path: root/virt
2009-06-15KVM: Explicity initialize cpus_hardware_enabledAvi Kivity
commit a4c0364be3f43d3e17fe19270f8b3d64881606e6 upstream. Under CONFIG_MAXSMP, cpus_hardware_enabled is allocated from the heap and not statically initialized. This causes a crash on reboot when kvm thinks vmx is enabled on random nonexistent cpus and accesses nonexistent percpu lists. Fix by explicitly clearing the variable. Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-08KVM: Fix overlapping check for memory slotsJan Kiszka
upstream commit: 4cd481f68dde99ac416003b825c835f71e364393 When checking for overlapping slots on registration of a new one, kvm currently also considers zero-length (ie. deleted) slots and rejects requests incorrectly. This finally denies user space from joining slots. Fix the check by skipping deleted slots and advertise this via a KVM_CAP_JOIN_MEMORY_REGIONS_WORKS. Cc: stable@kernel.org Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-05-08KVM: MMU: Fix off-by-one calculating large page countAvi Kivity
upstream commit: 99894a799f09cf9e28296bb16e75bd5830fd2c4e The large page initialization code concludes there are two large pages spanned by a slot covering 1 (small) page starting at gfn 1. This is incorrect, and also results in incorrect write_count initialization in some cases (base = 1, npages = 513 for example). Cc: stable@kernel.org Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27KVM: fix kvm_vm_ioctl_deassign_deviceWeidong Han
upstream commit: 4a906e49f103c2e544148a209ba1db316510799f only need to set assigned_dev_id for deassignment, use match->flags to judge and deassign it. Acked-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27KVM: MMU: handle compound pages in kvm_is_mmio_pfnJoerg Roedel
upstream commit: fc5659c8c6b6c4e02ac354b369017c1bf231f347 The function kvm_is_mmio_pfn is called before put_page is called on a page by KVM. This is a problem when when this function is called on some struct page which is part of a compund page. It does not test the reserved flag of the compound page but of the struct page within the compount page. This is a problem when KVM works with hugepages allocated at boot time. These pages have the reserved bit set in all tail pages. Only the flag in the compount head is cleared. KVM would not put such a page which results in a memory leak. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-04-27KVM: Interrupt mask notifiers for ioapicAvi Kivity
upstream commit: 75858a84a6207f5e60196f6bbd18fde4250e5759 Allow clients to request notifications when the guest masks or unmasks a particular irq line. This complements irq ack notifications, as the guest will not ack an irq line that is masked. Currently implemented for the ioapic only. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2009-02-15KVM: Fix assigned devices circular locking dependencyMark McLoughlin
kvm->slots_lock is outer to kvm->lock, so take slots_lock in kvm_vm_ioctl_assign_device() before taking kvm->lock, rather than taking it in kvm_iommu_map_memslots(). Cc: stable@kernel.org Signed-off-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: Fix INTx for device assignmentSheng Yang
Missing buckets and wrong parameter for free_irq() Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: Fix racy in kvm_free_assigned_irqSheng Yang
In the past, kvm_get_kvm() and kvm_put_kvm() was called in assigned device irq handler and interrupt_work, in order to prevent cancel_work_sync() in kvm_free_assigned_irq got a illegal state when waiting for interrupt_work done. But it's tricky and still got two problems: 1. A bug ignored two conditions that cancel_work_sync() would return true result in a additional kvm_put_kvm(). 2. If interrupt type is MSI, we would got a window between cancel_work_sync() and free_irq(), which interrupt would be injected again... This patch discard the reference count used for irq handler and interrupt_work, and ensure the legal state by moving the free function at the very beginning of kvm_destroy_vm(). And the patch fix the second bug by disable irq before cancel_work_sync(), which may result in nested disable of irq but OK for we are going to free it. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: Add kvm_arch_sync_events to sync with asynchronize eventsSheng Yang
kvm_arch_sync_events is introduced to quiet down all other events may happen contemporary with VM destroy process, like IRQ handler and work struct for assigned device. For kvm_arch_sync_events is called at the very beginning of kvm_destroy_vm(), so the state of KVM here is legal and can provide a environment to quiet down other events. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: mmu_notifiers release methodMarcelo Tosatti
The destructor for huge pages uses the backing inode for adjusting hugetlbfs accounting. Hugepage mappings are destroyed by exit_mmap, after mmu_notifier_release, so there are no notifications through unmap_hugepage_range at this point. The hugetlbfs inode can be freed with pages backed by it referenced by the shadow. When the shadow releases its reference, the huge page destructor will access a now freed inode. Implement the release operation for kvm mmu notifiers to release page refs before the hugetlbfs inode is gone. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-01-03kvm/iommu: fix compile warningJoerg Roedel
This fixes a compile warning about a variable thats maybe used uninitialized in the function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03KVM: change KVM to use IOMMU APIJoerg Roedel
2009-01-03KVM: rename vtd.c to iommu.cJoerg Roedel
Impact: file renamed The code in the vtd.c file can be reused for other IOMMUs as well. So rename it to make it clear that it handle more than VT-d. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03Deassign device in kvm_free_assgined_deviceWeidong Han
In kvm_iommu_unmap_memslots(), assigned_dev_head is already empty. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03KVM: support device deassignmentWeidong Han
Support device deassignment, it can be used in device hotplug. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03KVM: use the new intel iommu APIsWeidong Han
intel iommu APIs are updated, use the new APIs. In addition, change kvm_iommu_map_guest() to just create the domain, let kvm_iommu_assign_device() assign device. Signed-off-by: Weidong Han <weidong.han@intel.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2008-12-31KVM: fix handling of ACK from shared guest IRQMark McLoughlin
If an assigned device shares a guest irq with an emulated device then we currently interpret an ack generated by the emulated device as originating from the assigned device leading to e.g. "Unbalanced enable for IRQ 4347" from the enable_irq() in kvm_assigned_dev_ack_irq(). The fix is fairly simple - don't enable the physical device irq unless it was previously disabled. Of course, this can still lead to a situation where a non-assigned device ACK can cause the physical device irq to be reenabled before the device was serviced. However, being level sensitive, the interrupt will merely be regenerated. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Consolidate userspace memory capability reporting into common codeAvi Kivity
2008-12-31KVM: Advertise the bug in memory region destruction as fixedAvi Kivity
Userspace might need to act differently. Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: use cpumask_var_t for cpus_hardware_enabledRusty Russell
This changes cpus_hardware_enabled from a cpumask_t to a cpumask_var_t: equivalent for CONFIG_CPUMASKS_OFFSTACK=n, otherwise dynamically allocated. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: use modern cpumask primitives, no cpumask_t on stackRusty Russell
We're getting rid on on-stack cpumasks for large NR_CPUS. 1) Use cpumask_var_t/alloc_cpumask_var. 2) smp_call_function_mask -> smp_call_function_many 3) cpus_clear, cpus_empty, cpu_set -> cpumask_clear, cpumask_empty, cpumask_set_cpu. This actually generates slightly smaller code than the old one with CONFIG_CPUMASKS_OFFSTACK=n. (gcc knows that cpus cannot be NULL in that case, where cpumask_var_t is cpumask_t[1]). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Extract core of kvm_flush_remote_tlbs/kvm_reload_remote_mmusRusty Russell
Avi said: > Wow, code duplication from Rusty. Things must be bad. Something about glass houses comes to mind. But instead, a patch. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: set owner of cpu and vm file operationsChristian Borntraeger
There is a race between a "close of the file descriptors" and module unload in the kvm module. You can easily trigger this problem by applying this debug patch: >--- kvm.orig/virt/kvm/kvm_main.c >+++ kvm/virt/kvm/kvm_main.c >@@ -648,10 +648,14 @@ void kvm_free_physmem(struct kvm *kvm) > kvm_free_physmem_slot(&kvm->memslots[i], NULL); > } > >+#include <linux/delay.h> > static void kvm_destroy_vm(struct kvm *kvm) > { > struct mm_struct *mm = kvm->mm; > >+ printk("off1\n"); >+ msleep(5000); >+ printk("off2\n"); > spin_lock(&kvm_lock); > list_del(&kvm->vm_list); > spin_unlock(&kvm_lock); and killing the userspace, followed by an rmmod. The problem is that kvm_destroy_vm can run while the module count is 0. That means, you can remove the module while kvm_destroy_vm is running. But kvm_destroy_vm is part of the module text. This causes a kerneloops. The race exists without the msleep but is much harder to trigger. This patch requires the fix for anon_inodes (anon_inodes: use fops->owner for module refcount). With this patch, we can set the owner of all anonymous KVM inodes file operations. The VFS will then control the KVM module refcount as long as there is an open file. kvm_destroy_vm will be called by the release function of the last closed file - before the VFS drops the module refcount. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Really remove a slot when a user ask us soGlauber Costa
Right now, KVM does not remove a slot when we do a register ioctl for size 0 (would be the expected behaviour). Instead, we only mark it as empty, but keep all bitmaps and allocated data structures present. It completely nullifies our chances of reusing that same slot again for mapping a different piece of memory. In this patch, we destroy rmaps, and vfree() the pointers that used to hold the dirty bitmap, rmap and lpage_info structures. Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: split out kvm_free_assigned_irq()Mark McLoughlin
Split out the logic corresponding to undoing assign_irq() and clean it up a bit. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: add KVM_USERSPACE_IRQ_SOURCE_ID assertionsMark McLoughlin
Make sure kvm_request_irq_source_id() never returns KVM_USERSPACE_IRQ_SOURCE_ID. Likewise, check that kvm_free_irq_source_id() never accepts KVM_USERSPACE_IRQ_SOURCE_ID. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: don't free an unallocated irq source idMark McLoughlin
Set assigned_dev->irq_source_id to -1 so that we can avoid freeing a source ID which we never allocated. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: make kvm_unregister_irq_ack_notifier() safeMark McLoughlin
We never pass a NULL notifier pointer here, but we may well pass a notifier struct which hasn't previously been registered. Guard against this by using hlist_del_init() which will not do anything if the node hasn't been added to the list and, when removing the node, will ensure that a subsequent call to hlist_del_init() will be fine too. Fixes an oops seen when an assigned device is freed before and IRQ is assigned to it. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: remove the IRQ ACK notifier assertionsMark McLoughlin
We will obviously never pass a NULL struct kvm_irq_ack_notifier* to this functions. They are always embedded in the assigned device structure, so the assertion add nothing. The irqchip_in_kernel() assertion is very out of place - clearly this little abstraction needs to know nothing about the upper layer details. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: fix sparse warningHannes Eder
Impact: make global function static virt/kvm/kvm_main.c:85:6: warning: symbol 'kvm_rebooting' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Prevent trace call into unloaded module textWu Fengguang
Add marker_synchronize_unregister() before module unloading. This prevents possible trace calls into unloaded module text. Signed-off-by: Wu Fengguang <wfg@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: MSI to INTx translateSheng Yang
Now we use MSI as default one, and translate MSI to INTx when guest need INTx rather than MSI. For legacy device, we provide support for non-sharing host IRQ. Provide a parameter msi2intx for this method. The value is true by default in x86 architecture. We can't guarantee this mode can work on every device, but for most of us tested, it works. If your device encounter some trouble with this mode, you can try set msi2intx modules parameter to 0. If the device is OK with msi2intx=0, then please report it to KVM mailing list or me. We may prepare a blacklist for the device that can't work in this mode. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Enable MSI for device assignmentSheng Yang
We enable guest MSI and host MSI support in this patch. The userspace want to enable MSI should set KVM_DEV_IRQ_ASSIGN_ENABLE_MSI in the assigned_irq's flag. Function would return -ENOTTY if can't enable MSI, userspace shouldn't set MSI Enable bit when KVM_ASSIGN_IRQ return -ENOTTY with KVM_DEV_IRQ_ASSIGN_ENABLE_MSI. Userspace can tell the support of MSI device from #ifdef KVM_CAP_DEVICE_MSI. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Add assigned_device_msi_dispatch()Sheng Yang
The function is used to dispatch MSI to lapic according to MSI message address and message data. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Export ioapic_get_delivery_bitmaskSheng Yang
It would be used for MSI in device assignment, for MSI dispatch. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Clean up assigned_device_update_irqSheng Yang
2008-12-31KVM: Replace irq_requested with more generic irq_requested_typeSheng Yang
Separate guest irq type and host irq type, for we can support guest using INTx with host using MSI (but not opposite combination). Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Separate update irq to a single functionSheng Yang
Separate INTx enabling part to a independence function, so that we can add MSI enabling part easily. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Move ack notifier register and IRQ sourcd ID requestSheng Yang
Distinguish common part for device assignment and INTx part, perparing for refactor later. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Fix kernel allocated memory slotSheng Yang
Commit 7fd49de9773fdcb7b75e823b21c1c5dc1e218c14 "KVM: ensure that memslot userspace addresses are page-aligned" broke kernel space allocated memory slot, for the userspace_addr is invalid. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: ensure that memslot userspace addresses are page-alignedHollis Blanchard
Bad page translation and silent guest failure ensue if the userspace address is not page-aligned. I hit this problem using large (host) pages with qemu, because qemu currently has a hardcoded 4096-byte alignment for guest memory allocations. Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: MMU: Fix aliased gfns treated as unaliasedIzik Eidus
Some areas of kvm x86 mmu are using gfn offset inside a slot without unaliasing the gfn first. This patch makes sure that the gfn will be unaliased and add gfn_to_memslot_unaliased() to save the calculating of the gfn unaliasing in case we have it unaliased already. Signed-off-by: Izik Eidus <ieidus@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Enable Function Level Reset for assigned deviceSheng Yang
Ideally, every assigned device should in a clear condition before and after assignment, so that the former state of device won't affect later work. Some devices provide a mechanism named Function Level Reset, which is defined in PCI/PCI-e document. We should execute it before and after device assignment. (But sadly, the feature is new, and most device on the market now don't support it. We are considering using D0/D3hot transmit to emulate it later, but not that elegant and reliable as FLR itself.) [Update: Reminded by Xiantao, execute FLR after we ensure that the device can be assigned to the guest.] Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: IRQ ACK notifier should be used with in-kernel irqchipSheng Yang
Also remove unnecessary parameter of unregister irq ack notifier. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Kick NMI receiving VCPUJan Kiszka
Kick the NMI receiving VCPU in case the triggering caller runs in a different context. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-28KVM: Fix guest shared interrupt with in-kernel irqchipSheng Yang
Every call of kvm_set_irq() should offer an irq_source_id, which is allocated by kvm_request_irq_source_id(). Based on irq_source_id, we identify the irq source and implement logical OR for shared level interrupts. The allocated irq_source_id can be freed by kvm_free_irq_source_id(). Currently, we support at most sizeof(unsigned long) different irq sources. [Amit: - rebase to kvm.git HEAD - move definition of KVM_USERSPACE_IRQ_SOURCE_ID to common file - move kvm_request_irq_source_id to the update_irq ioctl] [Xiantao: - Add kvm/ia64 stuff and make it work for kvm/ia64 guests] Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-15KVM: Move irqchip_in_kernel() from ioapic.h to irq.hXiantao Zhang
Moving irqchip_in_kernel() from ioapic.h to irq.h. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Separate irq ack notification out of arch/x86/kvm/irq.cXiantao Zhang
Moving irq ack notification logic as common, and make it shared with ia64 side. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-10-15KVM: Change is_mmio_pfn to kvm_is_mmio_pfn, and make it common for all archsXiantao Zhang
Add a kvm_ prefix to avoid polluting kernel's name space. Signed-off-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Avi Kivity <avi@qumranet.com>
