commit 5419369ed6bd4cf711fdda5e52a5999b940413f5 upstream.
Prior to memory slot sorting this loop compared all of the user memory
slots for overlap with new entries. With memory slot sorting, we're
just checking some number of entries in the array that may or may not
be user slots. Instead, walk all the slots with kvm_for_each_memslot,
which has the added benefit of terminating early when we hit the first
empty slot, and skip comparison to private slots.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Pull kvm fixes from Avi Kivity:
"KVM updates for 3.7-rc2"
* tag 'kvm-3.7-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM guest: exit idleness when handling KVM_PV_REASON_PAGE_NOT_PRESENT
KVM: apic: fix LDR calculation in x2apic mode
KVM: MMU: fix release noslot pfn
We can not directly call kvm_release_pfn_clean to release the pfn
since we can meet noslot pfn which is used to cache mmio info into
spte
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org
Signed-off-by: Avi Kivity <avi@redhat.com>
set_bit_le()
Now that we have defined generic set_bit_le() we do not need to use
test_and_set_bit_le() for atomically setting a bit.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Pull KVM updates from Avi Kivity:
"Highlights of the changes for this release include support for vfio
level triggered interrupts, improved big real mode support on older
Intels, a streamlines guest page table walker, guest APIC speedups,
PIO optimizations, better overcommit handling, and read-only memory."
* tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits)
KVM: s390: Fix vcpu_load handling in interrupt code
KVM: x86: Fix guest debug across vcpu INIT reset
KVM: Add resampling irqfds for level triggered interrupts
KVM: optimize apic interrupt delivery
KVM: MMU: Eliminate pointless temporary 'ac'
KVM: MMU: Avoid access/dirty update loop if all is well
KVM: MMU: Eliminate eperm temporary
KVM: MMU: Optimize is_last_gpte()
KVM: MMU: Simplify walk_addr_generic() loop
KVM: MMU: Optimize pte permission checks
KVM: MMU: Update accessed and dirty bits after guest pagetable walk
KVM: MMU: Move gpte_access() out of paging_tmpl.h
KVM: MMU: Optimize gpte_access() slightly
KVM: MMU: Push clean gpte write protection out of gpte_access()
KVM: clarify kvmclock documentation
KVM: make processes waiting on vcpu mutex killable
KVM: SVM: Make use of asm.h
KVM: VMX: Make use of asm.h
KVM: VMX: Make lto-friendly
KVM: x86: lapic: Clean up find_highest_vector() and count_vectors()
arch/s390/include/asm/processor.h
arch/x86/kvm/i8259.c
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
To emulate level triggered interrupts, add a resample option to
KVM_IRQFD. When specified, a new resamplefd is provided that notifies
the user when the irqchip has been resampled by the VM. This may, for
instance, indicate an EOI. Also in this mode, posting of an interrupt
through an irqfd only asserts the interrupt. On resampling, the
interrupt is automatically de-asserted prior to user notification.
This enables level triggered interrupts to be posted and re-enabled
from vfio with no userspace intervention.
All resampling irqfds can make use of a single irq source ID, so we
reserve a new one for this interface.
Most interrupt are delivered to only one vcpu. Use pre-build tables to
find interrupt destination instead of looping through all vcpus. In case
of logical mode loop only through vcpus in a logical cluster irq is sent
to.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
vcpu mutex can be held for unlimited time so
taking it with mutex_lock on an ioctl is wrong:
one process could be passed a vcpu fd and
call this ioctl on the vcpu used by another process,
it will then be unkillable until the owner exits.
Call mutex_lock_killable instead and return status.
Note: mutex_lock_interruptible would be even nicer,
but I am not sure all users are prepared to handle EINTR
from these ioctls. They might misinterpret it as an error.
Cleanup paths expect a vcpu that can't be used by
any userspace so this will always succeed - catch bugs
by calling BUG_ON.
Catch callers that don't check return state by adding
__must_check.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Other arches do not need this.
v2: fix incorrect deletion of mmio sptes on gpa move (noticed by Takuya)
PPC must flush all translations before the new memory slot
is visible.
Introducing kvm_arch_flush_shadow_memslot, to invalidate the
translations of a single memory slot.
The build error was caused by that builtin functions are calling
the functions implemented in modules. This error was introduced by
commit 4d8b81abc4 ("KVM: introduce readonly memslot").
The patch fixes the build error by moving function __gfn_to_hva_memslot()
from kvm_main.c to kvm_host.h and making that "inline" so that the
builtin function (kvmppc_h_enter) can use that.
Acked-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
KVM_SET_SIGNAL_MASK passed a NULL argument leaves the on stack signal
sets uninitialized. It then passes them through to
kvm_vcpu_ioctl_set_sigmask.
We should be passing a NULL in this case not translated garbage.
Signed-off-by: Alan Cox <alan@linux.intel.com>
In current code, if we map a readonly memory space from host to guest
and the page is not currently mapped in the host, we will get a fault
pfn and async is not allowed, then the vm will crash
We introduce readonly memory region to map ROM/ROMD to the guest, read access
is happy for readonly memslot, write access on readonly memslot will cause
KVM_EXIT_MMIO exit
Then, remove bad_hva and inline kvm_is_error_hva
In current code, we always map writable pfn for the read fault, in order
to support readonly memslot, we map writable pfn only if 'writable'
is not NULL
We do too many things in hva_to_pfn, this patch reorganize the code,
let it be better readable
This set of functions is only used to read data from host space, in the
later patch, we will only get a readonly hva in gfn_to_hva_read, and
the function name is a good hint to let gfn_to_hva_read to pair with
kvm_read_hva()/kvm_read_hva_atomic()
It can instead of hva_to_pfn_atomic
Check flags when memslot is registered from userspace as Avi's suggestion
flush[_delayed]_work_sync() are now spurious. Mark them deprecated
and convert all users to flush[_delayed]_work().
If you're cc'd and wondering what's going on: Now all workqueues are
non-reentrant and the regular flushes guarantee that the work item is
not pending or running on any CPU on return, so there's no reason to
use the sync flushes at all and they're going away.
This patch doesn't make any functional difference.
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Mattia Dongili <malattia@linux.it>
Cc: Kent Yoder <key@linux.vnet.ibm.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Karsten Keil <isdn@linux-pingi.de>
Cc: Bryan Wu <bryan.wu@canonical.com>
Cc: Alasdair Kergon <agk@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Cc: linux-wireless@vger.kernel.org
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Sangbeom Kim <sbkim73@samsung.com>
Cc: "James E.J. Bottomley" <James.Bottomley@HansenPartnership.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: Mark Fasheh <mfasheh@suse.com>
We validate irq pin number when routing is setup, so
code handling illegal irq # in pic and ioapic on each injection
is never called.
Drop it, replace with BUG_ON to catch out of bounds access bugs.
After commit a2766325cf9f9, the error page is replaced by the
error code, it need not be released anymore
[ The patch has been compiling tested for powerpc ]
After commit a2766325cf9f9, the error pfn is replaced by the
It is used to eliminate the overload of function call and cleanup
the code
These functions are exported and can not inline, move them
to kvm_host.h to eliminate the overload of function call
Then, remove get_bad_pfn
Then, get_hwpoison_pfn and is_hwpoison_pfn can be removed
After that, the exported and un-inline function, get_fault_pfn,
can be removed
There are two bugs:
- the 'error page' is forgot to be released
[ it is unneeded after commit a2766325cf9f9, for backport, we
still do kvm_release_pfn_clean for the error pfn ]
- guest pages are always released regardless of the unmapped page
(e,g, caused by hwpoison)
Two reasons:
- x86 can integrate rmap and rmap_pde and remove heuristics in
__gfn_to_rmap().
- Some architectures do not need rmap.
Since rmap is one of the most memory consuming stuff in KVM, ppc'd
better restrict the allocation to Book3S HV.
Handle KVM_IRQ_LINE and KVM_IRQ_LINE_STATUS in the generic
kvm_vm_ioctl() function and call into kvm_vm_ioctl_irq_line().
This is even more relevant when KVM/ARM also uses this ioctl.
Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
Currently, kvm allocates some pages and use them as error indicators,
it wastes memory and is not good for scalability
Base on Avi's suggestion, we use the error codes instead of these pages
to indicate the error conditions
In kvm_async_pf_wakeup_all, it uses bad_page to generate broadcast wakeup,
and uses put_page to release bad_page, the work depends on the fact that
bad_page is the normal page. But we will use the error code instead of
bad_page, so use kvm_release_page_clean to release the page which will
release the error code properly
Merge patches queued during the run-up to the merge window.
* queue: (25 commits)
KVM: Choose better candidate for directed yield
KVM: Note down when cpu relax intercepted or pause loop exited
KVM: Add config to support ple or cpu relax optimzation
KVM: switch to symbolic name for irq_states size
KVM: x86: Fix typos in pmu.c
KVM: x86: Fix typos in lapic.c
KVM: x86: Fix typos in cpuid.c
KVM: x86: Fix typos in emulate.c
KVM: x86: Fix typos in x86.c
KVM: SVM: Fix typos
KVM: VMX: Fix typos
KVM: remove the unused parameter of gfn_to_pfn_memslot
KVM: remove is_error_hpa
KVM: make bad_pfn static to kvm_main.c
KVM: using get_fault_pfn to get the fault pfn
KVM: MMU: track the refcount when unmap the page
KVM: x86: remove unnecessary mark_page_dirty
KVM: MMU: Avoid handling same rmap_pde in kvm_handle_hva_range()
KVM: MMU: Push trace_kvm_age_page() into kvm_age_rmapp()
KVM: MMU: Add memslot parameter to hva handlers
"Highlights include
- full big real mode emulation on pre-Westmere Intel hosts (can be
disabled with emulate_invalid_guest_state=0)
- relatively small ppc and s390 updates
- PCID/INVPCID support in guests
- EOI avoidance; 3.6 guests should perform better on 3.6 hosts on
interrupt intensive workloads)
- Lockless write faults during live migration
- EPT accessed/dirty bits support for new Intel processors"
Fix up conflicts in:
- Documentation/virtual/kvm/api.txt:
Stupid subchapter numbering, added next to each other.
- arch/powerpc/kvm/booke_interrupts.S:
PPC asm changes clashing with the KVM fixes
- arch/s390/include/asm/sigp.h, arch/s390/kvm/sigp.c:
Duplicated commits through the kvm tree and the s390 tree, with
subsequent edits in the KVM tree.
* tag 'kvm-3.6-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (93 commits)
KVM: fix race with level interrupts
x86, hyper: fix build with !CONFIG_KVM_GUEST
Revert "apic: fix kvm build on UP without IOAPIC"
KVM guest: switch to apic_set_eoi_write, apic_write
apic: add apic_set_eoi_write for PV use
KVM: VMX: Implement PCID/INVPCID for guests with EPT
KVM: Add x86_hyper_kvm to complete detect_hypervisor_platform check
KVM: PPC: Critical interrupt emulation support
KVM: PPC: e500mc: Fix tlbilx emulation for 64-bit guests
KVM: PPC64: booke: Set interrupt computation mode for 64-bit host
KVM: PPC: bookehv: Add ESR flag to Data Storage Interrupt
KVM: PPC: bookehv64: Add support for std/ld emulation.
booke: Added crit/mc exception handler for e500v2
booke/bookehv: Add host crit-watchdog exception support
KVM: MMU: document mmu-lock and fast page fault
KVM: MMU: fix kvm_mmu_pagetable_walk tracepoint
KVM: MMU: trace fast page fault
KVM: MMU: fast path of handling guest page fault
KVM: MMU: introduce SPTE_MMU_WRITEABLE bit
KVM: MMU: fold tlb flush judgement into mmu_spte_update
Currently, on a large vcpu guests, there is a high probability of
yielding to the same vcpu who had recently done a pause-loop exit or
cpu relax intercepted. Such a yield can lead to the vcpu spinning
again and hence degrade the performance.
The patchset keeps track of the pause loop exit/cpu relax interception
and gives chance to a vcpu which:
(a) Has not done pause loop exit or cpu relax intercepted at all
(probably he is preempted lock-holder)
(b) Was skipped in last iteration because it did pause loop exit or
cpu relax intercepted, and probably has become eligible now
(next eligible lock holder)
Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> # on s390x
Noting pause loop exited vcpu or cpu relax intercepted helps in
filtering right candidate to yield. Wrong selection of vcpu;
i.e., a vcpu that just did a pl-exit or cpu relax intercepted may
contribute to performance degradation.
Suggested-by: Avi Kivity <avi@redhat.com>
Use PIC_NUM_PINS instead of hard-coded 16 for pic pins.
When more than 1 source id is in use for the same GSI, we have the
following race related to handling irq_states race:
CPU 0 clears bit 0. CPU 0 read irq_state as 0. CPU 1 sets level to 1.
CPU 1 calls kvm_ioapic_set_irq(1). CPU 0 calls kvm_ioapic_set_irq(0).
Now ioapic thinks the level is 0 but irq_state is not 0.
Fix by performing all irq_states bitmap handling under pic/ioapic lock.
This also removes the need for atomics with irq_states handling.
Reported-by: Gleb Natapov <gleb@redhat.com>
The parameter, 'kvm', is not used in gfn_to_pfn_memslot, we can happily remove
it
bad_pfn is not used out of kvm_main.c, so mark it static, also move it near
hwpoison_pfn and fault_pfn
Using get_fault_pfn to cleanup the code
kvm_mmu_notifier_invalidate_range_start()
When we tested KVM under memory pressure, with THP enabled on the host,
we noticed that MMU notifier took a long time to invalidate huge pages.
Since the invalidation was done with mmu_lock held, it not only wasted
the CPU but also made the host harder to respond.
This patch mitigates this by using kvm_handle_hva_range().
Cc: Alexander Graf <agraf@suse.de>
The kernel no longer allows us to pass NULL for the hard handler
without also specifying IRQF_ONESHOT. IRQF_ONESHOT imposes latency
in the exit path that we don't need for MSI interrupts. Long term
we'd like to inject these interrupts from the hard handler when
possible. In the short term, we can create dummy hard handlers
that return us to the previous behavior. Credit to Michael for
original patch.
Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=43328
If last_boosted_vcpu == 0, then we fall through all test cases and
may end up with all VCPUs pouncing on vcpu 0. With a large enough
guest, this can result in enormous runqueue lock contention, which
can prevent vcpu0 from running, leading to a livelock.
Changing < to <= makes sure we properly handle that case.
Signed-off-by: Rik van Riel <riel@redhat.com>
fault_page is forgot to be freed
We only know of one so far.
