This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0.
The patch is now part of meta-openembedded jethro branch.
The star syntax currently includes imx_usb.conf to be stripped. We
only deploy imx_usb (no .m32 variant), hence getting rid of the star
should be save.
The latest GTK2 version is 0.5.4, which contains several bug fixes.
Noteable, it fixes an issue where the SVG keys have not been displayed
with recent versions of its dependencies.
Note: This adds GStreamer 0.10 dependency...
update.sh guesses the module type from rootfs/etc/issue which works for images
created from our meta-toradex recipes.
If another rootfs is used one has to edit etc/issue.
Overcome that requirement by providing a -m parameter which allows forcing
the targeted module type.
Not giving -m or '-m 0' keeps the old behaviour.
see 'update.sh -h' for valid values.
Create a static UBI volume to store the Cortex-M4 firmware. Use
0xE0000 which makes the three static volumes exactly 9MiB.
Eliminate the following warning:
cp: warning: source file ‘colibri-imx6_bin/u-boot.imx’ specified more than once
To be more in-line with all our other modules change update_dtb to
update_fdt also on all our NAND based modules and document it as such.
U-Boot delivered with V2.6 Alpha1 does not have SoC type detection
which can be used to load the device tree (imx7s/imx7d). Flash
U-Boot first and reset to make sure we use the new U-Boot to flash
the rest of the components.
The later corrected the commit message.
Write kernel and device tree into seperate UBI Volumes. This
allows to use a lot less UBI/UBIFS support in U-Boot, which
should lower the risk of hitting bugs in this area.
The binary/symlink mkfs.vfat seems to be considered outdated, it
is only deployed if one configures dosfstools with the flag
--enable-compat-symlinks.
Switch to mkfs.fat which seems to be the official binary to create
FAT filesystems now.
Use static UBI volumes on Colibri T20.
Fix update over ethernet on Colibri Vybrid
Add exit trap to report unexpected exits (due to set -e). Note that
this traps every exit, also explicit calls to exit. Therefor register
the trap only during the sequencial image generating/coping part,
after the sanity checks...
If executing the command fails, the exit code will be <> 1 which
leads to an imeadiate exit (due to set -e). Avoid exiting by
adding "|| true" to the sanity check commands.
Use "command" instead of "which" for sanity checks. This is preferable
to several reasons, see:
http://stackoverflow.com/questions/592620/check-if-a-program-exists-from-a-bash-script
Also always use or (||) syntax to avoid bash script exits. Tested to
be working on Ubuntu, Fedora and Arch Linux.
By omitting an explicit exit code after the recovery command we
will get the exit code of the last command. This makes sense,
since we would be able to tell whether recovery actually succeeded
or not.
Since we introduced set -e commands which fail will exit silently.
This leads to no error message when the grep which tests for
specified parameters failed.
We could solve it with || true, but it seems more lightweight to
just test for the strings inside the if statement. It also checks
for the full length (e.g. disallows "25" as RAM size).
The later fixed only 256 MB RAM size copy paste issue.
Unix commands usually exit successfully when help was explicitly
asked for. However, in case arguments are incomplete or otherwise
wrong, exit with error.
printf allows to print escape sequences (e.g. for colored output)
and is part of the POSIX standard.
There are issues with running it with the mesa EGL component.
Adjusted update scripts for fast boot mode migration as per the
following article on our developer website:
http://developer.toradex.com/knowledge-base/linux-booting#eMMC_Fast_Boot_Mode_ApalisColibri_iMX6
pcman-fm and gtk RRECOMMEND adwaita.
Do not install them and keep the lxde-icon-theme
On the tegras we have to stay with gstreamer 0.10.
We want to append to the generic VAR when we build for a tegra machine.
Using VAR_tegra += "" creates a machine specific VAR.
Use Stefan's patch until it is available from the meta-openembedded jethro branch.
http://cgit.openembedded.org/meta-openembedded/commit/?h=master-next&id=bf8f27af3954ab68e39712516ab515de90b4db27
Add a .desktop file to get a start menu entry for the webkitgtk
browser MiniBrowser.
Currently _tkinter is only built when tcl/tk is available before the
python do_configure task is built.
Make this deterministic by providing a PACKAGECONFIG for it.
If tkinter is in PACKAGECONFIG add the needed dependencies,
if not force that tkinter is not built.
Note that currently enabling tkinter does not work due to a cyclic
dependency:
'python' depends on 'tk/tcl' depends on 'cracklib' depends on 'python'
The Linux Kernel 4.4 for Colibri VF does currently not support the needed
interfaces for mcc.
meta-angstrom unconditionally includes stuff from meta-qt5.
