path: root/virt/kvm/coalesced_mmio.h
2011-09-25KVM: Make coalesced mmio use a device per zoneSasha Levin
This patch changes coalesced mmio to create one mmio device per zone instead of handling all zones in one device. Doing so enables us to take advantage of existing locking and prevents a race condition between coalesced mmio registration/unregistration and lookups. Suggested-by: Avi Kivity <avi@redhat.com> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: Simplify coalesced mmio initializationAvi Kivity
- add destructor function - move related allocation into constructor - add stubs for !CONFIG_KVM_MMIO Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Add include guards for coalesced_mmio.hAvi Kivity
2009-09-10KVM: move coalesced_mmio locking to its own deviceMarcelo Tosatti
Move coalesced_mmio locking to its own device, instead of relying on kvm->lock. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-07-20KVM: Add coalesced MMIO support (common part)Laurent Vivier
This patch adds all needed structures to coalesce MMIOs. Until an architecture uses it, it is not compiled. Coalesced MMIO introduces two ioctl() to define where are the MMIO zones that can be coalesced: - KVM_REGISTER_COALESCED_MMIO registers a coalesced MMIO zone. It requests one parameter (struct kvm_coalesced_mmio_zone) which defines a memory area where MMIOs can be coalesced until the next switch to user space. The maximum number of MMIO zones is KVM_COALESCED_MMIO_ZONE_MAX. - KVM_UNREGISTER_COALESCED_MMIO cancels all registered zones inside the given bounds (bounds are also given by struct kvm_coalesced_mmio_zone). The userspace client can check kernel coalesced MMIO availability by asking ioctl(KVM_CHECK_EXTENSION) for the KVM_CAP_COALESCED_MMIO capability. The ioctl() call to KVM_CAP_COALESCED_MMIO will return 0 if not supported, or the page offset where will be stored the ring buffer. The page offset depends on the architecture. After an ioctl(KVM_RUN), the first page of the KVM memory mapped points to a kvm_run structure. The offset given by KVM_CAP_COALESCED_MMIO is an offset to the coalesced MMIO ring expressed in PAGE_SIZE relatively to the address of the start of th kvm_run structure. The MMIO ring buffer is defined by the structure kvm_coalesced_mmio_ring. [akio: fix oops during guest shutdown] Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Signed-off-by: Akio Takebe <takebe_akio@jp.fujitsu.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
