path: root/tools
2014-08-06tools: ffs-test: fix header values endianessMichal Nazarewicz
commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream. It appears that no one ever run ffs-test on a big-endian machine, since it used cpu-endianess for fs_count and hs_count fields which should be in little-endian format. Fix by wrapping the numbers in cpu_to_le32. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02turbostat: Use GCC's CPUID functions to support PICJosh Triplett
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream. turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems that have certain security features enabled by default that make -fPIC the default, this causes a build error: turbostat.c: In function ‘check_cpuid’: turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’ asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx"); ^ GCC provides a header cpuid.h, containing a __get_cpuid function that works with both PIC and non-PIC. (On PIC, it saves and restores ebx around the cpuid instruction.) Use that instead. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-02-15cpupower: Fix segfault due to incorrect getopt_long arugmentsJosh Boyer
commit f447ef4a56dee4b68a91460bcdfe06b5011085f2 upstream. If a user calls 'cpupower set --perf-bias 15', the process will end with a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi call. This is because the getopt_long structure currently has all of the options as having an optional_argument when they really have a required argument. We change the structure to use required_argument to match the short options and it resolves the issue. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439 Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-11-28perf tools: Fix getrusage() related build failure on glibc trunkMarkus Trippelsdorf
commit 7b78f13603c6fcb64e020a0bbe31a651ea2b657b upstream. On a system running glibc trunk perf doesn't build: CC builtin-sched.o builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration] [...] Fix it by including sys/resource.h. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120404084527.GA294@x4 Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-10-26perf tools: Handle JITed code in shared memoryAndi Kleen
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream. Need to check for /dev/zero. Most likely more strings are missing too. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-09-10perf tools: Add anonymous huge page recognitionJoshua Zhu
commit d0528b5d71faf612014dd7672e44225c915344b2 upstream. Judging anonymous memory's vm_area_struct, perf_mmap_event's filename will be set to "//anon" indicating this vma belongs to anonymous memory. Once hugepage is used, vma's vm_file points to hugetlbfs. In this way, this vma will not be regarded as anonymous memory by is_anon_memory() in perf user space utility. Signed-off-by: Joshua Zhu <zhu.wen-jie@hp.com> Cc: Akihiro Nagai <akihiro.nagai.hw@hitachi.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Joshua Zhu <zhu.wen-jie@hp.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1357363797-3550-1-git-send-email-zhu.wen-jie@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-05-30perf: net_dropmonitor: Fix symbol-relative addressesBen Hutchings
commit 5a1e99dd2028e00998d42029be86835d8ef4a46e upstream. The comparison between traced and symbol addresses is backwards: if the traced address doesn't exactly match a symbol (which we don't expect it to), we'll show the next symbol and the offset to it, whereas we should show the previous symbol and the offset from it. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-30perf: net_dropmonitor: Fix trace parameter orderBen Hutchings
commit 140c3c6a2bcd2c31e2f7f5a8d59689724776c8e5 upstream. This works much better if we don't treat protocol numbers as addresses. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-27tools: hv: Netlink source address validation allows DoSTomas Hozza
commit 95a69adab9acfc3981c504737a2b6578e4d846ef upstream. The source code without this patch caused hypervkvpd to exit when it processed a spoofed Netlink packet which has been sent from an untrusted local user. Now Netlink messages with a non-zero nl_pid source address are ignored and a warning is printed into the syslog. Signed-off-by: Tomas Hozza <thozza@redhat.com> Acked-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-03-27perf: Revert duplicated commitBen Hutchings
This reverts commit 923415295307845e614589c1cce62abedd4d1731 'perf: Fix parsing of __print_flags() in TP_printk()'. The same change was already included in 3.2 as commit d06c27b22aa66e48e32f03f9387328a9af9b0625 but in 3.2.1 this change was wrongly applied to similar code in a different function. Thanks to Jiri for pointing this out in 3.0.y. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Andrew Vagin <avagin@openvz.org> Cc: Steven Rostedt <rostedt@goodmis.org>
2012-10-17kbuild: Fix gcc -x syntaxJean Delvare
commit b1e0d8b70fa31821ebca3965f2ef8619d7c5e316 upstream. The correct syntax for gcc -x is "gcc -x assembler", not "gcc -xassembler". Even though the latter happens to work, the former is what is documented in the manual page and thus what gcc wrappers such as icecream do expect. This isn't a cosmetic change. The missing space prevents icecream from recognizing compilation tasks it can't handle, leading to silent kernel miscompilations. Besides me, credits go to Michael Matz and Dirk Mueller for investigating the miscompilation issue and tracking it down to this incorrect -x parameter syntax. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Bernhard Walle <bernhard@bwalle.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Michal Marek <mmarek@suse.cz> [bwh: Backported to 3.2: drop unneeded change to arch/x86/Makefile] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-10-17tools/hv: Fix exit() error codeBen Hutchings
commit 6bb22fea25624ab593eee376fa5fb82d1b13f45a upstream. Linux native exit codes are 8-bit unsigned values. exit(-1) results in an exit code of 255, which is usually reserved for shells reporting 'command not found'. Use the portable value EXIT_FAILURE. (Not that this matters much for a daemon.) Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [bwh: Backported to 3.2: drop changes to exit() calls not in this version]
2012-07-04Tools: hv: verify origin of netlink connector messageOlaf Hering
commit bcc2c9c3fff859e0eb019fe6fec26f9b8eba795c upstream. The SuSE security team suggested to use recvfrom instead of recv to be certain that the connector message is originated from kernel. CVE-2012-2669 Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Marcus Meissner <meissner@suse.de> Signed-off-by: Sebastian Krahmer <krahmer@suse.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31USB: ffs-test: fix length argument of out function callMatthias Fend
commit eb9c5836384cd2a276254df6254ed71117983626 upstream. The out functions should only handle actual available data instead of the complete buffer. Otherwise for example the ep0_consume function will report ghost events since it tries to decode the complete buffer - which may contain partly invalid data. Signed-off-by: Matthias Fend <matthias.fend@wolfvision.net> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11Perf: fix build breakageZeev Tarantov
[Patch not needed upstream as this is a backport build bugfix - gregkh gcc correctly complains: util/hist.c: In function ‘__hists__add_entry’: util/hist.c:240:27: error: invalid type argument of ‘->’ (have ‘struct hist_entry’) util/hist.c:241:23: error: invalid type argument of ‘->’ (have ‘struct hist_entry’) for this new code: + if (he->ms.map != entry->ms.map) { + he->ms.map = entry->ms.map; + if (he->ms.map) + he->ms.map->referenced = true; + } because "entry" is a "struct hist_entry", not a pointer to a struct. In mainline, "entry" is a pointer to struct passed as argument to the function. So this is broken during backporting. But obviously not compile tested. Signed-off-by: Zeev Tarantov <zeev.tarantov@gmail.com> Cc: Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-04-22perf hists: Catch and handle out-of-date hist entry maps.David Miller
commit 63fa471dd49e9c9ce029d910d1024330d9b1b145 upstream. When a process exec()'s, all the maps are retired, but we keep the hist entries around which hold references to those outdated maps. If the same library gets mapped in for which we have hist entries, a new map will be created. But when we take a perf entry hit within that map, we'll find the existing hist entry with the older map. This causes symbol translations to be done incorrectly. For example, the perf entry processing will lookup the correct uptodate map entry and use that to calculate the symbol and DSO relative address. But later when we update the histogram we'll translate the address using the outdated map file instead leading to conditions such as out-of-range offsets in symbol__inc_addr_samples(). Therefore, update the map of the hist_entry dynamically at lookup/ creation time. Signed-off-by: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/20120327.031418.1220315351537060808.davem@davemloft.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23perf tools: Use scnprintf where applicableArnaldo Carvalho de Melo
commit e7f01d1e3d8d501deb8abeaa269d5d48a703b8b0 upstream. Several places were expecting that the value returned was the number of characters printed, not what would be printed if there was space. Fix it by using the scnprintf and vscnprintf variants we inherited from the kernel sources. Some corner cases where the number of printed characters were not accounted were fixed too. Reported-by: Anton Blanchard <anton@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/n/tip-kwxo2eh29cxmd8ilixi2005x@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23perf tools: Incorrect use of snprintf results in SEGVAnton Blanchard
commit b832796caa1fda8516464a003c8c7cc547bc20c2 upstream. I have a workload where perf top scribbles over the stack and we SEGV. What makes it interesting is that an snprintf is causing this. The workload is a c++ gem that has method names over 3000 characters long, but snprintf is designed to avoid overrunning buffers. So what went wrong? The problem is we assume snprintf returns the number of characters written: ret += repsep_snprintf(bf + ret, size - ret, "[%c] ", self->level); ... ret += repsep_snprintf(bf + ret, size - ret, "%s", self->ms.sym->name); Unfortunately this is not how snprintf works. snprintf returns the number of characters that would have been written if there was enough space. In the above case, if the first snprintf returns a value larger than size, we pass a negative size into the second snprintf and happily scribble over the stack. If you have 3000 character c++ methods thats a lot of stack to trample. This patch fixes repsep_snprintf by clamping the value at size - 1 which is the maximum snprintf can write before adding the NULL terminator. I get the sinking feeling that there are a lot of other uses of snprintf that have this same bug, we should audit them all. Cc: David Ahern <dsahern@gmail.com> Cc: Eric B Munson <emunson@mgebm.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20120307114249.44275ca3@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20perf tools: Fix perf stack to non executable on x86_64Jiri Olsa
commit 7a0153ee15575a4d07b5da8c96b79e0b0fd41a12 upstream. By adding following objects: bench/mem-memcpy-x86-64-asm.o the x86_64 perf binary ended up with executable stack. The reason was that above object are assembler sourced and is missing the GNU-stack note section. In such case the linker assumes that the final binary should not be restricted at all and mark the stack as RWX. Adding section ".note.GNU-stack" definition to mentioned object, with all flags disabled, thus omiting this object from linker stack flags decision. Problem introduced in: $ git describe ea7872b v2.6.37-rc2-19-gea7872b Reported-at: https://bugzilla.redhat.com/show_bug.cgi?id=783570 Reported-by: Clark Williams <williams@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1328100848-5630-1-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> [ committer note: Backported fix to perf/urgent (3.3-rc2+) ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-20perf evsel: Fix an issue where perf report fails to show the proper percentageNaveen N. Rao
commit a4a03fc7ef89020baca4f19174e6a43767c6d78a upstream. This patch fixes an issue where perf report shows nan% for certain perf.data files. The below is from a report for a do_fork probe: -nan% sshd [kernel.kallsyms] [k] do_fork -nan% packagekitd [kernel.kallsyms] [k] do_fork -nan% dbus-daemon [kernel.kallsyms] [k] do_fork -nan% bash [kernel.kallsyms] [k] do_fork A git bisect shows commit f3bda2c as the cause. However, looking back through the git history, I saw commit 640c03c which seems to have removed the required initialization for perf_sample->period. The problem only started showing after commit f3bda2c. The below patch re-introduces the initialization and it fixes the problem for me. With the below patch, for the same perf.data: 73.08% bash [kernel.kallsyms] [k] do_fork 8.97% 11-dhclient [kernel.kallsyms] [k] do_fork 6.41% sshd [kernel.kallsyms] [k] do_fork 3.85% 20-chrony [kernel.kallsyms] [k] do_fork 2.56% sendmail [kernel.kallsyms] [k] do_fork This patch applies over current linux-tip commit 9949284. Problem introduced in: $ git describe 640c03c v2.6.37-rc3-83-g640c03c Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Robert Richter <robert.richter@amd.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120203170113.5190.25558.stgit@localhost6.localdomain6 Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-12perf: Fix parsing of __print_flags() in TP_printk()Steven Rostedt
commit 49908a1b25d448d68fd26faca260e1850201575f upstream. A update is made to the sched:sched_switch event that adds some logic to the first parameter of the __print_flags() that shows the state of tasks. This change cause perf to fail parsing the flags. A simple fix is needed to have the parser be able to process ops within the argument. Reported-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Do no try to schedule task events if there are none lockdep, kmemcheck: Annotate ->lock in lockdep_init_map() perf header: Use event_name() to get an event name perf stat: Failure with "Operation not supported"
2011-12-07Merge branch 'perf/urgent' of git://github.com/acmel/linux into perf/urgentIngo Molnar
2011-12-06Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ftrace: Fix hash record accounting bug perf: Fix parsing of __print_flags() in TP_printk() jump_label: jump_label_inc may return before the code is patched ftrace: Remove force undef config value left for testing tracing: Restore system filter behavior tracing: fix event_subsystem ref counting
2011-12-06perf header: Use event_name() to get an event nameAndrew Vagin
perf_evsel.name may be not initialized Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arun Sharma <asharma@fb.com> Cc: devel@openvz.org Link: http://lkml.kernel.org/r/1322471015-107825-2-git-send-email-avagin@openvz.org Signed-off-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix loss of notification with multi-event perf, x86: Force IBS LVT offset assignment for family 10h perf, x86: Disable PEBS on SandyBridge chips trace_events_filter: Use rcu_assign_pointer() when setting ftrace_event_call->filter perf session: Fix crash with invalid CPU list perf python: Fix undefined symbol problem perf/x86: Enable raw event access to Intel offcore events perf: Don't use -ENOSPC for out of PMU resources perf: Do not set task_ctx pointer in cpuctx if there are no events in the context perf/x86: Fix PEBS instruction unwind oprofile, x86: Fix crash when unloading module (nmi timer mode) oprofile: Fix crash when unloading module (hr timer mode)
2011-12-05perf: Fix parsing of __print_flags() in TP_printk()Steven Rostedt
A update is made to the sched:sched_switch event that adds some logic to the first parameter of the __print_flags() that shows the state of tasks. This change cause perf to fail parsing the flags. A simple fix is needed to have the parser be able to process ops within the argument. Cc: stable@vger.kernel.org Reported-by: Andrew Vagin <avagin@openvz.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-12-05perf stat: Failure with "Operation not supported"Anton Blanchard
perf stat is failing on PowerPC: Error: open_counter returned with 95 (Operation not supported). /bin/dmesg may provide additional information. Fatal: Not all events could be opened. commit 370faf1dd046 (perf stat: Fail softly on unsupported events) added a check for failure returning ENOENT, but the POWER backend returns EOPNOTSUPP. It looks like alpha, blackfin and mips do the same. With the patch applied, things work as expected: Performance counter stats for '/bin/true': 0.362176 task-clock # 0.623 CPUs utilized 0 context-switches # 0.000 M/sec 0 CPU-migrations # 0.000 M/sec 28 page-faults # 0.077 M/sec 1,677,020 cycles # 4.630 GHz <not supported> stalled-cycles-frontend <not supported> stalled-cycles-backend 431,220 instructions # 0.26 insns per cycle 101,889 branches # 281.325 M/sec 4,145 branch-misses # 4.07% of all branches 0.000581361 seconds time elapsed Cc: <stable@kernel.org> # 3.0+ Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20111202093833.5fef7226@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-18ktest: Check parent options for iterated testsRabin Vincent
Let's say we have "OUTPUT_DIR = build/${TEST_NAME}", and we're iterating a test. In the second iteration of a test, the TEST_NAME of the test we're repeating is not used. Instead, ${TEST_NAME} appears literally: touch /home/rabin/kernel/test/build/${TEST_NAME}/.config ... SUCCESS Fix this by making __eval_option() check the parent test options for a repeated test. Link: http://lkml.kernel.org/r/1321616131-21352-2-git-send-email-rabin@rab.in Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-11-16perf session: Fix crash with invalid CPU listDavid Ahern
commit 5d67be9 added the option to specify a range of CPUs of interest, but does not catch an invalid CPU list: $ perf script -c foo Segmentation fault (core dumped) Cc: Anton Blanchard <anton@samba.org> Link: http://lkml.kernel.org/r/1321206327-5881-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-16perf python: Fix undefined symbol problemArnaldo Carvalho de Melo
Recently we made perf_evsel__init call hists__init, which broke the perf python binding: [root@emilia linux]# ./tools/perf/python/twatch.py Traceback (most recent call last): File "./tools/perf/python/twatch.py", line 16, in <module> import perf ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: hists__init Fix it by moving the hists__init function to its only caller, evsel.c. This way we avoid dragging in other parts of tools/perf/util/ to the perf python binding. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-5nffmdt5mu6ozxgj54oi4qon@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: (21 commits) ktest: Evaluate variables entered on the command line ktest: Add variable ${PWD} ktest: Add another monitor flush before installing kernel ktest: Do not opencode reboot in grub setting ktest: Add processing of complex conditionals ktest: Fix parsing of config section lines ktest: Sort make_min_config configs by dependecies ktest: Add DEFINED keyword for IF statements ktest: Add OVERRIDE keyword to DEFAULTS section ktest: Consolidate TEST_TYPE and DEFAULT code ktest: Add INCLUDE keyword to include other config files ktest: Let IF keyword take comparisons ktest: Add IF and ELSE to config sections ktest: Do not reboot on config or build issues ktest: Add option REBOOT_SUCCESS_LINE to stop waiting after a reboot ktest: Add NO_INSTALL option to not install for a test ktest: Fail when grub menu not found ktest: Include monitor in reboot code ktest: Only need to save .config when doing mrproper ktest: Create outputdir if it does not exist ...
2011-11-07Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf top: Fix live annotation in the --stdio interface perf top tui: Don't recalc column widths considering just the first page perf report: Add progress bar when processing time ordered events perf hists browser: Warn about lost events perf tools: Fix a typo of command name as trace-cmd perf hists: Fix recalculation of total_period when sorting entries perf header: Fix build on old systems perf ui browser: Handle K_RESIZE in dialog windows perf ui browser: No need to switch char sets that often perf hists browser: Use K_TIMER perf ui: Rename ui__warning_paranoid to ui__error_paranoid perf ui: Reimplement the popup windows using libslang perf ui: Reimplement ui__popup_menu using ui__browser perf ui: Reimplement ui_helpline using libslang perf ui: Improve handling sigwinch a bit perf ui progress: Reimplement using slang perf evlist: Fix grouping of multiple events
2011-11-07Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: cpuidle: Single/Global registration of idle states cpuidle: Split cpuidle_state structure and move per-cpu statistics fields cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare() cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning ACPI: Export FADT pm_profile integer value to userspace thermal: Prevent polling from happening during system suspend ACPI: Drop ACPI_NO_HARDWARE_INIT ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast() PNPACPI: Simplify disabled resource registration ACPI: Fix possible recursive locking in hwregs.c ACPI: use kstrdup() mrst pmu: update comment tools/power turbostat: less verbose debugging
2011-11-06Merge branches 'acpi', 'idle', 'mrst-pmu' and 'pm-tools' into nextLen Brown
2011-11-03perf top: Fix live annotation in the --stdio interfaceArnaldo Carvalho de Melo
In the old --stdio interface the annotation is done just after one selects a symbol, while in --tui, now the default when the required libs are installed, we annotate all symbols with samples so that when annotation is asked we see what happened recently on that symbol. To achieve that the --stdio variant checks if the hist_entry being processed is the one selected by the user via the 's' hotkey. What happens now that we share the hist_entry abstractions with 'perf report' is that for minimizing locking contention multiple rb_trees are used, one for collecting the samples and other to browse/show them after resorting it by number of samples and decay them, which is done periodically. So the simple test in record_precise_ip doesn't work as we move hist_entries between those rb_trees. To fix it just check that the underlying struct symbol associated with those hist_entries is the same. Reported-by: Mike Galbraith <efault@gmx.de> Tested-by: Mike Galbraith <efault@gmx.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-bcfnraqkux88fox9ba9767ds@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf top tui: Don't recalc column widths considering just the first pageArnaldo Carvalho de Melo
It makes sense for the stdio where we can't navigate to the other pages. On the TUI it breaks as soon as we navigate to other pages that have, DSOs with longer names than the ones on the first page. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-zvqfp18mw229agb43cikgb0k@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf report: Add progress bar when processing time ordered eventsArnaldo Carvalho de Melo
So that for large perf.data files the user can have visual feedback that activity is being performed. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-3ysn01mpspfrbsy56gznzqqz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf hists browser: Warn about lost eventsArnaldo Carvalho de Melo
Just like the old perf top --tui and the --stdio version. But because we have the initial menu to choose which event to show in a session with multiple events we can see how many chunks were lost in each of the event types, clarifying which events are being affected the most. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-47yyqbubmjzch2chezmb21m6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-28ktest: Evaluate variables entered on the command lineSteven Rostedt
When ktest.pl is called without any arguments, or if the config file does not exist, ktest.pl will ask the user for some information. Some of these questions are code paths. Allowing the user to type ${PWD} for the current directory greatly simplifies these entries. Add variable processing to the entered values. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-10-28perf tools: Fix a typo of command name as trace-cmdMasami Hiramatsu
Fix a typo which may be introduced when original code has been copied from trace-cmd. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20111004104456.14591.37395.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-27perf hists: Fix recalculation of total_period when sorting entriesArnaldo Carvalho de Melo
We were doing parts of it in hists__collapse_resort and parts of it in hists__output_resort, leading to a bogus total_period. Fix it by doing just the filtering operation when collapsing because there we know that the Zoom operations adds filters just what is in hists->entries, not to the new batch of entries being collapsed. And move all the nr_entries + total_period recalculation to hists__output_resort since we will traverse all entries anyway there. Problem introduced when developing threaded addition of new batches of hist_entries, i.e. post v3.1. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-8xyh165h7hmwy0696hu25en6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: tools, slub: Fix off-by-one buffer corruption after readlink() call slub: Discard slab page when node partial > minimum partial number slub: correct comments error for per cpu partial mm: restrict access to slab files under procfs and sysfs slub: Code optimization in get_partial_node() slub: doc: update the slabinfo.c file path slub: explicitly document position of inserting slab to partial list slub: update slabinfo tools to report per cpu partial list statistics slub: per cpu cache for partial pages slub: return object pointer from get_partial() / new_slab(). slub: pass kmem_cache_cpu pointer to get_partial() slub: Prepare inuse field in new_slab() slub: Remove useless statements in __slab_alloc slub: free slabs without holding locks slub: use print_hex_dump slab: use print_hex_dump
2011-10-26perf header: Fix build on old systemsArnaldo Carvalho de Melo
For instance, on Fedora 8: CC /home/acme/git/build/perf/util/header.o cc1: warnings being treated as errors util/header.c: In function ‘write_cpudesc’: util/header.c:281: warning: implicit declaration of function ‘getline’ util/header.c:281: warning: nested extern declaration of ‘getline’ make: *** [/home/acme/git/build/perf/util/header.o] Error 1 make: Leaving directory `/home/acme/git/linux/tools/perf' [acme@localhost linux]$ This happens due to header ordering, in perf util.h sets _GNU_SOURCE, so it must come first. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-alfra9wao63euguj7gr8jw7e@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui browser: Handle K_RESIZE in dialog windowsArnaldo Carvalho de Melo
Just provide wrappers for things like ui__warning, ui__dialog_yesno and if they return K_RESIZE, refresh dimensions, redraw the entries, etc. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-3ih7hyk9weryxaxb501sfq4u@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui browser: No need to switch char sets that oftenArnaldo Carvalho de Melo
Just before and after the loop. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-0lh91cedngyg1pqarbky5vn7@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf hists browser: Use K_TIMERArnaldo Carvalho de Melo
In the switch case entry for the timer routine. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ypw3i9kmxoq28skx7jy914it@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26perf ui: Rename ui__warning_paranoid to ui__error_paranoidArnaldo Carvalho de Melo
As it will exit the tool after the user is notified. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-vy06m8xzlvkhr8tk7nylhbng@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-26Merge branches 'slab/next' and 'slub/partial' into slab/for-linusPekka Enberg
2011-10-26perf ui: Reimplement the popup windows using libslangArnaldo Carvalho de Melo
Just another step in stopping the use of libnewt in perf. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-vtxnmz1t1807ykprapnk9njl@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
