[ Upstream commit 4839ddc27b7212ec58874f62c97da7400c8523be ]
Commit fd1d0ddf2ae9 (KVM: arm/arm64: check IRQ number on userland
injection) rightly limited the range of interrupts userspace can
inject in a guest, but failed to consider the (unlikely) case where
a guest is configured with 1024 interrupts.
In this case, interrupts ranging from 1020 to 1023 are unuseable,
as they have a special meaning for the GIC CPU interface.
Make sure that these number cannot be used as an IRQ. Also delete
a redundant (and similarily buggy) check in kvm_set_irq.
Reported-by: Peter Maydell <peter.maydell@linaro.org>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: <stable@vger.kernel.org> # 4.1, 4.0, 3.19, 3.18
[ Upstream commit fd1d0ddf2ae92fb3df42ed476939861806c5d785 ]
When userland injects a SPI via the KVM_IRQ_LINE ioctl we currently
only check it against a fixed limit, which historically is set
to 127. With the new dynamic IRQ allocation the effective limit may
actually be smaller (64).
So when now a malicious or buggy userland injects a SPI in that
range, we spill over on our VGIC bitmaps and bytemaps memory.
I could trigger a host kernel NULL pointer dereference with current
mainline by injecting some bogus IRQ number from a hacked kvmtool:
DEBUG: kvm_vgic_inject_irq(kvm, cpu=0, irq=114, level=1)
DEBUG: vgic_update_irq_pending(kvm, cpu=0, irq=114, level=1)
DEBUG: IRQ #114 still in the game, writing to bytemap now...
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = ffffffc07652e000
[00000000] *pgd=00000000f658b003, *pud=00000000f658b003, *pmd=0000000000000000
Internal error: Oops: 96000006 [#1] PREEMPT SMP
Modules linked in:
CPU: 1 PID: 1053 Comm: lkvm-msi-irqinj Not tainted 4.0.0-rc7+ #3027
Hardware name: FVP Base (DT)
task: ffffffc0774e9680 ti: ffffffc0765a8000 task.ti: ffffffc0765a8000
PC is at kvm_vgic_inject_irq+0x234/0x310
LR is at kvm_vgic_inject_irq+0x30c/0x310
pc : [<ffffffc0000ae0a8>] lr : [<ffffffc0000ae180>] pstate: 80000145
So this patch fixes this by checking the SPI number against the
actual limit. Also we remove the former legacy hard limit of
127 in the ioctl code.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
CC: <stable@vger.kernel.org> # 4.0, 3.19, 3.18
[maz: wrap KVM_ARM_IRQ_GIC_MAX with #ifndef __KERNEL__,
as suggested by Christopher Covington]
[ Upstream commit ca3f0874723fad81d0c701b63ae3a17a408d5f25 ]
kvm_write_guest_cached() does not mark all written pages as dirty and
code comments in kvm_gfn_to_hva_cache_init() talk about NULL memslot
with cross page accesses. Fix all the easy way.
The check is '<= 1' to have the same result for 'len = 0' cache anywhere
in the page. (nr_pages_needed is 0 on page boundary.)
Fixes: 8f964525a121 ("KVM: Allow cross page reads and writes from cached translations.")
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Message-Id: <20150408121648.GA3519@potion.brq.redhat.com>
Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com>
commit ae705930fca6322600690df9dc1c7d0516145a93 upstream.
There is an interesting bug in the vgic code, which manifests itself
when the KVM run loop has a signal pending or needs a vmid generation
rollover after having disabled interrupts but before actually switching
to the guest.
In this case, we flush the vgic as usual, but we sync back the vgic
state and exit to userspace before entering the guest. The consequence
is that we will be syncing the list registers back to the software model
using the GICH_ELRSR and GICH_EISR from the last execution of the guest,
potentially overwriting a list register containing an interrupt.
This showed up during migration testing where we would capture a state
where the VM has masked the arch timer but there were no interrupts,
resulting in a hung test.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Reported-by: Alex Bennee <alex.bennee@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
commit 66b030e48af68fd4c22d343908bc057207a0a31e upstream.
To be more explicit on vgic initialization failure, -ENODEV is
returned by vgic_init when no online vcpus can be found at init.
Signed-off-by: Eric Auger <eric.auger@linaro.org>
commit 05971120fca43e0357789a14b3386bb56eef2201 upstream.
It is curently possible to run a VM with architected timers support
without creating an in-kernel VGIC, which will result in interrupts from
the virtual timer going nowhere.
To address this issue, move the architected timers initialization to the
time when we run a VCPU for the first time, and then only initialize
(and enable) the architected timers if we have a properly created and
initialized in-kernel VGIC.
When injecting interrupts from the virtual timer to the vgic, the
current setup should ensure that this never calls an on-demand init of
the VGIC, which is the only call path that could return an error from
kvm_vgic_inject_irq(), so capture the return value and raise a warning
if there's an error there.
We also change the kvm_timer_init() function from returning an int to be
a void function, since the function always succeeds.
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
commit ca7d9c829d419c06e450afa5f785d58198c37caa upstream.
Userspace assumes that it can wire up IRQ injections after having
created all VCPUs and after having created the VGIC, but potentially
before starting the first VCPU. This can currently lead to lost IRQs
because the state of that IRQ injection is not stored anywhere and we
don't return an error to userspace.
We haven't seen this problem manifest itself yet, presumably because
guests reset the devices on boot, but this could cause issues with
migration and other non-standard startup configurations.
commit 016ed39c54b8a3db680e5c6a43419f806133caf2 upstream.
When call kvm_vgic_inject_irq to inject interrupt, we can known which
vcpu the interrupt for by the irq_num and the cpuid. So we should just
kick this vcpu to avoid iterating through all.
Signed-off-by: Shannon Zhao <zhaoshenglong@huawei.com>
commit 6d3cfbe21bef5b66530b50ad16c88fdc71a04c35 upstream.
VGIC initialization currently happens in three phases:
(1) kvm_vgic_create() (triggered by userspace GIC creation)
(2) vgic_init_maps() (triggered by userspace GIC register read/write
requests, or from kvm_vgic_init() if not already run)
(3) kvm_vgic_init() (triggered by first VM run)
We were doing initialization of some state to correspond with the
state of a freshly-reset GIC in kvm_vgic_init(); this is too late,
since it will overwrite changes made by userspace using the
register access APIs before the VM is run. Move this initialization
earlier, into the vgic_init_maps() phase.
This fixes a bug where QEMU could successfully restore a saved
VM state snapshot into a VM that had already been run, but could
not restore it "from cold" using the -loadvm command line option
(the symptoms being that the restored VM would run but interrupts
were ignored).
Finally rename vgic_init_maps to vgic_init and renamed kvm_vgic_init to
kvm_vgic_map_resources.
[ This patch is originally written by Peter Maydell, but I have
modified it somewhat heavily, renaming various bits and moving code
around. If something is broken, I am to be blamed. - Christoffer ]
Reviewed-by: Eric Auger <eric.auger@linaro.org>
Signed-off-by: Peter Maydell <peter.maydell@linaro.org>
[ Upstream commit 744961341d472db6272ed9b42319a90f5a2aa7c4 ]
KVM guest can fail to startup with following trace on host:
qemu-system-x86: page allocation failure: order:4, mode:0x40d0
Call Trace:
dump_stack+0x47/0x67
warn_alloc_failed+0xee/0x150
__alloc_pages_direct_compact+0x14a/0x150
__alloc_pages_nodemask+0x776/0xb80
alloc_kmem_pages+0x3a/0x110
kmalloc_order+0x13/0x50
kmemdup+0x1b/0x40
__kvm_set_memory_region+0x24a/0x9f0 [kvm]
kvm_set_ioapic+0x130/0x130 [kvm]
kvm_set_memory_region+0x21/0x40 [kvm]
kvm_vm_ioctl+0x43f/0x750 [kvm]
Failure happens when attempting to allocate pages for
'struct kvm_memslots', however it doesn't have to be
present in physically contiguous (kmalloc-ed) address
space, change allocation to kvm_kvzalloc() so that
it will be vmalloc-ed when its size is more then a page.
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
[ Upstream commit dc9be0fac70a2ad86e31a81372bb0bdfb6945353 ]
POWER supports irqfds but forgot to advertise them. Some userspace does
not check for the capability, but others check it---thus they work on
x86 and s390 but not POWER.
To avoid that other architectures in the future make the same mistake, let
common code handle KVM_CAP_IRQFD the same way as KVM_CAP_IRQFD_RESAMPLE.
Reported-and-tested-by: Greg Kurz <gkurz@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org
Fixes: 297e21053a52f060944e9f0de4c64fad9bcd72fc
This reverts commit 85c8555ff0 ("KVM: check for !is_zero_pfn() in
kvm_is_mmio_pfn()") and renames the function to kvm_is_reserved_pfn.
The problem being addressed by the patch above was that some ARM code
based the memory mapping attributes of a pfn on the return value of
kvm_is_mmio_pfn(), whose name indeed suggests that such pfns should
be mapped as device memory.
However, kvm_is_mmio_pfn() doesn't do quite what it says on the tin,
and the existing non-ARM users were already using it in a way which
suggests that its name should probably have been 'kvm_is_reserved_pfn'
from the beginning, e.g., whether or not to call get_page/put_page on
it etc. This means that returning false for the zero page is a mistake
and the patch above should be reverted.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
If we detect another vCPU is running we just exit and return 0 as if we
succesfully created the VGIC, but the VGIC wouldn't actual be created.
This shouldn't break in-kernel behavior because the kernel will not
observe the failed the attempt to create the VGIC, but userspace could
be rightfully confused.
After commit 80ce163 (KVM: VFIO: register kvm_device_ops dynamically),
kvm_device_ops of vfio can be registered dynamically. Commit 3c3c29fd
(kvm-vfio: do not use module_init) move the dynamic register invoked by
kvm_init in order to fix broke unloading of the kvm module. However,
kvm_device_ops of vfio is unregistered after rmmod kvm-intel module
which lead to device type collision detection warning after kvm-intel
module reinsmod.
WARNING: CPU: 1 PID: 10358 at /root/cathy/kvm/arch/x86/kvm/../../../virt/kvm/kvm_main.c:3289 kvm_init+0x234/0x282 [kvm]()
Modules linked in: kvm_intel(O+) kvm(O) nfsv3 nfs_acl auth_rpcgss oid_registry nfsv4 dns_resolver nfs fscache lockd sunrpc pci_stub bridge stp llc autofs4 8021q cpufreq_ondemand ipv6 joydev microcode pcspkr igb i2c_algo_bit ehci_pci ehci_hcd e1000e i2c_i801 ixgbe ptp pps_core hwmon mdio tpm_tis tpm ipmi_si ipmi_msghandler acpi_cpufreq isci libsas scsi_transport_sas button dm_mirror dm_region_hash dm_log dm_mod [last unloaded: kvm_intel]
CPU: 1 PID: 10358 Comm: insmod Tainted: G W O 3.17.0-rc1 #2
Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013
0000000000000cd9 ffff880ff08cfd18 ffffffff814a61d9 0000000000000cd9
0000000000000000 ffff880ff08cfd58 ffffffff810417b7 ffff880ff08cfd48
ffffffffa045bcac ffffffffa049c420 0000000000000040 00000000000000ff
Call Trace:
[<ffffffff814a61d9>] dump_stack+0x49/0x60
[<ffffffff810417b7>] warn_slowpath_common+0x7c/0x96
[<ffffffffa045bcac>] ? kvm_init+0x234/0x282 [kvm]
[<ffffffff810417e6>] warn_slowpath_null+0x15/0x17
[<ffffffffa045bcac>] kvm_init+0x234/0x282 [kvm]
[<ffffffffa016e995>] vmx_init+0x1bf/0x42a [kvm_intel]
[<ffffffffa016e7d6>] ? vmx_check_processor_compat+0x64/0x64 [kvm_intel]
[<ffffffff810002ab>] do_one_initcall+0xe3/0x170
[<ffffffff811168a9>] ? __vunmap+0xad/0xb8
[<ffffffff8109c58f>] do_init_module+0x2b/0x174
[<ffffffff8109d414>] load_module+0x43e/0x569
[<ffffffff8109c6d8>] ? do_init_module+0x174/0x174
[<ffffffff8109c75a>] ? copy_module_from_user+0x39/0x82
[<ffffffff8109b7dd>] ? module_sect_show+0x20/0x20
[<ffffffff8109d65f>] SyS_init_module+0x54/0x81
[<ffffffff814a9a12>] system_call_fastpath+0x16/0x1b
---[ end trace 0626f4a3ddea56f3 ]---
The bug can be reproduced by:
rmmod kvm_intel.ko
insmod kvm_intel.ko
without rmmod/insmod kvm.ko
This patch fixes the bug by unregistering kvm_device_ops of vfio when the
kvm-intel module is removed.
Reported-by: Liu Rongrong <rongrongx.liu@intel.com>
Fixes: 3c3c29fd0d7cddc32862c350d0700ce69953e3bd
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
The third parameter of kvm_unpin_pages() when called from
kvm_iommu_map_pages() is wrong, it should be the number of pages to un-pin
and not the page size.
This error was facilitated with an inconsistent API: kvm_pin_pages() takes
a size, but kvn_unpin_pages() takes a number of pages, so fix the problem
by matching the two.
This was introduced by commit 350b8bd ("kvm: iommu: fix the third parameter
of kvm_iommu_put_pages (CVE-2014-3601)"), which fixes the lack of
un-pinning for pages intended to be un-pinned (i.e. memory leak) but
unfortunately potentially aggravated the number of pages we un-pin that
should have stayed pinned. As far as I understand though, the same
practical mitigations apply.
This issue was found during review of Red Hat 6.6 patches to prepare
Ksplice rebootless updates.
Thanks to Vegard for his time on a late Friday evening to help me in
understanding this code.
Fixes: 350b8bd ("kvm: iommu: fix the third parameter of... (CVE-2014-3601)")
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Reviewed-by: Sasha Levin <sasha.levin@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm
Pull second batch of changes for KVM/{arm,arm64} from Marc Zyngier:
"The most obvious thing is the sizeable MMU changes to support 48bit
VAs on arm64.
Summary:
- support for 48bit IPA and VA (EL2)
- a number of fixes for devices mapped into guests
- yet another VGIC fix for BE
- a fix for CPU hotplug
- a few compile fixes (disabled VGIC, strict mm checks)"
[ I'm pulling directly from Marc at the request of Paolo Bonzini, whose
backpack was stolen at Düsseldorf airport and will do new keys and
rebuild his web of trust. - Linus ]
* tag 'kvm-arm-for-3.18-take-2' of git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm:
arm/arm64: KVM: Fix BE accesses to GICv2 EISR and ELRSR regs
arm: kvm: STRICT_MM_TYPECHECKS fix for user_mem_abort
arm/arm64: KVM: Ensure memslots are within KVM_PHYS_SIZE
arm64: KVM: Implement 48 VA support for KVM EL2 and Stage-2
arm/arm64: KVM: map MMIO regions at creation time
arm64: kvm: define PAGE_S2_DEVICE as read-only by default
ARM: kvm: define PAGE_S2_DEVICE as read-only by default
arm/arm64: KVM: add 'writable' parameter to kvm_phys_addr_ioremap
arm/arm64: KVM: fix potential NULL dereference in user_mem_abort()
arm/arm64: KVM: use __GFP_ZERO not memset() to get zeroed pages
ARM: KVM: fix vgic-disabled build
arm: kvm: fix CPU hotplug
The EIRSR and ELRSR registers are 32-bit registers on GICv2, and we
store these as an array of two such registers on the vgic vcpu struct.
However, we access them as a single 64-bit value or as a bitmap pointer
in the generic vgic code, which breaks BE support.
Instead, store them as u64 values on the vgic structure and do the
word-swapping in the assembly code, which already handles the byte order
for BE systems.
Tested-by: Victor Kamensky <victor.kamensky@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
"This pull-request includes:
- change in the IOMMU-API to convert the former iommu_domain_capable
function to just iommu_capable
- various fixes in handling RMRR ranges for the VT-d driver (one fix
requires a device driver core change which was acked by Greg KH)
- the AMD IOMMU driver now assigns and deassigns complete alias
groups to fix issues with devices using the wrong PCI request-id
- MMU-401 support for the ARM SMMU driver
- multi-master IOMMU group support for the ARM SMMU driver
- various other small fixes all over the place"
* tag 'iommu-updates-v3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (41 commits)
iommu/vt-d: Work around broken RMRR firmware entries
iommu/vt-d: Store bus information in RMRR PCI device path
iommu/vt-d: Only remove domain when device is removed
driver core: Add BUS_NOTIFY_REMOVED_DEVICE event
iommu/amd: Fix devid mapping for ivrs_ioapic override
iommu/irq_remapping: Fix the regression of hpet irq remapping
iommu: Fix bus notifier breakage
iommu/amd: Split init_iommu_group() from iommu_init_device()
iommu: Rework iommu_group_get_for_pci_dev()
iommu: Make of_device_id array const
amd_iommu: do not dereference a NULL pointer address.
iommu/omap: Remove omap_iommu unused owner field
iommu: Remove iommu_domain_has_cap() API function
IB/usnic: Convert to use new iommu_capable() API function
vfio: Convert to use new iommu_capable() API function
kvm: iommu: Convert to use new iommu_capable() API function
iommu/tegra: Convert to iommu_capable() API function
iommu/msm: Convert to iommu_capable() API function
iommu/vt-d: Convert to iommu_capable() API function
iommu/fsl: Convert to iommu_capable() API function
Add support for read-only MMIO passthrough mappings by adding a
'writable' parameter to kvm_phys_addr_ioremap. For the moment,
mappings will be read-write even if 'writable' is false, but once
the definition of PAGE_S2_DEVICE gets changed, those mappings will
be created read-only.
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"The interesting things here are:
- Turn on Config Request Retry Status Software Visibility. This
caused hangs last time, but we included a fix this time.
- Rework PCI device configuration to use _HPP/_HPX more aggressively
- Allow PCI devices to be put into D3cold during system suspend
- Add arm64 PCI support
- Add APM X-Gene host bridge driver
- Add TI Keystone host bridge driver
- Add Xilinx AXI host bridge driver
More detailed summary:
Enumeration
- Check Vendor ID only for Config Request Retry Status (Rajat Jain)
- Enable Config Request Retry Status when supported (Rajat Jain)
- Add generic domain handling (Catalin Marinas)
- Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado)
Resource management
- Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu)
- Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr)
PCI device hotplug
- Prevent NULL dereference during pciehp probe (Andreas Noever)
- Move _HPP & _HPX handling into core (Bjorn Helgaas)
- Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas)
- Apply _HPP/_HPX to display devices (Bjorn Helgaas)
- Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas)
- Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas)
- Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas)
- Fix wait time in pciehp timeout message (Yinghai Lu)
- Add more pciehp Slot Control debug output (Yinghai Lu)
- Stop disabling pciehp notifications during init (Yinghai Lu)
MSI
- Remove arch_msi_check_device() (Alexander Gordeev)
- Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev)
- Move D0 check into pci_msi_check_device() (Alexander Gordeev)
- Remove unused kobject from struct msi_desc (Yijing Wang)
- Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang)
- Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang)
- Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang)
- Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang)
- Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang)
Power management
- Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki)
- Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki)
AER
- Add additional AER error strings (Gong Chen)
- Make <linux/aer.h> standalone includable (Thierry Reding)
Virtualization
- Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson)
- Add ACS quirk for Intel 10G NICs (Alex Williamson)
- Add ACS quirk for AMD A88X southbridge (Marti Raudsepp)
- Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson)
- Add device flag helpers (Ethan Zhao)
- Assume all Mellanox devices have broken INTx masking (Gavin Shan)
Generic host bridge driver
- Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau)
- Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau)
- Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau)
- Fix the conversion of IO ranges into IO resources (Liviu Dudau)
- Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau)
- Add support for parsing PCI host bridge resources from DT (Liviu Dudau)
- Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau)
- Add arm64 architectural support for PCI (Liviu Dudau)
APM X-Gene
- Add APM X-Gene PCIe driver (Tanmay Inamdar)
- Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar)
Freescale i.MX6
- Probe in module_init(), not fs_initcall() (Lucas Stach)
- Delay enabling reference clock for SS until it stabilizes (Tim Harvey)
Marvell MVEBU
- Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni)
NVIDIA Tegra
- Make sure the PCIe PLL is really reset (Eric Yuen)
- Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang)
- Fix extended configuration space mapping (Peter Daifuku)
- Implement resource hierarchy (Thierry Reding)
- Clear CLKREQ# enable on port disable (Thierry Reding)
- Add Tegra124 support (Thierry Reding)
ST Microelectronics SPEAr13xx
- Pass config resource through reg property (Pratyush Anand)
Synopsys DesignWare
- Use NULL instead of false (Fabio Estevam)
- Parse bus-range property from devicetree (Lucas Stach)
- Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach)
- Remove pci_assign_unassigned_resources() (Lucas Stach)
- Check private_data validity in single place (Lucas Stach)
- Setup and clear exactly one MSI at a time (Lucas Stach)
- Remove open-coded bitmap operations (Lucas Stach)
- Fix configuration base address when using 'reg' (Minghuan Lian)
- Fix IO resource end address calculation (Minghuan Lian)
- Rename get_msi_data() to get_msi_addr() (Minghuan Lian)
- Add get_msi_data() to pcie_host_ops (Minghuan Lian)
- Add support for v3.65 hardware (Murali Karicheri)
- Fold struct pcie_port_info into struct pcie_port (Pratyush Anand)
TI Keystone
- Add TI Keystone PCIe driver (Murali Karicheri)
- Limit MRSS for all downstream devices (Murali Karicheri)
- Assume controller is already in RC mode (Murali Karicheri)
- Set device ID based on SoC to support multiple ports (Murali Karicheri)
Xilinx AXI
- Add Xilinx AXI PCIe driver (Srikanth Thokala)
- Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter)
Miscellaneous
- Clean up whitespace (Quentin Lambert)
- Remove assignments from "if" conditions (Quentin Lambert)
- Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri)
- x86: Mark DMI tables as initialization data (Mathias Krause)
- x86: Move __init annotation to the correct place (Mathias Krause)
- x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause)
- x86: Constify pci_mmcfg_probes[] array (Mathias Krause)
- x86: Mark PCI BIOS initialization code as such (Mathias Krause)
- Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya)
- Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)"
* tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits)
arm64: dts: Add APM X-Gene PCIe device tree nodes
PCI: Add ACS quirk for AMD A88X southbridge devices
PCI: xgene: Add APM X-Gene PCIe driver
PCI: designware: Remove open-coded bitmap operations
PCI/MSI: Remove unnecessary temporary variable
PCI/MSI: Use __write_msi_msg() instead of write_msi_msg()
MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg()
PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg()
PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints
PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib
PCI/MSI: Remove unused kobject from struct msi_desc
PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported()
PCI/MSI: Move D0 check into pci_msi_check_device()
PCI/MSI: Remove arch_msi_check_device()
irqchip: armada-370-xp: Remove arch_msi_check_device()
PCI/MSI/PPC: Remove arch_msi_check_device()
arm64: Add architectural support for PCI
PCI: Add pci_remap_iospace() to map bus I/O resources
of/pci: Add support for parsing PCI host bridge resources from DT
of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr()
arch/arm64/boot/dts/apm-storm.dtsi
Pull KVM updates from Paolo Bonzini:
"Fixes and features for 3.18.
Apart from the usual cleanups, here is the summary of new features:
- s390 moves closer towards host large page support
- PowerPC has improved support for debugging (both inside the guest
and via gdbstub) and support for e6500 processors
- ARM/ARM64 support read-only memory (which is necessary to put
firmware in emulated NOR flash)
- x86 has the usual emulator fixes and nested virtualization
improvements (including improved Windows support on Intel and
Jailhouse hypervisor support on AMD), adaptive PLE which helps
overcommitting of huge guests. Also included are some patches that
make KVM more friendly to memory hot-unplug, and fixes for rare
caching bugs.
Two patches have trivial mm/ parts that were acked by Rik and Andrew.
Note: I will soon switch to a subkey for signing purposes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits)
kvm: do not handle APIC access page if in-kernel irqchip is not in use
KVM: s390: count vcpu wakeups in stat.halt_wakeup
KVM: s390/facilities: allow TOD-CLOCK steering facility bit
KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode
arm/arm64: KVM: Report correct FSC for unsupported fault types
arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc
kvm: Fix kvm_get_page_retry_io __gup retval check
arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset
kvm: x86: Unpin and remove kvm_arch->apic_access_page
kvm: vmx: Implement set_apic_access_page_addr
kvm: x86: Add request bit to reload APIC access page address
kvm: Add arch specific mmu notifier for page invalidation
kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static
kvm: Fix page ageing bugs
kvm/x86/mmu: Pass gfn and level to rmapp callback.
x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only
kvm: x86: use macros to compute bank MSRs
KVM: x86: Remove debug assertion of non-PAE reserved bits
kvm: don't take vcpu mutex for obviously invalid vcpu ioctls
kvm: Faults which trigger IO release the mmap_sem
and 'core' into next
drivers/iommu/arm-smmu.c
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-next
Changes for KVM for arm/arm64 for 3.18
This includes a bunch of changes:
- Support read-only memory slots on arm/arm64
- Various changes to fix Sparse warnings
- Correctly detect write vs. read Stage-2 faults
- Various VGIC cleanups and fixes
- Dynamic VGIC data strcuture sizing
- Fix SGI set_clear_pend offset bug
- Fix VTTBR_BADDR Mask
- Correctly report the FSC on Stage-2 faults
virt/kvm/eventfd.c
[duplicate, different patch where the kvm-arm version broke x86.
The kvm tree instead has the right one]
Confusion around -EBUSY and zero (inside a BUG_ON no less).
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
Signed-off-by: Andres Lagar-Cavilla <andreslc@google.com>
The sgi values calculated in read_set_clear_sgi_pend_reg() and
write_set_clear_sgi_pend_reg() were horribly incorrectly multiplied by 4
with catastrophic results in that subfunctions ended up overwriting
memory not allocated for the expected purpose.
This showed up as bugs in kfree() and the kernel complaining a lot of
you turn on memory debugging.
This addresses: http://marc.info/?l=kvm&m=141164910007868&w=2
Reported-by: Shannon Zhao <zhaoshenglong@huawei.com>
Cc: Gleb Natapov <gleb@kernel.org>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
This will be used to let the guest run while the APIC access page is
not pinned. Because subsequent patches will fill in the function
for x86, place the (still empty) x86 implementation in the x86.c file
instead of adding an inline function in kvm_host.h.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
it non-static
Different architectures need different requests, and in fact we
will use this function in architecture-specific code later. This
will be outside kvm_main.c, so make it non-static and rename it to
kvm_make_all_cpus_request().
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
1. We were calling clear_flush_young_notify in unmap_one, but we are
within an mmu notifier invalidate range scope. The spte exists no more
(due to range_start) and the accessed bit info has already been
propagated (due to kvm_pfn_set_accessed). Simply call
clear_flush_young.
2. We clear_flush_young on a primary MMU PMD, but this may be mapped
as a collection of PTEs by the secondary MMU (e.g. during log-dirty).
This required expanding the interface of the clear_flush_young mmu
notifier, so a lot of code has been trivially touched.
3. In the absence of shadow_accessed_mask (e.g. EPT A bit), we emulate
the access bit by blowing the spte. This requires proper synchronizing
with MMU notifier consumers, like every other removal of spte's does.
vcpu ioctls can hang the calling thread if issued while a vcpu is running.
However, invalid ioctls can happen when userspace tries to probe the kind
of file descriptors (e.g. isatty() calls ioctl(TCGETS)); in that case,
we know the ioctl is going to be rejected as invalid anyway and we can
fail before trying to take the vcpu mutex.
This patch does not change functionality, it just makes invalid ioctls
fail faster.
Signed-off-by: David Matlack <dmatlack@google.com>
When KVM handles a tdp fault it uses FOLL_NOWAIT. If the guest memory
has been swapped out or is behind a filemap, this will trigger async
readahead and return immediately. The rationale is that KVM will kick
back the guest with an "async page fault" and allow for some other
guest process to take over.
If async PFs are enabled the fault is retried asap from an async
workqueue. If not, it's retried immediately in the same code path. In
either case the retry will not relinquish the mmap semaphore and will
block on the IO. This is a bad thing, as other mmap semaphore users
now stall as a function of swap or filemap latency.
This patch ensures both the regular and async PF path re-enter the
fault allowing for the mmap semaphore to be relinquished in the case
of IO wait.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
/me got confused between the kernel and QEMU. In the kernel, you can
only have one module_init function, and it will prevent unloading the
module unless you also have the corresponding module_exit function.
So, commit 80ce1639727e (KVM: VFIO: register kvm_device_ops dynamically,
2014-09-02) broke unloading of the kvm module, by adding a module_init
function and no module_exit.
Repair it by making kvm_vfio_ops_init weak, and checking it in
kvm_init.
Cc: Alex Williamson <Alex.Williamson@redhat.com>
Fixes: 80ce1639727e9d38729c34f162378508c307ca25
Commit c77dcac (KVM: Move more code under CONFIG_HAVE_KVM_IRQFD) added
functionality that depends on definitions in ioapic.h when
__KVM_HAVE_IOAPIC is defined.
At the same time, kvm-arm commit 0ba0951 (KVM: EVENTFD: remove inclusion
of irq.h) removed the inclusion of irq.h, an architecture-specific header
that is not present on ARM but which happened to include ioapic.h on x86.
Include ioapic.h directly in eventfd.c if __KVM_HAVE_IOAPIC is defined.
This fixes x86 and lets ARM use eventfd.c.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
Fixes unaligned access to the gicv2 virtual cpu status.
We were using an atomic bitop on the vgic_v2.vgic_elrsr field which was
not aligned to the natural size on 64-bit platforms. This bug showed up
after QEMU correctly identifies the pl011 line as being level-triggered,
and not edge-triggered.
These data structures are protected by a spinlock so simply use a
non-atomic version of the accessor instead.
Tested-by: Joel Schopp <joel.schopp@amd.com>
Reported-by: Riku Voipio <riku.voipio@linaro.org>
Correct a simple mistake of checking the wrong variable
before a dereference, resulting in the dereference not being
properly protected by rcu_dereference().
Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com>
In order to make the number of interrupts configurable, use the new
fancy device management API to add KVM_DEV_ARM_VGIC_GRP_NR_IRQS as
a VGIC configurable attribute.
Userspace can now specify the exact size of the GIC (by increments
of 32 interrupts).
It is now quite easy to delay the allocation of the vgic tables
until we actually require it to be up and running (when the first
vcpu is kicking around, or someones tries to access the GIC registers).
This allow us to allocate memory for the exact number of CPUs we
have. As nobody configures the number of interrupts just yet,
use a fallback to VGIC_NR_IRQS_LEGACY.
Nuke VGIC_NR_IRQS entierly, now that the distributor instance
contains the number of IRQ allocated to this GIC.
Also add VGIC_NR_IRQS_LEGACY to preserve the current API.
Now that we can (almost) dynamically size the number of interrupts,
we're facing an interesting issue:
We have to evaluate at runtime whether or not an access hits a valid
register, based on the sizing of this particular instance of the
distributor. Furthermore, the GIC spec says that accessing a reserved
register is RAZ/WI.
For this, add a new field to our range structure, indicating the number
of bits a single interrupts uses. That allows us to find out whether or
not the access is in range.
We now have the information about the number of CPU interfaces in
the distributor itself. Let's get rid of VGIC_MAX_CPUS, and just
rely on KVM_MAX_VCPUS where we don't have the choice. Yet.
Having a dynamic number of supported interrupts means that we
cannot relly on VGIC_NR_SHARED_IRQS being fixed anymore.
Instead, make it take the distributor structure as a parameter,
so it can return the right value.
So far, all the VGIC data structures are statically defined by the
*maximum* number of vcpus and interrupts it supports. It means that
we always have to oversize it to cater for the worse case.
Start by changing the data structures to be dynamically sizeable,
and allocate them at runtime.
The sizes are still very static though.
As it stands, nothing prevents userspace from injecting an interrupt
before the guest's GIC is actually initialized.
This goes unnoticed so far (as everything is pretty much statically
allocated), but ends up exploding in a spectacular way once we switch
to a more dynamic allocation (the GIC data structure isn't there yet).
The fix is to test for the "ready" flag in the VGIC distributor before
trying to inject the interrupt. Note that in order to avoid breaking
userspace, we have to ignore what is essentially an error.
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
The VGIC virtual distributor implementation documentation was written a
very long time ago, before the true nature of the beast had been
partially absorbed into my bloodstream. Clarify the docs.
Plus, it fixes an actual bug. ICFRn, pfff.
Writes to GICD_ISPENDR0 and GICD_ICPENDR0 ignore all settings of the
pending state for SGIs. Make sure the implementation handles this
correctly.
Writes to GICD_ISPENDRn and GICD_ICPENDRn are currently not handled
correctly for level-triggered interrupts. The spec states that for
level-triggered interrupts, writes to the GICD_ISPENDRn activate the
output of a flip-flop which is in turn or'ed with the actual input
interrupt signal. Correspondingly, writes to GICD_ICPENDRn simply
deactivates the output of that flip-flop, but does not (of course) affect
the external input signal. Reads from GICC_IAR will also deactivate the
flip-flop output.
This requires us to track the state of the level-input separately from
the state in the flip-flop. We therefore introduce two new variables on
the distributor struct to track these two states. Astute readers may
notice that this is introducing more state than required (because an OR
of the two states gives you the pending state), but the remaining vgic
code uses the pending bitmap for optimized operations to figure out, at
the end of the day, if an interrupt is pending or not on the distributor
side. Refactoring the code to consider the two state variables all the
places where we currently access the precomputed pending value, did not
look pretty.
If we unqueue a level-triggered interrupt completely, and the LR does
not stick around in the active state (and will therefore no longer
generate a maintenance interrupt), then we should clear the queued flag
so that the vgic can actually queue this level-triggered interrupt at a
later time and deal with its pending state then.
Note: This should actually be properly fixed to handle the active state
on the distributor.
We have a special bitmap on the distributor struct to keep track of when
level-triggered interrupts are queued on the list registers. This was
named irq_active, which is confusing, because the active state of an
interrupt as per the GIC spec is a different thing, not specifically
related to edge-triggered/level-triggered configurations but rather
indicates an interrupt which has been ack'ed but not yet eoi'ed.
Rename the bitmap and the corresponding accessor functions to irq_queued
to clarify what this is actually used for.
The irq_state field on the distributor struct is ambiguous in its
meaning; the comment says it's the level of the input put, but that
doesn't make much sense for edge-triggered interrupts. The code
actually uses this state variable to check if the interrupt is in the
pending state on the distributor so clarify the comment and rename the
actual variable and accessor methods.
