Add missing space in front of DEPENDS_append in order to avoid issues
caused by further appending.
Since kernel module packages are generated dynamically, the dependency
resolution fails when one requests a specific package which is
generated at build time. Use PACKAGES_DYNAMIC to tell the build system
that backport-kernel-module-* packages can be considered available.
This reverts commit e6641b0a6f93ebf752534b283d0dfb0c2c656ec2.
add coreutils native to depends
in do_configure:
| /bin/bash: line 28: seq: command not found
resulting in do_compile failing:
| In file included from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/ieee80211_i.h:35:0,
| from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/status.c:17:
| /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/sta_info.h:460:21: error: field 'hash_node' has incom
| struct rhlist_head hash_node;
Don't use HEAD of branch for every build.
That way we get more reproduciable builds and the git fetcher will not access
the network on every build to check what the current HEAD actually is.
Use KERNEL_VERSION variable instad of running
make kernelversion
Introducing Backports.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Update defconfig and kernel version to latest version from git. This
also configures the USB Gadget ConfigFS as a module. Add the ConfigFS
module to the list of autoloaded modules.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
Use a fixed revision of the MCC kernel module which makes sure it
builds with the corresponding Vybrid Linux kernel, which also uses
a fixed git hash.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
This removes the 3.0.15 based Kernel for Colibri VFxx.
Since some time now we use a more recent Kernel provided from the
linux-toradex-vf_3.18.bb recipe.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
Add Atemsys Linux kernel module which enables to run the EtherCAT
Master stack from userspace.
Update to top of -next branch which also includes FEC unbind
fixes.
Also update default defconfig for colibri-vf.
Two last minute fixes: Default Product/Vendor ID for USB peripheral
in U-Boot and fix for the USB peripheral RNDIS freeze.
In order to make the MCC kernel module working with our newer kernel
some changes had been made on the MCC kernel module. The changes
are available on the Toradex Github account. Get the MCC kernel
module sources from Github.
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
