Use KERNEL_VERSION variable instad of running
make kernelversion
Introducing Backports.
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Update to latest revision which fixes Colibri iMX6D not powerering off but
creating a stacktrace.
We have this recipe in meta-fsl-arm-extra.
Convert it to a bbappend and only keep the changes to the bb files.
Add LOCALVERSION and generate a scmversion file to annotate the
Kernel with the Toradex release and a git hash.
Since we use USB Gadget ConfigFS now use libusbg to load the
USB Gadget configuration automatically.
Update defconfig and kernel version to latest version from git. This
also configures the USB Gadget ConfigFS as a module. Add the ConfigFS
module to the list of autoloaded modules.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
SCSI lock device disk support is required for USB mass storage to
work. Also enable asynchronous SCSI scanning by default.
Use a fixed revision of the MCC kernel module which makes sure it
builds with the corresponding Vybrid Linux kernel, which also uses
a fixed git hash.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
This removes the 3.0.15 based Kernel for Colibri VFxx.
Since some time now we use a more recent Kernel provided from the
linux-toradex-vf_3.18.bb recipe.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
Add Atemsys Linux kernel module which enables to run the EtherCAT
Master stack from userspace.
Update to top of -next branch which also includes FEC unbind
fixes.
Also update default defconfig for colibri-vf.
Two last minute fixes: Default Product/Vendor ID for USB peripheral
in U-Boot and fix for the USB peripheral RNDIS freeze.
In order to make the MCC kernel module working with our newer kernel
some changes had been made on the MCC kernel module. The changes
are available on the Toradex Github account. Get the MCC kernel
module sources from Github.
Switch default kernel recipe to linux-toradex-vf which will build
a kernel based on the toradex 3.18-next branch.
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
Add recipe to build mainline kernel. Currently, the 3.17 next branch will
be built. To use this kernel, add this lines to your local.conf
PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex"
IMAGE_INSTALL_append = "kernel-devicetree"
KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb"
Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong
and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc
since the required kernel interfaces are not available on the 3.17 mainline
port.
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus
code changes for Apalis iMX6.
deleted: recipes-bsp/libmcc/libmcc_1.04.bb
deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb
deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb
This commit switches Colibri VF machine back to use the colibri_vf
branch and use the latest Linux kernel.
The include files (such as linux.inc) are not resolved by priority
but on layer order instead. This can lead to build errors in case
the layers in BBLAYERS are ordered differently.
