path: root/tools
2011-04-07Merge branches 'x86-fixes-for-linus', 'sched-fixes-for-linus', ↵Linus Torvalds
'timers-fixes-for-linus', 'irq-fixes-for-linus' and 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32, fpu: Fix FPU exception handling on non-SSE systems x86, hibernate: Initialize mmu_cr4_features during boot x86-32, NUMA: Fix ACPI NUMA init broken by recent x86-64 change x86: visws: Fixup irq overhaul fallout * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Clean up rebalance_domains() load-balance interval calculation * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86/mrst/vrtc: Fix boot crash in mrst_rtc_init() rtc, x86/mrst/vrtc: Fix boot crash in rtc_read_alarm() * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Fix cpumask leak in __setup_irq() * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf probe: Fix listing incorrect line number with inline function perf probe: Fix to find recursively inlined function perf probe: Fix multiple --vars options behavior perf probe: Fix to remove redundant close perf probe: Fix to ensure function declared file
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-05perf probe: Fix listing incorrect line number with inline functionMasami Hiramatsu
Fix a bug showing incorrect line number when a probe is put on the head of an inline function. This patch updates find_perf_probe_point() and introduces new rules to get correct line number. - If debuginfo doesn't have a correct file name, we shouldn't return line number too, because, without file name, line number is meaningless. - If the address is in a function, it stores the function name and the offset from the function entry. - If the address is on a line, it tries to get the relative line number from the function entry line, except for the address is same as the entry address of the function (in this case, the relative line number should be 0). - If the address is in an inline function entry (call-site), it uses the inline function call line number as the line on which the address is. - If the address is in an inline function body, it stores the inline function name and offset from the inline function call site instead of the (non-inlined) function. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092605.2132.11629.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-05perf probe: Fix to find recursively inlined functionMasami Hiramatsu
Fix die_find_inlinefunc() to return correct innermost inlined function at given address. Without this fix, it returns the outermost inlined function. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092559.2132.78634.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-05perf probe: Fix multiple --vars options behaviorMasami Hiramatsu
Fix a bug that perf-probe fails to initialize libdwfl and shows incorrect error when user gives multiple --vars options. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092553.2132.42691.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-05perf probe: Fix to remove redundant closeMasami Hiramatsu
Since dwfl_end() closes given fd with dwfl, caller doesn't need to close its fd when finishing process. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092547.2132.93728.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-05perf probe: Fix to ensure function declared fileMasami Hiramatsu
Fix to ensure function declared file matches given file name. This fixes a potential bug. As I've commented on Lin Ming's fastpath enhancement, decl_file should be checked on each probe point if user gives a probe point as func@file. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092541.2132.3584.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-31perf: mmap 512 kiB by defaultFrederic Weisbecker
The default setting of perf record is to mmap 128 pages if the user did not override with -m. However the page size may vary accross different architecture settings, giving different default size between each. Moreover the kernel side still has a default max number of mlocked pages of 512 kiB + 1 page for unprivileged users. 128 + 1 pages with page size > 4096 overlaps this threshold. Thus, better adapt to this limitation and set the default number of pages to fit those 512 kiB + 1 page. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1301535324-9735-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-30Merge commits 'ca6a42586fae' and 'c286c419c784' into perf/urgentIngo Molnar
Pick up these two commits from Arnaldo's perf/core tree: ca6a42586fae: perf tools: Emit clearer message for sys_perf_event_open ENOENT return c286c419c784: perf tools: Fixup exit path when not able to open events As they are really fixes we want to have sooner than laer. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-29perf tools: Fix NO_NEWT=1 python build errorRobert Richter
Fix the following build error: GEN python/perf.so In file included from util/evsel.h:10, from util/python.c:6: util/hist.h:106:18: error: newt.h: No such file or directory error: command 'x86_64-pc-linux-gnu-gcc' failed with exit status 1 make: *** [python/perf.so] Error 1 by passing BASIC_CFLAGS to setup.py. BASIC_CFLAGS variable contains the -DNO_NEWT_SUPPORT switch which prevents building python c extension with newt. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <20110329180236.GA19366@erda.amd.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf symbols: Properly align symbol_conf.priv_sizeDavid S. Miller
If symbol_conf.priv_size is not a multiple of "sizeof(u64)" we'll bus error on sparc64 in symbol__new because the "struct symbol *" pointer is computed by adding symbol_conf.priv_size to the memory allocated. We cannot isolate the fix to symbol__new and symbol__delete since the private area is computed by subtracting the priv_size value from a "struct symbol" pointer, so then the private area can still be potentially unaligned. So, simply align the symbol_conf.priv_size value in symbol__init() Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110328.175849.112593455.davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf tools: Emit clearer message for sys_perf_event_open ENOENT returnDavid Ahern
Resend of patch sent back in January 2011 in light of recent confusion around unsupported events for a given platform. Improve sys_perf_event_open ENOENT return handling in top and record, just like 5a3446b does for stat. Retry of Arnaldo's patch using ui_warning instead of die which allows the fallback from hardware cycles to software clock. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org LKML-Reference: <1301080271-20945-1-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> [ committer note: Some adjustments to make it apply to newer codebase ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf tools: Fixup exit path when not able to open eventsArnaldo Carvalho de Melo
We have to deal with the TUI mode in perf top, so that we don't end up with a garbled screen when, say, a non root user on a machine with a paranoid setting (the default) tries to use 'perf top'. Introduce a ui__warning_paranoid() routine shared by top and record that tells the user the valid values for /proc/sys/kernel/perf_event_paranoid. Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-28perf symbols: Fix vsyscall symbol lookupAndrew Lutomirski
Perf can't currently trace into the vsyscall page. It looks like it was meant to work. Tested on 2.6.38 and today's -git. The bug is easy to reproduce. Compile this: int main() { int i; struct timespec t; for(i = 0; i < 10000000; i++) clock_gettime(CLOCK_MONOTONIC, &t); return 0; } and run it through perf record; perf report. The top entry shows "[unknown]" and you can't zoom in. It looks like there are two issues. The first is a that a test for user mode executing in kernel space is backwards. (That's the first hunk below). The second (I think) is that something's wrong with the code that generates lots of little struct dso objects for different sections -- when it runs on vmlinux it results in bogus long_name values which cause objdump to fail. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LPU-Reference: <AANLkTikxSw5+wJZUWNz++nL7mgivCh_Zf=2Kq6=f9Ce_@mail.gmail.com> Signed-off-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-25Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, x86: Complain louder about BIOSen corrupting CPU/PMU state and continue perf, x86: P4 PMU - Read proper MSR register to catch unflagged overflows perf symbols: Look at .dynsym again if .symtab not found perf build-id: Add quirk to deal with perf.data file format breakage perf session: Pass evsel in event_ops->sample() perf: Better fit max unprivileged mlock pages for tools needs perf_events: Fix stale ->cgrp pointer in update_cgrp_time_from_cpuctx() perf top: Fix uninitialized 'counter' variable tracing: Fix set_ftrace_filter probe function display perf, x86: Fix Intel fixed counters base initialization
2011-03-23perf symbols: Look at .dynsym again if .symtab not foundArnaldo Carvalho de Melo
The original intent of the code was to repeat the search with want_symtab = 0. But as the code stands now, we never hit the "default" case of the switch statement. Which means we never repeat the search. Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Reported-by: Arun Sharma <asharma@fb.com> Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Dave Martin <dave.martin@linaro.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf build-id: Add quirk to deal with perf.data file format breakageArnaldo Carvalho de Melo
The a1645ce1 changeset: "perf: 'perf kvm' tool for monitoring guest performance from host" Added a field to struct build_id_event that broke the file format. Since the kernel build-id is the first entry, process the table using the old format if the well known '[kernel.kallsyms]' string for the kernel build-id has the first 4 characters chopped off (where the pid_t sits). Reported-by: Han Pingtian <phan@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Zhang Yanmin <yanmin_zhang@linux.intel.com> Cc: stable@kernel.org LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf session: Pass evsel in event_ops->sample()Arnaldo Carvalho de Melo
Resolving the sample->id to an evsel since the most advanced tools, report and annotate, and the others will too when they evolve to properly support multi-event perf.data files. Good also because it does an extra validation, checking that the ID is valid when present. When that is not the case, the overhead is just a branch + function call (perf_evlist__id2evsel). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf top: Fix uninitialized 'counter' variableAkihiro Nagai
builtin-top.c has an uninitialized variable. gcc(version 4.5.1) warns about it and it results in build failure: builtin-top.c: In function 'display_thread': builtin-top.c:518:9: error: 'counter' may be used uninitialized This situation can indeed trigger, if the getline() call in prompt_integer() fails. Signed-off-by: Akihiro Nagai <akihiro.nagai.hw@hitachi.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110323072939.11638.50173.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest: ktest: Add STOP_TEST_AFTER to stop the test after a period of time ktest: Monitor kernel while running of user tests ktest: Fix bug where the test would not end after failure ktest: Add BISECT_FILES to run git bisect on paths ktest: Add BISECT_SKIP ktest: Add manual bisect ktest: Handle kernels before make oldnoconfig ktest: Start failure timeout on panic too ktest: Print logfile name on failure
2011-03-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) trace, filters: Initialize the match variable in process_ops() properly trace, documentation: Fix branch profiling location in debugfs oprofile, s390: Cleanups oprofile, s390: Remove hwsampler_files.c and merge it into init.c perf: Fix tear-down of inherited group events perf: Reorder & optimize perf_event_context to remove alignment padding on 64 bit builds perf: Handle stopped state with tracepoints perf: Fix the software events state check perf, powerpc: Handle events that raise an exception without overflowing perf, x86: Use INTEL_*_CONSTRAINT() for all PEBS event constraints perf, x86: Clean up SandyBridge PEBS events perf lock: Fix sorting by wait_min perf tools: Version incorrect with some versions of grep perf evlist: New command to list the names of events present in a perf.data file perf script: Add support for H/W and S/W events perf script: Add support for dumping symbols perf script: Support custom field selection for output perf script: Move printing of 'common' data from print_event and rename perf tracing: Remove print_graph_cpu and print_graph_proc from trace-event-parse perf script: Change process_event prototype ...
2011-03-16Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (172 commits) USB: Add support for SuperSpeed isoc endpoints xhci: Clean up cycle bit math used during stalls. xhci: Fix cycle bit calculation during stall handling. xhci: Update internal dequeue pointers after stalls. USB: Disable auto-suspend for USB 3.0 hubs. USB: Remove bogus USB_PORT_STAT_SUPER_SPEED symbol. xhci: Return canceled URBs immediately when host is halted. xhci: Fixes for suspend/resume of shared HCDs. xhci: Fix re-init on power loss after resume. xhci: Make roothub functions deal with device removal. xhci: Limit roothub ports to 15 USB3 & 31 USB2 ports. xhci: Return a USB 3.0 hub descriptor for USB3 roothub. xhci: Register second xHCI roothub. xhci: Change xhci_find_slot_id_by_port() API. xhci: Refactor bus suspend state into a struct. xhci: Index with a port array instead of PORTSC addresses. USB: Set usb_hcd->state and flags for shared roothubs. usb: Make core allocate resources per PCI-device. usb: Store bus type in usb_hcd, not in driver flags. usb: Change usb_hcd->bandwidth_mutex to a pointer. ...
2011-03-16perf lock: Fix sorting by wait_minMarcin Slusarz
If lock was uncontended, wait_time_min == ULLONG_MAX, so we need to handle this case differently to show high wait times first Acked-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110222174715.GC9687@joi.lan> Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-16perf tools: Version incorrect with some versions of grepJosh Hunt
Some versions of grep don't treat '\s' properly. When building perf on such systems and using a kernel tarball the perf version is unable to be determined from the main kernel Makefile and the user is left with a version of '..'. Replacing the use of '\s' with '[[:space:]]', which should work in all grep versions, gives a usable version number. Reported-by: Tapan Dhimant <tdhimant@akamai.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tapan Dhimant <tdhimant@akamai.com> Cc: linux-kernel@vger.kernel.org Cc: stable@kernel.org LKML-Reference: <1300241800-30281-1-git-send-email-johunt@akamai.com> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-16Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux-2.6 into perf/urgent
2011-03-15Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (184 commits) perf probe: Clean up probe_point_lazy_walker() return value tracing: Fix irqoff selftest expanding max buffer tracing: Align 4 byte ints together in struct tracer tracing: Export trace_set_clr_event() tracing: Explain about unstable clock on resume with ring buffer warning ftrace/graph: Trace function entry before updating index ftrace: Add .ref.text as one of the safe areas to trace tracing: Adjust conditional expression latency formatting. tracing: Fix event alignment: skb:kfree_skb tracing: Fix event alignment: mce:mce_record tracing: Fix event alignment: kvm:kvm_hv_hypercall tracing: Fix event alignment: module:module_request tracing: Fix event alignment: ftrace:context_switch and ftrace:wakeup tracing: Remove lock_depth from event entry perf header: Stop using 'self' perf session: Use evlist/evsel for managing perf.data attributes perf top: Don't let events to eat up whole header line perf top: Fix events overflow in top command ring-buffer: Remove unused #include <linux/trace_irq.h> tracing: Add an 'overwrite' trace_option. ...
2011-03-15perf probe: Clean up probe_point_lazy_walker() return valueIngo Molnar
Newer compilers (gcc 4.6) complains about: return ret < 0 ?: 0; For the following reason: util/probe-finder.c: In function ‘probe_point_lazy_walker’: util/probe-finder.c:1331:18: error: the omitted middle operand in ?: will always be ‘true’, suggest explicit middle operand [-Werror=parentheses] And indeed the return value is a somewhat obscure (but correct) value of 'true', so return 'ret' instead - this is cleaner and unconfuses GCC as well. Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-15perf evlist: New command to list the names of events present in a perf.data fileArnaldo Carvalho de Melo
[root@emilia ~]# perf record -a -e sched:* -e timer:timer* sleep 5 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.172 MB perf.data (~7530 samples) ] [root@emilia ~]# perf evlist sched:sched_kthread_stop sched:sched_kthread_stop_ret sched:sched_wakeup sched:sched_wakeup_new sched:sched_switch sched:sched_migrate_task sched:sched_process_free sched:sched_process_exit sched:sched_wait_task sched:sched_process_wait sched:sched_process_fork sched:sched_stat_wait sched:sched_stat_sleep sched:sched_stat_iowait sched:sched_stat_runtime sched:sched_pi_setprio timer:timer_init timer:timer_start timer:timer_expire_entry timer:timer_expire_exit timer:timer_cancel [root@emilia ~]# Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf script: Add support for H/W and S/W eventsDavid Ahern
Custom fields set for each type by prepending field argument with type. For file with multiple event types (e.g., trace and S/W) display of an event type suppressed by setting output fields to "". e.g., perf record -ga -e sched:sched_switch -e cpu-clock -c 10000000 -R -- sleep 1 perf script openssl 11496 [000] 9711.807107: cpu-clock-msecs: ffffffff810c22dc arch_local_irq_restore ([kernel.kallsyms]) ffffffff810c518c __alloc_pages_nodemask ([kernel.kallsyms]) ffffffff810297b2 pte_alloc_one ([kernel.kallsyms]) ffffffff810d8b98 __pte_alloc ([kernel.kallsyms]) ffffffff810daf07 handle_mm_fault ([kernel.kallsyms]) ffffffff8138763a do_page_fault ([kernel.kallsyms]) ffffffff81384a65 page_fault ([kernel.kallsyms]) 7f6130507d70 asn1_check_tlen (/lib64/libcrypto.so.1.0.0c) 0 () openssl 11496 [000] 9711.808042: sched_switch: prev_comm=openssl ... kworker/0:0 4 [000] 9711.808067: sched_switch: prev_comm=kworker/... swapper 0 [001] 9711.808090: sched_switch: prev_comm=kworker/... sshd 11451 [001] 9711.808185: sched_switch: prev_comm=sshd pre... swapper 0 [001] 9711.816155: cpu-clock-msecs: ffffffff81023609 native_safe_halt ([kernel.kallsyms]) ffffffff8100132a cpu_idle ([kernel.kallsyms]) ffffffff8137cf9b start_secondary ([kernel.kallsyms]) openssl 11496 [000] 9711.817104: cpu-clock-msecs: 7f61304ad723 AES_cbc_encrypt (/lib64/libcrypto.so.1.0.0c) 7fff3402f950 () 12f0debc9a785634 () swapper 0 [001] 9711.826155: cpu-clock-msecs: ffffffff81023609 native_safe_halt ([kernel.kallsyms]) ffffffff8100132a cpu_idle ([kernel.kallsyms]) ffffffff8137cf9b start_secondary ([kernel.kallsyms]) To suppress trace events within the file and use default output for S/W events: perf script -f trace: or to suppress S/W events and do default display for trace events: perf script -f sw: Custom field selections: perf script -f sw:comm,tid,time -f trace:time,trace openssl 11496 9711.797162: swapper 0 9711.807071: openssl 11496 9711.807107: 9711.808042: prev_comm=openssl prev_pid=11496 prev_prio=120 prev_state=R ... 9711.808067: prev_comm=kworker/0:0 prev_pid=4 prev_prio=120 prev_state=S ... 9711.808090: prev_comm=kworker/0:0 prev_pid=0 prev_prio=120 prev_state=R ... 9711.808185: prev_comm=sshd prev_pid=11451 prev_prio=120 prev_state=S ==>... swapper 0 9711.816155: openssl 11496 9711.817104: swapper 0 9711.826155: Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-7-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf script: Add support for dumping symbolsDavid Ahern
Add option to dump symbols found in events. e.g., perf script -f comm,pid,tid,time,trace,sym swapper 0/0 537.037184: prev_comm=swapper prev_pid=0 prev_prio=120... ffffffff81030350 perf_trace_sched_switch ([kernel.kallsyms]) ffffffff81382ac5 schedule ([kernel.kallsyms]) ffffffff8100134a cpu_idle ([kernel.kallsyms]) ffffffff81370b39 rest_init ([kernel.kallsyms]) ffffffff81696c23 start_kernel ([kernel.kallsyms].init.text) ffffffff816962af x86_64_start_reservations ([kernel.kallsyms].init.text) ffffffff816963b9 x86_64_start_kernel ([kernel.kallsyms].init.text) sshd 1675/1675 537.037309: prev_comm=sshd prev_pid=1675 prev_prio=120... ffffffff81030350 perf_trace_sched_switch ([kernel.kallsyms]) ffffffff81382ac5 schedule ([kernel.kallsyms]) ffffffff813837aa schedule_hrtimeout_range_clock ([kernel.kallsyms]) ffffffff81383886 schedule_hrtimeout_range ([kernel.kallsyms]) ffffffff8110c4f9 poll_schedule_timeout ([kernel.kallsyms]) ffffffff8110cd20 do_select ([kernel.kallsyms]) ffffffff8110ced8 core_sys_select ([kernel.kallsyms]) ffffffff8110d00d sys_select ([kernel.kallsyms]) ffffffff81002bc2 system_call ([kernel.kallsyms]) 7f1647e56e93 __GI_select (/lib64/libc-2.12.90.so) netstat 1692/1692 537.038664: prev_comm=netstat prev_pid=1692 prev_prio=... ffffffff81030350 perf_trace_sched_switch ([kernel.kallsyms]) ffffffff81382ac5 schedule ([kernel.kallsyms]) ffffffff81002c3a sysret_careful ([kernel.kallsyms]) 7f7a6cd1b210 __GI___libc_read (/lib64/libc-2.12.90.so) Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-6-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf script: Support custom field selection for outputDavid Ahern
Allow a user to select which fields to print to stdout for event data. Options include comm (command name), tid (thread id), pid (process id), time (perf timestamp), cpu, event (for event name), and trace (for trace data). Default is set to maintain compatibility with current output; this feature does alter output format slightly -- no '-' between command and pid/tid. Thanks to Frederic Weisbecker for detailed suggestions on this approach. Examples (output compressed) 1. trace, default format perf record -ga -e sched:sched_switch perf script swapper 0 [000] 537.037184: sched_switch: prev_comm=swapper prev_pid=0... sshd 1675 [000] 537.037309: sched_switch: prev_comm=sshd prev_pid=1675... netstat 1692 [001] 537.038664: sched_switch: prev_comm=netstat prev_pid=1692... 2. trace, custom format perf record -ga -e sched:sched_switch perf script -f comm,pid,time,trace <--- omitting cpu and event name swapper 0 537.037184: prev_comm=swapper prev_pid=0 prev_prio=120 ... sshd 1675 537.037309: prev_comm=sshd prev_pid=1675 prev_prio=120 ... netstat 1692 537.038664: prev_comm=netstat prev_pid=1692 prev_prio=120 ... Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-5-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf script: Move printing of 'common' data from print_event and renameDavid Ahern
This change does impact output: latency data is trace specific and is now printed after the common data - comm, tid, cpu, time and event name. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-4-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf tracing: Remove print_graph_cpu and print_graph_proc from trace-event-parseDavid Ahern
Next patch moves printing of 'common' data into perf-script which removes the need for these functions. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-3-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf script: Change process_event prototypeDavid Ahern
Prepare for handling of samples for any event type. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-2-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf stat: Provide support for filtersFrederic Weisbecker
Now the --filter option is usable with perf stat too. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1300117230-8404-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf symbol: Move sym_entry->skip to symbol->ignoreArnaldo Carvalho de Melo
While going thru each of the sym_entry fields looking to reduce it to the set of entries needed when in an active symbols list, 'skip' should really be in symbol, as we set it when loading the symtab. And the space used by the basic symbol allocation remains the same as we had 5 bytes of padding. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf symbols: Rename dso->origin to dso->symtab_typeArnaldo Carvalho de Melo
And the DSO__ORIG_ enum to SYMTAB__, to clarify that this is about from where the symtab was obtained. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf top: Remove redundant syme->origin fieldArnaldo Carvalho de Melo
We can get it from syme->map->dso->kernel (that should be renamed to origin, but leave this for another patch). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf top: Remove redundant perf_top->sym_counterArnaldo Carvalho de Melo
We can get that counter index from perf_top->sym_evsel->idx instead. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-10perf header: Stop using 'self'Arnaldo Carvalho de Melo
Stop using this python/OOP convention, doesn't really helps. Will do more from time to time till we get it cleaned up in all of tools/perf. Suggested-by: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <new-submission> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-10perf session: Use evlist/evsel for managing perf.data attributesArnaldo Carvalho de Melo
So that we can reuse things like the id to attr lookup routine (perf_evlist__id2evsel) that uses a hash table instead of the linear lookup done in the older perf_header_attr routines, etc. Also to make evsels/evlist more pervasive an API, simplyfing using the emerging perf lib. cc: Arun Sharma <arun@sharma-home.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-10perf top: Don't let events to eat up whole header lineJiri Olsa
Passing multiple events might force out information about pid/tid/cpu. Attached patch leaves 30 characters for this info at the expense of the events' names. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Han Pingtian <phan@redhat.com> LKML-Reference: <1299528821-17521-3-git-send-email-jolsa@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-10perf top: Fix events overflow in top commandJiri Olsa
The snprintf function returns number of printed characters even if it cross the size parameter. So passing enough events via '-e' parameter will cause segmentation fault. It's reproduced by following command: perf top -e `perf list | grep Tracepoint | awk -F'[' '\ {gsub(/[[:space:]]+/,"",$1);array[FNR]=$1}END{outputs=array[1];\ for (i=2;i<=FNR;i++){ outputs=outputs "," array[i];};print outputs}'` Attached patch is adding SNPRINTF macro that provides the overflow check and returns actuall number of printed characters. Reported-by: Han Pingtian <phan@redhat.com> Cc: Han Pingtian <phan@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1299528821-17521-2-git-send-email-jolsa@redhat.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-09perf symbols: Avoid resolving [kernel.kallsyms] to real path for buildid cacheLin Ming
kallsyms has a virtual file name [kernel.kallsyms]. Currently, it can't be added to buildid cache successfully because the code (build_id_cache__add_s) tries to resolve [kernel.kallsyms] to a real absolute pathname and that fails. Fixes it by not resolving it and just use the name [kernel.kallsyms]. So dir ~/.debug/[kernel.kallsyms] is created. Original bug report at: https://lkml.org/lkml/2011/3/1/524 Tested-by: Han Pingtian <phan@redhat.com> Cc: Han Pingtian <phan@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1299165837-27817-1-git-send-email-ming.m.lin@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-08ktest: Add STOP_TEST_AFTER to stop the test after a period of timeSteven Rostedt
Currently, if a test causes constant output but never reaches a boot prompt, or crashes, the test will never stop. Add STOP_TEST_AFTER to create a variable that will stop (and fail) the test after it has run for this amount of time. The default is 10 minutes. Setting this variable to -1 will disable it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-08ktest: Monitor kernel while running of user testsSteven Rostedt
Record the console of tests to both the console and the log. Also, record the bug reports afte the test has completed. Currently, if a kernel bug happens while running the userland test, the test stops and will not record the kernel bug. This makes it difficult to solve what happened. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-08ktest: Fix bug where the test would not end after failureSteven Rostedt
The config STOP_AFTER_FAILURE is the number of seconds to continue the test when a failure is detected. This lets the monitor record more data to the logs and console that may be helpful in solving the bug that was found. But the test had a bug. If the failure caused multiple "Call Trace" stack dumps, the start time to compare the STOP_AFTER_FAILURE would constantly be reset. Only update the start time at the first "Call Trace" instance. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-08ktest: Add BISECT_FILES to run git bisect on pathsSteven Rostedt
Add the config option BISECT_FILES that allows the user to specify what path in the kernel to run the git bisect on. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-08ktest: Add BISECT_SKIPSteven Rostedt
If a during a git bisect, ktest fails on something other than what it is testing (if BISECT_TYPE is test but it fails on build), if BISECT_SKIP is set, then it will do a "git bisect skip" instead of just failing the bisect and letting the user find a good commit to test. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
