path: root/virt
2013-04-15KVM: Return destination vcpu on interrupt injectionYang Zhang
Add a new parameter to know vcpus who received the interrupt. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-15KVM: Introduce struct rtc_statusYang Zhang
rtc_status is used to track RTC interrupt delivery status. The pending_eoi will be increased by vcpu who received RTC interrupt and will be decreased when EOI to this interrupt. Also, we use dest_map to record the destination vcpu to avoid the case that vcpu who didn't get the RTC interupt, but issued EOI with same vector of RTC and descreased pending_eoi by mistake. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-15KVM: Add vcpu info to ioapic_update_eoi()Yang Zhang
Add vcpu info to ioapic_update_eoi, so we can know which vcpu issued this EOI. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-04-08KVM: Move kvm_spurious_fault to x86.cGeoff Levand
The routine kvm_spurious_fault() is an x86 specific routine, so move it from virt/kvm/kvm_main.c to arch/x86/kvm/x86.c. Fixes this sparse warning when building on arm64: virt/kvm/kvm_main.c:warning: symbol 'kvm_spurious_fault' was not declared. Should it be static? Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-08KVM: Make local routines staticGeoff Levand
The routines get_user_page_nowait(), kvm_io_bus_sort_cmp(), kvm_io_bus_insert_dev() and kvm_io_bus_get_first_dev() are only referenced within kvm_main.c, so give them static linkage. Fixes sparse warnings like these: virt/kvm/kvm_main.c: warning: symbol 'get_user_page_nowait' was not declared. Should it be static? Signed-off-by: Geoff Levand <geoff@infradead.org> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-07kvm: fix MMIO/PIO collision misdetectionMichael S. Tsirkin
PIO and MMIO are separate address spaces, but ioeventfd registration code mistakenly detected two eventfds as duplicate if they use the same address, even if one is PIO and another one MMIO. Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-07KVM: Call kvm_apic_match_dest() to check destination vcpuYang Zhang
For a given vcpu, kvm_apic_match_dest() will tell you whether the vcpu in the destination list quickly. Drop kvm_calculate_eoi_exitmap() and use kvm_apic_match_dest() instead. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-04-07KVM: Allow cross page reads and writes from cached translations.Andrew Honig
This patch adds support for kvm_gfn_to_hva_cache_init functions for reads and writes that will cross a page. If the range falls within the same memslot, then this will be a fast operation. If the range is split between two memslots, then the slower kvm_read_guest and kvm_write_guest are used. Tested: Test against kvm_clock unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-03-21Merge remote-tracking branch 'upstream/master' into queueMarcelo Tosatti
Merge reason: From: Alexander Graf <agraf@suse.de> "Just recently this really important patch got pulled into Linus' tree for 3.9: commit 1674400aaee5b466c595a8fc310488263ce888c7 Author: Anton Blanchard <anton <at> samba.org> Date: Tue Mar 12 01:51:51 2013 +0000 Without that commit, I can not boot my G5, thus I can't run automated tests on it against my queue. Could you please merge kvm/next against linus/master, so that I can base my trees against that?" * upstream/master: (653 commits) PCI: Use ROM images from firmware only if no other ROM source available sparc: remove unused "config BITS" sparc: delete "if !ULTRA_HAS_POPULATION_COUNT" KVM: Fix bounds checking in ioapic indirect register reads (CVE-2013-1798) KVM: x86: Convert MSR_KVM_SYSTEM_TIME to use gfn_to_hva_cache functions (CVE-2013-1797) KVM: x86: fix for buffer overflow in handling of MSR_KVM_SYSTEM_TIME (CVE-2013-1796) arm64: Kconfig.debug: Remove unused CONFIG_DEBUG_ERRORS arm64: Do not select GENERIC_HARDIRQS_NO_DEPRECATED inet: limit length of fragment queue hash table bucket lists qeth: Fix scatter-gather regression qeth: Fix invalid router settings handling qeth: delay feature trace sgy-cts1000: Remove __dev* attributes KVM: x86: fix deadlock in clock-in-progress request handling KVM: allow host header to be included even for !CONFIG_KVM hwmon: (lm75) Fix tcn75 prefix hwmon: (lm75.h) Update header inclusion MAINTAINERS: Remove Mark M. Hoffman xfs: ensure we capture IO errors correctly xfs: fix xfs_iomap_eof_prealloc_initial_size type ... Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-19KVM: Fix bounds checking in ioapic indirect register reads (CVE-2013-1798)Andy Honig
If the guest specifies a IOAPIC_REG_SELECT with an invalid value and follows that with a read of the IOAPIC_REG_WINDOW KVM does not properly validate that request. ioapic_read_indirect contains an ASSERT(redir_index < IOAPIC_NUM_PINS), but the ASSERT has no effect in non-debug builds. In recent kernels this allows a guest to cause a kernel oops by reading invalid memory. In older kernels (pre-3.3) this allows a guest to read from large ranges of host memory. Tested: tested against apic unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-11kvm: Iterate over only vcpus that are preemptedRaghavendra K T
This helps in filtering out the eligible candidates further and thus potentially helps in quickly allowing preempted lockholders to run. Note that if a vcpu was spinning during preemption we filter them by checking whether they are preempted due to pause loop exit. Reviewed-by: Chegu Vinod <chegu_vinod@hp.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-03-11kvm: Record the preemption status of vcpus using preempt notifiersRaghavendra K T
Note that we mark as preempted only when vcpu's task state was Running during preemption. Thanks Jiannan, Avi for preemption notifier ideas. Thanks Gleb, PeterZ for their precious suggestions. Thanks Srikar for an idea on avoiding rcu lock while checking task state that improved overcommit numbers. Reviewed-by: Chegu Vinod <chegu_vinod@hp.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-03-05KVM: ioeventfd for virtio-ccw devices.Cornelia Huck
Enhance KVM_IOEVENTFD with a new flag that allows to attach to virtio-ccw devices on s390 via the KVM_VIRTIO_CCW_NOTIFY_BUS. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-05KVM: Initialize irqfd from kvm_init().Cornelia Huck
Currently, eventfd introduces module_init/module_exit functions to initialize/cleanup the irqfd workqueue. This only works, however, if no other module_init/module_exit functions are built into the same module. Let's just move the initialization and cleanup to kvm_init and kvm_exit. This way, it is also clearer where kvm startup may fail. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Refactor commit_memory_region()Takuya Yoshikawa
This patch makes the parameter old a const pointer to the old memory slot and adds a new parameter named change to know the change being requested: the former is for removing extra copying and the latter is for cleaning up the code. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Refactor prepare_memory_region()Takuya Yoshikawa
This patch drops the parameter old, a copy of the old memory slot, and adds a new parameter named change to know the change being requested. This not only cleans up the code but also removes extra copying of the memory slot structure. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Make kvm_mr_change available to arch codeTakuya Yoshikawa
This will be used for cleaning up prepare/commit_memory_region() later. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Drop user_alloc from set_memory_region()Takuya Yoshikawa
Except ia64's stale code, KVM_SET_MEMORY_REGION support, this is only used for sanity checks in __kvm_set_memory_region() which can easily be changed to use slot id instead. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-03-04KVM: set_memory_region: Drop user_alloc from prepare/commit_memory_region()Takuya Yoshikawa
X86 does not use this any more. The remaining user, s390's !user_alloc check, can be simply removed since KVM_SET_MEMORY_REGION ioctl is no longer supported. Note: fixed powerpc's indentations with spaces to suppress checkpatch errors. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-11KVM: Remove user_alloc from struct kvm_memory_slotTakuya Yoshikawa
This field was needed to differentiate memory slots created by the new API, KVM_SET_USER_MEMORY_REGION, from those by the old equivalent, KVM_SET_MEMORY_REGION, whose support was dropped long before: commit b74a07beed0e64bfba413dcb70dd6749c57f43dc KVM: Remove kernel-allocated memory regions Although we also have private memory slots to which KVM allocates memory with vm_mmap(), !user_alloc slots in other words, the slot id should be enough for differentiating them. Note: corresponding function parameters will be removed later. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-02-04KVM: set_memory_region: Disallow changing read-only attribute laterTakuya Yoshikawa
As Xiao pointed out, there are a few problems with it: - kvm_arch_commit_memory_region() write protects the memory slot only for GET_DIRTY_LOG when modifying the flags. - FNAME(sync_page) uses the old spte value to set a new one without checking KVM_MEM_READONLY flag. Since we flush all shadow pages when creating a new slot, the simplest fix is to disallow such problematic flag changes: this is safe because no one is doing such things. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Cc: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-02-04KVM: set_memory_region: Identify the requested change explicitlyTakuya Yoshikawa
KVM_SET_USER_MEMORY_REGION forces __kvm_set_memory_region() to identify what kind of change is being requested by checking the arguments. The current code does this checking at various points in code and each condition being used there is not easy to understand at first glance. This patch consolidates these checks and introduces an enum to name the possible changes to clean up the code. Although this does not introduce any functional changes, there is one change which optimizes the code a bit: if we have nothing to change, the new code returns 0 immediately. Note that the return value for this case cannot be changed since QEMU relies on it: we noticed this when we changed it to -EINVAL and got a section mismatch error at the final stage of live migration. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-01-29kvm: Handle yield_to failure return code for potential undercommit caseRaghavendra K T
yield_to returns -ESRCH, When source and target of yield_to run queue length is one. When we see three successive failures of yield_to we assume we are in potential undercommit case and abort from PLE handler. The assumption is backed by low probability of wrong decision for even worst case scenarios such as average runqueue length between 1 and 2. More detail on rationale behind using three tries: if p is the probability of finding rq length one on a particular cpu, and if we do n tries, then probability of exiting ple handler is: p^(n+1) [ because we would have come across one source with rq length 1 and n target cpu rqs with length 1 ] so num tries: probability of aborting ple handler (1.5x overcommit) 1 1/4 2 1/8 3 1/16 We can increase this probability with more tries, but the problem is the overhead. Also, If we have tried three times that means we would have iterated over 3 good eligible vcpus along with many non-eligible candidates. In worst case if we iterate all the vcpus, we reduce 1x performance and overcommit performance get hit. note that we do not update last boosted vcpu in failure cases. Thank Avi for raising question on aborting after first fail from yield_to. Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Tested-by: Chegu Vinod <chegu_vinod@hp.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-29x86, apicv: add virtual interrupt delivery supportYang Zhang
Virtual interrupt delivery avoids KVM to inject vAPIC interrupts manually, which is fully taken care of by the hardware. This needs some special awareness into existing interrupr injection path: - for pending interrupt, instead of direct injection, we may need update architecture specific indicators before resuming to guest. - A pending interrupt, which is masked by ISR, should be also considered in above update action, since hardware will decide when to inject it at right time. Current has_interrupt and get_interrupt only returns a valid vector from injection p.o.v. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Kevin Tian <kevin.tian@intel.com> Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-27kvm: Obey read-only mappings in iommuAlex Williamson
We've been ignoring read-only mappings and programming everything into the iommu as read-write. Fix this to only include the write access flag when read-only is not set. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-27kvm: Force IOMMU remapping on memory slot read-only flag changesAlex Williamson
Memory slot flags can be altered without changing other parameters of the slot. The read-only attribute is the only one the IOMMU cares about, so generate an un-map, re-map when this occurs. This also avoid unnecessarily re-mapping the slot when no IOMMU visible changes are made. Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-17KVM: set_memory_region: Remove unnecessary variable memslotTakuya Yoshikawa
One such variable, slot, is enough for holding a pointer temporarily. We also remove another local variable named slot, which is limited in a block, since it is confusing to have the same name in this function. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-17KVM: set_memory_region: Don't check for overlaps unless we create or move a slotTakuya Yoshikawa
Don't need the check for deleting an existing slot or just modifiying the flags. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-17KVM: set_memory_region: Don't jump to out_free unnecessarilyTakuya Yoshikawa
This makes the separation between the sanity checks and the rest of the code a bit clearer. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-01-14KVM: Write protect the updated slot only when dirty logging is enabledTakuya Yoshikawa
Calling kvm_mmu_slot_remove_write_access() for a deleted slot does nothing but search for non-existent mmu pages which have mappings to that deleted memory; this is safe but a waste of time. Since we want to make the function rmap based in a later patch, in a manner which makes it unsafe to be called for a deleted slot, we makes the caller see if the slot is non-zero and being dirty logged. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-12-24KVM: move the code that installs new slots array to a separate function.Gleb Natapov
Move repetitive code sequence to a separate function. Reviewed-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-12-23kvm: Fix memory slot generation updatesAlex Williamson
Previous patch "kvm: Minor memory slot optimization" (b7f69c555ca43) overlooked the generation field of the memory slots. Re-using the original memory slots left us with with two slightly different memory slots with the same generation. To fix this, make update_memslots() take a new parameter to specify the last generation. This also makes generation management more explicit to avoid such problems in the future. Reported-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-12-23KVM: remove a wrong hack of delivery PIT intr to vcpu0Yang Zhang
This hack is wrong. The pin number of PIT is connected to 2 not 0. This means this hack never takes effect. So it is ok to remove it. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-12-13KVM: struct kvm_memory_slot.id -> shortAlex Williamson
We're currently offering a whopping 32 memory slots to user space, an int is a bit excessive for storing this. We would like to increase our memslots, but SHRT_MAX should be more than enough. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: struct kvm_memory_slot.user_alloc -> boolAlex Williamson
There's no need for this to be an int, it holds a boolean. Move to the end of the struct for alignment. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Rename KVM_MEMORY_SLOTS -> KVM_USER_MEM_SLOTSAlex Williamson
It's easy to confuse KVM_MEMORY_SLOTS and KVM_MEM_SLOTS_NUM. One is the user accessible slots and the other is user + private. Make this more obvious. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Minor memory slot optimizationAlex Williamson
If a slot is removed or moved in the guest physical address space, we first allocate and install a new slot array with the invalidated entry. The old array is then freed. We then proceed to allocate yet another slot array to install the permanent replacement. Re-use the original array when this occurs and avoid the extra kfree/kmalloc. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Fix iommu map/unmap to handle memory slot movesAlex Williamson
The iommu integration into memory slots expects memory slots to be added or removed and doesn't handle the move case. We can unmap slots from the iommu after we mark them invalid and map them before installing the final memslot array. Also re-order the kmemdup vs map so we don't leave iommu mappings if we get ENOMEM. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Check userspace_addr when modifying a memory slotAlex Williamson
The API documents that only flags and guest physical memory space can be modified on an existing slot, but we don't enforce that the userspace address cannot be modified. Instead we just ignore it. This means that a user may think they've successfully moved both the guest and user addresses, when in fact only the guest address changed. Check and error instead. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-13KVM: Restrict non-existing slot state transitionsAlex Williamson
The API documentation states: When changing an existing slot, it may be moved in the guest physical memory space, or its flags may be modified. An "existing slot" requires a non-zero npages (memory_size). The only transition we should therefore allow for a non-existing slot should be to create the slot, which includes setting a non-zero memory_size. We currently allow calls to modify non-existing slots, which is pointless, confusing, and possibly wrong. With this we know that the invalidation path of __kvm_set_memory_region is always for a delete or move and never for adding a zero size slot. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-10kvm: Fix irqfd resampler list walkAlex Williamson
Typo for the next pointer means we're walking random data here. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-12-09Merge branch 'for-upstream' of https://github.com/agraf/linux-2.6 into queueMarcelo Tosatti
* 'for-upstream' of https://github.com/agraf/linux-2.6: (28 commits) KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation KVM: PPC: bookehv: Add guest computation mode for irq delivery KVM: PPC: Make EPCR a valid field for booke64 and bookehv KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation KVM: PPC: e500: Add emulation helper for getting instruction ea KVM: PPC: bookehv64: Add support for interrupt handling KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler KVM: PPC: booke: Fix get_tb() compile error on 64-bit KVM: PPC: e500: Silence bogus GCC warning in tlb code KVM: PPC: Book3S HV: Handle guest-caused machine checks on POWER7 without panicking KVM: PPC: Book3S HV: Improve handling of local vs. global TLB invalidations MAINTAINERS: Add git tree link for PPC KVM KVM: PPC: Book3S PR: MSR_DE doesn't exist on Book 3S KVM: PPC: Book3S PR: Fix VSX handling KVM: PPC: Book3S PR: Emulate PURR, SPURR and DSCR registers KVM: PPC: Book3S HV: Don't give the guest RW access to RO pages KVM: PPC: Book3S HV: Report correct HPT entry index when reading HPT ...
2012-12-06KVM: Distangle eventfd code from irqchipAlexander Graf
The current eventfd code assumes that when we have eventfd, we also have irqfd for in-kernel interrupt delivery. This is not necessarily true. On PPC we don't have an in-kernel irqchip yet, but we can still support easily support eventfd. Signed-off-by: Alexander Graf <agraf@suse.de>
2012-12-05kvm: deliver msi interrupts from irq handlerMichael S. Tsirkin
We can deliver certain interrupts, notably MSI, from atomic context. Use kvm_set_irq_inatomic, to implement an irq handler for msi. This reduces the pressure on scheduler in case where host and guest irq share a host cpu. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-12-05kvm: add kvm_set_irq_inatomicMichael S. Tsirkin
Add an API to inject IRQ from atomic context. Return EWOULDBLOCK if impossible (e.g. for multicast). Only MSI is supported ATM. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2012-11-29KVM: Fix user memslot overlap checkAlex Williamson
Prior to memory slot sorting this loop compared all of the user memory slots for overlap with new entries. With memory slot sorting, we're just checking some number of entries in the array that may or may not be user slots. Instead, walk all the slots with kvm_for_each_memslot, which has the added benefit of terminating early when we hit the first empty slot, and skip comparison to private slots. Cc: stable@vger.kernel.org Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-11-27KVM: x86: add kvm_arch_vcpu_postcreate callback, move TSC initializationMarcelo Tosatti
TSC initialization will soon make use of online_vcpus. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-11-27KVM: x86: implement PVCLOCK_TSC_STABLE_BIT pvclock flagMarcelo Tosatti
KVM added a global variable to guarantee monotonicity in the guest. One of the reasons for that is that the time between 1. ktime_get_ts(&timespec); 2. rdtscll(tsc); Is variable. That is, given a host with stable TSC, suppose that two VCPUs read the same time via ktime_get_ts() above. The time required to execute 2. is not the same on those two instances executing in different VCPUS (cache misses, interrupts...). If the TSC value that is used by the host to interpolate when calculating the monotonic time is the same value used to calculate the tsc_timestamp value stored in the pvclock data structure, and a single <system_timestamp, tsc_timestamp> tuple is visible to all vcpus simultaneously, this problem disappears. See comment on top of pvclock_update_vm_gtod_copy for details. Monotonicity is then guaranteed by synchronicity of the host TSCs and guest TSCs. Set TSC stable pvclock flag in that case, allowing the guest to read clock from userspace. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-11-13KVM: remove unnecessary return value checkGuo Chao
No need to check return value before breaking switch. Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
