commit 9432a3175770e06cb83eada2d91fac90c977cb99 upstream.
A comment warning against this bug is there, but the code is not doing what
the comment says. Therefore it is possible that an EPOLLHUP races against
irq_bypass_register_consumer. The EPOLLHUP handler schedules irqfd_shutdown,
and if that runs soon enough, you get a use-after-free.
Reported-by: syzbot <syzkaller@googlegroups.com>
Cc: stable@vger.kernel.org
Reviewed-by: David Hildenbrand <david@redhat.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
[ Upstream commit ba56bc3a0786992755e6804fbcbdc60ef6cfc24c ]
When booting a 64 KB pages kernel on a ACPI GICv3 system that
implements support for v2 emulation, the following warning is
produced
GICV size 0x2000 not a multiple of page size 0x10000
and support for v2 emulation is disabled, preventing GICv2 VMs
from being able to run on such hosts.
The reason is that vgic_v3_probe() performs a sanity check on the
size of the window (it should be a multiple of the page size),
while the ACPI MADT parsing code hardcodes the size of the window
to 8 KB. This makes sense, considering that ACPI does not bother
to describe the size in the first place, under the assumption that
platforms implementing ACPI will follow the architecture and not
put anything else in the same 64 KB window.
So let's just drop the sanity check altogether, and assume that
the window is at least 64 KB in size.
Fixes: 909777324588 ("KVM: arm/arm64: vgic-new: vgic_init: implement kvm_vgic_hyp_init")
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
commit b5020a8e6b54d2ece80b1e7dedb33c79a40ebd47 upstream.
Syzbot reports crashes in kvm_irqfd_assign(), caused by use-after-free
when kvm_irqfd_assign() and kvm_irqfd_deassign() run in parallel
for one specific eventfd. When the assign path hasn't finished but irqfd
has been added to kvm->irqfds.items list, another thead may deassign the
eventfd and free struct kvm_kernel_irqfd(). The assign path then uses
the struct kvm_kernel_irqfd that has been freed by deassign path. To avoid
such issue, keep irqfd under kvm->irq_srcu protection after the irqfd
has been added to kvm->irqfds.items list, and call synchronize_srcu()
in irq_shutdown() to make sure that irqfd has been fully initialized in
the assign path.
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Tianyu Lan <tianyu.lan@intel.com>
Commit 44a497abd621a71c645f06d3d545ae2f46448830 upstream.
kvm_vgic_global_state is part of the read-only section, and is
usually accessed using a PC-relative address generation (adrp + add).
It is thus useless to use kern_hyp_va() on it, and actively problematic
if kern_hyp_va() becomes non-idempotent. On the other hand, there is
no way that the compiler is going to guarantee that such access is
always PC relative.
So let's bite the bullet and provide our own accessor.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Reviewed-by: James Morse <james.morse@arm.com>
[ Upstream commit a340b3e229b24a56f1c7f5826b15a3af0f4b13e5 ]
For EPT-violations that are triggered by a read, the pages are also mapped with
write permissions (if their memory region is also writable). That would avoid
getting yet another fault on the same page when a write occurs.
This optimization only happens when you have a "struct page" backing the memory
region. So also enable it for memory regions that do not have a "struct page".
Cc: kvm@vger.kernel.org
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit bf308242ab98b5d1648c3663e753556bef9bec01 upstream.
kvm_read_guest() will eventually look up in kvm_memslots(), which requires
either to hold the kvm->slots_lock or to be inside a kvm->srcu critical
section.
In contrast to x86 and s390 we don't take the SRCU lock on every guest
exit, so we have to do it individually for each kvm_read_guest() call.
Provide a wrapper which does that and use that everywhere.
Note that ending the SRCU critical section before returning from the
kvm_read_guest() wrapper is safe, because the data has been *copied*, so
we don't need to rely on valid references to the memslot anymore.
Cc: Stable <stable@vger.kernel.org> # 4.8+
Reported-by: Jan Glauber <jan.glauber@caviumnetworks.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Christoffer Dall <christoffer.dall@arm.com>
commit b28676bb8ae4569cced423dc2a88f7cb319d5379 upstream.
Reported by syzkaller:
pte_list_remove: ffff9714eb1f8078 0->BUG
kernel BUG at arch/x86/kvm/mmu.c:1157!
invalid opcode: 0000 [#1] SMP
RIP: 0010:pte_list_remove+0x11b/0x120 [kvm]
Call Trace:
drop_spte+0x83/0xb0 [kvm]
mmu_page_zap_pte+0xcc/0xe0 [kvm]
kvm_mmu_prepare_zap_page+0x81/0x4a0 [kvm]
kvm_mmu_invalidate_zap_all_pages+0x159/0x220 [kvm]
kvm_arch_flush_shadow_all+0xe/0x10 [kvm]
kvm_mmu_notifier_release+0x6c/0xa0 [kvm]
? kvm_mmu_notifier_release+0x5/0xa0 [kvm]
__mmu_notifier_release+0x79/0x110
? __mmu_notifier_release+0x5/0x110
exit_mmap+0x15a/0x170
? do_exit+0x281/0xcb0
mmput+0x66/0x160
do_exit+0x2c9/0xcb0
? __context_tracking_exit.part.5+0x4a/0x150
do_group_exit+0x50/0xd0
SyS_exit_group+0x14/0x20
do_syscall_64+0x73/0x1f0
entry_SYSCALL64_slow_path+0x25/0x25
The reason is that when creates new memslot, there is no guarantee for new
memslot not overlap with private memslots. This can be triggered by the
following program:
#include <fcntl.h>
#include <pthread.h>
#include <setjmp.h>
#include <signal.h>
#include <stddef.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/ioctl.h>
#include <sys/stat.h>
#include <sys/syscall.h>
#include <sys/types.h>
#include <unistd.h>
#include <linux/kvm.h>
long r[16];
int main()
void *p = valloc(0x4000);
r[2] = open("/dev/kvm", 0);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0x0ul);
uint64_t addr = 0xf000;
ioctl(r[3], KVM_SET_IDENTITY_MAP_ADDR, &addr);
r[6] = ioctl(r[3], KVM_CREATE_VCPU, 0x0ul);
ioctl(r[3], KVM_SET_TSS_ADDR, 0x0ul);
ioctl(r[6], KVM_RUN, 0);
struct kvm_userspace_memory_region mr = {
.slot = 0,
.flags = KVM_MEM_LOG_DIRTY_PAGES,
.guest_phys_addr = 0xf000,
.memory_size = 0x4000,
.userspace_addr = (uintptr_t) p
ioctl(r[3], KVM_SET_USER_MEMORY_REGION, &mr);
return 0;
This patch fixes the bug by not adding a new memslot even if it
overlaps with private memslots.
Cc: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
[ Upstream commit 46bea48ac241fe0b413805952dda74dd0c09ba8b ]
The kvm slabs can consume a significant amount of system memory
and indeed in our production environment we have observed that
a lot of machines are spending significant amount of memory that
can not be left as system memory overhead. Also the allocations
from these slabs can be triggered directly by user space applications
which has access to kvm and thus a buggy application can leak
such memory. So, these caches should be accounted to kmemcg.
Signed-off-by: Shakeel Butt <shakeelb@google.com>
[ Upstream commit 0292e169b2d9c8377a168778f0b16eadb1f578fd ]
or VM memory are not put thus leaked in kvm_iommu_unmap_memslots() when
destroy VM.
This is consistent with current vfio implementation.
Signed-off-by: herongguang <herongguang.he@huawei.com>
commit 64afe6e9eb4841f35317da4393de21a047a883b3 upstream.
The current pending table parsing code assumes that we keep the
previous read of the pending bits, but keep that variable in
the current block, making sure it is discarded on each loop.
We end-up using whatever is on the stack. Who knows, it might
just be the right thing...
Fixes: 33d3bc9556a7d ("KVM: arm64: vgic-its: Read initial LPI pending table")
Cc: stable@vger.kernel.org # 4.8
Reported-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
[ Upstream commit a5e1e6ca94a8cec51571fd62e3eaec269717969c ]
The ITS spec says that ITS commands are only processed when the ITS
is enabled (section 8.19.4, Enabled, bit[0]). Our emulation was not taking
this into account.
Fix this by checking the enabled state before handling CWRITER writes.
On the other hand that means that CWRITER could advance while the ITS
is disabled, and enabling it would need those commands to be processed.
Fix this case as well by refactoring actual command processing and
calling this from both the GITS_CWRITER and GITS_CTLR handlers.
Reviewed-by: Eric Auger <eric.auger@redhat.com>
Reviewed-by: Christoffer Dall <cdall@linaro.org>
commit 686f294f2f1ae40705283dd413ca1e4c14f20f93 upstream.
We miss a test against NULL after allocation.
Fixes: 6d03a68f8054 ("KVM: arm64: vgic-its: Turn device_id validation into generic ID validation")
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 150009e2c70cc3c6e97f00e7595055765d32fb85 upstream.
Using the size of the structure we're allocating is a good idea
and avoids any surprise... In this case, we're happilly confusing
kvm_kernel_irq_routing_entry and kvm_irq_routing_entry...
Fixes: 95b110ab9a09 ("KVM: arm/arm64: Enable irqchip routing")
commit fc396e066318c0a02208c1d3f0b62950a7714999 upstream.
We are incorrectly rearranging 32-bit words inside a 64-bit typed value
for big endian systems, which would result in never marking a virtual
interrupt as inactive on big endian systems (assuming 32 or fewer LRs on
the hardware). Fix this by not doing any word order manipulation for
the typed values.
commit b1394e745b9453dcb5b0671c205b770e87dedb87 upstream.
Implementation of the unpinned APIC page didn't update the VMCS address
cache when invalidation was done through range mmu notifiers.
This became a problem when the page notifier was removed.
Re-introduce the arch-specific helper and call it from ...range_start.
Reported-by: Fabian Grünbichler <f.gruenbichler@proxmox.com>
Fixes: 38b9917350cb ("kvm: vmx: Implement set_apic_access_page_addr")
Fixes: 369ea8242c0f ("mm/rmap: update to new mmu_notifier semantic v2")
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Wanpeng Li <wanpeng.li@hotmail.com>
Tested-by: Fabian Grünbichler <f.gruenbichler@proxmox.com>
[ Upstream commit 63e41226afc3f7a044b70325566fa86ac3142538 ]
When a VCPU blocks (WFI) and has programmed the vtimer, we program a
soft timer to expire in the future to wake up the vcpu thread when
appropriate. Because such as wake up involves a vcpu kick, and the
timer expire function can get called from interrupt context, and the
kick may sleep, we have to schedule the kick in the work function.
The work function currently has a warning that gets raised if it turns
out that the timer shouldn't fire when it's run, which was added because
the idea was that in that case the work should never have been cancelled.
However, it turns out that this whole thing is racy and we can get
spurious warnings. The problem is that we clear the armed flag in the
work function, which may run in parallel with the
kvm_timer_unschedule->timer_disarm() call. This results in a possible
situation where the timer_disarm() call does not call
cancel_work_sync(), which effectively synchronizes the completion of the
work function with running the VCPU. As a result, the VCPU thread
proceeds before the work function completees, causing changes to the
timer state such that kvm_timer_should_fire(vcpu) returns false in the
work function.
All we do in the work function is to kick the VCPU, and an occasional
rare extra kick never harmed anyone. Since the race above is extremely
rare, we don't bother checking if the race happens but simply remove the
check and the clearing of the armed flag from the work function.
Reported-by: Matthias Brugger <mbrugger@suse.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
commit 5d6dee80a1e94cc284d03e06d930e60e8d3ecf7d upstream.
At the point where the kvm-vfio pseudo device wants to release its
vfio group reference, we can't always acquire a new reference to make
that happen. The group can be in a state where we wouldn't allow a
new reference to be added. This new helper function allows a caller
to match a file to a group to facilitate this. Given a file and
group, report if they match. Thus the caller needs to already have a
group reference to match to the file. This allows the deletion of a
group without acquiring a new reference.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Eric Auger <eric.auger@redhat.com>
commit ddf42d068f8802de122bb7efdfcb3179336053f1 upstream.
When an interrupt is injected with the HW bit set (indicating that
deactivation should be propagated to the physical distributor),
special care must be taken so that we never mark the corresponding
LR with the Active+Pending state (as the pending state is kept in
the physycal distributor).
Fixes: 140b086dd197 ("KVM: arm/arm64: vgic-new: Add GICv2 world switch backend")
Signed-off-by: Christoffer Dall <cdall@linaro.org>
commit 3d6e77ad1489650afa20da92bb589c8778baa8da upstream.
Fixes: 59529f69f504 ("KVM: arm/arm64: vgic-new: Add GICv3 world switch backend")
commit 90db10434b163e46da413d34db8d0e77404cc645 upstream.
No caller currently checks the return value of
kvm_io_bus_unregister_dev(). This is evil, as all callers silently go on
freeing their device. A stale reference will remain in the io_bus,
getting at least used again, when the iobus gets teared down on
kvm_destroy_vm() - leading to use after free errors.
There is nothing the callers could do, except retrying over and over
again.
So let's simply remove the bus altogether, print an error and make
sure no one can access this broken bus again (returning -ENOMEM on any
attempt to access it).
Fixes: e93f8a0f821e ("KVM: convert io_bus to SRCU")
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: David Hildenbrand <david@redhat.com>
commit df630b8c1e851b5e265dc2ca9c87222e342c093b upstream.
When releasing the bus, let's clear the bus pointers to mark it out. If
any further device unregister happens on this bus, we know that we're
done if we found the bus being released already.
Signed-off-by: Peter Xu <peterx@redhat.com>
commit 370a0ec1819990f8e2a93df7cc9c0146980ed45f upstream.
Currently, if a vcpu thread tries to change the active state of an
interrupt which is already on the same vcpu's AP list, it will loop
forever. Since the VGIC mmio handler is called after a vcpu has
already synced back the LR state to the struct vgic_irq, we can just
let it proceed safely.
Signed-off-by: Jintack Lim <jintack@cs.columbia.edu>
commit 0bdbf3b071986ba80731203683cf623d5c0cacb1 upstream.
The IRQFD framework calls the architecture dependent function
twice if the corresponding GSI type is edge triggered. For ARM,
the function kvm_set_msi() is getting called twice whenever the
IRQFD receives the event signal. The rest of the code path is
trying to inject the MSI without any validation checks. No need
to call the function vgic_its_inject_msi() second time to avoid
an unnecessary overhead in IRQ queue logic. It also avoids the
possibility of VM seeing the MSI twice.
Simple fix, return -1 if the argument 'level' value is zero.
Signed-off-by: Shanker Donthineni <shankerd@codeaurora.org>
commit 1193e6aeecb36c74c48c7cd0f641acbbed9ddeef upstream.
Dmitry Vyukov reported that the syzkaller fuzzer triggered a
deadlock in the vgic setup code when an error was detected, as
the cleanup code tries to take a lock that is already held by
the setup code.
The fix is to avoid retaking the lock when cleaning up, by
telling the cleanup function that we already hold it.
commit 4f3dbdf47e150016aacd734e663347fcaa768303 upstream.
Reported syzkaller:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
IP: irq_bypass_unregister_consumer+0x9d/0xb70 [irqbypass]
PGD 0
Oops: 0002 [#1] SMP
CPU: 1 PID: 125 Comm: kworker/1:1 Not tainted 4.9.0+ #1
Workqueue: kvm-irqfd-cleanup irqfd_shutdown [kvm]
task: ffff9bbe0dfbb900 task.stack: ffffb61802014000
RIP: 0010:irq_bypass_unregister_consumer+0x9d/0xb70 [irqbypass]
Call Trace:
irqfd_shutdown+0x66/0xa0 [kvm]
process_one_work+0x16b/0x480
worker_thread+0x4b/0x500
kthread+0x101/0x140
? process_one_work+0x480/0x480
? kthread_create_on_node+0x60/0x60
ret_from_fork+0x25/0x30
RIP: irq_bypass_unregister_consumer+0x9d/0xb70 [irqbypass] RSP: ffffb61802017e20
CR2: 0000000000000008
The syzkaller folks reported a NULL pointer dereference that due to
unregister an consumer which fails registration before. The syzkaller
creates two VMs w/ an equal eventfd occasionally. So the second VM
fails to register an irqbypass consumer. It will make irqfd as inactive
and queue an workqueue work to shutdown irqfd and unregister the irqbypass
consumer when eventfd is closed. However, the second consumer has been
initialized though it fails registration. So the token(same as the first
VM's) is taken to unregister the consumer through the workqueue, the
consumer of the first VM is found and unregistered, then NULL deref incurred
in the path of deleting consumer from the consumers list.
This patch fixes it by making irq_bypass_register/unregister_consumer()
looks for the consumer entry based on consumer pointer itself instead of
token matching.
Suggested-by: Alex Williamson <alex.williamson@redhat.com>
Cc: Alex Williamson <alex.williamson@redhat.com>
We should move the ops->destroy(dev) after the list_del(&dev->vm_node)
so that we don't use "dev" after freeing it.
Fixes: a28ebea2adc4 ("KVM: Protect device ops->create and list_add with kvm->lock")
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
KVM/ARM updates for v4.9-rc7
- Do not call kvm_notify_acked for PPIs
When we inject a level triggerered interrupt (and unless it
is backed by the physical distributor - timer style), we request
a maintenance interrupt. Part of the processing for that interrupt
is to feed to the rest of KVM (and to the eventfd subsystem) the
information that the interrupt has been EOIed.
But that notification only makes sense for SPIs, and not PPIs
(such as the PMU interrupt). Skip over the notification if
the interrupt is not an SPI.
Cc: stable@vger.kernel.org # 4.7+
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Catalin Marinas <catalin.marinas@arm.com>
This was reported by syzkaller:
[ INFO: possible recursive locking detected ]
4.9.0-rc4+ #49 Not tainted
kworker/2:1/5658 is trying to acquire lock:
([ 1644.769018] (&work->work)
[< inline >] list_empty include/linux/compiler.h:243
[<ffffffff8128dd60>] flush_work+0x0/0x660 kernel/workqueue.c:1511
but task is already holding lock:
[<ffffffff812916ab>] process_one_work+0x94b/0x1900 kernel/workqueue.c:2093
stack backtrace:
CPU: 2 PID: 5658 Comm: kworker/2:1 Not tainted 4.9.0-rc4+ #49
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: events async_pf_execute
ffff8800676ff630 ffffffff81c2e46b ffffffff8485b930 ffff88006b1fc480
0000000000000000 ffffffff8485b930 ffff8800676ff7e0 ffffffff81339b27
ffff8800676ff7e8 0000000000000046 ffff88006b1fcce8 ffff88006b1fccf0
Call Trace:
[<ffffffff8128ddf3>] flush_work+0x93/0x660 kernel/workqueue.c:2846
[<ffffffff812954ea>] __cancel_work_timer+0x17a/0x410 kernel/workqueue.c:2916
[<ffffffff81295797>] cancel_work_sync+0x17/0x20 kernel/workqueue.c:2951
[<ffffffff81073037>] kvm_clear_async_pf_completion_queue+0xd7/0x400 virt/kvm/async_pf.c:126
[< inline >] kvm_free_vcpus arch/x86/kvm/x86.c:7841
[<ffffffff810b728d>] kvm_arch_destroy_vm+0x23d/0x620 arch/x86/kvm/x86.c:7946
[< inline >] kvm_destroy_vm virt/kvm/kvm_main.c:731
[<ffffffff8105914e>] kvm_put_kvm+0x40e/0x790 virt/kvm/kvm_main.c:752
[<ffffffff81072b3d>] async_pf_execute+0x23d/0x4f0 virt/kvm/async_pf.c:111
[<ffffffff8129175c>] process_one_work+0x9fc/0x1900 kernel/workqueue.c:2096
[<ffffffff8129274f>] worker_thread+0xef/0x1480 kernel/workqueue.c:2230
[<ffffffff812a5a94>] kthread+0x244/0x2d0 kernel/kthread.c:209
[<ffffffff831f102a>] ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:433
The reason is that kvm_put_kvm is causing the destruction of the VM, but
the page fault is still on the ->queue list. The ->queue list is owned
by the VCPU, not by the work items, so we cannot just add list_del to
the work item.
Instead, use work->vcpu to note async page faults that have been resolved
and will be processed through the done list. There is no need to flush
those.
KVM/ARM updates for v4.9-rc6
- Fix handling of the 32bit cycle counter
- Fix cycle counter filtering
KVM calls kvm_pmu_set_counter_event_type() when PMCCFILTR is configured.
But this function can't deals with PMCCFILTR correctly because the evtCount
bits of PMCCFILTR, which is reserved 0, conflits with the SW_INCR event
type of other PMXEVTYPER<n> registers. To fix it, when eventsel == 0, this
function shouldn't return immediately; instead it needs to check further
if select_idx is ARMV8_PMU_CYCLE_IDX.
Another issue is that KVM shouldn't copy the eventsel bits of PMCCFILTER
blindly to attr.config. Instead it ought to convert the request to the
"cpu cycle" event type (i.e. 0x11).
To support this patch and to prevent duplicated definitions, a limited
set of ARMv8 perf event types were relocated from perf_event.c to
asm/perf_event.h.
Cc: stable@vger.kernel.org # 4.6+
Acked-by: Will Deacon <will.deacon@arm.com>
Signed-off-by: Wei Huang <wei@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into HEAD
KVM/ARM updates for v4.9-rc4
- Kick the vcpu when a pending interrupt becomes pending again
- Prevent access to invalid interrupt registers
- Invalid TLBs when two vcpus from the same VM share a CPU
Pull KVM updates from Paolo Bonzini:
"One NULL pointer dereference, and two fixes for regressions introduced
during the merge window.
The rest are fixes for MIPS, s390 and nested VMX"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvm: x86: Check memopp before dereference (CVE-2016-8630)
kvm: nVMX: VMCLEAR an active shadow VMCS after last use
KVM: x86: drop TSC offsetting kvm_x86_ops to fix KVM_GET/SET_CLOCK
KVM: x86: fix wbinvd_dirty_mask use-after-free
kvm/x86: Show WRMSR data is in hex
kvm: nVMX: Fix kernel panics induced by illegal INVEPT/INVVPID types
KVM: document lock orders
KVM: fix OOPS on flush_work
KVM: s390: Fix STHYI buffer alignment for diag224
KVM: MIPS: Precalculate MMIO load resume PC
KVM: MIPS: Make ERET handle ERL before EXL
KVM: MIPS: Fix lazy user ASID regenerate for SMP
In cases like IPI, we could be queueing an interrupt for a VCPU
that is already running and is not about to exit, because the
VCPU has entered the VM with the interrupt pending and would
not trap on EOI'ing that interrupt. This could result to delays
in interrupt deliveries or even loss of interrupts.
To guarantee prompt interrupt injection, here we have to try to
kick the VCPU.
Signed-off-by: Shih-Wei Li <shihwei@cs.columbia.edu>
In our VGIC implementation we limit the number of SPIs to a number
that the userland application told us. Accordingly we limit the
allocation of memory for virtual IRQs to that number.
However in our MMIO dispatcher we didn't check if we ever access an
IRQ beyond that limit, leading to out-of-bound accesses.
Add a test against the number of allocated SPIs in check_region().
Adjust the VGIC_ADDR_TO_INT macro to avoid an actual division, which
is not implemented on ARM(32).
[maz: cleaned-up original patch]
The conversion done by commit 3706feacd007 ("KVM: Remove deprecated
create_singlethread_workqueue") is broken. It flushes a single work
item &irqfd->shutdown instead of all of them, and even worse if there
is no irqfd on the list then you get a NULL pointer dereference.
Revert the virt/kvm/eventfd.c part of that patch; to avoid the
deprecated function, just allocate our own workqueue---it does
not even have to be unbound---with alloc_workqueue.
Fixes: 3706feacd007
This patch unexports the low-level __get_user_pages() function.
Recent refactoring of the get_user_pages* functions allow flags to be
passed through get_user_pages() which eliminates the need for access to
this function from its one user, kvm.
We can see that the two calls to get_user_pages() which replace
__get_user_pages() in kvm_main.c are equivalent by examining their call
stacks:
get_user_page_nowait():
get_user_pages(start, 1, flags, page, NULL)
__get_user_pages_locked(current, current->mm, start, 1, page, NULL, NULL,
false, flags | FOLL_TOUCH)
__get_user_pages(current, current->mm, start, 1,
flags | FOLL_TOUCH | FOLL_GET, page, NULL, NULL)
check_user_page_hwpoison():
get_user_pages(addr, 1, flags, NULL, NULL)
__get_user_pages_locked(current, current->mm, addr, 1, NULL, NULL, NULL,
__get_user_pages(current, current->mm, addr, 1, flags | FOLL_TOUCH, NULL,
NULL, NULL)
Signed-off-by: Lorenzo Stoakes <lstoakes@gmail.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
This removes the redundant 'write' and 'force' parameters from
__get_user_pages_unlocked() to make the use of FOLL_FORCE explicit in
callers as use of this flag can result in surprising behaviour (and
hence bugs) within the mm subsystem.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into next
KVM/ARM Changes for v4.9
- Various cleanups and removal of redundant code
- Two important fixes for not using an in-kernel irqchip
- A bit of optimizations
- Handle SError exceptions and present them to guests if appropriate
- Proxying of GICV access at EL2 if guest mappings are unsafe
- GICv3 on AArch32 on ARMv8
- Preparations for GICv3 save/restore, including ABI docs
If the vgic hasn't been created and initialized, we shouldn't attempt to
look at its data structures or flush/sync anything to the GIC hardware.
This fixes an issue reported by Alexander Graf when using a userspace
irqchip.
Fixes: 0919e84c0fc1 ("KVM: arm/arm64: vgic-new: Add IRQ sync/flush framework")
Reported-by: Alexander Graf <agraf@suse.de>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
If userspace creates a PMU for the VCPU, but doesn't create an in-kernel
irqchip, then we end up in a nasty path where we try to take an
uninitialized spinlock, which can lead to all sorts of breakages.
Luckily, QEMU always creates the VGIC before the PMU, so we can
establish this as ABI and check for the VGIC in the PMU init stage.
This can be relaxed at a later time if we want to support PMU with a
userspace irqchip.
Cc: Shannon Zhao <shannon.zhao@linaro.org>
This patch allows to build and use vgic-v3 in 32-bit mode.
Unfortunately, it can not be split in several steps without extra
stubs to keep patches independent and bisectable. For instance,
virt/kvm/arm/vgic/vgic-v3.c uses function from vgic-v3-sr.c, handling
access to GICv3 cpu interface from the guest requires vgic_v3.vgic_sre
to be already defined.
It is how support has been done:
* handle SGI requests from the guest
* report configured SRE on access to GICv3 cpu interface from the guest
* required vgic-v3 macros are provided via uapi.h
* static keys are used to select GIC backend
* to make vgic-v3 build KVM_ARM_VGIC_V3 guard is removed along with
the static inlines
Signed-off-by: Vladimir Murzin <vladimir.murzin@arm.com>
We have couple of 64-bit registers defined in GICv3 architecture, so
unsigned long accesses to these registers will only access a single
32-bit part of that regitser. On the other hand these registers can't
be accessed as 64-bit with a single instruction like ldrd/strd or
ldmia/stmia if we run a 32-bit host because KVM does not support
access to MMIO space done by these instructions.
It means that a 32-bit guest accesses these registers in 32-bit
chunks, so the only thing we need to do is to ensure that
extract_bytes() always takes 64-bit data.
Well, this patch is looking ahead of time, but we'll get following
compiler warnings as soon as we introduce vgic-v3 to 32-bit world
CC arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.o
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c: In function 'vgic_mmio_read_v3r_typer':
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:184:35: warning: left shift count >= width of type [-Wshift-count-overflow]
value = (mpidr & GENMASK(23, 0)) << 32;
In file included from ./include/linux/kernel.h:10:0,
from ./include/asm-generic/bug.h:13,
from ./arch/arm/include/asm/bug.h:59,
from ./include/linux/bug.h:4,
from ./include/linux/io.h:23,
from ./arch/arm/include/asm/arch_gicv3.h:23,
from ./include/linux/irqchip/arm-gic-v3.h:411,
from arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:14:
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c: In function 'vgic_v3_dispatch_sgi':
./include/linux/bitops.h:6:24: warning: left shift count >= width of type [-Wshift-count-overflow]
#define BIT(nr) (1UL << (nr))
arch/arm/kvm/../../../virt/kvm/arm/vgic/vgic-mmio-v3.c:614:20: note: in expansion of macro 'BIT'
broadcast = reg & BIT(ICC_SGI1R_IRQ_ROUTING_MODE_BIT);
Let's fix them now.
By now ITS code guarded with KVM_ARM_VGIC_V3 config option which was
introduced to hide everything specific to vgic-v3 from 32-bit world.
We are going to support vgic-v3 in 32-bit world and KVM_ARM_VGIC_V3
will gone, but we don't have support for ITS there yet and we need to
continue keeping ITS away.
Introduce the new config option to prevent ITS code being build in
32-bit mode when support for vgic-v3 is done.
So we can reuse the code under arch/arm
Currently GIC backend is selected via alternative framework and this
is fine. We are going to introduce vgic-v3 to 32-bit world and there
we don't have patching framework in hand, so we can either check
support for GICv3 every time we need to choose which backend to use or
try to optimise it by using static keys. The later looks quite
promising because we can share logic involved in selecting GIC backend
between architectures if both uses static keys.
This patch moves arm64 from alternative to static keys framework for
selecting GIC backend. For that we embed static key into vgic_global
and enable the key during vgic initialisation based on what has
already been exposed by the host GIC driver.
This commit adds the ability for archs to export
per-vcpu information via a new per-vcpu dir in
the VM's debugfs directory.
If kvm_arch_has_vcpu_debugfs() returns true, then KVM
will create a vcpu dir for each vCPU in the VM's
debugfs directory. Then kvm_arch_create_vcpu_debugfs()
is responsible for populating each vcpu directory
with arch specific entries.
The per-vcpu path in debugfs will look like:
/sys/kernel/debug/kvm/29162-10/vcpu0
/sys/kernel/debug/kvm/29162-10/vcpu1
This is all arch specific for now because the only
user of this interface (x86) wants to export x86-specific
per-vcpu information to user-space.
Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com>
This make it possible to call kvm_destroy_vm_debugfs() from
kvm_create_vm_debugfs() in error conditions.
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc into HEAD
Paul Mackerras writes:
The highlights are:
* Reduced latency for interrupts from PCI pass-through devices, from
Suresh Warrier and me.
* Halt-polling implementation from Suraj Jitindar Singh.
* 64-bit VCPU statistics, also from Suraj.
* Various other minor fixes and improvements.
