[ Upstream commit 6279eb3dd7946c69346a3b98473ed13d3a44adb5 ]
Since 9e3596b0c653 ("kbuild: initramfs cleanup, set target from Kconfig")
"make clean" leaves behind compressed initramfs images. Example:
$ make defconfig
$ sed -i 's|CONFIG_INITRAMFS_SOURCE=""|CONFIG_INITRAMFS_SOURCE="/tmp/ir.cpio"|' .config
$ make olddefconfig
$ make -s
$ make -s clean
$ git clean -ndxf | grep initramfs
Would remove usr/initramfs_data.cpio.gz
clean rules do not have CONFIG_* context so they do not know which
compression format was used. Thus they don't know which files to delete.
Tell clean to delete all possible compression formats.
Once patched usr/initramfs_data.cpio.gz and friends are deleted by
"make clean".
Link: http://lkml.kernel.org/r/20190722063251.55541-1-gthelen@google.com
Fixes: 9e3596b0c653 ("kbuild: initramfs cleanup, set target from Kconfig")
Signed-off-by: Greg Thelen <gthelen@google.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
This is a follow-up to commit 57ddfdaa9a72 ("initramfs: fix disabling of
initramfs (and its compression)"). This particular commit fixed the use
case where we build the kernel with an initramfs with no compression,
and then we build the kernel with no initramfs.
Now this still left us with the same case as described here:
http://lkml.kernel.org/r/20170521033337.6197-1-f.fainelli@gmail.com
not working with initramfs compression. This can be seen by the
following steps/timestamps:
https://www.spinics.net/lists/kernel/msg2598153.html
.initramfs_data.cpio.gz.cmd is correct:
cmd_usr/initramfs_data.cpio.gz := /bin/bash
./scripts/gen_initramfs_list.sh -o usr/initramfs_data.cpio.gz -u 1000 -g 1000 /home/fainelli/work/uclinux-rootfs/romfs /home/fainelli/work/uclinux-rootfs/misc/initramfs.dev
and was generated the first time we did generate the gzip initramfs, so
the command has not changed, nor its arguments, so we just don't call
it, no initramfs cpio is re-generated as a consequence.
The fix for this problem is just to properly keep track of the
.initramfs_cpio_data.d file by suffixing it with the compression
extension. This takes care of properly tracking dependencies such that
the initramfs get (re)generated any time files are added/deleted etc.
Link: http://lkml.kernel.org/r/20170930033936.6722-1-f.fainelli@gmail.com
Fixes: db2aa7fd15e8 ("initramfs: allow again choice of the embedded initramfs compression algorithm")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: "Francisco Blas Izquierdo Riera (klondike)" <klondike@xiscosoft.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
ramdisk.
Clarify help text that compression applies to ramfs as well as legacy ramdisk.
Link: http://lkml.kernel.org/r/f206a960-5a61-cf59-f27c-e9f34872063c@landley.net
Signed-off-by: Rob Landley <rob@landley.net>
Cc: Jonathan Corbet <corbet@lwn.net>
INITRAMFS_ROOT_GID that -1 means "current user".
Teach INITRAMFS_ROOT_UID and INITRAMFS_ROOT_GID that -1 means "current user".
Link: http://lkml.kernel.org/r/2df3a9fb-4378-fa16-679d-99e788926c05@landley.net
Cc: Michal Marek <mmarek@suse.com>
Commit db2aa7fd15e8 ("initramfs: allow again choice of the embedded
initram compression algorithm") introduced the possibility to select the
initramfs compression algorithm from Kconfig and while this is a nice
feature it broke the use case described below.
Here is what my build system does:
- kernel is initially configured not to have an initramfs included
- build the user space root file system
- re-configure the kernel to have an initramfs included
(CONFIG_INITRAMFS_SOURCE="/path/to/romfs") and set relevant
CONFIG_INITRAMFS options, in my case, no compression option
(CONFIG_INITRAMFS_COMPRESSION_NONE)
- kernel is re-built with these options -> kernel+initramfs image is
copied
- kernel is re-built again without these options -> kernel image is
copied
Building a kernel without an initramfs means setting this option:
CONFIG_INITRAMFS_SOURCE="" (and this one only)
whereas building a kernel with an initramfs means setting these options:
CONFIG_INITRAMFS_SOURCE="/home/fainelli/work/uclinux-rootfs/romfs /home/fainelli/work/uclinux-rootfs/misc/initramfs.dev"
CONFIG_INITRAMFS_ROOT_UID=1000
CONFIG_INITRAMFS_ROOT_GID=1000
CONFIG_INITRAMFS_COMPRESSION_NONE=y
CONFIG_INITRAMFS_COMPRESSION=""
Commit db2aa7fd15e85 ("initramfs: allow again choice of the embedded
initram compression algorithm") is problematic because
CONFIG_INITRAMFS_COMPRESSION which is used to determine the
initramfs_data.cpio extension/compression is a string, and due to how
Kconfig works it will evaluate in order, how to assign it.
Setting CONFIG_INITRAMFS_COMPRESSION_NONE with CONFIG_INITRAMFS_SOURCE=""
cannot possibly work (because of the depends on INITRAMFS_SOURCE!=""
imposed on CONFIG_INITRAMFS_COMPRESSION ) yet we still get
CONFIG_INITRAMFS_COMPRESSION assigned to ".gz" because CONFIG_RD_GZIP=y
is set in my kernel, even when there is no initramfs being built.
So we basically end-up generating two initramfs_data.cpio* files, one
without extension, and one with .gz. This causes usr/Makefile to track
usr/initramfs_data.cpio.gz, and not usr/initramfs_data.cpio anymore,
that is also largely problematic after 9e3596b0c6539e ("kbuild:
initramfs cleanup, set target from Kconfig") because we used to track
all possible initramfs_data files in the $(targets) variable before that
commit.
The end result is that the kernel with an initramfs clearly does not
contain what we expect it to, it has a stale initramfs_data.cpio file
built into it, and we keep re-generating an initramfs_data.cpio.gz file
which is not the one that we want to include in the kernel image proper.
The fix consists in hiding CONFIG_INITRAMFS_COMPRESSION when
CONFIG_INITRAMFS_SOURCE="". This puts us back in a state to the
pre-4.10 behavior where we can properly disable and re-enable initramfs
within the same kernel .config file, and be in control of what
CONFIG_INITRAMFS_COMPRESSION is set to.
Fixes: db2aa7fd15e8 ("initramfs: allow again choice of the embedded initram compression algorithm")
Link: http://lkml.kernel.org/r/20170521033337.6197-1-f.fainelli@gmail.com
Acked-by: Nicholas Piggin <npiggin@gmail.com>
Cc: P J P <ppandit@redhat.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Many "embedded" architectures provide CMDLINE_FORCE to allow the kernel
to override the command line provided by an inflexible bootloader.
However there is currrently no way for the kernel to override the
initramfs image provided by the bootloader meaning there are still ways
for bootloaders to make things difficult for us.
Fix this by introducing INITRAMFS_FORCE which can prevent the kernel
from loading the bootloader supplied image.
We use CMDLINE_FORCE (and its friend CMDLINE_EXTEND) to imply that the
system has an inflexible bootloader. This allow us to avoid presenting
this config option to users of systems where inflexible bootloaders
aren't usually a problem.
Link: http://lkml.kernel.org/r/20170217121940.30126-1-daniel.thompson@linaro.org
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Rather than keep a list of all possible compression types in the
Makefile, set the target explicitly from Kconfig.
Reviewed-by: Francisco Blas Izquierdo Riera (klondike) <klondike@klondike.es>
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
When using initramfs compression, the data file compression suffix
gets quotes pulled in from Kconfig, e.g., initramfs_data.cpio".gz"
which make does not match a target and causes rebuild.
Fix this by filtering out quotes from the Kconfig string.
Fixes: 35e669e1a254 ("initramfs: select builtin initram compression algorithm on KConfig instead of Makefile")
Choosing the appropriate compression option when using an embedded
initramfs can result in significant size differences in the resulting
data.
This is caused by avoiding double compression of the initramfs contents.
For example on my tests, choosing CONFIG_INITRAMFS_COMPRESSION_NONE when
compressing the kernel using XZ) results in up to 500KiB differences
(9MiB to 8.5MiB) in the kernel size as the dictionary will not get
polluted with uncomprensible data and may reuse kernel data too.
Despite embedding an uncompressed initramfs, a user may want to allow
for a compressed extra initramfs to be passed using the rd system, for
example to boot a recovery system. 9ba4bcb645898d ("initramfs: read
CONFIG_RD_ variables for initramfs compression") broke that behavior by
making the choice based on CONFIG_RD_* instead of adding
CONFIG_INITRAMFS_COMPRESSION_LZ4. Saddly, CONFIG_RD_* is also used to
choose the supported RD compression algorithms by the kernel and a user
may want to support more than one.
This patch also reverts commit 3e4e0f0a875 ("initramfs: remove
"compression mode" choice") restoring back the "compression mode" choice
and includes the CONFIG_INITRAMFS_COMPRESSION_LZ4 option which was never
added.
As a result the following options are added or readed affecting the embedded
initramfs compression:
INITRAMFS_COMPRESSION_NONE Do no compression
INITRAMFS_COMPRESSION_GZIP Compress using gzip
INITRAMFS_COMPRESSION_BZIP2 Compress using bzip2
INITRAMFS_COMPRESSION_LZMA Compress using lzma
INITRAMFS_COMPRESSION_XZ Compress using xz
INITRAMFS_COMPRESSION_LZO Compress using lzo
INITRAMFS_COMPRESSION_LZ4 Compress using lz4
These depend on the corresponding CONFIG_RD_* option being set (except
NONE which has no dependencies).
This patch depends on the previous one (the previous version didn't) to
simplify the way in which the algorithm is chosen and keep backwards
compatibility with the behaviour introduced by 9ba4bcb645898
("initramfs: read CONFIG_RD_ variables for initramfs compression").
Link: http://lkml.kernel.org/r/57EAD77B.7090607@klondike.es
Signed-off-by: Francisco Blas Izquierdo Riera (klondike) <klondike@klondike.es>
of Makefile
Move the current builtin initram compression algorithm selection from
the Makefile into the INITRAMFS_COMPRESSION variable. This makes
deciding algorithm precedence easier and would allow for overrides if
new algorithms want to be tested.
Link: http://lkml.kernel.org/r/57EAD769.1090401@klondike.es
The kernel has support for (nearly) every compression algorithm known to
man, each to handle some particular microscopic niche.
Unfortunately all of these always get compiled in if you want to support
INITRDs, and can be only disabled when CONFIG_EXPERT is set.
I don't see why I need to set EXPERT just to properly configure the initrd
compression algorithms, and not always include every possible algorithm
Usually the initrd is just compressed with gzip anyways, at least that's
true on all distributions I use.
Remove the dependencies for initrd compression on CONFIG_EXPERT.
Make the various options just default y, which should be good enough to
not break any previous configuration.
Commit 9ba4bcb64589 ("initramfs: read CONFIG_RD_ variables for initramfs
compression") removed the users of the various INITRAMFS_COMPRESSION_*
Kconfig symbols. So since v3.13 the entire "Built-in initramfs
compression mode" choice is a set of knobs connected to nothing. The
entire choice can safely be removed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
When expert configuration option(CONFIG_EXPERT) is enabled, menuconfig
offers a choice of compression algorithm to compress initial ramfs image;
This choice is stored into CONFIG_RD_* variables. But usr/Makefile uses
earlier INITRAMFS_COMPRESSION_* macros to build initial ramfs file. Since
none of them is defined, resulting 'initramfs_data.cpio' file remains
un-compressed.
This patch updates the Makefile to use CONFIG_RD_* variables and adds
support for LZ4 compression algorithm. Also updates the
'gen_initramfs_list.sh' script to check whether a selected compression
command is accessible or not. And fall-back to default gzip(1)
compression when it is not.
Signed-off-by: P J P <prasad@redhat.com>
getenv() may return NULL if given environment variable does not exist
which leads to NULL dereference when calling strncat.
Besides that, the environment variable name was copied to a temporary
env_var buffer, but this copying can be avoided by simply using the input
string.
Lastly, the whole loop can be greatly simplified by using the snprintf
function instead of the playing with strncat.
By the way, the current implementation allows a recursive variable
expansion, as in:
$ echo 'out ${A} out ' | A='a ${B} a' B=b /tmp/a
out a b a out
I'm assuming this is just a side effect and not a conscious decision
(especially as this may lead to infinite loop), but I didn't want to
change this behaviour without consulting.
If the current behaviour is deamed incorrect, I'll be happy to send
a patch without recursive processing.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jesper Juhl <jj@codesealer.com>
Add support for extracting LZ4-compressed kernel images, as well as
LZ4-compressed ramdisk images in the kernel boot process.
Signed-off-by: Kyungsik Lee <kyungsik.lee@lge.com>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: Yann Collet <yann.collet.73@gmail.com>
Just a completely trivial patch to remove a completely redundant blank
line from usr/gen_init_cpio.c
Signed-off-by: Jesper Juhl <jj@codesealer.com>
Fix possible overflow of the buffer used for expanding environment
variables when building file list.
In the extremely unlikely case of an attacker having control over the
environment variables visible to gen_init_cpio, control over the
contents of the file gen_init_cpio parses, and gen_init_cpio was built
without compiler hardening, the attacker can gain arbitrary execution
control via a stack buffer overflow.
$ cat usr/crash.list
file foo ${BIG}${BIG}${BIG}${BIG}${BIG}${BIG} 0755 0 0
$ BIG=$(perl -e 'print "A" x 4096;') ./usr/gen_init_cpio usr/crash.list
*** buffer overflow detected ***: ./usr/gen_init_cpio terminated
This also replaces the space-indenting with tabs.
Patch based on existing fix extracted from grsecurity.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
Cc: <stable@vger.kernel.org>
There have been new compression algorithms added without updating nearby
relevant descriptive text that refers to (a) the number of compression
algorithms and (b) the most recent one. Fix these inconsistencies.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Reported-by: <qasdfgtyuiop@gmail.com>
Cc: Lasse Collin <lasse.collin@tukaani.org>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Alain Knaff <alain@knaff.lu>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
gen_init_cpio gets the current time and uses it for each symlink,
special file, and directory. Grab the current time once and make it
possible to override it with the KBUILD_BUILD_TIMESTAMP variable for
reproducible builds.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This implements the API defined in <linux/decompress/generic.h> which is
used for kernel, initramfs, and initrd decompression. This patch together
with the first patch is enough for XZ-compressed initramfs and initrd;
XZ-compressed kernel will need arch-specific changes.
The buffering requirements described in decompress_unxz.c are stricter
than with gzip, so the relevant changes should be done to the
arch-specific code when adding support for XZ-compressed kernel.
Similarly, the heap size in arch-specific pre-boot code may need to be
increased (30 KiB is enough).
The XZ decompressor needs memmove(), memeq() (memcmp() == 0), and
memzero() (memset(ptr, 0, size)), which aren't available in all
arch-specific pre-boot environments. I'm including simple versions in
decompress_unxz.c, but a cleaner solution would naturally be nicer.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
mkuboot.sh: Fail if mkimage is missing
gen_init_cpio: checkpatch fixes
gen_init_cpio: Avoid race between call to stat() and call to open()
modpost: Fix address calculation in reloc_location()
Make fixdep error handling more explicit
checksyscalls: Fix stand-alone usage
modpost: Put .zdebug* section on white list
kbuild: fix interaction of CONFIG_IKCONFIG and KCONFIG_CONFIG
kbuild: export linux/{a.out,kvm,kvm_para}.h on headers_install_all
kbuild: introduce HDR_ARCH_LIST for headers_install_all
headers_install: check exit status of unifdef
gen_init_cpio: remove leading `/' from file names
scripts/genksyms: fix header usage
fixdep: use hash table instead of a single array
Cc: Jesper Juhl <jj@chaosbits.net>
In usr/gen_init_cpio.c::cpio_mkfile() a call to stat() is made based on
pathname, subsequently the file is open()'ed and then the value of the
initial stat() call is used to allocate a buffer. This is not safe since
the file may change between the call to stat() and the call to open().
Safer to just open() the file and then do fstat() using the filedescriptor
returned by open.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
When we extracted the generated cpio archive using "cpio -id" command,
it complained,
cpio: Removing leading `/' from member names
var/run
var/lib
var/lib/misc
It is worse with the latest "cpio" or "pax", which tries to overwrite
the host file system with the leading '/'.
So the leading '/' of file names should be removed. This is consistent
with the initramfs come with major distributions such as Fedora or
Debian, etc.
Acked-by: Mike Frysinger<vapier@gentoo.org>
Define the __initramfs_size variable using VMLINUX_SYMBOL() to take care
of symbol-prefixed architectures, for example, blackfin.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>,
[mmarek: leave out Makefile change, since d63f6d1 already takes care of the
SYMBOL_PREFIX define]
Commit ffe8018c3424 ("initramfs: fix initramfs size calculation") broke
32-bit big-endian arches like (on ARAnyM):
VFS: Cannot open root device "hda1" or unknown-block(3,1)
Please append a correct "root=" boot option; here are the available partitions:
fe80 1059408 nfhd8 (driver?)
fe81 921600 nfhd8p1 00000000-0000-0000-0000-000000000nfhd8p1
fe82 137807 nfhd8p2 00000000-0000-0000-0000-000000000nfhd8p2
0200 3280 fd0 (driver?)
0201 3280 fd1 (driver?)
0300 1059408 hda driver: ide-gd
0301 921600 hda1 00000000-0000-0000-0000-000000000hda1
0302 137807 hda2 00000000-0000-0000-0000-000000000hda2
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(3,1)
As pointed out by Kerstin Jonsson <kerstin.jonsson@ericsson.com>, this
is due to CONFIG_32BIT not being defined, so the initramfs size field is
done as a 64-bit quad. On little-endian (like x86) this doesn matter,
but on a big-endian machine the 32-bit reads will see the (zero) high
bits.
Only mips, s390, and score set CONFIG_32BIT for 32-bit builds, so fix it for
all other 32-bit arches by inverting the logic and testing for CONFIG_64BIT,
which should be defined on all 64-bit arches.
[ I think we should just make it "u64" on all architectures and get
rid of the whole #ifdef CONFIG_xxBIT - Linus ]
initramfs: Fix build break on symbol-prefixed archs
initramfs: generalize initramfs_data.xxx.S variants
scripts/kallsyms: Enable error messages while hush up unnecessary warnings
scripts/setlocalversion: update comment
kbuild: Use a single clean rule for kernel and external modules
kbuild: Do not run make clean in $(srctree)
scripts/mod/modpost.c: fix commentary accordingly to last changes
kbuild: Really don't clean bounds.h and asm-offsets.h
The size of a built-in initramfs is calculated in init/initramfs.c by
"__initramfs_end - __initramfs_start". Those symbols are defined in the
linker script include/asm-generic/vmlinux.lds.h:
#define INIT_RAM_FS \
. = ALIGN(PAGE_SIZE); \
VMLINUX_SYMBOL(__initramfs_start) = .; \
*(.init.ramfs) \
VMLINUX_SYMBOL(__initramfs_end) = .;
If the initramfs file has an odd number of bytes, the "__initramfs_end"
symbol points to an odd address, for example, the symbols in the
System.map might look like:
0000000000572000 T __initramfs_start
00000000005bcd05 T __initramfs_end <-- odd address
At least on s390 this causes a problem:
Certain s390 instructions, especially instructions for loading addresses
(larl) or branch addresses must be on even addresses. The compiler loads
the symbol addresses with the "larl" instruction. This instruction sets
the last bit to 0 and, therefore, for odd size files, the calculated size
is one byte less than it should be:
0000000000540a9c <populate_rootfs>:
540a9c: eb cf f0 78 00 24 stmg %r12,%r15,120(%r15),
540aa2: c0 10 00 01 8a af larl %r1,572000 <__initramfs_start>
540aa8: c0 c0 00 03 e1 2e larl %r12,5bcd04 <initramfs_end>
(Instead of 5bcd05)
540abe: 1b c1 sr %r12,%r1
To fix the problem, this patch introduces the global variable
__initramfs_size, which is calculated in the "usr/initramfs_data.S" file.
The populate_rootfs() function can then use the start marker of the
.init.ramfs section and the value of __initramfs_size for loading the
initramfs. Because the start marker and size is sufficient, the
__initramfs_end symbol is no longer needed and is removed.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Michal Marek <mmarek@suse.cz>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Remove initramfs_data.{lzo,lzma,gz,bz2}.S variants and use a common
implementation in initramfs_data.S. The common implementation expects the
file name of the initramfs to be defined in INITRAMFS_IMAGE.
Change the Makefile to set the INITRAMFS_IMAGE define symbol according
to the selected compression method.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Deleted a word which apeared twice.
Signed-off-by: Stephan Sperber <sperberstephan@googlemail.com>
Add the necessary parts to be enable the use of LZO-compressed initramfs
build into the kernel.
Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Tested-by: Wu Zhangjin <wuzhangjin@gmail.com>
Tested-by: Russell King <rmk@arm.linux.org.uk>
Acked-by: Russell King <rmk@arm.linux.org.uk>
On compilers with security warnings enabled by default, we get:
usr/gen_init_cpio.c: In function ‘cpio_mkfile’:
usr/gen_init_cpio.c:357: warning: ignoring return value of ‘fwrite’,
declared with attribute warn_unused_result
So check the return value and handle errors accordingly.
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-next: (30 commits)
Use macros for .data.page_aligned section.
Use macros for .bss.page_aligned section.
Use new __init_task_data macro in arch init_task.c files.
kbuild: Don't define ALIGN and ENTRY when preprocessing linker scripts.
arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0
kbuild: add static to prototypes
kbuild: fail build if recordmcount.pl fails
kbuild: set -fconserve-stack option for gcc 4.5
kbuild: echo the record_mcount command
gconfig: disable "typeahead find" search in treeviews
kbuild: fix cc1 options check to ensure we do not use -fPIC when compiling
checkincludes.pl: add option to remove duplicates in place
markup_oops: use modinfo to avoid confusion with underscored module names
checkincludes.pl: provide usage helper
checkincludes.pl: close file as soon as we're done with it
ctags: usability fix
kernel hacking: move STRIP_ASM_SYMS from General
gitignore usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma
kbuild: Check if linker supports the -X option
kbuild: introduce ld-option
Fix trivial conflict in scripts/basic/fixdep.c
Signed-off-by: Trevor Keith <tsrk@tsrk.net>
usr/initramfs_data.cpio.bz2 and usr/initramfs_data.cpio.lzma are binary
files should be ignored
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Fix the Makefile comment since bzip2 is now supported.
Impact: quiet Kconfig warning
It appears that Kconfig simply has no way to provide defaults for
entries that exist inside a conditionalized choice block.
Fortunately, it turns out we don't actually ever use
CONFIG_INITRAMFS_COMPRESSION_NONE, so we can just drop it for
everything outside the choice block.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Impact: Kconfig noise reduction, documentation
The default initramfs is so small that it makes no sense to worry
about the additional memory taken by not double-compressing it.
Therefore, don't bug the user with it.
Also, improve the description of the option, which was downright
incorrect.
Impact: message formatting
Consistently spell LZMA in all capitals, since it (unlike gzip or
bzip2) is an acronym.
Impact: Kconfig clarification
Make it clear that the CONFIG_RD_* options are about what formats are
supported, not about what formats are actually being used.
Impact: reduce Kconfig noise
Move the options that control possible initramfs/initrd compressions
underneath CONFIG_EMBEDDED. The only impact of leaving these options
set to y is additional code in the init section of the kernel; there
is no reason to burden non-embedded users with these options.
Impact: Avoids silent environment dependency
Make builtin initramfs compression an explicit configurable. The
previous version would pick a compression based on the binaries which
were installed on the system, which could lead to unexpected results.
It is now explicitly configured, and not having the appropriate
binaries installed on the build host is simply an error.
Signed-off-by: Alain Knaff <alain@knaff.lu>
Impact: Resolves build failures in some configurations
Makes it possible to disable CONFIG_RD_GZIP . In that case, the
built-in initramfs will be compressed by whatever compressor is
available (bzip2 or lzma) or left uncompressed if none is available.
It also removes a couple of warnings which occur when no ramdisk
compression at all is chosen.
It also restores the select ZLIB_INFLATE in drivers/block/Kconfig
which somehow came missing. This is needed to activate compilation of
the stuff in zlib_deflate.
Impact: Partial resolution of build failure
Move the initrd/initramfs configuration options from
drivers/block/Kconfig to usr/Kconfig, since they do not and should not
depend on CONFIG_BLK_DEV. This fixes builds when CONFIG_BLK_DEV=n.
Modify gen_init_cpio so that lines that specify files can contain
what looks like a shell variable that's expanded during processing.
For example:
file /sbin/kinit ${RFS_BASE}/usr/src/klibc/kinit/kinit 0755 0 0
given RFS_BASE is "/some/directory" in the environment
would be expanded to
file /sbin/kinit /some/directory/usr/src/klibc/kinit/kinit 0755 0 0
If several environment variables appear in a line, they are all expanded
with processing happening from left to right.
Undefined variables expand to a null string.
Syntax errors stop processing, letting the existing error handling
show the user offending line.
This patch helps embedded folks who frequently create several
RFS directories and then switch between them as they're tuning
an initramfs.
Signed-off-by: gene.sally@timesys.com
Treat an argument of "-" as meaning "read stdin for cpio files" so
gen_init_cpio can be piped into.
