2021-04-14linux-toradex-mainline: update to pre device tree rework for tezithud-nextthudMarcel Ziswiler
For the Toradex Easy Installer update to the last git hash before the device tree resp. overlay re-work of late. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-12-01linux-toradex-mainline: lock next to pre device tree reworkMarcel Ziswiler
Lock use-head-next to the last git hash before the device tree resp. overlay re-work of late. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-10-31backports: update to latestMax Krummenacher
2020-10-31linux-toradex-mainline: update to latestMax Krummenacher
2020-05-14linux-toradex-mainline: update to latestMarcel Ziswiler
2020-04-20linux-toradex-mainline: colibri-imx6ull: defconfig: add nand supportVerdin-iMX8MM_Console-Image_3.0b4.254-20200421Colibri-iMX8X_Console-Image_3.0b4.254-20200421Colibri-iMX7_Console-Image_3.0b4.254-20200421Colibri-iMX7-eMMC_Console-Image_3.0b4.254-20200421Colibri-iMX6_Console-Image_3.0b4.254-20200421Colibri-iMX6ULL_Console-Image_3.0b4.254-20200421Apalis-iMX8_Console-Image_3.0b4.254-20200421Apalis-iMX8X_Console-Image_3.0b4.254-20200421Apalis-iMX6_Console-Image_3.0b4.254-20200421Apalis-TK1_Console-Image_3.0b4.254-20200421Apalis-TK1-Mainline_Console-Image_3.0b4.254-20200421Marcel Ziswiler
NAND support may help (;-p). Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-04-20linux-toradex-mainline-rt-4.19: cleanup defconfigsMax Krummenacher
Both colibri-imx7 use the same defconfig, however we do not have a common mx7 override so provide it for each machine. Add a apalis-tk1-mainline defconfig using the 4.19.59 tegra_defconfig with enabled CONFIG_PREEMPT_RT_FULL. Add a default defconfig, use the 4.19.59 arm64 defconfig with enabled CONFIG_PREEMPT_RT_FULL. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 60f4dbc77be23abfe2995f9f2bd448694157d020)
2020-04-20linux-toradex-mainline-5.4: cleanup defconfigsMax Krummenacher
Both colibri-imx7 use the same defconfig, only provide it once. Add a apalis-tk1-mainline defconfig using the 5.4.6 tegra_defconfig. Add a default defconfig, use the 5.4.6 arm64 defconfig. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit f9d7fe8962838dbb8a166f8ec991b397fde28a5f) (cherry picked from commit 47bba89a6a09dc0e353cabb343b04f9322f7e3c2)
2020-04-20README: rework for thud branchesMax Krummenacher
2020-04-16backports: use backported only wireless driversOleksandr Suvorov
Using the only backported versions of mwifiex, cfg80211 and lib80211 allows to avoid several sporadical bugs about wrong dependencies from built-in modules to backports modules and vice versa. Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-16tezi-metadata: add new slidesMarcel Ziswiler
Related-to: ELB-2686 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-04-15backports: fix loading rtl8188eu for apalis-imx8Oleksandr Suvorov
With common depmod config file, the backported rtl8188eu driver tries to load for Realtek 8188EU USB devices. On the other hand, on-module Wi-Fi chip loads built-in mwifiex_pcie driver. This driver uses cfg80211 built-in module. Backported rtl8188eu driver can't use built-in cfg80211 module, so, to allow using Realtek 8188EU USB device with Colibri iMX8QXP module, the built-in rtl8188eu driver should be used. With this patch the specific depmod config file deploys on the image for Apalis iMX8QM. Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-15backports: fix loading rtl8188eu for colibri-imx8xOleksandr Suvorov
With common depmod config file, the backported rtl8188eu driver tries to load for Realtek 8188EU USB devices. On the other hand, on-module Wi-Fi chip loads built-in mwifiex_pcie driver. This driver uses cfg80211 built-in module. Backported rtl8188eu driver can't use built-in cfg80211 module, so to allow using Realtek 8188EU USB device with Colibri iMX8QXP module, the built-in rtl8188eu driver should be used. With this patch the specific depmod config file deploys on the image for Colibri iMX8QXP. Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-14depmodwrapper: add config directory optionOleksandr Suvorov
Backports recipe deploys the custom config file for depmod. Use it in depmodwrapper to generate modules dependencies properly. Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-14backports: fix pre- and post- scriptsOleksandr Suvorov
Deploying depmod.conf file makes almost all manipulations in postinst and postrm scripts useless. Clean up these scripts. Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-14backports: deploy depmod config fileOleksandr Suvorov
Only backported drivers should depend on backported common modules. Deploying the 99-backports.conf file allows depmod to build modules.dep dependancies file properly. Related-to: ELB-2687 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-10backports: update to latestMarcel Ziswiler
2020-04-09tezi-metadata: add new slidesMarcel Ziswiler
2020-04-09linux-toradex-mainline: update to latestMarcel Ziswiler
2020-04-07hostapd: revert rename distro_features_check to features_checkMarcel Ziswiler
This fixes the following build failure: ++ bitbake console-tdx-image Parsing recipes...ERROR: ParseError at /workdir/oe/build/../layers/meta-toradex-bsp-common/recipes-connectivity/hostapd/hostapd_2.9.bb:22: Could not inherit file classes/features_check.bbclass Summary: There was 1 ERROR message shown, returning a non-zero exit code. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-04-06hostapd: update hostapd to 2.9Oleksandr Suvorov
Update hostapd to version 2.9 to sync with wpa_supplicant 2.9. Related-to: ELB-2677 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-04backports: fix building for -rt kernelsOleksandr Suvorov
Generic and RT-kernels use diffierent package names. Add dependancy on virtual name kernel package fixes build issue for RT-kernels. Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-03backports: fix building for arm64 aka aarch64Marcel Ziswiler
Related-to: ELB-2388 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2020-04-01backports: upgrade from 4.19 to 5.4Oleksandr Suvorov
backports-5.4 provides latter drivers. The main issue that fixes with these backports: the earlier mwifiex drivers for Marvel 8997 WiFi module stucks on firmware crash (ELB-2596). Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-01wpa-supplicant: upgrade to version 2.9Oleksandr Suvorov
The version 2.9 works more stable with Marvel WiFi solutions. Related-to: ELB-2388 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-04-01linux-toradex-mainline: update to 5.4.28Marcel Ziswiler
2020-03-18hostname: generate a uniqe hostname on bootLuka Pivk
This will generate a hostname based on machine name and serial number. (E.g. colibri-imx7-031111777) If serial number is not found it will say "no-serial-number" in host name. If machine is not supported hostname will include "unsupported-device" string. If /dev/device-tree does not exist it will say "recovery-mode" as it assumes its in recovery mode of Toradex Easy Installer To prevent openembedded from creating /etc/hostname file add hostname_pn-base-files = "" to configration Related-to: TEI-100, ELB-1322 Signed-off-by: Luka Pivk <luka.pivk@toradex.com>
2020-03-17recipes-core: Add udev-toradex-rules recipePhilippe Schenker
These rules make sure that a symlink is created for all i2c and tty devices. This symlinks are named like on the Toradex carrier boards. This makes it easy to identify which device in software is matching the hardware pins. Additional non-standard devices that are not named clearly on the carrier board are left out to prevent confusion. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-03-11linux-toradex-mainline: update to 5.4.18 and add use-head-nextMax Krummenacher
While at it, add the use-head-next override which builds head instead of the pinned version. This is useful for integration work. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-03-02image: make sure u-boot enviroment is erasedLuka Pivk
Make sure u-boot enviroment is erased when installing new Toradex Easy Installer image Related-to: TEI-130 Signed-off-by: Luka Pivk <luka.pivk@toradex.com>
2020-01-12linux-toradex-mainline: fix version and update to latestMarcel Ziswiler
Fix Linux version to really represent 5.4.6. Update to latest which includes the following two commits: e87dbbae2576: ARM: dts: imx7: Fix Toradex Colibri iMX7S 256MB NAND flash support 575bd2d69a82: arm64: dts: freescale: add initial support for colibri imx8x Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-12-31linux-toradex-mainline: bump to Linux 5.4.6Verdin-iMX8MM_Console-Image_3.0b3.118-20200101Colibri-iMX8X_Console-Image_3.0b3.118-20200101Colibri-iMX7_Console-Image_3.0b3.118-20200101Colibri-iMX7-eMMC_Console-Image_3.0b3.118-20200101Colibri-iMX6_Console-Image_3.0b3.118-20200101Colibri-iMX6ULL_Console-Image_3.0b3.118-20200101Apalis-iMX8_Console-Image_3.0b3.118-20200101Apalis-iMX8X_Console-Image_3.0b3.118-20191231Apalis-iMX6_Console-Image_3.0b3.118-20191231Apalis-TK1_Console-Image_3.0b3.118-20191231Apalis-TK1-Mainline_Console-Image_3.0b3.118-20200101Marcel Ziswiler
Bump to latest LTS release Linux 5.4.6 plus Apalis T30/TK1 patches. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-12-20linux-toradex-mainline: remove stale Linux 5.2 recipeMarcel Ziswiler
2019-12-20linux-toradex-mainline: bump to Linux 5.4.5Marcel Ziswiler
Bump to latest LTS release Linux 5.4.5. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 2d635349eff45166feb4340c3008fd2a12f354cf)
2019-12-20linux-toradex-mainline: bump to Linux 5.4Stefan Agner
Bump to latest LTS release Linux 5.4.2. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> (cherry picked from commit 6e96e4c828b853edefbc9107680efa38c143c7f6) Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-12-04image_type_tezi.bbclass: refactor bootfs image functionMing Liu
This patch mainlay aims to refactor bootfs image function, use tar and xz conversion functions to replace our own create_tezi_bootfs, the benifit would be we could choose other compression type like Zstandard easily by setting TEZI_BOOT_SUFFIX and TEZI_ROOT_SUFFIX for bootfs and rootfs. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-12-03image_type_tezi.bbclass: fix some appendVarMing Liu
The blank should be before the value rather than after it, or else we risk on messing up the values by 'a b' > 'ab'. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-12-02u-boot-distro-boot: do not reuse bootcmd variableStefan Agner
The bootcmd variable is the entry point for regular boot. If booting fails for some reason and one saves the environment at this point, the next boot will no longer use distro boot. Often booting works since the boot script setup all variables correctly, so one does not notice that the boot flow has been altered/hard-coded. Do not reuse bootcmd to avoid accidentally alter the boot flow. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> (cherry picked from commit 98dbc9f5c52616618cbf722965ce2f5dd90409db)
2019-12-02image_type_tezi.bbclass: change logic on spl deploymentMax Krummenacher
Use OFFSET_SPL_PAYLOAD to decide if a SPL has to be deployed or not. This allows a simple integration of machines which have an SPL (as e.g. verdin-imx8mm has) but do aggregate the SPL and U-Boot proper into one binary. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-11-30image_type_tezi.bbclass: refacture/unify u-boot artefactsMax Krummenacher
The list of deployed U-Boot artefacts is set in python for the 'distro' tezi-image, but in the non 'distro' case directly in the tar command. Unify that to put the list together in python. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-11-27u-boot-distro-boot: fix serial console bootarg passingMarcel Ziswiler
2019-11-21Revert "systemd: bbappend: Remove systemd-rfkill from systemd"Philippe Schenker
The problem was within connman that constantly disables RF. So this commit is not needed. This reverts commit a64ff768b7d5d24360a1ac9bec67409f0daa931d.
2019-11-20systemd: bbappend: Remove systemd-rfkill from systemdPhilippe Schenker
systemd-rfkill disables by default our RF devices. We do not want them to be disabled at all so remove that rfkill from systemd. Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2019-10-14linux-toradex-mainline: set package version to full Linux versionStefan Agner
Set the package version to reflect the complete Linux kernel version plus the git hash it has been built from. This could be done in the inc file only once, however, the Yocto kernel recipes set PV in the individual recipies as well. The close proximity to LINUX_VERSION also makes it obvious what PV will be. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2019-10-03image_type_tezi: fix empty distro flavourMax Krummenacher
If DISTRO_FLAVOUR is not set, then the string '${DISTRO_FLAVOUR}' is appended. Fix this by providing a weak default. Fixes commit 3d072f3077b6. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-10-01image_type_tezi: add distro flavour to image summaryMax Krummenacher
So that one sees in the Toradex Easy Installer which image is which. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-09-07image_type_tezi.bbclass: set RM_WORK_EXCLUDEMing Liu
The image recipes do not really support rm_work, I have observed a lot of build issues when I modified some do_image tasks while do_rootfs not touched, to give a example: The stack trace of python calls that resulted in this exception/failure was: File: 'exec_python_func() autogenerated', lineno: 2, function: <module> 0001: *** 0002:buildinfo(d) 0003: File: 'meta/classes/image-buildinfo.bbclass', lineno: 67, function: buildinfo 0063:# Write build information to target filesystem 0064:python buildinfo () { 0065: if not d.getVar('IMAGE_BUILDINFO_FILE'): 0066: return *** 0067: with open(d.expand('${IMAGE_ROOTFS}${IMAGE_BUILDINFO_FILE}'), 'w') as build: 0068: build.writelines(( 0069: '''----------------------- 0070:Build Configuration: | 0071:----------------------- so we set RM_WORK_EXCLUDE to avoid running into those problems. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-09-07image_type_tezi.bbclass: fix basehash changed issueMing Liu
This patch mainly aims to reintroduce a old commit 1b5ef0c9: [ image_type_tezi.bbclass: drop some useless code ] which was reverted later on since it did not fix the problem, I refactor that patch to really fix it. I have observed this "basehash changed" issue quite often recently, it could be reproduced easily by the following steps: 1 bitbake imagename 2 change your system time by one day ahead. 3 bitbake imagename After debugging it with bitbake-diffsigs, I found it's still caused by 'DATE' variable changing, as follows: | basehash changed from ecb5b34a4997e7f037f146932728f3eca9af34d70729e4c83cdd920dc21d7677 to | 92ad5341f99ff3a56987f4ccdc34030d5aa3e3ea1365737b5a81a12e6eb83798 | Variable DATE value changed from '20190905' to '20190906' our tricky fix of introducing 'TDX_VERDATE' does not really work, actually it makes things worse, 'DATE' has been deleted when parsing IMAGE_CMD_* tasks, which was introduced by commit 4af13a48 in OE: [ image.bbclass: delete DATE variable too ] which means DATE would not be expanded during recipe parsing, but TDX_VERDATE would, so we should replace TDX_VERDATE with DATE in IMAGE_CMD_teziimg and IMAGE_CMD_teziimg-distro tasks. To fix this annoying issue, the key point is we should avoid expanding 'DATE' during recipe parsing stage, or else the vardepsexclude would not take effect since the 'DATE' has already been expanded, so we should change a DATE reference in rootfs_tezi_json function: d.getVar('DATE') -> d.getVar('DATE', False) And there is seems still some order issue when bitbake handle vardepsexclude of IMAGE_CMD_* tasks, I have to explicitly set it for do_image_teziimg and do_image_teziimg_distro. With the above changes, the error does not show up again. Signed-off-by: Ming Liu <ming.liu@toradex.com>
2019-08-29image_type_tezi.bbclass: fix image.json for rawnand devicesColibri-iMX8X_Console-Image_3.0b2.65-20190830Colibri-iMX7_Console-Image_3.0b2.65-20190830Colibri-iMX6_Console-Image_3.0b2.65-20190830Colibri-iMX6ULL_Console-Image_3.0b2.65-20190830Apalis-iMX8_Console-Image_3.0b2.65-20190830Apalis-iMX6_Console-Image_3.0b2.65-20190830Apalis-TK1_Console-Image_3.0b2.65-20190830Apalis-TK1-Mainline_Console-Image_3.0b2.65-20190830Max Krummenacher
The TEZI_KERNEL_IMAGETYPE definition has been removed, however it is still used in the code. Change that to use KERNEL_IMAGETYPE. The results in image.json containing '"zImage"' instead of 'null' as the kernel filename. Fixes c1891e02dc9c. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-08-26u-boot-distro-boot: add support for detecting UUID of rootfsIgor Opaniuk
Provide proper PARTUUID value in bootargs. Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
