Use OpenEmbedded standard variables such as PV and DATE as much
as possible. This allows to reuse the Tezi image class for non-
Toradex images with their own versioning scheme.
In IMAGE_CMD_teziimg(), if a dtb file has more than one dot the
current logic fails. e.g. device.tree.dtb will be truncated at the
first dot to device.
Fix by removing awk in favour of letting basename also remove
the .dtb extension.
Update tezi to use ext4 by default for emmc.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The volumes for kernel, device tree and Cortex-M4 firmware get
updated with a single binary for which a static volume is better
suited. This also allows the boot code to only load the amount of
written bytes and therefore speeds up boot time. Static volumes
have been used already with the update.sh script based update
method.
Raw NAND images flash the kernel and device tree directly into
UBI volumes, hence there is no need to generate a bootfs tarball.
Leave the kernel and device tree unpacked so we can copy it
directly into the UBI volume.
Add support for raw NAND devices. Describe the layout of the
MTD partitions and UBI volumes using JSON. Also split the
storage description into a separate function, called depending
on a machine specific variable for eMMC and raw NAND.
In case teziimg is not among the requested images (not part of
IMAGE_FSTYPES) we don't need to create a Toradex Easy Installer
image.json file.
Avoid ambiguity with other uses of the string "tezi", e.g. when used
as an image or distro name.
The Toradex Easy Installer is a Linux based installer for images. This
commit adds a new image type which allows to build images flashable with
this installer directly with OpenEmbedded.
The installer needs a JSON based image description (image.json) which will
be generated using a custom Python step. The IMAGE_CMD step then creates
a bootfs tar.xz and creates a tar with the bootfs, rootfs, U-Boot and SPL,
image.json and some more metadata files. This tarball can be extracted
on a SD card, USB flah drive or HTTP server and consumed by the Toradex
Easy Installer.
remove the files copied from meta-fsl* for Colibri-VF V2.1
move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
remove when moving to dora branch
