Enable CONFIG_UAPI_HEADER_TEST turns out the following build issues
HDRTEST usr/include/linux/mxc_asrc.h
In file included from <command-line>:32:0:
./usr/include/linux/mxc_asrc.h:125:2: error: unknown type name ‘snd_pcm_format_t’
snd_pcm_format_t input_format;
./usr/include/linux/mxc_asrc.h:126:2: error: unknown type name ‘snd_pcm_format_t’
snd_pcm_format_t output_format;
./usr/include/linux/mxc_asrc.h:134:2: error: unknown type name ‘uint64_t’
uint64_t supported_in_format;
./usr/include/linux/mxc_asrc.h:135:2: error: unknown type name ‘uint64_t’
uint64_t supported_out_format;
But even add the missing/necessary header file, it finally failed too in the end:
In file included from ./usr/include/linux/mxc_asrc.h:23:0,
./usr/include/sound/asound.h:459:18: error: field ‘trigger_tstamp’ has incomplete type
struct timespec trigger_tstamp; /* time when stream was started/stopped/paused */
./usr/include/sound/asound.h:460:18: error: field ‘tstamp’ has incomplete type
struct timespec tstamp; /* reference timestamp */
./usr/include/sound/asound.h:469:18: error: field ‘audio_tstamp’ has incomplete type
struct timespec audio_tstamp; /* sample counter, wall clock, PHC or on-demand sync'ed */
./usr/include/sound/asound.h:470:18: error: field ‘driver_tstamp’ has incomplete type
struct timespec driver_tstamp; /* useful in case reference system tstamp is reported with delay */
./usr/include/sound/asound.h:472:37: error: invalid application of ‘sizeof’ to incomplete type ‘struct timespec’
unsigned char reserved[52-2*sizeof(struct timespec)]; /* must be filled with zero */
./usr/include/sound/asound.h:479:18: error: field ‘tstamp’ has incomplete type
struct timespec tstamp; /* Timestamp */
./usr/include/sound/asound.h:481:18: error: field ‘audio_tstamp’ has incomplete type
struct timespec audio_tstamp; /* from sample counter or wall clock */
./usr/include/sound/asound.h:651:18: error: field ‘tstamp’ has incomplete type
./usr/include/sound/asound.h:763:18: error: field ‘tstamp’ has incomplete type
struct timespec tstamp; /* Timestamp - last update */
./usr/include/sound/asound.h:813:18: error: field ‘tstamp’ has incomplete type
./usr/include/sound/asound.h:956:18: error: field ‘tstamp’ has incomplete type
./usr/include/sound/asound.h:957:36: error: invalid application of ‘sizeof’ to incomplete type ‘struct timespec’
unsigned char reserved[128-sizeof(struct timespec)];
This is kernel known issue, just like other fixes as the following, put mxc_asrc.h into the skip-list:
header-test- += sound/asequencer.h
header-test- += sound/asoc.h
header-test- += sound/asound.h
header-test- += sound/compress_offload.h
header-test- += sound/emu10k1.h
header-test- += sound/sfnt_info.h
Signed-off-by: Jason Liu <jason.hui.liu@nxp.com>
(cherry picked from commit 4018355af34d9b25ff7bd4d27960d72b8d304e30)
Enable CONFIG_UAPI_HEADER_TEST turns on the following build issue
./usr/include/linux/ipu.h:167:2: error: unknown type name ‘u32’
u32 x;
./usr/include/linux/ipu.h:168:2: error: unknown type name ‘u32’
u32 y;
./usr/include/linux/ipu.h:173:2: error: unknown type name ‘u32’
u32 w;
./usr/include/linux/ipu.h:174:2: error: unknown type name ‘u32’
u32 h;
./usr/include/linux/ipu.h:179:2: error: unknown type name ‘u8’
u8 motion; /*see ipu_motion_sel*/
The fix is to use the __u32/__u8 instead and remove the internal definiton
But it finally will result in another failure as the followings:
HDRTEST usr/include/linux/ipu.h
In file included from ./usr/include/linux/ipu.h:29:0,
./usr/include/linux/videodev2.h:2353:20: error: field ‘timestamp’ has incomplete type
struct timespec timestamp;
This is kernel known issue. The fix is as others by adding the ipu.h to skip-list:
header-test- += linux/v4l2-mediabus.h
header-test- += linux/v4l2-subdev.h
header-test- += linux/videodev2.h
(cherry picked from commit 24c36527086fff43595bde2822f8277138ebcb55)
Enable CONFIG_UAPI_HEADER_TEST or make headers_install result in build issues:
include/uapi/linux/fmd/Peripherals/fm_port_ioctls.h: leak CONFIG_COMPAT to user-space
include/uapi/linux/fmd/Peripherals/fm_pcd_ioctls.h: leak CONFIG_COMPAT to user-space
include/uapi/linux/fmd/Peripherals/fm_ioctls.h: leak CONFIG_COMPAT to user-space
The comments from DN fix of the fmd related failure is to add to the skip-list due to the
historial reasons from DN(Layerscape) drivers - to avoid break the legacy users
(cherry picked from commit 569d6d3cc2a664de66ee980bd611687f4d785b4e)
[ Upstream commit 785d74ec3bbf26ac7f6e92e6e96a259aec0f107a ]
Even though INITRAMFS_SOURCE kconfig option isn't set in most of
defconfigs it is used (set) extensively by various build systems.
Commit f26661e12765 ("initramfs: make initramfs compression choice
non-optional") has changed default compression mode. Previously we
compress initramfs using available compression algorithm. Now
we don't use any compression at all by default.
It significantly increases the image size in case of build system
chooses embedded initramfs. Initially I faced with this issue while
using buildroot.
As of today it's not possible to set preferred compression mode
in target defconfig as this option depends on INITRAMFS_SOURCE
being set. Modification of all build systems either doesn't look
like good option.
Let's instead rewrite initramfs compression mode choices list
the way that "INITRAMFS_COMPRESSION_NONE" will be the last option
in the list. In that case it will be chosen only if all other
options (which implements any compression) are not available.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
[ Upstream commit cf6b58ab2d55f5a143c88c219c8e66ff0720fa69 ]
Since commit fcbb8461fd23 ("kbuild: remove header compile test"),
'make clean' with O= option in the pristine source tree emits
'No such file or directory' warning.
$ git clean -d -f -x
$ make O=foo clean
make[1]: Entering directory '/home/masahiro/linux/foo'
find: ‘usr/include’: No such file or directory
make[1]: Leaving directory '/home/masahiro/linux/foo'
Fixes: fcbb8461fd23 ("kbuild: remove header compile test")
Reported-by: kbuild test robot <lkp@intel.com>
commit 7ecaf069da52e472d393f03e79d721aabd724166 upstream.
Currently, some sanity checks for uapi headers are done by
scripts/headers_check.pl, which is wired up to the 'headers_check'
target in the top Makefile.
It is true compiling headers has better test coverage, but there
are still several headers excluded from the compile test. I like
to keep headers_check.pl for a while, but we can delete a lot of
code by moving the build rule to usr/include/Makefile.
commit fcbb8461fd2376ba3782b5b8bd440c929b8e4980 upstream.
There are both positive and negative options about this feature.
At first, I thought it was a good idea, but actually Linus stated a
negative opinion (https://lkml.org/lkml/2019/9/29/227). I admit it
is ugly and annoying.
The baseline I'd like to keep is the compile-test of uapi headers.
(Otherwise, kernel developers have no way to ensure the correctness
of the exported headers.)
I will maintain a small build rule in usr/include/Makefile.
Remove the other header test functionality.
[ added to 5.4.y due to start of build warnings from backported patches
because of this feature - gregkh]
commit cc976614f59bd8e45de8ce988a6bcb5de711d994 upstream.
Prior to commit 858805b336be ("kbuild: add $(BASH) to run scripts with
bash-extension"), this shell script was almost always run by bash since
bash is usually installed on the system by default.
Now, this script is run by sh, which might be a symlink to dash. On such
distributions, the following code emits an error:
local dev=`LC_ALL=C ls -l "${location}"`
You can reproduce the build error, for example by setting
CONFIG_INITRAMFS_SOURCE="/dev".
GEN usr/initramfs_data.cpio.gz
./usr/gen_initramfs_list.sh: 131: local: 1: bad variable name
make[1]: *** [usr/Makefile:61: usr/initramfs_data.cpio.gz] Error 2
This is because `LC_ALL=C ls -l "${location}"` contains spaces.
Surrounding it with double-quotes fixes the error.
Fixes: 858805b336be ("kbuild: add $(BASH) to run scripts with bash-extension")
Reported-by: Jory A. Pratt <anarchy@gentoo.org>
Commit 6dc280ebeed2 ("coda: remove uapi/linux/coda_psdev.h") removed
a header in question. Some more build errors were fixed. Add more
headers into the test coverage.
Pull networking fixes from David Miller:
1) Sanity check URB networking device parameters to avoid divide by
zero, from Oliver Neukum.
2) Disable global multicast filter in NCSI, otherwise LLDP and IPV6
don't work properly. Longer term this needs a better fix tho. From
Vijay Khemka.
3) Small fixes to selftests (use ping when ping6 is not present, etc.)
from David Ahern.
4) Bring back rt_uses_gateway member of struct rtable, it's semantics
were not well understood and trying to remove it broke things. From
David Ahern.
5) Move usbnet snaity checking, ignore endpoints with invalid
wMaxPacketSize. From Bjørn Mork.
6) Missing Kconfig deps for sja1105 driver, from Mao Wenan.
7) Various small fixes to the mlx5 DR steering code, from Alaa Hleihel,
Alex Vesker, and Yevgeny Kliteynik
8) Missing CAP_NET_RAW checks in various places, from Ori Nimron.
9) Fix crash when removing sch_cbs entry while offloading is enabled,
from Vinicius Costa Gomes.
10) Signedness bug fixes, generally in looking at the result given by
of_get_phy_mode() and friends. From Dan Crapenter.
11) Disable preemption around BPF_PROG_RUN() calls, from Eric Dumazet.
12) Don't create VRF ipv6 rules if ipv6 is disabled, from David Ahern.
13) Fix quantization code in tcp_bbr, from Kevin Yang.
* git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net: (127 commits)
net: tap: clean up an indentation issue
nfp: abm: fix memory leak in nfp_abm_u32_knode_replace
tcp: better handle TCP_USER_TIMEOUT in SYN_SENT state
sk_buff: drop all skb extensions on free and skb scrubbing
tcp_bbr: fix quantization code to not raise cwnd if not probing bandwidth
mlxsw: spectrum_flower: Fail in case user specifies multiple mirror actions
Documentation: Clarify trap's description
mlxsw: spectrum: Clear VLAN filters during port initialization
net: ena: clean up indentation issue
NFC: st95hf: clean up indentation issue
net: phy: micrel: add Asym Pause workaround for KSZ9021
net: socionext: ave: Avoid using netdev_err() before calling register_netdev()
ptp: correctly disable flags on old ioctls
lib: dimlib: fix help text typos
net: dsa: microchip: Always set regmap stride to 1
nfp: flower: fix memory leak in nfp_flower_spawn_vnic_reprs
nfp: flower: prevent memory leak in nfp_flower_spawn_phy_reprs
net/sched: Set default of CONFIG_NET_TC_SKB_EXT to N
vrf: Do not attempt to create IPv6 mcast rule if IPv6 is disabled
net: sched: sch_sfb: don't call qdisc_put() while holding tree lock
When CONFIG_UAPI_HEADER_TEST=y, exported headers are compile-tested to
make sure they can be included from user-space.
Currently, linux/netfilter_bridge/ebtables.h is excluded from the test
coverage. To make it join the compile-test, we need to fix the build
errors attached below.
For a case like this, we decided to use __u{8,16,32,64} variable types
in this discussion:
https://lkml.org/lkml/2019/6/5/18
Build log:
CC usr/include/linux/netfilter_bridge/ebtables.h.s
./usr/include/linux/netfilter_bridge/ebtables.h:126:4: error: unknown type name ‘uint8_t’
uint8_t revision;
./usr/include/linux/netfilter_bridge/ebtables.h:139:4: error: unknown type name ‘uint8_t’
uint8_t revision;
./usr/include/linux/netfilter_bridge/ebtables.h:152:4: error: unknown type name ‘uint8_t’
uint8_t revision;
Since 9e3596b0c653 ("kbuild: initramfs cleanup, set target from Kconfig")
"make clean" leaves behind compressed initramfs images. Example:
$ make defconfig
$ sed -i 's|CONFIG_INITRAMFS_SOURCE=""|CONFIG_INITRAMFS_SOURCE="/tmp/ir.cpio"|' .config
$ make olddefconfig
$ make -s
$ make -s clean
$ git clean -ndxf | grep initramfs
Would remove usr/initramfs_data.cpio.gz
clean rules do not have CONFIG_* context so they do not know which
compression format was used. Thus they don't know which files to delete.
Tell clean to delete all possible compression formats.
Once patched usr/initramfs_data.cpio.gz and friends are deleted by
"make clean".
Link: http://lkml.kernel.org/r/20190722063251.55541-1-gthelen@google.com
Fixes: 9e3596b0c653 ("kbuild: initramfs cleanup, set target from Kconfig")
Signed-off-by: Greg Thelen <gthelen@google.com>
Cc: Nicholas Piggin <npiggin@gmail.com>
The only the difference between clean-files and clean-dirs is the -r
option passed to the 'rm' command.
You can always pass -r, and then remove the clean-dirs syntax.
Masahiro Yamada changed the zcrypt.h header file to use __u{16,32,64}
instead of uint{16,32,64}_t with ("s390: use __u{16,32,64} instead of
uint{16,32,64}_t in uapi header").
This makes all s390 header files pass - remove zcrypt.h from the blacklist.
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- match the directory structure of the linux-libc-dev package to that
of Debian-based distributions
- fix incorrect include/config/auto.conf generation when Kconfig
creates it along with the .config file
- remove misleading $(AS) from documents
- clean up precious tag files by distclean instead of mrproper
- add a new coccinelle patch for devm_platform_ioremap_resource
migration
- refactor module-related scripts to read modules.order instead of
$(MODVERDIR)/*.mod files to get the list of created modules
- remove MODVERDIR
- update list of header compile-test
- add -fcf-protection=none flag to avoid conflict with the retpoline
flags when CONFIG_RETPOLINE=y
- misc cleanups
* tag 'kbuild-v5.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (25 commits)
kbuild: add -fcf-protection=none when using retpoline flags
kbuild: update compile-test header list for v5.3-rc1
kbuild: split out *.mod out of {single,multi}-used-m rules
kbuild: remove 'prepare1' target
kbuild: remove the first line of *.mod files
kbuild: create *.mod with full directory path and remove MODVERDIR
kbuild: export_report: read modules.order instead of .tmp_versions/*.mod
kbuild: modpost: read modules.order instead of $(MODVERDIR)/*.mod
kbuild: modsign: read modules.order instead of $(MODVERDIR)/*.mod
kbuild: modinst: read modules.order instead of $(MODVERDIR)/*.mod
scsi: remove pointless $(MODVERDIR)/$(obj)/53c700.ver
kbuild: remove duplication from modules.order in sub-directories
kbuild: get rid of kernel/ prefix from in-tree modules.{order,builtin}
kbuild: do not create empty modules.order in the prepare stage
coccinelle: api: add devm_platform_ioremap_resource script
kbuild: compile-test headers listed in header-test-m as well
kbuild: remove unused hostcc-option
kbuild: remove tag files by distclean instead of mrproper
kbuild: add --hash-style= and --build-id unconditionally
kbuild: get rid of misleading $(AS) from documents
- Some headers graduated from the blacklist
- hyperv_timer.h joined the header-test when CONFIG_X86=y
- nf_tables*.h joined the header-test when CONFIG_NF_TABLES is
enabled.
- The entry for nf_tables_offload.h was added to fix build error for
the combination of CONFIG_NF_TABLES=n and CONFIG_KERNEL_HEADER_TEST=y.
- The entry for iomap.h was added because this header is supposed to
be included only when CONFIG_BLOCK=y
Those documents describe a kAPI. So, add to the driver-api
book.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
The two files there describes a Kernel API feature, used to
support early userspace stuff. Prepare for moving them to
the kernel API book by converting to ReST format.
The conversion itself was quite trivial: just add/mark a few
titles as such, add a literal block markup, add a table markup
and a few blank lines, in order to make Sphinx to properly parse it.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Multiple people have suggested compile-testing UAPI headers to ensure
they can be really included from user-space. "make headers_check" is
obviously not enough to catch bugs, and we often leak unresolved
references to user-space.
Use the new header-test-y syntax to implement it. Please note exported
headers are compile-tested with a completely different set of compiler
flags. The header search path is set to $(objtree)/usr/include since
exported headers should not include unexported ones.
We use -std=gnu89 for the kernel space since the kernel code highly
depends on GNU extensions. On the other hand, UAPI headers should be
written in more standardized C, so they are compiled with -std=c90.
This will emit errors if C++ style comments, the keyword 'inline', etc.
are used. Please use C style comments (/* ... */), '__inline__', etc.
in UAPI headers.
There is additional compiler requirement to enable this test because
many of UAPI headers include <stdlib.h>, <sys/ioctl.h>, <sys/time.h>,
etc. directly or indirectly. You cannot use kernel.org pre-built
toolchains [1] since they lack <stdlib.h>.
I reused CONFIG_CC_CAN_LINK to check the system header availability.
The intention is slightly different, but a compiler that can link
userspace programs provide system headers.
For now, a lot of headers need to be excluded because they cannot
be compiled standalone, but this is a good start point.
[1] https://mirrors.edge.kernel.org/pub/tools/crosstool/index.html
Reviewed-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Eugen Cazacu <green182day@hotmail.com>
scripts/gen_initramfs_list.sh is only invoked from usr/Makefile.
Move it so that all tools to create initramfs are self-contained
in the usr/ directory.
With the special case handling for Blackfin and Metag was removed by
commit 94e58e0ac312 ("export.h: remove code for prefixing symbols with
underscore"), VMLINUX_SYMBOL() is no-op.
Replace the remaining usages, then remove the definition of
VMLINUX_SYMBOL() and VMLINUX_SYMBOL_STR().
Incremental linking is gone, so rename built-in.o to built-in.a, which
is the usual extension for archive files.
This patch does two things, first is a simple search/replace:
git grep -l 'built-in\.o' | xargs sed -i 's/built-in\.o/built-in\.a/g'
The second is to invert nesting of nested text manipulations to avoid
filtering built-in.a out from libs-y2:
-libs-y2 := $(filter-out %.a, $(patsubst %/, %/built-in.a, $(libs-y)))
+libs-y2 := $(patsubst %/, %/built-in.a, $(filter-out %.a, $(libs-y)))
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
This is a follow-up to commit 57ddfdaa9a72 ("initramfs: fix disabling of
initramfs (and its compression)"). This particular commit fixed the use
case where we build the kernel with an initramfs with no compression,
and then we build the kernel with no initramfs.
Now this still left us with the same case as described here:
http://lkml.kernel.org/r/20170521033337.6197-1-f.fainelli@gmail.com
not working with initramfs compression. This can be seen by the
following steps/timestamps:
https://www.spinics.net/lists/kernel/msg2598153.html
.initramfs_data.cpio.gz.cmd is correct:
cmd_usr/initramfs_data.cpio.gz := /bin/bash
./scripts/gen_initramfs_list.sh -o usr/initramfs_data.cpio.gz -u 1000 -g 1000 /home/fainelli/work/uclinux-rootfs/romfs /home/fainelli/work/uclinux-rootfs/misc/initramfs.dev
and was generated the first time we did generate the gzip initramfs, so
the command has not changed, nor its arguments, so we just don't call
it, no initramfs cpio is re-generated as a consequence.
The fix for this problem is just to properly keep track of the
.initramfs_cpio_data.d file by suffixing it with the compression
extension. This takes care of properly tracking dependencies such that
the initramfs get (re)generated any time files are added/deleted etc.
Link: http://lkml.kernel.org/r/20170930033936.6722-1-f.fainelli@gmail.com
Fixes: db2aa7fd15e8 ("initramfs: allow again choice of the embedded initramfs compression algorithm")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Cc: "Francisco Blas Izquierdo Riera (klondike)" <klondike@xiscosoft.net>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
ramdisk.
Clarify help text that compression applies to ramfs as well as legacy ramdisk.
Link: http://lkml.kernel.org/r/f206a960-5a61-cf59-f27c-e9f34872063c@landley.net
Signed-off-by: Rob Landley <rob@landley.net>
Cc: Jonathan Corbet <corbet@lwn.net>
INITRAMFS_ROOT_GID that -1 means "current user".
Teach INITRAMFS_ROOT_UID and INITRAMFS_ROOT_GID that -1 means "current user".
Link: http://lkml.kernel.org/r/2df3a9fb-4378-fa16-679d-99e788926c05@landley.net
Cc: Michal Marek <mmarek@suse.com>
Commit db2aa7fd15e8 ("initramfs: allow again choice of the embedded
initram compression algorithm") introduced the possibility to select the
initramfs compression algorithm from Kconfig and while this is a nice
feature it broke the use case described below.
Here is what my build system does:
- kernel is initially configured not to have an initramfs included
- build the user space root file system
- re-configure the kernel to have an initramfs included
(CONFIG_INITRAMFS_SOURCE="/path/to/romfs") and set relevant
CONFIG_INITRAMFS options, in my case, no compression option
(CONFIG_INITRAMFS_COMPRESSION_NONE)
- kernel is re-built with these options -> kernel+initramfs image is
copied
- kernel is re-built again without these options -> kernel image is
copied
Building a kernel without an initramfs means setting this option:
CONFIG_INITRAMFS_SOURCE="" (and this one only)
whereas building a kernel with an initramfs means setting these options:
CONFIG_INITRAMFS_SOURCE="/home/fainelli/work/uclinux-rootfs/romfs /home/fainelli/work/uclinux-rootfs/misc/initramfs.dev"
CONFIG_INITRAMFS_ROOT_UID=1000
CONFIG_INITRAMFS_ROOT_GID=1000
CONFIG_INITRAMFS_COMPRESSION_NONE=y
CONFIG_INITRAMFS_COMPRESSION=""
Commit db2aa7fd15e85 ("initramfs: allow again choice of the embedded
initram compression algorithm") is problematic because
CONFIG_INITRAMFS_COMPRESSION which is used to determine the
initramfs_data.cpio extension/compression is a string, and due to how
Kconfig works it will evaluate in order, how to assign it.
Setting CONFIG_INITRAMFS_COMPRESSION_NONE with CONFIG_INITRAMFS_SOURCE=""
cannot possibly work (because of the depends on INITRAMFS_SOURCE!=""
imposed on CONFIG_INITRAMFS_COMPRESSION ) yet we still get
CONFIG_INITRAMFS_COMPRESSION assigned to ".gz" because CONFIG_RD_GZIP=y
is set in my kernel, even when there is no initramfs being built.
So we basically end-up generating two initramfs_data.cpio* files, one
without extension, and one with .gz. This causes usr/Makefile to track
usr/initramfs_data.cpio.gz, and not usr/initramfs_data.cpio anymore,
that is also largely problematic after 9e3596b0c6539e ("kbuild:
initramfs cleanup, set target from Kconfig") because we used to track
all possible initramfs_data files in the $(targets) variable before that
commit.
The end result is that the kernel with an initramfs clearly does not
contain what we expect it to, it has a stale initramfs_data.cpio file
built into it, and we keep re-generating an initramfs_data.cpio.gz file
which is not the one that we want to include in the kernel image proper.
The fix consists in hiding CONFIG_INITRAMFS_COMPRESSION when
CONFIG_INITRAMFS_SOURCE="". This puts us back in a state to the
pre-4.10 behavior where we can properly disable and re-enable initramfs
within the same kernel .config file, and be in control of what
CONFIG_INITRAMFS_COMPRESSION is set to.
Fixes: db2aa7fd15e8 ("initramfs: allow again choice of the embedded initram compression algorithm")
Link: http://lkml.kernel.org/r/20170521033337.6197-1-f.fainelli@gmail.com
Acked-by: Nicholas Piggin <npiggin@gmail.com>
Cc: P J P <ppandit@redhat.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Many "embedded" architectures provide CMDLINE_FORCE to allow the kernel
to override the command line provided by an inflexible bootloader.
However there is currrently no way for the kernel to override the
initramfs image provided by the bootloader meaning there are still ways
for bootloaders to make things difficult for us.
Fix this by introducing INITRAMFS_FORCE which can prevent the kernel
from loading the bootloader supplied image.
We use CMDLINE_FORCE (and its friend CMDLINE_EXTEND) to imply that the
system has an inflexible bootloader. This allow us to avoid presenting
this config option to users of systems where inflexible bootloaders
aren't usually a problem.
Link: http://lkml.kernel.org/r/20170217121940.30126-1-daniel.thompson@linaro.org
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
Rather than keep a list of all possible compression types in the
Makefile, set the target explicitly from Kconfig.
Reviewed-by: Francisco Blas Izquierdo Riera (klondike) <klondike@klondike.es>
When using initramfs compression, the data file compression suffix
gets quotes pulled in from Kconfig, e.g., initramfs_data.cpio".gz"
which make does not match a target and causes rebuild.
Fix this by filtering out quotes from the Kconfig string.
Fixes: 35e669e1a254 ("initramfs: select builtin initram compression algorithm on KConfig instead of Makefile")
Choosing the appropriate compression option when using an embedded
initramfs can result in significant size differences in the resulting
data.
This is caused by avoiding double compression of the initramfs contents.
For example on my tests, choosing CONFIG_INITRAMFS_COMPRESSION_NONE when
compressing the kernel using XZ) results in up to 500KiB differences
(9MiB to 8.5MiB) in the kernel size as the dictionary will not get
polluted with uncomprensible data and may reuse kernel data too.
Despite embedding an uncompressed initramfs, a user may want to allow
for a compressed extra initramfs to be passed using the rd system, for
example to boot a recovery system. 9ba4bcb645898d ("initramfs: read
CONFIG_RD_ variables for initramfs compression") broke that behavior by
making the choice based on CONFIG_RD_* instead of adding
CONFIG_INITRAMFS_COMPRESSION_LZ4. Saddly, CONFIG_RD_* is also used to
choose the supported RD compression algorithms by the kernel and a user
may want to support more than one.
This patch also reverts commit 3e4e0f0a875 ("initramfs: remove
"compression mode" choice") restoring back the "compression mode" choice
and includes the CONFIG_INITRAMFS_COMPRESSION_LZ4 option which was never
added.
As a result the following options are added or readed affecting the embedded
initramfs compression:
INITRAMFS_COMPRESSION_NONE Do no compression
INITRAMFS_COMPRESSION_GZIP Compress using gzip
INITRAMFS_COMPRESSION_BZIP2 Compress using bzip2
INITRAMFS_COMPRESSION_LZMA Compress using lzma
INITRAMFS_COMPRESSION_XZ Compress using xz
INITRAMFS_COMPRESSION_LZO Compress using lzo
INITRAMFS_COMPRESSION_LZ4 Compress using lz4
These depend on the corresponding CONFIG_RD_* option being set (except
NONE which has no dependencies).
This patch depends on the previous one (the previous version didn't) to
simplify the way in which the algorithm is chosen and keep backwards
compatibility with the behaviour introduced by 9ba4bcb645898
("initramfs: read CONFIG_RD_ variables for initramfs compression").
Link: http://lkml.kernel.org/r/57EAD77B.7090607@klondike.es
Signed-off-by: Francisco Blas Izquierdo Riera (klondike) <klondike@klondike.es>
of Makefile
Move the current builtin initram compression algorithm selection from
the Makefile into the INITRAMFS_COMPRESSION variable. This makes
deciding algorithm precedence easier and would allow for overrides if
new algorithms want to be tested.
Link: http://lkml.kernel.org/r/57EAD769.1090401@klondike.es
The kernel has support for (nearly) every compression algorithm known to
man, each to handle some particular microscopic niche.
Unfortunately all of these always get compiled in if you want to support
INITRDs, and can be only disabled when CONFIG_EXPERT is set.
I don't see why I need to set EXPERT just to properly configure the initrd
compression algorithms, and not always include every possible algorithm
Usually the initrd is just compressed with gzip anyways, at least that's
true on all distributions I use.
Remove the dependencies for initrd compression on CONFIG_EXPERT.
Make the various options just default y, which should be good enough to
not break any previous configuration.
Commit 9ba4bcb64589 ("initramfs: read CONFIG_RD_ variables for initramfs
compression") removed the users of the various INITRAMFS_COMPRESSION_*
Kconfig symbols. So since v3.13 the entire "Built-in initramfs
compression mode" choice is a set of knobs connected to nothing. The
entire choice can safely be removed.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
When expert configuration option(CONFIG_EXPERT) is enabled, menuconfig
offers a choice of compression algorithm to compress initial ramfs image;
This choice is stored into CONFIG_RD_* variables. But usr/Makefile uses
earlier INITRAMFS_COMPRESSION_* macros to build initial ramfs file. Since
none of them is defined, resulting 'initramfs_data.cpio' file remains
un-compressed.
This patch updates the Makefile to use CONFIG_RD_* variables and adds
support for LZ4 compression algorithm. Also updates the
'gen_initramfs_list.sh' script to check whether a selected compression
command is accessible or not. And fall-back to default gzip(1)
compression when it is not.
Signed-off-by: P J P <prasad@redhat.com>
getenv() may return NULL if given environment variable does not exist
which leads to NULL dereference when calling strncat.
Besides that, the environment variable name was copied to a temporary
env_var buffer, but this copying can be avoided by simply using the input
string.
Lastly, the whole loop can be greatly simplified by using the snprintf
function instead of the playing with strncat.
By the way, the current implementation allows a recursive variable
expansion, as in:
$ echo 'out ${A} out ' | A='a ${B} a' B=b /tmp/a
out a b a out
I'm assuming this is just a side effect and not a conscious decision
(especially as this may lead to infinite loop), but I didn't want to
change this behaviour without consulting.
If the current behaviour is deamed incorrect, I'll be happy to send
a patch without recursive processing.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Jesper Juhl <jj@codesealer.com>
Add support for extracting LZ4-compressed kernel images, as well as
LZ4-compressed ramdisk images in the kernel boot process.
Signed-off-by: Kyungsik Lee <kyungsik.lee@lge.com>
Cc: Florian Fainelli <florian@openwrt.org>
Cc: Yann Collet <yann.collet.73@gmail.com>
Just a completely trivial patch to remove a completely redundant blank
line from usr/gen_init_cpio.c
Signed-off-by: Jesper Juhl <jj@codesealer.com>
Fix possible overflow of the buffer used for expanding environment
variables when building file list.
In the extremely unlikely case of an attacker having control over the
environment variables visible to gen_init_cpio, control over the
contents of the file gen_init_cpio parses, and gen_init_cpio was built
without compiler hardening, the attacker can gain arbitrary execution
control via a stack buffer overflow.
$ cat usr/crash.list
file foo ${BIG}${BIG}${BIG}${BIG}${BIG}${BIG} 0755 0 0
$ BIG=$(perl -e 'print "A" x 4096;') ./usr/gen_init_cpio usr/crash.list
*** buffer overflow detected ***: ./usr/gen_init_cpio terminated
This also replaces the space-indenting with tabs.
Patch based on existing fix extracted from grsecurity.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
Cc: <stable@vger.kernel.org>
There have been new compression algorithms added without updating nearby
relevant descriptive text that refers to (a) the number of compression
algorithms and (b) the most recent one. Fix these inconsistencies.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Reported-by: <qasdfgtyuiop@gmail.com>
Cc: Lasse Collin <lasse.collin@tukaani.org>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Alain Knaff <alain@knaff.lu>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
gen_init_cpio gets the current time and uses it for each symlink,
special file, and directory. Grab the current time once and make it
possible to override it with the KBUILD_BUILD_TIMESTAMP variable for
reproducible builds.
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option
is used to configure any non-standard kernel with a much larger scope than
only small devices.
This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes
references to the option throughout the kernel. A new CONFIG_EMBEDDED
option is added that automatically selects CONFIG_EXPERT when enabled and
can be used in the future to isolate options that should only be
considered for embedded systems (RISC architectures, SLOB, etc).
Calling the option "EXPERT" more accurately represents its intention: only
expert users who understand the impact of the configuration changes they
are making should enable it.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: David Woodhouse <david.woodhouse@intel.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg KH <gregkh@suse.de>
Cc: Robin Holt <holt@sgi.com>
Cc: <linux-arch@vger.kernel.org>
This implements the API defined in <linux/decompress/generic.h> which is
used for kernel, initramfs, and initrd decompression. This patch together
with the first patch is enough for XZ-compressed initramfs and initrd;
XZ-compressed kernel will need arch-specific changes.
The buffering requirements described in decompress_unxz.c are stricter
than with gzip, so the relevant changes should be done to the
arch-specific code when adding support for XZ-compressed kernel.
Similarly, the heap size in arch-specific pre-boot code may need to be
increased (30 KiB is enough).
The XZ decompressor needs memmove(), memeq() (memcmp() == 0), and
memzero() (memset(ptr, 0, size)), which aren't available in all
arch-specific pre-boot environments. I'm including simple versions in
decompress_unxz.c, but a cleaner solution would naturally be nicer.
Signed-off-by: Lasse Collin <lasse.collin@tukaani.org>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6:
mkuboot.sh: Fail if mkimage is missing
gen_init_cpio: checkpatch fixes
gen_init_cpio: Avoid race between call to stat() and call to open()
modpost: Fix address calculation in reloc_location()
Make fixdep error handling more explicit
checksyscalls: Fix stand-alone usage
modpost: Put .zdebug* section on white list
kbuild: fix interaction of CONFIG_IKCONFIG and KCONFIG_CONFIG
kbuild: export linux/{a.out,kvm,kvm_para}.h on headers_install_all
kbuild: introduce HDR_ARCH_LIST for headers_install_all
headers_install: check exit status of unifdef
gen_init_cpio: remove leading `/' from file names
scripts/genksyms: fix header usage
fixdep: use hash table instead of a single array
Cc: Jesper Juhl <jj@chaosbits.net>
In usr/gen_init_cpio.c::cpio_mkfile() a call to stat() is made based on
pathname, subsequently the file is open()'ed and then the value of the
initial stat() call is used to allocate a buffer. This is not safe since
the file may change between the call to stat() and the call to open().
Safer to just open() the file and then do fstat() using the filedescriptor
returned by open.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
When we extracted the generated cpio archive using "cpio -id" command,
it complained,
cpio: Removing leading `/' from member names
var/run
var/lib
var/lib/misc
It is worse with the latest "cpio" or "pax", which tries to overwrite
the host file system with the leading '/'.
So the leading '/' of file names should be removed. This is consistent
with the initramfs come with major distributions such as Fedora or
Debian, etc.
Acked-by: Mike Frysinger<vapier@gentoo.org>
Define the __initramfs_size variable using VMLINUX_SYMBOL() to take care
of symbol-prefixed architectures, for example, blackfin.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>,
[mmarek: leave out Makefile change, since d63f6d1 already takes care of the
SYMBOL_PREFIX define]
