path: root/virt
2015-10-27kvm: fix double free for fast mmio eventfdJason Wang
[ Upstream commit eefd6b06b17c5478e7c24bea6f64beaa2c431ca6 ] We register wildcard mmio eventfd on two buses, once for KVM_MMIO_BUS and once on KVM_FAST_MMIO_BUS but with a single iodev instance. This will lead to an issue: kvm_io_bus_destroy() knows nothing about the devices on two buses pointing to a single dev. Which will lead to double free[1] during exit. Fix this by allocating two instances of iodevs then registering one on KVM_MMIO_BUS and another on KVM_FAST_MMIO_BUS. CPU: 1 PID: 2894 Comm: qemu-system-x86 Not tainted 3.19.0-26-generic #28-Ubuntu Hardware name: LENOVO 2356BG6/2356BG6, BIOS G7ET96WW (2.56 ) 09/12/2013 task: ffff88009ae0c4b0 ti: ffff88020e7f0000 task.ti: ffff88020e7f0000 RIP: 0010:[<ffffffffc07e25d8>] [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm] RSP: 0018:ffff88020e7f3bc8 EFLAGS: 00010292 RAX: dead000000200200 RBX: ffff8801ec19c900 RCX: 000000018200016d RDX: ffff8801ec19cf80 RSI: ffffea0008bf1d40 RDI: ffff8801ec19c900 RBP: ffff88020e7f3bd8 R08: 000000002fc75a01 R09: 000000018200016d R10: ffffffffc07df6ae R11: ffff88022fc75a98 R12: ffff88021e7cc000 R13: ffff88021e7cca48 R14: ffff88021e7cca50 R15: ffff8801ec19c880 FS: 00007fc1ee3e6700(0000) GS:ffff88023e240000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f8f389d8000 CR3: 000000023dc13000 CR4: 00000000001427e0 Stack: ffff88021e7cc000 0000000000000000 ffff88020e7f3be8 ffffffffc07e2622 ffff88020e7f3c38 ffffffffc07df69a ffff880232524160 ffff88020e792d80 0000000000000000 ffff880219b78c00 0000000000000008 ffff8802321686a8 Call Trace: [<ffffffffc07e2622>] ioeventfd_destructor+0x12/0x20 [kvm] [<ffffffffc07df69a>] kvm_put_kvm+0xca/0x210 [kvm] [<ffffffffc07df818>] kvm_vcpu_release+0x18/0x20 [kvm] [<ffffffff811f69f7>] __fput+0xe7/0x250 [<ffffffff811f6bae>] ____fput+0xe/0x10 [<ffffffff81093f04>] task_work_run+0xd4/0xf0 [<ffffffff81079358>] do_exit+0x368/0xa50 [<ffffffff81082c8f>] ? recalc_sigpending+0x1f/0x60 [<ffffffff81079ad5>] do_group_exit+0x45/0xb0 [<ffffffff81085c71>] get_signal+0x291/0x750 [<ffffffff810144d8>] do_signal+0x28/0xab0 [<ffffffff810f3a3b>] ? do_futex+0xdb/0x5d0 [<ffffffff810b7028>] ? __wake_up_locked_key+0x18/0x20 [<ffffffff810f3fa6>] ? SyS_futex+0x76/0x170 [<ffffffff81014fc9>] do_notify_resume+0x69/0xb0 [<ffffffff817cb9af>] int_signal+0x12/0x17 Code: 5d c3 90 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb 48 83 ec 08 48 8b 7f 20 e8 06 d6 a5 c0 48 8b 43 08 48 8b 13 48 89 df 48 89 42 08 <48> 89 10 48 b8 00 01 10 00 00 RIP [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm] RSP <ffff88020e7f3bc8> Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27kvm: factor out core eventfd assign/deassign logicJason Wang
[ Upstream commit 85da11ca587c8eb73993a1b503052391a73586f9 ] This patch factors out core eventfd assign/deassign logic and leaves the argument checking and bus index selection to callers. Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27kvm: fix zero length mmio searchingJason Wang
[ Upstream commit 8f4216c7d28976f7ec1b2bcbfa0a9f787133c45e ] Currently, if we had a zero length mmio eventfd assigned on KVM_MMIO_BUS. It will never be found by kvm_io_bus_cmp() since it always compares the kvm_io_range() with the length that guest wrote. This will cause e.g for vhost, kick will be trapped by qemu userspace instead of vhost. Fixing this by using zero length if an iodevice is zero length. Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-27kvm: don't try to register to KVM_FAST_MMIO_BUS for non mmio eventfdJason Wang
[ Upstream commit 8453fecbecae26edb3f278627376caab05d9a88d ] We only want zero length mmio eventfd to be registered on KVM_FAST_MMIO_BUS. So check this explicitly when arg->len is zero to make sure this. Cc: stable@vger.kernel.org Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-07-03KVM: arm/arm64: vgic: Avoid injecting reserved IRQ numbersMarc Zyngier
[ Upstream commit 4839ddc27b7212ec58874f62c97da7400c8523be ] Commit fd1d0ddf2ae9 (KVM: arm/arm64: check IRQ number on userland injection) rightly limited the range of interrupts userspace can inject in a guest, but failed to consider the (unlikely) case where a guest is configured with 1024 interrupts. In this case, interrupts ranging from 1020 to 1023 are unuseable, as they have a special meaning for the GIC CPU interface. Make sure that these number cannot be used as an IRQ. Also delete a redundant (and similarily buggy) check in kvm_set_irq. Reported-by: Peter Maydell <peter.maydell@linaro.org> Cc: Andre Przywara <andre.przywara@arm.com> Cc: <stable@vger.kernel.org> # 4.1, 4.0, 3.19, 3.18 Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17KVM: arm/arm64: check IRQ number on userland injectionAndre Przywara
[ Upstream commit fd1d0ddf2ae92fb3df42ed476939861806c5d785 ] When userland injects a SPI via the KVM_IRQ_LINE ioctl we currently only check it against a fixed limit, which historically is set to 127. With the new dynamic IRQ allocation the effective limit may actually be smaller (64). So when now a malicious or buggy userland injects a SPI in that range, we spill over on our VGIC bitmaps and bytemaps memory. I could trigger a host kernel NULL pointer dereference with current mainline by injecting some bogus IRQ number from a hacked kvmtool: ----------------- .... DEBUG: kvm_vgic_inject_irq(kvm, cpu=0, irq=114, level=1) DEBUG: vgic_update_irq_pending(kvm, cpu=0, irq=114, level=1) DEBUG: IRQ #114 still in the game, writing to bytemap now... Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = ffffffc07652e000 [00000000] *pgd=00000000f658b003, *pud=00000000f658b003, *pmd=0000000000000000 Internal error: Oops: 96000006 [#1] PREEMPT SMP Modules linked in: CPU: 1 PID: 1053 Comm: lkvm-msi-irqinj Not tainted 4.0.0-rc7+ #3027 Hardware name: FVP Base (DT) task: ffffffc0774e9680 ti: ffffffc0765a8000 task.ti: ffffffc0765a8000 PC is at kvm_vgic_inject_irq+0x234/0x310 LR is at kvm_vgic_inject_irq+0x30c/0x310 pc : [<ffffffc0000ae0a8>] lr : [<ffffffc0000ae180>] pstate: 80000145 ..... So this patch fixes this by checking the SPI number against the actual limit. Also we remove the former legacy hard limit of 127 in the ioctl code. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> CC: <stable@vger.kernel.org> # 4.0, 3.19, 3.18 [maz: wrap KVM_ARM_IRQ_GIC_MAX with #ifndef __KERNEL__, as suggested by Christopher Covington] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-17KVM: use slowpath for cross page cached accessesRadim Krčmář
[ Upstream commit ca3f0874723fad81d0c701b63ae3a17a408d5f25 ] kvm_write_guest_cached() does not mark all written pages as dirty and code comments in kvm_gfn_to_hva_cache_init() talk about NULL memslot with cross page accesses. Fix all the easy way. The check is '<= 1' to have the same result for 'len = 0' cache anywhere in the page. (nr_pages_needed is 0 on page boundary.) Fixes: 8f964525a121 ("KVM: Allow cross page reads and writes from cached translations.") Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Message-Id: <20150408121648.GA3519@potion.brq.redhat.com> Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: Keep elrsr/aisr in sync with software modelChristoffer Dall
commit ae705930fca6322600690df9dc1c7d0516145a93 upstream. There is an interesting bug in the vgic code, which manifests itself when the KVM run loop has a signal pending or needs a vmid generation rollover after having disabled interrupts but before actually switching to the guest. In this case, we flush the vgic as usual, but we sync back the vgic state and exit to userspace before entering the guest. The consequence is that we will be syncing the list registers back to the software model using the GICH_ELRSR and GICH_EISR from the last execution of the guest, potentially overwriting a list register containing an interrupt. This showed up during migration testing where we would capture a state where the VM has masked the arch timer but there were no interrupts, resulting in a hung test. Cc: Marc Zyngier <marc.zyngier@arm.com> Reported-by: Alex Bennee <alex.bennee@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11KVM: arm/arm64: vgic: vgic_init returns -ENODEV when no online vcpuEric Auger
commit 66b030e48af68fd4c22d343908bc057207a0a31e upstream. To be more explicit on vgic initialization failure, -ENODEV is returned by vgic_init when no online vcpus can be found at init. Signed-off-by: Eric Auger <eric.auger@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: Require in-kernel vgic for the arch timersChristoffer Dall
commit 05971120fca43e0357789a14b3386bb56eef2201 upstream. It is curently possible to run a VM with architected timers support without creating an in-kernel VGIC, which will result in interrupts from the virtual timer going nowhere. To address this issue, move the architected timers initialization to the time when we run a VCPU for the first time, and then only initialize (and enable) the architected timers if we have a properly created and initialized in-kernel VGIC. When injecting interrupts from the virtual timer to the vgic, the current setup should ensure that this never calls an on-demand init of the VGIC, which is the only call path that could return an error from kvm_vgic_inject_irq(), so capture the return value and raise a warning if there's an error there. We also change the kvm_timer_init() function from returning an int to be a void function, since the function always succeeds. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: Initialize the vgic on-demand when injecting IRQsChristoffer Dall
commit ca7d9c829d419c06e450afa5f785d58198c37caa upstream. Userspace assumes that it can wire up IRQ injections after having created all VCPUs and after having created the VGIC, but potentially before starting the first VCPU. This can currently lead to lost IRQs because the state of that IRQ injection is not stored anywhere and we don't return an error to userspace. We haven't seen this problem manifest itself yet, presumably because guests reset the devices on boot, but this could cause issues with migration and other non-standard startup configurations. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: vgic: kick the specific vcpu instead of iterating through allShannon Zhao
commit 016ed39c54b8a3db680e5c6a43419f806133caf2 upstream. When call kvm_vgic_inject_irq to inject interrupt, we can known which vcpu the interrupt for by the irq_num and the cpuid. So we should just kick this vcpu to avoid iterating through all. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <zhaoshenglong@huawei.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-11arm/arm64: KVM: vgic: move reset initialization into vgic_init_maps()Peter Maydell
commit 6d3cfbe21bef5b66530b50ad16c88fdc71a04c35 upstream. VGIC initialization currently happens in three phases: (1) kvm_vgic_create() (triggered by userspace GIC creation) (2) vgic_init_maps() (triggered by userspace GIC register read/write requests, or from kvm_vgic_init() if not already run) (3) kvm_vgic_init() (triggered by first VM run) We were doing initialization of some state to correspond with the state of a freshly-reset GIC in kvm_vgic_init(); this is too late, since it will overwrite changes made by userspace using the register access APIs before the VM is run. Move this initialization earlier, into the vgic_init_maps() phase. This fixes a bug where QEMU could successfully restore a saved VM state snapshot into a VM that had already been run, but could not restore it "from cold" using the -loadvm command line option (the symptoms being that the restored VM would run but interrupts were ignored). Finally rename vgic_init_maps to vgic_init and renamed kvm_vgic_init to kvm_vgic_map_resources. [ This patch is originally written by Peter Maydell, but I have modified it somewhat heavily, renaming various bits and moving code around. If something is broken, I am to be blamed. - Christoffer ] Acked-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Eric Auger <eric.auger@linaro.org> Signed-off-by: Peter Maydell <peter.maydell@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-04-24kvm: avoid page allocation failure in kvm_set_memory_region()Igor Mammedov
[ Upstream commit 744961341d472db6272ed9b42319a90f5a2aa7c4 ] KVM guest can fail to startup with following trace on host: qemu-system-x86: page allocation failure: order:4, mode:0x40d0 Call Trace: dump_stack+0x47/0x67 warn_alloc_failed+0xee/0x150 __alloc_pages_direct_compact+0x14a/0x150 __alloc_pages_nodemask+0x776/0xb80 alloc_kmem_pages+0x3a/0x110 kmalloc_order+0x13/0x50 kmemdup+0x1b/0x40 __kvm_set_memory_region+0x24a/0x9f0 [kvm] kvm_set_ioapic+0x130/0x130 [kvm] kvm_set_memory_region+0x21/0x40 [kvm] kvm_vm_ioctl+0x43f/0x750 [kvm] Failure happens when attempting to allocate pages for 'struct kvm_memslots', however it doesn't have to be present in physically contiguous (kmalloc-ed) address space, change allocation to kvm_kvzalloc() so that it will be vmalloc-ed when its size is more then a page. Signed-off-by: Igor Mammedov <imammedo@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-03-28kvm: move advertising of KVM_CAP_IRQFD to common codePaolo Bonzini
[ Upstream commit dc9be0fac70a2ad86e31a81372bb0bdfb6945353 ] POWER supports irqfds but forgot to advertise them. Some userspace does not check for the capability, but others check it---thus they work on x86 and s390 but not POWER. To avoid that other architectures in the future make the same mistake, let common code handle KVM_CAP_IRQFD the same way as KVM_CAP_IRQFD_RESAMPLE. Reported-and-tested-by: Greg Kurz <gkurz@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Fixes: 297e21053a52f060944e9f0de4c64fad9bcd72fc Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2014-11-26kvm: fix kvm_is_mmio_pfn() and rename to kvm_is_reserved_pfn()Ard Biesheuvel
This reverts commit 85c8555ff0 ("KVM: check for !is_zero_pfn() in kvm_is_mmio_pfn()") and renames the function to kvm_is_reserved_pfn. The problem being addressed by the patch above was that some ARM code based the memory mapping attributes of a pfn on the return value of kvm_is_mmio_pfn(), whose name indeed suggests that such pfns should be mapped as device memory. However, kvm_is_mmio_pfn() doesn't do quite what it says on the tin, and the existing non-ARM users were already using it in a way which suggests that its name should probably have been 'kvm_is_reserved_pfn' from the beginning, e.g., whether or not to call get_page/put_page on it etc. This means that returning false for the zero page is a mistake and the patch above should be reverted. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-26arm/arm64: KVM: vgic: Fix error code in kvm_vgic_create()Christoffer Dall
If we detect another vCPU is running we just exit and return 0 as if we succesfully created the VGIC, but the VGIC wouldn't actual be created. This shouldn't break in-kernel behavior because the kernel will not observe the failed the attempt to create the VGIC, but userspace could be rightfully confused. Cc: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24kvm: vfio: fix unregister kvm_device_ops of vfioWanpeng Li
After commit 80ce163 (KVM: VFIO: register kvm_device_ops dynamically), kvm_device_ops of vfio can be registered dynamically. Commit 3c3c29fd (kvm-vfio: do not use module_init) move the dynamic register invoked by kvm_init in order to fix broke unloading of the kvm module. However, kvm_device_ops of vfio is unregistered after rmmod kvm-intel module which lead to device type collision detection warning after kvm-intel module reinsmod. WARNING: CPU: 1 PID: 10358 at /root/cathy/kvm/arch/x86/kvm/../../../virt/kvm/kvm_main.c:3289 kvm_init+0x234/0x282 [kvm]() Modules linked in: kvm_intel(O+) kvm(O) nfsv3 nfs_acl auth_rpcgss oid_registry nfsv4 dns_resolver nfs fscache lockd sunrpc pci_stub bridge stp llc autofs4 8021q cpufreq_ondemand ipv6 joydev microcode pcspkr igb i2c_algo_bit ehci_pci ehci_hcd e1000e i2c_i801 ixgbe ptp pps_core hwmon mdio tpm_tis tpm ipmi_si ipmi_msghandler acpi_cpufreq isci libsas scsi_transport_sas button dm_mirror dm_region_hash dm_log dm_mod [last unloaded: kvm_intel] CPU: 1 PID: 10358 Comm: insmod Tainted: G W O 3.17.0-rc1 #2 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013 0000000000000cd9 ffff880ff08cfd18 ffffffff814a61d9 0000000000000cd9 0000000000000000 ffff880ff08cfd58 ffffffff810417b7 ffff880ff08cfd48 ffffffffa045bcac ffffffffa049c420 0000000000000040 00000000000000ff Call Trace: [<ffffffff814a61d9>] dump_stack+0x49/0x60 [<ffffffff810417b7>] warn_slowpath_common+0x7c/0x96 [<ffffffffa045bcac>] ? kvm_init+0x234/0x282 [kvm] [<ffffffff810417e6>] warn_slowpath_null+0x15/0x17 [<ffffffffa045bcac>] kvm_init+0x234/0x282 [kvm] [<ffffffffa016e995>] vmx_init+0x1bf/0x42a [kvm_intel] [<ffffffffa016e7d6>] ? vmx_check_processor_compat+0x64/0x64 [kvm_intel] [<ffffffff810002ab>] do_one_initcall+0xe3/0x170 [<ffffffff811168a9>] ? __vunmap+0xad/0xb8 [<ffffffff8109c58f>] do_init_module+0x2b/0x174 [<ffffffff8109d414>] load_module+0x43e/0x569 [<ffffffff8109c6d8>] ? do_init_module+0x174/0x174 [<ffffffff8109c75a>] ? copy_module_from_user+0x39/0x82 [<ffffffff8109b7dd>] ? module_sect_show+0x20/0x20 [<ffffffff8109d65f>] SyS_init_module+0x54/0x81 [<ffffffff814a9a12>] system_call_fastpath+0x16/0x1b ---[ end trace 0626f4a3ddea56f3 ]--- The bug can be reproduced by: rmmod kvm_intel.ko insmod kvm_intel.ko without rmmod/insmod kvm.ko This patch fixes the bug by unregistering kvm_device_ops of vfio when the kvm-intel module is removed. Reported-by: Liu Rongrong <rongrongx.liu@intel.com> Fixes: 3c3c29fd0d7cddc32862c350d0700ce69953e3bd Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-24kvm: fix excessive pages un-pinning in kvm_iommu_map error path.Quentin Casasnovas
The third parameter of kvm_unpin_pages() when called from kvm_iommu_map_pages() is wrong, it should be the number of pages to un-pin and not the page size. This error was facilitated with an inconsistent API: kvm_pin_pages() takes a size, but kvn_unpin_pages() takes a number of pages, so fix the problem by matching the two. This was introduced by commit 350b8bd ("kvm: iommu: fix the third parameter of kvm_iommu_put_pages (CVE-2014-3601)"), which fixes the lack of un-pinning for pages intended to be un-pinned (i.e. memory leak) but unfortunately potentially aggravated the number of pages we un-pin that should have stayed pinned. As far as I understand though, the same practical mitigations apply. This issue was found during review of Red Hat 6.6 patches to prepare Ksplice rebootless updates. Thanks to Vegard for his time on a late Friday evening to help me in understanding this code. Fixes: 350b8bd ("kvm: iommu: fix the third parameter of... (CVE-2014-3601)") Cc: stable@vger.kernel.org Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Jamie Iles <jamie.iles@oracle.com> Reviewed-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-10-18Merge tag 'kvm-arm-for-3.18-take-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm Pull second batch of changes for KVM/{arm,arm64} from Marc Zyngier: "The most obvious thing is the sizeable MMU changes to support 48bit VAs on arm64. Summary: - support for 48bit IPA and VA (EL2) - a number of fixes for devices mapped into guests - yet another VGIC fix for BE - a fix for CPU hotplug - a few compile fixes (disabled VGIC, strict mm checks)" [ I'm pulling directly from Marc at the request of Paolo Bonzini, whose backpack was stolen at Düsseldorf airport and will do new keys and rebuild his web of trust. - Linus ] * tag 'kvm-arm-for-3.18-take-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm: arm/arm64: KVM: Fix BE accesses to GICv2 EISR and ELRSR regs arm: kvm: STRICT_MM_TYPECHECKS fix for user_mem_abort arm/arm64: KVM: Ensure memslots are within KVM_PHYS_SIZE arm64: KVM: Implement 48 VA support for KVM EL2 and Stage-2 arm/arm64: KVM: map MMIO regions at creation time arm64: kvm: define PAGE_S2_DEVICE as read-only by default ARM: kvm: define PAGE_S2_DEVICE as read-only by default arm/arm64: KVM: add 'writable' parameter to kvm_phys_addr_ioremap arm/arm64: KVM: fix potential NULL dereference in user_mem_abort() arm/arm64: KVM: use __GFP_ZERO not memset() to get zeroed pages ARM: KVM: fix vgic-disabled build arm: kvm: fix CPU hotplug
2014-10-16arm/arm64: KVM: Fix BE accesses to GICv2 EISR and ELRSR regsChristoffer Dall
The EIRSR and ELRSR registers are 32-bit registers on GICv2, and we store these as an array of two such registers on the vgic vcpu struct. However, we access them as a single 64-bit value or as a bitmap pointer in the generic vgic code, which breaks BE support. Instead, store them as u64 values on the vgic structure and do the word-swapping in the assembly code, which already handles the byte order for BE systems. Tested-by: Victor Kamensky <victor.kamensky@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-10-15Merge tag 'iommu-updates-v3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "This pull-request includes: - change in the IOMMU-API to convert the former iommu_domain_capable function to just iommu_capable - various fixes in handling RMRR ranges for the VT-d driver (one fix requires a device driver core change which was acked by Greg KH) - the AMD IOMMU driver now assigns and deassigns complete alias groups to fix issues with devices using the wrong PCI request-id - MMU-401 support for the ARM SMMU driver - multi-master IOMMU group support for the ARM SMMU driver - various other small fixes all over the place" * tag 'iommu-updates-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (41 commits) iommu/vt-d: Work around broken RMRR firmware entries iommu/vt-d: Store bus information in RMRR PCI device path iommu/vt-d: Only remove domain when device is removed driver core: Add BUS_NOTIFY_REMOVED_DEVICE event iommu/amd: Fix devid mapping for ivrs_ioapic override iommu/irq_remapping: Fix the regression of hpet irq remapping iommu: Fix bus notifier breakage iommu/amd: Split init_iommu_group() from iommu_init_device() iommu: Rework iommu_group_get_for_pci_dev() iommu: Make of_device_id array const amd_iommu: do not dereference a NULL pointer address. iommu/omap: Remove omap_iommu unused owner field iommu: Remove iommu_domain_has_cap() API function IB/usnic: Convert to use new iommu_capable() API function vfio: Convert to use new iommu_capable() API function kvm: iommu: Convert to use new iommu_capable() API function iommu/tegra: Convert to iommu_capable() API function iommu/msm: Convert to iommu_capable() API function iommu/vt-d: Convert to iommu_capable() API function iommu/fsl: Convert to iommu_capable() API function ...
2014-10-10arm/arm64: KVM: add 'writable' parameter to kvm_phys_addr_ioremapArd Biesheuvel
Add support for read-only MMIO passthrough mappings by adding a 'writable' parameter to kvm_phys_addr_ioremap. For the moment, mappings will be read-write even if 'writable' is false, but once the definition of PAGE_S2_DEVICE gets changed, those mappings will be created read-only. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-10-09Merge tag 'pci-v3.18-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "The interesting things here are: - Turn on Config Request Retry Status Software Visibility. This caused hangs last time, but we included a fix this time. - Rework PCI device configuration to use _HPP/_HPX more aggressively - Allow PCI devices to be put into D3cold during system suspend - Add arm64 PCI support - Add APM X-Gene host bridge driver - Add TI Keystone host bridge driver - Add Xilinx AXI host bridge driver More detailed summary: Enumeration - Check Vendor ID only for Config Request Retry Status (Rajat Jain) - Enable Config Request Retry Status when supported (Rajat Jain) - Add generic domain handling (Catalin Marinas) - Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado) Resource management - Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu) - Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr) PCI device hotplug - Prevent NULL dereference during pciehp probe (Andreas Noever) - Move _HPP & _HPX handling into core (Bjorn Helgaas) - Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas) - Apply _HPP/_HPX to display devices (Bjorn Helgaas) - Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas) - Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas) - Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas) - Fix wait time in pciehp timeout message (Yinghai Lu) - Add more pciehp Slot Control debug output (Yinghai Lu) - Stop disabling pciehp notifications during init (Yinghai Lu) MSI - Remove arch_msi_check_device() (Alexander Gordeev) - Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev) - Move D0 check into pci_msi_check_device() (Alexander Gordeev) - Remove unused kobject from struct msi_desc (Yijing Wang) - Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang) - Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang) - Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang) - Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang) - Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang) Power management - Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki) - Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki) AER - Add additional AER error strings (Gong Chen) - Make <linux/aer.h> standalone includable (Thierry Reding) Virtualization - Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson) - Add ACS quirk for Intel 10G NICs (Alex Williamson) - Add ACS quirk for AMD A88X southbridge (Marti Raudsepp) - Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson) - Add device flag helpers (Ethan Zhao) - Assume all Mellanox devices have broken INTx masking (Gavin Shan) Generic host bridge driver - Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau) - Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau) - Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau) - Fix the conversion of IO ranges into IO resources (Liviu Dudau) - Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau) - Add support for parsing PCI host bridge resources from DT (Liviu Dudau) - Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau) - Add arm64 architectural support for PCI (Liviu Dudau) APM X-Gene - Add APM X-Gene PCIe driver (Tanmay Inamdar) - Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar) Freescale i.MX6 - Probe in module_init(), not fs_initcall() (Lucas Stach) - Delay enabling reference clock for SS until it stabilizes (Tim Harvey) Marvell MVEBU - Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni) NVIDIA Tegra - Make sure the PCIe PLL is really reset (Eric Yuen) - Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang) - Fix extended configuration space mapping (Peter Daifuku) - Implement resource hierarchy (Thierry Reding) - Clear CLKREQ# enable on port disable (Thierry Reding) - Add Tegra124 support (Thierry Reding) ST Microelectronics SPEAr13xx - Pass config resource through reg property (Pratyush Anand) Synopsys DesignWare - Use NULL instead of false (Fabio Estevam) - Parse bus-range property from devicetree (Lucas Stach) - Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach) - Remove pci_assign_unassigned_resources() (Lucas Stach) - Check private_data validity in single place (Lucas Stach) - Setup and clear exactly one MSI at a time (Lucas Stach) - Remove open-coded bitmap operations (Lucas Stach) - Fix configuration base address when using 'reg' (Minghuan Lian) - Fix IO resource end address calculation (Minghuan Lian) - Rename get_msi_data() to get_msi_addr() (Minghuan Lian) - Add get_msi_data() to pcie_host_ops (Minghuan Lian) - Add support for v3.65 hardware (Murali Karicheri) - Fold struct pcie_port_info into struct pcie_port (Pratyush Anand) TI Keystone - Add TI Keystone PCIe driver (Murali Karicheri) - Limit MRSS for all downstream devices (Murali Karicheri) - Assume controller is already in RC mode (Murali Karicheri) - Set device ID based on SoC to support multiple ports (Murali Karicheri) Xilinx AXI - Add Xilinx AXI PCIe driver (Srikanth Thokala) - Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter) Miscellaneous - Clean up whitespace (Quentin Lambert) - Remove assignments from "if" conditions (Quentin Lambert) - Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri) - x86: Mark DMI tables as initialization data (Mathias Krause) - x86: Move __init annotation to the correct place (Mathias Krause) - x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause) - x86: Constify pci_mmcfg_probes[] array (Mathias Krause) - x86: Mark PCI BIOS initialization code as such (Mathias Krause) - Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya) - Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)" * tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits) arm64: dts: Add APM X-Gene PCIe device tree nodes PCI: Add ACS quirk for AMD A88X southbridge devices PCI: xgene: Add APM X-Gene PCIe driver PCI: designware: Remove open-coded bitmap operations PCI/MSI: Remove unnecessary temporary variable PCI/MSI: Use __write_msi_msg() instead of write_msi_msg() MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg() PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg() PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib PCI/MSI: Remove unused kobject from struct msi_desc PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported() PCI/MSI: Move D0 check into pci_msi_check_device() PCI/MSI: Remove arch_msi_check_device() irqchip: armada-370-xp: Remove arch_msi_check_device() PCI/MSI/PPC: Remove arch_msi_check_device() arm64: Add architectural support for PCI PCI: Add pci_remap_iospace() to map bus I/O resources of/pci: Add support for parsing PCI host bridge resources from DT of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr() ... Conflicts: arch/arm64/boot/dts/apm-storm.dtsi
2014-10-08Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "Fixes and features for 3.18. Apart from the usual cleanups, here is the summary of new features: - s390 moves closer towards host large page support - PowerPC has improved support for debugging (both inside the guest and via gdbstub) and support for e6500 processors - ARM/ARM64 support read-only memory (which is necessary to put firmware in emulated NOR flash) - x86 has the usual emulator fixes and nested virtualization improvements (including improved Windows support on Intel and Jailhouse hypervisor support on AMD), adaptive PLE which helps overcommitting of huge guests. Also included are some patches that make KVM more friendly to memory hot-unplug, and fixes for rare caching bugs. Two patches have trivial mm/ parts that were acked by Rik and Andrew. Note: I will soon switch to a subkey for signing purposes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits) kvm: do not handle APIC access page if in-kernel irqchip is not in use KVM: s390: count vcpu wakeups in stat.halt_wakeup KVM: s390/facilities: allow TOD-CLOCK steering facility bit KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode arm/arm64: KVM: Report correct FSC for unsupported fault types arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc kvm: Fix kvm_get_page_retry_io __gup retval check arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset kvm: x86: Unpin and remove kvm_arch->apic_access_page kvm: vmx: Implement set_apic_access_page_addr kvm: x86: Add request bit to reload APIC access page address kvm: Add arch specific mmu notifier for page invalidation kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static kvm: Fix page ageing bugs kvm/x86/mmu: Pass gfn and level to rmapp callback. x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only kvm: x86: use macros to compute bank MSRs KVM: x86: Remove debug assertion of non-PAE reserved bits kvm: don't take vcpu mutex for obviously invalid vcpu ioctls kvm: Faults which trigger IO release the mmap_sem ...
2014-10-02Merge branches 'arm/exynos', 'arm/omap', 'arm/smmu', 'x86/vt-d', 'x86/amd' ↵Joerg Roedel
and 'core' into next Conflicts: drivers/iommu/arm-smmu.c
2014-09-27Merge tag 'kvm-arm-for-3.18' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-next Changes for KVM for arm/arm64 for 3.18 This includes a bunch of changes: - Support read-only memory slots on arm/arm64 - Various changes to fix Sparse warnings - Correctly detect write vs. read Stage-2 faults - Various VGIC cleanups and fixes - Dynamic VGIC data strcuture sizing - Fix SGI set_clear_pend offset bug - Fix VTTBR_BADDR Mask - Correctly report the FSC on Stage-2 faults Conflicts: virt/kvm/eventfd.c [duplicate, different patch where the kvm-arm version broke x86. The kvm tree instead has the right one]
2014-09-26kvm: Fix kvm_get_page_retry_io __gup retval checkAndres Lagar-Cavilla
Confusion around -EBUSY and zero (inside a BUG_ON no less). Reported-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-25arm/arm64: KVM: Fix set_clear_sgi_pend_reg offsetChristoffer Dall
The sgi values calculated in read_set_clear_sgi_pend_reg() and write_set_clear_sgi_pend_reg() were horribly incorrectly multiplied by 4 with catastrophic results in that subfunctions ended up overwriting memory not allocated for the expected purpose. This showed up as bugs in kfree() and the kernel complaining a lot of you turn on memory debugging. This addresses: http://marc.info/?l=kvm&m=141164910007868&w=2 Reported-by: Shannon Zhao <zhaoshenglong@huawei.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-09-25kvm: iommu: Convert to use new iommu_capable() API functionJoerg Roedel
Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2014-09-24kvm: Add arch specific mmu notifier for page invalidationTang Chen
This will be used to let the guest run while the APIC access page is not pinned. Because subsequent patches will fill in the function for x86, place the (still empty) x86 implementation in the x86.c file instead of adding an inline function in kvm_host.h. Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make ↵Tang Chen
it non-static Different architectures need different requests, and in fact we will use this function in architecture-specific code later. This will be outside kvm_main.c, so make it non-static and rename it to kvm_make_all_cpus_request(). Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24kvm: Fix page ageing bugsAndres Lagar-Cavilla
1. We were calling clear_flush_young_notify in unmap_one, but we are within an mmu notifier invalidate range scope. The spte exists no more (due to range_start) and the accessed bit info has already been propagated (due to kvm_pfn_set_accessed). Simply call clear_flush_young. 2. We clear_flush_young on a primary MMU PMD, but this may be mapped as a collection of PTEs by the secondary MMU (e.g. during log-dirty). This required expanding the interface of the clear_flush_young mmu notifier, so a lot of code has been trivially touched. 3. In the absence of shadow_accessed_mask (e.g. EPT A bit), we emulate the access bit by blowing the spte. This requires proper synchronizing with MMU notifier consumers, like every other removal of spte's does. Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24kvm: don't take vcpu mutex for obviously invalid vcpu ioctlsDavid Matlack
vcpu ioctls can hang the calling thread if issued while a vcpu is running. However, invalid ioctls can happen when userspace tries to probe the kind of file descriptors (e.g. isatty() calls ioctl(TCGETS)); in that case, we know the ioctl is going to be rejected as invalid anyway and we can fail before trying to take the vcpu mutex. This patch does not change functionality, it just makes invalid ioctls fail faster. Cc: stable@vger.kernel.org Signed-off-by: David Matlack <dmatlack@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24kvm: Faults which trigger IO release the mmap_semAndres Lagar-Cavilla
When KVM handles a tdp fault it uses FOLL_NOWAIT. If the guest memory has been swapped out or is behind a filemap, this will trigger async readahead and return immediately. The rationale is that KVM will kick back the guest with an "async page fault" and allow for some other guest process to take over. If async PFs are enabled the fault is retried asap from an async workqueue. If not, it's retried immediately in the same code path. In either case the retry will not relinquish the mmap semaphore and will block on the IO. This is a bad thing, as other mmap semaphore users now stall as a function of swap or filemap latency. This patch ensures both the regular and async PF path re-enter the fault allowing for the mmap semaphore to be relinquished in the case of IO wait. Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24kvm-vfio: do not use module_initPaolo Bonzini
/me got confused between the kernel and QEMU. In the kernel, you can only have one module_init function, and it will prevent unloading the module unless you also have the corresponding module_exit function. So, commit 80ce1639727e (KVM: VFIO: register kvm_device_ops dynamically, 2014-09-02) broke unloading of the kvm module, by adding a module_init function and no module_exit. Repair it by making kvm_vfio_ops_init weak, and checking it in kvm_init. Cc: Will Deacon <will.deacon@arm.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: Alex Williamson <Alex.Williamson@redhat.com> Fixes: 80ce1639727e9d38729c34f162378508c307ca25 Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-24KVM: EVENTFD: Remove inclusion of irq.hChristoffer Dall
Commit c77dcac (KVM: Move more code under CONFIG_HAVE_KVM_IRQFD) added functionality that depends on definitions in ioapic.h when __KVM_HAVE_IOAPIC is defined. At the same time, kvm-arm commit 0ba0951 (KVM: EVENTFD: remove inclusion of irq.h) removed the inclusion of irq.h, an architecture-specific header that is not present on ARM but which happened to include ioapic.h on x86. Include ioapic.h directly in eventfd.c if __KVM_HAVE_IOAPIC is defined. This fixes x86 and lets ARM use eventfd.c. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-23Merge tag 'kvm-arm-for-v3.17-rc7-or-final' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master Fixes unaligned access to the gicv2 virtual cpu status.
2014-09-22arm/arm64: KVM: Fix unaligned access bug on gicv2 accessChristoffer Dall
We were using an atomic bitop on the vgic_v2.vgic_elrsr field which was not aligned to the natural size on 64-bit platforms. This bug showed up after QEMU correctly identifies the pl011 line as being level-triggered, and not edge-triggered. These data structures are protected by a spinlock so simply use a non-atomic version of the accessor instead. Tested-by: Joel Schopp <joel.schopp@amd.com> Reported-by: Riku Voipio <riku.voipio@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-09-22KVM: correct null pid check in kvm_vcpu_yield_to()Sam Bobroff
Correct a simple mistake of checking the wrong variable before a dereference, resulting in the dereference not being properly protected by rcu_dereference(). Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-09-18arm/arm64: KVM: vgic: make number of irqs a configurable attributeMarc Zyngier
In order to make the number of interrupts configurable, use the new fancy device management API to add KVM_DEV_ARM_VGIC_GRP_NR_IRQS as a VGIC configurable attribute. Userspace can now specify the exact size of the GIC (by increments of 32 interrupts). Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18arm/arm64: KVM: vgic: delay vgic allocation until init timeMarc Zyngier
It is now quite easy to delay the allocation of the vgic tables until we actually require it to be up and running (when the first vcpu is kicking around, or someones tries to access the GIC registers). This allow us to allocate memory for the exact number of CPUs we have. As nobody configures the number of interrupts just yet, use a fallback to VGIC_NR_IRQS_LEGACY. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18arm/arm64: KVM: vgic: kill VGIC_NR_IRQSMarc Zyngier
Nuke VGIC_NR_IRQS entierly, now that the distributor instance contains the number of IRQ allocated to this GIC. Also add VGIC_NR_IRQS_LEGACY to preserve the current API. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18arm/arm64: KVM: vgic: handle out-of-range MMIO accessesMarc Zyngier
Now that we can (almost) dynamically size the number of interrupts, we're facing an interesting issue: We have to evaluate at runtime whether or not an access hits a valid register, based on the sizing of this particular instance of the distributor. Furthermore, the GIC spec says that accessing a reserved register is RAZ/WI. For this, add a new field to our range structure, indicating the number of bits a single interrupts uses. That allows us to find out whether or not the access is in range. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18arm/arm64: KVM: vgic: kill VGIC_MAX_CPUSMarc Zyngier
We now have the information about the number of CPU interfaces in the distributor itself. Let's get rid of VGIC_MAX_CPUS, and just rely on KVM_MAX_VCPUS where we don't have the choice. Yet. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18arm/arm64: KVM: vgic: Parametrize VGIC_NR_SHARED_IRQSMarc Zyngier
Having a dynamic number of supported interrupts means that we cannot relly on VGIC_NR_SHARED_IRQS being fixed anymore. Instead, make it take the distributor structure as a parameter, so it can return the right value. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18arm/arm64: KVM: vgic: switch to dynamic allocationMarc Zyngier
So far, all the VGIC data structures are statically defined by the *maximum* number of vcpus and interrupts it supports. It means that we always have to oversize it to cater for the worse case. Start by changing the data structures to be dynamically sizeable, and allocate them at runtime. The sizes are still very static though. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-09-18KVM: ARM: vgic: plug irq injection raceMarc Zyngier
As it stands, nothing prevents userspace from injecting an interrupt before the guest's GIC is actually initialized. This goes unnoticed so far (as everything is pretty much statically allocated), but ends up exploding in a spectacular way once we switch to a more dynamic allocation (the GIC data structure isn't there yet). The fix is to test for the "ready" flag in the VGIC distributor before trying to inject the interrupt. Note that in order to avoid breaking userspace, we have to ignore what is essentially an error. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-09-18arm/arm64: KVM: vgic: Clarify and correct vgic documentationChristoffer Dall
The VGIC virtual distributor implementation documentation was written a very long time ago, before the true nature of the beast had been partially absorbed into my bloodstream. Clarify the docs. Plus, it fixes an actual bug. ICFRn, pfff. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2014-09-18arm/arm64: KVM: vgic: Fix SGI writes to GICD_I{CS}PENDR0Christoffer Dall
Writes to GICD_ISPENDR0 and GICD_ICPENDR0 ignore all settings of the pending state for SGIs. Make sure the implementation handles this correctly. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
