Bump to latest LTS release Linux 5.4.6 plus Apalis T30/TK1 patches.
Bump to latest LTS release Linux 5.4.5.
(cherry picked from commit 2d635349eff45166feb4340c3008fd2a12f354cf)
Bump to latest LTS release Linux 5.4.2.
(cherry picked from commit 6e96e4c828b853edefbc9107680efa38c143c7f6)
This patch mainlay aims to refactor bootfs image function, use tar and
xz conversion functions to replace our own create_tezi_bootfs, the
benifit would be we could choose other compression type like Zstandard
easily by setting TEZI_BOOT_SUFFIX and TEZI_ROOT_SUFFIX for bootfs and
rootfs.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
The blank should be before the value rather than after it, or else we
risk on messing up the values by 'a b' > 'ab'.
The bootcmd variable is the entry point for regular boot. If booting
fails for some reason and one saves the environment at this point,
the next boot will no longer use distro boot. Often booting works
since the boot script setup all variables correctly, so one does not
notice that the boot flow has been altered/hard-coded.
Do not reuse bootcmd to avoid accidentally alter the boot flow.
(cherry picked from commit 98dbc9f5c52616618cbf722965ce2f5dd90409db)
Use OFFSET_SPL_PAYLOAD to decide if a SPL has to be deployed or not.
This allows a simple integration of machines which have an SPL (as e.g.
verdin-imx8mm has) but do aggregate the SPL and U-Boot proper into one
binary.
The list of deployed U-Boot artefacts is set in python for the 'distro'
tezi-image, but in the non 'distro' case directly in the tar command.
Unify that to put the list together in python.
The problem was within connman that constantly disables RF. So this
commit is not needed.
This reverts commit a64ff768b7d5d24360a1ac9bec67409f0daa931d.
systemd-rfkill disables by default our RF devices. We do not want them
to be disabled at all so remove that rfkill from systemd.
Set the package version to reflect the complete Linux kernel version
plus the git hash it has been built from.
This could be done in the inc file only once, however, the Yocto
kernel recipes set PV in the individual recipies as well. The close
proximity to LINUX_VERSION also makes it obvious what PV will be.
If DISTRO_FLAVOUR is not set, then the string '${DISTRO_FLAVOUR}' is
appended.
Fix this by providing a weak default.
Fixes commit 3d072f3077b6.
So that one sees in the Toradex Easy Installer which image is which.
The image recipes do not really support rm_work, I have observed a lot
of build issues when I modified some do_image tasks while do_rootfs not
touched, to give a example:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:buildinfo(d)
0003:
File: 'meta/classes/image-buildinfo.bbclass', lineno: 67, function: buildinfo
0063:# Write build information to target filesystem
0064:python buildinfo () {
0065: if not d.getVar('IMAGE_BUILDINFO_FILE'):
0066: return
*** 0067: with open(d.expand('${IMAGE_ROOTFS}${IMAGE_BUILDINFO_FILE}'), 'w') as build:
0068: build.writelines((
0069: '''-----------------------
0070:Build Configuration: |
0071:-----------------------
so we set RM_WORK_EXCLUDE to avoid running into those problems.
This patch mainly aims to reintroduce a old commit 1b5ef0c9:
[ image_type_tezi.bbclass: drop some useless code ]
which was reverted later on since it did not fix the problem, I
refactor that patch to really fix it.
I have observed this "basehash changed" issue quite often recently, it
could be reproduced easily by the following steps:
1 bitbake imagename
2 change your system time by one day ahead.
3 bitbake imagename
After debugging it with bitbake-diffsigs, I found it's still caused by
'DATE' variable changing, as follows:
| basehash changed from ecb5b34a4997e7f037f146932728f3eca9af34d70729e4c83cdd920dc21d7677 to
| 92ad5341f99ff3a56987f4ccdc34030d5aa3e3ea1365737b5a81a12e6eb83798
| Variable DATE value changed from '20190905' to '20190906'
our tricky fix of introducing 'TDX_VERDATE' does not really work,
actually it makes things worse, 'DATE' has been deleted when parsing
IMAGE_CMD_* tasks, which was introduced by commit 4af13a48 in OE:
[ image.bbclass: delete DATE variable too ]
which means DATE would not be expanded during recipe parsing, but
TDX_VERDATE would, so we should replace TDX_VERDATE with DATE in
IMAGE_CMD_teziimg and IMAGE_CMD_teziimg-distro tasks.
To fix this annoying issue, the key point is we should avoid
expanding 'DATE' during recipe parsing stage, or else the
vardepsexclude would not take effect since the 'DATE' has already
been expanded, so we should change a DATE reference in rootfs_tezi_json
function:
d.getVar('DATE') -> d.getVar('DATE', False)
And there is seems still some order issue when bitbake handle
vardepsexclude of IMAGE_CMD_* tasks, I have to explicitly set it
for do_image_teziimg and do_image_teziimg_distro.
With the above changes, the error does not show up again.
The TEZI_KERNEL_IMAGETYPE definition has been removed, however it is still
used in the code. Change that to use KERNEL_IMAGETYPE.
The results in image.json containing '"zImage"' instead of 'null' as the
kernel filename.
Fixes c1891e02dc9c.
Provide proper PARTUUID value in bootargs.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
The changes include:
- Introduce tezi_deploy_files helper function, it could be used to
install files listed in IMAGE_BOOT_FILES, the install logic is same
with how WIC handle IMAGE_BOOT_FILES.
- Use WKS_FILE_DEPENDS to handle the dependencies of do_image_teziimg
and do_image_teziimg_distro, when USING_WIC is not set, then we need
add WKS_FILE_DEPENDS to DEPENDS, or else it would be done in wic
image bbclass.
- Drop TEZI_KERNEL_IMAGETYPE and TEZI_KERNEL_DEVICETREE, now all the
boot files would be controlled by IMAGE_BOOT_FILES.
- Use ${IMAGE_LINK_NAME} instead of ${IMAGE_NAME}, to avoid including
DATETIME for torizon builds.
Patch has been verified on the following machines, the artifacts
generated with and wihtout the patch are identical:
- apalis-imx6
- apalis-imx8
- apalis-tk1
- apalis-tk1-mainline
- colibri-imx6
- colibri-imx6ull
- colibri-imx7
- colibri-imx8x
- Inherit nopackages since it does not generate any non-empty packages.
- Drop do_compile, we can run mkimage directly in do_deploy task.
- Drop 'S = "${WORKDIR}"', we do not have to explicitly set it, the
default S would be good enough.
- Do not install DEPLOYDIR, that is not necessary, it's already done
in deploy.bbclass.
- Do not set noexec flag to do_install, do_populate_sysroot, they are
basically empty tasks, making do_populate_sysroot noexec also will
cause QA warning when u-boot-distro-boot is set to DEPENDS in other
recipes.
There are quite a few common code being shared by rootfs_tezi_rawnand
and rootfs_tezi_distro_rawnand, we should merge them to a same function
to avoid being redundant.
Add initial version of a recipe to build the mainline based PREEMPT_RT
kernel for Toradex modules. This kernel has been maintained for
TorizonCore and is now moving to the official BSP. At this point the
kernel is working well for the platforms supported by TorizonCore,
but the hardware support hasn't been completed or verified.
The defconfig files are the same configurations as generated by the
TorizonCore kernel-cache (kernel configuration metadata) commit
fd3d3be08c05 ("features/usb-net: enable some LTE/GSM modems").
Add initial version of a recipe to build the mainline based kernel for
Toradex modules. This kernel has been maintained for TorizonCore and
is now moving to the official BSP. At this point the kernel is working
well for the platforms supported by TorizonCore, but the hardware
This creates a distro boot script boot.scr and deploys it into
the ${DEPLOYDIR}.
Moved here from meta-toradex-torizon u-boot-distro-boot-ostree.
(cherry picked from commit c4cf9254547ce4fc1d49c0802c152262a26de2ab)
Works around:
| WARNING: vulkan-1.1.73.0-r0 do_package_qa: QA Issue: vulkan-bin rdepends on libvulkan-imx, but it isn't a build dependency? [build-deps]
| ERROR: vulkan-1.1.73.0-r0 do_package_qa: QA Issue: /usr/bin/vulkaninfo contained in package vulkan-bin requires libvulkan.so.1()(64bit), but no providers found in RDEPENDS_vulkan-bin? [file-rdeps]
Add the product name at compile time so that we do not need to provide
slightly different copies of the file.
While at it set package arch to machine arch. The packages created are
machine specific due to the g1.schema file.
With thud I still see "basehash value changed" errors, even though the
commit e74158b6c is available in the OE thud branch.
This reverts commit 9f84ffa4b42b4d518191116614aef269ab227f0e.
Check whether argument two is given before passing it to basename.
This avoids build failure when building without deploying device
trees in the bootfs (e.g. TorizonCore).
The i.MX8 kernel is currently 20MB and doesn't fit in the hard coded 16MB
boot partition size.
Set the boot partition size dynamically to twice the payload size
rounded up to the next power of 2, but at least to 16MB.
The Apalis iMX8 needs additional firmware for HDMI in the boot partition.
Provide a new MACHINE_BOOT_FILES variable which adds to the list of to be
installed files.
We have generic prepare.sh and wrapup.sh scripts hence tezi-metadata
is buildable and useable for any machine.
(cherry picked from commit 746241667086b2572b6d446b243ace00a09228a8)
Replace hard-coded tar.xz by TEZI_ROOT_SUFFIX since the rootfs image
suffix is being controlled by that variable.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
(cherry picked from commit 88f649a1b13762024413ba57e87b58b3a6bb6812)
We currently have some tricky code intended to get rid of the
"basehash value changed" errors, but they are actually not needed.
Since the references to "DATE" only exist in image tasks or their
prefuncs, so they would be expanded at task executing time but not
recipe parsing time, a 'vardepsexclude' flag would be enough in this
case.
I guess the reason we introduced this piece of code was that we
found we still could see the annoying "basehash value changed" errors
with 'vardepsexclude' flag set at that moment, but that's probably was
not caused by our code, it's actually another issue now had been fixed
in OE by e74158b6cc1d683ab14ef5d47ec531f986fc2259:
[ rm_work: sort the value of do_build dependencies ]
We can safely drop these useless code per my test.
(cherry picked from commit 1b5ef0c9c3d5765622d45725d9fd64154cf27fed)
(cherry picked from commit e9cc1d5996eee20018979f4e54e2239393bd3142)
Aarch64 typically stores device trees in subdirectories, e.g.
freescale/fsl-imx8qm-apalis.dtb. However, the kernel-devicetree.bbclass
deploys those files without subdirectory. Make sure the Tezi image class
behaves like the kernel-devicetree.bbclass.
Actually the systemd-udevd.service file is not deployed with systemd-conf but
with systemd proper.
This reverts commit 118f6b1b17b61cebf933b52979c1598231b90014.
Including u-boot-toradex-initial-env.inc will generate a uEnv.txt
for newer U-Boot versions using U-Boot's u-boot-initial-env
Makfile target. It essential does what u-boot-toradex-env.inc did
before.
Note: Since there is now support for an exported environment in
upstream U-Boot, we should upstream the OE logic to the official
U-Boot too.
(cherry picked from commit 8109e0a87240489e6bc698e79f2cc748cbe40b17)
(cherry picked from commit d02ed084d1c4a13e77898affc1b48beabef956f4)
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
Backports based on 4.19 kernel.
(cherry picked from commit 78e1cdabe0baeb794945bd4926c28058f9f12aa9)
(cherry picked from commit 7070114ca207cdee388af9db3c698d8bb1ed907b)
(cherry picked from commit fba57b66b0a584e4625bce4b2a2fb400fbce6758)
(cherry picked from commit 56829b6d643fa5dfdac42c0adddf5d41e7fb982e)
This machine hasn't been used nor updated in years.
The SoM's are discontinued by now.
Drop it.
The default setting is now done in the distro.
The systemd configuration has been split from the systemd recipe.
Thus we need to move our changes to the systemd configuration.
While at it drop the kmod packageconfig. This was only needed with angstrom.
