path: root/virt
2009-09-24KVM: Fix coalesced interrupt reporting in IOAPICGleb Natapov
commit 65a82211636f156a276cac3f8665605ae18f371f upstream. This bug was introduced by b4a2f5e723e4f7df467. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-09KVM: Avoid redelivery of edge interrupt before next edgeGleb Natapov
The check for an edge is broken in current ioapic code. ioapic->irr is cleared on each edge interrupt by ioapic_service() and this makes old_irr != ioapic->irr condition in kvm_ioapic_set_irq() to be always true. The patch fixes the code to properly recognise edge. Some HW emulation calls set_irq() without level change. If each such call is propagated to an OS it may confuse a device driver. This is the case with keyboard device emulation and Windows XP x64 installer on SMP VM. Each keystroke produce two interrupts (down/up) one interrupt is submitted to CPU0 and another to CPU1. This confuses Windows somehow and it ignores keystrokes. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-08-05KVM: fix ack not being delivered when msi presentMichael S. Tsirkin
kvm_notify_acked_irq does not check irq type, so that it sometimes interprets msi vector as irq. As a result, ack notifiers are not called, which typially hangs the guest. The fix is to track and check irq type. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-28KVM: protect concurrent make_all_cpus_requestMarcelo Tosatti
make_all_cpus_request contains a race condition which can trigger false request completed status, as follows: CPU0 CPU1 if (test_and_set_bit(req,&vcpu->requests)) .... if (test_and_set_bit(req,&vcpu->requests)) .. return proceed to smp_call_function_many(wait=1) Use a spinlock to serialize concurrent CPUs. Cc: stable@kernel.org Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-28KVM: Fix dirty bit tracking for slots with large pagesIzik Eidus
When slot is already allocated and being asked to be tracked we need to break the large pages. This code flush the mmu when someone ask a slot to start dirty bit tracking. Cc: stable@kernel.org Signed-off-by: Izik Eidus <ieidus@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-11kvm: remove the duplicated cpumask_clearYinghai Lu
zalloc_cpumask_var already cleared it. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-10KVM: Prevent overflow in largepages calculationAvi Kivity
If userspace specifies a memory slot that is larger than 8 petabytes, it could overflow the largepages variable. Cc: stable@kernel.org Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Disable large pages on misaligned memory slotsAvi Kivity
If a slots guest physical address and host virtual address unequal (mod large page size), then we would erronously try to back guest large pages with host large pages. Detect this misalignment and diable large page support for the trouble slot. Cc: stable@kernel.org Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: take mmu_lock when updating a deleted slotMarcelo Tosatti
kvm_handle_hva relies on mmu_lock protection to safely access the memslot structures. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: protect assigned dev workqueue, int handler and irq ackerMarcelo Tosatti
kvm_assigned_dev_ack_irq is vulnerable to a race condition with the interrupt handler function. It does: if (dev->host_irq_disabled) { enable_irq(dev->host_irq); dev->host_irq_disabled = false; } If an interrupt triggers before the host->dev_irq_disabled assignment, it will disable the interrupt and set dev->host_irq_disabled to true. On return to kvm_assigned_dev_ack_irq, dev->host_irq_disabled is set to false, and the next kvm_assigned_dev_ack_irq call will fail to reenable it. Other than that, having the interrupt handler and work handlers run in parallel sounds like asking for trouble (could not spot any obvious problem, but better not have to, its fragile). CC: sheng.yang@intel.com Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Trivial format fix in setup_routing_entry()Chris Wright
Remove extra tab. Signed-off-by: Chris Wright <chrisw@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: VMX: Disable VMX when system shutdownSheng Yang
Intel TXT(Trusted Execution Technology) required VMX off for all cpu to work when system shutdown. CC: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Enable snooping control for supported hardwareSheng Yang
Memory aliases with different memory type is a problem for guest. For the guest without assigned device, the memory type of guest memory would always been the same as host(WB); but for the assigned device, some part of memory may be used as DMA and then set to uncacheable memory type(UC/WC), which would be a conflict of host memory type then be a potential issue. Snooping control can guarantee the cache correctness of memory go through the DMA engine of VT-d. [avi: fix build on ia64] Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Fix interrupt unhalting a vcpu when it shouldn'tGleb Natapov
kvm_vcpu_block() unhalts vpu on an interrupt/timer without checking if interrupt window is actually opened. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Timer event should not unconditionally unhalt vcpu.Gleb Natapov
Currently timer events are processed before entering guest mode. Move it to main vcpu event loop since timer events should be processed even while vcpu is halted. Timer may cause interrupt/nmi to be injected and only then vcpu will be unhalted. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: MMU: do not free active mmu pages in free_mmu_pages()Gleb Natapov
free_mmu_pages() should only undo what alloc_mmu_pages() does. Free mmu pages from the generic VM destruction function, kvm_destroy_vm(). Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Device assignment framework reworkSheng Yang
After discussion with Marcelo, we decided to rework device assignment framework together. The old problems are kernel logic is unnecessary complex. So Marcelo suggest to split it into a more elegant way: 1. Split host IRQ assign and guest IRQ assign. And userspace determine the combination. Also discard msi2intx parameter, userspace can specific KVM_DEV_IRQ_HOST_MSI | KVM_DEV_IRQ_GUEST_INTX in assigned_irq->flags to enable MSI to INTx convertion. 2. Split assign IRQ and deassign IRQ. Import two new ioctls: KVM_ASSIGN_DEV_IRQ and KVM_DEASSIGN_DEV_IRQ. This patch also fixed the reversed _IOR vs _IOW in definition(by deprecated the old interface). [avi: replace homemade bitcount() by hweight_long()] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: APIC: get rid of deliver_bitmaskGleb Natapov
Deliver interrupt during destination matching loop. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: change the way how lowest priority vcpu is calculatedGleb Natapov
The new way does not require additional loop over vcpus to calculate the one with lowest priority as one is chosen during delivery bitmap construction. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: consolidate ioapic/ipi interrupt delivery logicGleb Natapov
Use kvm_apic_match_dest() in kvm_get_intr_delivery_bitmask() instead of duplicating the same code. Use kvm_get_intr_delivery_bitmask() in apic_send_ipi() to figure out ipi destination instead of reimplementing the logic. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: ioapic/msi interrupt delivery consolidationGleb Natapov
ioapic_deliver() and kvm_set_msi() have code duplication. Move the code into ioapic_deliver_entry() function and call it from both places. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: APIC: kvm_apic_set_irq deliver all kinds of interruptsGleb Natapov
Get rid of ioapic_inj_irq() and ioapic_inj_nmi() functions. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: Merge kvm_ioapic_get_delivery_bitmask into kvm_get_intr_delivery_bitmaskSheng Yang
Gleb fixed bitmap ops usage in kvm_ioapic_get_delivery_bitmask. Sheng merged two functions, as well as fixed several issues in kvm_get_intr_delivery_bitmask 1. deliver_bitmask is a bitmap rather than a unsigned long intereger. 2. Lowest priority target bitmap wrong calculated by mistake. 3. Prevent potential NULL reference. 4. Declaration in include/kvm_host.h caused powerpc compilation warning. 5. Add warning for guest broadcast interrupt with lowest priority delivery mode. 6. Removed duplicate bitmap clean up in caller of kvm_get_intr_delivery_bitmask. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: Enable MSI-X for KVM assigned deviceSheng Yang
This patch finally enable MSI-X. What we need for MSI-X: 1. Intercept one page in MMIO region of device. So that we can get guest desired MSI-X table and set up the real one. Now this have been done by guest, and transfer to kernel using ioctl KVM_SET_MSIX_NR and KVM_SET_MSIX_ENTRY. 2. Information for incoming interrupt. Now one device can have more than one interrupt, and they are all handled by one workqueue structure. So we need to identify them. The previous patch enable gsi_msg_pending_bitmap get this done. 3. Mapping from host IRQ to guest gsi as well as guest gsi to real MSI/MSI-X message address/data. We used same entry number for the host and guest here, so that it's easy to find the correlated guest gsi. What we lack for now: 1. The PCI spec said nothing can existed with MSI-X table in the same page of MMIO region, except pending bits. The patch ignore pending bits as the first step (so they are always 0 - no pending). 2. The PCI spec allowed to change MSI-X table dynamically. That means, the OS can enable MSI-X, then mask one MSI-X entry, modify it, and unmask it. The patch didn't support this, and Linux also don't work in this way. 3. The patch didn't implement MSI-X mask all and mask single entry. I would implement the former in driver/pci/msi.c later. And for single entry, userspace should have reposibility to handle it. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Add MSI-X interrupt injection logicSheng Yang
We have to handle more than one interrupt with one handler for MSI-X. Avi suggested to use a flag to indicate the pending. So here is it. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Ioctls for init MSI-X entrySheng Yang
Introduce KVM_SET_MSIX_NR and KVM_SET_MSIX_ENTRY two ioctls. This two ioctls are used by userspace to specific guest device MSI-X entry number and correlate MSI-X entry with GSI during the initialization stage. MSI-X should be well initialzed before enabling. Don't support change MSI-X entry number for now. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: bit ops for deliver_bitmapSheng Yang
It's also convenient when we extend KVM supported vcpu number in the future. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Update intr delivery func to accept unsigned long* bitmapSheng Yang
Would be used with bit ops, and would be easily extended if KVM_MAX_VCPUS is increased. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Change API of kvm_ioapic_get_delivery_bitmaskSheng Yang
In order to use with bit ops. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Unify the delivery of IOAPIC and MSI interruptsSheng Yang
2009-06-10KVM: Split IOAPIC structureSheng Yang
Prepared for reuse ioapic_redir_entry for MSI. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-09kvm: fix kvm reboot crash when MAXSMP is usedAvi Kivity
one system was found there is crash during reboot then kvm/MAXSMP Sending all processes the KILL signal... done Please stand by while rebooting the system... [ 1721.856538] md: stopping all md devices. [ 1722.852139] kvm: exiting hardware virtualization [ 1722.854601] BUG: unable to handle kernel NULL pointer dereference at (null) [ 1722.872219] IP: [<ffffffff8102c6b6>] hardware_disable+0x4c/0xb4 [ 1722.877955] PGD 0 [ 1722.880042] Oops: 0000 [#1] SMP [ 1722.892548] last sysfs file: /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/host0/target0:2:0/0:2:0:0/vendor [ 1722.900977] CPU 9 [ 1722.912606] Modules linked in: [ 1722.914226] Pid: 0, comm: swapper Not tainted 2.6.30-rc7-tip-01843-g2305324-dirty #299 ... [ 1722.932589] RIP: 0010:[<ffffffff8102c6b6>] [<ffffffff8102c6b6>] hardware_disable+0x4c/0xb4 [ 1722.942709] RSP: 0018:ffffc900010b6ed8 EFLAGS: 00010046 [ 1722.956121] RAX: 0000000000000000 RBX: ffffc9000e253140 RCX: 0000000000000009 [ 1722.972202] RDX: 000000000000b020 RSI: ffffc900010c3220 RDI: ffffffffffffd790 [ 1722.977399] RBP: ffffc900010b6f08 R08: 0000000000000000 R09: 0000000000000000 [ 1722.995149] R10: 00000000000004b8 R11: 966912b6c78fddbd R12: 0000000000000009 [ 1723.011551] R13: 000000000000b020 R14: 0000000000000009 R15: 0000000000000000 [ 1723.019898] FS: 0000000000000000(0000) GS:ffffc900010b3000(0000) knlGS:0000000000000000 [ 1723.034389] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b [ 1723.041164] CR2: 0000000000000000 CR3: 0000000001001000 CR4: 00000000000006e0 [ 1723.056192] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 1723.072546] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 1723.080562] Process swapper (pid: 0, threadinfo ffff88107e464000, task ffff88047e5a2550) [ 1723.096144] Stack: [ 1723.099071] 0000000000000046 ffffc9000e253168 966912b6c78fddbd ffffc9000e253140 [ 1723.115471] ffff880c7d4304d0 ffffc9000e253168 ffffc900010b6f28 ffffffff81011022 [ 1723.132428] ffffc900010b6f48 966912b6c78fddbd ffffc900010b6f48 ffffffff8100b83b [ 1723.141973] Call Trace: [ 1723.142981] <IRQ> <0> [<ffffffff81011022>] kvm_arch_hardware_disable+0x26/0x3c [ 1723.158153] [<ffffffff8100b83b>] hardware_disable+0x3f/0x55 [ 1723.172168] [<ffffffff810b95f6>] generic_smp_call_function_interrupt+0x76/0x13c [ 1723.178836] [<ffffffff8104cbea>] smp_call_function_interrupt+0x3a/0x5e [ 1723.194689] [<ffffffff81035bf3>] call_function_interrupt+0x13/0x20 [ 1723.199750] <EOI> <0> [<ffffffff814ad3b4>] ? acpi_idle_enter_c1+0xd3/0xf4 [ 1723.217508] [<ffffffff814ad3ae>] ? acpi_idle_enter_c1+0xcd/0xf4 [ 1723.232172] [<ffffffff814ad4bc>] ? acpi_idle_enter_bm+0xe7/0x2ce [ 1723.235141] [<ffffffff81a8d93f>] ? __atomic_notifier_call_chain+0x0/0xac [ 1723.253381] [<ffffffff818c3dff>] ? menu_select+0x58/0xd2 [ 1723.258179] [<ffffffff818c2c9d>] ? cpuidle_idle_call+0xa4/0xf3 [ 1723.272828] [<ffffffff81034085>] ? cpu_idle+0xb8/0x101 [ 1723.277085] [<ffffffff81a80163>] ? start_secondary+0x1bc/0x1d7 [ 1723.293708] Code: b0 00 00 65 48 8b 04 25 28 00 00 00 48 89 45 e0 31 c0 48 8b 04 cd 30 ee 27 82 49 89 cc 49 89 d5 48 8b 04 10 48 8d b8 90 d7 ff ff <48> 8b 87 70 28 00 00 48 8d 98 90 d7 ff ff eb 16 e8 e9 fe ff ff [ 1723.335524] RIP [<ffffffff8102c6b6>] hardware_disable+0x4c/0xb4 [ 1723.342076] RSP <ffffc900010b6ed8> [ 1723.352021] CR2: 0000000000000000 [ 1723.354348] ---[ end trace e2aec53dae150aa1 ]--- it turns out that we need clear cpus_hardware_enabled in that case. Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-08KVM: Explicity initialize cpus_hardware_enabledAvi Kivity
Under CONFIG_MAXSMP, cpus_hardware_enabled is allocated from the heap and not statically initialized. This causes a crash on reboot when kvm thinks vmx is enabled on random nonexistent cpus and accesses nonexistent percpu lists. Fix by explicitly clearing the variable. Cc: stable@kernel.org Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-04-22KVM: Fix overlapping check for memory slotsJan Kiszka
When checking for overlapping slots on registration of a new one, kvm currently also considers zero-length (ie. deleted) slots and rejects requests incorrectly. This finally denies user space from joining slots. Fix the check by skipping deleted slots and advertise this via a KVM_CAP_JOIN_MEMORY_REGIONS_WORKS. Cc: stable@kernel.org Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-04-22KVM: MMU: Fix off-by-one calculating large page countAvi Kivity
The large page initialization code concludes there are two large pages spanned by a slot covering 1 (small) page starting at gfn 1. This is incorrect, and also results in incorrect write_count initialization in some cases (base = 1, npages = 513 for example). Cc: stable@kernel.org Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Get support IRQ routing entry countsSheng Yang
In capability probing ioctl. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: fix sparse warnings: Should it be static?Hannes Eder
Impact: Make symbols static. Fix this sparse warnings: arch/x86/kvm/mmu.c:992:5: warning: symbol 'mmu_pages_add' was not declared. Should it be static? arch/x86/kvm/mmu.c:1124:5: warning: symbol 'mmu_pages_next' was not declared. Should it be static? arch/x86/kvm/mmu.c:1144:6: warning: symbol 'mmu_pages_clear_parents' was not declared. Should it be static? arch/x86/kvm/x86.c:2037:5: warning: symbol 'kvm_read_guest_virt' was not declared. Should it be static? arch/x86/kvm/x86.c:2067:5: warning: symbol 'kvm_write_guest_virt' was not declared. Should it be static? virt/kvm/irq_comm.c:220:5: warning: symbol 'setup_routing_entry' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: ia64: Fix the build errors due to lack of macros related to MSI.Xiantao Zhang
Include the newly introduced msidef.h to solve the build issues. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: fix kvm_vm_ioctl_deassign_deviceWeidong Han
only need to set assigned_dev_id for deassignment, use match->flags to judge and deassign it. Acked-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Report IRQ injection status for MSI delivered interruptsGleb Natapov
Return number of CPUs interrupt was successfully injected into or -1 if none. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Report IRQ injection status to userspace.Gleb Natapov
IRQ injection status is either -1 (if there was no CPU found that should except the interrupt because IRQ was masked or ioapic was misconfigured or ...) or >= 0 in that case the number indicates to how many CPUs interrupt was injected. If the value is 0 it means that the interrupt was coalesced and probably should be reinjected. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: MMU: handle compound pages in kvm_is_mmio_pfnJoerg Roedel
The function kvm_is_mmio_pfn is called before put_page is called on a page by KVM. This is a problem when when this function is called on some struct page which is part of a compund page. It does not test the reserved flag of the compound page but of the struct page within the compount page. This is a problem when KVM works with hugepages allocated at boot time. These pages have the reserved bit set in all tail pages. Only the flag in the compount head is cleared. KVM would not put such a page which results in a memory leak. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Use irq routing API for MSISheng Yang
Merge MSI userspace interface with IRQ routing table. Notice the API have been changed, and using IRQ routing table would be the only interface kvm-userspace supported. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: make irq ack notifications aware of routing tableMarcelo Tosatti
IRQ ack notifications assume an identity mapping between pin->gsi, which might not be the case with, for example, HPET. Translate before acking. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Gleb Natapov <gleb@redhat.com>
2009-03-24KVM: Userspace controlled irq routingAvi Kivity
Currently KVM has a static routing from GSI numbers to interrupts (namely, 0-15 are mapped 1:1 to both PIC and IOAPIC, and 16:23 are mapped 1:1 to the IOAPIC). This is insufficient for several reasons: - HPET requires non 1:1 mapping for the timer interrupt - MSIs need a new method to assign interrupt numbers and dispatch them - ACPI APIC mode needs to be able to reassign the PCI LINK interrupts to the ioapics This patch implements an interrupt routing table (as a linked list, but this can be easily changed) and a userspace interface to replace the table. The routing table is initialized according to the current hardwired mapping. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Interrupt mask notifiers for ioapicAvi Kivity
Allow clients to request notifications when the guest masks or unmasks a particular irq line. This complements irq ack notifications, as the guest will not ack an irq line that is masked. Currently implemented for the ioapic only. Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: Add support to disable MSI for assigned deviceSheng Yang
MSI is always enabled by default for msi2intx=1. But if msi2intx=0, we have to disable MSI if guest require to do so. The patch also discard unnecessary msi2intx judgment if guest want to update MSI state. Notice KVM_DEV_IRQ_ASSIGN_MSI_ACTION is a mask which should cover all MSI related operations, though we only got one for now. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-03-24KVM: New guest debug interfaceJan Kiszka
This rips out the support for KVM_DEBUG_GUEST and introduces a new IOCTL instead: KVM_SET_GUEST_DEBUG. The IOCTL payload consists of a generic part, controlling the "main switch" and the single-step feature. The arch specific part adds an x86 interface for intercepting both types of debug exceptions separately and re-injecting them when the host was not interested. Moveover, the foundation for guest debugging via debug registers is layed. To signal breakpoint events properly back to userland, an arch-specific data block is now returned along KVM_EXIT_DEBUG. For x86, the arch block contains the PC, the debug exception, and relevant debug registers to tell debug events properly apart. The availability of this new interface is signaled by KVM_CAP_SET_GUEST_DEBUG. Empty stubs for not yet supported archs are provided. Note that both SVM and VTX are supported, but only the latter was tested yet. Based on the experience with all those VTX corner case, I would be fairly surprised if SVM will work out of the box. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: Fix assigned devices circular locking dependencyMark McLoughlin
kvm->slots_lock is outer to kvm->lock, so take slots_lock in kvm_vm_ioctl_assign_device() before taking kvm->lock, rather than taking it in kvm_iommu_map_memslots(). Cc: stable@kernel.org Signed-off-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: Fix INTx for device assignmentSheng Yang
Missing buckets and wrong parameter for free_irq() Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
