commit 2ea75be3219571d0ec009ce20d9971e54af96e09 upstream.
vcpu ioctls can hang the calling thread if issued while a vcpu is running.
However, invalid ioctls can happen when userspace tries to probe the kind
of file descriptors (e.g. isatty() calls ioctl(TCGETS)); in that case,
we know the ioctl is going to be rejected as invalid anyway and we can
fail before trying to take the vcpu mutex.
This patch does not change functionality, it just makes invalid ioctls
fail faster.
Signed-off-by: David Matlack <dmatlack@google.com>
commit 00f034a12fdd81210d58116326d92780aac5c238 upstream.
The next patch will give a meaning (a la seqcount) to the low bit of the
generation number. Ensure that it matches between kvm->memslots->generation
and kvm_current_mmio_generation().
Reviewed-by: David Matlack <dmatlack@google.com>
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
commit ee3d1570b58677885b4552bce8217fda7b226a68 upstream.
vcpu exits and memslot mutations can run concurrently as long as the
vcpu does not aquire the slots mutex. Thus it is theoretically possible
for memslots to change underneath a vcpu that is handling an exit.
If we increment the memslot generation number again after
synchronize_srcu_expedited(), vcpus can safely cache memslot generation
without maintaining a single rcu_dereference through an entire vm exit.
And much of the x86/kvm code does not maintain a single rcu_dereference
of the current memslots during each exit.
We can prevent the following case:
vcpu (CPU 0) | thread (CPU 1)
1 vm exit |
2 srcu_read_unlock(&kvm->srcu) |
3 decide to cache something based on |
old memslots |
4 | change memslots
| (increments generation)
5 | synchronize_srcu(&kvm->srcu);
6 retrieve generation # from new memslots |
7 tag cache with new memslot generation |
8 srcu_read_unlock(&kvm->srcu) |
<action based on cache occurs even |
though the caching decision was based |
on the old memslots> |
<action *continues* to occur until next |
memslot generation change, which may |
be never> |
By incrementing the generation after synchronizing with kvm->srcu readers,
we ensure that the generation retrieved in (6) will become invalid soon
after (8).
Keeping the existing increment is not strictly necessary, but we
do keep it and just move it for consistency from update_memslots to
install_new_memslots. It invalidates old cached MMIOs immediately,
instead of having to wait for the end of synchronize_srcu_expedited,
which makes the code more clearly correct in case CPU 1 is preempted
right after synchronize_srcu() returns.
To avoid halving the generation space in SPTEs, always presume that the
low bit of the generation is zero when reconstructing a generation number
out of an SPTE. This effectively disables MMIO caching in SPTEs during
the call to synchronize_srcu_expedited. Using the low bit this way is
somewhat like a seqcount---where the protected thing is a cache, and
instead of retrying we can simply punt if we observe the low bit to be 1.
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
Fixes unaligned access to the gicv2 virtual cpu status.
We were using an atomic bitop on the vgic_v2.vgic_elrsr field which was
not aligned to the natural size on 64-bit platforms. This bug showed up
after QEMU correctly identifies the pl011 line as being level-triggered,
and not edge-triggered.
These data structures are protected by a spinlock so simply use a
non-atomic version of the accessor instead.
Tested-by: Joel Schopp <joel.schopp@amd.com>
Reported-by: Riku Voipio <riku.voipio@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Correct a simple mistake of checking the wrong variable
before a dereference, resulting in the dereference not being
properly protected by rcu_dereference().
Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com>
Read-only memory ranges may be backed by the zero page, so avoid
misidentifying it a a MMIO pfn.
This fixes another issue I identified when testing QEMU+KVM_UEFI, where
a read to an uninitialized emulated NOR flash brought in the zero page,
but mapped as a read-write device region, because kvm_is_mmio_pfn()
misidentifies it as a MMIO pfn due to its PG_reserved bit being set.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Fixes: b88657674d39 ("ARM: KVM: user_mem_abort: support stage 2 MMIO page mapping")
As a generic function, deassign_guest_irq() assumes it can be called
even if assign_guest_irq() is not be called successfully (which can be
triggered by ioctl from user mode, indirectly).
So for assign_guest_irq() failure process, need set 'dev->irq_source_id'
to -1 after free 'dev->irq_source_id', or deassign_guest_irq() may free
it again.
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
The third parameter of kvm_iommu_put_pages is wrong,
It should be 'gfn - slot->base_gfn'.
By making gfn very large, malicious guest or userspace can cause kvm to
go to this error path, and subsequently to pass a huge value as size.
Alternatively if gfn is small, then pages would be pinned but never
unpinned, causing host memory leak and local DOS.
Passing a reasonable but large value could be the most dangerous case,
because it would unpin a page that should have stayed pinned, and thus
allow the device to DMA into arbitrary memory. However, this cannot
happen because of the condition that can trigger the error:
- out of memory (where you can't allocate even a single page)
should not be possible for the attacker to trigger
- when exceeding the iommu's address space, guest pages after gfn
will also exceed the iommu's address space, and inside
kvm_iommu_put_pages() the iommu_iova_to_phys() will fail. The
page thus would not be unpinned at all.
Reported-by: Jack Morgenstein <jackm@mellanox.com>
Cc: stable@vger.kernel.org
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Commits e4d57e1ee1ab (KVM: Move irq notifier implementation into
eventfd.c, 2014-06-30) included the irq notifier code unconditionally
in eventfd.c, while it was under CONFIG_HAVE_KVM_IRQCHIP before.
Similarly, commit 297e21053a52 (KVM: Give IRQFD its own separate enabling
Kconfig option, 2014-06-30) moved code from CONFIG_HAVE_IRQ_ROUTING
to CONFIG_HAVE_KVM_IRQFD but forgot to move the pieces that used to be
under CONFIG_HAVE_KVM_IRQCHIP.
Together, this broke compilation without CONFIG_KVM_XICS. Fix by adding
or changing the #ifdefs so that they point at CONFIG_HAVE_KVM_IRQFD.
Currently, the IRQFD code is conditional on CONFIG_HAVE_KVM_IRQ_ROUTING.
So that we can have the IRQFD code compiled in without having the
IRQ routing code, this creates a new CONFIG_HAVE_KVM_IRQFD, makes
the IRQFD code conditional on it instead of CONFIG_HAVE_KVM_IRQ_ROUTING,
and makes all the platforms that currently select HAVE_KVM_IRQ_ROUTING
also select HAVE_KVM_IRQFD.
Tested-by: Eric Auger <eric.auger@linaro.org>
Tested-by: Cornelia Huck <cornelia.huck@de.ibm.com>
This moves the functions kvm_irq_has_notifier(), kvm_notify_acked_irq(),
kvm_register_irq_ack_notifier() and kvm_unregister_irq_ack_notifier()
from irqchip.c to eventfd.c. The reason for doing this is that those
functions are used in connection with IRQFDs, which are implemented in
eventfd.c. In future we will want to use IRQFDs on platforms that
don't implement the GSI routing implemented in irqchip.c, so we won't
be compiling in irqchip.c, but we still need the irq notifiers. The
implementation is unchanged.
Now that struct _irqfd does not keep a reference to storage pointed
to by the irq_routing field of struct kvm, we can move the statement
that updates it out from under the irqfds.lock and put it in
kvm_set_irq_routing() instead. That means we then have to take a
srcu_read_lock on kvm->irq_srcu around the irqfd_update call in
kvm_irqfd_assign(), since holding the kvm->irqfds.lock no longer
ensures that that the routing can't change.
Combined with changing kvm_irq_map_gsi() and kvm_irq_map_chip_pin()
to take a struct kvm * argument instead of the pointer to the routing
table, this allows us to to move all references to kvm->irq_routing
into irqchip.c. That in turn allows us to move the definition of the
kvm_irq_routing_table struct into irqchip.c as well.
This provides accessor functions for the KVM interrupt mappings, in
order to reduce the amount of code that accesses the fields of the
kvm_irq_routing_table struct, and restrict that code to one file,
virt/kvm/irqchip.c. The new functions are kvm_irq_map_gsi(), which
maps from a global interrupt number to a set of IRQ routing entries,
and kvm_irq_map_chip_pin, which maps from IRQ chip and pin numbers to
a global interrupt number.
This also moves the update of kvm_irq_routing_table::chip[][]
into irqchip.c, out of the various kvm_set_routing_entry
implementations. That means that none of the kvm_set_routing_entry
implementations need the kvm_irq_routing_table argument anymore,
so this removes it.
This does not change any locking or data lifetime rules.
This makes the irqfd code keep a copy of the irq routing table entry
for each irqfd, rather than a reference to the copy in the actual
irq routing table maintained in kvm/virt/irqchip.c. This will enable
us to change the routing table structure in future, or even not have a
routing table at all on some platforms.
The synchronization that was previously achieved using srcu_dereference
on the read side is now achieved using a seqcount_t structure. That
ensures that we don't get a halfway-updated copy of the structure if
we read it while another thread is updating it.
We still use srcu_read_lock/unlock around the read side so that when
changing the routing table we can be sure that after calling
synchronize_srcu, nothing will be using the old routing.
Patch queue for ppc - 2014-08-01
Highlights in this release include:
- BookE: Rework instruction fetch, not racy anymore now
- BookE HV: Fix ONE_REG accessors for some in-hardware registers
- Book3S: Good number of LE host fixes, enable HV on LE
- Book3S: Some misc bug fixes
- Book3S HV: Add in-guest debug support
- Book3S HV: Preload cache lines on context switch
- Remove 440 support
Alexander Graf (31):
KVM: PPC: Book3s PR: Disable AIL mode with OPAL
KVM: PPC: Book3s HV: Fix tlbie compile error
KVM: PPC: Book3S PR: Handle hyp doorbell exits
KVM: PPC: Book3S PR: Fix ABIv2 on LE
KVM: PPC: Book3S PR: Fix sparse endian checks
PPC: Add asm helpers for BE 32bit load/store
KVM: PPC: Book3S HV: Make HTAB code LE host aware
KVM: PPC: Book3S HV: Access guest VPA in BE
KVM: PPC: Book3S HV: Access host lppaca and shadow slb in BE
KVM: PPC: Book3S HV: Access XICS in BE
KVM: PPC: Book3S HV: Fix ABIv2 on LE
KVM: PPC: Book3S HV: Enable for little endian hosts
KVM: PPC: Book3S: Move vcore definition to end of kvm_arch struct
KVM: PPC: Deflect page write faults properly in kvmppc_st
KVM: PPC: Book3S: Stop PTE lookup on write errors
KVM: PPC: Book3S: Add hack for split real mode
KVM: PPC: Book3S: Make magic page properly 4k mappable
KVM: PPC: Remove 440 support
KVM: Rename and add argument to check_extension
KVM: Allow KVM_CHECK_EXTENSION on the vm fd
KVM: PPC: Book3S: Provide different CAPs based on HV or PR mode
KVM: PPC: Implement kvmppc_xlate for all targets
KVM: PPC: Move kvmppc_ld/st to common code
KVM: PPC: Remove kvmppc_bad_hva()
KVM: PPC: Use kvm_read_guest in kvmppc_ld
KVM: PPC: Handle magic page in kvmppc_ld/st
KVM: PPC: Separate loadstore emulation from priv emulation
KVM: PPC: Expose helper functions for data/inst faults
KVM: PPC: Remove DCR handling
KVM: PPC: HV: Remove generic instruction emulation
KVM: PPC: PR: Handle FSCR feature deselects
Alexey Kardashevskiy (1):
KVM: PPC: Book3S: Fix LPCR one_reg interface
Aneesh Kumar K.V (4):
KVM: PPC: BOOK3S: PR: Fix PURR and SPURR emulation
KVM: PPC: BOOK3S: PR: Emulate virtual timebase register
KVM: PPC: BOOK3S: PR: Emulate instruction counter
KVM: PPC: BOOK3S: HV: Update compute_tlbie_rb to handle 16MB base page
Anton Blanchard (2):
KVM: PPC: Book3S HV: Fix ABIv2 indirect branch issue
KVM: PPC: Assembly functions exported to modules need _GLOBAL_TOC()
Bharat Bhushan (10):
kvm: ppc: bookehv: Added wrapper macros for shadow registers
kvm: ppc: booke: Use the shared struct helpers of SRR0 and SRR1
kvm: ppc: booke: Use the shared struct helpers of SPRN_DEAR
kvm: ppc: booke: Add shared struct helpers of SPRN_ESR
kvm: ppc: booke: Use the shared struct helpers for SPRN_SPRG0-7
kvm: ppc: Add SPRN_EPR get helper function
kvm: ppc: bookehv: Save restore SPRN_SPRG9 on guest entry exit
KVM: PPC: Booke-hv: Add one reg interface for SPRG9
KVM: PPC: Remove comment saying SPRG1 is used for vcpu pointer
KVM: PPC: BOOKEHV: rename e500hv_spr to bookehv_spr
Michael Neuling (1):
KVM: PPC: Book3S HV: Add H_SET_MODE hcall handling
Mihai Caraman (8):
KVM: PPC: e500mc: Enhance tlb invalidation condition on vcpu schedule
KVM: PPC: e500: Fix default tlb for victim hint
KVM: PPC: e500: Emulate power management control SPR
KVM: PPC: e500mc: Revert "add load inst fixup"
KVM: PPC: Book3e: Add TLBSEL/TSIZE defines for MAS0/1
KVM: PPC: Book3s: Remove kvmppc_read_inst() function
KVM: PPC: Allow kvmppc_get_last_inst() to fail
KVM: PPC: Bookehv: Get vcpu's last instruction for emulation
Paul Mackerras (4):
KVM: PPC: Book3S: Controls for in-kernel sPAPR hypercall handling
KVM: PPC: Book3S: Allow only implemented hcalls to be enabled or disabled
KVM: PPC: Book3S PR: Take SRCU read lock around RTAS kvm_read_guest() call
KVM: PPC: Book3S: Make kvmppc_ld return a more accurate error indication
Stewart Smith (2):
Split out struct kvmppc_vcore creation to separate function
Use the POWER8 Micro Partition Prefetch Engine in KVM HV on POWER8
Documentation/virtual/kvm/api.txt
KVM/ARM New features for 3.17 include:
- Fixes and code refactoring for stage2 kvm MMU unmap_range
- Support unmapping IPAs on deleting memslots for arm and arm64
- Support MMIO mappings in stage2 faults
- KVM VGIC v2 emulation on GICv3 hardware
- Big-Endian support for arm/arm64 (guest and host)
- Debug Architecture support for arm64 (arm32 is on Christoffer's todo list)
virt/kvm/arm/vgic.c [last minute cherry-pick from 3.17 to 3.16]
Pull KVM changes from Paolo Bonzini:
"These are the x86, MIPS and s390 changes; PPC and ARM will come in a
few days.
MIPS and s390 have little going on this release; just bugfixes, some
small, some larger.
The highlights for x86 are nested VMX improvements (Jan Kiszka),
optimizations for old processor (up to Nehalem, by me and Bandan Das),
and a lot of x86 emulator bugfixes (Nadav Amit).
Stephen Rothwell reported a trivial conflict with the tracing branch"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (104 commits)
x86/kvm: Resolve shadow warnings in macro expansion
KVM: s390: rework broken SIGP STOP interrupt handling
KVM: x86: always exit on EOIs for interrupts listed in the IOAPIC redir table
KVM: vmx: remove duplicate vmx_mpx_supported() prototype
KVM: s390: Fix memory leak on busy SIGP stop
x86/kvm: Resolve shadow warning from min macro
kvm: Resolve missing-field-initializers warnings
Replace NR_VMX_MSR with its definition
KVM: x86: Assertions to check no overrun in MSR lists
KVM: x86: set rflags.rf during fault injection
KVM: x86: Setting rflags.rf during rep-string emulation
KVM: x86: DR6/7.RTM cannot be written
KVM: nVMX: clean up nested_release_vmcs12 and code around it
KVM: nVMX: fix lifetime issues for vmcs02
KVM: x86: Defining missing x86 vectors
KVM: x86: emulator injects #DB when RFLAGS.RF is set
KVM: x86: Cleanup of rflags.rf cleaning
KVM: x86: Clear rflags.rf on emulated instructions
KVM: x86: popf emulation should not change RF
KVM: x86: Clearing rflags.rf upon skipped emulated instruction
Just like GICv2 was fixed in 63afbe7a0ac1
(kvm: arm64: vgic: fix hyp panic with 64k pages on juno platform),
mandate the GICV region to be both aligned on a page boundary and
its size to be a multiple of page size.
This prevents a guest from being able to poke at regions where we
have no idea what is sitting there.
Currently, the EOI exit bitmap (used for APICv) does not include
interrupts that are masked. However, this can cause a bug that manifests
as an interrupt storm inside the guest. Alex Williamson reported the
bug and is the one who really debugged this; I only wrote the patch. :)
The scenario involves a multi-function PCI device with OHCI and EHCI
USB functions and an audio function, all assigned to the guest, where
both USB functions use legacy INTx interrupts.
As soon as the guest boots, interrupts for these devices turn into an
interrupt storm in the guest; the host does not see the interrupt storm.
Basically the EOI path does not work, and the guest continues to see the
interrupt over and over, even after it attempts to mask it at the APIC.
The bug is only visible with older kernels (RHEL6.5, based on 2.6.32
with not many changes in the area of APIC/IOAPIC handling).
Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ)
on in the eoi_exit_bitmap and TMR, and things then work. What happens
is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap.
It does not have set bit 59 because the RTE was masked, so the IOAPIC
never sees the EOI and the interrupt continues to fire in the guest.
My guess was that the guest is masking the interrupt in the redirection
table in the interrupt routine, i.e. while the interrupt is set in a
LAPIC's ISR, The simplest fix is to ignore the masking state, we would
rather have an unnecessary exit rather than a missed IRQ ACK and anyway
IOAPIC interrupts are not as performance-sensitive as for example MSIs.
Alex tested this patch and it fixed his bug.
[Thanks to Alex for his precise description of the problem
and initial debugging effort. A lot of the text above is
based on emails exchanged with him.]
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
If the physical address of GICV isn't page-aligned, then we end up
creating a stage-2 mapping of the page containing it, which causes us to
map neighbouring memory locations directly into the guest.
As an example, consider a platform with GICV at physical 0x2c02f000
running a 64k-page host kernel. If qemu maps this into the guest at
0x80010000, then guest physical addresses 0x80010000 - 0x8001efff will
map host physical region 0x2c020000 - 0x2c02efff. Accesses to these
physical regions may cause UNPREDICTABLE behaviour, for example, on the
Juno platform this will cause an SError exception to EL3, which brings
down the entire physical CPU resulting in RCU stalls / HYP panics / host
crashing / wasted weeks of debugging.
SBSA recommends that systems alias the 4k GICV across the bounding 64k
region, in which case GICV physical could be described as 0x2c020000 in
the above scenario.
This patch fixes the problem by failing the vgic probe if the physical
base address or the size of GICV aren't page-aligned. Note that this
generated a warning in dmesg about freeing enabled IRQs, so I had to
move the IRQ enabling later in the probe.
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Joel Schopp <joel.schopp@amd.com>
Cc: Don Dutile <ddutile@redhat.com>
Acked-by: Peter Maydell <peter.maydell@linaro.org>
Acked-by: Joel Schopp <joel.schopp@amd.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
The KVM_CHECK_EXTENSION is only available on the kvm fd today. Unfortunately
on PPC some of the capabilities change depending on the way a VM was created.
So instead we need a way to expose capabilities as VM ioctl, so that we can
see which VM type we're using (HV or PR). To enable this, add the
KVM_CHECK_EXTENSION ioctl to our vm ioctl portfolio.
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
In preparation to make the check_extension function available to VM scope
we add a struct kvm * argument to the function header and rename the function
accordingly. It will still be called from the /dev/kvm fd, but with a NULL
argument for struct kvm *.
Resolve missing-field-initializers warnings seen in W=2 kernel
builds by having macros generate more elaborated initializers.
That is enough to silence the warnings.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Fix vgic_bitmap_get_reg function to return 'right' word address of
'unsigned long' bitmap value in case of BE 64bit image.
Signed-off-by: Victor Kamensky <victor.kamensky@linaro.org>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
According to recent clarifications of mmio.data array meaning -
the mmio.data array should hold bytes as they would appear in
memory. Vgic is little endian device. And in case of BE image
kernel side that emulates vgic, holds data in BE form. So we
need to byteswap cpu<->le32 vgic registers when we read/write them
from mmio.data[].
Change has no effect in LE case because cpu already runs in le32.
Add the last missing bits that enable GICv2 emulation on top of
GICv3 hardware.
Introduce the support code for emulating a GICv2 on top of GICv3
hardware.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Move the GICv2 world switch code into its own file, and add the
necessary indirection to the arm64 switch code.
Also introduce a new type field to the vgic_params structure.
So far, irqchip_in_kernel() was implemented by testing the value of
vctrl_base, which worked fine with GICv2.
With GICv3, this field is useless, as we're using system registers
instead of a emmory mapped interface. To solve this, add a boolean
flag indicating if the we're using a vgic or not.
Brutally hack the innocent vgic code, and move the GICv2 specific code
to its own file, using vgic_ops and vgic_params as a way to pass
information between the two blocks.
Move all the data specific to a given GIC implementation into its own
little structure.
Move the code dealing with enabling the VGIC on to vgic_ops.
Instead of directly messing with with the GICH_VMCR bits for the CPU
interface save/restore code, add accessors that encode/decode the
entire set of registers exposed by VMCR.
Not the most efficient thing, but given that this code is only used
by the save/restore code, performance is far from being critical.
Move the code dealing with LR underflow handling to its own functions,
and make them accessible through vgic_ops.
Instead of directly dealing with the GICH_MISR bits, move the code to
its own function and use a couple of public flags to represent the
actual state.
Move the GICH_EISR access to its own function.
Move the GICH_ELRSR access to its own functions, and add them to
the vgic_ops structure.
In order to split the various register manipulation from the main vgic
code, introduce a vgic_ops structure, and start by abstracting the
LR manipulation code with a couple of accessors.
In order to make way for the GICv3 registers, move the v2-specific
registers to their own structure.
Pull more scheduler updates from Ingo Molnar:
"Second round of scheduler changes:
- try-to-wakeup and IPI reduction speedups, from Andy Lutomirski
- continued power scheduling cleanups and refactorings, from Nicolas
Pitre
- misc fixes and enhancements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/deadline: Delete extraneous extern for to_ratio()
sched/idle: Optimize try-to-wake-up IPI
sched/idle: Simplify wake_up_idle_cpu()
sched/idle: Clear polling before descheduling the idle thread
sched, trace: Add a tracepoint for IPI-less remote wakeups
cpuidle: Set polling in poll_idle
sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...)
sched: Rename capacity related flags
sched: Final power vs. capacity cleanups
sched: Remove remaining dubious usage of "power"
sched: Let 'struct sched_group_power' care about CPU capacity
sched/fair: Disambiguate existing/remaining "capacity" usage
sched/fair: Change "has_capacity" to "has_free_capacity"
sched/fair: Remove "power" from 'struct numa_stats'
sched: Fix signedness bug in yield_to()
sched/fair: Use time_after() in record_wakee()
sched/balancing: Reduce the rate of needless idle load balancing
sched/fair: Fix unlocked reads of some cfs_b->quota/period
yield_to() is supposed to return -ESRCH if there is no task to
yield to, but because the type is bool that is the same as returning
true.
The only place I see which cares is kvm_vcpu_on_spin().
Reviewed-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: kvm@vger.kernel.org
Link: http://lkml.kernel.org/r/20140523102042.GA7267@mwanda
Pull KVM updates from Paolo Bonzini:
"At over 200 commits, covering almost all supported architectures, this
was a pretty active cycle for KVM. Changes include:
- a lot of s390 changes: optimizations, support for migration, GDB
support and more
- ARM changes are pretty small: support for the PSCI 0.2 hypercall
interface on both the guest and the host (the latter acked by
Catalin)
- initial POWER8 and little-endian host support
- support for running u-boot on embedded POWER targets
- pretty large changes to MIPS too, completing the userspace
interface and improving the handling of virtualized timer hardware
- for x86, a larger set of changes is scheduled for 3.17. Still, we
have a few emulator bugfixes and support for running nested
fully-virtualized Xen guests (para-virtualized Xen guests have
always worked). And some optimizations too.
The only missing architecture here is ia64. It's not a coincidence
that support for KVM on ia64 is scheduled for removal in 3.17"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (203 commits)
KVM: add missing cleanup_srcu_struct
KVM: PPC: Book3S PR: Rework SLB switching code
KVM: PPC: Book3S PR: Use SLB entry 0
KVM: PPC: Book3S HV: Fix machine check delivery to guest
KVM: PPC: Book3S HV: Work around POWER8 performance monitor bugs
KVM: PPC: Book3S HV: Make sure we don't miss dirty pages
KVM: PPC: Book3S HV: Fix dirty map for hugepages
KVM: PPC: Book3S HV: Put huge-page HPTEs in rmap chain for base address
KVM: PPC: Book3S HV: Fix check for running inside guest in global_invalidates()
KVM: PPC: Book3S: Move KVM_REG_PPC_WORT to an unused register number
KVM: PPC: Book3S: Add ONE_REG register names that were missed
KVM: PPC: Add CAP to indicate hcall fixes
KVM: PPC: MPIC: Reset IRQ source private members
KVM: PPC: Graciously fail broken LE hypercalls
PPC: ePAPR: Fix hypercall on LE guest
KVM: PPC: BOOK3S: Remove open coded make_dsisr in alignment handler
KVM: PPC: BOOK3S: Always use the saved DAR value
PPC: KVM: Make NX bit available with magic page
KVM: PPC: Disable NX for old magic page using guests
KVM: PPC: BOOK3S: HV: Add mixed page-size support for guest
Reported-by: hrg <hrgstephen@gmail.com>
When starting lots of dataplane devices the bootup takes very long on
Christian's s390 with irqfd patches. With larger setups he is even
able to trigger some timeouts in some components. Turns out that the
KVM_SET_GSI_ROUTING ioctl takes very long (strace claims up to 0.1 sec)
when having multiple CPUs. This is caused by the synchronize_rcu and
the HZ=100 of s390. By changing the code to use a private srcu we can
speed things up. This patch reduces the boot time till mounting root
from 8 to 2 seconds on my s390 guest with 100 disks.
Uses of hlist_for_each_entry_rcu, hlist_add_head_rcu, hlist_del_init_rcu
are fine because they do not have lockdep checks (hlist_for_each_entry_rcu
uses rcu_dereference_raw rather than rcu_dereference, and write-sides
do not do rcu lockdep at all).
Note that we're hardly relying on the "sleepable" part of srcu. We just
want SRCU's faster detection of grace periods.
Testing was done by Andrew Theurer using netperf tests STREAM, MAERTS
and RR. The difference between results "before" and "after" the patch
has mean -0.2% and standard deviation 0.6%. Using a paired t-test on the
data points says that there is a 2.5% probability that the patch is the
cause of the performance difference (rather than a random fluctuation).
(Restricting the t-test to RR, which is the most likely to be affected,
changes the numbers to respectively -0.3% mean, 0.7% stdev, and 8%
probability that the numbers actually say something about the patch.
The probability increases mostly because there are fewer data points).
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> # s390
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
First round of KVM/ARM Fixes for 3.15
Includes vgic fixes, a possible kernel corruption bug due to
misalignment of pages and disabling of KVM in KConfig on big-endian
systems, because the last one breaks the build.
base address.
Currently below check in vgic_ioaddr_overlap will always succeed,
because the vgic dist base and vgic cpu base are still kept UNDEF
after initialization. The code as follows will be return forever.
if (IS_VGIC_ADDR_UNDEF(dist) || IS_VGIC_ADDR_UNDEF(cpu))
return 0;
So, before invoking the vgic_ioaddr_overlap, it needs to set the
corresponding base address firstly.
Signed-off-by: Haibin Wang <wanghaibin.wang@huawei.com>
async_pf_execute() passes tsk == current to gup(), this is doesn't
hurt but unnecessary and misleading. "tsk" is only used to account
the number of faults and current is the random workqueue thread.
Suggested-by: Andrea Arcangeli <aarcange@redhat.com>
async_pf_execute() has no reasons to adopt apf->mm, gup(current, mm)
should work just fine even if current has another or NULL ->mm.
Recently kvm_async_page_present_sync() was added insedie the "use_mm"
section, but it seems that it doesn't need current->mm too.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Since KVM internally represents the ICFGR registers by stuffing two
of them into one word, the offset for accessing the internal
representation and the one for the MMIO based access are different.
So keep the original offset around, but adjust the internal array
offset by one bit.
Reported-by: Haibin Wang <wanghaibin.wang@huawei.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
