Bump SRCREV hashes as used in build of Thu Jul 15 22:53:20 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 364
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/364
Signed-off-by: ci.toradex <cicd@toradex.com>
(cherry picked from commit 9f07b468d6cecb6fcda469866c305d37fb20f230)
Change versions, source path to the rt patch, SRCREV and checksums
to bump the mainline kernel to the 5.4.129 stable version.
Related-to: ELB-4007
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit 69377c5ada04dc63d4abcefab37bf6e833a3c8f3)
Move the content of the bbappend to meta-toradex-nxp, recipe
linux-toradex_5.4-2.3.x.bb. That it were it belongs and through
that we no longer interfere with the meta-freescale-3rdparty
linux-toradex recipes which cannot cope with "-@" DTC parameter.
(cherry picked from commit da87dc976fb48ead79355089047cbc8b71f66918)
(cherry picked from commit d6164c573eee25fce9366e2af9e365e2401ed7f8)
Bump SRCREV hashes as used in build of Thu Jun 24 23:53:00 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 343
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/343
(cherry picked from commit 869312de75c9187e02523ff2cfa806144ace949f)
Bump SRCREV hashes as used in build of Fri May 7 22:38:51 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 297
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/297
(cherry picked from commit 2c539036e3421150b29336fc926b2678df589206)
Bump SRCREV hashes as used in build of Mon Apr 19 22:46:50 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 280
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/280
(cherry picked from commit 2c22dbf1b58cdb340ccd44780c44845341191835)
toradex-imx_v6_v7_defconfig now builds RTC drivers not used on Toradex HW
as kernel modules to reduce the zImage size. With that the kernel fits
again also on the raw NAND based modules.
Related-to: ELB-3931
(cherry picked from commit 5234d3b8bc7f1fb6269a350213e93a0f8f66d6aa)
Matrix Build: image-torizoncore-dunfell-5.x.y-nightly-matrix 262
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-dunfell-5.x.y-nightly-matrix/262
(cherry picked from commit ce4387040bbac9598b8232e86d09e2397a9cda28)
The major reason for doing this is because we are currently deploying
all dtbo files to ${DEPLOY_DIR_IMAGE}/devicetree, but not machine
specific ones, and they will be unnecessarily bundled into fitimage
when kernel-fitimage.bbclass is being inherited.
To fix that, we introduce a extra task do_collect_overlays to collect
machine specific overlays to ${DT_FILES_PATH} before do_compile, where
dtb compilation is being compiled in. In this way, only machine
specific overlays would be compiled and deployed.
Related-to: TOR-1700
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 3f3703403ce8451c997faee1eb1f7665bff24437)
squashed with
(cherry picked from commit 80534650f210472afbfd6f5d6d80559c708eb72e)
(cherry picked from commit 6d8f8337ff1bf0200dead6adbc2615556b6495de)
Export DTC_FLAGS instead of passing it to make command by EXTRA_OEMAKE,
this ensures 'make dtbs' in a devshell also get 'DTC_FLAGS=-@' option.
Related-to: ELB-3578
(cherry picked from commit 64737e025826e3dfa85caba4fd9d81638cd227be)
Related-to: ELB-3341
(cherry picked from commit 02ee9a4f47d195a3b47a31b8db439e1b7bb78539)
Bump SRCREV hashes as used in build of Wed Feb 10 22:59:24 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 215
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/215
Bump SRCREV
Bump SRCREV hashes as used in build of Tue Feb 23 21:40:40 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 228
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/228
(cherry picked from commit e74e8590a515a9aaa0b820120cb8640aba2a5351)
Bump SRCREV hashes as used in build of Tue Feb 2 05:36:13 UTC 2021
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 207
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/207
(cherry picked from commit 2b830c7a4aaf39dc7ea971c638b5042290c9ee1e)
This helps people which can't access the web with the git protocol.
Related-to: ELB-3475
(cherry picked from commit 45d29e2645711f617b16809c5edb0ce9e17c58ec)
Bump SRCREV hashes as used in build of Thu Dec 24 23:56:45 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 169
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/169
(cherry picked from commit cdbfe017be9096adbbfb4d3bbea0421e44f54cf3)
Bump SRCREV hashes as used in build of Fri Nov 27 22:22:56 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 143
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/143
(cherry picked from commit cab1ac409fa532c22f64c570f1b5c2350b570f94)
Add usbgadget and libcomposite as autoload modules.
Related-to: ELB-3152
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 9893d9662d5c9f883eaca89227945c13894463c0)
(cherry picked from commit bcd4d7508135db639c7d0fc28416a8d0d4152dce)
(cherry picked from commit f374cadde139f2b6c92d65903ca6c39c67650a67)
Explicitly disable kernel configs that could lead to latency on
preempt-rt kernel.
Also explicitly enable CONFIG_EXPERT which is being depended by
CONFIG_PREEMPT_RT.
Related-to: TOR-1354
(cherry picked from commit 2fb9cca9965e345915488b5693d63c0e137ae3ce)
(cherry picked from commit 8c080afc33399c39e8c11691f8b1339a54231093)
It's being referred nowhere, let's drop it.
Related-to: ELB-3035
(cherry picked from commit 180be762f3945471a54961b3c473f228418cc689)
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 115
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/115
(cherry picked from commit 0470394a5e435ab68c0a242783f937bb9402ba8b)
This is complementary commit of:
[ 09fa0594: linux-toradex-mainline-rt: drop obsolete recipe ]
The main recipe of linux-toradex-mainline-rt-4.19 has been dropped,
drop the defconfigs as well.
Related-to: ELB-2631
(cherry picked from commit 3d1731f91dcff78bdbd0abcb978436d25280b8f1)
Completes commit 48ea0df ("linux-firmware: drop bbappend").
The package split for sd8997 has been upstreamed to openembedded-core.
openembedded-core provides now a rtl8188 package which contains the
firmware for rtl8188 and rtl8188eu. Use that one.
Change to use the defconfig which is part of the kernel tree. In order
to provide a defconfig from your bbappend add a file 'defconfig' through
SRC_URI which will take precedence.
(cherry picked from commit 0006e2a7616674e768a698123a13caff5c1661ba)
Change to add preempt-rt configs as scc file by including
linux-imx.inc, also avoid setting KERNEL_FEATURES to empty, it could be
used in torizoncore layer.
Related-to: ELB-3171
(cherry picked from commit 6737ce79c453953be6faf02519d9fc920dd58bb9)
Bump SRCREV hashes as used in build of Tue Sep 29 12:07:53 UTC 2020
Matrix Build: image-tdxref-dunfell-5.x.y-nightly-matrix 81
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-dunfell-5.x.y-nightly-matrix/81
(cherry picked from commit 15385a89f3aff2a13f316c26ef23abc7efa19cab)
Add CAN_J1939 as a module. and run savedefconfig.
This is a copy of tegra_defconfig from the kernel sources.
Related-to: ELB-3023
Use the common defconfig from the kernel sources toradex-imx_v6_v7_defconfig.
This increases the kernel size for the so far smallest kernel by about 200k.
We need a file for each machine as we do not have a common override to use
in the use-mainline-bsp case.
This additionally adds CAN_J1939 as a kernel module.
Add the accidently dropped file reference name so the checksums
are found.
fixes 9b13de4 ("linux-toradex-mainline: update to latest")
(cherry picked from commit cf3aca30b171672fe011b404d0c12378b7c79f5d)
Enable GPIO and serial-port (CD-signal) sources for
the PPS (pulse-per-second) module.
Related-to: ELB-2837
(cherry picked from commit b736ab934b1067d032c1ac61bb753a8039222096)
This fixes a following compilation error when compiling zImage:
| /bin/sh: lzop: command not found
The firmware for Marvell 8997 using SDIO as the interface is also
available from the regular linux-firmware repo, although with an
other filename.
Use that one and provide a symlink to cope with the old name.
(cherry picked from commit 5c82f9ec57e0676de240acaa40b78ce4d3cd2181)
(cherry picked from commit 14ccfef1cb6334ca165cae84173476cb6d961383)
This driver is also applicable to the ADV7280 e.g. as found on our
Analogue Camera Adapter V2.0B.
(cherry picked from commit 441c2eec6c7b59331642395e5d962540b214aaae)
With the addition of preempt-rt support using the 5.4 mainline based
kernel tree the 4.19 mainline based preempt-rt kernel tree can be
considered obsolete. Drop the recipe.
(cherry picked from commit 5f773cd50f387c92f9511c173cb08a8af8263075)
There is a dead code in the linux-toradex-mainline.inc,
that doesn't really install dtb files into the final image.
Remove this code add add the option to compile dtb files
with symbols in the proper place.
Related-to: ELB-2797
(cherry picked from commit e0beff9f048259b24b147b21f49c1463ebd70511)
Add WiFi drivers useful for the Gumstix AutoBSP as kernel modules.
Related-to: TOR-1068
(cherry picked from commit a84d18c541f5525e7821c389fb41339be8c702c2)
Symbols are required for overlay dtbo files to resolve external links.
Related-to: ELB-1316
(cherry picked from commit 9818a0bac82a8059668ab9062deac69c8fae9c56)
Create a seperate recipe for each kernel flavour and move the recipe
into the same directory as the kernel recipe.
This allows to have a better control over which machine needs which
device-tree-overlays. E.g. apalis-tk1 does not make use of the NXP
use-mainline-bsp facility.
(cherry picked from commit 5b3099862584aff19af6bdc28e8ce87043b92210)
(cherry picked from commit 32aeba91e07c0f3ed043e3b7e9714eba7fa429d7)
(cherry picked from commit 4ec7f0934fc019ab5f98a7e7bc21fca645ee6b83)
The downstream kernel gets to old to be used with the new zeus
userspace components. Reuse the apalis-tk1 machine name to build
a mainline kernel and drop the apalis-tk1-mainline machine.
Related-to: ELB-2733
(cherry picked from commit bd9bbe90a379468c60f689c99c3940bfb4a4181d)
