commit 0f6c0a740b7d3e1f3697395922d674000f83d060 upstream.
Currently, the EOI exit bitmap (used for APICv) does not include
interrupts that are masked. However, this can cause a bug that manifests
as an interrupt storm inside the guest. Alex Williamson reported the
bug and is the one who really debugged this; I only wrote the patch. :)
The scenario involves a multi-function PCI device with OHCI and EHCI
USB functions and an audio function, all assigned to the guest, where
both USB functions use legacy INTx interrupts.
As soon as the guest boots, interrupts for these devices turn into an
interrupt storm in the guest; the host does not see the interrupt storm.
Basically the EOI path does not work, and the guest continues to see the
interrupt over and over, even after it attempts to mask it at the APIC.
The bug is only visible with older kernels (RHEL6.5, based on 2.6.32
with not many changes in the area of APIC/IOAPIC handling).
Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ)
on in the eoi_exit_bitmap and TMR, and things then work. What happens
is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap.
It does not have set bit 59 because the RTE was masked, so the IOAPIC
never sees the EOI and the interrupt continues to fire in the guest.
My guess was that the guest is masking the interrupt in the redirection
table in the interrupt routine, i.e. while the interrupt is set in a
LAPIC's ISR, The simplest fix is to ignore the masking state, we would
rather have an unnecessary exit rather than a missed IRQ ACK and anyway
IOAPIC interrupts are not as performance-sensitive as for example MSIs.
Alex tested this patch and it fixed his bug.
[Thanks to Alex for his precise description of the problem
and initial debugging effort. A lot of the text above is
based on emails exchanged with him.]
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
commit 5678de3f15010b9022ee45673f33bcfc71d47b60 upstream.
QE reported that they got the BUG_ON in ioapic_service to trigger.
I cannot reproduce it, but there are two reasons why this could happen.
The less likely but also easiest one, is when kvm_irq_delivery_to_apic
does not deliver to any APIC and returns -1.
Because irqe.shorthand == 0, the kvm_for_each_vcpu loop in that
function is never reached. However, you can target the similar loop in
kvm_irq_delivery_to_apic_fast; just program a zero logical destination
address into the IOAPIC, or an out-of-range physical destination address.
We already know the trigger mode of a given interrupt when programming
the ioapice entry. So it's not necessary to set it in each interrupt
delivery.
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
Reviewed-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Both TMR and EOI exit bitmap need to be updated when ioapic changed
or vcpu's id/ldr/dfr changed. So use common function instead eoi exit
bitmap specific function.
Current interrupt coalescing logci which only used by RTC has conflict
with Posted Interrupt.
This patch introduces a new mechinism to use eoi to track interrupt:
When delivering an interrupt to vcpu, the pending_eoi set to number of
vcpu that received the interrupt. And decrease it when each vcpu writing
eoi. No subsequent RTC interrupt can deliver to vcpu until all vcpus
write eoi.
Userspace may deliver RTC interrupt without query the status. So we
want to track RTC EOI for this case.
Need the EOI to track interrupt deliver status, so force vmexit
on EOI for rtc interrupt when enabling virtual interrupt delivery.
restore rtc_status from migration or save/restore
Add a new parameter to know vcpus who received the interrupt.
Add vcpu info to ioapic_update_eoi, so we can know which vcpu
issued this EOI.
For a given vcpu, kvm_apic_match_dest() will tell you whether
the vcpu in the destination list quickly. Drop kvm_calculate_eoi_exitmap()
and use kvm_apic_match_dest() instead.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
If the guest specifies a IOAPIC_REG_SELECT with an invalid value and follows
that with a read of the IOAPIC_REG_WINDOW KVM does not properly validate
that request. ioapic_read_indirect contains an
ASSERT(redir_index < IOAPIC_NUM_PINS), but the ASSERT has no effect in
non-debug builds. In recent kernels this allows a guest to cause a kernel
oops by reading invalid memory. In older kernels (pre-3.3) this allows a
guest to read from large ranges of host memory.
Tested: tested against apic unit tests.
Signed-off-by: Andrew Honig <ahonig@google.com>
Virtual interrupt delivery avoids KVM to inject vAPIC interrupts
manually, which is fully taken care of by the hardware. This needs
some special awareness into existing interrupr injection path:
- for pending interrupt, instead of direct injection, we may need
update architecture specific indicators before resuming to guest.
- A pending interrupt, which is masked by ISR, should be also
considered in above update action, since hardware will decide
when to inject it at right time. Current has_interrupt and
get_interrupt only returns a valid vector from injection p.o.v.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Kevin Tian <kevin.tian@intel.com>
This hack is wrong. The pin number of PIT is connected to
2 not 0. This means this hack never takes effect. So it is ok
to remove it.
We validate irq pin number when routing is setup, so
code handling illegal irq # in pic and ioapic on each injection
is never called.
Drop it, replace with BUG_ON to catch out of bounds access bugs.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
When more than 1 source id is in use for the same GSI, we have the
following race related to handling irq_states race:
CPU 0 clears bit 0. CPU 0 read irq_state as 0. CPU 1 sets level to 1.
CPU 1 calls kvm_ioapic_set_irq(1). CPU 0 calls kvm_ioapic_set_irq(0).
Now ioapic thinks the level is 0 but irq_state is not 0.
Fix by performing all irq_states bitmap handling under pic/ioapic lock.
This also removes the need for atomics with irq_states handling.
Reported-by: Gleb Natapov <gleb@redhat.com>
Intel spec says that TMR needs to be set/cleared
when IRR is set, but kvm also clears it on EOI.
I did some tests on a real (AMD based) system,
and I see same TMR values both before
and after EOI, so I think it's a minor bug in kvm.
This patch fixes TMR to be set/cleared on IRR set
only as per spec.
And now that we don't clear TMR, we can save
an atomic read of TMR on EOI that's not propagated
to ioapic, by checking whether ioapic needs
a specific vector first and calculating
the mode afterwards.
Drop bsp_vcpu pointer from kvm struct since its only use is incorrect
anyway.
This fixes byte accesses to IOAPIC_REG_SELECT as mandated by at least the
ICH10 and Intel Series 5 chipset specs. It also makes ioapic_mmio_write
consistent with ioapic_mmio_read, which also allows byte and word accesses.
Signed-off-by: Julian Stecklina <js@alien8.de>
Signed-off-by: Avi Kivity <avi@redhat.com>
Currently the method of dealing with an IO operation on a bus (PIO/MMIO)
is to call the read or write callback for each device registered
on the bus until we find a device which handles it.
Since the number of devices on a bus can be significant due to ioeventfds
and coalesced MMIO zones, this leads to a lot of overhead on each IO
operation.
Instead of registering devices, we now register ranges which points to
a device. Lookup is done using an efficient bsearch instead of a linear
search.
Performance test was conducted by comparing exit count per second with
200 ioeventfds created on one byte and the guest is trying to access a
different byte continuously (triggering usermode exits).
Before the patch the guest has achieved 259k exits per second, after the
patch the guest does 274k exits per second.
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Function ioapic_debug() in the ioapic_deliver() misnames
one filed by reference. This patch correct it.
Signed-off-by: Liu Yuan <tailai.ly@taobao.com>
Devices register mask notifier using gsi, but irqchip knows about
irqchip/pin, so conversion from irqchip/pin to gsi should be done before
looking for mask notifier to call.
Read ioapic->irr inside ioapic->lock protected section.
KVM-Stable-Tag
kvm_set_irq is used from non sleepable contexes, so convert ioapic from
mutex to spinlock.
KVM-Stable-Tag.
Tested-by: Ralf Bonenkamp <ralf.bonenkamp@swyx.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
If we fail to init ioapic device or the fail to setup the default irq
routing, the device register by kvm_create_pic() and kvm_ioapic_init()
remain unregister. This patch fixed to do this.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
kvm->arch.vioapic should be NULL in case of kvm_ioapic_init() failure
due to cannot register io dev.
When the guest acknowledges an interrupt, it sends an EOI message to the local
apic, which broadcasts it to the ioapic. To handle the EOI, we need to take
the ioapic mutex.
On large guests, this causes a lot of contention on this mutex. Since large
guests usually don't route interrupts via the ioapic (they use msi instead),
this is completely unnecessary.
Avoid taking the mutex by introducing a handled_vectors bitmap. Before taking
the mutex, check if the ioapic was actually responsible for the acked vector.
If not, we can return early.
The allows removal of irq_lock from the injection path.
This bug was introduced by b4a2f5e723e4f7df467.
Cc: stable@kernel.org
Today kvm_io_bus_regsiter_dev() returns void and will internally BUG_ON
if it fails. We want to create dynamic MMIO/PIO entries driven from
userspace later in the series, so we need to enhance the code to be more
robust with the following changes:
1) Add a return value to the registration function
2) Fix up all the callsites to check the return code, handle any
failures, and percolate the error up to the caller.
3) Add an unregister function that collapses holes in the array
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Add tracepoint in msi/ioapic/pic set_irq() functions,
in IPI sending and in the point where IRQ is placed into
apic's IRR.
Cosmetic only. No logic is changed by this patch.
There is a missing unlock on one fail path in ioapic_mmio_write,
fix that.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
This changes bus accesses to use high-level kvm_io_bus_read/kvm_io_bus_write
functions. in_range now becomes unused so it is removed from device ops in
favor of read/write callbacks performing range checks internally.
This allows aliasing (mostly for in-kernel virtio), as well as better error
handling by making it possible to pass errors up to userspace.
Use slots_lock to protect device list on the bus. slots_lock is already
taken for read everywhere, so we only need to take it for write when
registering devices. This is in preparation to removing in_range and
kvm->lock around it.
Use it instead of open code "vcpu_id zero is BSP" assumption.
Introduce irq_lock, and use to protect ioapic data structures.
We modernize the io_device code so that we use container_of() instead of
dev->private, and move the vtable to a separate ops structure
(theoretically allows better caching for multiple instances of the same
ops structure)
Acked-by: Chris Wright <chrisw@sous-sol.org>
The check for an edge is broken in current ioapic code. ioapic->irr is
cleared on each edge interrupt by ioapic_service() and this makes
old_irr != ioapic->irr condition in kvm_ioapic_set_irq() to be always
true. The patch fixes the code to properly recognise edge.
Some HW emulation calls set_irq() without level change. If each such
call is propagated to an OS it may confuse a device driver. This is the
case with keyboard device emulation and Windows XP x64 installer on SMP VM.
Each keystroke produce two interrupts (down/up) one interrupt is
submitted to CPU0 and another to CPU1. This confuses Windows somehow
and it ignores keystrokes.
Deliver interrupt during destination matching loop.
Acked-by: Xiantao Zhang <xiantao.zhang@intel.com>
Use kvm_apic_match_dest() in kvm_get_intr_delivery_bitmask() instead
of duplicating the same code. Use kvm_get_intr_delivery_bitmask() in
apic_send_ipi() to figure out ipi destination instead of reimplementing
the logic.
ioapic_deliver() and kvm_set_msi() have code duplication. Move
the code into ioapic_deliver_entry() function and call it from
both places.
Get rid of ioapic_inj_irq() and ioapic_inj_nmi() functions.
Gleb fixed bitmap ops usage in kvm_ioapic_get_delivery_bitmask.
Sheng merged two functions, as well as fixed several issues in
1. deliver_bitmask is a bitmap rather than a unsigned long intereger.
2. Lowest priority target bitmap wrong calculated by mistake.
3. Prevent potential NULL reference.
4. Declaration in include/kvm_host.h caused powerpc compilation warning.
5. Add warning for guest broadcast interrupt with lowest priority delivery mode.
6. Removed duplicate bitmap clean up in caller of kvm_get_intr_delivery_bitmask.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
It's also convenient when we extend KVM supported vcpu number in the future.
In order to use with bit ops.
