelf without get_phdrnumAdrian Hunter
Add a feature check for get_phdrnum() and implement a replacement if it is not present. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1379080170-6608-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf tools: Fix buildid cache handling of kallsyms with kcoreAdrian Hunter
When kallsyms is used with kcore the dso long_name becomes the kcore file name. That prevents the buildid cache from caching kallsyms. (There is no support at present for caching kcore). Fix by changing it so that the kallsyms name is used in that case instead. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1379009959-28046-1-git-send-email-adrian.hunter@intel.com [ Kept 'struct foo' pointer as first parameter of foo__ prefixed functions ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf annotate: Fix objdump line parsing offset validationAdrian Hunter
When parsing lines from objdump a line containing source code starting with a numeric label is mistaken for a line of disassembly starting with a memory address. Current validation fails to recognise that the "memory address" is out of range and calculates an invalid offset which later causes this segfault: Program received signal SIGSEGV, Segmentation fault. 0x0000000000457315 in disasm__calc_percent (notes=0xc98970, evidx=0, offset=143705, end=2127526177, path=0x7fffffffbf50) at util/annotate.c:631 631 hits += h->addr[offset++]; (gdb) bt #0 0x0000000000457315 in disasm__calc_percent (notes=0xc98970, evidx=0, offset=143705, end=2127526177, path=0x7fffffffbf50) at util/annotate.c:631 #1 0x00000000004d65e3 in annotate_browser__calc_percent (browser=0x7fffffffd130, evsel=0xa01da0) at ui/browsers/annotate.c:364 #2 0x00000000004d7433 in annotate_browser__run (browser=0x7fffffffd130, evsel=0xa01da0, hbt=0x0) at ui/browsers/annotate.c:672 #3 0x00000000004d80c9 in symbol__tui_annotate (sym=0xc989a0, map=0xa02660, evsel=0xa01da0, hbt=0x0) at ui/browsers/annotate.c:962 #4 0x00000000004d7aa0 in hist_entry__tui_annotate (he=0xdf73f0, evsel=0xa01da0, hbt=0x0) at ui/browsers/annotate.c:823 #5 0x00000000004dd648 in perf_evsel__hists_browse (evsel=0xa01da0, nr_events=1, helpline= 0x58b768 "For a higher level overview, try: perf report --sort comm,dso", ev_name=0xa02cd0 "cycles", left_exits=false, hbt= 0x0, min_pcnt=0, env=0xa011e0) at ui/browsers/hists.c:1659 #6 0x00000000004de372 in perf_evlist__tui_browse_hists (evlist=0xa01520, help= 0x58b768 "For a higher level overview, try: perf report --sort comm,dso", hbt=0x0, min_pcnt=0, env=0xa011e0) at ui/browsers/hists.c:1950 #7 0x000000000042cf6b in __cmd_report (rep=0x7fffffffd6c0) at builtin-report.c:581 #8 0x000000000042e25d in cmd_report (argc=0, argv=0x7fffffffe4b0, prefix=0x0) at builtin-report.c:965 #9 0x000000000041a0e1 in run_builtin (p=0x801548, argc=1, argv=0x7fffffffe4b0) at perf.c:319 #10 0x000000000041a319 in handle_internal_command (argc=1, argv=0x7fffffffe4b0) at perf.c:376 #11 0x000000000041a465 in run_argv (argcp=0x7fffffffe38c, argv=0x7fffffffe380) at perf.c:420 #12 0x000000000041a707 in main (argc=1, argv=0x7fffffffe4b0) at perf.c:521 After the fix is applied the symbol can be annotated showing the problematic line "1: rep" copy_user_generic_string /usr/lib/debug/lib/modules/3.9.10-100.fc17.x86_64/vmlinux */ ENTRY(copy_user_generic_string) CFI_STARTPROC ASM_STAC andl %edx,%edx and %edx,%edx jz 4f je 37 cmpl $8,%edx cmp $0x8,%edx jb 2f /* less than 8 bytes, go to byte copy loop */ jb 33 ALIGN_DESTINATION mov %edi,%ecx and $0x7,%ecx je 28 sub $0x8,%ecx neg %ecx sub %ecx,%edx 1a: mov (%rsi),%al mov %al,(%rdi) inc %rsi inc %rdi dec %ecx jne 1a movl %edx,%ecx 28: mov %edx,%ecx shrl $3,%ecx shr $0x3,%ecx andl $7,%edx and $0x7,%edx 1: rep 100.00 rep movsq %ds:(%rsi),%es:(%rdi) movsq 2: movl %edx,%ecx 33: mov %edx,%ecx 3: rep rep movsb %ds:(%rsi),%es:(%rdi) movsb 4: xorl %eax,%eax 37: xor %eax,%eax data32 xchg %ax,%ax ASM_CLAC ret retq Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1379009721-27667-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf tools: Fill in new definitions for madvise()/mmap() flagsIngo Molnar
builtin-trace.c started using various new syscall features not defined in the header files of older distros - resulting in build failures. Fill in the (ABI) constants if they are not defined. (There might be a better place to put this than builtin-trace.c, into a compat header or so.) Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-tip-commits@vger.kernel.org Link: http://lkml.kernel.org/r/20130912132900.GE23826@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-19perf tools: Sharpen the libaudit dependencies testIngo Molnar
There are older libaudit versions that don't have an audit_errno_to_name() method, resulting in a builtin-trace.c build error: builtin-trace.c: In function ‘trace__sys_exit’: builtin-trace.c:794: warning: implicit declaration of function ‘audit_errno_to_name’ Expand the libaudit test to detect this. Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20130912132706.GD23826@gmail.com [ Fix the test by escaping the double quotes ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-12Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Various fixes. The -g perf report lockup you reported is only partially addressed, patches that fix the excessive runtime are still being worked on" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Fix uncore PCI fixed counter handling uprobes: Fix utask->depth accounting in handle_trampoline() perf/x86: Add constraint for IVB CYCLE_ACTIVITY:CYCLES_LDM_PENDING perf: Fix up MMAP2 buffer space reservation perf tools: Add attr->mmap2 support perf kvm: Fix sample_type manipulation perf evlist: Fix id pos in perf_evlist__open() perf trace: Handle perf.data files with no tracepoints perf session: Separate progress bar update when processing events perf trace: Check if MAP_32BIT is defined perf hists: Fix formatting of long symbol names perf evlist: Fix parsing with no sample_id_all bit set perf tools: Add test for parsing with no sample_id_all bit perf trace: Check control+C more often
2013-09-11perf tools: Add attr->mmap2 supportStephane Eranian
This patch adds support for the new PERF_RECORD_MMAP2 record type exposed by the kernel. This is an extended PERF_RECORD_MMAP record. It adds for each file-backed mapping the device major, minor number and the inode number and generation. This triplet uniquely identifies the source of a file-backed mapping. It can be used to detect identical virtual mappings between processes, for instance. The patch will prefer MMAP2 over MMAP. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1377079825-19057-3-git-send-email-eranian@google.com [ Cope with 314add6 "Change machine__findnew_thread() to set thread pid", fix 'perf test' regression test entry affected, use perf_missing_features.mmap2 to fallback to not using .mmap2 in older kernels, so that new tools can work with kernels where this feature is not present ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-09perf kvm: Fix sample_type manipulationAdrian Hunter
Manipulating the sample_type of an evsel requires the use of: perf_evsel__set_sample_bit() and perf_evsel__reset_sample_bit() Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: David Ahern <dsahern@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1378496412-2424-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-09perf evlist: Fix id pos in perf_evlist__open()Adrian Hunter
Ensure the id_pos is correct when perf_evlist__open() is used. This fixes a problem introduced in 7556257 that broke 'perf kvm stat live' in that this tool wasn't updated to use the sample_type bits setting helpers. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: David Ahern <dsahern@gmail.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1378496412-2424-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-09perf trace: Handle perf.data files with no tracepointsArnaldo Carvalho de Melo
Before: perf trace -i perf.data Segmentation fault (core dumped) # After: # perf trace -i perf.data Data file does not have raw_syscalls:sys_enter events # When there are no tracepoints in a perf.data file the struct pevent that contains the list of tracepoints that will be used to lookup the tracepoint id by name will not be populated, causing a NULL deref. And we don't need to do all that dance to look at pevents for an entry with a slighly different name to then lookup the tracepoint by its id on the evlist, just use the perf_evlist__find_tracepoint_by_name() routine, that will find the tracepoint, if present. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-egcm21k1e6gcyxpcgjxtmsq3@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-09-09Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio update from Rusty Russell: "More console fixes; these are the theoretical ones which didn't get CC:stable. But for that reason, I did a merge with master partway through to avoid an unnecessary conflict. Also: a fun lguest bug turns out if you don't clear the TF flag when trapping Bad Things happen to the guest kernel as the stack overflows..." * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio_pci: pm: Use CONFIG_PM_SLEEP instead of CONFIG_PM lguest: fix GPF in guest when using gdb. lguest: fix guest kernel stack overflow when TF bit set. lguest: fix BUG_ON() in invalid guest page table. virtio: console: prevent use-after-free of port name in port unplug virtio: console: cleanup an error message virtio: console: fix locking around send_sigio_to_port() virtio: console: add locking in port unplug path virtio: console: add locks around buffer removal in port unplug path tools/lguest: offer VIRTIO_F_ANY_LAYOUT for net device. virtio tools: add .gitignore lguest: Point to the right directory for the lguest launcher
2013-09-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc updates from Ben Herrenschmidt: "Here's the powerpc batch for this merge window. Some of the highlights are: - A bunch of endian fixes ! We don't have full LE support yet in that release but this contains a lot of fixes all over arch/powerpc to use the proper accessors, call the firmware with the right endian mode, etc... - A few updates to our "powernv" platform (non-virtualized, the one to run KVM on), among other, support for bridging the P8 LPC bus for UARTs, support and some EEH fixes. - Some mpc51xx clock API cleanups in preparation for a clock API overhaul - A pile of cleanups of our old math emulation code, including better support for using it to emulate optional FP instructions on embedded chips that otherwise have a HW FPU. - Some infrastructure in selftest, for powerpc now, but could be generalized, initially used by some tests for our perf instruction counting code. - A pile of fixes for hotplug on pseries (that was seriously bitrotting) - The usual slew of freescale embedded updates, new boards, 64-bit hiberation support, e6500 core PMU support, etc..." * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits) powerpc: Correct FSCR bit definitions powerpc/xmon: Fix printing of set of CPUs in xmon powerpc/pseries: Move lparcfg.c to platforms/pseries powerpc/powernv: Return secondary CPUs to firmware on kexec powerpc/btext: Fix CONFIG_PPC_EARLY_DEBUG_BOOTX on ppc32 powerpc: Cleanup handling of the DSCR bit in the FSCR register powerpc/pseries: Child nodes are not detached by dlpar_detach_node powerpc/pseries: Add mising of_node_put in delete_dt_node powerpc/pseries: Make dlpar_configure_connector parent node aware powerpc/pseries: Do all node initialization in dlpar_parse_cc_node powerpc/pseries: Fix parsing of initial node path in update_dt_node powerpc/pseries: Pack update_props_workarea to map correctly to rtas buffer header powerpc/pseries: Fix over writing of rtas return code in update_dt_node powerpc/pseries: Fix creation of loop in device node property list powerpc: Skip emulating & leave interrupts off for kernel program checks powerpc: Add more exception trampolines for hypervisor exceptions powerpc: Fix location and rename exception trampolines powerpc: Add more trap names to xmon powerpc/pseries: Add a warning in the case of cross-cpu VPA registration powerpc: Update the 00-Index in Documentation/powerpc ...
