path: root/tools
2012-04-20perf symbols: Read plt symbols from proper symtab_type binaryJiri Olsa
When loading symbols from DSO we check multiple paths of DSO binary until we succeed to load symbols ('.symtab' section). Once symbols are read we try to load also plt symbols. During the reading of plt symbols, the dso file is reopened from location given by dso->long_name. This could be wrong in case we want process buildid binaries. The change is to make the plt symbols being read from the DSO path, that normal symbols were read from. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1334756818-6631-1-git-send-email-jolsa@redhat.com [ committer note: moved dso to be the first parameter of that function ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-17perf tools: Add 'G' and 'H' modifiers to event parsingGleb Natapov
They were dropped during conversion of event parser. Add test case to make sure this will not happen again. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/20120417111345.GK11918@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-16perf tools: Drop CROSS_COMPILE from flex and bison callsOtavio Salvador
The flex and bison tools generate arch-independent C code so its binaries are not prefixed with the target-arch prefix. With this patch the Linux 3.4-rc2 can be successfuly build on OE-Core. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Link: http://lkml.kernel.org/r/1334148270-13139-1-git-send-email-otavio@ossystems.com.br Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-16perf report: Fix crash showing warning related to kernel mapsDavid Ahern
While testing https://lkml.org/lkml/2012/4/10/123 I hit this crash: (gdb) bt 0 0x000000000042000f in __cmd_report (rep=0x7fff80cec580) at builtin-report.c:380 1 cmd_report (argc=0, argv=<optimized out>, prefix=<optimized out>) at builtin-report.c:759 2 0x0000000000414513 in run_builtin (p=0x7724a8, argc=3, argv=0x7fff80ceca70) at perf.c:273 3 0x0000000000413d41 in handle_internal_command (argv=0x7fff80ceca70, argc=3) at perf.c:345 4 run_argv (argv=0x7fff80cec880, argcp=0x7fff80cec88c) at perf.c:389 5 main (argc=3, argv=0x7fff80ceca70) at perf.c:487 kernel_map can be NULL, so need to handle it while dumping a warning to user. v2: - fixed RB_EMPTY_ROOT check -- desc takes the altnerative output when RB_EMPTY_ROOT is false. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Link: http://lkml.kernel.org/r/1334544855-55021-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-15Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf tooling fixes from Arnaldo Carvalho de Melo: . Properly handle ~/.debug, the build id cache, when it is a symlink, fix from Chanho Park . Fixes for the parser generation process, from Jiri Olsa and Namhyung Kim . Fix build when NO_GTK2 is specified, From Stephane Eranian . When a machine is not found, bump the relevant error stat but return 0, so that we correctly move to the next perf event. Fix from Jiri Olsa Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-04-14perf archive: Correct cutting of symbolic linkChanho Park
If a '$PERF_BUILDID_DIR'(typically $HOME/.debug) is a symbolic link directory, cutting of the path will fail. Here is an example where a buildid directory is a symbolic link. / # ls -al /root lrwxrwxrwx 1 root root 13 Mar 26 2012 /root -> opt/home/root / # cd ~ /opt/home/root # perf record -a -g sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.322 MB perf.data (~14057 samples) ] /opt/home/root # perf archive tar: Removing leading `/' from member names Now please run: $ tar xvf perf.data.tar.bz2 -C ~/.debug wherever you need to run 'perf report' on. /opt/home/root # mkdir temp /opt/home/root # tar xf perf.data.tar.bz2 -C ./temp /opt/home/root # find ./temp -name "*kernel*" ./temp/opt/home/root/.debug/[kernel.kallsyms] -> If successfully cut off the path, [kernel.kallsyms] is located in top of the archived file. This patch enables to cut correctly even if the buildid directory is a symbolic link. Signed-off-by: Chanho Park <chanho61.park@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333348109-12598-1-git-send-email-chanho61.park@samsung.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-14perf tools: Ignore auto-generated bison/flex filesNamhyung Kim
The commit 65f3e56e0c81 ("perf tools: Remove auto-generated bison/flex files") removed those files from git, so they'll be listed on untracked files after building perf. Fix it. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333948274-20043-1-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-14perf tools: Fix parsers' rules to dependenciesJiri Olsa
Currently the parsers objects (bison/flex related) are each time perf is built. No matter the generated files are already in place, the parser generation is executed every time. Changing the rules to have proper flex/bison objects generation dependencies. The parsers code is not rebuilt until the flex/bison source files are touched. Also when flex/bison source is changed, only dependent objects are rebuilt. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1334140791-3024-1-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-13Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull various perf tooling fixes from Arnaldo Carvalho de Melo.
2012-04-12Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull trivial perf build failure fix from Thomas Gleixner. * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix getrusage() related build failure on glibc trunk
2012-04-12perf tools: fix NO_GTK2 Makefile config errorStephane Eranian
In case the user specified NO_GTK2 on the make cmdline, compilation would fail with undefined symbol because the Makefile would not set the correct cpp variable: NO_GTK2 vs. NO_GTK2_SUPPORT. This patch renames the variable to the correct name. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120410103513.GA9229@quad Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-12perf session: Skip event correctly for unknown id/machineJiri Olsa
In case the perf_session__process_event function fails, we estimate the next event offset. This is not necessary for sample event failing on unknown ID or machine. In such case we know proper size of the event, so we dont need to guess. Also failure statistics are updated correctly so we don't miss any information. Forcing perf_session__process_event to return 0 in case of unknown ID or machine. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1334233262-5679-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-11perf kvm: Finding struct machine fails for PERF_RECORD_MMAPNikunj A. Dadhania
Running 'perf kvm --host --guest --guestmount /tmp/guestmount record -a -g -- sleep 2' Was resulting in a segfault. For event type PERF_RECORD_MMAP, event->ip.pid is being used in perf_session__find_machine_for_cpumode, which is not correct. The event->ip.pid field happens to be 0 in this case and results in returning a NULL machine object. Finally, access to self->pid in machine__mmap_name, results in a segfault later. For PERF_RECORD_MMAP type, pass event->mmap.pid. Signed-off-by: Nikunj A. Dadhania <nikunj@linux.vnet.ibm.com> Reviewed-by: David Ahern <dsahern@gmail.com> Tested-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Nikunj A. Dadhania <nikunj@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20120409081835.10576.22018.stgit@abhimanyu.in.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf annotate: Validate addr in symbol__inc_addr_samplesArnaldo Carvalho de Melo
This routine was checking only if the provided address was after sym->end, not if it was before sym->start. Fix that by checking for both and return in both cases -ERANGE, so that tools can communicate this to the user properly, or if they chose so, to abort. This problem was reported previously but the fixes involved either doing what was being done for the > end case, i.e. silently drop the sample, returning 0, or aborting at this function, which is in a lib (or better, is slated to be at some point) and shouldn't abort. The 'report' tool already checks this value and uses pr_debug to warn the user. This patch makes the 'top' tool check it too and warn once per map where such range problem takes place. Reported-by: David Miller <davem@davemloft.net> Reported-by: Sorin Dumitru <dumitru.sorin87@gmail.com> Reported-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-lw8gs7p9i9nhldilo82tzpne@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf hists browser: Fix NULL deref in hists browsing codeJiri Olsa
If there's an event with no samples in data file, the perf report command can segfault after entering the event details menu. Following steps reproduce the issue: # ./perf record -e syscalls:sys_enter_kexec_load,syscalls:sys_enter_mmap ls # ./perf report # enter '0 syscalls:sys_enter_kexec_load' menu # pres ENTER twice Above steps are valid assuming ls wont run kexec.. ;) The check for sellection to be NULL is missing. The fix makes sure it's being check. Above steps now endup with menu being displayed allowing 'Exit' as the only option. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333570898-10505-2-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf hists: Catch and handle out-of-date hist entry maps.David Miller
When a process exec()'s, all the maps are retired, but we keep the hist entries around which hold references to those outdated maps. If the same library gets mapped in for which we have hist entries, a new map will be created. But when we take a perf entry hit within that map, we'll find the existing hist entry with the older map. This causes symbol translations to be done incorrectly. For example, the perf entry processing will lookup the correct uptodate map entry and use that to calculate the symbol and DSO relative address. But later when we update the histogram we'll translate the address using the outdated map file instead leading to conditions such as out-of-range offsets in symbol__inc_addr_samples(). Therefore, update the map of the hist_entry dynamically at lookup/ creation time. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/20120327.031418.1220315351537060808.davem@davemloft.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf annotate: Fix hist decayArnaldo Carvalho de Melo
We were only decaying the entries for the offsets that were associated with an objdump line. That way, when we accrued the whole instruction addr range, more than 100% was appearing in some cases in the live annotation TUI. Fix it by not traversing the source code line at all, just iterate thru the complete addr range decaying each one. Reported-by: Mike Galbraith <mgalbraith@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-hcae5oxa22syjrnalsxz7s6n@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-05perf top: Add intel_idle to the skip listArnaldo Carvalho de Melo
TODO: Accrue the cycles in the skip_list to an idle total, and show this on the 'top' UI, as suggested by Steven. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-9nfecmgghgl5747rjxqpc28f@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-04perf tools: Fix getrusage() related build failure on glibc trunkMarkus Trippelsdorf
On a system running glibc trunk perf doesn't build: CC builtin-sched.o builtin-sched.c: In function ‘get_cpu_usage_nsec_parent’: builtin-sched.c:399:16: error: storage size of ‘ru’ isn’t known builtin-sched.c:403:2: error: implicit declaration of function ‘getrusage’ [-Werror=implicit-function-declaration] [...] Fix it by including sys/resource.h. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120404084527.GA294@x4 Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-31Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates and fixes from Ingo Molnar: "It's mostly fixes, but there's also two late items: - preliminary GTK GUI support for perf report - PMU raw event format descriptors in sysfs, to be parsed by tooling The raw event format in sysfs is a new ABI. For example for the 'CPU' PMU we have: aldebaran:~> ll /sys/bus/event_source/devices/cpu/format/* -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/any -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/cmask -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/edge -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/event -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/inv -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/offcore_rsp -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/pc -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/umask those lists of fields contain a specific format: aldebaran:~> cat /sys/bus/event_source/devices/cpu/format/offcore_rsp config1:0-63 So, those who wish to specify raw events can now use the following event format: -e cpu/cmask=1,event=2,umask=3 Most people will not want to specify any events (let alone raw events), they'll just use whatever default event the tools use. But for more obscure PMU events that have no cross-architecture generic events the above syntax is more usable and a bit more structured than specifying hex numbers." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) perf tools: Remove auto-generated bison/flex files perf annotate: Fix off by one symbol hist size allocation and hit accounting perf tools: Add missing ref-cycles event back to event parser perf annotate: addr2line wants addresses in same format as objdump perf probe: Finder fails to resolve function name to address tracing: Fix ent_size in trace output perf symbols: Handle NULL dso in dso__name_len perf symbols: Do not include libgen.h perf tools: Fix bug in raw sample parsing perf tools: Fix display of first level of callchains perf tools: Switch module.h into export.h perf: Move mmap page data_head offset assertion out of header perf: Fix mmap_page capabilities and docs perf diff: Fix to work with new hists design perf tools: Fix modifier to be applied on correct events perf tools: Fix various casting issues for 32 bits perf tools: Simplify event_read_id exit path tracing: Fix ftrace stack trace entries tracing: Move the tracing_on/off() declarations into CONFIG_TRACING perf report: Add a simple GTK2-based 'perf report' browser ...
2012-03-31Merge branch 'perf/urgent' of ↵Ingo Molnar
2012-03-30Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & Power Management changes from Len Brown: - ACPI 5.0 after-ripples, ACPICA/Linux divergence cleanup - cpuidle evolving, more ARM use - thermal sub-system evolving, ditto - assorted other PM bits Fix up conflicts in various cpuidle implementations due to ARM cpuidle cleanups (ARM at91 self-refresh and cpu idle code rewritten into "standby" in asm conflicting with the consolidation of cpuidle time keeping), trivial SH include file context conflict and RCU tracing fixes in generic code. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (77 commits) ACPI throttling: fix endian bug in acpi_read_throttling_status() Disable MCP limit exceeded messages from Intel IPS driver ACPI video: Don't start video device until its associated input device has been allocated ACPI video: Harden video bus adding. ACPI: Add support for exposing BGRT data ACPI: export acpi_kobj ACPI: Fix logic for removing mappings in 'acpi_unmap' CPER failed to handle generic error records with multiple sections ACPI: Clean redundant codes in scan.c ACPI: Fix unprotected smp_processor_id() in acpi_processor_cst_has_changed() ACPI: consistently use should_use_kmap() PNPACPI: Fix device ref leaking in acpi_pnp_match ACPI: Fix use-after-free in acpi_map_lsapic ACPI: processor_driver: add missing kfree ACPI, APEI: Fix incorrect APEI register bit width check and usage Update documentation for parameter *notrigger* in einj.txt ACPI, APEI, EINJ, new parameter to control trigger action ACPI, APEI, EINJ, limit the range of einj_param ACPI, APEI, Fix ERST header length check cpuidle: power_usage should be declared signed integer ...
2012-03-30perf tools: Remove auto-generated bison/flex filesIngo Molnar
These should not be in the Git history - they are auto-generated. Extend the Makefile rules of the parser files to include the generation run. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120327183335.GA27621@gmail.com [ committer note: Fixed up O= handling ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-29tools turbostat: harden against cpu online/offlineLen Brown
Sometimes users have turbostat running in interval mode when they take processors offline/online. Previously, turbostat would survive, but not gracefully. Tighten up the error checking so turbostat notices changesn sooner, and print just 1 line on change: turbostat: re-initialized with num_cpus %d Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-29tools turbostat: reduce measurement overhead due to IPIsLen Brown
turbostat uses /dev/cpu/*/msr interface to read MSRs. For modern systems, it reads 10 MSR/CPU. This can be observed as 10 "Function Call Interrupts" per CPU per sample added to /proc/interrupts. This overhead is measurable on large idle systems, and as Yoquan Song pointed out, it can even trick cpuidle into thinking the system is busy. Here turbostat re-schedules itself in-turn to each CPU so that its MSR reads will always be local. This replaces the 10 "Function Call Interrupts" with a single "Rescheduling interrupt" per sample per CPU. On an idle 32-CPU system, this shifts some residency from the shallow c1 state to the deeper c7 state: # ./turbostat.old -s %c0 GHz TSC %c1 %c3 %c6 %c7 %pc2 %pc3 %pc6 %pc7 0.27 1.29 2.29 0.95 0.02 0.00 98.77 20.23 0.00 77.41 0.00 0.25 1.24 2.29 0.98 0.02 0.00 98.75 20.34 0.03 77.74 0.00 0.27 1.22 2.29 0.54 0.00 0.00 99.18 20.64 0.00 77.70 0.00 0.26 1.22 2.29 1.22 0.00 0.00 98.52 20.22 0.00 77.74 0.00 0.26 1.38 2.29 0.78 0.02 0.00 98.95 20.51 0.05 77.56 0.00 ^C i# ./turbostat.new -s %c0 GHz TSC %c1 %c3 %c6 %c7 %pc2 %pc3 %pc6 %pc7 0.27 1.20 2.29 0.24 0.01 0.00 99.49 20.58 0.00 78.20 0.00 0.27 1.22 2.29 0.25 0.00 0.00 99.48 20.79 0.00 77.85 0.00 0.27 1.20 2.29 0.25 0.02 0.00 99.46 20.71 0.03 77.89 0.00 0.28 1.26 2.29 0.25 0.01 0.00 99.46 20.89 0.02 77.67 0.00 0.27 1.20 2.29 0.24 0.01 0.00 99.48 20.65 0.00 78.04 0.00 cc: Youquan Song <youquan.song@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutilsLinus Torvalds
Pull cpupower updates from Dominik Brodowski. * git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils: cpupower tools: add install target to the debug tools' makefiles cpupower tools: allow to build debug tools in a separate directory too cpupower: Fix broken mask values cpupower tool: allow to build in a separate directory cpupower tool: makefile: simplify the recipe used to generate cpupower.pot target cpupower tool: remove use of undefined variables from the clean target of the top makefile cpupower: Fix linking with --as-needed cpupower: Remove unneeded code and by that fix a memleak cpupower: Fix number of idle states cpupower: Unify cpupower-frequency-* manpages cpupower: Add cpupower-idle-info manpage cpupower: AMD fam14h/Ontario monitor can also be used by fam12h cpus cpupower: Better interface for accessing AMD pci registers
2012-03-29perf annotate: Fix off by one symbol hist size allocation and hit accountingArnaldo Carvalho de Melo
We were not noticing it because symbol__inc_addr_samples was erroneously dropping samples that hit the last byte in a function. Working on a fix for a problem reported by David Miller, Stephane Eranian and Sorin Dumitru, where addresses < sym->start were causing problems, I noticed this other problem. Cc: David Ahern <dsahern@gmail.com> Cc: David Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sorin Dumitru <dumitru.sorin87@gmail.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-pqjaq4cr1xs2xen73pjhbav4@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-29tools turbostat: add summary optionLen Brown
turbostat -s cuts down on the amount of output, per user request. also treak some output whitespace and the man page. Signed-off-by: Len Brown <len.brown@intel.com>
2012-03-29perf tools: Add missing ref-cycles event back to event parserNamhyung Kim
The commit 89812fc81f8d ("perf tools: Add parser generator for events parsing") changed event parsing engine but missed the ref-cycles event. Add it. Signed-off-by: Namhyung Kim <namhyung.kim@lge.com> Acked-by: Jiri Olsa <jolsa@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1333016517-10591-1-git-send-email-namhyung.kim@lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-28mm: move hugepage test examples to tools/testing/selftests/vmDave Young
hugepage-mmap.c, hugepage-shm.c and map_hugetlb.c in Documentation/vm are simple pass/fail tests, It's better to promote them to tools/testing/selftests. Thanks suggestion of Andrew Morton about this. They all need firstly setting up proper nr_hugepages and hugepage-mmap need to mount hugetlbfs. So I add a shell script run_vmtests to do such work which will call the three test programs and check the return value of them. Changes to original code including below: a. add run_vmtests script b. return error when read_bytes mismatch with writed bytes. c. coding style fixes: do not use assignment in if condition [akpm@linux-foundation.org: build the targets before trying to execute them] [akpm@linux-foundation.org: Documentation/vm/ no longer has a Makefile. Fixes "make clean"] Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move slabinfo.c to tools/vmDave Young
We have tools/vm/ folder for vm tools, so move slabinfo.c from tools/slub/ to tools/vm/ Signed-off-by: Dave Young <dyoung@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28mm: move page-types.c from Documentation to tools/vmDave Young
tools/ is the better place for vm tools which are used by many people. Moving them to tools also make them open to more users instead of hide in Documentation folder. This patch moves page-types.c to tools/vm/page-types.c. Also add a Makefile in tools/vm and fix two coding style problems: a) change const arrary to 'const char * const', b) change a space to tab for indent. Signed-off-by: Dave Young <dyoung@redhat.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28selftests/Makefile: make `run_tests' depend on `all'Andrew Morton
So a "make run_tests" will build the tests before trying to run them. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28selftests: launch individual selftests from the main MakefileFrederic Weisbecker
Remove the run_tests script and launch the selftests by calling "make run_tests" from the selftests top directory instead. This delegates to the Makefile in each selftest directory, where it is decided how to launch the local test. This removes the need to add each selftest directory to the now removed "run_tests" top script. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Dave Young <dyoung@redhat.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28perf annotate: addr2line wants addresses in same format as objdumpDavid Miller
Therefore, in symbol__get_source_line(), use map__rip_2objdump instead of calling map->unmap_ip() unconditionally. Link: http://lkml.kernel.org/r/20120325.162812.59519424882536855.davem@davemloft.net Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-28perf probe: Finder fails to resolve function name to addressPrashanth Nageshappa
If DIE entries corresponding to declarations appear before definition entry, probe finder returns error instead of continuing to look further for a definition entry. This patch ensures we reach to the DIE entry corresponding to the definition and get the function address. V2: A simpler solution based on Masami's suggestion. Signed-off-by: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/4F703FB9.9020407@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Name string overrun fix in gianfar driver from Joe Perches. 2) VHOST bug fixes from Michael S. Tsirkin and Nadav Har'El 3) Fix dependencies on xt_LOG netfilter module, from Pablo Neira Ayuso. 4) Fix RCU locking in xt_CT, also from Pablo Neira Ayuso. 5) Add a parameter to skb_add_rx_frag() so we can fix the truesize adjustments in the drivers that use it. The individual drivers aren't fixed by this commit, but will be dealt with using follow-on commits. From Eric Dumazet. 6) Add some device IDs to qmi_wwan driver, from Andrew Bird. 7) Fix a potential rcu_read_lock() imbalancein rt6_fill_node(). From Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: net: fix a potential rcu_read_lock() imbalance in rt6_fill_node() net: add a truesize parameter to skb_add_rx_frag() gianfar: Fix possible overrun and simplify interrupt name field creation USB: qmi_wwan: Add ZTE (Vodafone) K3570-Z and K3571-Z net interfaces USB: option: Ignore ZTE (Vodafone) K3570/71 net interfaces USB: qmi_wwan: Add ZTE (Vodafone) K3565-Z and K4505-Z net interfaces qlcnic: Bug fix for LRO netfilter: nf_conntrack: permanently attach timeout policy to conntrack netfilter: xt_CT: fix assignation of the generic protocol tracker netfilter: xt_CT: missing rcu_read_lock section in timeout assignment netfilter: cttimeout: fix dependency with l4protocol conntrack module netfilter: xt_LOG: use CONFIG_IP6_NF_IPTABLES instead of CONFIG_IPV6 vhost: fix release path lockdep checks vhost: don't forget to schedule() tools/virtio: stub out strong barriers tools/virtio: add linux/hrtimer.h stub tools/virtio: add linux/module.h stub
2012-03-27perf symbols: Handle NULL dso in dso__name_lenDavid Miller
We should use "[unknown]" in this case, in concert with the code in _hist_entry__dso_snprintf(). Otherwise we'll crash when recomputing the histogram column lengths in hists__calc_col_len(). Signed-off-by: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/20120325.162822.2267799792062571623.davem@davemloft.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-27perf symbols: Do not include libgen.hDavid Miller
That causes us to end up using the XPG version of basename which can modify it's argument. Signed-off-by: David S. Miller <davem@davemloft.net> Link: http://lkml.kernel.org/r/20120327.000301.1122788061724345175.davem@davemloft.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-26perf tools: Fix bug in raw sample parsingStephane Eranian
In perf_event__parse_sample(), the array variable was not incremented by the amount of data used by the raw_data. That was okay until we added PERF_SAMPLE_BRANCH_STACK which depends on the array variable pointing to the beginning of the branch stack data. But that was not the case if branch stack was combined with raw mode sampling. That led to bogus branch stack addresses and count. The bug would show up with: $ perf record -R -b foo This patch fixes the problem by correctly moving the array pointer forward for RAW samples. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120317222317.GA8803@quad [ committer note: Fix also later submitted by Jiri Olsa ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-26perf tools: Fix display of first level of callchainsFrederic Weisbecker
The callchain stdio mode display was written using a sorted by symbol report. In this mode we have only one callchain root per hist so we forgot to handle cases where we have multiple callchain root, as in per dso sorting for example. Fix this by handling these roots like any other branch, with the hist as the parent. Before: 1.97% libpthread-2.12.1.so | --- __libc_write create_worker bench_sched_messaging cmd_bench run_builtin main __libc_start_main | --- __libc_read create_worker bench_sched_messaging cmd_bench run_builtin main __libc_start_main After: 1.97% libpthread-2.12.1.so | |--36.97%-- __libc_write | create_worker | bench_sched_messaging | cmd_bench | run_builtin | main | __libc_start_main | |--31.47%-- __libc_read | create_worker | bench_sched_messaging | cmd_bench | run_builtin | main | __libc_start_main ... Single roots keep their entry without percentage because they have the same overhead than the hist they refer to. ie: 100% in fractal mode and the percentage of the hist in graph mode: 0.00% [k] reschedule_interrupt | --- default_idle amd_e400_idle cpu_idle start_secondary Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1332526010-15400-1-git-send-email-fweisbec@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-26perf tools: Switch module.h into export.hJiri Olsa
When merged to Linus's latest tree the perf build is broken due to following change in lib/rbtree.c object: lib: reduce the use of module.h wherever possible commit 8bc3bcc93a2b4e47d5d410146f6546bca6171663 Author: Paul Gortmaker <paul.gortmaker@windriver.com> Date: Wed Nov 16 21:29:17 2011 -0500 We need to move module.h header into export.h. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: acme@redhat.com Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: cjashfor@linux.vnet.ibm.com Cc: fweisbec@gmail.com Link: http://lkml.kernel.org/r/1332753425-3299-1-git-send-email-jolsa@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-03-26Merge branch 'linus' into perf/urgentIngo Molnar
Merge reason: we need to fix a non-trivial merge conflict. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-23bitops: rename for_each_set_bit_cont() in favor of analogous list.h functionAkinobu Mita
This renames for_each_set_bit_cont() to for_each_set_bit_from() because it is analogous to list_for_each_entry_from() in list.h rather than list_for_each_entry_continue(). This doesn't remove for_each_set_bit_cont() for now. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23Merge branch 'vhost-net' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
2012-03-23Merge tag 'ktest-v3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest changes from Steven Rostedt. * tag 'ktest-v3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Allow a test to override REBOOT_ON_SUCCESS ktest: Fix SWITCH_TO_GOOD to also reboot the machine ktest: Add SCP_TO_TARGET_INSTALL option ktest: Add warning when bugs are ignored ktest: Add INSTALL_MOD_STRIP=1 when installing modules
2012-03-22perf diff: Fix to work with new hists designJiri Olsa
The perf diff command is broken since: perf hists: Threaded addition and sorting of entries commit 1980c2ebd7020d82c024b8c4046849b38e78e7da Several places were broken: - hists data need to be collected into opened sessions instead of into events - session's hists data need to be initialized properly when the session is created - hist_entry__pcnt_snprintf: the percentage and displacement buffer preparation must not use 'ret' because it's used as a pointer to the final buffer Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120322133726.GB1601@m.brq.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-22perf tools: Fix modifier to be applied on correct eventsJiri Olsa
The event modifier needs to be applied only on the event definition it is attached to. The current state is that in case of multiple events definition (in single '-e' option, separated by ',') all will get modifier of the last one. Fixing this by adding separated list for each event definition, so the modifier is applied only to proper event(s). Added automated test to catch this, plus some other modifier tests. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1332267341-26338-3-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-22perf tools: Fix various casting issues for 32 bitsJiri Olsa
- util/parse-events.c(parse_events_add_breakpoint) need to use unsigned long instead of u64, otherwise we get following gcc error on 32 bits: error: cast from pointer to integer of different size - util/header.c(print_event_desc) cannot retype to signed type, otherwise we get following gcc error on 32 bits: error: comparison between signed and unsigned integer expressions Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1332267341-26338-2-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-22perf tools: Simplify event_read_id exit pathBorislav Petkov
We're freeing the token in any case so simplify the exit path by unifying it. No functional change. Signed-off-by: Borislav Petkov <bp@amd64.org> Link: http://lkml.kernel.org/r/1332339347-21342-1-git-send-email-bp@amd64.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
