path: root/virt
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01KVM: Convert kvm->requests_lock to raw_spinlock_tAvi Kivity
The code relies on kvm->requests_lock inhibiting preemption. Noted by Jan Kiszka. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: do not store wqh in irqfdMichael S. Tsirkin
wqh is unused, so we do not need to store it in irqfd anymore Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: cleanup the failure path of KVM_CREATE_IRQCHIP ioctrlWei Yongjun
If we fail to init ioapic device or the fail to setup the default irq routing, the device register by kvm_create_pic() and kvm_ioapic_init() remain unregister. This patch fixed to do this. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: kvm->arch.vioapic should be NULL if kvm_ioapic_init() failureWei Yongjun
kvm->arch.vioapic should be NULL in case of kvm_ioapic_init() failure due to cannot register io dev. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Fix Codestyle in virt/kvm/coalesced_mmio.cJochen Maes
Fixed 2 codestyle issues in virt/kvm/coalesced_mmio.c Signed-off-by: Jochen Maes <jochen.maes@sejo.be> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Introduce kvm_host_page_sizeJoerg Roedel
This patch introduces a generic function to find out the host page size for a given gfn. This function is needed by the kvm iommu code. This patch also simplifies the x86 host_mapping_level function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: enable PCI multiple-segments for pass-through deviceZhai, Edwin
Enable optional parameter (default 0) - PCI segment (or domain) besides BDF, when assigning PCI device to guest. Signed-off-by: Zhai Edwin <edwin.zhai@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: Fix kvm_coalesced_mmio_ring duplicate allocationSheng Yang
The commit 0953ca73 "KVM: Simplify coalesced mmio initialization" allocate kvm_coalesced_mmio_ring in the kvm_coalesced_mmio_init(), but didn't discard the original allocation... Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: fix cleanup_srcu_struct on vm destructionMarcelo Tosatti
cleanup_srcu_struct on VM destruction remains broken: BUG: unable to handle kernel paging request at ffffffffffffffff IP: [<ffffffff802533d2>] srcu_read_lock+0x16/0x21 RIP: 0010:[<ffffffff802533d2>] [<ffffffff802533d2>] srcu_read_lock+0x16/0x21 Call Trace: [<ffffffffa05354c4>] kvm_arch_vcpu_uninit+0x1b/0x48 [kvm] [<ffffffffa05339c6>] kvm_vcpu_uninit+0x9/0x15 [kvm] [<ffffffffa0569f7d>] vmx_free_vcpu+0x7f/0x8f [kvm_intel] [<ffffffffa05357b5>] kvm_arch_destroy_vm+0x78/0x111 [kvm] [<ffffffffa053315b>] kvm_put_kvm+0xd4/0xfe [kvm] Move it to kvm_arch_destroy_vm. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
2010-03-01KVM: avoid taking ioapic mutex for non-ioapic EOIsAvi Kivity
When the guest acknowledges an interrupt, it sends an EOI message to the local apic, which broadcasts it to the ioapic. To handle the EOI, we need to take the ioapic mutex. On large guests, this causes a lot of contention on this mutex. Since large guests usually don't route interrupts via the ioapic (they use msi instead), this is completely unnecessary. Avoid taking the mutex by introducing a handled_vectors bitmap. Before taking the mutex, check if the ioapic was actually responsible for the acked vector. If not, we can return early. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: convert slots_lock to a mutexMarcelo Tosatti
2010-03-01KVM: convert io_bus to SRCUMarcelo Tosatti
2010-03-01KVM: x86: switch kvm_set_memory_alias to SRCU updateMarcelo Tosatti
Using a similar two-step procedure as for memslots. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: introduce kvm->srcu and convert kvm_set_memory_region to SRCU updateMarcelo Tosatti
Use two steps for memslot deletion: mark the slot invalid (which stops instantiation of new shadow pages for that slot, but allows destruction), then instantiate the new empty slot. Also simplifies kvm_handle_hva locking. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: use gfn_to_pfn_memslot in kvm_iommu_map_pagesMarcelo Tosatti
So its possible to iommu map a memslot before making it visible to kvm. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: introduce gfn_to_pfn_memslotMarcelo Tosatti
Which takes a memslot pointer instead of using kvm->memslots. To be used by SRCU convertion later. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: split kvm_arch_set_memory_region into prepare and commitMarcelo Tosatti
Required for SRCU convertion later. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: modify memslots layout in struct kvmMarcelo Tosatti
Have a pointer to an allocated region inside struct kvm. [alex: fix ppc book 3s] Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: Simplify coalesced mmio initializationAvi Kivity
- add destructor function - move related allocation into constructor - add stubs for !CONFIG_KVM_MMIO Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Add KVM_MMIO kconfig itemAvi Kivity
s390 doesn't have mmio, this will simplify ifdefing it out. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-01KVM: Remove ifdefs from mmu notifier initializationAvi Kivity
2010-03-01KVM: Add include guards for coalesced_mmio.hAvi Kivity
2010-03-01KVM: Disentangle mmu notifiers and coalesced_mmio registrationAvi Kivity
They aren't related. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-01-25KVM: fix spurious interrupt with irqfdMichael S. Tsirkin
kvm didn't clear irqfd counter on deassign, as a result we could get a spurious interrupt when irqfd is assigned back. this leads to poor performance and, in theory, guest crash. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-01-25KVM: properly check max PIC pin in irq route setupMarcelo Tosatti
Otherwise memory beyond irq_states[16] might be accessed. Noticed by Juan Quintela. Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Juan Quintela <quintela@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-01-25KVM: only allow one gsi per fdMichael S. Tsirkin
Looks like repeatedly binding same fd to multiple gsi's with irqfd can use up a ton of kernel memory for irqfd structures. A simple fix is to allow each fd to only trigger one gsi: triggering a storm of interrupts in guest is likely useless anyway, and we can do it by binding a single gsi to many interrupts if we really want to. Cc: stable@kernel.org Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-27KVM: get rid of kvm_create_vm() unused label warning on s390Heiko Carstens
arch/s390/kvm/../../../virt/kvm/kvm_main.c: In function 'kvm_create_vm': arch/s390/kvm/../../../virt/kvm/kvm_main.c:409: warning: label 'out_err' defined but not used Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-27KVM: Fix possible circular locking in kvm_vm_ioctl_assign_device()Sheng Yang
One possible order is: KVM_CREATE_IRQCHIP ioctl(took kvm->lock) -> kvm_iobus_register_dev() -> down_write(kvm->slots_lock). The other one is in kvm_vm_ioctl_assign_device(), which take kvm->slots_lock first, then kvm->lock. Update the comment of lock order as well. Observe it due to kernel locking debug warnings. Cc: stable@kernel.org Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-22anonfd: Allow making anon files read-onlyRoland Dreier
It seems a couple places such as arch/ia64/kernel/perfmon.c and drivers/infiniband/core/uverbs_main.c could use anon_inode_getfile() instead of a private pseudo-fs + alloc_file(), if only there were a way to get a read-only file. So provide this by having anon_inode_getfile() create a read-only file if we pass O_RDONLY in flags. Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-09Merge commit 'origin/master' into nextBenjamin Herrenschmidt
Conflicts: include/linux/kvm.h
2009-12-03KVM: Allow internal errors reported to userspace to carry extra dataAvi Kivity
Usually userspace will freeze the guest so we can inspect it, but some internal state is not available. Add extra data to internal error reporting so we can expose it to the debugger. Extra data is specific to the suberror. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: only clear irq_source_id if irqchip is presentMarcelo Tosatti
Otherwise kvm might attempt to dereference a NULL pointer. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Enable 32bit dirty log pointers on 64bit hostArnd Bergmann
With big endian userspace, we can't quite figure out if a pointer is 32 bit (shifted >> 32) or 64 bit when we read a 64 bit pointer. This is what happens with dirty logging. To get the pointer interpreted correctly, we thus need Arnd's patch to implement a compat layer for the ioctl: A better way to do this is to add a separate compat_ioctl() method that converts this for you. Based on initial patch from Arnd Bergmann. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: fix irq_source_id size verificationMarcelo Tosatti
find_first_zero_bit works with bit numbers, not bytes. Fixes https://sourceforge.net/tracker/?func=detail&aid=2847560&group_id=180599&atid=893831 Reported-by: "Xu, Jiajun" <jiajun.xu@intel.com> Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-03KVM: introduce kvm_vcpu_on_spinZhai, Edwin
Introduce kvm_vcpu_on_spin, to be used by VMX/SVM to yield processing once the cpu detects pause-based looping. Signed-off-by: "Zhai, Edwin" <edwin.zhai@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-03KVM: fix lock imbalance in kvm_*_irq_source_id()Jiri Slaby
Stanse found 2 lock imbalances in kvm_request_irq_source_id and kvm_free_irq_source_id. They omit to unlock kvm->irq_lock on fail paths. Fix that by adding unlock labels at the end of the functions and jump there from the fail paths. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Activate Virtualization On DemandAlexander Graf
X86 CPUs need to have some magic happening to enable the virtualization extensions on them. This magic can result in unpleasant results for users, like blocking other VMMs from working (vmx) or using invalid TLB entries (svm). Currently KVM activates virtualization when the respective kernel module is loaded. This blocks us from autoloading KVM modules without breaking other VMMs. To circumvent this problem at least a bit, this patch introduces on demand activation of virtualization. This means, that instead virtualization is enabled on creation of the first virtual machine and disabled on destruction of the last one. So using this, KVM can be easily autoloaded, while keeping other hypervisors usable. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move assigned device code to own fileAvi Kivity
2009-12-03KVM: Drop kvm->irq_lock lock from irq injection pathGleb Natapov
The only thing it protects now is interrupt injection into lapic and this can work lockless. Even now with kvm->irq_lock in place access to lapic is not entirely serialized since vcpu access doesn't take kvm->irq_lock. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move IO APIC to its own lockGleb Natapov
The allows removal of irq_lock from the injection path. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Convert irq notifiers lists to RCU lockingGleb Natapov
Use RCU locking for mask/ack notifiers lists. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq ack notifier list to arch independent codeGleb Natapov
Mask irq notifier list is already there. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq routing data structure to rcu lockingGleb Natapov
2009-12-03KVM: Maintain back mapping from irqchip/pin to gsiGleb Natapov
Maintain back mapping from irqchip/pin to gsi to speedup interrupt acknowledgment notifications. [avi: build fix on non-x86/ia64] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Change irq routing table to use gsi indexed arrayGleb Natapov
Use gsi indexed array instead of scanning all entries on each interrupt injection. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move irq sharing information to irqchip levelGleb Natapov
This removes assumptions that max GSIs is smaller than number of pins. Sharing is tracked on pin level not GSI level. [avi: no PIC on ia64] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Don't wrap schedule() with vcpu_put()/vcpu_load()Avi Kivity
Preemption notifiers will do that for us automatically. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-11-05Use Little Endian for Dirty BitmapAlexander Graf
We currently use host endian long types to store information in the dirty bitmap. This works reasonably well on Little Endian targets, because the u32 after the first contains the next 32 bits. On Big Endian this breaks completely though, forcing us to be inventive here. So Ben suggested to always use Little Endian, which looks reasonable. We only have dirty bitmap implemented in Little Endian targets so far and since PowerPC would be the first Big Endian platform, we can just as well switch to Little Endian always with little effort without breaking existing targets. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-16KVM: Prevent kvm_init from corrupting debugfs structuresDarrick J. Wong
I'm seeing an oops condition when kvm-intel and kvm-amd are modprobe'd during boot (say on an Intel system) and then rmmod'd: # modprobe kvm-intel kvm_init() kvm_init_debug() kvm_arch_init() <-- stores debugfs dentries internally (success, etc) # modprobe kvm-amd kvm_init() kvm_init_debug() <-- second initialization clobbers kvm's internal pointers to dentries kvm_arch_init() kvm_exit_debug() <-- and frees them # rmmod kvm-intel kvm_exit() kvm_exit_debug() <-- double free of debugfs files! *BOOM* If execution gets to the end of kvm_init(), then the calling module has been established as the kvm provider. Move the debugfs initialization to the end of the function, and remove the now-unnecessary call to kvm_exit_debug() from the error path. That way we avoid trampling on the debugfs entries and freeing them twice. Cc: stable@kernel.org Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
