When building tools/objtool/ it rightly complains about a number of
files being out of sync. Fix this up by syncing them properly with the
relevant in-kernel versions.
When building tools/perf/ it rightly complains about a number of .h
commit 0afd0d9e0e7879d666c1df2fa1bea4d8716909fe upstream.
Objtool has some crude logic for detecting static "noreturn" functions
(aka "dead ends"). This is necessary for being able to correctly follow
GCC code flow when such functions are called.
It's remotely possible for two functions to call each other via sibling
calls. If they don't have RET instructions, objtool's noreturn
detection logic goes into a recursive loop:
drivers/char/ipmi/ipmi_ssif.o: warning: objtool: return_hosed_msg()+0x0: infinite recursion (objtool bug!)
drivers/char/ipmi/ipmi_ssif.o: warning: objtool: deliver_recv_msg()+0x0: infinite recursion (objtool bug!)
Instead of reporting an error in this case, consider the functions to be
non-dead-ends.
Reported-and-tested-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: damian <damian.tometzki@icloud.com>
Link: http://lkml.kernel.org/r/7cc156408c5781a1f62085d352ced1fe39fe2f91.1525923412.git.jpoimboe@redhat.com
commit 7dec80ccbe310fb7e225bf21c48c672bb780ce7b upstream.
With the following commit:
fd35c88b7417 ("objtool: Support GCC 8 switch tables")
I added a "can't find switch jump table" warning, to stop covering up
silent failures if add_switch_table() can't find anything.
That warning found yet another bug in the objtool switch table detection
logic. For cases 1 and 2 (as described in the comments of
find_switch_table()), the find_symbol_containing() check doesn't adjust
the offset for RIP-relative switch jumps.
Incidentally, this bug was already fixed for case 3 with:
6f5ec2993b1f ("objtool: Detect RIP-relative switch table references")
However, that commit missed the fix for cases 1 and 2.
The different cases are now starting to look more and more alike. So
fix the bug by consolidating them into a single case, by checking the
original dynamic jump instruction in the case 3 loop.
This also simplifies the code and makes it more robust against future
switch table detection issues -- of which I'm sure there will be many...
Switch table detection has been the most fragile area of objtool, by
far. I long for the day when we'll have a GCC plugin for annotating
switch tables. Linus asked me to delay such a plugin due to the
flakiness of the plugin infrastructure in older versions of GCC, so this
rickety code is what we're stuck with for now. At least the code is now
a little simpler than it was.
Reported-by: kbuild test robot <lkp@intel.com>
Link: http://lkml.kernel.org/r/f400541613d45689086329432f3095119ffbc328.1526674218.git.jpoimboe@redhat.com
commit 6f5ec2993b1f39aed12fa6fd56e8dc2272ee8a33 upstream.
Typically a switch table can be found by detecting a .rodata access
followed an indirect jump:
1969: 4a 8b 0c e5 00 00 00 mov 0x0(,%r12,8),%rcx
1970: 00
196d: R_X86_64_32S .rodata+0x438
1971: e9 00 00 00 00 jmpq 1976 <dispc_runtime_suspend+0xb6a>
1972: R_X86_64_PC32 __x86_indirect_thunk_rcx-0x4
Randy Dunlap reported a case (seen with GCC 4.8) where the .rodata
access uses RIP-relative addressing:
19bd: 48 8b 3d 00 00 00 00 mov 0x0(%rip),%rdi # 19c4 <dispc_runtime_suspend+0xbb8>
19c0: R_X86_64_PC32 .rodata+0x45c
19c4: e9 00 00 00 00 jmpq 19c9 <dispc_runtime_suspend+0xbbd>
19c5: R_X86_64_PC32 __x86_indirect_thunk_rdi-0x4
In this case the relocation addend needs to be adjusted accordingly in
order to find the location of the switch table.
The fix is for case 3 (as described in the comments), but also make the
existing case 1 & 2 checks more precise by only adjusting the addend for
R_X86_64_PC32 relocations.
This fixes the following warnings:
drivers/video/fbdev/omap2/omapfb/dss/dispc.o: warning: objtool: dispc_runtime_suspend()+0xbb8: sibling call from callable instruction with modified stack frame
drivers/video/fbdev/omap2/omapfb/dss/dispc.o: warning: objtool: dispc_runtime_resume()+0xcc5: sibling call from callable instruction with modified stack frame
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Link: http://lkml.kernel.org/r/b6098294fd67afb69af8c47c9883d7a68bf0f8ea.1526305958.git.jpoimboe@redhat.com
commit fd35c88b74170d9335530d9abf271d5d73eb5401 upstream.
With GCC 8, some issues were found with the objtool switch table
detection.
1) In the .rodata section, immediately after the switch table, there can
be another object which contains a pointer to the function which had
the switch statement. In this case objtool wrongly considers the
function pointer to be part of the switch table. Fix it by:
a) making sure there are no pointers to the beginning of the
function; and
b) making sure there are no gaps in the switch table.
Only the former was needed, the latter adds additional protection for
future optimizations.
2) In find_switch_table(), case 1 and case 2 are missing the check to
ensure that the .rodata switch table data is anonymous, i.e. that it
isn't already associated with an ELF symbol. Fix it by adding the
same find_symbol_containing() check which is used for case 3.
This fixes the following warnings with GCC 8:
drivers/block/virtio_blk.o: warning: objtool: virtio_queue_rq()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+72
net/ipv6/icmp.o: warning: objtool: icmpv6_rcv()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+64
drivers/usb/core/quirks.o: warning: objtool: quirks_param_set()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+48
drivers/mtd/nand/raw/nand_hynix.o: warning: objtool: hynix_nand_decode_id()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+24
drivers/mtd/nand/raw/nand_samsung.o: warning: objtool: samsung_nand_decode_id()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+32
drivers/gpu/drm/nouveau/nvkm/subdev/top/gk104.o: warning: objtool: gk104_top_oneinit()+0x0: stack state mismatch: cfa1=7+8 cfa2=7+64
Cc: Randy Dunlap <rdunlap@infradead.org>
Link: http://lkml.kernel.org/r/20180510224849.xwi34d6tzheb5wgw@treble
commit 13810435b9a7014fb92eb715f77da488f3b65b99 upstream.
GCC 8 moves a lot of unlikely code out of line to "cold" subfunctions in
.text.unlikely. Properly detect the new subfunctions and treat them as
extensions of the original functions.
This fixes a bunch of warnings like:
kernel/cgroup/cgroup.o: warning: objtool: parse_cgroup_root_flags()+0x33: sibling call from callable instruction with modified stack frame
kernel/cgroup/cgroup.o: warning: objtool: cgroup_addrm_files()+0x290: sibling call from callable instruction with modified stack frame
kernel/cgroup/cgroup.o: warning: objtool: cgroup_apply_control_enable()+0x25b: sibling call from callable instruction with modified stack frame
kernel/cgroup/cgroup.o: warning: objtool: rebind_subsystems()+0x325: sibling call from callable instruction with modified stack frame
Reported-and-tested-by: damian <damian.tometzki@icloud.com>
Link: http://lkml.kernel.org/r/0965e7fcfc5f31a276f0c7f298ff770c19b68706.1525923412.git.jpoimboe@redhat.com
There are pros and cons of dealing with tools in the kernel directory.
The pros are the fact that development happens fast, and new features
can be added to the kernel and the tools at the same times. The cons
are when dealing with backported kernel patches, it can be necessary to
backport parts of the tool changes as well.
For 4.9.y so far, we have backported individual patches. That quickly
breaks down when there are minor differences between how backports were
handled, so grabbing 40+ patch long series can be difficult, not
impossible, but really frustrating to attempt.
To help mitigate this mess, here's a single big patch to sync up the
objtool logic to the 4.14.47 version of the tool. From this point
forward (after some other minor header file patches are applied), the
tool should be in sync and much easier to maintain over time.
This has survivied my limited testing, and as the codebase is identical
to 4.14.47, I'm pretty comfortable dropping this big change in here in
4.9.y. Hopefully all goes well...
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
commit a12a4e023a55f058178afea1ada3ce7bf4db94c3 upstream.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-7wj865zidu5ylf87i6i7v6z7@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 68289cbd83eaa20faef7cc818121bc8e769065de upstream.
As tools/include/linux/kernel.h has it now, with the goodies present in
the kernel.h counterpart, i.e. checking that the parameter is an array
at build time.
Link: http://lkml.kernel.org/n/tip-v0b41ivu6z6dyugbq9ffa9ez@git.kernel.org
commit 8607c1ee734d12f62c6a46abef13a510e25a1839 upstream.
To match the kernel, then look for places redefining it to make it use
this version, which checks that its parameter is an array at build time.
Link: http://lkml.kernel.org/n/tip-txlcf1im83bcbj6kh0wxmyy8@git.kernel.org
commit f6441aff8946f7fd6ab730d7eb9eba18a9ebeba4 upstream.
Will be used to adopt the more stringent version of ARRAY_SIZE(), the
one in the kernel sources.
Link: http://lkml.kernel.org/n/tip-d85dpvay1hoqscpezlntyd8x@git.kernel.org
commit 379d61b1c7d42512cded04d372f15a7e725db9e1 upstream.
With just what we will need in the upcoming changesets, the
BUILD_BUG_ON_ZERO() definition.
Link: http://lkml.kernel.org/n/tip-lw8zg7x6ttwcvqhp90mwe3vo@git.kernel.org
commit 67ef28794d7e30f33936d655f2951e8dcae7cd5a upstream.
We will need it to build tools/perf/trace/beauty/statx.h.
Link: http://lkml.kernel.org/n/tip-nin41ve2fa63lrfbdr6x57yr@git.kernel.org
commit aeafd623f866c429307e3a4a39998f5f06b4f00e upstream.
To make it nicer and easily maintainable.
Also moving the check into fixdep sub make, so its output is not
scattered around the build output.
Removing extra $$ from mman*.h checks.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/1481030331-31944-5-git-send-email-jolsa@kernel.org
[ Use /bin/sh, and 'function check() {' -> 'check () {' to make it work with busybox, in Alpine Linux, for instance ]
commit abb26210a39522a6645bce3f438ed9a26bedb11b upstream.
The fixdep tool needs to be built before everything else, because it fixes
every object dependency file.
We handle this currently by making all objects to depend on fixdep, which is
error prone and is easily forgotten when new object is added.
Instead of this, this patch force fixdep tool to be built as the first target
in the separate make session. This way we don't need to handle extra fixdep
dependencies and we are certain there's no fixdep race with any parallel make
job.
Committer notes:
Testing it:
Before:
$ rm -rf /tmp/build/perf/ ; mkdir -p /tmp/build/perf ; make -k O=/tmp/build/perf -C tools/perf install-bin
make: Entering directory '/home/acme/git/linux/tools/perf'
BUILD: Doing 'make -j4' parallel build
Auto-detecting system features:
... dwarf: [ on ]
... dwarf_getlocations: [ on ]
... glibc: [ on ]
... gtk2: [ on ]
... libaudit: [ on ]
... libbfd: [ on ]
... libelf: [ on ]
... libnuma: [ on ]
... numa_num_possible_cpus: [ on ]
... libperl: [ on ]
... libpython: [ on ]
... libslang: [ on ]
... libcrypto: [ on ]
... libunwind: [ on ]
... libdw-dwarf-unwind: [ on ]
... zlib: [ on ]
... lzma: [ on ]
... get_cpuid: [ on ]
... bpf: [ on ]
GEN /tmp/build/perf/common-cmds.h
HOSTCC /tmp/build/perf/fixdep.o
HOSTLD /tmp/build/perf/fixdep-in.o
LINK /tmp/build/perf/fixdep
MKDIR /tmp/build/perf/pmu-events/
HOSTCC /tmp/build/perf/pmu-events/json.o
HOSTCC /tmp/build/perf/pmu-events/jsmn.o
HOSTCC /tmp/build/perf/pmu-events/jevents.o
HOSTLD /tmp/build/perf/pmu-events/jevents-in.o
PERF_VERSION = 4.9.rc8.g868cd5
CC /tmp/build/perf/perf-read-vdso32
<SNIP>
After:
... dwarf: [ on ]
... glibc: [ on ]
... gtk2: [ on ]
... libbfd: [ on ]
... libelf: [ on ]
... libnuma: [ on ]
... libperl: [ on ]
... zlib: [ on ]
... lzma: [ on ]
... bpf: [ on ]
MKDIR /tmp/build/perf/fd/
CC /tmp/build/perf/fd/array.o
LD /tmp/build/perf/fd/libapi-in.o
MKDIR /tmp/build/perf/fs/
CC /tmp/build/perf/event-parse.o
CC /tmp/build/perf/fs/fs.o
PERF_VERSION = 4.9.rc8.g57a92f
CC /tmp/build/perf/event-plugin.o
CC /tmp/build/perf/fs/tracing_path.o
<SNIP>
Link: http://lkml.kernel.org/r/1481030331-31944-3-git-send-email-jolsa@kernel.org
commit 73a9bf95ed1c05698ecabe2f28c47aedfa61b52b upstream.
To aid in catching bugs when using atomics as a reference count.
This is a trimmed down version with just what is used by tools/ at
this point.
After this, the patches submitted by Elena for tools/ doing the
conversion from atomic_ to recount_ methods can be applied and tested.
To activate it, buint perf with:
make DEBUG=1 -C tools/perf
Cc: Elena Reshetova <elena.reshetova@intel.com>
Link: http://lkml.kernel.org/n/tip-dqtxsumns9ov0l9r5x398f19@git.kernel.org
commit eaa75b5117d52adf1efd3c6c3fb4bd8f97de648b upstream.
The kernel has it and some files we got from there would require us
including the userland header for that, so add it conditionally.
Link: http://lkml.kernel.org/n/tip-gmwyal7c9vzzttlyk6u59rzn@git.kernel.org
commit 2bcdeadbc094b4f6511aedea1e5b8052bf0cc89c upstream.
Will be used by refcnt.h
Link: http://lkml.kernel.org/n/tip-jszriruqfqpez1bkivwfj6qb@git.kernel.org
commit 4900653829175f60356efc279695bb23c59483c3 upstream.
From the kernel, get the gcc one and provide the fallback so that we can
continue build with other compilers, such as with clang.
Will be used by tools/arch/x86/include/asm/cmpxchg.h.
Link: http://lkml.kernel.org/n/tip-pecgz6efai4a9euuk4rxuotr@git.kernel.org
commit 12ea65390bd5a46f8a70f068eb0d48922576a781 upstream.
Move the pieces we still need to tools/include and update a few implicit
includes.
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
[ Just take the tools/include/linux/* portions of this patch - gregkh]
commit 192614010a5052fe92611c7076ef664fd9bb60e8 upstream.
To match the kernel headers structure, setting up things that are
specific to gcc or to some specific version of gcc.
It gets included by linux/compiler.h when gcc is the compiler being
used.
Cc: Joe Perches <joe@perches.com>
Link: http://lkml.kernel.org/n/tip-fabcqfq4asodq9t158hcs8t3@git.kernel.org
commit 376a5fb34b04524af501a0c5979c5920be940e05 upstream.
We dropped need for __CHECK_ENDIAN__ for linux,
this mirrors this for tools.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit b328daf3b7130098b105c18bdae694ddaad5b6e3 upstream.
I need the following functions for the radix tree:
bitmap_fill
bitmap_empty
bitmap_full
Copy the implementations from include/linux/bitmap.h
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
commit 02bc11de567273da8ab25c54336ddbb71986f38f upstream.
Adding for_each_clear_bit macro plus all its the necessary backbone
functions. Taken from related kernel code. It will be used in following
patch.
Link: http://lkml.kernel.org/n/tip-cayv2zbqi0nlmg5sjjxs1775@git.kernel.org
commit dcc914f44f065ef73685b37e59877a5bb3cb7358 upstream.
In preparation for the new 'objtool undwarf generate' command, which
will rely on 'objtool check', move the checking code from
builtin-check.c to check.c where it can be used by other commands.
Reviewed-by: Jiri Slaby <jslaby@suse.cz>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/294c5c695fd73c1a5000bbe5960a7c9bec4ee6b4.1498659915.git.jpoimboe@redhat.com
[backported by hand to 4.9, this was a pain... - gregkh]
commit d1091c7fa3d52ebce4dd3f15d04155b3469b2f90 upstream.
The BUG() macro's use of __builtin_unreachable() via the unreachable()
macro tells gcc that the instruction is a dead end, and that it's safe
to assume the current code path will not execute past the previous
instruction.
On x86, the BUG() macro is implemented with the 'ud2' instruction. When
objtool's branch analysis sees that instruction, it knows the current
code path has come to a dead end.
Peter Zijlstra has been working on a patch to change the WARN macros to
use 'ud2'. That patch will break objtool's assumption that 'ud2' is
always a dead end.
Generally it's best for objtool to avoid making those kinds of
assumptions anyway. The more ignorant it is of kernel code internals,
the better.
So create a more generic way for objtool to detect dead ends by adding
an annotation to the unreachable() macro. The annotation stores a
pointer to the end of the unreachable code path in an '__unreachable'
section. Objtool can read that section to find the dead ends.
Tested-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: http://lkml.kernel.org/r/41a6d33971462ebd944a1c60ad4bf5be86c17b77.1487712920.git.jpoimboe@redhat.com
[ Upstream commit ddd0010392d9cbcb95b53d11b7cafc67b373ab56 ]
eBPF test fails due to verifier failure because log_buf is too small.
Fixed by increasing log_buf size
Signed-off-by: Prashant Bhole <bhole_prashant_q7@lab.ntt.co.jp>
Acked-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit e3ebaa465136ecfedf9c6f4671df02bf625f8125 ]
Jin Yao reported memory corrupton in perf report with
branch info used for stack trace:
> Following command lines will cause perf crash.
> perf record -j call -g -a <application>
> perf report --branch-history
> *** Error in `perf': double free or corruption (!prev): 0x00000000104aa040 ***
> ======= Backtrace: =========
> /lib/x86_64-linux-gnu/libc.so.6(+0x77725)[0x7f6b37254725]
> /lib/x86_64-linux-gnu/libc.so.6(+0x7ff4a)[0x7f6b3725cf4a]
> /lib/x86_64-linux-gnu/libc.so.6(cfree+0x4c)[0x7f6b37260abc]
> perf[0x51b914]
> perf(hist_entry_iter__add+0x1e5)[0x51f305]
> perf[0x43cf01]
> perf[0x4fa3bf]
> perf[0x4fa923]
> perf[0x4fd396]
> perf[0x4f9614]
> perf(perf_session__process_events+0x89e)[0x4fc38e]
> perf(cmd_report+0x15d2)[0x43f202]
> perf[0x4a059f]
> perf(main+0x631)[0x427b71]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f6b371fd830]
> perf(_start+0x29)[0x427d89]
For the cumulative output, we allocate the he_cache array based on the
--max-stack option value and populate it with data from 'callchain_cursor'.
The --max-stack option value does not ensure now the limit for number of
callchain_cursor nodes, so the cumulative iter code will allocate smaller array
than it's actually needed and cause above corruption.
I think the --max-stack limit does not apply here anyway, because we add
callchain data as normal hist entries, while the --max-stack control the limit
of single entry callchain depth.
Using the callchain_cursor.nr as he_cache array count to fix this. Also
removing struct hist_entry_iter::max_stack, because there's no longer any use
for it.
We need more fixes to ensure that the branch stack code follows properly the
logic of --max-stack, which is not the case at the moment.
Original-patch-by: Jin Yao <yao.jin@linux.intel.com>
Reported-by: Jin Yao <yao.jin@linux.intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/20180216123619.GA9945@krava
[ Upstream commit ab6e9a99345131cd8e54268d1d0dc04a33f7ed11 ]
The symbol search called by machine__find_kernel_symbol_by_name is using
internally arch__compare_symbol_names function to compare 2 symbol
names, because different archs have different ways of comparing symbols.
Mostly for skipping '.' prefixes and similar.
In test 1 when we try to find matching symbols in kallsyms and vmlinux,
by address and by symbol name. When either is found we compare the pair
symbol names by simple strcmp, which is not good enough for reasons
explained in previous paragraph.
On powerpc this can cause lockup, because even thought we found the
pair, the compared names are different and don't match simple strcmp.
Following code path is executed, that leads to lockup:
- we find the pair in kallsyms by sym->start
next_pair:
- we compare the names and it fails
- we find the pair by sym->name
- the pair addresses match so we call goto next_pair
because we assume the names match in this case
Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Fixes: 031b84c407c3 ("perf probe ppc: Enable matching against dot symbols automatically")
Link: http://lkml.kernel.org/r/20180215122635.24029-10-jolsa@kernel.org
[ Upstream commit fca32340a5e8b896f57d41fd94b8b1701df25eb1 ]
Executing command 'perf stat -T -- ls' dumps core on x86 and s390.
Here is the call back chain (done on x86):
# gdb ./perf
(gdb) r stat -T -- ls
Program received signal SIGSEGV, Segmentation fault.
0x00007ffff56d1963 in vasprintf () from /lib64/libc.so.6
(gdb) where
#0 0x00007ffff56d1963 in vasprintf () from /lib64/libc.so.6
#1 0x00007ffff56ae484 in asprintf () from /lib64/libc.so.6
#2 0x00000000004f1982 in __parse_events_add_pmu (parse_state=0x7fffffffd580,
list=0xbfb970, name=0xbf3ef0 "cpu",
head_config=0xbfb930, auto_merge_stats=false) at util/parse-events.c:1233
#3 0x00000000004f1c8e in parse_events_add_pmu (parse_state=0x7fffffffd580,
head_config=0xbfb930) at util/parse-events.c:1288
#4 0x0000000000537ce3 in parse_events_parse (_parse_state=0x7fffffffd580,
scanner=0xbf4210) at util/parse-events.y:234
#5 0x00000000004f2c7a in parse_events__scanner (str=0x6b66c0
"task-clock,{instructions,cycles,cpu/cycles-t/,cpu/tx-start/}",
parse_state=0x7fffffffd580, start_token=258) at util/parse-events.c:1673
#6 0x00000000004f2e23 in parse_events (evlist=0xbe9990, str=0x6b66c0
"task-clock,{instructions,cycles,cpu/cycles-t/,cpu/tx-start/}", err=0x0)
at util/parse-events.c:1713
#7 0x000000000044e137 in add_default_attributes () at builtin-stat.c:2281
#8 0x000000000044f7b5 in cmd_stat (argc=1, argv=0x7fffffffe3b0) at
builtin-stat.c:2828
#9 0x00000000004c8b0f in run_builtin (p=0xab01a0 <commands+288>, argc=4,
argv=0x7fffffffe3b0) at perf.c:297
#10 0x00000000004c8d7c in handle_internal_command (argc=4,
argv=0x7fffffffe3b0) at perf.c:349
#11 0x00000000004c8ece in run_argv (argcp=0x7fffffffe20c,
argv=0x7fffffffe200) at perf.c:393
#12 0x00000000004c929c in main (argc=4, argv=0x7fffffffe3b0) at perf.c:537
(gdb)
It turns out that a NULL pointer is referenced. Here are the
function calls:
cmd_stat()
+---> add_default_attributes()
+---> parse_events(evsel_list, transaction_attrs, NULL);
3rd parameter set to NULL
Function parse_events(xx, xx, struct parse_events_error *err) dives
into a bison generated scanner and creates
parser state information for it first:
struct parse_events_state parse_state = {
.list = LIST_HEAD_INIT(parse_state.list),
.idx = evlist->nr_entries,
.error = err, <--- NULL POINTER !!!
.evlist = evlist,
Now various functions inside the bison scanner are called to end up in
__parse_events_add_pmu(struct parse_events_state *parse_state, ..) with
first parameter being a pointer to above structure definition.
Now the PMU event name is not found (because being executed in a VM) and
this function tries to create an error message with
asprintf(&parse_state->error.str, ....)
which references a NULL pointer and dumps core.
Fix this by providing a pointer to the necessary error information
instead of NULL. Technically only the else part is needed to avoid the
core dump, just lets be safe...
Signed-off-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20180308145735.64717-1-tmricht@linux.vnet.ibm.com
[ Upstream commit a3a4a3b37c9b911af4c375b2475cea0fd2b84d38 ]
When trying to add the "call-graph" variable for top into the
.perfconfig file, like:
[top]
call-graph = fp
I that perf_top_config() do not parse this variable.
Fix it by calling perf_default_config() when the top.call-graph variable
is set.
Signed-off-by: Yisheng Xie <xieyisheng1@huawei.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Fixes: b8cbb349061e ("perf config: Bring perf_default_config to the very beginning at main()")
Link: http://lkml.kernel.org/r/1520853957-36106-1-git-send-email-xieyisheng1@huawei.com
[ Upstream commit 88893cf787d3062c631cc20b875068eb11756e03 ]
Some tests cause the kernel to print things to the kernel log
buffer (ie. printk), in particular oops and warnings etc. However when
running all the tests in succession it's not always obvious which
test(s) caused the kernel to print something.
We can narrow it down by printing which test directory we're running
in to /dev/kmsg, if it's writable.
Example output:
[ 170.149149] kselftest: Running tests in powerpc
[ 305.300132] kworker/dying (71) used greatest stack depth: 7776 bytes
left
[ 808.915456] kselftest: Running tests in pstore
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[ Upstream commit 6c59f64b7ecf2bccbe73931d7d573d66ed13b537 ]
Fixes a segfault occurring when e.g. <TAB> is pressed multiple times in the
ncurses tmon application. The segfault is caused by incrementing
cur_thermal_record in the main function without checking if it's value reached
NR_THERMAL_RECORD immediately. Since the boundary check only occurred in
update_thermal_data a race condition existed, which lead to an attempted read
beyond the last element of the trec array.
The fix was implemented by moving the cur_thermal_record incrementation to the
update_thermal_data function using a temporary variable on which the boundary
condition is checked before updating cur_thread_record, so that the variable is
never incremented beyond the trec array's boundary.
It seems the segfault does not occur on every machine: On a HP EliteBook G4 the
segfault happens, while it does not happen on a Thinkpad T540p.
Signed-off-by: Frank Asseg <frank.asseg@objecthunter.net>
[ Upstream commit dfa453bc90eca0febff33c8d292a656e53702158 ]
Add a testcase for probe point definition. This tests
symbol, address and symbol+offset syntax. The offset
must be positive and smaller than UINT_MAX.
Link: http://lkml.kernel.org/r/152129043097.31874.14273580606301767394.stgit@devbox
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
[ Upstream commit 5fbdbed797b6d12d043a5121fdbc8d8b49d10e80 ]
Add a testcase for string type with kprobe event.
This tests good/bad syntax combinations and also
the traced data is correct in several way.
Link: http://lkml.kernel.org/r/152129038381.31874.9201387794548737554.stgit@devbox
[ Upstream commit 871bef2000968c312a4000b2f56d370dcedbc93c ]
Add a testcase for probe event argument syntax which
ensures the kprobe_events interface correctly parses
given event arguments.
Link: http://lkml.kernel.org/r/152129033679.31874.12705519603869152799.stgit@devbox
[ Upstream commit cd4a6f3ab4d80cb919d15897eb3cbc85c2009d4b ]
The subpage_prot syscall is only functional when the system is using
the Hash MMU. Since commit 5b2b80714796 ("powerpc/mm: Invalidate
subpage_prot() system call on radix platforms") it returns ENOENT when
the Radix MMU is active. Currently this just makes the test fail.
Additionally the syscall is not available if the kernel is built with
4K pages, or if CONFIG_PPC_SUBPAGE_PROT=n, in which case it returns
ENOSYS because the syscall is missing entirely.
So check explicitly for ENOENT and ENOSYS and skip if we see either of
those.
[ Upstream commit 9a606f8d55cfc932ec02172aaed4124fdc150047 ]
The memfd test requires to insert the fuse module (CONFIG_FUSE_FS).
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
Signed-off-by: Daniel Díaz <daniel.diaz@linaro.org>
[ Upstream commit 9a379e77033f02c4a071891afdf0f0a01eff8ccb ]
pstore_tests and pstore_post_reboot_tests need CONFIG_PSTORE_RAM=m
Signed-off-by: Naresh Kamboju <naresh.kamboju@linaro.org>
[ Upstream commit 941ff6f11c020913f5cddf543a9ec63475d7c082 ]
Fix two issues in the reuseport_bpf selftests that were
reported by Linaro CI:
+ ./reuseport_bpf
---- IPv4 UDP ----
Testing EBPF mod 10...
Reprograming, testing mod 5...
./reuseport_bpf: ebpf error. log:
0: (bf) r6 = r1
1: (20) r0 = *(u32 *)skb[0]
2: (97) r0 %= 10
3: (95) exit
processed 4 insns
: Operation not permitted
+ echo FAIL
---- IPv4 TCP ----
./reuseport_bpf: failed to bind send socket: Address already in use
+ echo FAIL
For the former adjust rlimit since this was the cause of
failure for loading the BPF prog, and for the latter add
SO_REUSEADDR.
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Link: https://bugs.linaro.org/show_bug.cgi?id=3502
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit e3d91b0ca523d53158f435a3e13df7f0cb360ea2 ]
V3: More generic skipping of relo-section (suggested by Daniel)
If clang >= 4.0.1 is missing the option '-target bpf', it will cause
llc/llvm to create two ELF sections for "Exception Frames", with
section names '.eh_frame' and '.rel.eh_frame'.
The BPF ELF loader library libbpf fails when loading files with these
sections. The other in-kernel BPF ELF loader in samples/bpf/bpf_load.c,
handle this gracefully. And iproute2 loader also seems to work with these
"eh" sections.
The issue in libbpf is caused by bpf_object__elf_collect() skipping
some sections, and later when performing relocation it will be
pointing to a skipped section, as these sections cannot be found by
bpf_object__find_prog_by_idx() in bpf_object__collect_reloc().
This is a general issue that also occurs for other sections, like
debug sections which are also skipped and can have relo section.
As suggested by Daniel. To avoid keeping state about all skipped
sections, instead perform a direct qlookup in the ELF object. Lookup
the section that the relo-section points to and check if it contains
executable machine instructions (denoted by the sh_flags
SHF_EXECINSTR). Use this check to also skip irrelevant relo-sections.
Note, for samples/bpf/ the '-target bpf' parameter to clang cannot be used
due to incompatibility with asm embedded headers, that some of the samples
include. This is explained in more details by Yonghong Song in bpf_devel_QA.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit 81fccd6ca507d3b2012eaf1edeb9b1dbf4bd22db ]
In x86 architecture dependend part function get_cpuid_str() mallocs a
128 byte buffer, but does not check if the memory allocation succeeded
or not.
When the memory allocation fails, function __get_cpuid() is called with
first parameter being a NULL pointer. However this function references
its first parameter and operates on a NULL pointer which might cause
core dumps.
Link: http://lkml.kernel.org/r/20180117131611.34319-1-tmricht@linux.vnet.ibm.com
[ Upstream commit d777f8de99b05d399c0e4e51cdce016f26bd971b ]
If a field is a dynamic string, get_field_str() returned just the
offset/size value and not the string. Have it parse the offset/size
correctly to return the actual string. Otherwise filtering fails when
trying to filter fields that are dynamic strings.
Reported-by: Gopanapalli Pradeep <prap_hai@yahoo.com>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/20180112004823.146333275@goodmis.org
[ Upstream commit 249d98e567e25dd03e015e2d31e1b7b9648f34df ]
When setting the "dwarf" unwinder for a specific event and not
specifying the max-stack, the attr.sample_max_stack ended up using an
uninitialized callchain_param.max_stack, fix it by using designated
initializers for that callchain_param variable, zeroing all non
explicitely initialized struct members.
Here is what happened:
# perf trace -vv --no-syscalls --max-stack 4 -e probe_libc:inet_pton/call-graph=dwarf/ ping -6 -c 1 ::1
callchain: type DWARF
callchain: stack dump size 8192
perf_event_attr:
type 2
size 112
config 0x730
{ sample_period, sample_freq } 1
sample_type IP|TID|TIME|ADDR|CALLCHAIN|CPU|PERIOD|RAW|REGS_USER|STACK_USER|DATA_SRC
exclude_callchain_user 1
{ wakeup_events, wakeup_watermark } 1
sample_regs_user 0xff0fff
sample_stack_user 8192
sample_max_stack 50656
sys_perf_event_open failed, error -75
Value too large for defined data type
perf_event_attr:
type 2
size 112
config 0x730
sample_max_stack 30448
Now the attr.sample_max_stack is set to zero and the above works as
expected:
# perf trace --no-syscalls --max-stack 4 -e probe_libc:inet_pton/call-graph=dwarf/ ping -6 -c 1 ::1
PING ::1(::1) 56 data bytes
64 bytes from ::1: icmp_seq=1 ttl=64 time=0.072 ms
--- ::1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 0.072/0.072/0.072/0.000 ms
0.000 probe_libc:inet_pton:(7feb7a998350))
__inet_pton (inlined)
gaih_inet.constprop.7 (/usr/lib64/libc-2.26.so)
__GI_getaddrinfo (inlined)
[0xffffaa39b6108f3f] (/usr/bin/ping)
Cc: Hendrick Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Thomas Richter <tmricht@linux.vnet.ibm.com>
Link: https://lkml.kernel.org/n/tip-is9tramondqa9jlxxsgcm9iz@git.kernel.org
[ Upstream commit 38d70b7ca1769f26c0b79f3c08ff2cc949712b59 ]
When processing %pX in pretty_print(), simplify the logic slightly by
incrementing the ptr to the format string if isalnum(ptr[1]) is true.
This follows the logic a bit more closely to what is in the kernel.
Also, this fixes a small bug where %pF was not giving the offset of the
function.
Link: http://lkml.kernel.org/r/20180112004822.260262257@goodmis.org
commit 00a02d0c502a06d15e07b857f8ff921e3e402675 upstream
If a seccomp user is not interested in Speculative Store Bypass mitigation
by default, it can set the new SECCOMP_FILTER_FLAG_SPEC_ALLOW flag when
adding filters.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit e538409257d0217a9bc715686100a5328db75a15 upstream.
Commit 65c79230576 tried to clear the custom firmware path on exit by
writing a single space to the firmware_class.path parameter. This
doesn't work because nothing strips this space from the value stored
and fw_get_filesystem_firmware() only ignores zero-length paths.
Instead, write a null byte.
Fixes: 0a8adf58475 ("test: add firmware_class loader test")
Fixes: 65c79230576 ("test_firmware: fix setting old custom fw path back on exit")
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Acked-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: stable <stable@vger.kernel.org>
commit ad343a98e74e85aa91d844310e797f96fee6983b upstream.
Use a separate fd set for select()-s exception fds param to fix the
following gcc warning:
pager.c:36:12: error: passing argument 2 to restrict-qualified parameter aliases with argument 4 [-Werror=restrict]
select(1, &in, NULL, &in, NULL);
Link: http://lkml.kernel.org/r/20180101105626.7168-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Fredrik Schön <fredrikschon@gmail.com>
commit 854e55ad289ef8888e7991f0ada85d5846f5afb9 upstream.
Starting with recent GCC 8 builds, objtool and perf fail to build with
the following error:
../str_error_r.c: In function ‘str_error_r’:
../str_error_r.c:25:3: error: passing argument 1 to restrict-qualified parameter aliases with argument 5 [-Werror=restrict]
snprintf(buf, buflen, "INTERNAL ERROR: strerror_r(%d, %p, %zd)=%d", errnum, buf, buflen, err);
The code seems harmless, but there's probably no benefit in printing the
'buf' pointer in this situation anyway, so just remove it to make GCC
happy.
Reported-by: Laura Abbott <labbott@redhat.com>
Tested-by: Laura Abbott <labbott@redhat.com>
Link: http://lkml.kernel.org/r/20180316031154.juk2uncs7baffctp@treble
