path: root/virt
2011-03-23kvm: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23kvm: stop including asm-generic/bitops/le.h directlyAkinobu Mita
asm-generic/bitops/le.h is only intended to be included directly from asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h which implements generic ext2 or minix bit operations. This stops including asm-generic/bitops/le.h directly and use ext2 non-atomic bit operations instead. It seems odd to use ext2_set_bit() on kvm, but it will replaced with __set_bit_le() after introducing little endian bit operations for all architectures. This indirect step is necessary to maintain bisectability for some architectures which have their own little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17KVM: improve comment on rcu use in irqfd_deassignMichael S. Tsirkin
The RCU use in kvm_irqfd_deassign is tricky: we have rcu_assign_pointer but no synchronize_rcu: synchronize_rcu is done by kvm_irq_routing_update which we share a spinlock with. Fix up a comment in an attempt to make this clearer. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: Convert kvm_lock to raw_spinlockJan Kiszka
Code under this lock requires non-preemptibility. Ensure this also over -rt by converting it to raw spinlock. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: use yield_to instead of sleep in kvm_vcpu_on_spinRik van Riel
Instead of sleeping in kvm_vcpu_on_spin, which can cause gigantic slowdowns of certain workloads, we instead use yield_to to get another VCPU in the same KVM guest to run sooner. This seems to give a 10-15% speedup in certain workloads. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: keep track of which task is running a KVM vcpuRik van Riel
Keep track of which task is running a KVM vcpu. This helps us figure out later what task to wake up if we want to boost a vcpu that got preempted. Unfortunately there are no guarantees that the same task always keeps the same vcpu, so we can only track the task across a single "run" of the vcpu. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: Replace is_hwpoison_address with __get_user_pagesHuang Ying
is_hwpoison_address only checks whether the page table entry is hwpoisoned, regardless the memory page mapped. While __get_user_pages will check both. QEMU will clear the poisoned page table entry (via unmap/map) to make it possible to allocate a new memory page for the virtual address across guest rebooting. But it is also possible that the underlying memory page is kept poisoned even after the corresponding page table entry is cleared, that is, a new memory page can not be allocated. __get_user_pages can catch these situations. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17KVM: make make_all_cpus_request() locklessXiao Guangrong
Now, we have 'vcpu->mode' to judge whether need to send ipi to other cpus, this way is very exact, so checking request bit is needless, then we can drop the spinlock let it's collateral Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: Add "exiting guest mode" stateXiao Guangrong
Currently we keep track of only two states: guest mode and host mode. This patch adds an "exiting guest mode" state that tells us that an IPI will happen soon, so unless we need to wait for the IPI, we can avoid it completely. Also 1: No need atomically to read/write ->mode in vcpu's thread 2: reorganize struct kvm_vcpu to make ->mode and ->requests in the same cache line explicitly Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: fix build warning within __kvm_set_memory_region() on s390Heiko Carstens
Get rid of this warning: CC arch/s390/kvm/../../../virt/kvm/kvm_main.o arch/s390/kvm/../../../virt/kvm/kvm_main.c:596:12: warning: 'kvm_create_dirty_bitmap' defined but not used The only caller of the function is within a !CONFIG_S390 section, so add the same ifdef around kvm_create_dirty_bitmap() as well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17KVM: MMU: Don't flush shadow when enabling dirty trackingAvi Kivity
Instead, drop large mappings, which were the reason we dropped shadow. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-13thp: add compound_trans_head() helperAndrea Arcangeli
Cleanup some code with common compound_trans_head helper. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: mmu_notifier_test_youngAndrea Arcangeli
For GRU and EPT, we need gup-fast to set referenced bit too (this is why it's correct to return 0 when shadow_access_mask is zero, it requires gup-fast to set the referenced bit). qemu-kvm access already sets the young bit in the pte if it isn't zero-copy, if it's zero copy or a shadow paging EPT minor fault we relay on gup-fast to signal the page is in use... We also need to check the young bits on the secondary pagetables for NPT and not nested shadow mmu as the data may never get accessed again by the primary pte. Without this closer accuracy, we'd have to remove the heuristic that avoids collapsing hugepages in hugepage virtual regions that have not even a single subpage in use. ->test_young is full backwards compatible with GRU and other usages that don't have young bits in pagetables set by the hardware and that should nuke the secondary mmu mappings when ->clear_flush_young runs just like EPT does. Removing the heuristic that checks the young bit in khugepaged/collapse_huge_page completely isn't so bad either probably but I thought it was worth it and this makes it reliable. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: kvm mmu transparent hugepage supportAndrea Arcangeli
This should work for both hugetlbfs and transparent hugepages. [akpm@linux-foundation.org: bring forward PageTransCompound() addition for bisectability] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12KVM: Don't spin on virt instruction faults during rebootAvi Kivity
Since vmx blocks INIT signals, we disable virtualization extensions during reboot. This leads to virtualization instructions faulting; we trap these faults and spin while the reboot continues. Unfortunately spinning on a non-preemptible kernel may block a task that reboot depends on; this causes the reboot to hang. Fix by skipping over the instruction and hoping for the best. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: MMU: delay flush all tlbs on sync_page pathXiao Guangrong
Quote from Avi: | I don't think we need to flush immediately; set a "tlb dirty" bit somewhere | that is cleareded when we flush the tlb. kvm_mmu_notifier_invalidate_page() | can consult the bit and force a flush if set. Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: fast-path msi injection with irqfdMichael S. Tsirkin
Store irq routing table pointer in the irqfd object, and use that to inject MSI directly without bouncing out to a kernel thread. While we touch this structure, rearrange irqfd fields to make fastpath better packed for better cache utilization. This also adds some comments about locking rules and rcu usage in code. Some notes on the design: - Use pointer into the rt instead of copying an entry, to make it possible to use rcu, thus side-stepping locking complexities. We also save some memory this way. - Old workqueue code is still used for level irqs. I don't think we DTRT with level anyway, however, it seems easier to keep the code around as it has been thought through and debugged, and fix level later than rip out and re-instate it later. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: rename hardware_[dis|en]able() to *_nolock() and add locking wrappersTakuya Yoshikawa
The naming convension of hardware_[dis|en]able family is little bit confusing because only hardware_[dis|en]able_all are using _nolock suffix. Renaming current hardware_[dis|en]able() to *_nolock() and using hardware_[dis|en]able() as wrapper functions which take kvm_lock for them reduces extra confusion. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: take kvm_lock for hardware_disable() during cpu hotplugTakuya Yoshikawa
In kvm_cpu_hotplug(), only CPU_STARTING case is protected by kvm_lock. This patch adds missing protection for CPU_DYING case. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clean up kvm_vm_ioctl_assigned_deviceJan Kiszka
Any arch not supporting device assigment will also not build assigned-dev.c. So testing for KVM_CAP_DEVICE_DEASSIGNMENT is pointless. KVM_CAP_ASSIGN_DEV_IRQ is unconditinally set. Moreover, add a default case for dispatching the ioctl. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Save/restore state of assigned PCI deviceJan Kiszka
The guest may change states that pci_reset_function does not touch. So we better save/restore the assigned device across guest usage. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Refactor IRQ names of assigned devicesJan Kiszka
Cosmetic change, but it helps to correlate IRQs with PCI devices. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Switch assigned device IRQ forwarding to threaded handlerJan Kiszka
This improves the IRQ forwarding for assigned devices: By using the kernel's threaded IRQ scheme, we can get rid of the latency-prone work queue and simplify the code in the same run. Moreover, we no longer have to hold assigned_dev_lock while raising the guest IRQ, which can be a lenghty operation as we may have to iterate over all VCPUs. The lock is now only used for synchronizing masking vs. unmasking of INTx-type IRQs, thus is renames to intx_lock. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clear assigned guest IRQ on releaseJan Kiszka
When we deassign a guest IRQ, clear the potentially asserted guest line. There might be no chance for the guest to do this, specifically if we switch from INTx to MSI mode. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clean up vm creation and releaseJan Kiszka
IA64 support forces us to abstract the allocation of the kvm structure. But instead of mixing this up with arch-specific initialization and doing the same on destruction, split both steps. This allows to move generic destruction calls into generic code. It also fixes error clean-up on failures of kvm_create_vm for IA64. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: Refactor srcu struct release on early errorsJan Kiszka
2011-01-12KVM: fix the race while wakeup all pv guestXiao Guangrong
In kvm_async_pf_wakeup_all(), we add a dummy apf to vcpu->async_pf.done without holding vcpu->async_pf.lock, it will break if we are handling apfs at this time. Also use 'list_empty_careful()' instead of 'list_empty()' Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: handle more completed apfs if possibleXiao Guangrong
If it's no need to inject async #PF to PV guest we can handle more completed apfs at one time, so we can retry guest #PF as early as possible Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: replace vmalloc and memset with vzallocTakuya Yoshikawa
Let's use newly introduced vzalloc(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: get rid of warning within kvm_dev_ioctl_create_vmHeiko Carstens
Fixes this: CC arch/s390/kvm/../../../virt/kvm/kvm_main.o arch/s390/kvm/../../../virt/kvm/kvm_main.c: In function 'kvm_dev_ioctl_create_vm': arch/s390/kvm/../../../virt/kvm/kvm_main.c:1828:10: warning: unused variable 'r' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: add cast within kvm_clear_guest_page to fix warningHeiko Carstens
Fixes this: CC arch/s390/kvm/../../../virt/kvm/kvm_main.o arch/s390/kvm/../../../virt/kvm/kvm_main.c: In function 'kvm_clear_guest_page': arch/s390/kvm/../../../virt/kvm/kvm_main.c:1224:2: warning: passing argument 3 of 'kvm_write_guest_page' makes pointer from integer without a cast arch/s390/kvm/../../../virt/kvm/kvm_main.c:1185:5: note: expected 'const void *' but argument is of type 'long unsigned int' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: use kmalloc() for small dirty bitmapsTakuya Yoshikawa
Currently we are using vmalloc() for all dirty bitmaps even if they are small enough, say less than K bytes. We use kmalloc() if dirty bitmap size is less than or equal to PAGE_SIZE so that we can avoid vmalloc area usage for VGA. This will also make the logging start/stop faster. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: pre-allocate one more dirty bitmap to avoid vmalloc()Takuya Yoshikawa
Currently x86's kvm_vm_ioctl_get_dirty_log() needs to allocate a bitmap by vmalloc() which will be used in the next logging and this has been causing bad effect to VGA and live-migration: vmalloc() consumes extra systime, triggers tlb flush, etc. This patch resolves this issue by pre-allocating one more bitmap and switching between two bitmaps during dirty logging. Performance improvement: I measured performance for the case of VGA update by trace-cmd. The result was 1.5 times faster than the original one. In the case of live migration, the improvement ratio depends on the workload and the guest memory size. In general, the larger the memory size is the more benefits we get. Note: This does not change other architectures's logic but the allocation size becomes twice. This will increase the actual memory consumption only when the new size changes the number of pages allocated by vmalloc(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: introduce wrapper functions for creating/destroying dirty bitmapsTakuya Yoshikawa
This makes it easy to change the way of allocating/freeing dirty bitmaps. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: x86: trace "exit to userspace" eventGleb Natapov
Add tracepoint for userspace exit. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: propagate fault r/w information to gup(), allow read-only memoryMarcelo Tosatti
As suggested by Andrea, pass r/w error code to gup(), upgrading read fault to writable if host pte allows it. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: improve hva_to_pfn() readabilityGleb Natapov
Improve vma handling code readability in hva_to_pfn() and fix async pf handling code to properly check vma returned by find_vma(). Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Inject asynchronous page fault into a PV guest if page is swapped out.Gleb Natapov
Send async page fault to a PV guest if it accesses swapped out memory. Guest will choose another task to run upon receiving the fault. Allow async page fault injection only when guest is in user mode since otherwise guest may be in non-sleepable context and will not be able to reschedule. Vcpu will be halted if guest will fault on the same page again or if vcpu executes kernel code. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Add PV MSR to enable asynchronous page faults delivery.Gleb Natapov
Guest enables async PF vcpu functionality using this MSR. Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Add memory slot versioning and use it to provide fast guest write interfaceGleb Natapov
Keep track of memslots changes by keeping generation number in memslots structure. Provide kvm_write_guest_cached() function that skips gfn_to_hva() translation if memslots was not changed since previous invocation. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Retry fault before vmentryGleb Natapov
When page is swapped in it is mapped into guest memory only after guest tries to access it again and generate another fault. To save this fault we can map it immediately since we know that guest is going to access the page. Do it only when tdp is enabled for now. Shadow paging case is more complicated. CR[034] and EFER registers should be switched before doing mapping and then switched back. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Halt vcpu if page it tries to access is swapped outGleb Natapov
If a guest accesses swapped out memory do not swap it in from vcpu thread context. Schedule work to do swapping and put vcpu into halted state instead. Interrupts will still be delivered to the guest and if interrupt will cause reschedule guest will continue to run another task. [avi: remove call to get_user_pages_noio(), nacked by Linus; this makes everything synchrnous again] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits) KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages KVM: Fix signature of kvm_iommu_map_pages stub KVM: MCE: Send SRAR SIGBUS directly KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED KVM: fix typo in copyright notice KVM: Disable interrupts around get_kernel_ns() KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address KVM: MMU: move access code parsing to FNAME(walk_addr) function KVM: MMU: audit: check whether have unsync sps after root sync KVM: MMU: audit: introduce audit_printk to cleanup audit code KVM: MMU: audit: unregister audit tracepoints before module unloaded KVM: MMU: audit: fix vcpu's spte walking KVM: MMU: set access bit for direct mapping KVM: MMU: cleanup for error mask set while walk guest page table KVM: MMU: update 'root_hpa' out of loop in PAE shadow path KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn() KVM: x86: Fix constant type in kvm_get_time_scale KVM: VMX: Add AX to list of registers clobbered by guest switch KVM guest: Move a printk that's using the clock before it's ready KVM: x86: TSC catchup mode ...
2010-10-24KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pagesJan Kiszka
We also have to call kvm_iommu_map_pages for CONFIG_AMD_IOMMU. So drop the dependency on Intel IOMMU, kvm_iommu_map_pages will be a nop anyway if CONFIG_IOMMU_API is not defined. KVM-Stable-Tag. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: fix typo in copyright noticeNicolas Kaiser
Fix typo in copyright notice. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: cpu_relax() during spin waiting for rebootAvi Kivity
It doesn't really matter, but if we spin, we should spin in a more relaxed manner. This way, if something goes wrong at least it won't contribute to global warming. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: MMU: rewrite audit_mappings_page() functionXiao Guangrong
There is a bugs in this function, we call gfn_to_pfn() and kvm_mmu_gva_to_gpa_read() in atomic context(kvm_mmu_audit() is called under the spinlock(mmu_lock)'s protection). This patch fix it by: - introduce gfn_to_pfn_atomic instead of gfn_to_pfn - get the mapping gfn from kvm_mmu_page_get_gfn() And it adds 'notrap' ptes check in unsync/direct sps Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: MMU: introduce gfn_to_page_many_atomic() functionXiao Guangrong
Introduce this function to get consecutive gfn's pages, it can reduce gup's overload, used by later patch Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: MMU: introduce hva_to_pfn_atomic functionXiao Guangrong
Introduce hva_to_pfn_atomic(), it's the fast path and can used in atomic context, the later patch will use it Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: x86: Add clock sync request to hardware enableZachary Amsden
If there are active VCPUs which are marked as belonging to a particular hardware CPU, request a clock sync for them when enabling hardware; the TSC could be desynchronized on a newly arriving CPU, and we need to recompute guests system time relative to boot after a suspend event. This covers both cases. Note that it is acceptable to take the spinlock, as either no other tasks will be running and no locks held (BSP after resume), or other tasks will be guaranteed to drop the lock relatively quickly (AP on CPU_STARTING). Noting we now get clock synchronization requests for VCPUs which are starting up (or restarting), it is tempting to attempt to remove the arch/x86/kvm/x86.c CPU hot-notifiers at this time, however it is not correct to do so; they are required for systems with non-constant TSC as the frequency may not be known immediately after the processor has started until the cpufreq driver has had a chance to run and query the chipset. Updated: implement better locking semantics for hardware_enable Removed the hack of dropping and retaking the lock by adding the semantic that we always hold kvm_lock when hardware_enable is called. The one place that doesn't need to worry about it is resume, as resuming a frozen CPU, the spinlock won't be taken. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
