In the Toradex Easy Installer we do not use the example programs
or configuration. Create a separate package for the library and
the example programs and configurations.
Don't use HEAD of branch for every build.
That way we get more reproduciable builds and the git fetcher will not access
the network on every build to check what the current HEAD actually is.
To clearly distinguish between images for Toradex Easy Installer
and legacy images we add the suffix -Tezi to the Toradex Easy
Installer images.
Use RFC 3339 date (2017-11-15) in the release_date field.
Use KERNEL_VERSION variable instad of running
make kernelversion
Use configurable rather than hard-coded boot ROM and SPL payload
offsets.
UBOOT_BINARY is only available in U-Boot recipes and the Toradex
image recipes. If the Toradex image recipes are not used, then
UBOOT_BINARY is undefined and image.json contains "null" instead of
the binary name.
Define UBOOT_BINARY with a reasonable default.
Generate the image description file just before the Tezi image
gets generated by attaching rootfs_tezi_json as a prefunc of
do_image. It should lead to better root file system size
estimation since all do_rootfs post processing functions have
been processed at that time.
It also allows to move the check whether an Tezi image will be
built into the anonymous python function. Later we should be
able to get rid of the check by just adding rootfs_tezi_json as
a prefunc of do_image_tezirun.
Without this, if nothing else makes sure that U-Boot got built
then image_type_tezi fails.
This can happen when one does build core-image-minimal.
| NOTE: Create bootfs tarball
| tar: SPL: Cannot stat: No such file or directory
So far a generic USB vendor and product ID has been used in the
Toradex specific schema files. However, the startup service wrote a
Toradex specific USB product ID. This lead to the awkward combination
of a generic USB vendor ID and Toradex specific product ID.
Use the Toradex vendor ID by default and do not specify the product ID
since it will get filled in by the usbg service.
This allows to use the same schema for Colibri iMX7 with raw
NAND and eMMC flash.
The utility to create ext4 file systems (mkfs.ext4) discards all
data on the target partition before creating the file system by
default. On some eMMC this operation takes a while several seconds
which makes flashing images slow.
Often a new image is written to a already (almost) empty eMMC, so
there is not a lot of value in discarding all data before flashing.
Also, the Toradex Easy Installer has its own option which uses
blkdiscard to discard blocks before writing (see "erase" option).
Disable discard during file system creation by default using the
nodiscard option.
Colibri iMX7 Dual 1GB uses eMMC but no SPL. Make sure that Tezi
flashes the u-boot.imx binary to the location where the boot
loader expects the image.
Use OpenEmbedded standard variables such as PV and DATE as much
as possible. This allows to reuse the Tezi image class for non-
Toradex images with their own versioning scheme.
In IMAGE_CMD_teziimg(), if a dtb file has more than one dot the
current logic fails. e.g. device.tree.dtb will be truncated at the
first dot to device.
Fix by removing awk in favour of letting basename also remove
the .dtb extension.
Introducing Backports.
Update tezi to use ext4 by default for emmc.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Pull later xfsprogs 4.11.0 from meta-filesystems required by snapd from
meta-snappy:
http://cgit.openembedded.org/meta-openembedded/commit/meta-filesystems/recipes-utils/xfsprogs?id=d53546b7cb38e0dfea6f458859f7f477065daa43
This already incorporates the following fix as reported by our
customer:
https://patchwork.openembedded.org/patch/141247/
Reported-by: Carlos Silvestre Herrera Trujillo <carlos.herrera.trujillo@gmail.com>
https://github.com/morphis/meta-snappy/commit/f6df6a63756d9976bcccb5fefdbc64e5cc794c99
The Toradex product ID from the config block is decimal coded
ASCII with leading zeros. In C and bash, leading zeros means octal
number... This leads to wrong calculation of the USB product ID
and to errors if the product ID contains the number 8 or 9 (since
those are not valid under the octal numeric system).
Fix both issues by explicitly force decimal system for the Toradex
product ID.
Toradex CSI 5MP OV5640 camera module uses two GPIOs for power
and reset control, exporting them here leads to failure of OV5640 driver.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The volumes for kernel, device tree and Cortex-M4 firmware get
updated with a single binary for which a static volume is better
suited. This also allows the boot code to only load the amount of
written bytes and therefore speeds up boot time. Static volumes
have been used already with the update.sh script based update
method.
Raw NAND images flash the kernel and device tree directly into
UBI volumes, hence there is no need to generate a bootfs tarball.
Leave the kernel and device tree unpacked so we can copy it
directly into the UBI volume.
Add support for raw NAND devices. Describe the layout of the
MTD partitions and UBI volumes using JSON. Also split the
storage description into a separate function, called depending
on a machine specific variable for eMMC and raw NAND.
The default (empty) prepare/wrapup scripts will be used which is
fine since there is no need for special scripting on Colibri iMX7
currently.
Configure the read_ahead cache size to optimal value, for the
mmcblk devices (eMMC and SD card).
The cache values are module specific, tests were run on the pre-built
image (BSP V2.7 Beta 1). The measurement of read speed for a range of
cache sizes (16kB to 256MB) was made using hdparm -t.
Signed-off-by: Leonardo Graboski Veiga <leogveiga@gmail.com>
0123456789012345678901234567890123456789012345678901234567890123456789
These variables are used to mark the BSP version in U-Boot, the Linux
kernel and the final image.
Note that some can be overridden from the shell environment, e.g.:
export BB_ENV_EXTRAWHITE="$BB_ENV_EXTRAWHITE TDX_VERNIGHTLY"
export TDX_VERNIGHTLY="-nightly"
While at it clean-up and unify with other Toradex layers.
Prevents a warning when not building for one of the machines which have a g1.schema
| WARNING: ...libusbgx/libusbgx_git.bb: Unable to get checksum for libusbgx SRC_URI entry g1.schema: file could not be found
In case teziimg is not among the requested images (not part of
IMAGE_FSTYPES) we don't need to create a Toradex Easy Installer
image.json file.
