path: root/virt
2014-06-09KVM: async_pf: mm->mm_users can not pin apf->mmOleg Nesterov
commit 41c22f626254b9dc0376928cae009e73d1b6a49a upstream. get_user_pages(mm) is simply wrong if mm->mm_users == 0 and exit_mmap/etc was already called (or is in progress), mm->mm_count can only pin mm->pgd and mm_struct itself. Change kvm_setup_async_pf/async_pf_execute to inc/dec mm->mm_users. kvm_create_vm/kvm_destroy_vm play with ->mm_count too but this case looks fine at first glance, it seems that this ->mm is only used to verify that current->mm == kvm->mm. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-06-09kvm: remove .done from struct kvm_async_pfRadim Krčmář
commit 98fda169290b3b28c0f2db2b8f02290c13da50ef upstream. '.done' is used to mark the completion of 'async_pf_execute()', but 'cancel_work_sync()' returns true when the work was canceled, so we use it instead. Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-06-09kvm: free resources after canceling async_pfRadim Krčmář
commit 28b441e24088081c1e213139d1303b451a34a4f4 upstream. When we cancel 'async_pf_execute()', we should behave as if the work was never scheduled in 'kvm_setup_async_pf()'. Fixes a bug when we can't unload module because the vm wasn't destroyed. Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-04-02KVM: return an error code in kvm_vm_ioctl_register_coalesced_mmio()Dan Carpenter
commit aac5c4226e7136c331ed384c25d5560204da10a0 upstream. If kvm_io_bus_register_dev() fails then it returns success but it should return an error code. I also did a little cleanup like removing an impossible NULL test. Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03KVM: Fix iommu map/unmap to handle memory slot movesAlex Williamson
commit e40f193f5bb022e927a57a4f5d5194e4f12ddb74 upstream. The iommu integration into memory slots expects memory slots to be added or removed and doesn't handle the move case. We can unmap slots from the iommu after we mark them invalid and map them before installing the final memslot array. Also re-order the kmemdup vs map so we don't leave iommu mappings if we get ENOMEM. Reviewed-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03KVM: perform an invalid memslot step for gpa base changeMarcelo Tosatti
commit 12d6e7538e2d418c08f082b1b44ffa5fb7270ed8 upstream. PPC must flush all translations before the new memory slot is visible. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> [bwh: Backported to 3.2: adjust context] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03KVM: Improve create VCPU parameter (CVE-2013-4587)Andy Honig
commit 338c7dbadd2671189cec7faf64c84d01071b3f96 upstream. In multiple functions the vcpu_id is used as an offset into a bitfield. Ag malicious user could specify a vcpu_id greater than 255 in order to set or clear bits in kernel memory. This could be used to elevate priveges in the kernel. This patch verifies that the vcpu_id provided is less than 255. The api documentation already specifies that the vcpu_id must be less than max_vcpus, but this is currently not checked. Reported-by: Andrew Honig <ahonig@google.com> Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2014-01-03KVM: IOMMU: hva align mapping page sizeGreg Edwards
commit 27ef63c7e97d1e5dddd85051c03f8d44cc887f34 upstream. When determining the page size we could use to map with the IOMMU, the page size should also be aligned with the hva, not just the gfn. The gfn may not reflect the real alignment within the hugetlbfs file. Most of the time, this works fine. However, if the hugetlbfs file is backed by non-contiguous huge pages, a multi-huge page memslot starts at an unaligned offset within the hugetlbfs file, and the gfn is aligned with respect to the huge page size, kvm_host_page_size() will return the huge page size and we will use that to map with the IOMMU. When we later unpin that same memslot, the IOMMU returns the unmap size as the huge page size, and we happily unpin that many pfns in monotonically increasing order, not realizing we are spanning non-contiguous huge pages and partially unpin the wrong huge page. Ensure the IOMMU mapping page size is aligned with the hva corresponding to the gfn, which does reflect the alignment within the hugetlbfs file. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Edwards <gedwards@ddn.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> [bwh: Backported to 3.2: s/__gfn_to_hva_memslot/gfn_to_hva_memslot/] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-25KVM: Allow cross page reads and writes from cached translations.Andrew Honig
commit 8f964525a121f2ff2df948dac908dcc65be21b5b upstream. This patch adds support for kvm_gfn_to_hva_cache_init functions for reads and writes that will cross a page. If the range falls within the same memslot, then this will be a fast operation. If the range is split between two memslots, then the slower kvm_read_guest and kvm_write_guest are used. Tested: Test against kvm_clock unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> [bwh: Backported to 3.2: - Drop change in lapic.c - Keep using __gfn_to_memslot() in kvm_gfn_to_hva_cache_init()] Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2013-04-25KVM: Fix bounds checking in ioapic indirect register reads (CVE-2013-1798)Andy Honig
commit a2c118bfab8bc6b8bb213abfc35201e441693d55 upstream. If the guest specifies a IOAPIC_REG_SELECT with an invalid value and follows that with a read of the IOAPIC_REG_WINDOW KVM does not properly validate that request. ioapic_read_indirect contains an ASSERT(redir_index < IOAPIC_NUM_PINS), but the ASSERT has no effect in non-debug builds. In recent kernels this allows a guest to cause a kernel oops by reading invalid memory. In older kernels (pre-3.3) this allows a guest to read from large ranges of host memory. Tested: tested against apic unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-07-25KVM: Fix buffer overflow in kvm_set_irq()Avi Kivity
commit f2ebd422f71cda9c791f76f85d2ca102ae34a1ed upstream. kvm_set_irq() has an internal buffer of three irq routing entries, allowing connecting a GSI to three IRQ chips or on MSI. However setup_routing_entry() does not properly enforce this, allowing three irqchip routes followed by an MSI route to overflow the buffer. Fix by ensuring that an MSI entry is added to an empty list. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31KVM: lock slots_lock around device assignmentAlex Williamson
(cherry picked from commit 21a1416a1c945c5aeaeaf791b63c64926018eb77) As pointed out by Jason Baron, when assigning a device to a guest we first set the iommu domain pointer, which enables mapping and unmapping of memory slots to the iommu. This leaves a window where this path is enabled, but we haven't synchronized the iommu mappings to the existing memory slots. Thus a slot being removed at that point could send us down unexpected code paths removing non-existent pinnings and iommu mappings. Take the slots_lock around creating the iommu domain and initial mappings as well as around iommu teardown to avoid this race. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31KVM: Ensure all vcpus are consistent with in-kernel irqchip settingsAvi Kivity
(cherry picked from commit 3e515705a1f46beb1c942bb8043c16f8ac7b1e9e) If some vcpus are created before KVM_CREATE_IRQCHIP, then irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading to potential NULL pointer dereferences. Fix by: - ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called - ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP This is somewhat long winded because vcpu->arch.apic is created without kvm->lock held. Based on earlier patch by Michael Ellerman. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-31KVM: mmu_notifier: Flush TLBs before releasing mmu_lockTakuya Yoshikawa
(cherry picked from commit 565f3be2174611f364405bbea2d86e153c2e7e78 Other threads may process the same page in that small window and skip TLB flush and then return before these functions do flush. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2012-05-11KVM: unmap pages from the iommu when slots are removedAlex Williamson
commit 32f6daad4651a748a58a3ab6da0611862175722f upstream. We've been adding new mappings, but not destroying old mappings. This can lead to a page leak as pages are pinned using get_user_pages, but only unpinned with put_page if they still exist in the memslots list on vm shutdown. A memslot that is destroyed while an iommu domain is enabled for the guest will therefore result in an elevated page reference count that is never cleared. Additionally, without this fix, the iommu is only programmed with the first translation for a gpa. This can result in peer-to-peer errors if a mapping is destroyed and replaced by a new mapping at the same gpa as the iommu will still be pointing to the original, pinned memory address. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Jonathan Nieder <jrnieder@gmail.com> Signed-off-by: Ben Hutchings <ben@decadent.org.uk>
2011-12-25KVM: Device assignment permission checksAlex Williamson
Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-25KVM: Remove ability to assign a device without iommu supportAlex Williamson
This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-10-31kvm: iommu.c file requires the full module.h present.Paul Gortmaker
This file has things like module_param_named() and MODULE_PARM_DESC() so it needs the full module.h header present. Without it, you'll get: CC arch/x86/kvm/../../../virt/kvm/iommu.o virt/kvm/iommu.c:37: error: expected ‘)’ before ‘bool’ virt/kvm/iommu.c:39: error: expected ‘)’ before string constant make[3]: *** [arch/x86/kvm/../../../virt/kvm/iommu.o] Error 1 make[2]: *** [arch/x86/kvm] Error 2 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31kvm: fix implicit use of stat.h header filePaul Gortmaker
This was coming in via an implicit module.h (and its sub-includes) before, but we'll be cleaning that up shortly. Call out the stat.h include requirement in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-30Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits) iommu/core: Remove global iommu_ops and register_iommu iommu/msm: Use bus_set_iommu instead of register_iommu iommu/omap: Use bus_set_iommu instead of register_iommu iommu/vt-d: Use bus_set_iommu instead of register_iommu iommu/amd: Use bus_set_iommu instead of register_iommu iommu/core: Use bus->iommu_ops in the iommu-api iommu/core: Convert iommu_found to iommu_present iommu/core: Add bus_type parameter to iommu_domain_alloc Driver core: Add iommu_ops to bus_type iommu/core: Define iommu_ops and register_iommu only with CONFIG_IOMMU_API iommu/amd: Fix wrong shift direction iommu/omap: always provide iommu debug code iommu/core: let drivers know if an iommu fault handler isn't installed iommu/core: export iommu_set_fault_handler() iommu/omap: Fix build error with !IOMMU_SUPPORT iommu/omap: Migrate to the generic fault report mechanism iommu/core: Add fault reporting mechanism iommu/core: Use PAGE_SIZE instead of hard-coded value iommu/core: use the existing IS_ALIGNED macro iommu/msm: ->unmap() should return order of unmapped page ... Fixup trivial conflicts in drivers/iommu/Makefile: "move omap iommu to dedicated iommu folder" vs "Rename the DMAR and INTR_REMAP config options" just happened to touch lines next to each other.
2011-10-30Merge branch 'kvm-updates/3.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'kvm-updates/3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (75 commits) KVM: SVM: Keep intercepting task switching with NPT enabled KVM: s390: implement sigp external call KVM: s390: fix register setting KVM: s390: fix return value of kvm_arch_init_vm KVM: s390: check cpu_id prior to using it KVM: emulate lapic tsc deadline timer for guest x86: TSC deadline definitions KVM: Fix simultaneous NMIs KVM: x86 emulator: convert push %sreg/pop %sreg to direct decode KVM: x86 emulator: switch lds/les/lss/lfs/lgs to direct decode KVM: x86 emulator: streamline decode of segment registers KVM: x86 emulator: simplify OpMem64 decode KVM: x86 emulator: switch src decode to decode_operand() KVM: x86 emulator: qualify OpReg inhibit_byte_regs hack KVM: x86 emulator: switch OpImmUByte decode to decode_imm() KVM: x86 emulator: free up some flag bits near src, dst KVM: x86 emulator: switch src2 to generic decode_operand() KVM: x86 emulator: expand decode flags to 64 bits KVM: x86 emulator: split dst decode to a generic decode_operand() KVM: x86 emulator: move memop, memopp into emulation context ...
2011-10-21iommu/core: Convert iommu_found to iommu_presentJoerg Roedel
With per-bus iommu_ops the iommu_found function needs to work on a bus_type too. This patch adds a bus_type parameter to that function and converts all call-places. The function is also renamed to iommu_present because the function now checks if an iommu is present for a given bus and does not check for a global iommu anymore. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-10-21iommu/core: Add bus_type parameter to iommu_domain_allocJoerg Roedel
This is necessary to store a pointer to the bus-specific iommu_ops in the iommu-domain structure. It will be used later to call into bus-specific iommu-ops. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-09-25KVM: Split up MSI-X assigned device IRQ handlerJan Kiszka
The threaded IRQ handler for MSI-X has almost nothing in common with the INTx/MSI handler. Move its code into a dedicated handler. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-25KVM: Avoid needless registrations of IRQ ack notifier for assigned devicesJan Kiszka
We only perform work in kvm_assigned_dev_ack_irq if the guest IRQ is of INTx type. This completely avoids the callback invocation in non-INTx cases by registering the IRQ ack notifier only for INTx. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-25KVM: Clean up unneeded void pointer castsJan Kiszka
2011-09-25KVM: Intelligent device lookup on I/O busSasha Levin
Currently the method of dealing with an IO operation on a bus (PIO/MMIO) is to call the read or write callback for each device registered on the bus until we find a device which handles it. Since the number of devices on a bus can be significant due to ioeventfds and coalesced MMIO zones, this leads to a lot of overhead on each IO operation. Instead of registering devices, we now register ranges which points to a device. Lookup is done using an efficient bsearch instead of a linear search. Performance test was conducted by comparing exit count per second with 200 ioeventfds created on one byte and the guest is trying to access a different byte continuously (triggering usermode exits). Before the patch the guest has achieved 259k exits per second, after the patch the guest does 274k exits per second. Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-09-25KVM: Make coalesced mmio use a device per zoneSasha Levin
This patch changes coalesced mmio to create one mmio device per zone instead of handling all zones in one device. Doing so enables us to take advantage of existing locking and prevents a race condition between coalesced mmio registration/unregistration and lookups. Suggested-by: Avi Kivity <avi@redhat.com> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-25KVM: MMIO: Lock coalesced device when checking for available entrySasha Levin
Move the check whether there are available entries to within the spinlock. This allows working with larger amount of VCPUs and reduces premature exits when using a large number of VCPUs. Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Pekka Enberg <penberg@kernel.org> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-09-23pci: Add flag indicating device has been assigned by KVMGreg Rose
Device drivers that create and destroy SR-IOV virtual functions via calls to pci_enable_sriov() and pci_disable_sriov can cause catastrophic failures if they attempt to destroy VFs while they are assigned to guest virtual machines. By adding a flag for use by the KVM module to indicate that a device is assigned a device driver can check that flag and avoid destroying VFs while they are assigned and avoid system failures. CC: Ian Campbell <ijc@hellion.org.uk> CC: Konrad Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-07-24KVM: IOMMU: Disable device assignment without interrupt remappingAlex Williamson
IOMMU interrupt remapping support provides a further layer of isolation for device assignment by preventing arbitrary interrupt block DMA writes by a malicious guest from reaching the host. By default, we should require that the platform provides interrupt remapping support, with an opt-in mechanism for existing behavior. Both AMD IOMMU and Intel VT-d2 hardware support interrupt remapping, however we currently only have software support on the Intel side. Users wishing to re-enable device assignment when interrupt remapping is not supported on the platform can use the "allow_unsafe_assigned_interrupts=1" module option. [avi: break long lines] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-24KVM: MMU: mmio page fault supportXiao Guangrong
The idea is from Avi: | We could cache the result of a miss in an spte by using a reserved bit, and | checking the page fault error code (or seeing if we get an ept violation or | ept misconfiguration), so if we get repeated mmio on a page, we don't need to | search the slot list/tree. | (https://lkml.org/lkml/2011/2/22/221) When the page fault is caused by mmio, we cache the info in the shadow page table, and also set the reserved bits in the shadow page table, so if the mmio is caused again, we can quickly identify it and emulate it directly Searching mmio gfn in memslots is heavy since we need to walk all memeslots, it can be reduced by this feature, and also avoid walking guest page table for soft mmu. [jan: fix operator precedence issue] Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-24KVM: MMU: filter out the mmio pfn from the fault pfnXiao Guangrong
If the page fault is caused by mmio, the gfn can not be found in memslots, and 'bad_pfn' is returned on gfn_to_hva path, so we can use 'bad_pfn' to identify the mmio page fault. And, to clarify the meaning of mmio pfn, we return fault page instead of bad page when the gfn is not allowd to prefetch Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: introduce kvm_read_guest_cachedGleb Natapov
Introduce kvm_read_guest_cached() function in addition to write one we already have. [ by glauber: export function signature in kvm header ] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Glauber Costa <glommer@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Eric Munson <emunson@mgebm.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Fix off-by-one in overflow check of KVM_ASSIGN_SET_MSIX_NRJan Kiszka
KVM_MAX_MSIX_PER_DEV implies that up to that many MSI-X entries can be requested. But the kernel so far rejected already the upper limit. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Add compat ioctl for KVM_SET_SIGNAL_MASKAlexander Graf
KVM has an ioctl to define which signal mask should be used while running inside VCPU_RUN. At least for big endian systems, this mask is different on 32-bit and 64-bit systems (though the size is identical). Add a compat wrapper that converts the mask to whatever the kernel accepts, allowing 32-bit kvm user space to set signal masks. This patch fixes qemu with --enable-io-thread on ppc64 hosts when running 32-bit user land. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Clean up error handling during VCPU creationJan Kiszka
So far kvm_arch_vcpu_setup is responsible for freeing the vcpu struct if it fails. Move this confusing resonsibility back into the hands of kvm_vm_ioctl_create_vcpu. Only kvm_arch_vcpu_setup of x86 is affected, all other archs cannot fail. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: use __copy_to_user/__clear_user to write guest pageXiao Guangrong
Simply use __copy_to_user/__clear_user to write guest page since we have already verified the user address when the memslot is set Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-06-07Merge branch 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Initialize kvm before registering the mmu notifier KVM: x86: use proper port value when checking io instruction permission KVM: add missing void __user * cast to access_ok() call
2011-06-06KVM: Initialize kvm before registering the mmu notifierMike Waychison
It doesn't make sense to ever see a half-initialized kvm structure on mmu notifier callbacks. Previously, 85722cda changed the ordering to ensure that the mmu_lock was initialized before mmu notifier registration, but there is still a race where the mmu notifier could come in and try accessing other portions of struct kvm before they are intialized. Solve this by moving the mmu notifier registration to occur after the structure is completely initialized. Google-Bug-Id: 452199 Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-26KVM: add missing void __user * cast to access_ok() callHeiko Carstens
fa3d315a "KVM: Validate userspace_addr of memslot when registered" introduced this new warning onn s390: kvm_main.c: In function '__kvm_set_memory_region': kvm_main.c:654:7: warning: passing argument 1 of '__access_ok' makes pointer from integer without a cast arch/s390/include/asm/uaccess.h:53:19: note: expected 'const void *' but argument is of type '__u64' Add the missing cast to get rid of it again... Cc: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-22KVM: Fix kvm mmu_notifier initialization orderOGAWA Hirofumi
Like the following, mmu_notifier can be called after registering immediately. So, kvm have to initialize kvm->mmu_lock before it. BUG: spinlock bad magic on CPU#0, kswapd0/342 lock: ffff8800af8c4000, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 Pid: 342, comm: kswapd0 Not tainted 2.6.39-rc5+ #1 Call Trace: [<ffffffff8118ce61>] spin_bug+0x9c/0xa3 [<ffffffff8118ce91>] do_raw_spin_lock+0x29/0x13c [<ffffffff81024923>] ? flush_tlb_others_ipi+0xaf/0xfd [<ffffffff812e22f3>] _raw_spin_lock+0x9/0xb [<ffffffffa0582325>] kvm_mmu_notifier_clear_flush_young+0x2c/0x66 [kvm] [<ffffffff810d3ff3>] __mmu_notifier_clear_flush_young+0x2b/0x57 [<ffffffff810c8761>] page_referenced_one+0x88/0xea [<ffffffff810c89bf>] page_referenced+0x1fc/0x256 [<ffffffff810b2771>] shrink_page_list+0x187/0x53a [<ffffffff810b2ed7>] shrink_inactive_list+0x1e0/0x33d [<ffffffff810acf95>] ? determine_dirtyable_memory+0x15/0x27 [<ffffffff812e90ee>] ? call_function_single_interrupt+0xe/0x20 [<ffffffff810b3356>] shrink_zone+0x322/0x3de [<ffffffff810a9587>] ? zone_watermark_ok_safe+0xe2/0xf1 [<ffffffff810b3928>] kswapd+0x516/0x818 [<ffffffff810b3412>] ? shrink_zone+0x3de/0x3de [<ffffffff81053d17>] kthread+0x7d/0x85 [<ffffffff812e9394>] kernel_thread_helper+0x4/0x10 [<ffffffff81053c9a>] ? __init_kthread_worker+0x37/0x37 [<ffffffff812e9390>] ? gs_change+0xb/0xb Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: Validate userspace_addr of memslot when registeredTakuya Yoshikawa
This way, we can avoid checking the user space address many times when we read the guest memory. Although we can do the same for write if we check which slots are writable, we do not care write now: reading the guest memory happens more often than writing. [avi: change VERIFY_READ to VERIFY_WRITE] Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: ioapic: Fix an error field referenceLiu Yuan
Function ioapic_debug() in the ioapic_deliver() misnames one filed by reference. This patch correct it. Signed-off-by: Liu Yuan <tailai.ly@taobao.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-21KVM: Use pci_store/load_saved_state() around VM device usageAlex Williamson
Store the device saved state so that we can reload the device back to the original state when it's unassigned. This has the benefit that the state survives across pci_reset_function() calls via the PCI sysfs reset interface while the VM is using the device. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Avi Kivity <avi@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-11KVM: cleanup memslot_id functionXiao Guangrong
We can get memslot id from memslot->id directly Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-04-07Merge branch 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: move and fix substitue search for missing CPUID entries KVM: fix XSAVE bit scanning KVM: Enable async page fault processing KVM: fix crash on irqfd deassign
2011-04-06KVM: Enable async page fault processingGleb Natapov
If asynchronous hva_to_pfn() is requested call GUP with FOLL_NOWAIT to avoid sleeping on IO. Check for hwpoison is done at the same time, otherwise check_user_page_hwpoison() will call GUP again and will put vcpu to sleep. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-04-06KVM: fix crash on irqfd deassignMichael S. Tsirkin
irqfd in kvm used flush_work incorrectly: it assumed that work scheduled previously can't run after flush_work, but since kvm uses a non-reentrant workqueue (by means of schedule_work) we need flush_work_sync to get that guarantee. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Reported-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr> Tested-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr> Signed-off-by: Avi Kivity <avi@redhat.com>
