path: root/tools
2014-06-08Merge branch 'next' (accumulated 3.16 merge window patches) into masterLinus Torvalds
Now that 3.15 is released, this merges the 'next' branch into 'master', bringing us to the normal situation where my 'master' branch is the merge window. * accumulated work in next: (6809 commits) ufs: sb mutex merge + mutex_destroy powerpc: update comments for generic idle conversion cris: update comments for generic idle conversion idle: remove cpu_idle() forward declarations nbd: zero from and len fields in NBD_CMD_DISCONNECT. mm: convert some level-less printks to pr_* MAINTAINERS: adi-buildroot-devel is moderated MAINTAINERS: add linux-api for review of API/ABI changes mm/kmemleak-test.c: use pr_fmt for logging fs/dlm/debug_fs.c: replace seq_printf by seq_puts fs/dlm/lockspace.c: convert simple_str to kstr fs/dlm/config.c: convert simple_str to kstr mm: mark remap_file_pages() syscall as deprecated mm: memcontrol: remove unnecessary memcg argument from soft limit functions mm: memcontrol: clean up memcg zoneinfo lookup mm/memblock.c: call kmemleak directly from memblock_(alloc|free) mm/mempool.c: update the kmemleak stack trace for mempool allocations lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations mm: introduce kmemleak_update_trace() mm/kmemleak.c: use %u to print ->checksum ...
2014-06-06tools/testing/selftests/sysctl: validate sysctl_writes_strictKees Cook
This adds several behavioral tests to sysctl string and number writing to detect unexpected cases that behaved differently when the sysctl kernel.sysctl_writes_strict != 1. [ original ] root@localhost:~# make test_num == Testing sysctl behavior against /proc/sys/kernel/domainname == Writing test file ... ok Checking sysctl is not set to test value ... ok Writing sysctl from shell ... ok Resetting sysctl to original value ... ok Writing entire sysctl in single write ... ok Writing middle of sysctl after synchronized seek ... FAIL Writing beyond end of sysctl ... FAIL Writing sysctl with multiple long writes ... FAIL Writing entire sysctl in short writes ... FAIL Writing middle of sysctl after unsynchronized seek ... ok Checking sysctl maxlen is at least 65 ... ok Checking sysctl keeps original string on overflow append ... FAIL Checking sysctl stays NULL terminated on write ... ok Checking sysctl stays NULL terminated on overwrite ... ok make: *** [test_num] Error 1 root@localhost:~# make test_string == Testing sysctl behavior against /proc/sys/vm/swappiness == Writing test file ... ok Checking sysctl is not set to test value ... ok Writing sysctl from shell ... ok Resetting sysctl to original value ... ok Writing entire sysctl in single write ... ok Writing middle of sysctl after synchronized seek ... FAIL Writing beyond end of sysctl ... FAIL Writing sysctl with multiple long writes ... ok make: *** [test_string] Error 1 [ with CONFIG_PROC_SYSCTL_STRICT_WRITES ] root@localhost:~# make run_tests == Testing sysctl behavior against /proc/sys/kernel/domainname == Writing test file ... ok Checking sysctl is not set to test value ... ok Writing sysctl from shell ... ok Resetting sysctl to original value ... ok Writing entire sysctl in single write ... ok Writing middle of sysctl after synchronized seek ... ok Writing beyond end of sysctl ... ok Writing sysctl with multiple long writes ... ok Writing entire sysctl in short writes ... ok Writing middle of sysctl after unsynchronized seek ... ok Checking sysctl maxlen is at least 65 ... ok Checking sysctl keeps original string on overflow append ... ok Checking sysctl stays NULL terminated on write ... ok Checking sysctl stays NULL terminated on overwrite ... ok == Testing sysctl behavior against /proc/sys/vm/swappiness == Writing test file ... ok Checking sysctl is not set to test value ... ok Writing sysctl from shell ... ok Resetting sysctl to original value ... ok Writing entire sysctl in single write ... ok Writing middle of sysctl after synchronized seek ... ok Writing beyond end of sysctl ... ok Writing sysctl with multiple long writes ... ok Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04tools/vm/page-types.c: catch sigbus if raced with truncateKonstantin Khlebnikov
Recently added page-cache dumping is known to be a little bit racy. But after race with truncate it just dies due to unhandled SIGBUS when it tries to poke pages beyond the new end of file. This patch adds handler for SIGBUS which skips the rest of the file. Signed-off-by: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04Merge tag 'pm+acpi-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm into next Pull ACPI and power management updates from Rafael Wysocki: "ACPICA is the leader this time (63 commits), followed by cpufreq (28 commits), devfreq (15 commits), system suspend/hibernation (12 commits), ACPI video and ACPI device enumeration (10 commits each). We have no major new features this time, but there are a few significant changes of how things work. The most visible one will probably be that we are now going to create platform devices rather than PNP devices by default for ACPI device objects with _HID. That was long overdue and will be really necessary to be able to use the same drivers for the same hardware blocks on ACPI and DT-based systems going forward. We're not expecting fallout from this one (as usual), but it's something to watch nevertheless. The second change having a chance to be visible is that ACPI video will now default to using native backlight rather than the ACPI backlight interface which should generally help systems with broken Win8 BIOSes. We're hoping that all problems with the native backlight handling that we had previously have been addressed and we are in a good enough shape to flip the default, but this change should be easy enough to revert if need be. In addition to that, the system suspend core has a new mechanism to allow runtime-suspended devices to stay suspended throughout system suspend/resume transitions if some extra conditions are met (generally, they are related to coordination within device hierarchy). However, enabling this feature requires cooperation from the bus type layer and for now it has only been implemented for the ACPI PM domain (used by ACPI-enumerated platform devices mostly today). Also, the acpidump utility that was previously shipped as a separate tool will now be provided by the upstream ACPICA along with the rest of ACPICA code, which will allow it to be more up to date and better supported, and we have one new cpuidle driver (ARM clps711x). The rest is improvements related to certain specific use cases, cleanups and fixes all over the place. Specifics: - ACPICA update to upstream version 20140424. That includes a number of fixes and improvements related to things like GPE handling, table loading, headers, memory mapping and unmapping, DSDT/SSDT overriding, and the Unload() operator. The acpidump utility from upstream ACPICA is included too. From Bob Moore, Lv Zheng, David Box, David Binderman, and Colin Ian King. - Fixes and cleanups related to ACPI video and backlight interfaces from Hans de Goede. That includes blacklist entries for some new machines and using native backlight by default. - ACPI device enumeration changes to create platform devices rather than PNP devices for ACPI device objects with _HID by default. PNP devices will still be created for the ACPI device object with device IDs corresponding to real PNP devices, so that change should not break things left and right, and we're expecting to see more and more ACPI-enumerated platform devices in the future. From Zhang Rui and Rafael J Wysocki. - Updates for the ACPI LPSS (Low-Power Subsystem) driver allowing it to handle system suspend/resume on Asus T100 correctly. From Heikki Krogerus and Rafael J Wysocki. - PM core update introducing a mechanism to allow runtime-suspended devices to stay suspended over system suspend/resume transitions if certain additional conditions related to coordination within device hierarchy are met. Related PM documentation update and ACPI PM domain support for the new feature. From Rafael J Wysocki. - Fixes and improvements related to the "freeze" sleep state. They affect several places including cpuidle, PM core, ACPI core, and the ACPI battery driver. From Rafael J Wysocki and Zhang Rui. - Miscellaneous fixes and updates of the ACPI core from Aaron Lu, Bjørn Mork, Hanjun Guo, Lan Tianyu, and Rafael J Wysocki. - Fixes and cleanups for the ACPI processor and ACPI PAD (Processor Aggregator Device) drivers from Baoquan He, Manuel Schölling, Tony Camuso, and Toshi Kani. - System suspend/resume optimization in the ACPI battery driver from Lan Tianyu. - OPP (Operating Performance Points) subsystem updates from Chander Kashyap, Mark Brown, and Nishanth Menon. - cpufreq core fixes, updates and cleanups from Srivatsa S Bhat, Stratos Karafotis, and Viresh Kumar. - Updates, fixes and cleanups for the Tegra, powernow-k8, imx6q, s5pv210, nforce2, and powernv cpufreq drivers from Brian Norris, Jingoo Han, Paul Bolle, Philipp Zabel, Stratos Karafotis, and Viresh Kumar. - intel_pstate driver fixes and cleanups from Dirk Brandewie, Doug Smythies, and Stratos Karafotis. - Enabling the big.LITTLE cpufreq driver on arm64 from Mark Brown. - Fix for the cpuidle menu governor from Chander Kashyap. - New ARM clps711x cpuidle driver from Alexander Shiyan. - Hibernate core fixes and cleanups from Chen Gang, Dan Carpenter, Fabian Frederick, Pali Rohár, and Sebastian Capella. - Intel RAPL (Running Average Power Limit) driver updates from Jacob Pan. - PNP subsystem updates from Bjorn Helgaas and Fabian Frederick. - devfreq core updates from Chanwoo Choi and Paul Bolle. - devfreq updates for exynos4 and exynos5 from Chanwoo Choi and Bartlomiej Zolnierkiewicz. - turbostat tool fix from Jean Delvare. - cpupower tool updates from Prarit Bhargava, Ramkumar Ramachandra and Thomas Renninger. - New ACPI ec_access.c tool for poking at the EC in a safe way from Thomas Renninger" * tag 'pm+acpi-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (187 commits) ACPICA: Namespace: Remove _PRP method support. intel_pstate: Improve initial busy calculation intel_pstate: add sample time scaling intel_pstate: Correct rounding in busy calculation intel_pstate: Remove C0 tracking PM / hibernate: fixed typo in comment ACPI: Fix x86 regression related to early mapping size limitation ACPICA: Tables: Add mechanism to control early table checksum verification. ACPI / scan: use platform bus type by default for _HID enumeration ACPI / scan: always register ACPI LPSS scan handler ACPI / scan: always register memory hotplug scan handler ACPI / scan: always register container scan handler ACPI / scan: Change the meaning of missing .attach() in scan handlers ACPI / scan: introduce platform_id device PNP type flag ACPI / scan: drop unsupported serial IDs from PNP ACPI scan handler ID list ACPI / scan: drop IDs that do not comply with the ACPI PNP ID rule ACPI / PNP: use device ID list for PNPACPI device enumeration ACPI / scan: .match() callback for ACPI scan handlers ACPI / battery: wakeup the system only when necessary power_supply: allow power supply devices registered w/o wakeup source ...
2014-06-04perf probe: Fix perf probe to find correct variable DIEMasami Hiramatsu
Fix perf probe to find correct variable DIE which has location or external instance by tracking down the lexical blocks. Current die_find_variable() expects that the all variable DIEs which has DW_TAG_variable have a location. However, since recent dwarf information may have declaration variable DIEs at the entry of function (subprogram), die_find_variable() returns it. To solve this problem, it must track down the DIE tree to find a DIE which has an actual location or a reference for external instance. e.g. finding a DIE which origin is <0xdc73>; <1><11496>: Abbrev Number: 95 (DW_TAG_subprogram) <11497> DW_AT_abstract_origin: <0xdc42> <1149b> DW_AT_low_pc : 0x1850 [...] <2><114cc>: Abbrev Number: 119 (DW_TAG_variable) <- this is a declaration <114cd> DW_AT_abstract_origin: <0xdc73> <2><114d1>: Abbrev Number: 119 (DW_TAG_variable) [...] <3><115a7>: Abbrev Number: 105 (DW_TAG_lexical_block) <115a8> DW_AT_ranges : 0xaa0 <4><115ac>: Abbrev Number: 96 (DW_TAG_variable) <- this has a location <115ad> DW_AT_abstract_origin: <0xdc73> <115b1> DW_AT_location : 0x486c (location list) Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Acked-by: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20140529121930.30879.87092.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-06-04perf probe: Fix a segfault if asked for variable it doesn't findMasami Hiramatsu
Fix a segfault bug by asking for variable it doesn't find. Since the convert_variable() didn't handle error code returned from convert_variable_location(), it just passed an incomplete variable field and then a segfault was occurred when formatting the field. This fixes that bug by handling success code correctly in convert_variable(). Other callers of convert_variable_location() are correctly checking the return code. This bug was introduced by following commit. But another hidden erroneous error handling has been there previously (-ENOMEM case). commit 3d918a12a1b3088ac16ff37fa52760639d6e2403 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20140529105232.28251.30447.stgit@ltc230.yrl.intra.hitachi.co.jp Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-06-03Merge branches 'acpi-tools' and 'pm-tools'Rafael J. Wysocki
* acpi-tools: ACPI / tools: Introduce ec_access.c - tool to access the EC * pm-tools: cpupower: Remove mc and smt power aware scheduler info/settings cpupower: cpupower info -b should return 0 on success, not the perf bias value cpupower: If root, try to load msr driver on x86 if /dev/cpu/0/msr is not available cpupower: Install recently added cpupower-idle-{set, info} manpages cpupower: Introduce idle state disable-by-latency and enable-all cpupower: Remove all manpages on make uninstall cpupower: Remove dead link to homepage, and update the targets built. cpupower: Rename cpufrequtils -> cpupower, and libcpufreq -> libcpupower. PM / tools: cpupower: add option to display values without round offs tools / power: turbostat: Drop temperature checks
2014-06-03Merge branch 'pm-cpufreq'Rafael J. Wysocki
* pm-cpufreq: (28 commits) cpufreq: handle calls to ->target_index() in separate routine cpufreq: s5pv210: drop check for CONFIG_PM_VERBOSE cpufreq: intel_pstate: Remove unused member name of cpudata cpufreq: Break out early when frequency equals target_freq cpufreq: Tegra: drop wrapper around tegra_update_cpu_speed() cpufreq: imx6q: Remove unused include cpufreq: imx6q: Drop devm_clk/regulator_get usage cpufreq: powernow-k8: Suppress checkpatch warnings cpufreq: powernv: make local function static cpufreq: Enable big.LITTLE cpufreq driver on arm64 cpufreq: nforce2: remove DEFINE_PCI_DEVICE_TABLE macro intel_pstate: Add CPU IDs for Broadwell processors cpufreq: Fix build error on some platforms that use cpufreq_for_each_* PM / OPP: Move cpufreq specific OPP functions out of generic OPP library PM / OPP: Remove cpufreq wrapper dependency on internal data organization cpufreq: Catch double invocations of cpufreq_freq_transition_begin/end intel_pstate: Remove sample parameter in intel_pstate_calc_busy cpufreq: Kconfig: Fix spelling errors cpufreq: Make linux-pm@vger.kernel.org official mailing list cpufreq: exynos: Use dev_err/info function instead of pr_err/info ...
2014-06-03Merge branch 'acpica'Rafael J. Wysocki
* acpica: (63 commits) ACPICA: Namespace: Remove _PRP method support. ACPI: Fix x86 regression related to early mapping size limitation ACPICA: Tables: Add mechanism to control early table checksum verification. ACPICA: acpidump: Fix repetitive table dump in -n mode. ACPI: Clean up acpi_os_map/unmap_memory() to eliminate __iomem. ACPICA: Clean up redudant definitions already defined elsewhere ACPICA: Linux headers: Add <asm/acenv.h> to remove mis-ordered inclusion of <asm/acpi.h> ACPICA: Linux headers: Add <acpi/platform/aclinuxex.h> ACPICA: Linux headers: Remove ACPI_PREEMPTION_POINT() due to no usages. ACPICA: Update version to 20140424. ACPICA: Comment/format update, no functional change. ACPICA: Events: Update GPE handling and initialization code. ACPICA: Remove extraneous error message for large number of GPEs. ACPICA: Tables: Remove old mechanism to validate if XSDT contains NULL entries. ACPICA: Tables: Add new mechanism to skip NULL entries in RSDT and XSDT. ACPICA: acpidump: Add support to force using RSDT. ACPICA: Back port of improvements on exception code. ACPICA: Back port of _PRP update. ACPICA: acpidump: Fix truncated RSDP signature validation. ACPICA: Linux header: Add support for stubbed externals. ...
2014-06-03Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull perf updates from Ingo Molnar: "The tooling changes maintained by Jiri Olsa until Arnaldo is on vacation: User visible changes: - Add -F option for specifying output fields (Namhyung Kim) - Propagate exit status of a command line workload for record command (Namhyung Kim) - Use tid for finding thread (Namhyung Kim) - Clarify the output of perf sched map plus small sched command fixes (Dongsheng Yang) - Wire up perf_regs and unwind support for ARM64 (Jean Pihet) - Factor hists statistics counts processing which in turn also fixes several bugs in TUI report command (Namhyung Kim) - Add --percentage option to control absolute/relative percentage output (Namhyung Kim) - Add --list-cmds to 'kmem', 'mem', 'lock' and 'sched', for use by completion scripts (Ramkumar Ramachandra) Development/infrastructure changes and fixes: - Android related fixes for pager and map dso resolving (Michael Lentine) - Add libdw DWARF post unwind support for ARM (Jean Pihet) - Consolidate types.h for ARM and ARM64 (Jean Pihet) - Fix possible null pointer dereference in session.c (Masanari Iida) - Cleanup, remove unused variables in map_switch_event() (Dongsheng Yang) - Remove nr_state_machine_bugs in perf latency (Dongsheng Yang) - Remove usage of trace_sched_wakeup(.success) (Peter Zijlstra) - Cleanups for perf.h header (Jiri Olsa) - Consolidate types.h and export.h within tools (Borislav Petkov) - Move u64_swap union to its single user's header, evsel.h (Borislav Petkov) - Fix for s390 to properly parse tracepoints plus test code (Alexander Yarygin) - Handle EINTR error for readn/writen (Namhyung Kim) - Add a test case for hists filtering (Namhyung Kim) - Share map_groups among threads of the same group (Arnaldo Carvalho de Melo, Jiri Olsa) - Making some code (cpu node map and report parse callchain callback) global to be usable by upcomming changes (Don Zickus) - Fix pmu object compilation error (Jiri Olsa) Kernel side changes: - intrusive uprobes fixes from Oleg Nesterov. Since the interface is admin-only, and the bug only affects user-space ("any probed jmp/call can kill the application"), we queued these fixes via the development tree, as a special exception. - more fuzzer motivated race fixes and related refactoring and robustization. - allow PMU drivers to be built as modules. (No actual module yet, because the x86 Intel uncore module wasn't ready in time for this)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) perf tools: Add automatic remapping of Android libraries perf tools: Add cat as fallback pager perf tests: Add a testcase for histogram output sorting perf tests: Factor out print_hists_*() perf tools: Introduce reset_output_field() perf tools: Get rid of obsolete hist_entry__sort_list perf hists: Reset width of output fields with header length perf tools: Skip elided sort entries perf top: Add --fields option to specify output fields perf report/tui: Fix a bug when --fields/sort is given perf tools: Add ->sort() member to struct sort_entry perf report: Add -F option to specify output fields perf tools: Call perf_hpp__init() before setting up GUI browsers perf tools: Consolidate management of default sort orders perf tools: Allow hpp fields to be sort keys perf ui: Get rid of callback from __hpp__fmt() perf tools: Consolidate output field handling to hpp format routines perf tools: Use hpp formats to sort final output perf tools: Support event grouping in hpp ->sort() perf tools: Use hpp formats to sort hist entries ...
2014-06-03Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next Pull RCU changes from Ingo Molnar: "The main RCU changes in this cycle were: - RCU torture-test changes. - variable-name renaming cleanup. - update RCU documentation. - miscellaneous fixes. - patch to suppress RCU stall warnings while sysrq requests are being processed" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (68 commits) rcu: Provide API to suppress stall warnings while sysrc runs rcu: Variable name changed in tree_plugin.h and used in tree.c torture: Remove unused definition torture: Remove __init from torture_init_begin/end torture: Check for multiple concurrent torture tests locktorture: Remove reference to nonexistent Kconfig parameter rcutorture: Run rcu_torture_writer at normal priority rcutorture: Note diffs from git commits rcutorture: Add missing destroy_timer_on_stack() rcutorture: Explicitly test synchronous grace-period primitives rcutorture: Add tests for get_state_synchronize_rcu() rcutorture: Test RCU-sched primitives in TREE_PREEMPT_RCU kernels torture: Use elapsed time to detect hangs rcutorture: Check for rcu_torture_fqs creation errors torture: Better summary diagnostics for build failures torture: Notice if an all-zero cpumask is passed inside a critical section rcutorture: Make rcu_torture_reader() use cond_resched() sched,rcu: Make cond_resched() report RCU quiescent states percpu: Fix raw_cpu_inc_return() rcutorture: Export RCU grace-period kthread wait state to rcutorture ...
2014-06-03Merge tag 'usb-3.16-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb into next Pull USB driver updates from Greg KH: "Here is the big USB driver pull request for 3.16-rc1. Nothing huge here, but lots of little things in the USB core, and in lots of drivers. Hopefully the USB power management will be work better now that it has been reworked to do per-port power control dynamically. There's also a raft of gadget driver updates and fixes, CONFIG_USB_DEBUG is finally gone now that everything has been converted over to the dynamic debug inteface, the last hold-out drivers were cleaned up and the config option removed. There were also other minor things all through the drivers/usb/ tree, the shortlog shows this pretty well. All have been in linux-next, including the very last patch, which came from linux-next to fix a build issue on some platforms" * tag 'usb-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (314 commits) usb: hub_handle_remote_wakeup() only exists for CONFIG_PM=y USB: orinoco_usb: remove CONFIG_USB_DEBUG support USB: media: lirc: igorplugusb: remove CONFIG_USB_DEBUG support USB: media: streamzap: remove CONFIG_USB_DEBUG USB: media: redrat3: remove CONFIG_USB_DEBUG usage USB: media: redrat3: remove unneeded tracing macro usb: qcserial: add additional Sierra Wireless QMI devices usb: host: max3421-hcd: Use module_spi_driver usb: host: max3421-hcd: Allow platform-data to specify Vbus polarity usb: host: max3421-hcd: fix "spi_rd8" uses dynamic stack allocation warning usb: host: max3421-hcd: Fix missing unlock in max3421_urb_enqueue() usb: qcserial: add Netgear AirCard 341U Documentation: dt-bindings: update xhci-platform DT binding for R-Car H2 and M2 usb: host: xhci-plat: add xhci_plat_start() usb: host: max3421-hcd: Fix potential NULL urb dereference Revert "usb: gadget: net2280: Add support for PLX USB338X" USB: usbip: remove CONFIG_USB_DEBUG reference USB: remove CONFIG_USB_DEBUG from defconfig files usb: resume child device when port is powered on usb: hub_handle_remote_wakeup() depends on CONFIG_PM_RUNTIME=y ...
2014-06-03Merge back earlier cpufreq material.Rafael J. Wysocki
Conflicts: arch/mips/loongson/lemote-2f/clock.c drivers/cpufreq/intel_pstate.c
2014-05-29ACPICA: acpidump: Fix repetitive table dump in -n mode.Lv Zheng
In "-n" mode, reserved tables (RSDP/RSDT/XSDT/DSDT/FACS) are dumped multiple times due a missing instance check in osl_get_bios_table(). This patch fixes this issue. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-23Merge tag 'usb-for-v3.16' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next Felipe writes: usb: patches for v3.16 merge window Not a lot here during this merge window. Mostly we just have the usual miscellaneous patches (removal of unnecessary prints, proper dependencies being added to Kconfig, build warning fixes, new device ID, etc. Other than those, the only important new features are the new support for OS Strings which should help Linux Gadget Drivers behave better under MS Windows. Also Babble Recovery implementation for MUSB on AM335x. Lastly, we also have ARCH_QCOM PHY support though phy-msm. Signed-of-by: Felipe Balbi <balbi@ti.com> Conflicts: drivers/usb/phy/phy-mv-u3d-usb.c
2014-05-22Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: " 1. Update RCU documentation. These were posted to LKML at https://lkml.org/lkml/2014/4/28/634. 2. Miscellaneous fixes. These were posted to LKML at https://lkml.org/lkml/2014/4/28/645. 3. Torture-test changes. These were posted to LKML at https://lkml.org/lkml/2014/4/28/667. 4. Variable-name renaming cleanup, sent separately due to conflicts. This was posted to LKML at https://lkml.org/lkml/2014/5/13/854. 5. Patch to suppress RCU stall warnings while sysrq requests are being processed. This patch is the RCU portions of the patch that Rik posted to LKML at https://lkml.org/lkml/2014/4/29/457. The reason for pushing this patch ahead instead of waiting until 3.17 is that the NMI-based stack traces are messing up sysrq output, and in some cases also messing up the system as well." Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-21perf tools: Add automatic remapping of Android librariesMichael Lentine
This patch automatically adjusts the path of MMAP records associated with Android system libraries. The Android system is organized with system libraries found in /system/lib and user libraries in /data/app-lib. On the host system (not running Android), system libraries can be found in the downloaded NDK directory under ${NDK_ROOT}/platforms/${APP_PLATFORM}/arch-${ARCH}/usr/lib and the user libraries are installed under libs/${APP_ABI} within the apk build directory. This patch makes running the reporting tools possible on the host system using the libraries from the NDK. Signed-off-by: Michael Lentine <mlentine@google.com> Reviewed-by: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1400579330-5043-3-git-send-email-eranian@google.com [ fixed 'space required before the open parenthesis' checkpatch.pl errors ] Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Add cat as fallback pagerMichael Lentine
This patch adds a fallback to cat for the pager. This is useful on environments, such as Android, where less does not exist. It is better to default to cat than to abort. Signed-off-by: Michael Lentine <mlentine@google.com> Reviewed-by: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1400579330-5043-2-git-send-email-eranian@google.com Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tests: Add a testcase for histogram output sortingNamhyung Kim
With new output fields option, its internal implementation was changed so add a new testcase to verify whether it breaks things. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-21-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tests: Factor out print_hists_*()Namhyung Kim
Those print helper functions can be reused by later hist test cases so factor them out to a common location. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-20-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Introduce reset_output_field()Namhyung Kim
The reset_output_field() function is for clearing output field settings and will be used for test code in later patch. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-19-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Get rid of obsolete hist_entry__sort_listNamhyung Kim
Now we moved to the perf_hpp_[_sort]_list so no need to keep the old hist_entry__sort_list and sort__first_dimension. Also the hist_entry__sort_snprintf() can be gone as hist_entry__snprintf() provides the functionality. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-18-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf hists: Reset width of output fields with header lengthNamhyung Kim
Some fields missed to set default column length so it broke align in --stdio output. Add perf_hpp__reset_width() to set it to a sane default value. Note that this change will ignore -w/--column-widths option for now. Before: $ perf report -F cpu,comm,overhead --stdio ... # CPU Command Overhead # ............... ........ # 0 firefox 2.65% 0 kworker/0:0 1.45% 0 swapper 5.52% 0 synergys 0.92% 1 firefox 4.54% After: # CPU Command Overhead # ... ............... ........ # 0 firefox 2.65% 0 kworker/0:0 1.45% 0 swapper 5.52% 0 synergys 0.92% 1 firefox 4.54% Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-17-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Skip elided sort entriesNamhyung Kim
When it converted sort entries to hpp formats, it missed se->elide handling, so add it for compatibility. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-16-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf top: Add --fields option to specify output fieldsNamhyung Kim
The --fields option is to allow user setup output field in any order. It can receive any sort keys and following (hpp) fields: overhead, overhead_sys, overhead_us, sample and period If guest profiling is enabled, overhead_guest_{sys,us} will be available too. More more information, please see previous patch "perf report: Add -F option to specify output fields" Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-15-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf report/tui: Fix a bug when --fields/sort is givenNamhyung Kim
The hists__filter_entries() function is called when down arrow key is pressed for navigating through the entries in TUI. It has a check for filtering out entries that have very small overhead (under min_pcnt). However it just assumed the entries are sorted by the overhead so when it saw such a small overheaded entry, it just stopped navigating as an optimization. But it's not true anymore due to new --fields and --sort optoin behavior and this case users cannot go down to a next entry if ther's an entry with small overhead in-between. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-14-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Add ->sort() member to struct sort_entryNamhyung Kim
Currently, what the sort_entry does is just identifying hist entries so that they can be grouped properly. However, with -F option support, it indeed needs to sort entries appropriately to be shown to users. So add ->sort() member to do it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-13-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf report: Add -F option to specify output fieldsNamhyung Kim
The -F/--fields option is to allow user setup output field in any order. It can receive any sort keys and following (hpp) fields: overhead, overhead_sys, overhead_us, sample and period If guest profiling is enabled, overhead_guest_{sys,us} will be available too. The output fields also affect sort order unless you give -s/--sort option. And any keys specified on -s option, will also be added to the output field list automatically. $ perf report -F sym,sample,overhead ... # Symbol Samples Overhead # .......................... ............ ........ # [.] __cxa_atexit 2 2.50% [.] __libc_csu_init 4 5.00% [.] __new_exitfn 3 3.75% [.] _dl_check_map_versions 1 1.25% [.] _dl_name_match_p 4 5.00% [.] _dl_setup_hash 1 1.25% [.] _dl_sysdep_start 1 1.25% [.] _init 5 6.25% [.] _setjmp 6 7.50% [.] a 8 10.00% [.] b 8 10.00% [.] brk 1 1.25% [.] c 8 10.00% Note that, the example output above is captured after applying next patch which fixes sort/comparing behavior. Requested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-12-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Call perf_hpp__init() before setting up GUI browsersNamhyung Kim
So that it can be set properly prior to set up output fields. That makes easy to handle/warn errors during the setup since it doesn't need to be bothered with the GUI. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-11-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Consolidate management of default sort ordersNamhyung Kim
The perf uses different default sort orders for different use-cases, and this was scattered throughout the code. Add get_default_sort_ order() function to handle this and change initial value of sort_order to NULL to distinguish it from user-given one. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1400480762-22852-10-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Allow hpp fields to be sort keysNamhyung Kim
Add overhead{,_sys,_us,_guest_sys,_guest_us}, sample and period sort keys so that they can be selected with --sort/-s option. $ perf report -s period,comm --stdio ... # Overhead Period Command # ........ ............ ............... # 47.06% 152 swapper 13.93% 45 qemu-system-arm 12.38% 40 synergys 3.72% 12 firefox 2.48% 8 xchat Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-9-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf ui: Get rid of callback from __hpp__fmt()Namhyung Kim
The callback was used by TUI for determining color of folded sign using percent of first field/column. But it cannot be used anymore since it now support dynamic reordering of output field. So move the logic to the hist_browser__show_entry(). Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-8-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Consolidate output field handling to hpp format routinesNamhyung Kim
Until now the hpp and sort functions do similar jobs different ways. Since the sort functions converted/wrapped to hpp formats it can do the job in a uniform way. The perf_hpp__sort_list has a list of hpp formats to sort entries and the perf_hpp__list has a list of hpp formats to print output result. To have a backward compatibility, it automatically adds 'overhead' field in front of sort list. And then all of fields in sort list added to the output list (if it's not already there). Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/n/tip-7g3h86woz2sckg3h1lj42ygj@git.kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Use hpp formats to sort final outputNamhyung Kim
Convert output sorting function to use ->sort hpp functions. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-6-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Support event grouping in hpp ->sort()Namhyung Kim
Move logic of hist_entry__sort_on_period to __hpp__sort() in order to support event group report. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-5-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Use hpp formats to sort hist entriesNamhyung Kim
It wrapped sort entries to hpp functions, so using the hpp sort list to sort entries. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-4-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Convert sort entries to hpp formatsNamhyung Kim
This is a preparation of consolidating management of output field and sort keys. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-3-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-21perf tools: Add ->cmp(), ->collapse() and ->sort() to perf_hpp_fmtNamhyung Kim
Those function pointers will be used to sort report output based on the selected fields. This is a preparation of later change. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/1400480762-22852-2-git-send-email-namhyung@kernel.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-17cpupower: Remove mc and smt power aware scheduler info/settingsThomas Renninger
These kernel interfaces got removed by: commit 8e7fbcbc22c12414bcc9dfdd683637f58fb32759 Author: Peter Zijlstra <peterz@infradead.org> Date: Mon Jan 9 11:28:35 2012 +0100 sched: Remove stale power aware scheduling remnants and dysfunctional knobs No need to further keep them as userspace configurations. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-17cpupower: cpupower info -b should return 0 on success, not the perf bias valueThomas Renninger
2014-05-17cpupower: If root, try to load msr driver on x86 if /dev/cpu/0/msr is not ↵Thomas Renninger
available Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-17cpupower: Install recently added cpupower-idle-{set, info} manpagesThomas Renninger
2014-05-17cpupower: Introduce idle state disable-by-latency and enable-allThomas Renninger
2014-05-17cpupower: Remove all manpages on make uninstallRamkumar Ramachandra
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com> Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-05-17cpupower: Remove dead link to homepage, and update the targets built.Ramkumar Ramachandra
2014-05-17cpupower: Rename cpufrequtils -> cpupower, and libcpufreq -> libcpupower.Ramkumar Ramachandra
2014-05-16perf tools: Add libdw DWARF post unwind support for ARMJean Pihet
Adding libdw DWARF post unwind support, which is part of elfutils-devel/libdw-dev package from version 0.158. The new code is contained in unwin-libdw.c object, and implements unwind__get_entries unwind interface function. Signed-off-by: Jean Pihet <jean.pihet@linaro.org> Reviewed-by: Will Deacon <will.deacon@arm.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1400229672-16104-4-git-send-email-jean.pihet@linaro.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-16perf tests: Add dwarf unwind test on ARMJean Pihet
Adding dwarf unwind test, that setups live machine data over the perf test thread and does the remote unwind. Need to use -fno-optimize-sibling-calls for test compilation, otherwise 'krava_*' function calls are optimized into jumps and omitted from the stack unwind. So far it was enabled only for x86. Signed-off-by: Jean Pihet <jean.pihet@linaro.org> Reviewed-by: Will Deacon <will.deacon@arm.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1400229672-16104-3-git-send-email-jean.pihet@linaro.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-16perf tests: Introduce perf_regs_load function on ARMJean Pihet
Introducing perf_regs_load function, which is going to be used for dwarf unwind test in following patches. It takes single argument as a pointer to the regs dump buffer and populates it with current registers values. Signed-off-by: Jean Pihet <jean.pihet@linaro.org> Reviewed-by: Will Deacon <will.deacon@arm.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1400229672-16104-2-git-send-email-jean.pihet@linaro.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-05-16perf tools: Consolidate types.h for ARM and ARM64Jean Pihet
Prevents a build breakage since commit d944c4eebcf4c0d5e5d9728fec110cbf0047ad7f 'tools: Consolidate types.h' Signed-off-by: Jean Pihet <jean.pihet@linaro.org> Link: http://lkml.kernel.org/r/1400229672-16104-1-git-send-email-jean.pihet@linaro.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
