commit 63afbe7a0ac184ef8485dac4914e87b211b5bfaa upstream.
If the physical address of GICV isn't page-aligned, then we end up
creating a stage-2 mapping of the page containing it, which causes us to
map neighbouring memory locations directly into the guest.
As an example, consider a platform with GICV at physical 0x2c02f000
running a 64k-page host kernel. If qemu maps this into the guest at
0x80010000, then guest physical addresses 0x80010000 - 0x8001efff will
map host physical region 0x2c020000 - 0x2c02efff. Accesses to these
physical regions may cause UNPREDICTABLE behaviour, for example, on the
Juno platform this will cause an SError exception to EL3, which brings
down the entire physical CPU resulting in RCU stalls / HYP panics / host
crashing / wasted weeks of debugging.
SBSA recommends that systems alias the 4k GICV across the bounding 64k
region, in which case GICV physical could be described as 0x2c020000 in
the above scenario.
This patch fixes the problem by failing the vgic probe if the physical
base address or the size of GICV aren't page-aligned. Note that this
generated a warning in dmesg about freeing enabled IRQs, so I had to
move the IRQ enabling later in the probe.
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Joel Schopp <joel.schopp@amd.com>
Cc: Don Dutile <ddutile@redhat.com>
Acked-by: Peter Maydell <peter.maydell@linaro.org>
Acked-by: Joel Schopp <joel.schopp@amd.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Shannon Zhao <shannon.zhao@linaro.org>
base address.
commit 30c2117085bc4e05d091cee6eba79f069b41a9cd upstream.
Currently below check in vgic_ioaddr_overlap will always succeed,
because the vgic dist base and vgic cpu base are still kept UNDEF
after initialization. The code as follows will be return forever.
if (IS_VGIC_ADDR_UNDEF(dist) || IS_VGIC_ADDR_UNDEF(cpu))
return 0;
So, before invoking the vgic_ioaddr_overlap, it needs to set the
corresponding base address firstly.
Signed-off-by: Haibin Wang <wanghaibin.wang@huawei.com>
commit f2ae85b2ab3776b9e4e42e5b6fa090f40d396794 upstream.
Since KVM internally represents the ICFGR registers by stuffing two
of them into one word, the offset for accessing the internal
representation and the one for the MMIO based access are different.
So keep the original offset around, but adjust the internal array
offset by one bit.
Reported-by: Haibin Wang <wanghaibin.wang@huawei.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
commit ca3f0874723fad81d0c701b63ae3a17a408d5f25 upstream.
kvm_write_guest_cached() does not mark all written pages as dirty and
code comments in kvm_gfn_to_hva_cache_init() talk about NULL memslot
with cross page accesses. Fix all the easy way.
The check is '<= 1' to have the same result for 'len = 0' cache anywhere
in the page. (nr_pages_needed is 0 on page boundary.)
Fixes: 8f964525a121 ("KVM: Allow cross page reads and writes from cached translations.")
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Message-Id: <20150408121648.GA3519@potion.brq.redhat.com>
Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com>
commit 3d32e4dbe71374a6780eaf51d719d76f9a9bf22f upstream.
The third parameter of kvm_unpin_pages() when called from
kvm_iommu_map_pages() is wrong, it should be the number of pages to un-pin
and not the page size.
This error was facilitated with an inconsistent API: kvm_pin_pages() takes
a size, but kvn_unpin_pages() takes a number of pages, so fix the problem
by matching the two.
This was introduced by commit 350b8bd ("kvm: iommu: fix the third parameter
of kvm_iommu_put_pages (CVE-2014-3601)"), which fixes the lack of
un-pinning for pages intended to be un-pinned (i.e. memory leak) but
unfortunately potentially aggravated the number of pages we un-pin that
should have stayed pinned. As far as I understand though, the same
practical mitigations apply.
This issue was found during review of Red Hat 6.6 patches to prepare
Ksplice rebootless updates.
Thanks to Vegard for his time on a late Friday evening to help me in
understanding this code.
Fixes: 350b8bd ("kvm: iommu: fix the third parameter of... (CVE-2014-3601)")
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Reviewed-by: Sasha Levin <sasha.levin@oracle.com>
commit 2ea75be3219571d0ec009ce20d9971e54af96e09 upstream.
vcpu ioctls can hang the calling thread if issued while a vcpu is running.
However, invalid ioctls can happen when userspace tries to probe the kind
of file descriptors (e.g. isatty() calls ioctl(TCGETS)); in that case,
we know the ioctl is going to be rejected as invalid anyway and we can
fail before trying to take the vcpu mutex.
This patch does not change functionality, it just makes invalid ioctls
fail faster.
Signed-off-by: David Matlack <dmatlack@google.com>
commit ee3d1570b58677885b4552bce8217fda7b226a68 upstream.
vcpu exits and memslot mutations can run concurrently as long as the
vcpu does not aquire the slots mutex. Thus it is theoretically possible
for memslots to change underneath a vcpu that is handling an exit.
If we increment the memslot generation number again after
synchronize_srcu_expedited(), vcpus can safely cache memslot generation
without maintaining a single rcu_dereference through an entire vm exit.
And much of the x86/kvm code does not maintain a single rcu_dereference
of the current memslots during each exit.
We can prevent the following case:
vcpu (CPU 0) | thread (CPU 1)
1 vm exit |
2 srcu_read_unlock(&kvm->srcu) |
3 decide to cache something based on |
old memslots |
4 | change memslots
| (increments generation)
5 | synchronize_srcu(&kvm->srcu);
6 retrieve generation # from new memslots |
7 tag cache with new memslot generation |
8 srcu_read_unlock(&kvm->srcu) |
<action based on cache occurs even |
though the caching decision was based |
on the old memslots> |
<action *continues* to occur until next |
memslot generation change, which may |
be never> |
By incrementing the generation after synchronizing with kvm->srcu readers,
we ensure that the generation retrieved in (6) will become invalid soon
after (8).
Keeping the existing increment is not strictly necessary, but we
do keep it and just move it for consistency from update_memslots to
install_new_memslots. It invalidates old cached MMIOs immediately,
instead of having to wait for the end of synchronize_srcu_expedited,
which makes the code more clearly correct in case CPU 1 is preempted
right after synchronize_srcu() returns.
To avoid halving the generation space in SPTEs, always presume that the
low bit of the generation is zero when reconstructing a generation number
out of an SPTE. This effectively disables MMIO caching in SPTEs during
the call to synchronize_srcu_expedited. Using the low bit this way is
somewhat like a seqcount---where the protected thing is a cache, and
instead of retrying we can simply punt if we observe the low bit to be 1.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Reviewed-by: David Matlack <dmatlack@google.com>
commit 350b8bdd689cd2ab2c67c8a86a0be86cfa0751a7 upstream.
The third parameter of kvm_iommu_put_pages is wrong,
It should be 'gfn - slot->base_gfn'.
By making gfn very large, malicious guest or userspace can cause kvm to
go to this error path, and subsequently to pass a huge value as size.
Alternatively if gfn is small, then pages would be pinned but never
unpinned, causing host memory leak and local DOS.
Passing a reasonable but large value could be the most dangerous case,
because it would unpin a page that should have stayed pinned, and thus
allow the device to DMA into arbitrary memory. However, this cannot
happen because of the condition that can trigger the error:
- out of memory (where you can't allocate even a single page)
should not be possible for the attacker to trigger
- when exceeding the iommu's address space, guest pages after gfn
will also exceed the iommu's address space, and inside
kvm_iommu_put_pages() the iommu_iova_to_phys() will fail. The
page thus would not be unpinned at all.
Reported-by: Jack Morgenstein <jackm@mellanox.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 0f6c0a740b7d3e1f3697395922d674000f83d060 upstream.
Currently, the EOI exit bitmap (used for APICv) does not include
interrupts that are masked. However, this can cause a bug that manifests
as an interrupt storm inside the guest. Alex Williamson reported the
bug and is the one who really debugged this; I only wrote the patch. :)
The scenario involves a multi-function PCI device with OHCI and EHCI
USB functions and an audio function, all assigned to the guest, where
both USB functions use legacy INTx interrupts.
As soon as the guest boots, interrupts for these devices turn into an
interrupt storm in the guest; the host does not see the interrupt storm.
Basically the EOI path does not work, and the guest continues to see the
interrupt over and over, even after it attempts to mask it at the APIC.
The bug is only visible with older kernels (RHEL6.5, based on 2.6.32
with not many changes in the area of APIC/IOAPIC handling).
Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ)
on in the eoi_exit_bitmap and TMR, and things then work. What happens
is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap.
It does not have set bit 59 because the RTE was masked, so the IOAPIC
never sees the EOI and the interrupt continues to fire in the guest.
My guess was that the guest is masking the interrupt in the redirection
table in the interrupt routine, i.e. while the interrupt is set in a
LAPIC's ISR, The simplest fix is to ignore the masking state, we would
rather have an unnecessary exit rather than a missed IRQ ACK and anyway
IOAPIC interrupts are not as performance-sensitive as for example MSIs.
Alex tested this patch and it fixed his bug.
[Thanks to Alex for his precise description of the problem
and initial debugging effort. A lot of the text above is
based on emails exchanged with him.]
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
commit 5678de3f15010b9022ee45673f33bcfc71d47b60 upstream.
QE reported that they got the BUG_ON in ioapic_service to trigger.
I cannot reproduce it, but there are two reasons why this could happen.
The less likely but also easiest one, is when kvm_irq_delivery_to_apic
does not deliver to any APIC and returns -1.
Because irqe.shorthand == 0, the kvm_for_each_vcpu loop in that
function is never reached. However, you can target the similar loop in
kvm_irq_delivery_to_apic_fast; just program a zero logical destination
address into the IOAPIC, or an out-of-range physical destination address.
commit 41c22f626254b9dc0376928cae009e73d1b6a49a upstream.
get_user_pages(mm) is simply wrong if mm->mm_users == 0 and exit_mmap/etc
was already called (or is in progress), mm->mm_count can only pin mm->pgd
and mm_struct itself.
Change kvm_setup_async_pf/async_pf_execute to inc/dec mm->mm_users.
kvm_create_vm/kvm_destroy_vm play with ->mm_count too but this case looks
fine at first glance, it seems that this ->mm is only used to verify that
current->mm == kvm->mm.
commit 91021a6c8ffdc55804dab5acdfc7de4f278b9ac3 upstream.
When dispatch SGI(mode == 0), that is the vcpu of VM should send
sgi to the cpu which the target_cpus list.
So, there must add the "break" to branch of case 0.
This fixes the build breakage introduced by
c07a0191ef2de1f9510f12d1f88e3b0b5cd8d66f and adds support for the device
control API and save/restore of the VGIC state for ARMv8.
The defines were simply missing from the arm64 header files and
uaccess.h must be implicitly imported from somewhere else on arm.
If kvm_io_bus_register_dev() fails then it returns success but it should
return an error code.
I also did a little cleanup like removing an impossible NULL test.
Cc: stable@vger.kernel.org
Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone')
Pull KVM updates from Paolo Bonzini:
"First round of KVM updates for 3.14; PPC parts will come next week.
Nothing major here, just bugfixes all over the place. The most
interesting part is the ARM guys' virtualized interrupt controller
overhaul, which lets userspace get/set the state and thus enables
migration of ARM VMs"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits)
kvm: make KVM_MMU_AUDIT help text more readable
KVM: s390: Fix memory access error detection
KVM: nVMX: Update guest activity state field on L2 exits
KVM: nVMX: Fix nested_run_pending on activity state HLT
KVM: nVMX: Clean up handling of VMX-related MSRs
KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject
KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit
KVM: nVMX: Leave VMX mode on clearing of feature control MSR
KVM: VMX: Fix DR6 update on #DB exception
KVM: SVM: Fix reading of DR6
KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS
add support for Hyper-V reference time counter
KVM: remove useless write to vcpu->hv_clock.tsc_timestamp
KVM: x86: fix tsc catchup issue with tsc scaling
KVM: x86: limit PIT timer frequency
KVM: x86: handle invalid root_hpa everywhere
kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub
kvm: vfio: silence GCC warning
KVM: ARM: Remove duplicate include
arm/arm64: KVM: relax the requirements of VMA alignment for THP
Commit 7940876e1330671708186ac3386aa521ffb5c182 ("kvm: make local
functions static") broke KVM PPC builds due to removing (rather than
moving) the stub version of kvm_vcpu_eligible_for_directed_yield().
This patch reintroduces it.
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Alexander Graf <agraf@suse.de>
[Move the #ifdef inside the function. - Paolo]
Building vfio.o triggers a GCC warning (when building for 32 bits x86):
arch/x86/kvm/../../../virt/kvm/vfio.c: In function 'kvm_vfio_set_group':
arch/x86/kvm/../../../virt/kvm/vfio.c:104:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
void __user *argp = (void __user *)arg;
Silence this warning by casting arg to unsigned long.
argp's current type, "void __user *", is always casted to "int32_t
__user *". So its type might as well be changed to "int32_t __user *".
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The function kvm_io_bus_read_cookie is defined but never used
in current in-tree code.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Running 'make namespacecheck' found lots of functions that
should be declared static, since only used in one file.
Implement support for the CPU interface register access driven by MMIO
address offsets from the CPU interface base address. Useful for user
space to support save/restore of the VGIC state.
This commit adds support only for the same logic as the current VGIC
support, and no more. For example, the active priority registers are
handled as RAZ/WI, just like setting priorities on the emulated
distributor.
Handle MMIO accesses to the two registers which should support both the
case where the VMs want to read/write either of these registers and the
case where user space reads/writes these registers to do save/restore of
the VGIC state.
Note that the added complexity compared to simple set/clear enable
registers stems from the bookkeping of source cpu ids. It may be
possible to change the underlying data structure to simplify the
complexity, but since this is not in the critical path at all, this will
do.
Also note that reading this register from a live guest will not be
accurate compared to on hardware, because some state may be living on
the CPU LRs and the only way to give a consistent read would be to force
stop all the VCPUs and request them to unqueu the LR state onto the
distributor. Until we have an actual user of live reading this
register, we can live with the difference.
To properly access the VGIC state from user space it is very unpractical
to have to loop through all the LRs in all register access functions.
Instead, support moving all pending state from LRs to the distributor,
but leave active state LRs alone.
Note that to accurately present the active and pending state to VCPUs
reading these distributor registers from a live VM, we would have to
stop all other VPUs than the calling VCPU and ask each CPU to unqueue
their LR state onto the distributor and add fields to track active state
on the distributor side as well. We don't have any users of such
functionality yet and there are other inaccuracies of the GIC emulation,
so don't provide accurate synchronized access to this state just yet.
However, when the time comes, having this function should help.
Add infrastructure to handle distributor and cpu interface register
accesses through the KVM_{GET/SET}_DEVICE_ATTR interface by adding the
KVM_DEV_ARM_VGIC_GRP_DIST_REGS and KVM_DEV_ARM_VGIC_GRP_CPU_REGS groups
and defining the semantics of the attr field to be the MMIO offset as
specified in the GICv2 specs.
Missing register accesses or other changes in individual register access
functions to support save/restore of the VGIC state is added in
subsequent patches.
Rename the vgic_ranges array to vgic_dist_ranges to be more specific and
to prepare for handling CPU interface register access as well (for
save/restore of VGIC state).
Pass offset from distributor or interface MMIO base to
find_matching_range function instead of the physical address of the
access in the VM memory map. This allows other callers unaware of the
VM specifics, but with generic VGIC knowledge to reuse the function.
Support setting the distributor and cpu interface base addresses in the
VM physical address space through the KVM_{SET,GET}_DEVICE_ATTR API
in addition to the ARM specific API.
This has the added benefit of being able to share more code in user
space and do things in a uniform manner.
Also deprecate the older API at the same time, but backwards
compatibility will be maintained.
Support creating the ARM VGIC device through the KVM_CREATE_DEVICE
ioctl, which can then later be leveraged to use the
KVM_{GET/SET}_DEVICE_ATTR, which is useful both for setting addresses in
a more generic API than the ARM-specific one and is useful for
save/restore of VGIC state.
Adds KVM_CAP_DEVICE_CTRL to ARM capabilities.
Note that we change the check for creating a VGIC from bailing out if
any VCPUs were created, to bailing out if any VCPUs were ever run. This
is an important distinction that shouldn't break anything, but allows
creating the VGIC after the VCPUs have been created.
Rework the VGIC initialization slightly to allow initialization of the
vgic cpu-specific state even if the irqchip (the VGIC) hasn't been
created by user space yet. This is safe, because the vgic data
structures are already allocated when the CPU is allocated if VGIC
support is compiled into the kernel. Further, the init process does not
depend on any other information and the sacrifice is a slight
performance degradation for creating VMs in the no-VGIC case.
The reason is that the new device control API doesn't mandate creating
the VGIC before creating the VCPU and it is unreasonable to require user
space to create the VGIC before creating the VCPUs.
At the same time move the irqchip_in_kernel check out of
kvm_vcpu_first_run_init and into the init function to make the per-vcpu
and global init functions symmetric and add comments on the exported
functions making it a bit easier to understand the init flow by only
looking at vgic.c.
For migration to work we need to save (and later restore) the state of
each core's virtual generic timer.
Since this is per VCPU, we can use the [gs]et_one_reg ioctl and export
the three needed registers (control, counter, compare value).
Though they live in cp15 space, we don't use the existing list, since
they need special accessor functions and the arch timer is optional.
Acked-by: Marc Zynger <marc.zyngier@arm.com>
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Initialize the cntvoff at kvm_init_vm time, not before running the VCPUs
at the first time because that will overwrite any potentially restored
values from user space.
Cc: Andre Przywara <andre.przywara@linaro.org>
Since the commit 15ad7146 ("KVM: Use the scheduler preemption notifiers
to make kvm preemptible"), the remaining stuff in this function is a
simple cond_resched() call with an extra need_resched() check which was
there to avoid dropping VCPUs unnecessarily. Now it is meaningless.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
In multiple functions the vcpu_id is used as an offset into a bitfield. Ag
malicious user could specify a vcpu_id greater than 255 in order to set or
clear bits in kernel memory. This could be used to elevate priveges in the
kernel. This patch verifies that the vcpu_id provided is less than 255.
The api documentation already specifies that the vcpu_id must be less than
max_vcpus, but this is currently not checked.
Reported-by: Andrew Honig <ahonig@google.com>
Signed-off-by: Andrew Honig <ahonig@google.com>
Using the address of 'empty_zero_page' as source address in order to
clear a page is wrong. On some architectures empty_zero_page is only the
pointer to the struct page of the empty_zero_page. Therefore the clear
page operation would copy the contents of a couple of struct pages instead
of clearing a page. For kvm only arm/arm64 are affected by this bug.
To fix this use the ZERO_PAGE macro instead which will return the struct
page address of the empty_zero_page on all architectures.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Pull KVM changes from Paolo Bonzini:
"Here are the 3.13 KVM changes. There was a lot of work on the PPC
side: the HV and emulation flavors can now coexist in a single kernel
is probably the most interesting change from a user point of view.
On the x86 side there are nested virtualization improvements and a few
bugfixes.
ARM got transparent huge page support, improved overcommit, and
support for big endian guests.
Finally, there is a new interface to connect KVM with VFIO. This
helps with devices that use NoSnoop PCI transactions, letting the
driver in the guest execute WBINVD instructions. This includes some
nVidia cards on Windows, that fail to start without these patches and
the corresponding userspace changes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
kvm, vmx: Fix lazy FPU on nested guest
arm/arm64: KVM: PSCI: propagate caller endianness to the incoming vcpu
arm/arm64: KVM: MMIO support for BE guest
kvm, cpuid: Fix sparse warning
kvm: Delete prototype for non-existent function kvm_check_iopl
kvm: Delete prototype for non-existent function complete_pio
hung_task: add method to reset detector
pvclock: detect watchdog reset at pvclock read
kvm: optimize out smp_mb after srcu_read_unlock
srcu: API for barrier after srcu read unlock
KVM: remove vm mmap method
KVM: IOMMU: hva align mapping page size
KVM: x86: trace cpuid emulation when called from emulator
KVM: emulator: cleanup decode_register_operand() a bit
KVM: emulator: check rex prefix inside decode_register()
KVM: x86: fix emulation of "movzbl %bpl, %eax"
kvm_host: typo fix
KVM: x86: emulate SAHF instruction
MAINTAINERS: add tree for kvm.git
Documentation/kvm: add a 00-INDEX file
It was used in conjunction with KVM_SET_MEMORY_REGION ioctl which was
removed by b74a07beed0 in 2010, QEMU stopped using it in 2008, so
it is time to remove the code finally.
When determining the page size we could use to map with the IOMMU, the
page size should also be aligned with the hva, not just the gfn. The
gfn may not reflect the real alignment within the hugetlbfs file.
Most of the time, this works fine. However, if the hugetlbfs file is
backed by non-contiguous huge pages, a multi-huge page memslot starts at
an unaligned offset within the hugetlbfs file, and the gfn is aligned
with respect to the huge page size, kvm_host_page_size() will return the
huge page size and we will use that to map with the IOMMU.
When we later unpin that same memslot, the IOMMU returns the unmap size
as the huge page size, and we happily unpin that many pfns in
monotonically increasing order, not realizing we are spanning
non-contiguous huge pages and partially unpin the wrong huge page.
Ensure the IOMMU mapping page size is aligned with the hva corresponding
to the gfn, which does reflect the alignment within the hugetlbfs file.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Greg Edwards <gedwards@ddn.com>
arch/powerpc/include/asm/processor.h
We currently use some ad-hoc arch variables tied to legacy KVM device
assignment to manage emulation of instructions that depend on whether
non-coherent DMA is present. Create an interface for this, adapting
legacy KVM device assignment and adding VFIO via the KVM-VFIO device.
For now we assume that non-coherent DMA is possible any time we have a
VFIO group. Eventually an interface can be developed as part of the
VFIO external user interface to query the coherency of a group.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Default to operating in coherent mode. This simplifies the logic when
we switch to a model of registering and unregistering noncoherent I/O
with KVM.
So far we've succeeded at making KVM and VFIO mostly unaware of each
other, but areas are cropping up where a connection beyond eventfds
and irqfds needs to be made. This patch introduces a KVM-VFIO device
that is meant to be a gateway for such interaction. The user creates
the device and can add and remove VFIO groups to it via file
descriptors. When a group is added, KVM verifies the group is valid
and gets a reference to it via the VFIO external user interface.
I don't know if this was due to cut and paste, or somebody was really
using a D20 to pick the error code for kvm_init_debugfs as suggested by
Linus (EFAULT is 14, so the possibility cannot be entirely ruled out).
In any case, this patch fixes it.
Reported-by: Tim Gardner <tim.gardner@canonical.com>
In kvm_iommu_map_pages(), we need to know the page size via call
kvm_host_page_size(). And it will check whether the target slot
is valid before return the right page size.
Currently, we will map the iommu pages when creating a new slot.
But we call kvm_iommu_map_pages() during preparing the new slot.
At that time, the new slot is not visible by domain(still in preparing).
So we cannot get the right page size from kvm_host_page_size() and
this will break the IOMMU super page logic.
The solution is to map the iommu pages after we insert the new slot
into domain.
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
Tested-by: Patrick Lu <patrick.lu@intel.com>
Merging master into next to satisfy the dependencies.
arch/arm/kvm/reset.c
We will use that in the later patch to find the kvm ops handler
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
[agraf: squash in compile fix]
Page pinning is not mandatory in kvm async page fault processing since
after async page fault event is delivered to a guest it accesses page once
again and does its own GUP. Drop the FOLL_GET flag in GUP in async_pf
code, and do some simplifying in check/clear processing.
Suggested-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Gu zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: chai wen <chaiw.fnst@cn.fujitsu.com>
When KVM (de)assigns PCI(e) devices to VMs, a debug message is printed
including the BDF notation of the respective device. Currently, the BDF
notation does not have the commonly used leading zeros. This produces
messages like "assign device 0:1:8.0", which look strange at first sight.
The patch fixes this by exchanging the printk(KERN_DEBUG ...) with dev_info()
and also inserts "kvm" into the debug message, so that it is obvious where
the message comes from. Also reduces LoC.
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Andre Richter <andre.o.richter@gmail.com>
gfn_to_memslot() can return NULL or invalid slot. We need to check slot
validity before accessing it.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
In commit e935b8372cf8 ("KVM: Convert kvm_lock to raw_spinlock"),
the kvm_lock was made a raw lock. However, the kvm mmu_shrink()
function tries to grab the (non-raw) mmu_lock within the scope of
the raw locked kvm_lock being held. This leads to the following:
BUG: sleeping function called from invalid context at kernel/rtmutex.c:659
in_atomic(): 1, irqs_disabled(): 0, pid: 55, name: kswapd0
Preemption disabled at:[<ffffffffa0376eac>] mmu_shrink+0x5c/0x1b0 [kvm]
Pid: 55, comm: kswapd0 Not tainted 3.4.34_preempt-rt
Call Trace:
[<ffffffff8106f2ad>] __might_sleep+0xfd/0x160
[<ffffffff817d8d64>] rt_spin_lock+0x24/0x50
[<ffffffffa0376f3c>] mmu_shrink+0xec/0x1b0 [kvm]
[<ffffffff8111455d>] shrink_slab+0x17d/0x3a0
[<ffffffff81151f00>] ? mem_cgroup_iter+0x130/0x260
[<ffffffff8111824a>] balance_pgdat+0x54a/0x730
[<ffffffff8111fe47>] ? set_pgdat_percpu_threshold+0xa7/0xd0
[<ffffffff811185bf>] kswapd+0x18f/0x490
[<ffffffff81070961>] ? get_parent_ip+0x11/0x50
[<ffffffff81061970>] ? __init_waitqueue_head+0x50/0x50
[<ffffffff81118430>] ? balance_pgdat+0x730/0x730
[<ffffffff81060d2b>] kthread+0xdb/0xe0
[<ffffffff8106e122>] ? finish_task_switch+0x52/0x100
[<ffffffff817e1e94>] kernel_thread_helper+0x4/0x10
[<ffffffff81060c50>] ? __init_kthread_worker+0x
After the previous patch, kvm_lock need not be a raw spinlock anymore,
so change it back.
Reported-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: kvm@vger.kernel.org
Cc: gleb@redhat.com
Cc: jan.kiszka@siemens.com
Reviewed-by: Gleb Natapov <gleb@redhat.com>
The VM list need not be protected by a raw spinlock. Separate the
two so that kvm_lock can be made non-raw.
Cc: gleb@redhat.com
Remove the useless argument, and do not do anything if there are no
VMs running at the time of the hotplug.
Cc: gleb@redhat.com
