path: root/virt
2014-04-14Merge git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Marcelo Tosatti: - Fix for guest triggerable BUG_ON (CVE-2014-0155) - CR4.SMAP support - Spurious WARN_ON() fix * git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: x86: remove WARN_ON from get_kernel_ns() KVM: Rename variable smep to cr4_smep KVM: expose SMAP feature to guest KVM: Disable SMAP for guests in EPT realmode and EPT unpaging mode KVM: Add SMAP support when setting CR4 KVM: Remove SMAP bit from CR4_RESERVED_BITS KVM: ioapic: try to recover if pending_eoi goes out of range KVM: ioapic: fix assignment of ioapic->rtc_status.pending_eoi (CVE-2014-0155)
2014-04-08arm, kvm: fix double lock on cpu_add_remove_lockMing Lei
Commit 8146875de7d4 (arm, kvm: Fix CPU hotplug callback registration) holds the lock before calling the two functions: kvm_vgic_hyp_init() kvm_timer_hyp_init() and both the two functions are calling register_cpu_notifier() to register cpu notifier, so cause double lock on cpu_add_remove_lock. Considered that both two functions are only called inside kvm_arch_init() with holding cpu_add_remove_lock, so simply use __register_cpu_notifier() to fix the problem. Fixes: 8146875de7d4 (arm, kvm: Fix CPU hotplug callback registration) Signed-off-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-04KVM: ioapic: try to recover if pending_eoi goes out of rangePaolo Bonzini
The RTC tracking code tracks the cardinality of rtc_status.dest_map into rtc_status.pending_eoi. It has some WARN_ONs that trigger if pending_eoi ever becomes negative; however, these do not do anything to recover, and it bad things will happen soon after they trigger. When the next RTC interrupt is triggered, rtc_check_coalesced() will return false, but ioapic_service will find pending_eoi != 0 and do a BUG_ON. To avoid this, should pending_eoi ever be nonzero, call kvm_rtc_eoi_tracking_restore_all to recompute a correct dest_map and pending_eoi. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-04-04KVM: ioapic: fix assignment of ioapic->rtc_status.pending_eoi (CVE-2014-0155)Paolo Bonzini
QE reported that they got the BUG_ON in ioapic_service to trigger. I cannot reproduce it, but there are two reasons why this could happen. The less likely but also easiest one, is when kvm_irq_delivery_to_apic does not deliver to any APIC and returns -1. Because irqe.shorthand == 0, the kvm_for_each_vcpu loop in that function is never reached. However, you can target the similar loop in kvm_irq_delivery_to_apic_fast; just program a zero logical destination address into the IOAPIC, or an out-of-range physical destination address. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-04-03Merge tag 'vfio-v3.15-rc1' of git://github.com/awilliam/linux-vfioLinus Torvalds
Pull VFIO updates from Alex Williamson: "VFIO updates for v3.15 include: - Allow the vfio-type1 IOMMU to support multiple domains within a container - Plumb path to query whether all domains are cache-coherent - Wire query into kvm-vfio device to avoid KVM x86 WBINVD emulation - Always select CONFIG_ANON_INODES, vfio depends on it (Arnd) The first patch also makes the vfio-type1 IOMMU driver completely independent of the bus_type of the devices it's handling, which enables it to be used for both vfio-pci and a future vfio-platform (and hopefully combinations involving both simultaneously)" * tag 'vfio-v3.15-rc1' of git://github.com/awilliam/linux-vfio: vfio: always select ANON_INODES kvm/vfio: Support for DMA coherent IOMMUs vfio: Add external user check extension interface vfio/type1: Add extension to test DMA cache coherence of IOMMU vfio/iommu_type1: Multi-IOMMU domain support
2014-04-02Merge tag 'kvm-3.15-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Paolo Bonzini: "PPC and ARM do not have much going on this time. Most of the cool stuff, instead, is in s390 and (after a few releases) x86. ARM has some caching fixes and PPC has transactional memory support in guests. MIPS has some fixes, with more probably coming in 3.16 as QEMU will soon get support for MIPS KVM. For x86 there are optimizations for debug registers, which trigger on some Windows games, and other important fixes for Windows guests. We now expose to the guest Broadwell instruction set extensions and also Intel MPX. There's also a fix/workaround for OS X guests, nested virtualization features (preemption timer), and a couple kvmclock refinements. For s390, the main news is asynchronous page faults, together with improvements to IRQs (floating irqs and adapter irqs) that speed up virtio devices" * tag 'kvm-3.15-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (96 commits) KVM: PPC: Book3S HV: Save/restore host PMU registers that are new in POWER8 KVM: PPC: Book3S HV: Fix decrementer timeouts with non-zero TB offset KVM: PPC: Book3S HV: Don't use kvm_memslots() in real mode KVM: PPC: Book3S HV: Return ENODEV error rather than EIO KVM: PPC: Book3S: Trim top 4 bits of physical address in RTAS code KVM: PPC: Book3S HV: Add get/set_one_reg for new TM state KVM: PPC: Book3S HV: Add transactional memory support KVM: Specify byte order for KVM_EXIT_MMIO KVM: vmx: fix MPX detection KVM: PPC: Book3S HV: Fix KVM hang with CONFIG_KVM_XICS=n KVM: PPC: Book3S: Introduce hypervisor call H_GET_TCE KVM: PPC: Book3S HV: Fix incorrect userspace exit on ioeventfd write KVM: s390: clear local interrupts at cpu initial reset KVM: s390: Fix possible memory leak in SIGP functions KVM: s390: fix calculation of idle_mask array size KVM: s390: randomize sca address KVM: ioapic: reinject pending interrupts on KVM_SET_IRQCHIP KVM: Bump KVM_MAX_IRQ_ROUTES for s390 KVM: s390: irq routing for adapter interrupts. KVM: s390: adapter interrupt sources ...
2014-03-31Merge branch 'x86-asmlinkage-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 LTO changes from Peter Anvin: "More infrastructure work in preparation for link-time optimization (LTO). Most of these changes is to make sure symbols accessed from assembly code are properly marked as visible so the linker doesn't remove them. My understanding is that the changes to support LTO are still not upstream in binutils, but are on the way there. This patchset should conclude the x86-specific changes, and remaining patches to actually enable LTO will be fed through the Kbuild tree (other than keeping up with changes to the x86 code base, of course), although not necessarily in this merge window" * 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits) Kbuild, lto: Handle basic LTO in modpost Kbuild, lto: Disable LTO for asm-offsets.c Kbuild, lto: Add a gcc-ld script to let run gcc as ld Kbuild, lto: add ld-version and ld-ifversion macros Kbuild, lto: Drop .number postfixes in modpost Kbuild, lto, workaround: Don't warn for initcall_reference in modpost lto: Disable LTO for sys_ni lto: Handle LTO common symbols in module loader lto, workaround: Add workaround for initcall reordering lto: Make asmlinkage __visible x86, lto: Disable LTO for the x86 VDSO initconst, x86: Fix initconst mistake in ts5500 code initconst: Fix initconst mistake in dcdbas asmlinkage: Make trace_hardirqs_on/off_caller visible asmlinkage, x86: Fix 32bit memcpy for LTO asmlinkage Make __stack_chk_failed and memcmp visible asmlinkage: Mark rwsem functions that can be called from assembler asmlinkage asmlinkage: Make main_extable_sort_needed visible asmlinkage, mutex: Mark __visible asmlinkage: Make trace_hardirq visible ...
2014-03-21KVM: ioapic: reinject pending interrupts on KVM_SET_IRQCHIPPaolo Bonzini
After the previous patches, an interrupt whose bit is set in the IRR register will never be in the LAPIC's IRR and has never been injected on the migration source. So inject it on the destination. This fixes migration of Windows guests without HPET (they use the RTC to trigger the scheduler tick, and lose it after migration). Reviewed-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-03-21KVM: ioapic: extract body of kvm_ioapic_set_irqPaolo Bonzini
We will reuse it to process a nonzero IRR that is passed to KVM_SET_IRQCHIP. Reviewed-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-03-21KVM: ioapic: clear IRR for edge-triggered interrupts at deliveryPaolo Bonzini
This ensures that IRR bits are set in the KVM_GET_IRQCHIP result only if the interrupt is still sitting in the IOAPIC. After the next patches, it avoids spurious reinjection of the interrupt when KVM_SET_IRQCHIP is called. Reviewed-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-03-21KVM: ioapic: merge ioapic_deliver into ioapic_servicePaolo Bonzini
Commonize the handling of masking, which was absent for kvm_ioapic_set_irq. Setting remote_irr does not need a separate function either, and merging the two functions avoids confusion. Reviewed-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-03-18KVM: eventfd: Fix lock order inversion.Cornelia Huck
When registering a new irqfd, we call its ->poll method to collect any event that might have previously been pending so that we can trigger it. This is done under the kvm->irqfds.lock, which means the eventfd's ctx lock is taken under it. However, if we get a POLLHUP in irqfd_wakeup, we will be called with the ctx lock held before getting the irqfds.lock to deactivate the irqfd, causing lockdep to complain. Calling the ->poll method does not really need the irqfds.lock, so let's just move it after we've given up the irqfds.lock in kvm_irqfd_assign(). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-03-13kvm: x86: ignore ioapic polarityGabriel L. Somlo
Both QEMU and KVM have already accumulated a significant number of optimizations based on the hard-coded assumption that ioapic polarity will always use the ActiveHigh convention, where the logical and physical states of level-triggered irq lines always match (i.e., active(asserted) == high == 1, inactive == low == 0). QEMU guests are expected to follow directions given via ACPI and configure the ioapic with polarity 0 (ActiveHigh). However, even when misbehaving guests (e.g. OS X <= 10.9) set the ioapic polarity to 1 (ActiveLow), QEMU will still use the ActiveHigh signaling convention when interfacing with KVM. This patch modifies KVM to completely ignore ioapic polarity as set by the guest OS, enabling misbehaving guests to work alongside those which comply with the ActiveHigh polarity specified by QEMU's ACPI tables. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Gabriel L. Somlo <somlo@cmu.edu> [Move documentation to KVM_IRQ_LINE, add ia64. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-02-26kvm/vfio: Support for DMA coherent IOMMUsAlex Williamson
VFIO now has support for using the IOMMU_CACHE flag and a mechanism for an external user to test the current operating mode of the IOMMU. Add support for this to the kvm-vfio pseudo device so that we only register noncoherent DMA when necessary. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Paolo Bonzini <pbonzini@redhat.com>
2014-02-26KVM: add kvm_arch_vcpu_runnable() test to kvm_vcpu_on_spin() loopMichael Mueller
Use the arch specific function kvm_arch_vcpu_runnable() to add a further criterium to identify a suitable vcpu to yield to during undirected yield processing. Signed-off-by: Michael Mueller <mimu@linux.vnet.ibm.com> Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-02-18KVM: Simplify kvm->tlbs_dirty handlingTakuya Yoshikawa
When this was introduced, kvm_flush_remote_tlbs() could be called without holding mmu_lock. It is now acknowledged that the function must be called before releasing mmu_lock, and all callers have already been changed to do so. There is no need to use smp_mb() and cmpxchg() any more. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-02-14Merge branch 'kvm-master' into kvm-queuePaolo Bonzini
2014-02-14arm64: KVM: Add VGIC device control for arm64Christoffer Dall
This fixes the build breakage introduced by c07a0191ef2de1f9510f12d1f88e3b0b5cd8d66f and adds support for the device control API and save/restore of the VGIC state for ARMv8. The defines were simply missing from the arm64 header files and uaccess.h must be implicitly imported from somewhere else on arm. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-02-13asmlinkage, kvm: Make kvm_rebooting visibleAndi Kleen
kvm_rebooting is referenced from assembler code, thus needs to be visible. Cc: Gleb Natapov <gleb@redhat.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1391845930-28580-1-git-send-email-ak@linux.intel.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-02-04KVM: async_pf: Add missing call for async page presentDominik Dingel
Commit KVM: async_pf: Provide additional direct page notification missed the call from kvm_check_async_pf_completion to the new introduced function. Reported-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-30KVM: async_pf: Allow to wait for outstanding workDominik Dingel
On s390 we are not able to cancel work. Instead we will flush the work and wait for completion. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-01-30KVM: async_pf: Provide additional direct page notificationDominik Dingel
By setting a Kconfig option, the architecture can control when guest notifications will be presented by the apf backend. There is the default batch mechanism, working as before, where the vcpu thread should pull in this information. Opposite to this, there is now the direct mechanism, that will push the information to the guest. This way s390 can use an already existing architecture interface. Still the vcpu thread should call check_completion to cleanup leftovers. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-01-30KVM: return an error code in kvm_vm_ioctl_register_coalesced_mmio()Dan Carpenter
If kvm_io_bus_register_dev() fails then it returns success but it should return an error code. I also did a little cleanup like removing an impossible NULL test. Cc: stable@vger.kernel.org Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-30KVM: s390: add floating irq controllerJens Freimann
This patch adds a floating irq controller as a kvm_device. It will be necessary for migration of floating interrupts as well as for hardening the reset code by allowing user space to explicitly remove all pending floating interrupts. Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
2014-01-22Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "First round of KVM updates for 3.14; PPC parts will come next week. Nothing major here, just bugfixes all over the place. The most interesting part is the ARM guys' virtualized interrupt controller overhaul, which lets userspace get/set the state and thus enables migration of ARM VMs" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits) kvm: make KVM_MMU_AUDIT help text more readable KVM: s390: Fix memory access error detection KVM: nVMX: Update guest activity state field on L2 exits KVM: nVMX: Fix nested_run_pending on activity state HLT KVM: nVMX: Clean up handling of VMX-related MSRs KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit KVM: nVMX: Leave VMX mode on clearing of feature control MSR KVM: VMX: Fix DR6 update on #DB exception KVM: SVM: Fix reading of DR6 KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS add support for Hyper-V reference time counter KVM: remove useless write to vcpu->hv_clock.tsc_timestamp KVM: x86: fix tsc catchup issue with tsc scaling KVM: x86: limit PIT timer frequency KVM: x86: handle invalid root_hpa everywhere kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub kvm: vfio: silence GCC warning KVM: ARM: Remove duplicate include arm/arm64: KVM: relax the requirements of VMA alignment for THP ...
2014-01-15kvm: Provide kvm_vcpu_eligible_for_directed_yield() stubScott Wood
Commit 7940876e1330671708186ac3386aa521ffb5c182 ("kvm: make local functions static") broke KVM PPC builds due to removing (rather than moving) the stub version of kvm_vcpu_eligible_for_directed_yield(). This patch reintroduces it. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Alexander Graf <agraf@suse.de> [Move the #ifdef inside the function. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-15kvm: vfio: silence GCC warningPaul Bolle
Building vfio.o triggers a GCC warning (when building for 32 bits x86): arch/x86/kvm/../../../virt/kvm/vfio.c: In function 'kvm_vfio_set_group': arch/x86/kvm/../../../virt/kvm/vfio.c:104:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] void __user *argp = (void __user *)arg; ^ Silence this warning by casting arg to unsigned long. argp's current type, "void __user *", is always casted to "int32_t __user *". So its type might as well be changed to "int32_t __user *". Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-08kvm: remove dead codeStephen Hemminger
The function kvm_io_bus_read_cookie is defined but never used in current in-tree code. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2014-01-08kvm: make local functions staticStephen Hemminger
Running 'make namespacecheck' found lots of functions that should be declared static, since only used in one file. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-12-21KVM: arm-vgic: Support CPU interface reg accessChristoffer Dall
Implement support for the CPU interface register access driven by MMIO address offsets from the CPU interface base address. Useful for user space to support save/restore of the VGIC state. This commit adds support only for the same logic as the current VGIC support, and no more. For example, the active priority registers are handled as RAZ/WI, just like setting priorities on the emulated distributor. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Add GICD_SPENDSGIR and GICD_CPENDSGIR handlersChristoffer Dall
Handle MMIO accesses to the two registers which should support both the case where the VMs want to read/write either of these registers and the case where user space reads/writes these registers to do save/restore of the VGIC state. Note that the added complexity compared to simple set/clear enable registers stems from the bookkeping of source cpu ids. It may be possible to change the underlying data structure to simplify the complexity, but since this is not in the critical path at all, this will do. Also note that reading this register from a live guest will not be accurate compared to on hardware, because some state may be living on the CPU LRs and the only way to give a consistent read would be to force stop all the VCPUs and request them to unqueu the LR state onto the distributor. Until we have an actual user of live reading this register, we can live with the difference. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Support unqueueing of LRs to the distChristoffer Dall
To properly access the VGIC state from user space it is very unpractical to have to loop through all the LRs in all register access functions. Instead, support moving all pending state from LRs to the distributor, but leave active state LRs alone. Note that to accurately present the active and pending state to VCPUs reading these distributor registers from a live VM, we would have to stop all other VPUs than the calling VCPU and ask each CPU to unqueue their LR state onto the distributor and add fields to track active state on the distributor side as well. We don't have any users of such functionality yet and there are other inaccuracies of the GIC emulation, so don't provide accurate synchronized access to this state just yet. However, when the time comes, having this function should help. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Add vgic reg access from dev attrChristoffer Dall
Add infrastructure to handle distributor and cpu interface register accesses through the KVM_{GET/SET}_DEVICE_ATTR interface by adding the KVM_DEV_ARM_VGIC_GRP_DIST_REGS and KVM_DEV_ARM_VGIC_GRP_CPU_REGS groups and defining the semantics of the attr field to be the MMIO offset as specified in the GICv2 specs. Missing register accesses or other changes in individual register access functions to support save/restore of the VGIC state is added in subsequent patches. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Make vgic mmio functions more genericChristoffer Dall
Rename the vgic_ranges array to vgic_dist_ranges to be more specific and to prepare for handling CPU interface register access as well (for save/restore of VGIC state). Pass offset from distributor or interface MMIO base to find_matching_range function instead of the physical address of the access in the VM memory map. This allows other callers unaware of the VM specifics, but with generic VGIC knowledge to reuse the function. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Set base addr through device APIChristoffer Dall
Support setting the distributor and cpu interface base addresses in the VM physical address space through the KVM_{SET,GET}_DEVICE_ATTR API in addition to the ARM specific API. This has the added benefit of being able to share more code in user space and do things in a uniform manner. Also deprecate the older API at the same time, but backwards compatibility will be maintained. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Support KVM_CREATE_DEVICE for VGICChristoffer Dall
Support creating the ARM VGIC device through the KVM_CREATE_DEVICE ioctl, which can then later be leveraged to use the KVM_{GET/SET}_DEVICE_ATTR, which is useful both for setting addresses in a more generic API than the ARM-specific one and is useful for save/restore of VGIC state. Adds KVM_CAP_DEVICE_CTRL to ARM capabilities. Note that we change the check for creating a VGIC from bailing out if any VCPUs were created, to bailing out if any VCPUs were ever run. This is an important distinction that shouldn't break anything, but allows creating the VGIC after the VCPUs have been created. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21ARM: KVM: Allow creating the VGIC after VCPUsChristoffer Dall
Rework the VGIC initialization slightly to allow initialization of the vgic cpu-specific state even if the irqchip (the VGIC) hasn't been created by user space yet. This is safe, because the vgic data structures are already allocated when the CPU is allocated if VGIC support is compiled into the kernel. Further, the init process does not depend on any other information and the sacrifice is a slight performance degradation for creating VMs in the no-VGIC case. The reason is that the new device control API doesn't mandate creating the VGIC before creating the VCPU and it is unreasonable to require user space to create the VGIC before creating the VCPUs. At the same time move the irqchip_in_kernel check out of kvm_vcpu_first_run_init and into the init function to make the per-vcpu and global init functions symmetric and add comments on the exported functions making it a bit easier to understand the init flow by only looking at vgic.c. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21ARM/KVM: save and restore generic timer registersAndre Przywara
For migration to work we need to save (and later restore) the state of each core's virtual generic timer. Since this is per VCPU, we can use the [gs]et_one_reg ioctl and export the three needed registers (control, counter, compare value). Though they live in cp15 space, we don't use the existing list, since they need special accessor functions and the arch timer is optional. Acked-by: Marc Zynger <marc.zyngier@arm.com> Signed-off-by: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21arm/arm64: KVM: arch_timer: Initialize cntvoff at kvm_initChristoffer Dall
Initialize the cntvoff at kvm_init_vm time, not before running the VCPUs at the first time because that will overwrite any potentially restored values from user space. Cc: Andre Przywara <andre.przywara@linaro.org> Acked-by: Marc Zynger <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-13KVM: Use cond_resched() directly and remove useless kvm_resched()Takuya Yoshikawa
Since the commit 15ad7146 ("KVM: Use the scheduler preemption notifiers to make kvm preemptible"), the remaining stuff in this function is a simple cond_resched() call with an extra need_resched() check which was there to avoid dropping VCPUs unnecessarily. Now it is meaningless. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-12-12KVM: Improve create VCPU parameter (CVE-2013-4587)Andy Honig
In multiple functions the vcpu_id is used as an offset into a bitfield. Ag malicious user could specify a vcpu_id greater than 255 in order to set or clear bits in kernel memory. This could be used to elevate priveges in the kernel. This patch verifies that the vcpu_id provided is less than 255. The api documentation already specifies that the vcpu_id must be less than max_vcpus, but this is currently not checked. Reported-by: Andrew Honig <ahonig@google.com> Cc: stable@vger.kernel.org Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-11-21KVM: kvm_clear_guest_page(): fix empty_zero_page usageHeiko Carstens
Using the address of 'empty_zero_page' as source address in order to clear a page is wrong. On some architectures empty_zero_page is only the pointer to the struct page of the empty_zero_page. Therefore the clear page operation would copy the contents of a couple of struct pages instead of clearing a page. For kvm only arm/arm64 are affected by this bug. To fix this use the ZERO_PAGE macro instead which will return the struct page address of the empty_zero_page on all architectures. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-11-15Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Paolo Bonzini: "Here are the 3.13 KVM changes. There was a lot of work on the PPC side: the HV and emulation flavors can now coexist in a single kernel is probably the most interesting change from a user point of view. On the x86 side there are nested virtualization improvements and a few bugfixes. ARM got transparent huge page support, improved overcommit, and support for big endian guests. Finally, there is a new interface to connect KVM with VFIO. This helps with devices that use NoSnoop PCI transactions, letting the driver in the guest execute WBINVD instructions. This includes some nVidia cards on Windows, that fail to start without these patches and the corresponding userspace changes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits) kvm, vmx: Fix lazy FPU on nested guest arm/arm64: KVM: PSCI: propagate caller endianness to the incoming vcpu arm/arm64: KVM: MMIO support for BE guest kvm, cpuid: Fix sparse warning kvm: Delete prototype for non-existent function kvm_check_iopl kvm: Delete prototype for non-existent function complete_pio hung_task: add method to reset detector pvclock: detect watchdog reset at pvclock read kvm: optimize out smp_mb after srcu_read_unlock srcu: API for barrier after srcu read unlock KVM: remove vm mmap method KVM: IOMMU: hva align mapping page size KVM: x86: trace cpuid emulation when called from emulator KVM: emulator: cleanup decode_register_operand() a bit KVM: emulator: check rex prefix inside decode_register() KVM: x86: fix emulation of "movzbl %bpl, %eax" kvm_host: typo fix KVM: x86: emulate SAHF instruction MAINTAINERS: add tree for kvm.git Documentation/kvm: add a 00-INDEX file ...
2013-11-06KVM: remove vm mmap methodGleb Natapov
It was used in conjunction with KVM_SET_MEMORY_REGION ioctl which was removed by b74a07beed0 in 2010, QEMU stopped using it in 2008, so it is time to remove the code finally. Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-11-05KVM: IOMMU: hva align mapping page sizeGreg Edwards
When determining the page size we could use to map with the IOMMU, the page size should also be aligned with the hva, not just the gfn. The gfn may not reflect the real alignment within the hugetlbfs file. Most of the time, this works fine. However, if the hugetlbfs file is backed by non-contiguous huge pages, a multi-huge page memslot starts at an unaligned offset within the hugetlbfs file, and the gfn is aligned with respect to the huge page size, kvm_host_page_size() will return the huge page size and we will use that to map with the IOMMU. When we later unpin that same memslot, the IOMMU returns the unmap size as the huge page size, and we happily unpin that many pfns in monotonically increasing order, not realizing we are spanning non-contiguous huge pages and partially unpin the wrong huge page. Ensure the IOMMU mapping page size is aligned with the hva corresponding to the gfn, which does reflect the alignment within the hugetlbfs file. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Edwards <gedwards@ddn.com> Cc: stable@vger.kernel.org Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-11-04Merge branch 'kvm-ppc-queue' of git://github.com/agraf/linux-2.6 into queueGleb Natapov
Conflicts: arch/powerpc/include/asm/processor.h
2013-10-30kvm: Create non-coherent DMA registerationAlex Williamson
We currently use some ad-hoc arch variables tied to legacy KVM device assignment to manage emulation of instructions that depend on whether non-coherent DMA is present. Create an interface for this, adapting legacy KVM device assignment and adding VFIO via the KVM-VFIO device. For now we assume that non-coherent DMA is possible any time we have a VFIO group. Eventually an interface can be developed as part of the VFIO external user interface to query the coherency of a group. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30kvm/x86: Convert iommu_flags to iommu_noncoherentAlex Williamson
Default to operating in coherent mode. This simplifies the logic when we switch to a model of registering and unregistering noncoherent I/O with KVM. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30kvm: Add VFIO deviceAlex Williamson
So far we've succeeded at making KVM and VFIO mostly unaware of each other, but areas are cropping up where a connection beyond eventfds and irqfds needs to be made. This patch introduces a KVM-VFIO device that is meant to be a gateway for such interaction. The user creates the device and can add and remove VFIO groups to it via file descriptors. When a group is added, KVM verifies the group is valid and gets a reference to it via the VFIO external user interface. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30KVM: use a more sensible error number when debugfs directory creation failsPaolo Bonzini
I don't know if this was due to cut and paste, or somebody was really using a D20 to pick the error code for kvm_init_debugfs as suggested by Linus (EFAULT is 14, so the possibility cannot be entirely ruled out). In any case, this patch fixes it. Reported-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
