All of meta-toradex-tegra contains now all needed for TK1.
Drop meta-jetson-tk1.
Without gphoto libusb is otherwise not available and configure fails.
meta-oe now provides libpwquality. Drop the recipe here.
The backports recipe does not yet work with the kernel used for
apalis-imx8 and colibri-imx8qxp.
gstreamer1.0-libav needs commercial licenses to be whitelisted,
thus only install it when this is allowed through configuration.
E.g. add
LICENSE_FLAGS_WHITELIST = "commercial_gstreamer1.0-libav" to local.conf
to allow installing libav.
The backports configuration does not match the kernel used.
Angstrom sets this in the distro configuration, poky does not.
So enable it in local.conf to get the usefull debug aid build/buildhistroy.
These machines use an old Nvidia provided downstream kernel 3.1.10.
They are no longer compatible with more recent sysroot components,
e.g. libc, xserver et. al.
The maintenance burden to keep the userspace components in their old version
becomes simply to high. Keep using the rocko based 2.8 BSP for these machines.
Thus we keep the openembedded defconfig with changes due to version updates
or changed system policies.
The defconfig's only change is CONFIG_RESIZE when compared to the upstream
defconfig around the time of the fork:
http://cgit.openembedded.org/openembedded-core/plain/meta/recipes-core/busybox/busybox/defconfig?h=dizzy&id=ad1a50a549377a0a74c51e20e53f146011e6c269
This reverts commit 9e6dbea0a9590c87d1b6ca0bd20b561eaa1307cf.
openembedded-core commit 544ade2d78f1375d9e93d6bf5842d857ddaf3530 dropped
the RRECOMMENDS setting, so this is no longer needed.
meta-openembedded no longer builds with samba in PACKAGE_CONFIG. Thus drop
removing it here.
This adds a new recipe tdx-updater which provides the files needed by
tdx-image-fstype.inc rather than copying them in a non OE way in
tdx-image-fstype.inc.
This required to restructure the layout in files. An additional update
directory is inserted. Also in each of the overrides directories a
symlink to library is created.
This now allows to build legacy update images with a custom machine
configuration if one adds the relevant machine override, e.g. for a
machine targeting a colibri-imx6 module:
MACHINEOVERRIDES .= ":colibri-imx6"
The U-Boot fw-utils recipe was moved to meta-freescale. While moving
the recipe name was renamed, follow that.
These warnings were triggered by a bug in meta-angstrom.
Reenable the warnings again.
firefox now needs meta-rust.
This reverts commit aa265d1c86597e479629734145b638b51117ef02.
Upstream updated the recipe no longer uses the patchfile.
qtwebkit bb no longer supports the use of gstreamer 0.10 packageconfig.
Also it looks like qtwebkit itself no longer picks up a 0.10 installation.
qt3d picks up the configured flavours of OpenGL from qtbase.
So add them to DEPENDS or one gets linker errors.
OE-core dropped to prefix the device tree files with the kernel image type.
Follow that.
While at it drop the empty ${DEPLOY_DIR_IMAGE} path element which sneaked in
through copy/paste.
With commit 7193a7f1f meta-qt5 removed qtquick1.
upstream added an ontarget postinst routine rather than postinst returning
not 0 for code which should run on target.
The upstream systemd recipe now uses meson to build systemd. Follow the
changed config syntax.
The changes have been added upstream.
This reverts commit d568bc40cabdb27fb1948206b8d2f3f911f6e252.
wireless-regdb version 2018.05.31 was failing when
populating the SDK.
Use wireless-regdb version 2018.05.31.
WARNING: No recipes available for:
layers/meta-toradex-demos/recipes-support/icu/icu_57%.bbappend
layers/meta-toradex-demos/recipes-support/opencv/opencv_2.4.bbappend
How can one even live without util-linux-lsblk? Let's add it.
Tezi now shows the image description more prominently. Update the standard
image descriptions using DESCRIPTION.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Revert once 8382cdc0888ca645a44aacaac1155afb8dcde979 and
77c353cc9bdfbf1b6453b2579b72726db05eb69c are backported to rocko.
This reverts commit 4ade18dd772a72a4ca8d58df8ef82d67948a65c7.
bbappend does no longer apply as OE-core updated the version and with it also
pulled in the needed fix to allow using thumb2.
