path: root/virt/kvm/eventfd.c
2014-05-05kvm/irqchip: Speed up KVM_SET_GSI_ROUTINGChristian Borntraeger
When starting lots of dataplane devices the bootup takes very long on Christian's s390 with irqfd patches. With larger setups he is even able to trigger some timeouts in some components. Turns out that the KVM_SET_GSI_ROUTING ioctl takes very long (strace claims up to 0.1 sec) when having multiple CPUs. This is caused by the synchronize_rcu and the HZ=100 of s390. By changing the code to use a private srcu we can speed things up. This patch reduces the boot time till mounting root from 8 to 2 seconds on my s390 guest with 100 disks. Uses of hlist_for_each_entry_rcu, hlist_add_head_rcu, hlist_del_init_rcu are fine because they do not have lockdep checks (hlist_for_each_entry_rcu uses rcu_dereference_raw rather than rcu_dereference, and write-sides do not do rcu lockdep at all). Note that we're hardly relying on the "sleepable" part of srcu. We just want SRCU's faster detection of grace periods. Testing was done by Andrew Theurer using netperf tests STREAM, MAERTS and RR. The difference between results "before" and "after" the patch has mean -0.2% and standard deviation 0.6%. Using a paired t-test on the data points says that there is a 2.5% probability that the patch is the cause of the performance difference (rather than a random fluctuation). (Restricting the t-test to RR, which is the most likely to be affected, changes the numbers to respectively -0.3% mean, 0.7% stdev, and 8% probability that the numbers actually say something about the patch. The probability increases mostly because there are fewer data points). Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Michael S. Tsirkin <mst@redhat.com> Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> # s390 Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-04-17KVM: VMX: speed up wildcard MMIO EVENTFDMichael S. Tsirkin
With KVM, MMIO is much slower than PIO, due to the need to do page walk and emulation. But with EPT, it does not have to be: we know the address from the VMCS so if the address is unique, we can look up the eventfd directly, bypassing emulation. Unfortunately, this only works if userspace does not need to match on access length and data. The implementation adds a separate FAST_MMIO bus internally. This serves two purposes: - minimize overhead for old userspace that does not use eventfd with lengtth = 0 - minimize disruption in other code (since we don't know the length, devices on the MMIO bus only get a valid address in write, this way we don't need to touch all devices to teach them to handle an invalid length) At the moment, this optimization only has effect for EPT on x86. It will be possible to speed up MMIO for NPT and MMU using the same idea in the future. With this patch applied, on VMX MMIO EVENTFD is essentially as fast as PIO. I was unable to detect any measureable slowdown to non-eventfd MMIO. Making MMIO faster is important for the upcoming virtio 1.0 which includes an MMIO signalling capability. The idea was suggested by Peter Anvin. Lots of thanks to Gleb for pre-review and suggestions. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2014-04-17KVM: support any-length wildcard ioeventfdMichael S. Tsirkin
It is sometimes benefitial to ignore IO size, and only match on address. In hindsight this would have been a better default than matching length when KVM_IOEVENTFD_FLAG_DATAMATCH is not set, In particular, this kind of access can be optimized on VMX: there no need to do page lookups. This can currently be done with many ioeventfds but in a suboptimal way. However we can't change kernel/userspace ABI without risk of breaking some applications. Use len = 0 to mean "ignore length for matching" in a more optimal way. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2014-03-18KVM: eventfd: Fix lock order inversion.Cornelia Huck
When registering a new irqfd, we call its ->poll method to collect any event that might have previously been pending so that we can trigger it. This is done under the kvm->irqfds.lock, which means the eventfd's ctx lock is taken under it. However, if we get a POLLHUP in irqfd_wakeup, we will be called with the ctx lock held before getting the irqfds.lock to deactivate the irqfd, causing lockdep to complain. Calling the ->poll method does not really need the irqfds.lock, so let's just move it after we've given up the irqfds.lock in kvm_irqfd_assign(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-09-03kvm eventfd: switch to fdgetAl Viro
2013-06-04kvm: exclude ioeventfd from counting kvm_io_range limitAmos Kong
We can easily reach the 1000 limit by start VM with a couple hundred I/O devices (multifunction=on). The hardcode limit already been adjusted 3 times (6 ~ 200 ~ 300 ~ 1000). In userspace, we already have maximum file descriptor to limit ioeventfd count. But kvm_io_bus devices also are used for pit, pic, ioapic, coalesced_mmio. They couldn't be limited by maximum file descriptor. Currently only ioeventfds take too much kvm_io_bus devices, so just exclude it from counting kvm_io_range limit. Also fixed one indent issue in kvm_host.h Signed-off-by: Amos Kong <akong@redhat.com> Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-26KVM: Introduce CONFIG_HAVE_KVM_IRQ_ROUTINGAlexander Graf
Quite a bit of code in KVM has been conditionalized on availability of IOAPIC emulation. However, most of it is generically applicable to platforms that don't have an IOPIC, but a different type of irq chip. Make code that only relies on IRQ routing, not an APIC itself, on CONFIG_HAVE_KVM_IRQ_ROUTING, so that we can reuse it later. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Michael S. Tsirkin <mst@redhat.com>
2013-04-15KVM: Let ioapic know the irq line statusYang Zhang
Userspace may deliver RTC interrupt without query the status. So we want to track RTC EOI for this case. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-07kvm: fix MMIO/PIO collision misdetectionMichael S. Tsirkin
PIO and MMIO are separate address spaces, but ioeventfd registration code mistakenly detected two eventfds as duplicate if they use the same address, even if one is PIO and another one MMIO. Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-03-05KVM: ioeventfd for virtio-ccw devices.Cornelia Huck
Enhance KVM_IOEVENTFD with a new flag that allows to attach to virtio-ccw devices on s390 via the KVM_VIRTIO_CCW_NOTIFY_BUS. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-05KVM: Initialize irqfd from kvm_init().Cornelia Huck
Currently, eventfd introduces module_init/module_exit functions to initialize/cleanup the irqfd workqueue. This only works, however, if no other module_init/module_exit functions are built into the same module. Let's just move the initialization and cleanup to kvm_init and kvm_exit. This way, it is also clearer where kvm startup may fail. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-10kvm: Fix irqfd resampler list walkAlex Williamson
Typo for the next pointer means we're walking random data here. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-06KVM: Distangle eventfd code from irqchipAlexander Graf
The current eventfd code assumes that when we have eventfd, we also have irqfd for in-kernel interrupt delivery. This is not necessarily true. On PPC we don't have an in-kernel irqchip yet, but we can still support easily support eventfd. Signed-off-by: Alexander Graf <agraf@suse.de>
2012-10-04Merge tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Avi Kivity: "Highlights of the changes for this release include support for vfio level triggered interrupts, improved big real mode support on older Intels, a streamlines guest page table walker, guest APIC speedups, PIO optimizations, better overcommit handling, and read-only memory." * tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits) KVM: s390: Fix vcpu_load handling in interrupt code KVM: x86: Fix guest debug across vcpu INIT reset KVM: Add resampling irqfds for level triggered interrupts KVM: optimize apic interrupt delivery KVM: MMU: Eliminate pointless temporary 'ac' KVM: MMU: Avoid access/dirty update loop if all is well KVM: MMU: Eliminate eperm temporary KVM: MMU: Optimize is_last_gpte() KVM: MMU: Simplify walk_addr_generic() loop KVM: MMU: Optimize pte permission checks KVM: MMU: Update accessed and dirty bits after guest pagetable walk KVM: MMU: Move gpte_access() out of paging_tmpl.h KVM: MMU: Optimize gpte_access() slightly KVM: MMU: Push clean gpte write protection out of gpte_access() KVM: clarify kvmclock documentation KVM: make processes waiting on vcpu mutex killable KVM: SVM: Make use of asm.h KVM: VMX: Make use of asm.h KVM: VMX: Make lto-friendly KVM: x86: lapic: Clean up find_highest_vector() and count_vectors() ... Conflicts: arch/s390/include/asm/processor.h arch/x86/kvm/i8259.c
2012-09-23KVM: Add resampling irqfds for level triggered interruptsAlex Williamson
To emulate level triggered interrupts, add a resample option to KVM_IRQFD. When specified, a new resamplefd is provided that notifies the user when the irqchip has been resampled by the VM. This may, for instance, indicate an EOI. Also in this mode, posting of an interrupt through an irqfd only asserts the interrupt. On resampling, the interrupt is automatically de-asserted prior to user notification. This enables level triggered interrupts to be posted and re-enabled from vfio with no userspace intervention. All resampling irqfds can make use of a single irq source ID, so we reserve a new one for this interface. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-08-20workqueue: deprecate flush[_delayed]_work_sync()Tejun Heo
flush[_delayed]_work_sync() are now spurious. Mark them deprecated and convert all users to flush[_delayed]_work(). If you're cc'd and wondering what's going on: Now all workqueues are non-reentrant and the regular flushes guarantee that the work item is not pending or running on any CPU on return, so there's no reason to use the sync flushes at all and they're going away. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Mattia Dongili <malattia@linux.it> Cc: Kent Yoder <key@linux.vnet.ibm.com> Cc: David Airlie <airlied@linux.ie> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Bryan Wu <bryan.wu@canonical.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Alasdair Kergon <agk@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: linux-wireless@vger.kernel.org Cc: Anton Vorontsov <cbou@mail.ru> Cc: Sangbeom Kim <sbkim73@samsung.com> Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Avi Kivity <avi@redhat.com>
2012-07-02KVM: Sanitize KVM_IRQFD flagsAlex Williamson
We only know of one so far. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-07-02KVM: Pass kvm_irqfd to functionsAlex Williamson
Prune this down to just the struct kvm_irqfd so we can avoid changing function definition for every flag or field we use. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-25KVM: Intelligent device lookup on I/O busSasha Levin
Currently the method of dealing with an IO operation on a bus (PIO/MMIO) is to call the read or write callback for each device registered on the bus until we find a device which handles it. Since the number of devices on a bus can be significant due to ioeventfds and coalesced MMIO zones, this leads to a lot of overhead on each IO operation. Instead of registering devices, we now register ranges which points to a device. Lookup is done using an efficient bsearch instead of a linear search. Performance test was conducted by comparing exit count per second with 200 ioeventfds created on one byte and the guest is trying to access a different byte continuously (triggering usermode exits). Before the patch the guest has achieved 259k exits per second, after the patch the guest does 274k exits per second. Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-04-07Merge branch 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: move and fix substitue search for missing CPUID entries KVM: fix XSAVE bit scanning KVM: Enable async page fault processing KVM: fix crash on irqfd deassign
2011-04-06KVM: fix crash on irqfd deassignMichael S. Tsirkin
irqfd in kvm used flush_work incorrectly: it assumed that work scheduled previously can't run after flush_work, but since kvm uses a non-reentrant workqueue (by means of schedule_work) we need flush_work_sync to get that guarantee. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Reported-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr> Tested-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: improve comment on rcu use in irqfd_deassignMichael S. Tsirkin
The RCU use in kvm_irqfd_deassign is tricky: we have rcu_assign_pointer but no synchronize_rcu: synchronize_rcu is done by kvm_irq_routing_update which we share a spinlock with. Fix up a comment in an attempt to make this clearer. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: fast-path msi injection with irqfdMichael S. Tsirkin
Store irq routing table pointer in the irqfd object, and use that to inject MSI directly without bouncing out to a kernel thread. While we touch this structure, rearrange irqfd fields to make fastpath better packed for better cache utilization. This also adds some comments about locking rules and rcu usage in code. Some notes on the design: - Use pointer into the rt instead of copying an entry, to make it possible to use rcu, thus side-stepping locking complexities. We also save some memory this way. - Old workqueue code is still used for level irqs. I don't think we DTRT with level anyway, however, it seems easier to keep the code around as it has been thought through and debugged, and fix level later than rip out and re-instate it later. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-09-23KVM: fix irqfd assign/deassign raceMichael S. Tsirkin
I think I see the following (theoretical) race: During irqfd assign, we drop irqfds lock before we schedule inject work. Therefore, deassign running on another CPU could cause shutdown and flush to run before inject, causing user after free in inject. A simple fix it to schedule inject under the lock. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Update Red Hat copyrightsAvi Kivity
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01KVM: do not store wqh in irqfdMichael S. Tsirkin
wqh is unused, so we do not need to store it in irqfd anymore Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: convert slots_lock to a mutexMarcelo Tosatti
2010-03-01KVM: convert io_bus to SRCUMarcelo Tosatti
2010-01-25KVM: fix spurious interrupt with irqfdMichael S. Tsirkin
kvm didn't clear irqfd counter on deassign, as a result we could get a spurious interrupt when irqfd is assigned back. this leads to poor performance and, in theory, guest crash. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-01-25KVM: only allow one gsi per fdMichael S. Tsirkin
Looks like repeatedly binding same fd to multiple gsi's with irqfd can use up a ton of kernel memory for irqfd structures. A simple fix is to allow each fd to only trigger one gsi: triggering a storm of interrupts in guest is likely useless anyway, and we can do it by binding a single gsi to many interrupts if we really want to. Cc: stable@kernel.org Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Drop kvm->irq_lock lock from irq injection pathGleb Natapov
The only thing it protects now is interrupt injection into lapic and this can work lockless. Even now with kvm->irq_lock in place access to lapic is not entirely serialized since vcpu access doesn't take kvm->irq_lock. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: correct error-handling codeJulia Lawall
This code is not executed before file has been initialized to the result of calling eventfd_fget. This function returns an ERR_PTR value in an error case instead of NULL. Thus the test that file is not NULL is always true. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @match exists@ expression x, E; statement S1, S2; @@ x = eventfd_fget(...) ... when != x = E ( * if (x == NULL || ...) S1 else S2 | * if (x == NULL && ...) S1 else S2 ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: add ioeventfd supportGregory Haskins
ioeventfd is a mechanism to register PIO/MMIO regions to trigger an eventfd signal when written to by a guest. Host userspace can register any arbitrary IO address with a corresponding eventfd and then pass the eventfd to a specific end-point of interest for handling. Normal IO requires a blocking round-trip since the operation may cause side-effects in the emulated model or may return data to the caller. Therefore, an IO in KVM traps from the guest to the host, causes a VMX/SVM "heavy-weight" exit back to userspace, and is ultimately serviced by qemu's device model synchronously before returning control back to the vcpu. However, there is a subclass of IO which acts purely as a trigger for other IO (such as to kick off an out-of-band DMA request, etc). For these patterns, the synchronous call is particularly expensive since we really only want to simply get our notification transmitted asychronously and return as quickly as possible. All the sychronous infrastructure to ensure proper data-dependencies are met in the normal IO case are just unecessary overhead for signalling. This adds additional computational load on the system, as well as latency to the signalling path. Therefore, we provide a mechanism for registration of an in-kernel trigger point that allows the VCPU to only require a very brief, lightweight exit just long enough to signal an eventfd. This also means that any clients compatible with the eventfd interface (which includes userspace and kernelspace equally well) can now register to be notified. The end result should be a more flexible and higher performance notification API for the backend KVM hypervisor and perhipheral components. To test this theory, we built a test-harness called "doorbell". This module has a function called "doorbell_ring()" which simply increments a counter for each time the doorbell is signaled. It supports signalling from either an eventfd, or an ioctl(). We then wired up two paths to the doorbell: One via QEMU via a registered io region and through the doorbell ioctl(). The other is direct via ioeventfd. You can download this test harness here: ftp://ftp.novell.com/dev/ghaskins/doorbell.tar.bz2 The measured results are as follows: qemu-mmio: 110000 iops, 9.09us rtt ioeventfd-mmio: 200100 iops, 5.00us rtt ioeventfd-pio: 367300 iops, 2.72us rtt I didn't measure qemu-pio, because I have to figure out how to register a PIO region with qemu's device model, and I got lazy. However, for now we can extrapolate based on the data from the NULLIO runs of +2.56us for MMIO, and -350ns for HC, we get: qemu-pio: 153139 iops, 6.53us rtt ioeventfd-hc: 412585 iops, 2.37us rtt these are just for fun, for now, until I can gather more data. Here is a graph for your convenience: http://developer.novell.com/wiki/images/7/76/Iofd-chart.png The conclusion to draw is that we save about 4us by skipping the userspace hop. -------------------- Signed-off-by: Gregory Haskins <ghaskins@novell.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: switch irq injection/acking data structures to irq_lockMarcelo Tosatti
Protect irq injection/acking data structures with a separate irq_lock mutex. This fixes the following deadlock: CPU A CPU B kvm_vm_ioctl_deassign_dev_irq() mutex_lock(&kvm->lock); worker_thread() -> kvm_deassign_irq() -> kvm_assigned_dev_interrupt_work_handler() -> deassign_host_irq() mutex_lock(&kvm->lock); -> cancel_work_sync() [blocked] [gleb: fix ia64 path] Reported-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: irqfdGregory Haskins
KVM provides a complete virtual system environment for guests, including support for injecting interrupts modeled after the real exception/interrupt facilities present on the native platform (such as the IDT on x86). Virtual interrupts can come from a variety of sources (emulated devices, pass-through devices, etc) but all must be injected to the guest via the KVM infrastructure. This patch adds a new mechanism to inject a specific interrupt to a guest using a decoupled eventfd mechnanism: Any legal signal on the irqfd (using eventfd semantics from either userspace or kernel) will translate into an injected interrupt in the guest at the next available interrupt window. Signed-off-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
