Fixes run.do_configure: line 172: glib-gettextize: command not found.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
change all recipe which fail out of tree builds to autotools-brokensep
Do not use symlink for configure.ac since autoconf don't like
both, configure.in and configure.ac in place.
Solves issue when building lxrandr with persistent work directory:
| mv: cannot stat '/build/linuxdev/yocto-autobuilder/yocto-worker/toradex/build/build/out-eglibc/work/armv7ahf-vfp-neon-angstrom-linux-gnueabi/lxrandr/0.1.2-r0/lxrandr-0.1.2/configure.in': No such file or directory
while at it, add attional DEPENDS for lxrandr
