The changes include:
- Introduce tezi_deploy_files helper function, it could be used to
install files listed in IMAGE_BOOT_FILES, the install logic is same
with how WIC handle IMAGE_BOOT_FILES.
- Use WKS_FILE_DEPENDS to handle the dependencies of do_image_teziimg
and do_image_teziimg_distro, when USING_WIC is not set, then we need
add WKS_FILE_DEPENDS to DEPENDS, or else it would be done in wic
image bbclass.
- Drop TEZI_KERNEL_IMAGETYPE and TEZI_KERNEL_DEVICETREE, now all the
boot files would be controlled by IMAGE_BOOT_FILES.
- Use ${IMAGE_LINK_NAME} instead of ${IMAGE_NAME}, to avoid including
DATETIME for torizon builds.
Patch has been verified on the following machines, the artifacts
generated with and wihtout the patch are identical:
- apalis-imx6
- apalis-imx8
- apalis-tk1
- apalis-tk1-mainline
- colibri-imx6
- colibri-imx6ull
- colibri-imx7
- colibri-imx8x
Signed-off-by: Ming Liu <ming.liu@toradex.com>
- Inherit nopackages since it does not generate any non-empty packages.
- Drop do_compile, we can run mkimage directly in do_deploy task.
- Drop 'S = "${WORKDIR}"', we do not have to explicitly set it, the
default S would be good enough.
- Do not install DEPLOYDIR, that is not necessary, it's already done
in deploy.bbclass.
- Do not set noexec flag to do_install, do_populate_sysroot, they are
basically empty tasks, making do_populate_sysroot noexec also will
cause QA warning when u-boot-distro-boot is set to DEPENDS in other
recipes.
The i.MX8 kernel is currently 20MB and doesn't fit in the hard coded 16MB
boot partition size.
Set the boot partition size dynamically to twice the payload size
rounded up to the next power of 2, but at least to 16MB.
The Apalis iMX8 needs additional firmware for HDMI in the boot partition.
Provide a new MACHINE_BOOT_FILES variable which adds to the list of to be
installed files.
With thud I still see "basehash value changed" errors, even though the
commit e74158b6c is available in the OE thud branch.
This reverts commit 9f84ffa4b42b4d518191116614aef269ab227f0e.
This creates a distro boot script boot.scr and deploys it into
the ${DEPLOYDIR}.
Moved here from meta-toradex-torizon u-boot-distro-boot-ostree.
(cherry picked from commit 8109e0a87240489e6bc698e79f2cc748cbe40b17)
(cherry picked from commit 95e057e986e782e85c7ed37e61d27ff389ea4239)
(cherry picked from commit d02ed084d1c4a13e77898affc1b48beabef956f4)
(cherry picked from commit 5bf79f8880f4193bd9c7fd490a25c90383aa0514)
Backports based on 4.19 kernel.
(cherry picked from commit 78e1cdabe0baeb794945bd4926c28058f9f12aa9)
(cherry picked from commit 5d59a8eddb01c439281970496529e0e9a3d6f493)
(cherry picked from commit 56829b6d643fa5dfdac42c0adddf5d41e7fb982e)
(cherry picked from commit 85f6a85b8a8cc400a6f4e201ff5c5cbc43ac1d85)
Add the product name at compile time so that we do not need to provide
slightly different copies of the file.
While at it set package arch to machine arch. The packages created are
machine specific due to the g1.schema file.
(cherry picked from commit 3fa96f28bb30643cac3b8a49d3abd7c976acb704)
(cherry picked from commit 88fbe7232ef49a4564de97c0e676a66577986f43)
We decided we won't do a BSP 3.0 for Vybrid.
For new designs we recommend ULL now.
(cherry picked from commit 0f57f7913867e70ec691eaf31d4a74dd0becb0d4)
This machine hasn't been used nor updated in years.
The SoM's are discontinued by now.
Drop it.
The default setting is now done in the distro.
Check whether argument two is given before passing it to basename.
This avoids build failure when building without deploying device
trees in the bootfs (e.g. TorizonCore).
Aarch64 typically stores device trees in subdirectories, e.g.
freescale/fsl-imx8qm-apalis.dtb. However, the kernel-devicetree.bbclass
deploys those files without subdirectory. Make sure the Tezi image class
behaves like the kernel-devicetree.bbclass.
There are quite a few common code being shared by rootfs_tezi_rawnand
and rootfs_tezi_distro_rawnand, we should merge them to a same function
to avoid being redundant.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
We have generic prepare.sh and wrapup.sh scripts hence tezi-metadata
is buildable and useable for any machine.
Replace hard-coded tar.xz by TEZI_ROOT_SUFFIX since the rootfs image
suffix is being controlled by that variable.
We currently have some tricky code intended to get rid of the
"basehash value changed" errors, but they are actually not needed.
Since the references to "DATE" only exist in image tasks or their
prefuncs, so they would be expanded at task executing time but not
recipe parsing time, a 'vardepsexclude' flag would be enough in this
case.
I guess the reason we introduced this piece of code was that we
found we still could see the annoying "basehash value changed" errors
with 'vardepsexclude' flag set at that moment, but that's probably was
not caused by our code, it's actually another issue now had been fixed
in OE by e74158b6cc1d683ab14ef5d47ec531f986fc2259:
[ rm_work: sort the value of do_build dependencies ]
We can safely drop these useless code per my test.
Since oe-core commit 3150253898ba ("systemd-conf: simplify
creation of machine-specific configuration") systemd-conf no
longer unpacks the systemd sources. Hence the patch which patches
units/systemd-udevd.service.in does no longer apply.
Apply the patch in the systemd recipe instead.
The systemd-udevd.service file is only deployed in a package
built from the systemd recipe anyway, hence this also makes sure
that the patched file gets actually deployed.
This essentially reverts commit 118f6b1b17b6 ("systemd: follow
recipe split which added systemd-conf").
Including u-boot-toradex-initial-env.inc will generate a uEnv.txt
for newer U-Boot versions using U-Boot's u-boot-initial-env
Makfile target. It essential does what u-boot-toradex-env.inc did
before.
Note: Since there is now support for an exported environment in
upstream U-Boot, we should upstream the OE logic to the official
U-Boot too.
Upstream has changes in the context lines.
The patch is not obsolete AFAIKT.
i.e. the configuration file should NOT make mounts by udevd private or
other processes will not be able to see the mount.
This reverts commit 3640a12c85df4ac180e38f19038072df6b1d6d55.
That patch has been merged to systemd-conf.
Or else the changes for systemd-conf recipe will be missed.
The systemd configuration has been split from the systemd recipe.
Thus we need to move our changes to the systemd configuration.
While at it drop the kmod packageconfig. This was only needed with angstrom.
These machines use an old Nvidia provided downstream kernel 3.1.10. They no
longer much the way more recent sysroot components, e.g. libc, xserver et. al.
The maintance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
With the removal of angstrom we can drop this workaround.
Drop bootfs_get_size since it has a obvious flaw, it's being called in
both do_image_teziimg and do_image_teziimg_distro but the boot files of
these two tasks are different.
Drop rootfs_get_size, it's trying to get the size of IMAGE_ROOTFS
directory, but in some cases, that is not correct, for instance, when
TEZI_ROOT_SUFFIX is 'ota.tar.gz', the rootfs directory should be
OTA_SYSROOT rather than IMAGE_ROOTFS.
Introduce get_uncompressed_size function, it reads the image size from
a image-size file in ${T} directory, and that image size is written into
this file by the image functions when they making the tarballs.
Also split the duplicated bootfs tarball creating code to a common
function create_bootfs, and it must run as a prefuncs before
rootfs_tezi_run_json and rootfs_tezi_run_distro_json, this ensures the
image size has been written to the file when the later functions run.
[use _append for tar commands]
Search made with the following regex: getVar ?\((.*), True\), this is
to be consistent with OE.
This is follows the fix upstream in oe-core commit 7c552996:
[ meta: remove True option to getVar calls ]
In some cases kernel and device tree may be a part of rootfs and in this
case we do not want to install anything related to kernel or device
tree.
Use TEZI_KERNEL_IMAGETYPE = "" to exclude kernel
Use TEZI_KERNEL_DEVICETREE = "" to exclude device tree
Signed-off-by: Luka Pivk <luka.pivk@toradex.com>
It's redundant to inherit image_types bbclass, it's already done in
image.bbclass.
A main package being empty without setting ALLOW_EMPTY can lead to
errors in populate_sdk task. If it does not provide any packages then
we should let it inherit nopackages bbclass.
Before the latest changes eMMC was considered the default flash
type and therefor not specified for all machines. Make sure that
image_type_tezi.bbclass is backward compatible by setting
TORADEX_FLASH_TYPE to "emmc" by default.
Implement a separate teziimg class which support distro boot. This
image format uses a layout which allows distro boot on block devices
as well as raw NAND devices. It also support multi flash type images
by creating two image.json files for each flash type. It requires
machine specific meta data e.g.:
TORADEX_PRODUCT_IDS = "0032 0033 0039 0041"
TORADEX_PRODUCT_IDS[0032] = "imx7s-colibri-eval-v3.dtb,rawnand"
TORADEX_PRODUCT_IDS[0033] = "imx7d-colibri-eval-v3.dtb,rawnand"
TORADEX_PRODUCT_IDS[0039] = "imx7d-colibri-emmc-eval-v3.dtb,emmc"
TORADEX_PRODUCT_IDS[0041] = "imx7d-colibri-eval-v3.dtb,rawnand"
TORADEX_FLASH_TYPE = "rawnand emmc"
UBOOT_BINARY_TEZI_EMMC = "u-boot.imx-sd"
UBOOT_BINARY_TEZI_RAWNAND = "u-boot.imx-nd"
UBOOT_ENV_TEZI_EMMC = "uEnv-sd.txt"
UBOOT_ENV_TEZI_RAWNAND = "uEnv-nd.txt"
Prefer the $() syntax, it is POSIX and allows nesting.
Allow to use a different U-Boot binary/environment file per
flash type. This prepares for a multi flash type image.
Add variables to customize which rootfs image type we use in
the Toradex Easy Installer image. Also allow custom root
filesystem label.
This prepares support for images with multiple flash types.
The whole tarball is built as part of the the teziimg CMD.
Break tar commands for better readability. No functional change.
Create a separate function to calculate bootfs size. This allows
to reuse bootfs size calculation for distro boot.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Now that OpenEmbedded core does not prefix dtb files names with
the type of the kernel image, we can get rid of our intermediate
KERNEL_DEVICETREE_FILES variable. Also the tar transformation
which removed kernel type prefix is no longer necessary.
This starts a service which inserts kernel modules on boot.
Updates in meta-angstrom removed this default packageconfig.
