path: root/virt/kvm/irq_comm.c
2012-09-23KVM: Add resampling irqfds for level triggered interruptsAlex Williamson
To emulate level triggered interrupts, add a resample option to KVM_IRQFD. When specified, a new resamplefd is provided that notifies the user when the irqchip has been resampled by the VM. This may, for instance, indicate an EOI. Also in this mode, posting of an interrupt through an irqfd only asserts the interrupt. On resampling, the interrupt is automatically de-asserted prior to user notification. This enables level triggered interrupts to be posted and re-enabled from vfio with no userspace intervention. All resampling irqfds can make use of a single irq source ID, so we reserve a new one for this interface. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-09-20KVM: optimize apic interrupt deliveryGleb Natapov
Most interrupt are delivered to only one vcpu. Use pre-build tables to find interrupt destination instead of looping through all vcpus. In case of logical mode loop only through vcpus in a logical cluster irq is sent to. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-26Merge branch 'queue' into nextAvi Kivity
Merge patches queued during the run-up to the merge window. * queue: (25 commits) KVM: Choose better candidate for directed yield KVM: Note down when cpu relax intercepted or pause loop exited KVM: Add config to support ple or cpu relax optimzation KVM: switch to symbolic name for irq_states size KVM: x86: Fix typos in pmu.c KVM: x86: Fix typos in lapic.c KVM: x86: Fix typos in cpuid.c KVM: x86: Fix typos in emulate.c KVM: x86: Fix typos in x86.c KVM: SVM: Fix typos KVM: VMX: Fix typos KVM: remove the unused parameter of gfn_to_pfn_memslot KVM: remove is_error_hpa KVM: make bad_pfn static to kvm_main.c KVM: using get_fault_pfn to get the fault pfn KVM: MMU: track the refcount when unmap the page KVM: x86: remove unnecessary mark_page_dirty KVM: MMU: Avoid handling same rmap_pde in kvm_handle_hva_range() KVM: MMU: Push trace_kvm_age_page() into kvm_age_rmapp() KVM: MMU: Add memslot parameter to hva handlers ... Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-24Merge tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Avi Kivity: "Highlights include - full big real mode emulation on pre-Westmere Intel hosts (can be disabled with emulate_invalid_guest_state=0) - relatively small ppc and s390 updates - PCID/INVPCID support in guests - EOI avoidance; 3.6 guests should perform better on 3.6 hosts on interrupt intensive workloads) - Lockless write faults during live migration - EPT accessed/dirty bits support for new Intel processors" Fix up conflicts in: - Documentation/virtual/kvm/api.txt: Stupid subchapter numbering, added next to each other. - arch/powerpc/kvm/booke_interrupts.S: PPC asm changes clashing with the KVM fixes - arch/s390/include/asm/sigp.h, arch/s390/kvm/sigp.c: Duplicated commits through the kvm tree and the s390 tree, with subsequent edits in the KVM tree. * tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (93 commits) KVM: fix race with level interrupts x86, hyper: fix build with !CONFIG_KVM_GUEST Revert "apic: fix kvm build on UP without IOAPIC" KVM guest: switch to apic_set_eoi_write, apic_write apic: add apic_set_eoi_write for PV use KVM: VMX: Implement PCID/INVPCID for guests with EPT KVM: Add x86_hyper_kvm to complete detect_hypervisor_platform check KVM: PPC: Critical interrupt emulation support KVM: PPC: e500mc: Fix tlbilx emulation for 64-bit guests KVM: PPC64: booke: Set interrupt computation mode for 64-bit host KVM: PPC: bookehv: Add ESR flag to Data Storage Interrupt KVM: PPC: bookehv64: Add support for std/ld emulation. booke: Added crit/mc exception handler for e500v2 booke/bookehv: Add host crit-watchdog exception support KVM: MMU: document mmu-lock and fast page fault KVM: MMU: fix kvm_mmu_pagetable_walk tracepoint KVM: MMU: trace fast page fault KVM: MMU: fast path of handling guest page fault KVM: MMU: introduce SPTE_MMU_WRITEABLE bit KVM: MMU: fold tlb flush judgement into mmu_spte_update ...
2012-07-20KVM: switch to symbolic name for irq_states sizeMichael S. Tsirkin
Use PIC_NUM_PINS instead of hard-coded 16 for pic pins. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-07-20KVM: fix race with level interruptsMichael S. Tsirkin
When more than 1 source id is in use for the same GSI, we have the following race related to handling irq_states race: CPU 0 clears bit 0. CPU 0 read irq_state as 0. CPU 1 sets level to 1. CPU 1 calls kvm_ioapic_set_irq(1). CPU 0 calls kvm_ioapic_set_irq(0). Now ioapic thinks the level is 0 but irq_state is not 0. Fix by performing all irq_states bitmap handling under pic/ioapic lock. This also removes the need for atomics with irq_states handling. Reported-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-06-05KVM: Fix buffer overflow in kvm_set_irq()Avi Kivity
kvm_set_irq() has an internal buffer of three irq routing entries, allowing connecting a GSI to three IRQ chips or on MSI. However setup_routing_entry() does not properly enforce this, allowing three irqchip routes followed by an MSI route to overflow the buffer. Fix by ensuring that an MSI entry is added to an empty list. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-24KVM: Introduce direct MSI message injection for in-kernel irqchipsJan Kiszka
Currently, MSI messages can only be injected to in-kernel irqchips by defining a corresponding IRQ route for each message. This is not only unhandy if the MSI messages are generated "on the fly" by user space, IRQ routes are a limited resource that user space has to manage carefully. By providing a direct injection path, we can both avoid using up limited resources and simplify the necessary steps for user land. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: fast-path msi injection with irqfdMichael S. Tsirkin
Store irq routing table pointer in the irqfd object, and use that to inject MSI directly without bouncing out to a kernel thread. While we touch this structure, rearrange irqfd fields to make fastpath better packed for better cache utilization. This also adds some comments about locking rules and rcu usage in code. Some notes on the design: - Use pointer into the rt instead of copying an entry, to make it possible to use rcu, thus side-stepping locking complexities. We also save some memory this way. - Old workqueue code is still used for level irqs. I don't think we DTRT with level anyway, however, it seems easier to keep the code around as it has been thought through and debugged, and fix level later than rip out and re-instate it later. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: fix typo in copyright noticeNicolas Kaiser
Fix typo in copyright notice. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-02KVM: Convert mask notifiers to use irqchip/pin instead of gsiGleb Natapov
Devices register mask notifier using gsi, but irqchip knows about irqchip/pin, so conversion from irqchip/pin to gsi should be done before looking for mask notifier to call. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: x86: In DM_LOWEST, only deliver interrupts to vcpus with enabled LAPIC'sChris Lalancette
Otherwise we might try to deliver a timer interrupt to a cpu that can't possibly handle it. Signed-off-by: Chris Lalancette <clalance@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Update Red Hat copyrightsAvi Kivity
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-25KVM: properly check max PIC pin in irq route setupMarcelo Tosatti
Otherwise memory beyond irq_states[16] might be accessed. Noticed by Juan Quintela. Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Juan Quintela <quintela@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: only clear irq_source_id if irqchip is presentMarcelo Tosatti
Otherwise kvm might attempt to dereference a NULL pointer. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: fix irq_source_id size verificationMarcelo Tosatti
find_first_zero_bit works with bit numbers, not bytes. Fixes https://sourceforge.net/tracker/?func=detail&aid=2847560&group_id=180599&atid=893831 Reported-by: "Xu, Jiajun" <jiajun.xu@intel.com> Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-03KVM: fix lock imbalance in kvm_*_irq_source_id()Jiri Slaby
Stanse found 2 lock imbalances in kvm_request_irq_source_id and kvm_free_irq_source_id. They omit to unlock kvm->irq_lock on fail paths. Fix that by adding unlock labels at the end of the functions and jump there from the fail paths. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Drop kvm->irq_lock lock from irq injection pathGleb Natapov
The only thing it protects now is interrupt injection into lapic and this can work lockless. Even now with kvm->irq_lock in place access to lapic is not entirely serialized since vcpu access doesn't take kvm->irq_lock. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move IO APIC to its own lockGleb Natapov
The allows removal of irq_lock from the injection path. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Convert irq notifiers lists to RCU lockingGleb Natapov
Use RCU locking for mask/ack notifiers lists. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq ack notifier list to arch independent codeGleb Natapov
Mask irq notifier list is already there. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq routing data structure to rcu lockingGleb Natapov
2009-12-03KVM: Maintain back mapping from irqchip/pin to gsiGleb Natapov
Maintain back mapping from irqchip/pin to gsi to speedup interrupt acknowledgment notifications. [avi: build fix on non-x86/ia64] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Change irq routing table to use gsi indexed arrayGleb Natapov
Use gsi indexed array instead of scanning all entries on each interrupt injection. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq sharing information to irqchip levelGleb Natapov
This removes assumptions that max GSIs is smaller than number of pins. Sharing is tracked on pin level not GSI level. [avi: no PIC on ia64] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Add trace points in irqchip codeGleb Natapov
Add tracepoint in msi/ioapic/pic set_irq() functions, in IPI sending and in the point where IRQ is placed into apic's IRR. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: ignore msi request if !levelMichael S. Tsirkin
Irqfd sets level for interrupt to 1 and then to 0. For MSI, check level so that a single message is sent. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Trace irq level and source idAvi Kivity
2009-09-10KVM: convert custom marker based tracing to event tracesMarcelo Tosatti
This allows use of the powerful ftrace infrastructure. See Documentation/trace/ for usage information. [avi, stephen: various build fixes] [sheng: fix control register breakage] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Use macro to iterate over vcpus.Gleb Natapov
[christian: remove unused variables on s390] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: switch irq injection/acking data structures to irq_lockMarcelo Tosatti
Protect irq injection/acking data structures with a separate irq_lock mutex. This fixes the following deadlock: CPU A CPU B kvm_vm_ioctl_deassign_dev_irq() mutex_lock(&kvm->lock); worker_thread() -> kvm_deassign_irq() -> kvm_assigned_dev_interrupt_work_handler() -> deassign_host_irq() mutex_lock(&kvm->lock); -> cancel_work_sync() [blocked] [gleb: fix ia64 path] Reported-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-08-05KVM: fix ack not being delivered when msi presentMichael S. Tsirkin
kvm_notify_acked_irq does not check irq type, so that it sometimes interprets msi vector as irq. As a result, ack notifiers are not called, which typially hangs the guest. The fix is to track and check irq type. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Trivial format fix in setup_routing_entry()Chris Wright
Remove extra tab. Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: APIC: get rid of deliver_bitmaskGleb Natapov
Deliver interrupt during destination matching loop. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: change the way how lowest priority vcpu is calculatedGleb Natapov
The new way does not require additional loop over vcpus to calculate the one with lowest priority as one is chosen during delivery bitmap construction. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: consolidate ioapic/ipi interrupt delivery logicGleb Natapov
Use kvm_apic_match_dest() in kvm_get_intr_delivery_bitmask() instead of duplicating the same code. Use kvm_get_intr_delivery_bitmask() in apic_send_ipi() to figure out ipi destination instead of reimplementing the logic. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: ioapic/msi interrupt delivery consolidationGleb Natapov
ioapic_deliver() and kvm_set_msi() have code duplication. Move the code into ioapic_deliver_entry() function and call it from both places. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: APIC: kvm_apic_set_irq deliver all kinds of interruptsGleb Natapov
Get rid of ioapic_inj_irq() and ioapic_inj_nmi() functions. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: Merge kvm_ioapic_get_delivery_bitmask into kvm_get_intr_delivery_bitmaskSheng Yang
Gleb fixed bitmap ops usage in kvm_ioapic_get_delivery_bitmask. Sheng merged two functions, as well as fixed several issues in kvm_get_intr_delivery_bitmask 1. deliver_bitmask is a bitmap rather than a unsigned long intereger. 2. Lowest priority target bitmap wrong calculated by mistake. 3. Prevent potential NULL reference. 4. Declaration in include/kvm_host.h caused powerpc compilation warning. 5. Add warning for guest broadcast interrupt with lowest priority delivery mode. 6. Removed duplicate bitmap clean up in caller of kvm_get_intr_delivery_bitmask. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: bit ops for deliver_bitmapSheng Yang
It's also convenient when we extend KVM supported vcpu number in the future. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Update intr delivery func to accept unsigned long* bitmapSheng Yang
Would be used with bit ops, and would be easily extended if KVM_MAX_VCPUS is increased. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Change API of kvm_ioapic_get_delivery_bitmaskSheng Yang
In order to use with bit ops. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Unify the delivery of IOAPIC and MSI interruptsSheng Yang
2009-03-24KVM: fix sparse warnings: Should it be static?Hannes Eder
Impact: Make symbols static. Fix this sparse warnings: arch/x86/kvm/mmu.c:992:5: warning: symbol 'mmu_pages_add' was not declared. Should it be static? arch/x86/kvm/mmu.c:1124:5: warning: symbol 'mmu_pages_next' was not declared. Should it be static? arch/x86/kvm/mmu.c:1144:6: warning: symbol 'mmu_pages_clear_parents' was not declared. Should it be static? arch/x86/kvm/x86.c:2037:5: warning: symbol 'kvm_read_guest_virt' was not declared. Should it be static? arch/x86/kvm/x86.c:2067:5: warning: symbol 'kvm_write_guest_virt' was not declared. Should it be static? virt/kvm/irq_comm.c:220:5: warning: symbol 'setup_routing_entry' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: ia64: Fix the build errors due to lack of macros related to MSI.Xiantao Zhang
Include the newly introduced msidef.h to solve the build issues. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Report IRQ injection status for MSI delivered interruptsGleb Natapov
Return number of CPUs interrupt was successfully injected into or -1 if none. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Report IRQ injection status to userspace.Gleb Natapov
IRQ injection status is either -1 (if there was no CPU found that should except the interrupt because IRQ was masked or ioapic was misconfigured or ...) or >= 0 in that case the number indicates to how many CPUs interrupt was injected. If the value is 0 it means that the interrupt was coalesced and probably should be reinjected. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Use irq routing API for MSISheng Yang
Merge MSI userspace interface with IRQ routing table. Notice the API have been changed, and using IRQ routing table would be the only interface kvm-userspace supported. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: make irq ack notifications aware of routing tableMarcelo Tosatti
IRQ ack notifications assume an identity mapping between pin->gsi, which might not be the case with, for example, HPET. Translate before acking. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Gleb Natapov <gleb@redhat.com>
