path: root/virt/kvm/assigned-dev.c
2011-05-21KVM: Use pci_store/load_saved_state() around VM device usageAlex Williamson
Store the device saved state so that we can reload the device back to the original state when it's unassigned. This has the benefit that the state survives across pci_reset_function() calls via the PCI sysfs reset interface while the VM is using the device. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Avi Kivity <avi@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-01-12KVM: Clean up kvm_vm_ioctl_assigned_deviceJan Kiszka
Any arch not supporting device assigment will also not build assigned-dev.c. So testing for KVM_CAP_DEVICE_DEASSIGNMENT is pointless. KVM_CAP_ASSIGN_DEV_IRQ is unconditinally set. Moreover, add a default case for dispatching the ioctl. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Save/restore state of assigned PCI deviceJan Kiszka
The guest may change states that pci_reset_function does not touch. So we better save/restore the assigned device across guest usage. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Refactor IRQ names of assigned devicesJan Kiszka
Cosmetic change, but it helps to correlate IRQs with PCI devices. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Switch assigned device IRQ forwarding to threaded handlerJan Kiszka
This improves the IRQ forwarding for assigned devices: By using the kernel's threaded IRQ scheme, we can get rid of the latency-prone work queue and simplify the code in the same run. Moreover, we no longer have to hold assigned_dev_lock while raising the guest IRQ, which can be a lenghty operation as we may have to iterate over all VCPUs. The lock is now only used for synchronizing masking vs. unmasking of INTx-type IRQs, thus is renames to intx_lock. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clear assigned guest IRQ on releaseJan Kiszka
When we deassign a guest IRQ, clear the potentially asserted guest line. There might be no chance for the guest to do this, specifically if we switch from INTx to MSI mode. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Fix unused but set warningsAndi Kleen
No real bugs in this one. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Update Red Hat copyrightsAvi Kivity
2010-08-01KVM: remove CAP_SYS_RAWIO requirement from kvm_vm_ioctl_assign_irqAlex Williamson
Remove this check in an effort to allow kvm guests to run without root privileges. This capability check doesn't seem to add any security since the device needs to have already been added via the assign device ioctl and the io actually occurs through the pci sysfs interface. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-05-17KVM: fix assigned_device_enable_host_msix error handlingjing zhang
Free IRQ's and disable MSIX upon failure. Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Jing Zhang <zj.barak@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01KVM: enable PCI multiple-segments for pass-through deviceZhai, Edwin
Enable optional parameter (default 0) - PCI segment (or domain) besides BDF, when assigning PCI device to guest. Signed-off-by: Zhai Edwin <edwin.zhai@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: introduce kvm->srcu and convert kvm_set_memory_region to SRCU updateMarcelo Tosatti
Use two steps for memslot deletion: mark the slot invalid (which stops instantiation of new shadow pages for that slot, but allows destruction), then instantiate the new empty slot. Also simplifies kvm_handle_hva locking. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-27KVM: Fix possible circular locking in kvm_vm_ioctl_assign_device()Sheng Yang
One possible order is: KVM_CREATE_IRQCHIP ioctl(took kvm->lock) -> kvm_iobus_register_dev() -> down_write(kvm->slots_lock). The other one is in kvm_vm_ioctl_assign_device(), which take kvm->slots_lock first, then kvm->lock. Update the comment of lock order as well. Observe it due to kernel locking debug warnings. Cc: stable@kernel.org Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move assigned device code to own fileAvi Kivity
