path: root/virt/kvm/async_pf.c
2011-01-12KVM: fix the race while wakeup all pv guestXiao Guangrong
In kvm_async_pf_wakeup_all(), we add a dummy apf to vcpu->async_pf.done without holding vcpu->async_pf.lock, it will break if we are handling apfs at this time. Also use 'list_empty_careful()' instead of 'list_empty()' Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: handle more completed apfs if possibleXiao Guangrong
If it's no need to inject async #PF to PV guest we can handle more completed apfs at one time, so we can retry guest #PF as early as possible Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Inject asynchronous page fault into a PV guest if page is swapped out.Gleb Natapov
Send async page fault to a PV guest if it accesses swapped out memory. Guest will choose another task to run upon receiving the fault. Allow async page fault injection only when guest is in user mode since otherwise guest may be in non-sleepable context and will not be able to reschedule. Vcpu will be halted if guest will fault on the same page again or if vcpu executes kernel code. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Add PV MSR to enable asynchronous page faults delivery.Gleb Natapov
Guest enables async PF vcpu functionality using this MSR. Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Retry fault before vmentryGleb Natapov
When page is swapped in it is mapped into guest memory only after guest tries to access it again and generate another fault. To save this fault we can map it immediately since we know that guest is going to access the page. Do it only when tdp is enabled for now. Shadow paging case is more complicated. CR[034] and EFER registers should be switched before doing mapping and then switched back. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Halt vcpu if page it tries to access is swapped outGleb Natapov
If a guest accesses swapped out memory do not swap it in from vcpu thread context. Schedule work to do swapping and put vcpu into halted state instead. Interrupts will still be delivered to the guest and if interrupt will cause reschedule guest will continue to run another task. [avi: remove call to get_user_pages_noio(), nacked by Linus; this makes everything synchrnous again] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
